[GRASS-SVN] r51216 - in grass-addons/grass6/raster: . r.cva
Sat Mar 31 03:58:03 EDT 2012
Author: amuriy
Date: 2012-03-31 00:58:03 -0700 (Sat, 31 Mar 2012)
New Revision: 51216
Added:
   grass-addons/grass6/raster/r.cva/
   grass-addons/grass6/raster/r.cva/Makefile
   grass-addons/grass6/raster/r.cva/README
   grass-addons/grass6/raster/r.cva/TODO
   grass-addons/grass6/raster/r.cva/authors
   grass-addons/grass6/raster/r.cva/bugs
   grass-addons/grass6/raster/r.cva/config.h
   grass-addons/grass6/raster/r.cva/count_visible_cells.c
   grass-addons/grass6/raster/r.cva/count_visible_cells.h
   grass-addons/grass6/raster/r.cva/cumulate_visible_cells.c
   grass-addons/grass6/raster/r.cva/cumulate_visible_cells.h
   grass-addons/grass6/raster/r.cva/delete3.c
   grass-addons/grass6/raster/r.cva/delete_lists.c
   grass-addons/grass6/raster/r.cva/delete_lists.h
   grass-addons/grass6/raster/r.cva/delete_one_list.c
   grass-addons/grass6/raster/r.cva/description
   grass-addons/grass6/raster/r.cva/description.html
   grass-addons/grass6/raster/r.cva/global_vars.h
   grass-addons/grass6/raster/r.cva/init_segment_file.c
   grass-addons/grass6/raster/r.cva/init_segment_file.h
   grass-addons/grass6/raster/r.cva/line_of_sight.c
   grass-addons/grass6/raster/r.cva/line_of_sight.h
   grass-addons/grass6/raster/r.cva/main.c
   grass-addons/grass6/raster/r.cva/make_list3.c
   grass-addons/grass6/raster/r.cva/make_point3.c
   grass-addons/grass6/raster/r.cva/point.h
   grass-addons/grass6/raster/r.cva/point_sample.c
   grass-addons/grass6/raster/r.cva/point_sample.h
   grass-addons/grass6/raster/r.cva/pts_elim3.c
   grass-addons/grass6/raster/r.cva/pts_elim3.h
   grass-addons/grass6/raster/r.cva/r.cva.tmp.html
   grass-addons/grass6/raster/r.cva/radians.h
   grass-addons/grass6/raster/r.cva/random_int.c
   grass-addons/grass6/raster/r.cva/random_sample.c
   grass-addons/grass6/raster/r.cva/random_sample.h
   grass-addons/grass6/raster/r.cva/scan_all_cells.c
   grass-addons/grass6/raster/r.cva/scan_all_cells.h
   grass-addons/grass6/raster/r.cva/segment3.c
   grass-addons/grass6/raster/r.cva/segment3.h
   grass-addons/grass6/raster/r.cva/segment_file.c
   grass-addons/grass6/raster/r.cva/segment_file.h
   grass-addons/grass6/raster/r.cva/systematic_sample.c
   grass-addons/grass6/raster/r.cva/systematic_sample.h
   grass-addons/grass6/raster/r.cva/version
   grass-addons/grass6/raster/r.cva/zufall.c
   grass-addons/grass6/raster/r.cva/zufall.h
   grass-addons/grass6/raster/r.cva/zufalli.c
   grass-addons/grass6/raster/Makefile
<r.cva> added to grass6/raster; grass6/raster/Makefile edited
Modified: grass-addons/grass6/raster/Makefile
--- grass-addons/grass6/raster/Makefile	2012-03-30 23:00:09 UTC (rev 51215)
+++ grass-addons/grass6/raster/Makefile	2012-03-31 07:58:03 UTC (rev 51216)
@@ -1,31 +1,53 @@
 MODULE_TOPDIR = ..
-# r.convert
-# r.roughness
 SUBDIRS = \
 	LandDyn \
 	mcda \
+	r.area \
+	r.basin	\
 	r.boxcount \
 	r.boxcount.sh \
 	r.burn.frict \
 	r.clim \
+	r.clump2 \
+	r.colors.out_sld \
+	r.colors.out_vtk \
 	r.colors.quantiles \
+	r.colors.tools \
+	r.convergence \
+	r.convert \
+	r.csr \
+	r.cva \
 	r.denoise \
+        r.diversity \
+	r.flip \
+	r.fuzzy \
+	r.fuzzy.logic \
+	r.fuzzy.system \
 	r.game_of_life \
+	r.hazard.flood \
+	r.in.swisstopo \
 	r.inund.fluv \
 	r.in.xyz.auto \
 	r.ipso \
 	r.isoregions \
+	r.maxent.lambdas \
 	r.out.gmap \
 	r.out.gmt \
 	r.out.gmt2 \
-	r.out.kml \
+	r.out.kap_template \
+	r.out.kml \
+	r.out.maxent_swd \
 	r.out.netcdf \
 	r.pack \
 	r.pi \
 	r.prominence \
 	r.rast4d \
+	r.roughness \
+	r.seg \
 	r.soils.texture \
+	r.stack \
+	r.stream.angle \
 	r.stream.basins \
 	r.stream.del \
 	r.stream.distance \
@@ -37,11 +59,14 @@
 	r.surf.volcano \
 	r.terracost \
 	r.terraflow.tools \
-	r.univar2.zonal \
+	r.threshold \
+	r.univar.zonal \
+	r.unpack \
 	r.viewshed \
 	r.wf \
-	r.xtent
+	r.xtent
 include $(MODULE_TOPDIR)/include/Make/Dir.make
 default: htmldir
Added: grass-addons/grass6/raster/r.cva/Makefile
--- grass-addons/grass6/raster/r.cva/Makefile	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/Makefile	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,15 @@
+MODULE_TOPDIR = ../..
+PGM = r.cva
+LIBES = $(GISLIB) $(DATETIMELIB) $(SEGMENTLIB) $(VECTLIB) $(DBMILIB) $(RASTERLIB)
+DEPENDENCIES = $(RASTERDEP) $(VECTDEP) $(DBMIDEP) $(GISDEP)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+EXTRA_INC = $(VECT_INC)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass6/raster/r.cva/README
--- grass-addons/grass6/raster/r.cva/README	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/README	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,2 @@
+This is a GRASS 6 extension that contains additional functionality
+for cumulative viewshed analysis.
Added: grass-addons/grass6/raster/r.cva/TODO
--- grass-addons/grass6/raster/r.cva/TODO	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/TODO	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,121 @@
+HAS THE PATCH FOR r.los BEEN APPLIED IN GRASS 6.1 CVS (DOES IT DO ANYTHING IN r.los, anyway?)
+BUGS:
+	dist=sqrt(del_x * del_x + del_y * del_y)*window.ns_res;
+	in pts_elim3.c seems to indicate, that this module always
+	assumes N/S res to be = E/W res for distance calculations!
+CHECK:
+	Check that OFFSETB now gives the desired results.
+	(pts_elim3.c)
+	Check that target_elev is really just handled as an alias
+	for OFFSETB (main.c)
+	Check correctness of Earth Curvature Correction
+	point_sample.c: L149: it seems that db_init_string (&sql) is called iteratively
+	in this loop w/o releasing any memory resulting in a mem leak
+PARAMS:
+	the default operation should NOT be reflex viewsheds!
+	Some of the parameters are redundant (obs height, tgt height)
+	or should at least be more clearly named (e.g.: "global OFFSET A")
+	make sure the word "sites" disappeards from all titles and parameter names
+	unify writing of all parameter names: capitalise first word, NO period at end
+	- parameters must be declared GRASS 6.0.0 style, so that the right
+	 selector buttons will be provided!
+DOCS:
+	HTML man page for r.prominence
+	state, that missing values are not allowed in site parameters!
+	A separate section to clarify:
+	clarify NULL handling:	discarded in systematic samples
+				not valid in random samples
+				discarded in site sampling
+				discarded in total sampling
+				achieved sample size discounts NULL cells
+				what does the "convert -1 to NULL" option do?
+				state that NULL cells do not count for
+				  the reflexive viewshed!
+* Store visibility count of sites in an attribute in the input vector map,
+(count case only)
+if attribute with name VCOUNT exists (or create such an attribute).
+Add a "z" factor for height scaling.
+Convenience: user supplies a map of obstructing objects as vector objects
+with a field HEIGHT that gives relative height of object. This is
+rasterised into tmp1 map, the height is added to dem and the result
+output as tmp2 and fed into r.cva instead of the original dem.
+Rename "all" option to "total", as it is less ambiguous. Change default option
+to "sites".
+Implement fuzzy viewsheds that can attribute for unknown variations in terrain
+heights, due to error or vegetation. Add a random offset within a user-defined
+range to observer point,
+target point and all blocking points. Do this n times and the final result
+is the average visibility over all trials.
+Offset size can be determined from error specifications of DEM and
+average height of vegetation (?).
+WE MUST BE ABLE TO MASK OUT CERTAIN AREAS FROM VEGETATION OFFSET, WHICH
+ARE CLEARED AREAS (?).
+Alternative, systematic fuzzy viewsheds:
+The user supplies a set of maps with different configurations of spatial
+obstacles. All of these configurations are taken into account and the final
+result is the average visibility over all configurations (e.g. 4 of 5 times=80%).
+* Implement probabilistic viewsheds: user defines a distance D1, at which objects
+of interest are no longer clearly identifiable from the obersvation Point P and
+distance D2, at which they are no longer observable at all.
+The program computes a corresponding interpolation curve from "1" (P) to "0.5"
+(P+D1) and on to "0" (P+D2). Instead of "0"/"1" viewsheds,
+we can then have a continuous probability. For the cumulative case, we would
+multiply probabilities instead of adding. We can also have functions that
+relate to viewing angles. Secondly, use a visibility map with values in the
+range of 0..1 that encode probability of objects being spotted on a certain
+type of terrain. With these functions, we are moving away from terrain
+visibility and towards hypothetical object visibility.
+This needs a float output map. Two alternatives for the cumulative case:
+directly work on an FCELL map (SLOW, but can link in cache!) or create another
+segment file of FCELL type. Option one should work, as operations are fairly
+localised.
+The terrain adjacent to a viewing location also has a major impact on visibility
+target locations! This can be catered for by adding the height of obstructing
+objects to the terrain.
+Another field has to be added to the linked list of points storing
+its probability in point.h [DONE: probability]
+This probability has to be updated according to the function linking it to
+distance and viewing angle:
+Add a parameter probability to function definition in make_point3.c and
+make_point3.h.
+Add probability calculation function to make_list3.c, at the end, but before
+call to make_point().
+It has also got to be updated using floats in ONE map that encodes visibility
+for e.g. different types of terrain (e.g. green objects are harder to spot
+on grassland than on rock surface).
+For the two (*) above: files cumulate_visible_cells.c (-f option) and
+count_visible_cells.c as a starting point.
+Is the mask option really needed or can the same effect be achieved by setting
+the GRASS global mask?
Added: grass-addons/grass6/raster/r.cva/authors
--- grass-addons/grass6/raster/r.cva/authors	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/authors	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,3 @@
+#comment
+Mark Lake (University College London)<br>
+Benjamin Ducke (University of Kiel, Germany)
Added: grass-addons/grass6/raster/r.cva/bugs
--- grass-addons/grass6/raster/r.cva/bugs	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/bugs	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,6 @@
+# Please describe all known bugs and shortcomings of the current implementation
+# of your extension.
+<strong>r.cva:</strong><br>
+Earth curvature correction has not been sufficiently tested.<br>
+The 'offsetb' option (=target height) has not been sufficiently tested.<br>
+Please feel free to test and report!<br>
Added: grass-addons/grass6/raster/r.cva/config.h
--- grass-addons/grass6/raster/r.cva/config.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/config.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,207 @@
+/* include/config.h.  Generated automatically by configure.  */
+ * config.h.in
+#ifndef _config_h
+#define _config_h
+#define GDEBUG 1
+/* define if standard C headers exist:  headers are
+ * stdlib.h, stdarg.h, string.h, and float.h */
+/* define if curses.h exists */
+/* #undef HAVE_CURSES_H */
+/* define if keypad in lib[n]curses */
+/* #undef HAVE_KEYPAD */
+/* define if limits.h exists */
+#define HAVE_LIMITS_H 1
+/* define if termio.h exists */
+#define HAVE_TERMIO_H 1
+/* define if termios.h exists */
+#define HAVE_TERMIOS_H 1
+/* define if unistd.h exists */
+#define HAVE_UNISTD_H 1
+/* define if values.h exists */
+#define HAVE_VALUES_H 1
+/* define if zlib.h exists */
+#define HAVE_ZLIB_H 1
+/* define if sys/ioctl.h exists */
+#define HAVE_SYS_IOCTL_H 1
+/* define if sys/mtio.h exists */
+#define HAVE_SYS_MTIO_H 1
+/* define if sys/resource.h exists */
+#define HAVE_SYS_RESOURCE_H 1
+/* define if sys/time.h exists */
+#define HAVE_SYS_TIME_H 1
+/* define if time.h and sys/time.h can be included together */
+#define TIME_WITH_SYS_TIME 1
+/* define if sys/timeb.h exists */
+#define HAVE_SYS_TIMEB_H 1
+/* define if sys/types.h exists */
+#define HAVE_SYS_TYPES_H 1
+/* define if sys/utsname.h exists */
+#define HAVE_SYS_UTSNAME_H 1
+/* define if g2c.h exists */
+#define HAVE_G2C_H 1
+/* define if f2c.h exists */
+/* #undef HAVE_F2C_H */
+/* define gid_t type */
+/* #undef gid_t */
+/* define off_t type */
+/* #undef off_t */
+/* define uid_t type */
+/* #undef uid_t */
+/* Define the return type of signal handlers */
+#define RETSIGTYPE void
+/* define curses.h WINDOW structure component */
+#define CURSES_MAXY @CURSES_MAXY@
+/* define if ftime() exists */
+#define HAVE_FTIME 1
+/* define if gethostname() exists */
+#define HAVE_GETHOSTNAME 1
+/* define if gettimeofday() exists */
+#define HAVE_GETTIMEOFDAY 1
+/* define if lseek() exists */
+#define HAVE_LSEEK 1
+/* define if time() exists */
+#define HAVE_TIME 1
+/* define if uname() exists */
+#define HAVE_UNAME 1
+/* define if seteuid() exists */
+#define HAVE_SETEUID 1
+/* define if setpriority() exists */
+#define HAVE_SETPRIORITY 1
+/* define if setreuid() exists */
+#define HAVE_SETREUID 1
+/* define if setruid() exists */
+/* #undef HAVE_SETRUID */
+/* define if setpgrp() takes no argument */
+#define SETPGRP_VOID 1
+/* define if drand48() exists */
+#define HAVE_DRAND48 1
+/* define if postgres is to be used */
+/* #undef HAVE_POSTGRES */
+/* define if OGR is to be used */
+#define HAVE_OGR 1
+/* define if postgres client header exists */
+/* #undef HAVE_LIBPQ_FE_H */
+/* define if PQcmdTuples in lpq */
+/* #undef HAVE_PQCMDTUPLES */
+/* define if ODBC exists */
+/* #undef HAVE_SQL_H */
+/* define if PNG support exists */
+/* #undef HAVE_PNG */
+/* define if jpeglib.h exists */
+/* #undef HAVE_JPEGLIB_H */
+/* define if fftw.h exists */
+/* #undef HAVE_FFTW_H */
+/* define if dfftw.h exists */
+/* #undef HAVE_DFFTW_H */
+/* define if BLAS exists */
+/* #undef HAVE_LIBBLAS */
+/* define if LAPACK exists */
+/* #undef HAVE_LIBLAPACK */
+/* define if dbm.h exists */
+/* #undef HAVE_DBM_H */
+/* define if readline exists */
+/* #undef HAVE_READLINE_READLINE_H */
+/* define if ft2build.h exists */
+/* #undef HAVE_FT2BUILD_H */
+/* Whether or not we are using G_socks for display communications */
+#define USE_G_SOCKS 1
+/* define if X is disabled or unavailable */
+/* #undef X_DISPLAY_MISSING */
+/* define if libintl.h exists */
+#define HAVE_LIBINTL_H 1
+/* define if iconv.h exists */
+#define HAVE_ICONV_H 1
+/* define if NLS requested */
+/* #undef USE_NLS */
+/* define if <GL/GLwMDrawA.h> exists */
+/* #undef HAVE_GL_GLWMDRAWA_H */
+/* define if <X11/GLw/GLwMDrawA.h> exists */
+/* #undef HAVE_X11_GLW_GLWMDRAWA_H */
+/* define if TclTk exists */
+/* #undef HAVE_TCLTK */
+/* define if putenv() exists */
+#define HAVE_PUTENV 1
+/* define if setenv() exists */
+#define HAVE_SETENV 1
+/* define if glXCreatePbuffer exists */
+/* #undef HAVE_PBUFFERS */
+/* define if glXCreateGLXPixmap exists */
+/* #undef HAVE_PIXMAPS */
+ * configuration information solely dependent on the above
+ * nothing below this point should need changing
+#if defined(HAVE_VALUES_H) && !defined(HAVE_LIMITS_H)
+#define INT_MIN -MAXINT
+#endif
+#endif /* _config_h */
Added: grass-addons/grass6/raster/r.cva/count_visible_cells.c
--- grass-addons/grass6/raster/r.cva/count_visible_cells.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/count_visible_cells.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,108 @@
+ *      count_visible_cells.c
+ *      Counts the number of cells visible from the current
+ *      viewpoint, i.e. counts the number of cells on the
+ *      16 segment lists.  Writes the current viewpoint number
+ *      to the temporary segment file after a cell has been
+ *      counted in order prevent cells which occur on more than
+ *      one list from being counted more than once.  Writes the
+ *      number of visible cells to the output segment file
+ *      and updates the minimum and maximum number of visible
+ *      cells.
+/* Written by Mark Lake on 1/3/96 to:-
+ * Updated by Mark Lake on 17/8/01 for GRASS 5.x
+ * 1) Count the number of cells visible from the current
+ *    viewpoint.
+ * Modifications to r.los:-
+ * 1) r.los does not perform this function.
+ * Called by:
+ * 1) scan_all_cells
+ * 2) random_sample
+ * 3) systematic_sample
+ * 4) point_sample
+ * Calls:
+ * 1)  None.
