[GRASS-SVN] r51211 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Fri Mar 30 18:56:54 EDT 2012
Author: neteler
Date: 2012-03-30 15:56:54 -0700 (Fri, 30 Mar 2012)
New Revision: 51211
grass/branches/releasebranch_6_4/locale/po/grasslibs_ar.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_cs.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_de.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_el.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_es.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_fr.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_hi.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_it.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_ja.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_ko.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_lv.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_ml.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_mr.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_pl.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_pt.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_pt_br.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_ru.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_sl.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_th.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_tr.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_vi.po
grass/branches/releasebranch_6_4/locale/po/grasslibs_zh.po
fix typo
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_ar.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_ar.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_ar.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3555,7 +3555,7 @@
#: ../lib/gis/parser.c:637
#, fuzzy
-msgid "Name to input file"
+msgid "Name of input file"
msgstr "اسÙ
اÙÙ
Ù٠اÙÙ
ÙØªÙØ %s\n"
#: ../lib/gis/parser.c:645
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_cs.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_cs.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_cs.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3578,7 +3578,7 @@
#, fuzzy
msgstr "Název vstupního souboru %s"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_de.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_de.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_de.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3426,7 +3426,7 @@
msgstr "Objekt-IDs"
msgstr "Name der Eingabedatei"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_el.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_el.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_el.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3609,7 +3609,7 @@
#, fuzzy
msgstr "¼íïìá áñ÷åßïõ åéóáãùãÞò"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_es.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_es.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_es.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3769,7 +3769,7 @@
#, fuzzy
msgstr "Ruta del archivo de entrada."
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_fr.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_fr.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3502,7 +3502,7 @@
#, fuzzy
msgstr "Nom du fichier en entrée"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_hi.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_hi.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_hi.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3587,7 +3587,7 @@
#, fuzzy
msgstr "à¤à¤¾"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_it.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_it.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_it.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3606,7 +3606,7 @@
msgstr "Id delle feature"
msgstr "Percorso al file di input"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_ja.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_ja.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_ja.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3425,7 +3425,7 @@
msgstr "ãã£ã¼ã㣠ids"
msgstr "å
¥åãããã¡ã¤ã«å"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_ko.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_ko.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_ko.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3478,7 +3478,7 @@
#, fuzzy
msgstr "ìë MASKíì¼ì ì´ ì ììµëë¤"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_lv.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_lv.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_lv.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3576,7 +3576,7 @@
#, fuzzy
msgstr "AtvÄrtÄ faila nosaukums %s"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_ml.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_ml.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_ml.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3427,7 +3427,7 @@
#, fuzzy
msgstr "ഫയൽ à´¤àµà´±à´àµà´àµ» പറàµà´±àµà´¨àµà´¨à´¿à´²àµà´² %s"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_mr.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_mr.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_mr.po 2012-03-30 22:56:54 UTC (rev 51211)
#, fuzzy
msgstr "à¤à¤à¤¡à¤²à¥à¤²à¥à¤¯à¤¾ फाà¤à¤²à¤à¥ नाव %s\n"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_pl.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_pl.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3586,7 +3586,7 @@
msgstr "ID obiektów"
msgstr "Åcieżka do pliku wejÅciowego"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_pt.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_pt.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_pt.po 2012-03-30 22:56:54 UTC (rev 51211)
#, fuzzy
msgstr "Nome do arquivo de entrada"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_pt_br.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_pt_br.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_pt_br.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3567,7 +3567,7 @@
#, fuzzy
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_ru.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_ru.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_ru.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3585,7 +3585,7 @@
#, fuzzy
msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного Ñайла"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_sl.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_sl.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_sl.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3584,7 +3584,7 @@
#, fuzzy
msgstr "Ime odprte datoteke %s\n"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_th.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_th.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_th.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3597,7 +3597,7 @@
#, fuzzy
msgstr "à¸à¸·à¹à¸à¹à¸à¸¥à¹à¸à¸µà¹à¸à¸°à¸à¸³à¹à¸à¹à¸²"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_tr.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_tr.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_tr.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3463,7 +3463,7 @@
#, fuzzy
msgstr "Girdi dosyasının adı"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_vi.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_vi.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_vi.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3571,7 +3571,7 @@
#, fuzzy
msgstr "Tên cá»§a táºp tin Äầu và o"
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_zh.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_zh.po 2012-03-30 22:53:59 UTC (rev 51210)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_zh.po 2012-03-30 22:56:54 UTC (rev 51211)
@@ -3640,7 +3640,7 @@
#, fuzzy
msgstr "æå¼æä»¶çåç§° %s"
