[GRASS-SVN] r51196 - grass/branches/develbranch_6/include/Make
svn_grass at osgeo.org
Fri Mar 30 08:10:25 EDT 2012
Author: martinl
Date: 2012-03-30 05:10:25 -0700 (Fri, 30 Mar 2012)
New Revision: 51196
grass/branches/develbranch_6/include/Make/Doxyfile_arch_html.in
grass/branches/develbranch_6/include/Make/Doxyfile_arch_latex.in
doxygen: backport conf files from trunk (ignore ctypes)
Modified: grass/branches/develbranch_6/include/Make/Doxyfile_arch_html.in
--- grass/branches/develbranch_6/include/Make/Doxyfile_arch_html.in 2012-03-30 12:00:07 UTC (rev 51195)
+++ grass/branches/develbranch_6/include/Make/Doxyfile_arch_html.in 2012-03-30 12:10:25 UTC (rev 51196)
@@ -23,7 +23,7 @@
# This could be handy for archiving the generated documentation or
# if some version control system is used.
-PROJECT_NUMBER = @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@ (@GRASS_VERSION_DATE@)
+PROJECT_NUMBER = @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@ (@GRASS_VERSION_DATE@) - r at GRASS_VERSION_SVN@
# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
# base path where the generated documentation will be put.
@@ -456,10 +456,23 @@
dist. at ARCH@ \
doc \
general \
- gui/wxpython/vdigit \
- gui/wxpython/nviz \
+ gui/scripts \
+ gui/wxpython/compat \
+ gui/wxpython/icons \
+ gui/wxpython/scripts \
+ gui/wxpython/tools \
imagery \
+ include \
+ lib/btree/test \
+ lib/db/dbmi_base/test \
+ lib/db/sqlp/test \
+ lib/gmath/test \
+ lib/gpde/test \
+ lib/linkm/test \
+ lib/g3d/test \
lib/python/ctypes \
+ lib/vector/dglib/examples \
+ lib/vector/rtree/docs \
locale \
macosx \
man \
Modified: grass/branches/develbranch_6/include/Make/Doxyfile_arch_latex.in
--- grass/branches/develbranch_6/include/Make/Doxyfile_arch_latex.in 2012-03-30 12:00:07 UTC (rev 51195)
+++ grass/branches/develbranch_6/include/Make/Doxyfile_arch_latex.in 2012-03-30 12:10:25 UTC (rev 51196)
@@ -17,13 +17,13 @@
# The PROJECT_NAME tag is a single word (or a sequence of words surrounded
# by quotes) that should identify the project.
-PROJECT_NAME = GRASS
+PROJECT_NAME = "GRASS Programmer's Manual"
# The PROJECT_NUMBER tag can be used to enter a project or revision number.
@@ -434,7 +434,7 @@
FILE_PATTERNS = *.h \
*.c \
- *.i \
+ *.i \
*.py \
*.dox
@@ -456,11 +456,23 @@
dist. at ARCH@ \
doc \
general \
+ gui/scripts \
imagery \
include \
+ lib/btree/test \
+ lib/gmath/test \
+ lib/gpde/test \
+ lib/linkm/test \
+ lib/g3d/test \
lib/python/ctypes \
locale \
macosx \
man \
@@ -512,7 +524,7 @@
# directories that contain image that are included in the documentation (see
# the \image command).
-IMAGE_PATH =
+IMAGE_PATH = .
# The INPUT_FILTER tag can be used to specify a program that doxygen should
# invoke to filter for each input file. Doxygen will invoke the filter program
@@ -615,7 +627,7 @@
# If a relative path is entered the value of OUTPUT_DIRECTORY will be
# put in front of it. If left blank `html' will be used as the default path.
-HTML_OUTPUT =
+HTML_OUTPUT =
# The HTML_FILE_EXTENSION tag can be used to specify the file extension for
# each generated HTML page (for example: .htm,.php,.asp). If it is left blank