+#include <grass/segment.h>
+#include <grass/gis.h>
+#include "config.h"
+#include "point.h"
+#include "global_vars.h"
+#define NEXT_SEARCH_PT  SEARCH_PT->next
+void count_visible_cells (CELL cell_no, int row_viewpt, int col_viewpt,
+			  SEGMENT *seg_out_1_p, SEGMENT *seg_out_2_p,
+                          SEGMENT *seg_patt_p, struct point *heads[])
+/*     struct point *heads[] is same as "struct point **heads" */
+  int segment_no;
+  char *value_read, *value_to_write;
+  CELL visible_cells;
+  CELL data_read, data_to_write;
+  struct point *SEARCH_PT;
+  int mask;
+  visible_cells = 0;
+  value_read = (char*) &data_read;
+  value_to_write = (char*) &data_to_write;
+  mask = 1;
+  /* Count cells visible from current viewpoint */
+  for (segment_no = 1; segment_no <= 16; segment_no++)
+      data_to_write =  cell_no;
+      SEARCH_PT = heads[segment_no-1];
+      while(SEARCH_PT != NULL)
+	  segment_get (seg_out_1_p, value_read,
+		       row_viewpt - SEARCH_PT->y,
+		       col_viewpt + SEARCH_PT->x);
+	  if (data_read == 0) /*   if not already counted or deleted */
+	      visible_cells++;
+	      /* Write cell_no to temporary segment file to show
+	         that cell has already been counted              */
+		segment_put (seg_out_1_p, value_to_write,
+	  SEARCH_PT = NEXT_SEARCH_PT;
+  /* Include viewpoint itself if it is not a masked destination */
+  if (patt_flag)
+      segment_get (seg_patt_p, value_read, row_viewpt, col_viewpt);
+      mask = (int) data_read;
+      if (mask)
+	visible_cells += 1; /*   include viewpoint */
+  value_to_write = (char*) &visible_cells;
+  segment_put (seg_out_2_p, value_to_write, row_viewpt, col_viewpt);
Added: grass-addons/grass6/raster/r.cva/count_visible_cells.h
--- grass-addons/grass6/raster/r.cva/count_visible_cells.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/count_visible_cells.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,10 @@
+#ifndef __COUNT_VISIBLE_CELLS_H__
+#define __COUNT_VISIBLE_CELLS_H__
+                          SEGMENT *seg_patt_p, struct point *heads[]);
+#endif
Added: grass-addons/grass6/raster/r.cva/cumulate_visible_cells.c
--- grass-addons/grass6/raster/r.cva/cumulate_visible_cells.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/cumulate_visible_cells.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,125 @@
+ *      cumulate_visible_cells.c
+ *      Marks the cells visible from the current viewpoint
+ *      by adding 1 to the values of visible cells on the
+ *      output segment file.  Writes the current viewpoint
+ *      number to the temporary segment file to prevent
+ *      cells which occur on more than one segment list from
+ *      being marked more than once for a given viewpoint.
+ *      The end effect is to produce a map showing from how
+ *      viewpoints a given cell can be seen.  Updates the
+ *      minimum and maximum number of visible cells.
+ * 1) Cumulate the number of visible cells.
+ * Called by:-
+ * Called by:
+ * 4) point_sample
+ * Calls:
+ * 1)  None.
+#include "point.h"
+void cumulate_visible_cells (CELL cell_no,
+                             int row_viewpt, int col_viewpt,
+                             struct point *heads[])
+  int segment_no;
+  int mask;
+  mask = 1;
+  for (segment_no = 1; segment_no <= 16; segment_no++) {
+#ifdef DEBUG
+      printf ("\nCumulate_cells SEARCH_PT = %p", SEARCH_PT);
+      fflush (stdout);
+#endif
+      while(SEARCH_PT != NULL) {
+		/*   if not already counted or deleted */
+	  	if (data_read < cell_no ) {
+	      visible_cells++;
+	      /* Add one to cell on output segment file  */
+	      segment_get (seg_out_2_p, value_read,
+	      if (data_read == background) /* NULL value */
+		    data_read = 0;
+		  data_to_write = data_read + 1;
+  } /* END (iterate through segments */
+  if (patt_flag) {
+  if (mask) {
+      segment_get (seg_out_2_p, value_read, row_viewpt, col_viewpt);
+	    data_read = 0;
Added: grass-addons/grass6/raster/r.cva/cumulate_visible_cells.h
--- grass-addons/grass6/raster/r.cva/cumulate_visible_cells.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/cumulate_visible_cells.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,12 @@
+#ifndef __CUMULATE_VISIBLE_CELLS_H__
+#define __CUMULATE_VISIBLE_CELLS_H__
+                             struct point *heads[]);
+#endif
Added: grass-addons/grass6/raster/r.cva/delete3.c
--- grass-addons/grass6/raster/r.cva/delete3.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/delete3.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,106 @@
+/*	delete3.c	 	                                */
+/*	This function detaches a point data structure from	*/
+/*	the linked list and frees memory allocated for it.	*/
+/* Modified from r.los by MWL on 14/12/95 to:-
+ * 1) Detach a point structure from the linked list.
+ * Version 3.0, differs from v.1.0 as follows:-
+ * 1) Recieves cell_no and writes to segment file at deleted point.
+ *    This ensures that make_point3.c can differentiate between a
+ *    point that has been deleted during the current los analysis,
+ *    and one which was deleted or counted during los
+ *    analysis from a preceeding viewpoint.
+ * Implicated files:-
+ * 1) See main3.c.
+ * 1) Writes cell_no to seg_out_p instead of value 1.
+ * Called by:-
+ * 1) hidden_point_elimination()
+ * Calls:-
+ * 1)  None. */
+#include <stdlib.h>
+#include "point.h"
+#define  PT_TO_DELETE_X		  PT_TO_DELETE->x
+#define  PT_TO_DELETE_Y		  PT_TO_DELETE->y
+#define  PT_NEXT_TO_DELETED	  PT_TO_DELETE->next
+#define  PT_PREVIOUS_TO_DELETED	  PT_TO_DELETE->previous
+#define  NEXT_PT_BACK_PTR	  PT_TO_DELETE->next->previous
+#define	 PREVIOUS_PT_NEXT_PTR     PT_TO_DELETE->previous->next
+struct point *delete(struct point *PT_TO_DELETE, struct point *head,
+                     SEGMENT *seg_out_p, int row_viewpt, int col_viewpt,
+                     CELL cell_no)
+        CELL data;
+        char *value;
+        data = cell_no;
+        value = (char *) &data;
+        segment_put(seg_out_p,value,
+	   row_viewpt-PT_TO_DELETE_Y,PT_TO_DELETE_X+col_viewpt);
+	/* If first and last point.  This fixes a bug in r.los.
+	   See pts_elim3.c for details */
+        if((PT_TO_DELETE==head) && (PT_NEXT_TO_DELETED == NULL))
+                head = PT_NEXT_TO_DELETED;
+                free(PT_TO_DELETE);
+                return(head);
+        if(PT_TO_DELETE==head)   /*  first one ?  */
+                NEXT_PT_BACK_PTR = NULL;
+                return(head);
+	/* If last point.  This fixes a bug in r.los.
+	if (PT_NEXT_TO_DELETED == NULL)
+	    PREVIOUS_PT_NEXT_PTR = PT_NEXT_TO_DELETED;
+	    return (head);
+	/*  otherwise  */
+	NEXT_PT_BACK_PTR = PT_PREVIOUS_TO_DELETED;
+	return(head);
+/************* END OF FUNCTION "DELETE" *************************/
Added: grass-addons/grass6/raster/r.cva/delete_lists.c
--- grass-addons/grass6/raster/r.cva/delete_lists.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/delete_lists.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,59 @@
+ *      delete_lists.c
+ *      Delete the 16 segment lists used to record the cells
+ *      that are visible from each viewpoint.
+/* Modified from r.cumlos
+ * by MWL on 1/3/96 to:-
+ * 1) Delete the 16 segment lists used to record the cells
+ * Modifications to r.cumlos version 3.0:-
+ * 1) Taken out of main() and placed in function delete_lists().
+ * Called by:-
+ * 1) scan_all_cells()
+ * 2) random_sample()
+ * 3) systematic_sample()
+ * 4) from_sites()
+ * Calls:-
+ * 1)  delete_one_list()
+#include "point.h"
+void delete_lists (struct point *heads[])
+    int segment_no;
+    void delete_one_list ();
+    /* delete the list of visible cells */
+	/*		printf ("\nDeleting list for segment = %d ", segment_no);
+			fflush (stdout);*/
+	delete_one_list (heads[segment_no-1]);
Added: grass-addons/grass6/raster/r.cva/delete_lists.h
--- grass-addons/grass6/raster/r.cva/delete_lists.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/delete_lists.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,8 @@
+#ifndef __DELETE_LISTS_H__
+#define __DELETE_LISTS_H__
+#include "point.h"
+void delete_lists (struct point *heads[]);
+#endif
Added: grass-addons/grass6/raster/r.cva/delete_one_list.c
--- grass-addons/grass6/raster/r.cva/delete_one_list.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/delete_one_list.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,71 @@
+/*	delete_list.c	                                        */
+/*	This function frees the memory used in a segment list.	*/
+ * 1) Free the memory used in a single segment list.
+ * 1) See main3.c.
+ * Called by:-
+ * 1) delete_lists()
+ * Calls:-
+ * 1)  None. */
+#include "point.h"
+void delete_one_list (struct point *head)
+    struct point *PT_TO_DELETE;
+/*    PT_TO_DELETE = head;
+    while (PT_TO_DELETE != NULL)
+	printf ("\nPOINT = %d ", PT_TO_DELETE); fflush (stdout);
+	PT_TO_DELETE = PT_NEXT_TO_DELETED;
+    PT_TO_DELETE = head;
+/*printf ("\nPT_TO_DELETE = %d ", PT_TO_DELETE); fflush (stdout);*/
+        if (PT_NEXT_TO_DELETED != NULL)
+/*printf ("\nPT_NEXT = %d ", PT_NEXT_TO_DELETED); fflush (stdout);*/
+/*printf ("\nDELETED");*/
+/************* END OF FUNCTION "DELETE_LIST" *************************/
Added: grass-addons/grass6/raster/r.cva/description
--- grass-addons/grass6/raster/r.cva/description	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/description	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,6 @@
+# This file should contain a very brief description of what your extension does.
+# All lines will be output as you write them in here, including linebreaks.
+# commented lines and parts of lines after a comment mark ('#') will be skipped.
+This is a GRASS 6.1.0 (and above) extension to perform cumulative viewshed analysis.
+If you have GIS Manager installed (which is true per default for a GRASS 6.1.0 installation), you should be able to locate the new modules in a submenu called "Viewshed Analysis" under the "Xtns" menu in the main menu bar.
Added: grass-addons/grass6/raster/r.cva/description.html
--- grass-addons/grass6/raster/r.cva/description.html	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/description.html	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,428 @@
+<TITLE>r.cva</TITLE>
+<body bgcolor="white">
+<H2>NAME</H2>
+<EM><b>r.cva</b></EM>  - Cumulative viewshed analysis program.
+<BR>
+<EM>(GRASS Raster Program)</EM>
+<H2>SYNOPSIS</H2>
+<B>r.cva</B>
+<BR>
+<B>r.cva help</B>
+<BR>
+<B>r.cva</B>
+[<B>-afmnoqrs</B>]
+<B>input=</B><EM>name</EM>
+[<B>target_mask=</B><EM>name</EM>]
+[<B>viewpt_mask=</B><EM>name</EM>]
+[<B>sites=</B><EM>name</EM>]
+<B>output=</B><EM>name</EM>
+[<B>obs_elev=</B><EM>value</EM>]
+[<B>target_elev=</B><EM>value</EM>]
+[<B>max_dist=</B><EM>value</EM>]
+[<B>seed=</B><EM>value</EM>]
+[<B>sample=</B><EM>value</EM>]
+<B>type=</B><EM>value</EM>
+<H2>QUICKSTART</H2>
+To perform the most common cumulative viewshed analysis (for each cell of
+the input elevation raster map: count the number of observer sites from which it
+can be seen) type in the following:
+<p>
+<B>r.cva</B> <B>-f</B> <B>input=</B><EM>elevation</EM> <B>sites=</B><EM>observers</EM> <B>output=</B><EM>result</EM> <B>type=</B><EM>sites</EM>
+<P>
+'elevation' can be a raster map containing elevation values in CELL, FCELL or DCELL format. 'observers' must a map containing vector points.
+'result' will be an output map in CELL format containing the cumulative visibility counts for each cell.
+<A NAME = "description"><H2>DESCRIPTION</H2></A>
+<EM>r.cva</EM> generates a cumulative viewshed map.  When run without
+the <EM>-f</EM> flag each viewpoint is marked with the number of cells in its
+viewshed (i.e. that can be seen from it).  In this mode the only cells
+that contain genuine data in the output map are the viewpoints.
+Alternatively, if the <EM>-f</EM> flag is set then each cell in the
+<EM>output</EM> map is marked with the number of viewpoints from which
+it can be seen.  In either case, viewpoints may be chosen in one of
+four ways.  The first (`all') treats every cell as a viewpoint. This
+is so computationally demanding that it is unlikely to be feasible
+unless either the <EM>input</EM> map or <EM>max_dist</EM> is very
+small.  The second (`systematic') uses a systematic sample of cells
+arranged on a rectangular grid.  The third (`random') uses a random
+sample.  By default the random sampling algorithm does not allow
+replacement (i.e. a cell can be treated as a viewpoint only once), but
+this behaviour can be altered by setting the <EM>-r</EM> flag.  The
+fourth option (`sites') uses the points in the specified <EM>vector</EM>
+map. The options `systematic' and `random' allow the user to specify
+any sampling frequency between 0% and 100%.
+<p>
+The cells used in viewshed analysis can be constrained by one or both
+of two masks. Both masks should be binary raster maps in which the
+areas of interest are coded `1' and all other cells `0'.
+<EM>target_mask</EM> determines which cells are targets: a cell which
+is not a target will be returned as not visible from a given viewpoint
+even if it is actually visible according to the line-of-sight analysis
+(i.e. this mask performs the same function as <EM>patt_map</EM> in
+<EM><A HREF="../../html/r.los.html">r.los</A></EM>).  <EM>viewpt_mask</EM>
+constrains which cells may be treated as viewpoints.  For example,
+suppose that the raster map `no_sea' codes sea (elevation = 0) as `0'
+and land (elevation > 0) as `1'.  In this case, specifying `no_sea' as
+the <EM>target_mask</EM> would cause <EM>r.cva</EM> to count cells on
+land that are visible from any viewpoint.  Alternatively, specifying
+`no_sea' as the <EM>viewpt_mask</EM> would count any cells visible
+from viewpoints on land.  Finally, specifying `no_sea' as both the
+<EM>target_mask</EM> and <EM>viewpt_mask</EM> would count cells on
+land that are visible from viewpoints on land.
+<p>
+The geometry of the potential line of sight between each pair of cells
+may be altered by means of two offsets, <EM>obs_elev</EM> and
+<EM>target_elev</EM>. The height <EM>obs_elev</EM> is added to the
+viewpoint and the height <EM>target_elev</EM> to each target cell.
+Note that by swapping these values it is possible to produce maps
+showing the number of cells from which a viewpoint is visible, or if
+the <EM>-f</EM> flag is set, the number of viewpoints which it is
+possible to see from each map cell.
+<p>
+A particular set of viewpoint locations in a random sample can be
+repeated by specifying the same value for <EM>seed</EM>.
+Alternatively, different values can be used to produce independent
+samples for statistical testing.
+<p>
+The program can be run either non-interactively or interactively.  To
+run <EM>r.cva</EM> non-interactively the user must minimally specify
+the <B>input</B> and <B>output</B> maps and the <B>type</B> of
+analysis.  If the chosen <B>type</B> is `sites' then the
+<B>sites</B> list must also be specified.  Any remaining parameters
+whose values have not been specified on the command line will be set
+to their default values (see <A HREF = "#parameters">below</A>).  Non-interactive usage format is:
+<DL>
+<DD>
+<B>r.cva</B>
+[<B>-afmnoqrs</B>]
+</DL>
+<H2>OPTIONS</H2>
+<H3>Flags:</H3>
+<DL>
+<DT><B>-a</B>
+<DD> Treat the specified sample size as an absolute number of cells
+rather than a percentage.  Note, this flag is only for use with random
+sampling.
+<DT><B>-f</B>
+<DD> Mark each cell in the output map with the number of viewpoints
+from which it can be seen.
+<DT><B>-h</B>
+<DD> Adjust height of oberserver points so that they will never fall
+below surface level. This is only useful in conjunction with the
+<b>spot</b> parameter or attribute (see <A HREF ="#atributes">below</A>).
+<DT><B>-i</B>
+<DD> Do not interpret control attributes in input vector map as
+described <A HREF ="#atributes">below</A>).
+<DT><B>-m</B> <DD> Differentiate between genuine zero data values and
+null data in the output map.  When the <EM>-f</EM> flag has not been
+set this ensures that all non-viewpoint cells are coded `-1'.  When
+the <EM>-f</EM> flag has been set then all cells coded `0' in the
+<EM>target_mask</EM> (if there is one) are coded `-1'.  See <A HREF =
+"#notes">below</A> for guidance when to set this flag.
+<DT><B>-n</B> <DD> In conjunction with <B>-m</B>: write NULL values instead of '-1' to output map.
+<DT><B>-o</B>
+<DD> Overwrite the output raster map if it already exists.
+<DT><B>-q</B>
+<DD> Be quiet about progress, confirming only the output file and
+sampling frequency.  This is useful when <EM>r.cva</EM> is invoked from a
+script with standard output redirected to a disk file.
+<DT><B>-r</B>
+<DD> Allow replacement during random sampling (i.e. allow a given cell
+to be picked as a viewpoint more than once).  Note that no cumulation
+occurs for replacement viewpoints; this ensures that the resulting
+cumulative viewshed will be as though the viewpoint was selected once
+only (the final output map will, of course, be different because
+replacement effectively results in the use of fewer viewpoints for a
+given sampling frequency).
