[GRASS-SVN] r51200 - grass/branches/releasebranch_6_4/include/Make
    svn_grass at osgeo.org
    Fri Mar 30 10:37:13 EDT 2012
Author: martinl
Date: 2012-03-30 07:37:13 -0700 (Fri, 30 Mar 2012)
New Revision: 51200
   grass/branches/releasebranch_6_4/include/Make/Doxyfile_arch_html.in
   grass/branches/releasebranch_6_4/include/Make/Doxyfile_arch_latex.in
wxGUI: backport conf doxyfiles from devbr6
Modified: grass/branches/releasebranch_6_4/include/Make/Doxyfile_arch_html.in
--- grass/branches/releasebranch_6_4/include/Make/Doxyfile_arch_html.in	2012-03-30 13:48:58 UTC (rev 51199)
+++ grass/branches/releasebranch_6_4/include/Make/Doxyfile_arch_html.in	2012-03-30 14:37:13 UTC (rev 51200)
@@ -23,7 +23,7 @@
 # This could be handy for archiving the generated documentation or
 # if some version control system is used.
-PROJECT_NUMBER         = @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@ (@GRASS_VERSION_DATE@)
+PROJECT_NUMBER         = @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@ (@GRASS_VERSION_DATE@) - r at GRASS_VERSION_SVN@
 # The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
 # base path where the generated documentation will be put.
@@ -456,11 +456,23 @@
 			 dist. at ARCH@ \
 			 doc \
 			 general \
-		         gui/wxpython/vdigit \
-			 gui/wxpython/nviz \
+			 gui/scripts \
+		         gui/wxpython/compat \
+			 gui/wxpython/icons \
+			 gui/wxpython/scripts \
+			 gui/wxpython/tools \
 			 imagery \
 			 include \
+			 lib/btree/test \
+			 lib/db/dbmi_base/test \
+			 lib/db/sqlp/test \
+			 lib/gmath/test \
+			 lib/gpde/test \
+			 lib/linkm/test \
+			 lib/g3d/test \
                          lib/python/ctypes \
+			 lib/vector/dglib/examples \
+			 lib/vector/rtree/docs \
 			 locale \
 			 macosx \
 			 man \
Modified: grass/branches/releasebranch_6_4/include/Make/Doxyfile_arch_latex.in
--- grass/branches/releasebranch_6_4/include/Make/Doxyfile_arch_latex.in	2012-03-30 13:48:58 UTC (rev 51199)
+++ grass/branches/releasebranch_6_4/include/Make/Doxyfile_arch_latex.in	2012-03-30 14:37:13 UTC (rev 51200)
@@ -17,13 +17,13 @@
 # The PROJECT_NAME tag is a single word (or a sequence of words surrounded
 # by quotes) that should identify the project.
-PROJECT_NAME           = GRASS
+PROJECT_NAME           = "GRASS Programmer's Manual"
 # The PROJECT_NUMBER tag can be used to enter a project or revision number.
@@ -434,7 +434,7 @@
 FILE_PATTERNS          = *.h \
                          *.c \
-                         *.i \
+			 *.i \
                          *.py \
                          *.dox
 			 dist. at ARCH@ \
 			 doc \
 			 general \
+			 gui/scripts \
 			 imagery \
 			 include \
+			 lib/btree/test \
+			 lib/gmath/test \
+			 lib/gpde/test \
+			 lib/linkm/test \
+			 lib/g3d/test \
                          lib/python/ctypes \
 			 locale \
 			 macosx \
 			 man \
@@ -512,7 +524,7 @@
 # directories that contain image that are included in the documentation (see
 # the \image command).
-IMAGE_PATH             =
+IMAGE_PATH             = .
 # The INPUT_FILTER tag can be used to specify a program that doxygen should
 # invoke to filter for each input file. Doxygen will invoke the filter program
@@ -615,7 +627,7 @@
 # If a relative path is entered the value of OUTPUT_DIRECTORY will be
 # put in front of it. If left blank `html' will be used as the default path.
-HTML_OUTPUT            =
+HTML_OUTPUT            =
 # The HTML_FILE_EXTENSION tag can be used to specify the file extension for
 # each generated HTML page (for example: .htm,.php,.asp). If it is left blank
@@ -706,7 +718,7 @@
 # Netscape 6.0+, Internet explorer 5.0+, or Konqueror). Windows users are
 # probably better off using the HTML help feature.
-GENERATE_TREEVIEW      = NO
+GENERATE_TREEVIEW      = YES
 # If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
 # used to set the initial width (in pixels) of the frame in which the tree
@@ -727,7 +739,7 @@
 # put in front of it. If left blank `latex' will be used as the default path.
-LATEX_OUTPUT           =
+LATEX_OUTPUT           = latex
 # The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
 # invoked. If left blank `latex' will be used as the default command name.
@@ -744,7 +756,7 @@
 # LaTeX documents. This may be useful for small projects and may help to
 # save some trees in general.
-COMPACT_LATEX          = YES
+COMPACT_LATEX          = NO
 # The PAPER_TYPE tag can be used to set the paper type that is used
 # by the printer. Possible values are: a4, a4wide, letter, legal and
@@ -769,20 +781,20 @@
 # contain links (just like the HTML output) instead of page references
 # This makes the output suitable for online browsing using a pdf viewer.
-PDF_HYPERLINKS         = YES
+PDF_HYPERLINKS         = NO
 # If the USE_PDFLATEX tag is set to YES, pdflatex will be used instead of
 # plain latex in the generated Makefile. Set this option to YES to get a
 # higher quality PDF documentation.
-USE_PDFLATEX           = YES
+USE_PDFLATEX           = NO
 # If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \\batchmode.
 # command to the generated LaTeX files. This will instruct LaTeX to keep
 # running if errors occur, instead of asking the user for help.
 # This option is also used when generating formulas in HTML.
-LATEX_BATCHMODE        = YES
+LATEX_BATCHMODE        = NO
 # If LATEX_HIDE_INDICES is set to YES then doxygen will not
 # include the index chapters (such as File Index, Compound Index, etc.)
@@ -1189,4 +1201,4 @@
 # The SEARCHENGINE tag specifies whether or not a search engine should be
 # used. If set to NO the values of all tags below this one will be ignored.
-SEARCHENGINE           = NO
+SEARCHENGINE           = YES
