[GRASS-SVN] r51206 - grass/trunk/raster/r.in.arc
svn_grass at osgeo.org
Fri Mar 30 13:24:58 EDT 2012
Author: martinl
Date: 2012-03-30 10:24:58 -0700 (Fri, 30 Mar 2012)
New Revision: 51206
grass/trunk/raster/r.in.arc/main.c
r.in.arc: use standard options (input)
Modified: grass/trunk/raster/r.in.arc/main.c
--- grass/trunk/raster/r.in.arc/main.c 2012-03-30 17:18:11 UTC (rev 51205)
+++ grass/trunk/raster/r.in.arc/main.c 2012-03-30 17:24:58 UTC (rev 51206)
@@ -62,14 +62,10 @@
module->description =
_("Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map.");
- parm.input = G_define_option();
- parm.input->key = "input";
- parm.input->type = TYPE_STRING;
- parm.input->required = YES;
+ parm.input = G_define_standard_option(G_OPT_F_INPUT);
parm.input->description =
- _("ARC/INFO ASCII raster file (GRID) to be imported");
- parm.input->gisprompt = "old_file,file,input";
+ _("Name of ARC/INFO ASCII raster file (GRID) to be imported");
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
parm.type = G_define_option();
@@ -98,7 +94,8 @@
exit(EXIT_FAILURE);
input = parm.input->answer;
output = parm.output->answer;
- if (title = parm.title->answer)
+ title = parm.title->answer;
+ if (title)
G_strip(title);
sscanf(parm.mult->answer, "%lf", &mult_fact);