+<DT><B>-s</B> <DD>Be silent about progress, in which case it is
+strongly recommended that you use <EM><A
+HREF="../../html/r.info.html">r.info</A></EM> to confirm what sampling frequency
+was actually achieved.
+<A NAME = "parameters"><H3>Parameters:</H3></A>
+<DT><B>input=</B><EM>name</EM>
+<DD>Name of a raster map layer containing elevation
+data, used as program input.
+<DT><B>target_mask=</B><EM>name</EM> <DD>Name of a binary raster map
+layer in which target cells within the areas of interest are assigned
+the category value `1' and all other cells are assigned the category
+value `0'.  A cell is treated as a target when it is viewed from a
+viewpoint (note, therefore, that viewpoints are targets when viewed
+from other viewpoints).
+<DT><B>viewpt_mask=</B><EM>name</EM>
+<DD>Name of a binary raster map layer in which viewpoints within the areas
+of interest are assigned the category value `1' and all other cells
+are assigned the category value `0'.
+<DT><B>sites=</B><EM>name</EM>
+<DD>The name of a vector map containing the sites (vector points) that are to be treated as
+viewpoints.  Sites falling outside the current region are ignored.
+<DT><B>obs_elev=</B><EM>value</EM>
+<DD>Height of the observer (in metres) above the elevation of the
+viewpoint.  Default: 1.75 m
+<DT><B>target_elev=</B><EM>value</EM>
+<DD>Height of the object of interest (in metres) above the elevation
+of the target cell.  Default: 0.0 m
+<DT><B>max_dist=</B><EM>value</EM>
+<DD>Maximum distance (in metres) from the viewing point within which
+the line-of-sight analysis will be performed.  Options: 0-99999
+(stated in map units). Default: 100
+<DT><B>seed=</B><EM>value</EM>
+<DD>The seed for the random number generator used during random
+sampling.  This option allows exact reproduction of a previous result.
+Options: 0-32767. Default: 1
+<DT><B>sample=</B><EM>value</EM>
+<DD>The sampling frequency as a percentage of the number of map cells
+in the current region.  Options: 0.0-100.0. Default: 10.0
+<DT><B>type=</B><EM>value</EM> <DD>The type of sampling regime used to
+select viewpoints for analysis. See <A HREF = "#description">above</A>
+for details.  Options: `all', `systematic', `random', `sites'.
+<DT><B>spot, offseta, offsetb, azimuth1, azimuth2, vert1, vert2, radius1, radius2</B>
+<DD> See <A HREF ="#atributes">below</A>) for a description of what they do.
+<DT><B>curvc=</B><EM>value</EM>
+<DD>Earth curvature correction will be applied if the distance from the observer
+point exceeds the given threshold. Set this to 0.0 to disable curvature correction
+(default). While correction slows down calculations, it is recommend for
+viewing distances of more than about 3 km. The correction uses a simplified
+formula which is accurate to 1 in 10,000 for distances up to 40 km:<p>
+<i>d(height)=dist^2/(2*Re)</i><p>
+With <i>Re</i> being the radius of the earth (ca. 6,356,766 m).
+</DL>
+<A NAME = "attributes"><H3>Vector map attributes:</H3>
+When using 'sites' type operation mode, <EM>r.cva</EM> checks for the
+presence of a number of attributes in the input vector map. The names
+of these attributes are all uppercase and match those used by the
+viewshed module of ESRI's ArcGIS Spatial Extension (trademarks of ESRI Corp.).
+They control <EM>r.cva</EM> operation in an analogous way.
+Each attribute, if present, must store a double value. The following
+attribute names and value ranges are recognised and interpreted:
+<dl>
+<dt>SPOT</dt>
+	<dd>This determines absolute observer height. If this attribute is given,
+	    observer height will no longer be determined from the DEM.
+		 <EM>r.cva</EM> can automatically raise this value to that of the DEM
+		 point below the oberserver's position, if the value in SPOT would
+		 cause the observer to get below ground level (use the <b>-h</b> flag).</dd>
+<dt>OFFSETA</dt>
+	<dd>Use this to add an offset to each oberver point's height. This is
+	    just an alias for the <b>obs_elev</b> option and exists for
+	    compatibility reasons.</dd>
+<dt>OFFSETB</dt>
+		<dd>The value stored in 'OFFSETB' will be added to each target point
+		at the moment it is considered for visibility. All blocking points
+		on the line-of-sight between observer and target will be left untouched.
+		This is different from the <b>target_elev</b> parameter. It can be
+		used to simulate visibility of targets with a certain height.</dd>
+<dt>AZIMUTH1, AZIMUTH2</dt>
+		<dd>These attributes must be given as values between 0.0 and 360.0 and
+		can be used to limit the horizontal scan range of the viewshed.
+		Limits are measured in degrees with 0.0 in the North and values
+		increasing clock-wise. Thus, if you wanted to limit visibility scans
+		to eastward directions only, you would set AZIMUTH1=1 and AZIMUTH2=180.
+		</dd>
+<dt>VERT1, VERT2</dt>
+		<dd>In analogy to 'AZIMUTH1' and 'AZIMUTH2', these attributes can be
+		used to limit the vertical range of the scan. The range is -90 to 0 for
+		'VERT1' and 0 to 90 for 'VERT2'.
+		At -90 degrees, the observer looks straight down to the ground and at
+		90 degress up into the sky.
+		</dd>
+<dt>RADIUS1, RADIUS2</dt>
+		<dd>Finally, two attributes exist to limit the distance of the scan.
+		'RADIUS1' determines the minimum distance from the observer and 'RADIUS2'
+		the maximum distance. The latter is thus equivalent to using the
+		<b>max_dist</b> parameter and exists for compatibility reasons.
+		</dd>
+</dl>
+Interpretation of these attributes can be turned off by using the <b>-i</b> flag.
+<p>
+Note that you can use the same control values in operation modes
+other than 'sites', if you specify the equivalent parameters
+(see <A HREF = "#parameters">above</A>). The latter will also work
+as global settings in 'sites' mode. Attributes stored in the vector
+map table will override these global settings unless the <b>-i</b>
+flag is specified. The meaning of <b>OFFSETA, OFFSETB</b> and <b>RADIUS1</b> is
+the same as <b>obs_elev, target_elev</b> and <b>max_dist</b>. The latter still
+exist for compatibility with earlier versions of <em>r.cva</em>.
+<A NAME = "notes"><H2>NOTES</H2></A>
+<EM>r.cva</EM> works in the current geographic region, but ignores the
+current mask. Masking is achieved by specifying a target_mask and/or a
+viewpt_mask. For accurate results, the program must be run with the
+resolution of the geographic region set equal to the resolution of the
+data (see <EM><A HREF="../../html/g.region.html">g.region</A></EM>).
+<P>
+This program assumes all height and distance measurements in meters.
+Legacy units must be converted to meters by the user before running <EM>r.cva</EM>.
+<P>
+It is also assumed, that N-S and E-W resolution of the current region are the
+same. If they differ, distances calculated for limiting the viewshed will
+be imprecise and results affected accordingly.
+<P>
+The number of cells visible from a given viewpoint includes the
+viewpoint itself only if the viewpoint is a target cell.
+Consequently, if neither the viewpoint nor any other cell within
+<EM>max_dist</EM> of it is a target cell then the size of that
+viewpoint's viewshed will be zero. Set the <EM>-m</EM> flag to locate
+such viewpoints (they will show as cells coded `0' as opposed to
+`-1'). Similarly, set the <EM>-m</EM> flag when the <EM>-f</EM> flag has
+been set in order to differentiate cells which are genuinely not
+visible from any viewpoint as opposed to those that are not target
+cells.
+<P>
+<EM>r.cva</EM> always informs the user what sampling frequency was
+attempted and subsequently achieved.  This information is printed to
+standard output and is also placed in the output map's history file
+(which can be viewed using <EM><A HREF="../../html/r.info.html">r.info</A></EM>).
+The sample attempted may differ slightly from that requested owing to
+the need to sample a whole number of cells.  Any such discrepancy will
+be greatest in the case of small maps of coarse resolution.  The
+sample achieved may be further reduced when a <EM>viewpt_mask</EM> has been
+specified.  This will not occur with the option `random', because its
+algorithm repeatedly allocates viewpoints until the number that fall
+within mask cells coded `1' produces the frequency attempted. Such a
+reduction can, however, occur with the options `all', `systematic' and
+`sites', because their algorithms allocate viewpoints without
+reference to the mask and then simply ignore those that fall in mask
+cells coded `0'.
+<P>
+<H2>SEE ALSO</H2>
+<br>
+<EM><A HREF="../../html/r.info.html">r.info</A></EM>
+<br>
+<EM><A HREF="../../html/g.region.html">g.region</A></EM>
+<P>
+Cumulative viewshed analysis was defined by D. Wheatley, 1995,
+`Cumulative viewshed analysis: a GIS-based method for investigating
+intervisibility, and its archaeological application', in G. R. Lock
+and Z. Stancic (eds.)  <EM>Archaeology and Geographic Information
+Systems: A European Perspective</EM>, London: Taylor and Francis,
+pp. 171-186.
+<P>
+Lake et al. (M. W. Lake, P. E. Woodman and S. J. Mithen, 1998,
+`Tailoring GIS software for archaeological applications: an example
+concerning viewshed analysis', <EM>Journal of Archaeological
+Science</EM> 25: 27-38) discuss the first version of <EM>r.cva</EM>
+and provide some timing estimates.  They also discuss the importance
+of eliminating the edge effect that occurs when calculating the number
+of cells visible from a viewpoint that is closer than
+<EM>max_dist</EM> to the edge of the map.
+<P>
+Fisher et al. (P. Fisher, C. Farrelly, A. Maddocks and C.  Ruggles,
+1997, `Spatial Analysis of Visible Areas from the Bronze Age Cairns of
+Mull', <EM>Journal of Archaeological Science</EM> 24: 581--592)
+provide a useful review of some of the pitfalls that may trap unwary
+users of cumulative viewshed analysis. Most of these are easily
+avoided using <EM>r.cva</EM>.
+<H2>AUTHOR</H2>
+Mark Lake, Institute of Archaeology, University College London (the author).
+<P>
+With contributions by:
+Benjamin Ducke, Institute of Archaeology, University of Bamberg, Germany.
+<H2>ACKNOWLEDGEMENTS</H2>
+This version of <EM>r.cva</EM> was completed during the author's
+tenure of a Leverhulme Trust Special Research Fellowship at the
+Institute of Archaeology, University College London, U.K.
+<P>
+The first version of <EM>r.cva</EM> was written by the author as part of the
+MAGICAL Project directed by Dr. Steven Mithen (Dept. of Archaeology,
+University of Reading, U.K.).  The MAGICAL Project was made possible
+by a Natural Environment Research Council award (NERC GR3/9540) to
+Dr. Mithen.
+<P>
+<EM>r.cva</EM> draws heavily on the code for <EM><A
+HREF="../../html/r.los.html">r.los</A></EM>, which was written by Kewan
+Q. Khawaja, Intelligent Engineering Systems Laboratory, M.I.T.
+<P>
+Adaptation to GRASS 6 vector and raster formats, additional functionality,
+documentation updates by Benjamin Ducke (2005).
+<H2>BUGS</H2>
+Missing values in site attributes are currently not handled.
+<p>
+Earth curvature correction has not been sufficiently tested. The 'offsetb' option (=target_elev)
+has not been sufficiently tested. Please feel free to test and report!
+<p>
+When <EM>max_dist</EM> is set to 100, the N-S and E-W resolutions are
+50, and a <EM>target_mask</EM> has been specified, the cells
+immediately NE, SE, SW and NW of the viewpoint may not be masked when
+then should be.  Please report any others that you find to the author.
+<P>
+Note that <EM>r.cva</EM> fixes two bugs in the current version of
+<EM><A HREF="../../html/r.los.html">r.los</A></EM>: that <EM>obs_elev</EM> is
+truncated to its integer component and that the target mask
+(<EM>patt_map</EM> in <EM><A HREF="../../html/r.los.html">r.los</A></EM>) does
+not apply to the viewpoint or its eight immediate neighbours.
Added: grass-addons/grass6/raster/r.cva/global_vars.h
--- grass-addons/grass6/raster/r.cva/global_vars.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/global_vars.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,46 @@
+  global_vars.h
+  CONTAINS
+  Global variables                                                     */
+#ifdef MAIN
+#define GLOBAL
+#else
+#define GLOBAL extern
+#endif
+GLOBAL double Re;
+GLOBAL double obs_elev, target_elev;
+GLOBAL double max_dist;
+GLOBAL double sample;
+GLOBAL int background, seed, from_cells;
+GLOBAL int patt_flag, patt_flag_v;
+GLOBAL int show_mask;
+GLOBAL int fract;
+GLOBAL struct Cell_head window;   /* Region info used for sites option */
+/* distance above which to apply earth curvature correction */
+GLOBAL double DIST_CC;
+/* these are set if the vector points support the ArcGIS attributes */
+GLOBAL double SPOT;
+GLOBAL int SPOT_SET;
+GLOBAL double OFFSETB;
+GLOBAL int OFFSETB_SET;
+GLOBAL int ADJUST;
+GLOBAL double AZIMUTH1;
+GLOBAL int AZIMUTH1_SET;
+GLOBAL double AZIMUTH2;
+GLOBAL int AZIMUTH2_SET;
+GLOBAL double VERT1;
+GLOBAL int VERT1_SET;
+GLOBAL double VERT2;
+GLOBAL int VERT2_SET;
+GLOBAL double RADIUS1;
Added: grass-addons/grass6/raster/r.cva/init_segment_file.c
--- grass-addons/grass6/raster/r.cva/init_segment_file.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/init_segment_file.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,74 @@
+  init_segment_file.c
+  CONTAINS
+  1) init_segment_file                                                 */
+  init_segment_file
+  Called from:
+  1) scan_all_cells     scan_all_cells.c
+  2) systematic_sample  systematic_sample.c
+  3) random_sample      random_sample.c
+  4) point_sample       point_sample.c
+  Calls:
+  None        */
+void init_segment_file (int nrows, int ncols, SEGMENT *seg_to_init_p,
+			SEGMENT *seg_patt_p)
+  int row, col;
+  char *value;
+  CELL data;
+  value = (char*) &data;
+  if (from_cells && patt_flag && (background == -1))
+      CELL data_read;
+      char *value_to_get;
+      value_to_get = (char*) &data_read;
+      for (row = 0; row < nrows; row ++)
+	  for (col = 0; col < ncols; col ++)
+	      segment_get (seg_patt_p, value_to_get,
+			  row, col);
+	      if (! data_read)
+		data = background;
+	      else
+		data = 0;
+	      segment_put (seg_to_init_p, value,
+			   row, col);
+  else
+	      segment_put (seg_to_init_p, value, row, col);
Added: grass-addons/grass6/raster/r.cva/init_segment_file.h
--- grass-addons/grass6/raster/r.cva/init_segment_file.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/init_segment_file.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,10 @@
+#ifndef __INIT_SEGMENT_FILE_H__
+#define __INIT_SEGMENT_FILE_H__
+			SEGMENT *seg_patt_p);
+#endif
Added: grass-addons/grass6/raster/r.cva/line_of_sight.c
--- grass-addons/grass6/raster/r.cva/line_of_sight.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/line_of_sight.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,104 @@
+  line_of_site.c
+  Updated by Mark Lake on 17/8/01 for GRASS 5.x
+  CONTAINS
+  1) line_of_site                                                      */
+  line_of_site
+  Called from:
+  2) random_sample      random_sample.c
+  3) systematic_sample  systematic_sample.c
+  Calls:
+  1)  segment()         segment3.c                                     */
+#include "point.h"
+#include "segment3.h"
+void line_of_sight (CELL cell_no, int row_viewpt, int col_viewpt,
+		    int nrows, int ncols, double viewpt_elev,
+		    struct point *heads[],
+            SEGMENT *seg_in_p, SEGMENT *seg_out_1_p, SEGMENT *seg_patt_p,
+		    int patt_flag, RASTER_MAP_TYPE data_type)
+     /* struct point *heads[] is same as "struct point **heads" */
+  int a,b;
+  int segment_no, flip, xmax, ymax, sign_on_y, sign_on_x;
+  double slope_1, slope_2;
+  /* Do los analysis from current viewpoint for 16 segments  */
+  for(segment_no=1; segment_no<=16; segment_no++)
+      sign_on_y= 1- (segment_no-1)/8 * 2;
+      if(segment_no>4 && segment_no<13)
+	sign_on_x= -1;
+      else sign_on_x=1;
+      /* Calc slopes for bounding rays of this segment */
+      if(segment_no==1 || segment_no==4 || segment_no==5  ||
+	 segment_no==8 || segment_no==9 || segment_no==12 ||
+	 segment_no==13 || segment_no==16)
+	  slope_1= 0.0;
+	  slope_2= 0.5;
+      else
+	  slope_1= 0.5;
+	  slope_2= 1.0;
+      if(segment_no==1 || segment_no==2 || segment_no==7 ||
+	 segment_no==8 || segment_no==9  || segment_no==10 ||
+	 segment_no==15 || segment_no==16)
+	flip = 0;
+      else flip = 1;
+      /* Calculate max and min 'x' and 'y' */
+      a= ((ncols-1)*(sign_on_x+1)/2 - sign_on_x * col_viewpt);
+      b= (1-sign_on_y)/2*(nrows-1) + sign_on_y*row_viewpt;
+      if(flip==0)
+	  xmax=a;
+	  ymax=b;
+      else
+	  xmax=b;
+	  ymax=a;
+      /* Perform los analysis for this segment */
+	  /* this function is in file 'segment3.c' */
+      heads[segment_no-1] = segment(segment_no,xmax,ymax,
+				   slope_1,slope_2,flip,sign_on_y,sign_on_x,
+				   viewpt_elev,
+	               seg_in_p,seg_out_1_p, seg_patt_p,
+				   row_viewpt,col_viewpt,patt_flag,
+				   cell_no, data_type);
Added: grass-addons/grass6/raster/r.cva/line_of_sight.h
--- grass-addons/grass6/raster/r.cva/line_of_sight.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/line_of_sight.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,13 @@
+#ifndef __LINE_OF_SIGHT_H__
+#define __LINE_OF_SIGHT_H__
+		    int patt_flag, RASTER_MAP_TYPE data_type);
+#endif
Added: grass-addons/grass6/raster/r.cva/main.c
--- grass-addons/grass6/raster/r.cva/main.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/main.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,687 @@
+  r.cva   in $GIS/src.contrib/IoA
+  Mark Lake  30/6/99 (pdated 17/8/01 for GRASS 5.x)
+  University College London
+  Institute of Archaeology
+  31-34 Gordon Square
+  London.  WC1H 0PY
+  Email: mark.lake at ucl.ac.uk
+  Adaptations for new GRASS 5 site and raster formats
+  Adaptations for new GRASS 6 vector format
+  by Benjamin Ducke 2004
+  benducke at compuserve.de
+  Summary of changes:
+       	- updated to GRASS 5 sites API
+		   	- use GRASS routines to convert Site coordinates to raster coords
+			- handle CELL, FCELL or DCELL as elevation input map format
+			- handle NULL values in input map by copying them through to result
+  	     		- renamed flag '-n' to '-a'
+		 	- new flag '-n': convert -1 to NULL in output map
+			- max viewing distance now set to 2000 m by default
+			- handle all progress display through 'G_percent()'
+			- all output now goes to 'stdout', so it can be piped to a file
+  			- made source code more readable
+			- updated manual pages
+			- update tcltkgrass menu file
+	- updated to GRASS 6
+			- use new vector points format instead of sites
+			- read and interpret special attributes in the vector map's DB table
+			  the same way ArcInfo(tm) Spatial Analyst Extension(tm I guess) does
+			- same attributes can also be set as global options
+			- earth curvature correction
+			- fixed nasty FP handling bugs that would cause the previous GRASS 5 version to
+			  crash when compiled with newer versions of GCC
+			- lots of fixes for NULL data handling in DEM
+			- updated HTML manual page to reflect changes
+  ACKNOWLEDGEMENTS
+  The first version of r.cva was written by the author as part of the
+  MAGICAL Project directed by Dr. Steven Mithen (University of Reading,
+  U.K.).  The MAGICAL Project was made possible by a Natural Environment
+  Research Council award (NERC GR3/9540) to Dr. Mithen.
+  This version of r.cva was significantly enhanced during the author's
+  tenure of a Leverhulme Trust Special Research Fellowship at the
+  Institute of Archaeology, U.C.L., U.K.
+  r.cva draws heavily on the code for r.los, which was written by
+  Kewan Q. Khawaja, Intelligent Engineering Systems Laboratory, M.I.T.
+  PURPOSE
+  1) Perform cumulative viewshed (CVA) analysis.
+  OPTIONS
+  1)  Record the number of cells visible from:
+  all          every map cell;
+  systematic   a systematic sample of map cells;
+  random       a random sample of map cells;
+  sites        a list of sites.
+  2)  Record how often each cell in the map is visible from:
+  3) Random sampling may occur with or without replacement.
+  4) All types of sampling may be subject to binary masks such that:
+     i)  Not all possible destination cells (cells to be `looked at')
+         are of interest;
+     ii) Not all possible viewpoints are of interest.
+  5) It is possible to specify the height of the observer.
+  6) It is possible to specify the height of the target object
+     above ground.
+  NOTE
+  r.cva includes fixes for two bugs in the current version of r.los.
+  These are that the observer elevation is cast to an integer, and that
+  the patt_map does not effect the viewpoint and its immediately
+  neighbouring cells                                                   */
+/* main
+   Called from:
+   1) None
+   Calls functions in:
+   1) scan_all_cells.c
+   2) random_sample.c
+   3) systematic_sample.c
+   4) point_sample.c
+   5) segment_file.c                                                   */
+#include <string.h>
+#define MAIN
+#include "point.h"
+#include "segment_file.h"
+#include "scan_all_cells.h"
+#include "systematic_sample.h"
+#include "random_sample.h"
+#include "point_sample.h"
+#define kSEGFRACT 4             /* Controls no. of segments
+                                   DO NOT CHANGE */
+int main(int argc, char *argv[])
+  int nrows, ncols;
+  int new,old,patt,patt_v,in_fd,out_fd_1, out_fd_2;
+  int patt_fd, patt_fd_v, rnd_fd;
+  int same_mask;
+  char old_mapset [50], patt_mapset [50], patt_mapset_v [50];
+  char current_mapset [50];
+  char in_name [128], out_name_1 [128], out_name_2 [128];
+  char patt_name [128], patt_name_v [128], rnd_name [128];
+  double attempted_sample, actual_sample;
+  struct Categories cats;
+  struct History history;
+  extern struct Cell_head window;
+  CELL *cell = NULL;
+  DCELL *dcell = NULL;
+  FCELL *fcell = NULL;
+  SEGMENT seg_in, seg_out_1, seg_out_2, seg_patt, seg_patt_v, seg_rnd;
+  SEGMENT *seg_patt_p_v = NULL;
+  struct point *segment();
+  struct GModule *module;
+  struct Option *input, *patt_map, *patt_map_v, *type;
+  struct Option *opt_obs_elev, *opt_target_elev;
+  struct Option *opt_max_dist, *output, *opt_seed, *opt_sample;
+  struct Option *sites;
+  struct Option *curvature_corr;
+  struct Option *spot, *offseta, *offsetb, *azimuth1, *azimuth2, *vert1, *vert2, *radius1, *radius2;
+  struct Flag *replace, *from, *overwrite, *quiet, *mask, *silent;
+  struct Flag *adjust, *absolute, *nulls, *ignore;
+  /* stores cell data mode (CELL_TYPE, FCELL_TYPE or DCELL_TYPE) */
+  int cell_mode;
+  int make_nulls = 0; /* this signals whether -1 in output map should be
+                             converted to NULL */
+  /* Preliminary things                                                  */
+  /* Initialize the GIS calls and sort out error handling */
+  G_gisinit (argv[0]);
+  G_sleep_on_error (0);
+  /* Define the options */
+  module = G_define_module();
+  module->description = "Multiple/cumulative viewshed analysis";
+  input = G_define_standard_option(G_OPT_R_INPUT) ;
+  input->key        = "input";
+  input->type       = TYPE_STRING;
+  input->required   = YES;
+  input->gisprompt  = "old,fcell,dcell,cell,raster" ;
+  input->description= "Elevation raster map" ;
+  patt_map = G_define_standard_option(G_OPT_R_INPUT);
+  patt_map->key        = "target_mask";
+  patt_map->type       = TYPE_STRING;
+  patt_map->required   = NO;
+  patt_map->description= "Binary raster map for target cells";
+  patt_map->gisprompt  = "old,cell,raster" ;
+  patt_map_v = G_define_standard_option(G_OPT_R_INPUT);
+  patt_map_v->key        = "viewpt_mask";
+  patt_map_v->type       = TYPE_STRING;
+  patt_map_v->required   = NO;
+  patt_map_v->description= "Binary raster map for viewpoints";
+  patt_map_v->gisprompt  = "old,cell,raster" ;
+  sites = G_define_standard_option(G_OPT_V_MAP);
+  sites->key        = "sites";
+  sites->type       = TYPE_STRING;
+  sites->required   = NO;
+  sites->description= "Vector map with sites points" ;
+  output = G_define_standard_option(G_OPT_R_OUTPUT);
+  output->key        = "output";
+  output->type       = TYPE_STRING;
+  output->required   = YES;
+  output->gisprompt  = "cell,raster" ;
+  output->description= "Raster map name for storing results";
+  opt_obs_elev = G_define_option() ;
+  opt_obs_elev->key        = "obs_elev";
+  opt_obs_elev->type       = TYPE_DOUBLE;
+  opt_obs_elev->required   = NO;
+  opt_obs_elev->answer     = "1.75";
+  opt_obs_elev->description= "Height of the viewing location";
+  opt_target_elev = G_define_option() ;
+  opt_target_elev->key        = "target_elev";
+  opt_target_elev->type       = TYPE_DOUBLE;
+  opt_target_elev->required   = NO;
+  opt_target_elev->answer     = "0.0";
+  opt_target_elev->description= "Height of the target location";
+  opt_max_dist = G_define_option() ;
+  opt_max_dist->key        = "max_dist";
+  opt_max_dist->type       = TYPE_DOUBLE;
+  opt_max_dist->required   = NO;
+  opt_max_dist->answer     = "2000";
+  opt_max_dist->options    = "0.0-9999999.9" ;
+  opt_max_dist->description= "Max viewing distance in meters" ;
+  opt_seed = G_define_option() ;
+  opt_seed->key        = "seed";
+  opt_seed->type       = TYPE_INTEGER;
+  opt_seed->required   = NO;
+  opt_seed->answer     = "1";
+  opt_seed->options    = "0-32767" ;
+  opt_seed->description= "Seed for the random number generator" ;
+  opt_sample = G_define_option() ;
+  opt_sample->key        = "sample";
+  opt_sample->type       = TYPE_DOUBLE;
+  opt_sample->required   = NO;
+  opt_sample->answer     = "10.0";
+  opt_sample->description= "Sampling frequency as a percentage of cells" ;
+  type = G_define_option();
+  type->key        = "type";
+  type->type       = TYPE_STRING;
+  type->required   = YES;
+  type->answer     = "sites";
+  type->options    = "sites,systematic,random,all";
+  type->description= "Type of vieshed analysis";
+  spot = G_define_option();
+  spot->key = "spot";
+  spot->type = TYPE_DOUBLE;
+  spot->required = NO;
+  spot->description = "Absolute observer height";
+  offseta = G_define_option();
+  offseta->key = "offseta";
+  offseta->type = TYPE_DOUBLE;
+  offseta->required = NO;
+  offseta->description = "Observer offset (OFFSETA=obs_elev)";
+  offsetb = G_define_option();
+  offsetb->key = "offsetb";
+  offsetb->type = TYPE_DOUBLE;
+  offsetb->required = NO;
+  offsetb->description = "target offset (OFFSETB=target_elev)";
+  azimuth1 = G_define_option();
+  azimuth1->key = "azimuth1";
+  azimuth1->type = TYPE_DOUBLE;
+  azimuth1->required = NO;
+  azimuth1->options = "0.0-360.0";
+  azimuth1->description = "Minimum azimuth (AZIMUTH1)";
+  azimuth2 = G_define_option();
+  azimuth2->key = "azimuth2";
+  azimuth2->type = TYPE_DOUBLE;
+  azimuth2->required = NO;
+  azimuth2->options = "0.0-360.0";
+  azimuth2->description = "Maximum azimuth (AZIMUTH2)";
+  vert1 = G_define_option();
+  vert1->key = "vert1";
+  vert1->type = TYPE_DOUBLE;
+  vert1->required = NO;
+  vert1->options = "0.0-90.0";
+  vert1->description = "Minimum vertical angle (VERT1)";
+  vert2 = G_define_option();
+  vert2->key = "vert2";
+  vert2->type = TYPE_DOUBLE;
+  vert2->required = NO;
+  vert2->options = "-90.0-0.0";
+  vert2->description = "Maximum vertical angle (VERT2)";
+  radius1 = G_define_option();
+  radius1->key = "radius1";
+  radius1->type = TYPE_DOUBLE;
+  radius1->required = NO;
+  radius1->description = "Minimum distance from observer (RADIUS1)";
+  radius2 = G_define_option();
+  radius2->key = "radius2";
+  radius2->type = TYPE_DOUBLE;
+  radius2->required = NO;
+  radius2->description = "Maximum distance to observer (RADIUS2)";
+  curvature_corr = G_define_option ();
+  curvature_corr->key = "curvc";
+  curvature_corr->type = TYPE_DOUBLE;
+  curvature_corr->required = NO;
+  curvature_corr->answer = "0.0";
+  curvature_corr->description = "Earth curvature correction threshold (0.0 = off)";
+  from = G_define_flag ();
+  from->key = 'f';
+  from->description = "Calculate the `visibility from' rather than `viewsheds of' ";
+  mask = G_define_flag ();
+  mask->key = 'm';
+  mask->description = "Differentiate masked cells from data value zero ";
+  absolute = G_define_flag ();
+  absolute->key = 'a';
+  absolute->description = "Treat sample size as no. of cells ";
+  overwrite = G_define_flag ();
+  overwrite->key = 'o';
+  overwrite->description = "Overwrite output file if it exists ";
+  quiet = G_define_flag ();
+  quiet->key = 'q';
+  quiet->description = "Run quietly (i.e. do not report \% complete) ";
+  replace = G_define_flag ();
+  replace->key = 'r';
+  replace->description = "Allow replacement during random sampling ";
+  adjust = G_define_flag ();
+  adjust->key = 'h';
+  adjust->description = "Adjust spot heights below surface";
+  ignore = G_define_flag ();
+  ignore->key = 'i';
+  ignore->description = "Ignore site attributes";
+  nulls = G_define_flag ();
+  nulls->key = 'n';
+  nulls->description = "Convert -1 to NULL in output map ";
+  silent = G_define_flag ();
+  silent->key = 's';
+  silent->description = "Run silently ";
+  if (G_parser(argc, argv))
+    exit (-1);
+  /* Make numeric parameters globally available */
+  sscanf (opt_obs_elev->answer, "%lf", &obs_elev);
+  //sscanf (opt_target_elev->answer, "%lf", &target_elev);
+  if ( opt_target_elev->answer != NULL ) {
+  	OFFSETB_SET = 1; /* OFFSETB is the same as old parameter target_elev */
+	OFFSETB = atof (opt_target_elev->answer);
+  sscanf (opt_max_dist->answer, "%lf", &max_dist);
+  sscanf (opt_seed->answer, "%d", &seed);
+  sscanf (opt_sample->answer, "%lf", &sample);
+  from_cells = from->answer;
+  if(patt_map->answer == NULL)
+    patt_flag = 0;
+  else
+    patt_flag = 1;
+  if(patt_map_v->answer == NULL)
+    patt_flag_v = 0;
+  else
+    patt_flag_v = 1;
+  if (mask->answer)
+    background = -1;
+  else
+    background = 0;
+  if (adjust->answer) {
+  	ADJUST = 1;
+  } else {
+  	ADJUST = 0;
+  if (nulls->answer)
+	make_nulls = 1;
+  fract = kSEGFRACT;
+  /* Check sample size is sensible */
+  if (!absolute->answer)
+      if ((sample < 0.0) || (sample > 100.0))
+	G_fatal_error ("Sample size must be in range 0 to 100 ");
+  else
+    if (sample < 0.0)
+      G_fatal_error ("Sample size must be a positive number ");
+  /* If both destination and viewpoint masks have been specified
+     check whether they are the same.  If so set flag so that only
+     one is loaded into memory and the other is simply made a duplicate
+     set of pointers. */
+  if (patt_flag && patt_flag_v)
+      if (strcmp (patt_map->answer, patt_map_v->answer) == 0)
+	same_mask = 1;
+      else
+	same_mask = 0;
+  else same_mask = 0;
+  /* Must be quiet if silent */
+  if (silent->answer)
+    quiet->answer = 1;
+  /* Get current region */
+  G_get_window (&window);
+  nrows = G_window_rows();
+  ncols = G_window_cols();
+  /* determine mode of input map */
+  cell_mode = G_raster_map_type (input->answer,"");
+  /* Allocate buffer space for row-io to layer */
+  cell = G_allocate_c_raster_buf(); /* we need a cell buffer, anyhow */
+  if (cell_mode == FCELL_TYPE){ /* we might also need an fcell or dcell buffer for */
+	  fcell = G_allocate_f_raster_buf(); /* elevation data */
+  if (cell_mode == DCELL_TYPE) {
+	  dcell = G_allocate_d_raster_buf();
+  /* Open files and initialise memory for random access */
+  /* create segment files for all input raster maps and store */
+  /* raster maps in them */
+  /* input->answer is the elevation map */
+  /* store elevation map in a CELL, FCELL or DCELL segment file, */
+  /* according to its type */
+  if ( cell_mode == CELL_TYPE) {
+    Segment_infile (input->answer, old_mapset, "", &old,
+		  in_name, &in_fd, &seg_in, cell, fract, cell_mode);
+  if ( cell_mode == FCELL_TYPE) {
+		  in_name, &in_fd, &seg_in, fcell, fract, cell_mode);
+  if ( cell_mode == DCELL_TYPE) {
+		  in_name, &in_fd, &seg_in, dcell, fract, cell_mode);
+  /* store mask maps in CELL segment files */
+  if (patt_flag)
+    Segment_infile (patt_map->answer, patt_mapset, "", &patt,
+		            patt_name, &patt_fd, &seg_patt, cell, fract, CELL_TYPE);
+  if (patt_flag_v) {
+    if (same_mask)
+	  seg_patt_p_v = &seg_patt;
+    else {
+	  seg_patt_p_v = &seg_patt_v;
+	  Segment_infile (patt_map_v->answer, patt_mapset_v, "", &patt_v,
+			          patt_name_v, &patt_fd_v, seg_patt_p_v, cell, fract, CELL_TYPE);
+  Segment_named_outfile  (output->answer, current_mapset, &new,
+			  out_name_2, &out_fd_2, &seg_out_2,
+			  overwrite->answer, quiet->answer, fract, CELL_TYPE);
+  Segment_tmpfile (out_name_1, &out_fd_1, &seg_out_1, fract, CELL_TYPE);
+  /* Record name of output map if in quiet mode but not silent mode */
+  if (!silent->answer)
+      if (quiet->answer)
+	  fprintf (stdout, "\n\nOutput map is: '%s'", output->answer);
+	  if (mask->answer)
+	    fprintf (stdout, "   (masked cells = -1)");
+	  fflush (stdout);
+  /* Perform analysis of the type requested                              */
+  /* earth curvature correction threshold */
+    DIST_CC = atof (curvature_corr->answer);
+    Re = 6356766.0; /* radius of Earth in m */
+  /* set attributes to default values */
+    SPOT = 0.0;
+    SPOT_SET = 0;
+    OFFSETB = 0.0;
+    OFFSETB_SET = 0;
+    AZIMUTH1 = 0.0;
+    AZIMUTH1_SET = 0;
+    AZIMUTH2 = 360.0;
+    AZIMUTH2_SET = 0;
+    VERT1 = 90.0;
+    VERT1_SET = 0;
+    VERT2 = -90.0;
+    VERT2_SET = 0;
+    RADIUS1 = 0.0;
+  /* check for global attributes */
+  if (spot->answer != NULL) {
+  	SPOT = atof (spot->answer);
+	SPOT_SET = 1;
+  if (offseta->answer != NULL) {
+  	obs_elev = atof (offseta->answer);
+  if (offsetb->answer != NULL) {
+  	OFFSETB_SET = 1;
+	OFFSETB = atof (offsetb->answer);
+  if (azimuth1->answer != NULL) {
+  	AZIMUTH1 = atof (azimuth1->answer);
+  	AZIMUTH1_SET = 1;
+  if (azimuth2->answer != NULL) {
+  	AZIMUTH2 = atof (azimuth2->answer);
+	AZIMUTH2_SET = 1;
+  if (vert1->answer != NULL) {
+  	VERT1 = atof (vert1->answer);
+	VERT1_SET = 1;
+  if (vert2->answer != NULL) {
+  	VERT2 = atof (vert2->answer);
+	VERT2_SET = 1;
+  if (radius2->answer != NULL) {
+  	max_dist = atof (radius2->answer);
+  if ((radius1->answer != NULL) && (atof (radius1->answer) < max_dist)) {
+  	RADIUS1 = atof (radius1->answer);
+  /* use all raster cells in input map as observer locations (!) */
+  if (strcmp (type->answer, "all") == 0)
+    scan_all_cells (nrows, ncols,
+		    &seg_in, &seg_out_1, &seg_out_2, &seg_patt,
+		    seg_patt_p_v, &attempted_sample, &actual_sample,
+		    quiet->answer, cell_mode);
+  /* use a gridded set of raster cells as observer locations */
+  if (strcmp (type->answer, "systematic") == 0)
+    systematic_sample (nrows, ncols,
+		       &actual_sample, quiet->answer,
+		       absolute->answer, cell_mode);
+  /* use a random set of raster cells as observer locations */
+  if (strcmp (type->answer, "random") == 0) {
+      Segment_tmpfile (rnd_name, &rnd_fd, &seg_rnd, fract, CELL_TYPE);
+      random_sample (nrows, ncols,
+		     seg_patt_p_v, &seg_rnd,
+		     &attempted_sample, &actual_sample,
+		     replace->answer, quiet->answer,
+      Close_segmented_tmpfile (rnd_name, rnd_fd, &seg_rnd);
+  /* do a point sample using site locations */
+  if (strcmp (type->answer, "sites") == 0)
+    point_sample (&window, nrows, ncols,
+		  sites->answer, quiet->answer, cell_mode, ignore->answer);
+  /* Tidy up                                                             */
+  /* write result file */
+  Close_segmented_outfile (output->answer, new, out_name_2, out_fd_2,
+			               &seg_out_2, cell, quiet->answer,
+  						   &seg_in, cell_mode, make_nulls);
+  /* Close remaining files */
+  Close_segmented_infile (old, in_name, in_fd, &seg_in);
+  if (patt_flag)
+    Close_segmented_infile (patt, patt_name, patt_fd, &seg_patt);
+  if ((patt_flag_v) && (! same_mask))
+    Close_segmented_infile (patt_v, patt_name_v, patt_fd_v,
+			    seg_patt_p_v);
+  Close_segmented_tmpfile (out_name_1, out_fd_1, &seg_out_1);
+  /* Remind user about value used to indicate NULL data */
+  if ((! quiet->answer) && mask->answer)
+  /* Provide user with info about actual sampling frequencies */
+    sample = attempted_sample;
+  if (! quiet->answer)
+      fprintf (stdout, "\n");
+      fflush (stdout);
+      if (absolute->answer)
+	  fprintf (stdout,
+		   "\nSample: requested = %8.5lf  attempted = %8.5lf  actual = %8.5lf\n", sample, attempted_sample, actual_sample);
+      else
+	  fprintf (stdout,
+		   "\nSample: requested = %8.5lf%%  attempted = %8.5lf%%  actual = %8.5lf%%\n", sample, attempted_sample, actual_sample);
+      fflush (stdout);
+  /* Create support files */
+    fprintf (stdout, "\nCreating support files "); fflush (stdout);
+  /* Create category file for output map */
+  G_read_cats (output->answer, current_mapset, &cats);
+  G_set_cats_fmt ("$1 cell$?s", 1.0, 0.0, 0.0, 0.0, &cats);
+  G_write_cats (output->answer, &cats);
+  G_free_cats (&cats);
+  /* Create history support file for output map */
+  G_short_history (output->answer, "raster", &history);
+  history.edlinecnt = 4;
+  sprintf (history.edhist [0], "Sample type = %s", type->answer);
+  sprintf (history.edhist[1], "Requested = %8.5lf%%", sample);
+  sprintf (history.edhist[2], "Attempted = %8.5lf%%", attempted_sample);
+  sprintf (history.edhist[3], "Actual = %8.5lf%%", actual_sample);
+  if (G_write_history (output->answer, &history) == -1)
+    G_warning ("Failed to write history file ");
+    fprintf (stdout, "\nJob finished\n");
+  return (0);
Added: grass-addons/grass6/raster/r.cva/make_list3.c
--- grass-addons/grass6/raster/r.cva/make_list3.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/make_list3.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,149 @@
+/*	make_list3.c                                       	*/
+/*	This function adds a new point to the point list	*/
+/*	for any segment of the map.				*/
+/* Modified from r.los by Mark Lake on 14/12/95 to:-
+ * 1) Add a new point to the list of cells that are
+ *    potentially visible from the current viewpoint,
+ *    i.e. which are within the maximum visible
+ *    distance.
+ * 1) Calls make_point.c version 3;
+ * 2) Passes cell_no to make_point.c.
+ * 1) See main3.c.
+ * 1) Recieves cell_no and passes it on to make_point.c.
+ * Called by:
+ * 1) segment
+ * Calls:
+ * 1) make_point
+ * 2) find_orientation
+ * 3) find_inclination
+#include "point.h"
+#define		NEXT_PT		PRESENT_PT->next
+struct point *make_list(struct point *head, int y, int x,
+			SEGMENT *seg_in_p, SEGMENT *seg_out_p,
+			double viewpt_elev, int quadrant,
+			int row_viewpt, int col_viewpt, CELL cell_no,
+			RASTER_MAP_TYPE data_type)
+    double del_x,del_y,dist,sqrt(),orientation,inclination,
+    find_orientation(), find_inclination();
+    struct point *make_point();
+    static struct point  *PRESENT_PT;
+    extern double AZIMUTH1;
+    extern double AZIMUTH2;
+    extern double VERT1;
+    extern double VERT2;
+    extern int AZIMUTH1_SET;
+    extern int AZIMUTH2_SET;
+    extern int VERT1_SET;
+    extern int VERT2_SET;
+    extern double max_dist;
+    double v_angle, h_angle;
+    del_x= abs(x)  ;
+    del_y= abs(y)  ;
+    dist = sqrt(del_x*del_x +del_y*del_y) * window.ns_res;
+    /* if distance from viewpt is greater than the max	*/
+    /* range specified, neglect that point			*/
+    if (dist > max_dist) {
+	  return(head);
+    /* otherwise find orientation and inclination		*/
+    orientation = find_orientation(x,y,quadrant);
+    inclination = find_inclination(x,y,viewpt_elev,seg_in_p,
+				   row_viewpt,col_viewpt, data_type);
+    /* check, if limits are imposed on orientation and inclination */
+    if ( AZIMUTH1_SET ) {
+        h_angle = orientation * (180.0 / 3.14159265359);
+	h_angle = 360 - h_angle;
+	h_angle = h_angle + 90;
+	if (h_angle > 360) {
+		h_angle = h_angle - 360;
+    	if (h_angle < AZIMUTH1) {
+		return (head);
+    if ( AZIMUTH2_SET ) {
+   	if (h_angle > AZIMUTH2) {
+		return (head);
+    if ( VERT1_SET ) {
+    	v_angle = inclination * (180.0 / 3.14159265359);
+	if (v_angle > VERT1) {
+		return (head);
+    if ( VERT2_SET ) {
+	if (v_angle < VERT2) {
+		return (head);
+#ifdef DEBUG
+    printf ("\nlist y = %d, x = %d", y, x);
+#endif
+    if(head == NULL)
+    {  			    /* 	first point ? 		*/
+	head= make_point(orientation,inclination,y,x,
+			 row_viewpt,col_viewpt,seg_out_p,cell_no);
+	PRESENT_PT = head;
+    else
+    {	/*	add new point to tail of list		*/
+	NEXT_PT = make_point(orientation,inclination,y,x,
+        PRESENT_PT = NEXT_PT ;
+    return(head);
+/********** END OF FUNCTION "MAKE_LIST" *************************/
Added: grass-addons/grass6/raster/r.cva/make_point3.c
--- grass-addons/grass6/raster/r.cva/make_point3.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/make_point3.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,88 @@
+/*	make_point3.c	                                	*/
+/*	This function allocates memory space for a new point,	*/
+/*	initializes the various fields using the values of	*/
+/*	the parameters passed and returns the address of this	*/
+/*	new point so that it can be attached in the linked	*/
+/*	list.							*/
+ * 1) Create a new point on a segment list.
+ * 1) Receives cell_no and uses it to determine whether or not
+ *    to initialise segment file with value 0.  Allows main3.c
+ *    to count only those cells on a list which have the value 0.
+ *    Since main3.c writes cell_no once a cell has been counted,
+ *    this ensures that cells which occur on more than one list
+ *    are counted only once.  If the segment file already contains
+ *    the current cell_no then the cell has already been deleted
+ *    during the current los analysis and should not be
+ *    reinitialised.
+ * 1) See main3.c.
+ * 1) Initialises segment file with value zero if not already
+ *    deleted during the the current los analysis.
+ * Called by:
+ * 1) make_list
+ * Calls:
+ * 1)  None.
+#include "point.h"
+#define NULL_HERE 0
+#define		NEW_PT_X		NEW_PT->x
+#define		NEW_PT_Y		NEW_PT->y
+#define		NEW_PT_ORIENTATION	NEW_PT->orientation
+#define		NEW_PT_INCLINATION	NEW_PT->inclination
+#define		NEXT_NEW_PT		NEW_PT->next
+struct point *make_point( double orientation, double inclination,
+			  int y, int x, int row_viewpt, int col_viewpt,
+			  SEGMENT *seg_out_p, CELL cell_no)
+    struct point *NEW_PT;
+    NEW_PT = (struct point *) G_malloc(sizeof(struct point));
+    NEW_PT_ORIENTATION = orientation;
+    NEW_PT_INCLINATION = inclination;
+    NEW_PT_Y           = y;
+    NEW_PT_X           = x;
+    NEXT_NEW_PT        = NULL_HERE;
+    data_to_write = 0;
+    segment_get (seg_out_p, value_read,
+		 row_viewpt - y, x + col_viewpt);
+    if (data_read != cell_no)
+	segment_put (seg_out_p, value_to_write,
+    return(NEW_PT);
+/********* END OF FUNCTION "MAKE_POINT" *************************/
Added: grass-addons/grass6/raster/r.cva/point.h
--- grass-addons/grass6/raster/r.cva/point.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/point.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,38 @@
+#ifndef __POINT_H__
+#define __POINT_H__
+/*	point.h		in	~/src/Glos			*/
+/*	This header file defines the data structure of a 	*/
+/*	point (structure containing various attributes of	*/
+/*	a grid cell).						*/
+	struct point {
+        double orientation;
+	/* horizontal angle(degrees) measured from +ve x-axis	*/
+        double inclination;
+	/* vertical angle(degrees) from the viewing point	*/
+	double probability;
+	/* for probabilistic viewsheds: this stores the probability
+	   of the point being visible */
+        int x;	/* x-coor measured from viewing point location	*/
+        int y;	/* y-coor measured from viewing point location  */
+        struct point *next;	/* pointer to next point in list*/
+        struct point *previous; /* ptr to previous pt. in list	*/
+#endif
Added: grass-addons/grass6/raster/r.cva/point_sample.c
--- grass-addons/grass6/raster/r.cva/point_sample.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/point_sample.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,329 @@
+  point_sample.c
+  CONTAINS
+  1) point_sample                                                      */
+  point_sample
+  Called from:
+  1) main                   main.c
+  Calls:
+  1) line_of_sight          line_of_site.c
+  2) count_visible_cells    count_visible_cells.c
+  3) cumulate_visible_cells cumulate_visible_cells.c
+  4) delete_lists           delete_lists.c                             */
+#include <grass/Vect.h>
+#include <grass/dbmi.h>
+#include "point.h"
+#include "init_segment_file.h"
+#include "line_of_sight.h"
+#include "count_visible_cells.h"
+#include "cumulate_visible_cells.h"
+#include "delete_lists.h"
+void point_sample (struct Cell_head *window, int nrows, int ncols,
+		   SEGMENT *seg_out_2_p, SEGMENT *seg_patt_p,
+		   SEGMENT *seg_patt_p_v,
+		   double *attempted_sample, double *actual_sample,
+		   char *site_file, int terse, RASTER_MAP_TYPE data_type,
+		   int ignore_att)
+  int row_viewpt, col_viewpt;
+  /* 'value' stores a byte-sized (CELL) item from the mask segment file(s) */
+  void *value = NULL;
+  CELL cell_no;
+  double viewpt_elev = 0;
+  struct point *heads[16];
+  long int sites_in_region, sites_of_interest, cells_in_map;
+  int null_value;
+  char *site_mapset;
+  CELL mask = 0;
+  long num_sites = 0;
+  /* the following are used to store different raster map types */
+  CELL c_value;
+  FCELL f_value;
+  DCELL d_value;
+  struct Map_info in_vect_map;
+  struct line_pnts *vect_points;
+  struct line_cats *vect_cats;
+  int cur_type;
+  char errmsg [200];
+  double x,y,z;
+  int n_points = 1;
+  /* site attribute management */
+  int i;
+  struct field_info *field;
+  char     buf[5000], *colname;
+  int      dbcol, dbncols, ctype, sqltype, more;
+  dbString sql, str;
+  dbDriver *driver;
+  dbHandle handle;
+  dbCursor cursor;
+  dbTable  *table;
+  dbColumn *column;
+  dbValue  *dbvalue;
+  vect_points = Vect_new_line_struct ();
+  vect_cats = Vect_new_cats_struct ();
+  if ((site_mapset = G_find_vector2 (site_file, "")) == NULL) {
+    sprintf (errmsg, "Could not find input vector map %s\n", site_file);
+    G_fatal_error (errmsg);
+  Vect_set_open_level (1);
+  if (1 > Vect_open_old (&in_vect_map, site_file, site_mapset)) {
+    sprintf (errmsg, "Could not open input vector points.\n");
+  /* Initialise output segment file with appropriate data value */
+  init_segment_file (nrows, ncols, seg_out_2_p, seg_patt_p);
+  /* Initialise variables */
+  cells_in_map = nrows * ncols;
+  sites_in_region = 0;
+  sites_of_interest = 0;
+  cell_no = 0;
+  /* filter vector objects to current region and point types only */
+  Vect_set_constraint_region (&in_vect_map, window->north, window->south,
+			      window->east, window->west, 0.0, 0.0);
+  Vect_set_constraint_type (&in_vect_map, GV_POINT);
+  /* calculate number of vector points in map and current region */
+  while ((cur_type = Vect_read_next_line (&in_vect_map, vect_points, NULL)) > 0) {
+      num_sites ++;
+  /* rewind vector points file: close and re-open */
+  Vect_close (&in_vect_map);
+  Vect_open_old(&in_vect_map, site_file, site_mapset);
+  /* Traverse site list  */
+  while ((cur_type = Vect_read_next_line (&in_vect_map, vect_points, vect_cats)) > 0) {
+    mask = 0;
+    cell_no ++;
+    /* check for site attributes */
+    for (i = 0; i < vect_cats->n_cats; i++) {
+    	field = Vect_get_field( &in_vect_map, vect_cats->field[i]);
+	if ((field != NULL) && (!ignore_att)) {
+		db_init_string (&sql);
+		driver = db_start_driver(field->driver);
+		db_init_handle (&handle);
+		db_set_handle (&handle, field->database, NULL);
+		if (db_open_database(driver, &handle) == DB_OK){
+			/* sql query */
+			sprintf (buf, "select * from %s where %s = %d", field->table,
+									field->key,
+									vect_cats->cat[i]);
+			db_set_string (&sql, buf);
+			db_open_select_cursor(driver, &sql, &cursor, DB_SEQUENTIAL);
+			table = db_get_cursor_table (&cursor);
+			db_fetch (&cursor, DB_NEXT, &more );
+			dbncols = db_get_table_number_of_columns (table);
+			for( dbcol = 0; dbcol < dbncols; dbcol++) {
+				column = db_get_table_column(table, dbcol);
+				sqltype = db_get_column_sqltype (column);
+				ctype = db_sqltype_to_Ctype(sqltype);
+				dbvalue  = db_get_column_value(column);
+				db_convert_value_to_string( dbvalue, sqltype, &str);
+				colname = db_get_column_name (column);
+				/* check if we have some of the supported attributes */
+				if (ctype == DB_C_TYPE_DOUBLE) {
+					if (!strcmp (colname,"SPOT")){
+						SPOT = atof (db_get_string (&str));
+						SPOT_SET = 1;
+					if (!strcmp (colname,"OFFSETA")){
+						obs_elev = atof (db_get_string (&str));
+					if (!strcmp (colname,"OFFSETB")){
+						OFFSETB_SET =1;
+						OFFSETB = atof (db_get_string (&str));
+					if (!strcmp (colname,"AZIMUTH1")){
+						AZIMUTH1 = atof (db_get_string (&str));
+						AZIMUTH1_SET = 1;
+					if (!strcmp (colname,"AZIMUTH2")){
+						AZIMUTH2 = atof (db_get_string (&str));
+						AZIMUTH2_SET = 1;
+					if (!strcmp (colname,"VERT1")){
+						VERT1 = atof (db_get_string (&str));
+						VERT1_SET = 1;
+					if (!strcmp (colname,"VERT2")){
+						VERT2 = atof (db_get_string (&str));
+						VERT2_SET = 1;
+					if (!strcmp (colname,"RADIUS1")){
+						RADIUS1 = atof (db_get_string (&str));
+					if (!strcmp (colname,"RADIUS2")){
+						max_dist = atof (db_get_string (&str));
+			db_close_cursor(&cursor);
+			db_close_database(driver);
+			db_shutdown_driver(driver);
+		} else {
+    Vect_copy_pnts_to_xyz (vect_points, &x, &y, &z, &n_points);
+    /* If site falls within current region */
+	  sites_in_region ++;
+	  /* Get array coordinates of viewpoint */
+	  /* row_viewpt = (window->north - site->north) / window->ns_res;
+          col_viewpt = (site->east - window->west) / window->ew_res;
+	  row_viewpt = G_northing_to_row ( y, window );
+	  col_viewpt = G_easting_to_col ( x, window );
+	  /* Check whether viewpoint is in area of interest */
+	    value = (char*) &mask;
+	    segment_get(seg_patt_p_v, value, row_viewpt, col_viewpt);
+	  } else
+	    mask = 1;
+	  /* Only include if viewpoint is in area of interest */
+	  if (mask == 1) {
+	    sites_of_interest ++;
+	    /* We do not check for duplicates because it is possible
+		in cases of low resolution that two or more sites with
+		different map coordinates could have the same array
+		coordinates */
+	    /* Read elevation of current view point */
+	    if ( data_type == CELL_TYPE ) {
+	      value = (CELL*) &c_value;
+	    if ( data_type == FCELL_TYPE ) {
+	      value = (FCELL*) &f_value;
+	    if ( data_type == DCELL_TYPE ) {
+	      value = (DCELL*) &d_value;
+	    null_value = 0;
+	    segment_get (seg_in_p, value, row_viewpt, col_viewpt); /* height now in value */    														     /* and in read_viewpt_elev */
+		viewpt_elev = c_value + obs_elev;
+		if (G_is_c_null_value (&c_value)) {
+			null_value = 1;
+	    	viewpt_elev = f_value + obs_elev;
+		if (G_is_f_null_value (&f_value)) {
+			null_value = 1;
+	    	viewpt_elev = d_value + obs_elev;
+		if (G_is_d_null_value (&d_value)) {
+			null_value = 1;
+	    /* skip sites on NULL dem cells */
+	    if (!null_value) {
+	    	if (SPOT_SET) {
+	       		if (ADJUST) {
+				if (SPOT >= viewpt_elev) {
+					viewpt_elev = SPOT + obs_elev;
+	       		} else {
+	    			viewpt_elev = SPOT;
+	    	/* Do line of sight analysis from current viewpoint */
+		/* this updates the information in 'heads', defined in 'point.h' */
+	    	line_of_sight (cell_no, row_viewpt, col_viewpt,
+			           nrows, ncols, viewpt_elev,
+			           heads, seg_in_p, seg_out_1_p, seg_patt_p,
+			           patt_flag, data_type);
+	    	/* Calculate viewshed */
+	    	if (! from_cells) {
+			count_visible_cells (cell_no, row_viewpt, col_viewpt,
+		                       seg_out_1_p, seg_out_2_p, seg_patt_p, heads);
+		} else
+			cumulate_visible_cells (cell_no, row_viewpt, col_viewpt,
+	    	/* Free memory used in line-of-sight analysis */
+	    	delete_lists (heads);
+	    /* Print progress message */
+	    if (!terse) {
+			G_percent (sites_of_interest, num_sites, 1);
+	  } /* END (if (mask == 1)) */
+  } /* END (loop through sites list) */
+  /* Calculate_sample */
+  /* % of cells in region */
+  *attempted_sample = 100.0 / (double) cells_in_map * (double) sites_in_region;
+  /* % of cells in area of interest */
+  *actual_sample = 100.0 / (double) cells_in_map * (double) sites_of_interest;
+#ifdef DEBUG
+  fprintf (stdout, "\nSites in: region = %ld, area of interest = %ld",
+	   sites_in_region,
+	   sites_of_interest);
+  fflush (stdout);
+#endif
Added: grass-addons/grass6/raster/r.cva/point_sample.h
--- grass-addons/grass6/raster/r.cva/point_sample.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/point_sample.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,15 @@
+#ifndef __POINT_SAMPLE_H__
+#define __POINT_SAMPLE_H__
+#include <grass/gis.h>
+#include <grass/segment.h>
+		   int ignore_att);
+#endif
Added: grass-addons/grass6/raster/r.cva/pts_elim3.c
--- grass-addons/grass6/raster/r.cva/pts_elim3.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/pts_elim3.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,550 @@
+/*	pts_elim3.c 	                                	*/
+/*	This function prunes a linked list of all points 	*/
+/*	picked up from a map segment to leave only those	*/
+/*	points in the list that are visible from the viewpt.	*/
+ * Updated by Mark Lake on 17/8/01 for GRASS 5.x
+ * 1) Eliminate invisible cells from a segment list.
+ * Version 3.0, differs from v.1.0 as follows:-
+ * 1) Calls delete.c version 3;
+ * 2) Receives cell_no and passes it to delete.c.
+ * Implicated files:-
+ * 1) See main3.c.
+ * Modifications to r.los:-
+ * 1) Recieves cell_no and passes it on to delete.c.
+ * Called by:
+ * 1) segment
+ * Calls:
+ * 1) find_orientation
+ * 2) find_inclination
+ * 3) delete
+#include <stdlib.h>
+#include <math.h>
+#include "config.h"
+#include "pts_elim3.h"
+#include "point.h"
+#include "radians.h"
+#include "global_vars.h"
+#define	  SECOND_PT			head->next
+#define   NEXT_BLOCKING_PT		BLOCKING_PT->next
+#define   BLOCKING_PT_X	 		BLOCKING_PT->x
+#define   BLOCKING_PT_Y			BLOCKING_PT->y
+#define   BLOCKING_PT_INCLINATION 	BLOCKING_PT->inclination
+#define   BLOCKING_PT_ORIENTATION	BLOCKING_PT->orientation
+#define   NEXT_CHECKED_PT		CHECKED_PT->next
+#define	  CHECKED_PT_X			CHECKED_PT->x
+#define	  CHECKED_PT_Y			CHECKED_PT->y
+#define	  CHECKED_PT_INCLINATION	CHECKED_PT->inclination
+#define   CHECKED_PT_ORIENTATION	CHECKED_PT->orientation
+/*	This function takes a linked list of points picked	*/
+/*	up from a segment of the map and deletes all the points	*/
+/*	from the list that are not visible from the viewing pt.	*/
+struct point *hidden_point_elimination (struct point *head,
+					SEGMENT *seg_patt_p,
+					int quadrant,
+					int sign_on_y, int sign_on_x,
+					int patt_flag, CELL cell_no,
+    struct point *CHECKED_PT, *BLOCKING_PT, *delete();
+    double orientation_neighbor_1,orientation_neighbor_2,
+    find_orientation(),inclination_neighbor_1,
+    inclination_neighbor_2,interpolated_inclination,
+    find_inclination(),find_inclination2(),correct_neighbor_inclination,
+    correct_neighbor_orientation,fabs();
+    int correct_neighbor_x,correct_neighbor_y,neighbor_1_y,
+    neighbor_1_x,neighbor_2_x,neighbor_2_y, uu,vv;
+    CELL mask;
+    char *value;
+    int do_check = 1;
+    extern double RADIUS1;
+    extern int OFFSETB_SET;
+    double del_x, del_y,dist,atan(),sqrt();
+    uu = (sign_on_y + sign_on_x)/2;
+    vv = (sign_on_y - sign_on_x)/2;
+    value = (char *) &mask;
+#ifdef DEBUG
+    printf ("\nrow = %d, col = %d", row_viewpt, col_viewpt);
+    fflush (stdout);
+#endif
+    /*   move blocking pt. from the 2nd pt till the end	*/
+    for(BLOCKING_PT  = SECOND_PT;
+	BLOCKING_PT != NULL;
+	BLOCKING_PT  = NEXT_BLOCKING_PT)
+#ifdef DEBUG
+      printf ("\nBlocking point y = %d, x = %d",
+	      BLOCKING_PT_Y, BLOCKING_PT_X);
+      fflush (stdout);
+#endif
+	/*   calc coors of the two immediate neighbors on either  */
+	/*   side of the blocking point                           */
+	if(BLOCKING_PT_X == 0 || BLOCKING_PT_Y == 0)
+	    neighbor_1_x = BLOCKING_PT_X - vv;
+	    neighbor_1_y = BLOCKING_PT_Y + uu;
+	    neighbor_2_x = BLOCKING_PT_X + uu;
+	    neighbor_2_y = BLOCKING_PT_Y + vv;
+	else
+	    neighbor_1_x = BLOCKING_PT_X - uu;
+	    neighbor_1_y = BLOCKING_PT_Y - vv;
+	    neighbor_2_x = BLOCKING_PT_X + vv;
+	    neighbor_2_y = BLOCKING_PT_Y - uu;
+	/*   find orientation and inclination for both neighbors	*/
+	orientation_neighbor_1 =
+	    find_orientation(neighbor_1_x,neighbor_1_y,quadrant);
+	orientation_neighbor_2 =
+	    find_orientation(neighbor_2_x,neighbor_2_y,quadrant);
+	inclination_neighbor_1 =
+	    find_inclination(neighbor_1_x,neighbor_1_y,viewpt_elev,
+			     seg_in_p,row_viewpt,col_viewpt, data_type);
+	inclination_neighbor_2 =
+	    find_inclination(neighbor_2_x,neighbor_2_y,viewpt_elev,
+	/*   check all points behind the blocking point		*/
+	for(CHECKED_PT  = head;
+	    CHECKED_PT != BLOCKING_PT;
+	    CHECKED_PT  = NEXT_CHECKED_PT)
+#ifdef DEBUG
+	  printf ("\nChecked point y = %d, x = %d",
+		  CHECKED_PT_Y, CHECKED_PT_X);
+	  fflush (stdout);
+#endif
+	    /*   if pattern layer specified, check to see if checked	*/
+	    /*   point is of interest. If not, delete it from list	*/
+	    if(patt_flag == 1)
+		segment_get(seg_patt_p,value,
+			    row_viewpt-CHECKED_PT_Y,col_viewpt+CHECKED_PT_X);
+		if(mask == 0)
+		    head=delete(CHECKED_PT,head,seg_out_p,
+				row_viewpt,col_viewpt,cell_no);
+		    goto next_iter;
+	    /* if the OFFSETB parameter is set, we will raise the height of only the
+	       target point under consideration, leaving all blocking points the
+	       way they are. This improves visibility of current target point and
+	       simulates an object of a known height */
+	    if (OFFSETB_SET) {
+	    	CHECKED_PT_INCLINATION = find_inclination2(CHECKED_PT_X,CHECKED_PT_Y,viewpt_elev,
+	    do_check = 1;
+	    /* no need to check if this condition holds true */
+	    if(BLOCKING_PT_INCLINATION <= CHECKED_PT_INCLINATION) {
+	       do_check = 0;
+	    if (BLOCKING_PT_INCLINATION == NULLPT) {
+	       do_check = 0;
+            /* delete this point, if it lies closer than the minimum distance */
+	    del_x = abs(CHECKED_PT_X);
+    	    del_y = abs(CHECKED_PT_Y);
+    	    dist=sqrt(del_x * del_x + del_y * del_y)*window.ns_res;
+	    if ( dist < RADIUS1) {
+		head= delete(CHECKED_PT,head,seg_out_p,row_viewpt,col_viewpt,cell_no);
+		   do_check = 0;
+	    if (do_check == 1)
+	    {  	/*   otherwise, proceed to check */
+		if(CHECKED_PT_ORIENTATION == BLOCKING_PT_ORIENTATION)
+		/*   if checked point directly behind, delete it */
+		else
+		{	/*   if checked point not directly behind, check */
+		    /*   find the coors of the actual neighbor that might be  */
+		    /*   required for interpolation.			      */
+		    if(CHECKED_PT_ORIENTATION > BLOCKING_PT_ORIENTATION)
+			correct_neighbor_x = neighbor_1_x;
+			correct_neighbor_y = neighbor_1_y;
+			correct_neighbor_inclination = inclination_neighbor_1;
+			correct_neighbor_orientation = orientation_neighbor_1;
+		    else
+			correct_neighbor_x = neighbor_2_x;
+			correct_neighbor_y = neighbor_2_y;
+			correct_neighbor_inclination = inclination_neighbor_2;
+			correct_neighbor_orientation = orientation_neighbor_2;
+		    if(fabs(BLOCKING_PT_ORIENTATION-CHECKED_PT_ORIENTATION) <
+		       fabs(BLOCKING_PT_ORIENTATION-correct_neighbor_orientation))
+		    { /*   yes, the point neighboring the blocking point */
+		      /*    must be taken into consideration		 */
+			if(CHECKED_PT_Y == correct_neighbor_y &&
+			   CHECKED_PT_X == correct_neighbor_x);	/*   same point */
+			else
+			{     /*   CHECK !! */
+			    /*   if the checked point's inclination is even lower  */
+			    /*   than that of the blocking pt.'s neighbor, blocked */
+			    if(CHECKED_PT_INCLINATION < correct_neighbor_inclination)
+			    else
+			    {	/*   INTERPOLATION */
+				interpolated_inclination= BLOCKING_PT_INCLINATION +
+				    (CHECKED_PT_ORIENTATION - BLOCKING_PT_ORIENTATION)/
+					(correct_neighbor_orientation-BLOCKING_PT_ORIENTATION)*
+					    (correct_neighbor_inclination - BLOCKING_PT_INCLINATION);
+				if(CHECKED_PT_INCLINATION < interpolated_inclination)
+				{	/*   interpolated point blocks */
+	  next_iter:
+	}       /*   end of loop over points to be checked */
+	/*   if pattern layer specified, check if blocking point */
+	/*   itself is an area of interest. If not, of no use	 */
+	    segment_get(seg_patt_p, value,row_viewpt- BLOCKING_PT_Y,
+			col_viewpt+BLOCKING_PT_X);
+	    if(mask == 0)
+	      /* Commenting out the following fixes a bug in r.los.
+		 In that program the 8 cells around the viewpoint
+		 are marked as visible (when visible)
+		 even if they fall outside the area of interest
+		 specified by the patt_map.  This occurs because
+		 these cells are always the last blocking points
+		 on the segment lists, and therefore don't get
+		 deleted when they should.  This fix allows them
+		 to be deleted, but it required modifications
+		 to delete, in delete3.c.  MWL 25/6/99 */
+	      /* if (NEXT_BLOCKING_PT != NULL) */
+	      head = delete(BLOCKING_PT, head, seg_out_p,
+				  row_viewpt, col_viewpt,cell_no);
+    }       /*   end of loop over blocking points */
+    return(head);
+/*********** END OF FUNCTION "HIDDEN_POINT_ELIMINATION" *********/
+/* Called by:-
+ * 1) make_list()
+ * 2) hidden_point_elimination()
+ * Calls:-
+ * 1) None.
+/*	This function finds the orientation of a point if	*/
+/*	provided with the number of the quadrant and the	*/
+/*	coordinates of that point.				*/
+double find_orientation(int x, int y, int quadrant)
+    double del_x,del_y,atan(),angle;
+    int abs();
+    del_x = abs(x) ;
+    del_y = abs(y);
+    if(del_x == 0.0) angle = PIBYTWO;
+    else	angle = atan(del_y/del_x) ;
+    switch(quadrant)
+      case 1 :
+	  break;
+	case 2 :
+	    angle = PI - angle;
+	  break;
+	case 3 :
+	    angle = PI + angle;
+	  break;
+	case 4 :
+	    angle = TWOPI - angle;
+	  break;
+	default :
+	    break;
+    return(angle);
+}       /* END OF FUNCTION ANGLE */
+/************* END OF FUNCTION "FIND_ORIENTATION" ***************/
+/* Called by:-
+ * 1) make_list()
+ * Calls:-
+ * 1) None.
+/*	This function calculates the vertical angle of a point	*/
+/*	with respect to the viewing pt.				*/
+double find_inclination(int x, int y, double viewpt_elev,
+			int row_viewpt, int col_viewpt, RASTER_MAP_TYPE data_type)
+    int abs();
+    double dest_elev = 0.0;
+	/* these vars can store one data value from the elevation input map, */
+	/* which could be CELL, DCELL or FCELL type. */
+    CELL c_value;
+    FCELL f_value;
+    DCELL d_value;
+    del_x = abs(x) ;
+    del_y = abs(y) ;
+    	/* this takes care, that target elevation has the right format,
+	   depending on type of input DEM */
+	if (data_type == CELL_TYPE) {
+	if (data_type == FCELL_TYPE) {
+	if (data_type == DCELL_TYPE) {
+    /* read value from elevation input map, convert to appropriate */
+	/* map type */
+    segment_get(seg_in_p,value,row_viewpt-y,x+col_viewpt);
+	  if ( G_is_c_null_value (&c_value) ) {
+	  	return (NULLPT);
+	  } else {
+	  	dest_elev = c_value;
+	  if ( G_is_f_null_value (&f_value) ) {
+	  	return (NULLPT);
+	  } else {
+	  	dest_elev = f_value;
+	  if ( G_is_d_null_value (&d_value) ) {
+	  	return (NULLPT);
+	  } else {
+	  	dest_elev = d_value;
+	/* CURVATURE CORRECTION */
+	/* decrease height of target point */
+	if (DIST_CC > 0.0) {
+		if (dist >= DIST_CC) {
+			dest_elev = dest_elev - ((dist*dist) / (2 * Re));
+    return(atan((dest_elev - viewpt_elev) / dist));
+/* THIS IS CALLED IF ONLY THE TARGET POINT UNDER CURRENT CONSIDERATION IS TO
+   BE RAISED BY 'OFFSETB' AMOUNT */
+double find_inclination2(int x, int y, double viewpt_elev,
+    int abs();
+    CELL c_value;
+    FCELL f_value;
+    DCELL d_value;
+    del_x = abs(x) ;
+    del_y = abs(y) ;
+	/* map type */
+	  	return (NULLPT);
+	  } else {
+	  	dest_elev = c_value + OFFSETB;
+	  	return (NULLPT);
+	  } else {
+	  	dest_elev = f_value + OFFSETB;
+	  	return (NULLPT);
+	  } else {
+	  	dest_elev = d_value + OFFSETB;
+/************ END OF FUNCTION "FIND_INCLINATION"*****************/
Added: grass-addons/grass6/raster/r.cva/pts_elim3.h
--- grass-addons/grass6/raster/r.cva/pts_elim3.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/pts_elim3.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,17 @@
+#ifndef __PTS_ELIM3_H__
+#define __PTS_ELIM3_H__
+int NULLPT = 999999.999999;
+					int quadrant,
+					RASTER_MAP_TYPE data_type);
+#endif
Added: grass-addons/grass6/raster/r.cva/r.cva.tmp.html
--- grass-addons/grass6/raster/r.cva/r.cva.tmp.html	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/r.cva.tmp.html	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,445 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>GRASS GIS Manual: r.cva</title>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+<link rel="stylesheet" href="grassdocs.css" type="text/css">
+</head>
+<body bgcolor="white">
+<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
+<h2>NAME</h2>
+<em><b>r.cva</b></em>
+<TITLE>r.cva</TITLE>
+<H2>NAME</H2>
+<EM><b>r.cva</b></EM>  - Cumulative viewshed analysis program.
+<BR>
+<EM>(GRASS Raster Program)</EM>
+<H2>SYNOPSIS</H2>
+<B>r.cva</B>
+<BR>
+<B>r.cva help</B>
+<BR>
+<B>r.cva</B>
+[<B>-afmnoqrs</B>]
+<B>input=</B><EM>name</EM>
+[<B>target_mask=</B><EM>name</EM>]
+[<B>viewpt_mask=</B><EM>name</EM>]
+[<B>sites=</B><EM>name</EM>]
+<B>output=</B><EM>name</EM>
+[<B>obs_elev=</B><EM>value</EM>]
+[<B>target_elev=</B><EM>value</EM>]
+[<B>max_dist=</B><EM>value</EM>]
+[<B>seed=</B><EM>value</EM>]
+[<B>sample=</B><EM>value</EM>]
+<B>type=</B><EM>value</EM>
+<H2>QUICKSTART</H2>
+To perform the most common cumulative viewshed analysis (for each cell of
+the input elevation raster map: count the number of observer sites from which it
+can be seen) type in the following:
+<p>
+<B>r.cva</B> <B>-f</B> <B>input=</B><EM>elevation</EM> <B>sites=</B><EM>observers</EM> <B>output=</B><EM>result</EM> <B>type=</B><EM>sites</EM>
+<P>
+'elevation' can be a raster map containing elevation values in CELL, FCELL or DCELL format. 'observers' must a map containing vector points.
+'result' will be an output map in CELL format containing the cumulative visibility counts for each cell.
+<A NAME = "description"><H2>DESCRIPTION</H2></A>
+<EM>r.cva</EM> generates a cumulative viewshed map.  When run without
+the <EM>-f</EM> flag each viewpoint is marked with the number of cells in its
+viewshed (i.e. that can be seen from it).  In this mode the only cells
+that contain genuine data in the output map are the viewpoints.
+Alternatively, if the <EM>-f</EM> flag is set then each cell in the
+<EM>output</EM> map is marked with the number of viewpoints from which
+it can be seen.  In either case, viewpoints may be chosen in one of
+four ways.  The first (`all') treats every cell as a viewpoint. This
+is so computationally demanding that it is unlikely to be feasible
+unless either the <EM>input</EM> map or <EM>max_dist</EM> is very
+small.  The second (`systematic') uses a systematic sample of cells
+arranged on a rectangular grid.  The third (`random') uses a random
+sample.  By default the random sampling algorithm does not allow
+replacement (i.e. a cell can be treated as a viewpoint only once), but
+this behaviour can be altered by setting the <EM>-r</EM> flag.  The
+fourth option (`sites') uses the points in the specified <EM>vector</EM>
+map. The options `systematic' and `random' allow the user to specify
+any sampling frequency between 0% and 100%.
+<p>
+The cells used in viewshed analysis can be constrained by one or both
+of two masks. Both masks should be binary raster maps in which the
+areas of interest are coded `1' and all other cells `0'.
+<EM>target_mask</EM> determines which cells are targets: a cell which
+is not a target will be returned as not visible from a given viewpoint
+even if it is actually visible according to the line-of-sight analysis
+(i.e. this mask performs the same function as <EM>patt_map</EM> in
+<EM><A HREF="../../html/r.los.html">r.los</A></EM>).  <EM>viewpt_mask</EM>
+constrains which cells may be treated as viewpoints.  For example,
+suppose that the raster map `no_sea' codes sea (elevation = 0) as `0'
+and land (elevation > 0) as `1'.  In this case, specifying `no_sea' as
+the <EM>target_mask</EM> would cause <EM>r.cva</EM> to count cells on
+land that are visible from any viewpoint.  Alternatively, specifying
+`no_sea' as the <EM>viewpt_mask</EM> would count any cells visible
+from viewpoints on land.  Finally, specifying `no_sea' as both the
+<EM>target_mask</EM> and <EM>viewpt_mask</EM> would count cells on
+land that are visible from viewpoints on land.
+<p>
+The geometry of the potential line of sight between each pair of cells
+may be altered by means of two offsets, <EM>obs_elev</EM> and
+<EM>target_elev</EM>. The height <EM>obs_elev</EM> is added to the
+viewpoint and the height <EM>target_elev</EM> to each target cell.
+Note that by swapping these values it is possible to produce maps
+showing the number of cells from which a viewpoint is visible, or if
+the <EM>-f</EM> flag is set, the number of viewpoints which it is
+possible to see from each map cell.
+<p>
+A particular set of viewpoint locations in a random sample can be
+repeated by specifying the same value for <EM>seed</EM>.
+Alternatively, different values can be used to produce independent
+samples for statistical testing.
+<p>
+The program can be run either non-interactively or interactively.  To
+run <EM>r.cva</EM> non-interactively the user must minimally specify
+the <B>input</B> and <B>output</B> maps and the <B>type</B> of
+analysis.  If the chosen <B>type</B> is `sites' then the
+<B>sites</B> list must also be specified.  Any remaining parameters
+whose values have not been specified on the command line will be set
+to their default values (see <A HREF = "#parameters">below</A>).  Non-interactive usage format is:
+<DL>
+<DD>
+<B>r.cva</B>
+[<B>-afmnoqrs</B>]
+</DL>
+<H2>OPTIONS</H2>
+<H3>Flags:</H3>
+<DL>
+<DT><B>-a</B>
+<DD> Treat the specified sample size as an absolute number of cells
+rather than a percentage.  Note, this flag is only for use with random
+sampling.
+<DT><B>-f</B>
+<DD> Mark each cell in the output map with the number of viewpoints
+from which it can be seen.
+<DT><B>-h</B>
+<DD> Adjust height of oberserver points so that they will never fall
+below surface level. This is only useful in conjunction with the
+<b>spot</b> parameter or attribute (see <A HREF ="#atributes">below</A>).
+<DT><B>-i</B>
+<DD> Do not interpret control attributes in input vector map as
+described <A HREF ="#atributes">below</A>).
+<DT><B>-m</B> <DD> Differentiate between genuine zero data values and
+null data in the output map.  When the <EM>-f</EM> flag has not been
+set this ensures that all non-viewpoint cells are coded `-1'.  When
+the <EM>-f</EM> flag has been set then all cells coded `0' in the
+<EM>target_mask</EM> (if there is one) are coded `-1'.  See <A HREF =
+"#notes">below</A> for guidance when to set this flag.
+<DT><B>-n</B> <DD> In conjunction with <B>-m</B>: write NULL values instead of '-1' to output map.
+<DT><B>-o</B>
+<DD> Overwrite the output raster map if it already exists.
+<DT><B>-q</B>
+<DD> Be quiet about progress, confirming only the output file and
+sampling frequency.  This is useful when <EM>r.cva</EM> is invoked from a
+script with standard output redirected to a disk file.
+<DT><B>-r</B>
+<DD> Allow replacement during random sampling (i.e. allow a given cell
+to be picked as a viewpoint more than once).  Note that no cumulation
+occurs for replacement viewpoints; this ensures that the resulting
+cumulative viewshed will be as though the viewpoint was selected once
+only (the final output map will, of course, be different because
+replacement effectively results in the use of fewer viewpoints for a
+given sampling frequency).
+<DT><B>-s</B> <DD>Be silent about progress, in which case it is
+strongly recommended that you use <EM><A
+HREF="../../html/r.info.html">r.info</A></EM> to confirm what sampling frequency
+was actually achieved.
+<A NAME = "parameters"><H3>Parameters:</H3></A>
+<DT><B>input=</B><EM>name</EM>
+<DD>Name of a raster map layer containing elevation
+data, used as program input.
+<DT><B>target_mask=</B><EM>name</EM> <DD>Name of a binary raster map
+layer in which target cells within the areas of interest are assigned
+the category value `1' and all other cells are assigned the category
+value `0'.  A cell is treated as a target when it is viewed from a
+viewpoint (note, therefore, that viewpoints are targets when viewed
+from other viewpoints).
+<DT><B>viewpt_mask=</B><EM>name</EM>
+<DD>Name of a binary raster map layer in which viewpoints within the areas
+of interest are assigned the category value `1' and all other cells
+are assigned the category value `0'.
+<DT><B>sites=</B><EM>name</EM>
+<DD>The name of a vector map containing the sites (vector points) that are to be treated as
+viewpoints.  Sites falling outside the current region are ignored.
+<DT><B>obs_elev=</B><EM>value</EM>
+<DD>Height of the observer (in metres) above the elevation of the
+viewpoint.  Default: 1.75 m
+<DT><B>target_elev=</B><EM>value</EM>
+<DD>Height of the object of interest (in metres) above the elevation
+of the target cell.  Default: 0.0 m
+<DT><B>max_dist=</B><EM>value</EM>
+<DD>Maximum distance (in metres) from the viewing point within which
+the line-of-sight analysis will be performed.  Options: 0-99999
+(stated in map units). Default: 100
+<DT><B>seed=</B><EM>value</EM>
+<DD>The seed for the random number generator used during random
+sampling.  This option allows exact reproduction of a previous result.
+Options: 0-32767. Default: 1
+<DT><B>sample=</B><EM>value</EM>
+<DD>The sampling frequency as a percentage of the number of map cells
+in the current region.  Options: 0.0-100.0. Default: 10.0
+<DT><B>type=</B><EM>value</EM> <DD>The type of sampling regime used to
+select viewpoints for analysis. See <A HREF = "#description">above</A>
+for details.  Options: `all', `systematic', `random', `sites'.
+<DT><B>spot, offseta, offsetb, azimuth1, azimuth2, vert1, vert2, radius1, radius2</B>
+<DD> See <A HREF ="#atributes">below</A>) for a description of what they do.
+<DT><B>curvc=</B><EM>value</EM>
+<DD>Earth curvature correction will be applied if the distance from the observer
+point exceeds the given threshold. Set this to 0.0 to disable curvature correction
+(default). While correction slows down calculations, it is recommend for
+viewing distances of more than about 3 km. The correction uses a simplified
+formula which is accurate to 1 in 10,000 for distances up to 40 km:<p>
+<i>d(height)=dist^2/(2*Re)</i><p>
+With <i>Re</i> being the radius of the earth (ca. 6,356,766 m).
+</DL>
+<A NAME = "attributes"><H3>Vector map attributes:</H3>
+When using 'sites' type operation mode, <EM>r.cva</EM> checks for the
+presence of a number of attributes in the input vector map. The names
+of these attributes are all uppercase and match those used by the
+viewshed module of ESRI's ArcGIS Spatial Extension (trademarks of ESRI Corp.).
+They control <EM>r.cva</EM> operation in an analogous way.
+Each attribute, if present, must store a double value. The following
+attribute names and value ranges are recognised and interpreted:
+<dl>
+<dt>SPOT</dt>
+	<dd>This determines absolute observer height. If this attribute is given,
+	    observer height will no longer be determined from the DEM.
+		 <EM>r.cva</EM> can automatically raise this value to that of the DEM
+		 point below the oberserver's position, if the value in SPOT would
+		 cause the observer to get below ground level (use the <b>-h</b> flag).</dd>
+<dt>OFFSETA</dt>
+	<dd>Use this to add an offset to each oberver point's height. This is
+	    just an alias for the <b>obs_elev</b> option and exists for
+	    compatibility reasons.</dd>
+<dt>OFFSETB</dt>
+		<dd>The value stored in 'OFFSETB' will be added to each target point
+		at the moment it is considered for visibility. All blocking points
+		on the line-of-sight between observer and target will be left untouched.
+		This is different from the <b>target_elev</b> parameter. It can be
+		used to simulate visibility of targets with a certain height.</dd>
+<dt>AZIMUTH1, AZIMUTH2</dt>
+		<dd>These attributes must be given as values between 0.0 and 360.0 and
+		can be used to limit the horizontal scan range of the viewshed.
+		Limits are measured in degrees with 0.0 in the North and values
+		increasing clock-wise. Thus, if you wanted to limit visibility scans
+		to eastward directions only, you would set AZIMUTH1=1 and AZIMUTH2=180.
+		</dd>
+<dt>VERT1, VERT2</dt>
+		<dd>In analogy to 'AZIMUTH1' and 'AZIMUTH2', these attributes can be
+		used to limit the vertical range of the scan. The range is -90 to 0 for
+		'VERT1' and 0 to 90 for 'VERT2'.
+		At -90 degrees, the observer looks straight down to the ground and at
+		90 degress up into the sky.
+		</dd>
+<dt>RADIUS1, RADIUS2</dt>
+		<dd>Finally, two attributes exist to limit the distance of the scan.
+		'RADIUS1' determines the minimum distance from the observer and 'RADIUS2'
+		the maximum distance. The latter is thus equivalent to using the
+		<b>max_dist</b> parameter and exists for compatibility reasons.
+		</dd>
+</dl>
+Interpretation of these attributes can be turned off by using the <b>-i</b> flag.
+<p>
+Note that you can use the same control values in operation modes
+other than 'sites', if you specify the equivalent parameters
+(see <A HREF = "#parameters">above</A>). The latter will also work
+as global settings in 'sites' mode. Attributes stored in the vector
+map table will override these global settings unless the <b>-i</b>
+flag is specified. The meaning of <b>OFFSETA, OFFSETB</b> and <b>RADIUS1</b> is
+the same as <b>obs_elev, target_elev</b> and <b>max_dist</b>. The latter still
+exist for compatibility with earlier versions of <em>r.cva</em>.
+<A NAME = "notes"><H2>NOTES</H2></A>
+<EM>r.cva</EM> works in the current geographic region, but ignores the
+current mask. Masking is achieved by specifying a target_mask and/or a
+viewpt_mask. For accurate results, the program must be run with the
+resolution of the geographic region set equal to the resolution of the
+data (see <EM><A HREF="../../html/g.region.html">g.region</A></EM>).
+<P>
+This program assumes all height and distance measurements in meters.
+Legacy units must be converted to meters by the user before running <EM>r.cva</EM>.
+<P>
+It is also assumed, that N-S and E-W resolution of the current region are the
+same. If they differ, distances calculated for limiting the viewshed will
+be imprecise and results affected accordingly.
+<P>
+The number of cells visible from a given viewpoint includes the
+viewpoint itself only if the viewpoint is a target cell.
+Consequently, if neither the viewpoint nor any other cell within
+<EM>max_dist</EM> of it is a target cell then the size of that
+viewpoint's viewshed will be zero. Set the <EM>-m</EM> flag to locate
+such viewpoints (they will show as cells coded `0' as opposed to
+`-1'). Similarly, set the <EM>-m</EM> flag when the <EM>-f</EM> flag has
+been set in order to differentiate cells which are genuinely not
+visible from any viewpoint as opposed to those that are not target
+cells.
+<P>
+<EM>r.cva</EM> always informs the user what sampling frequency was
+attempted and subsequently achieved.  This information is printed to
+standard output and is also placed in the output map's history file
+(which can be viewed using <EM><A HREF="../../html/r.info.html">r.info</A></EM>).
+The sample attempted may differ slightly from that requested owing to
+the need to sample a whole number of cells.  Any such discrepancy will
+be greatest in the case of small maps of coarse resolution.  The
+sample achieved may be further reduced when a <EM>viewpt_mask</EM> has been
+specified.  This will not occur with the option `random', because its
+algorithm repeatedly allocates viewpoints until the number that fall
+within mask cells coded `1' produces the frequency attempted. Such a
+reduction can, however, occur with the options `all', `systematic' and
+`sites', because their algorithms allocate viewpoints without
+reference to the mask and then simply ignore those that fall in mask
+cells coded `0'.
+<P>
+<H2>SEE ALSO</H2>
+<br>
+<EM><A HREF="../../html/r.info.html">r.info</A></EM>
+<br>
+<EM><A HREF="../../html/g.region.html">g.region</A></EM>
+<P>
+Cumulative viewshed analysis was defined by D. Wheatley, 1995,
+`Cumulative viewshed analysis: a GIS-based method for investigating
+intervisibility, and its archaeological application', in G. R. Lock
+and Z. Stancic (eds.)  <EM>Archaeology and Geographic Information
+Systems: A European Perspective</EM>, London: Taylor and Francis,
+pp. 171-186.
+<P>
+Lake et al. (M. W. Lake, P. E. Woodman and S. J. Mithen, 1998,
+`Tailoring GIS software for archaeological applications: an example
+concerning viewshed analysis', <EM>Journal of Archaeological
+Science</EM> 25: 27-38) discuss the first version of <EM>r.cva</EM>
+and provide some timing estimates.  They also discuss the importance
+of eliminating the edge effect that occurs when calculating the number
+of cells visible from a viewpoint that is closer than
+<EM>max_dist</EM> to the edge of the map.
+<P>
+Fisher et al. (P. Fisher, C. Farrelly, A. Maddocks and C.  Ruggles,
+1997, `Spatial Analysis of Visible Areas from the Bronze Age Cairns of
+Mull', <EM>Journal of Archaeological Science</EM> 24: 581--592)
+provide a useful review of some of the pitfalls that may trap unwary
+users of cumulative viewshed analysis. Most of these are easily
+avoided using <EM>r.cva</EM>.
+<H2>AUTHOR</H2>
+Mark Lake, Institute of Archaeology, University College London (the author).
+<P>
+With contributions by:
+Benjamin Ducke, Institute of Archaeology, University of Bamberg, Germany.
+<H2>ACKNOWLEDGEMENTS</H2>
+This version of <EM>r.cva</EM> was completed during the author's
+tenure of a Leverhulme Trust Special Research Fellowship at the
+Institute of Archaeology, University College London, U.K.
+<P>
+The first version of <EM>r.cva</EM> was written by the author as part of the
+MAGICAL Project directed by Dr. Steven Mithen (Dept. of Archaeology,
+University of Reading, U.K.).  The MAGICAL Project was made possible
+by a Natural Environment Research Council award (NERC GR3/9540) to
+Dr. Mithen.
+<P>
+<EM>r.cva</EM> draws heavily on the code for <EM><A
+HREF="../../html/r.los.html">r.los</A></EM>, which was written by Kewan
+Q. Khawaja, Intelligent Engineering Systems Laboratory, M.I.T.
+<P>
+Adaptation to GRASS 6 vector and raster formats, additional functionality,
+documentation updates by Benjamin Ducke (2005).
+<H2>BUGS</H2>
+Missing values in site attributes are currently not handled.
+<p>
+Earth curvature correction has not been sufficiently tested. The 'offsetb' option (=target_elev)
+has not been sufficiently tested. Please feel free to test and report!
+<p>
+When <EM>max_dist</EM> is set to 100, the N-S and E-W resolutions are
+50, and a <EM>target_mask</EM> has been specified, the cells
+immediately NE, SE, SW and NW of the viewpoint may not be masked when
+then should be.  Please report any others that you find to the author.
+<P>
+Note that <EM>r.cva</EM> fixes two bugs in the current version of
+<EM><A HREF="../../html/r.los.html">r.los</A></EM>: that <EM>obs_elev</EM> is
+truncated to its integer component and that the target mask
+(<EM>patt_map</EM> in <EM><A HREF="../../html/r.los.html">r.los</A></EM>) does
+not apply to the viewpoint or its eight immediate neighbours.
+<HR>
+<P><a href="index.html">Main index</a> - <a href="raster.html">raster index</a> - <a href="full_index.html">Full index</a></P>
+<P>&copy; 2003-2012 <a href="http://grass.osgeo.org">GRASS Development Team</a></p>
+</body>
+</html>
Added: grass-addons/grass6/raster/r.cva/radians.h
--- grass-addons/grass6/raster/r.cva/radians.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/radians.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,16 @@
+/*	radians.h	in ~/src/Glos				*/
+/* 	This header file defines the syntactic sugar to be	*/
+/*	used for some prominent radian measures.                */
+#define		PI		3.141592654
+#define		PIBYFOUR 	0.785398163
+#define		PIBYTWO		1.570796327
+#define		TWOPI		6.283185308
+#define 	THREEPIBYTWO	4.71238898
Added: grass-addons/grass6/raster/r.cva/random_int.c
--- grass-addons/grass6/raster/r.cva/random_int.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/random_int.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,47 @@
+ *      random_int.c
+ *      Return a random integer between a specified minimum
+ *      and maximum value.  Integer is a long and is drawn from
+ *      a uniform population.  Minimum and maximum values may
+ *      be returned.
+/* Written by Mark Lake on 1/3/96 to:-
+ * 1) Return a random integer between a specified minimum
+ * Called by:-
+ * 1) random_sample()
+ * Calls:-
+ * 1)  zufall()
+#include <string.h>
+#include <math.h>
+#include "zufall.h"
+long int random_int (long int min, long int max)
+    double u[1];
+    char message[32];
+    strcpy (message, "Random number generator failed!");
+    if (zufall (1, u) != 0)
+	G_fatal_error (message);
+    return (long int) min + floor ((max - min + 1) * u[0]);
Added: grass-addons/grass6/raster/r.cva/random_sample.c
--- grass-addons/grass6/raster/r.cva/random_sample.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/random_sample.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,273 @@
+  random_sample.c
+  Updated by Mark Lake on 17/8/01 for GRASS 5.x
+  CONTAINS
+  1) random_sample                                                     */
+  random_sample
+  Called from:
+  1) main                   main.c
+  Calls:
+#include "point.h"
+#define MAX_RANDOM_ALLOCATIONS 1000  /*   number of attempts to pick cell
+					 from which los has not yet been
+					 conducted before it is assumed
+					 that prog has gone into infinite
+					 loop   */
+void random_sample (int nrows, int ncols, SEGMENT *seg_in_p,
+		    SEGMENT *seg_out_1_p, SEGMENT *seg_out_2_p,
+		    SEGMENT *seg_patt_p, SEGMENT *seg_patt_p_v,
+		    SEGMENT *seg_rnd_p,
+		    int replace, int terse, int absolute, RASTER_MAP_TYPE data_type)
+  void *value;
+  double viewpt_elev = 0.0;
+  extern long int random_int();
+  int loop_check, duplicate;
+  int row, col;
+  int null_value;
+  CELL mask;
+  CELL cell_no;
+  long int cells_in_map, cells_to_sample;
+  long int cells_sampled, cells_sampled_uniquely;
+  CELL data, already_analysed;
+  char message[128];
+  CELL c_value;
+  FCELL f_value;
+  DCELL d_value;
+  /*   Seed random number generator */
+  if ((seed < MIN_SEED) || (seed > MAX_SEED))
+    G_fatal_error ("Seed out of range ");
+  if (zufalli (seed) != 0) {
+	sprintf (message, "Failed to seed random number generator!");
+  /* Initialise segment file used to prevent / report replacement */
+  data = background;
+  value = (char*) &data;
+  for (row = 0; row < nrows; row ++) {
+    for (col = 0; col < ncols; col ++) {
+	  segment_put (seg_rnd_p, value, row, col);
+  already_analysed = background + 1;
+  if (absolute)                  /* Sample is no. of cells not % */
+    cells_to_sample = (long int) sample;
+  else
+    cells_to_sample = (long int) (sample / 100.0 * (double) cells_in_map);
+  cell_no = 0;
+  cells_sampled = 0;
+  cells_sampled_uniquely = 0;
+  /* Randomly select cells and perform line of sight analysis from each */
+  if (! terse)
+   fprintf (stdout, "\nPercentage complete:\n");
+  for (cells_sampled = 1; cells_sampled <= cells_to_sample; cells_sampled += 1) {
+      cell_no ++;
+      /* Do preparatory things to prevent long or infinite loop */
+      loop_check = 0;
+      do {
+	  	/* Check that number of attempts is not excessive */
+	  	loop_check ++;
+	  	if (loop_check > MAX_RANDOM_ALLOCATIONS) {
+			sprintf (message, "Failed to pick a viewpoint which has not\nyet been analysed.");
+	  	/* Randomly allocate the viewpoint... */
+	  	row_viewpt = (int) random_int (0, nrows - 1);
+	  	col_viewpt = (int) random_int (0, ncols - 1);
+		/* check for NULL values in DEM */
+	    	null_value = 0;
+				null_value = 1;
+				null_value = 1;
+				null_value = 1;
+	  	/* ...and check that this cell has not already been analysed */
+	  	segment_get (seg_rnd_p, value, row_viewpt, col_viewpt);
+	  	if (replace) {
+	      		if (data == already_analysed) {
+		  		data = background;  /* Trick to break out out
+					 			   of repeat loop */
+		  		duplicate = 1;
+		  	} else
+				duplicate = 0;
+	    	} else
+	      		duplicate = 0;
+	  	if(patt_flag_v) {
+	    	} else
+	      		mask = 1;
+	  } while ((data == already_analysed) || (! mask) || (null_value) );
+      /* Don't actually reanalyse duplicates.  This saves time.
+	     More importantly, it prevents erroneous results
+	     with cumulate (-f) option */
+      if (! duplicate) {
+	    cells_sampled_uniquely ++;
+	    /* Mark viewpoint in temporary file to
+	       prevent duplication or allow number of
+	       duplications to be counted */
+	    value = (char*) &already_analysed;
+	    segment_put (seg_rnd_p, value, row_viewpt, col_viewpt);
+	    null_value = 0;
+	    if (SPOT_SET) {
+	       	if (ADJUST) {
+	       	} else {
+	    line_of_sight (cell_no, row_viewpt, col_viewpt, nrows, ncols, viewpt_elev,
+			           heads, seg_in_p, seg_out_1_p, seg_patt_p, patt_flag, data_type);
+	    } else {
+      /* Print percentage complete */
+      if (! terse) {
+	  	G_percent (cells_sampled, cells_to_sample, 1);
+   } /* END (loop through sampled cells) */
+  if (absolute) {
+      *attempted_sample = cell_no;
+      *actual_sample = cells_sampled_uniquely;
+  } else {
+      *attempted_sample = 100.0 / (double) cells_in_map * (double) cell_no;
+	(double) cells_in_map * (double) cells_sampled_uniquely;
Added: grass-addons/grass6/raster/r.cva/random_sample.h
--- grass-addons/grass6/raster/r.cva/random_sample.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/random_sample.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,13 @@
+#ifndef __RANDOM_SAMPLE_H__
+#define __RANDOM_SAMPLE_H__
+		    int replace, int terse, int absolute, RASTER_MAP_TYPE data_type);
+#endif
Added: grass-addons/grass6/raster/r.cva/scan_all_cells.c
--- grass-addons/grass6/raster/r.cva/scan_all_cells.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/scan_all_cells.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,171 @@
+  scan_all_cells.c
+  CONTAINS
+  1) scan_all_cells                                                    */
+  scan_all_cells
+  Called from:
+  1) main                   main.c
+  Calls:
+#include "point.h"
+void scan_all_cells (int nrows, int ncols,
+		     SEGMENT *seg_in_p, SEGMENT *seg_out_1_p,
+		     int terse, RASTER_MAP_TYPE data_type)
+  int mask;
+  int null_value;
+  int null_count;
+  double cells_in_map;
+  CELL cell_no;
+  long int cells_analysed;
+  CELL c_value;
+  FCELL f_value;
+  DCELL d_value;
+  cell_no = 0;
+  cells_analysed = 0;
+  /* Loop through all cells and perform line of sight analysis from each */
+  if (! terse)
+  null_count = 0;
+  for (row_viewpt = 0; row_viewpt < nrows; row_viewpt ++) {
+      for (col_viewpt = 0; col_viewpt < ncols; col_viewpt ++) {
+	  	cell_no ++;
+	    if(patt_flag_v) {
+			  row_viewpt, col_viewpt);
+	    } else
+	      mask = 1;
+	  if (mask) {
+	      cells_analysed ++;
+	     null_value = 0;
+			null_value = 1;
+			null_count ++;
+			null_value = 1;
+			null_count ++;
+			null_value = 1;
+			null_count ++;
+	     	if (SPOT_SET) {
+	       		if (ADJUST) {
+	       		} else {
+			     seg_patt_p, patt_flag, data_type);
+	      	if (! from_cells)
+	      	else
+	  } /* END (process one cell in mask) */
+	  /* Print progress report */
+	  if (! terse) {
+		  G_percent (cell_no, (int) cells_in_map, 2);
+  } /* END (loop through ALL cells) */
+  /* Calculate sample */
+  *attempted_sample = 100.0;
+  cells_analysed = cells_analysed - null_count;
+  *actual_sample = 100 / (double) cells_in_map * (double) cells_analysed;
Added: grass-addons/grass6/raster/r.cva/scan_all_cells.h
--- grass-addons/grass6/raster/r.cva/scan_all_cells.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/scan_all_cells.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,15 @@
+#ifndef __SCAN_ALL_CELLS_H__
+#define __SCAN_ALL_CELLS_H__
+		     int terse, RASTER_MAP_TYPE data_type);
+#endif
Added: grass-addons/grass6/raster/r.cva/segment3.c
--- grass-addons/grass6/raster/r.cva/segment3.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/segment3.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,123 @@
+/*	segment3.c	                                	*/
+/*	This function picks up all the points in one segment	*/
+/*	and performs los analysis on them.			*/
+/* Modified from r.los by MWL on 14/12/95 to:
+ * 1) Return the head of a list of cells in the current
+ *    segment that are visible from the current viewpoint.
+ * 1) Calls make_list.c version 3;
+ * 2) Calls pts_elim.c version3;
+ * 3) Recieves cell_no and passes it to make_list.c.
+ *    and pts_elim.c.
+ * 1) See main3.c.
+ * 1) Recieves cell_no and passes it on to make_list.c
+ *    and pts_elim.c.
+#include "point.h"
+#define	  NEXT_PT_BACK_PTR	PRESENT_PT->next->previous
+#define	  HEAD_BACK_PTR		head->previous
+struct point *segment(int segment_no, int xmax, int ymax,
+		      double slope_1, double slope_2,
+		      int flip, int sign_on_y, int sign_on_x,
+		      SEGMENT *seg_in_p, SEGMENT *seg_out_p, SEGMENT *seg_patt_p,
+		      int row_viewpt, int col_viewpt, int patt_flag,
+		      CELL cell_no, RASTER_MAP_TYPE data_type)
+    int lower_limit_y ,upper_limit_y,less,x,y;
+    int x_actual,y_actual,x_flip,y_flip;
+    struct point *head = NULL_HERE, *PRESENT_PT, *make_list();
+    int quadrant;
+    struct point *hidden_point_elimination();
+    /*   decide which one of the four quadrants	*/
+    quadrant = 1 + (segment_no-1)/4;
+#ifdef DEBUG
+    printf ("\n Quadrant = %d", quadrant);
+#endif
+    if(slope_1 != 0){ less= ymax/slope_1 + 0.99;
+		      xmax= (xmax<=less)?xmax:less;
+    /*   outer loop over x coors for picking up points */
+    for(x=xmax ; x > 0; x--)
+	/*   calculate limits for range of y for a single x */
+        lower_limit_y = x * slope_1 + 0.9;
+        upper_limit_y = x * slope_2 ;
+        upper_limit_y = (upper_limit_y<=ymax)?upper_limit_y:ymax;
+	/*   loop over y range to pick up correct points */
+        for(y= upper_limit_y; y>= lower_limit_y ; y--)
+	/*   calculate actual x, y that lie in current segment */
+	    if(flip==0) { x_flip = x; y_flip = y;}
+	    else        { y_flip = x; x_flip = y;}
+	    x_actual = sign_on_x*x_flip ;
+	    y_actual = sign_on_y*y_flip;
+	    /*   add chosen point to the point list */
+	    head = make_list(head,y_actual,x_actual,seg_in_p,seg_out_p,
+			     viewpt_elev,quadrant,row_viewpt,col_viewpt,cell_no, data_type);
+    }  /*   end of outer loop */
+    if(head != NULL_HERE)
+	/*   assign back pointers in linked list */
+        HEAD_BACK_PTR = NULL_HERE;
+        while(NEXT_PT != NULL_HERE)
+	    NEXT_PT_BACK_PTR = PRESENT_PT;
+	    PRESENT_PT = NEXT_PT;
+	head = hidden_point_elimination(head,viewpt_elev,
+					seg_in_p,seg_out_p,seg_patt_p,quadrant,sign_on_y,
+					sign_on_x,row_viewpt,col_viewpt,patt_flag,cell_no,
+					data_type);
+#ifdef DEBUG
+    printf ("\nSegment, head = %p", head); fflush (stdout);
+#endif
+    return(head);
+/**************** END OF FUNCTION "SEGMENT" *********************/
Added: grass-addons/grass6/raster/r.cva/segment3.h
--- grass-addons/grass6/raster/r.cva/segment3.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/segment3.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,12 @@
+#ifndef __SEGMENT3_H__
+#define __SEGMENT3_H__
+		      CELL cell_no, RASTER_MAP_TYPE data_type);
+#endif
Added: grass-addons/grass6/raster/r.cva/segment_file.c
--- grass-addons/grass6/raster/r.cva/segment_file.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/segment_file.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,332 @@
+/* modified by Benjamin Ducke to work with different raster map types */
+/* May 2004 */
+   Use fract to set the number of segments.  On a machine with 32Kb RAM
+   it is possible that only 1 segment is required unless many maps
+   are to be opened simultaneously.  Increasing the number of segments
+   seriously degrades performance                	  						   */
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+char* Create_segment_file (int, int, RASTER_MAP_TYPE);
+int Init_segment_file (char*, SEGMENT*);
+/* Public functions                                                       */
+void Close_segmented_infile (int map_fd, char* seg_name, int seg_fd, SEGMENT* seg)
+  segment_release (seg);
+  close (seg_fd);
+  unlink (seg_name);
+  G_close_cell (map_fd);
+/* Create result map in CELL format */
+/* NULL cell handling added by Benjamin Ducke, May 2004 */
+void Close_segmented_outfile (char* map_name, int map_fd,
+			             char* seg_name, int seg_fd, SEGMENT* seg,
+                         CELL* cell_buf, int terse,
+                         SEGMENT* elevation_seg, RASTER_MAP_TYPE data_type, int make_nulls)
+  unsigned long row, nrows, col, ncols;
+  char *null_flags;
+  CELL c_value;
+  FCELL f_value;
+  DCELL d_value;
+  /* Find number of rows and columns in elevation map */
+  nrows = G_window_rows();
+  ncols = G_window_cols();
+  /* allocate memory for a NULL data row */
+  null_flags = G_calloc ((signed) ncols, sizeof (char));
+  /* Write pending updates by segment_put() to output map */
+  segment_flush(seg);
+  if (!terse) {
+    fprintf (stdout, "\nWriting raster map '%s': \n", map_name);
+  /* Convert output submatrices to full cell overlay */
+  for(row=0; row< nrows; row++) {
+    segment_get_row(seg, cell_buf, (signed) row);
+	/* check for NULL values in the corresponding row of the */
+	/* elevation input file. If there are any, set the CELLs */
+	/* in the output file to NULL, as well */
+	/* initialize null data row */
+	for (col=0; col<ncols; col++) {
+		null_flags[col] = 0;
+	/* convert all -1 cells to NULL, if user wants it so */
+    if ( make_nulls == 1 ) {
+		   if ( cell_buf[col] == -1 ) {
+		     null_flags[col] = 1;
+	/* update NULL flags in row */
+        segment_get (elevation_seg, value, (signed) row, (signed) col);
+		/* check for NULL value and record in null_flags row */
+		    if (G_is_c_null_value (&c_value) ) {
+			  null_flags[col] = 1; /* signal NULL value in null_flags row */
+		    if (G_is_f_null_value (&f_value) ) {
+		    if (G_is_d_null_value (&d_value) ) {
+    /* set all NULL cells according to null_flags row */
+	G_insert_c_null_values (cell_buf, null_flags, (signed) ncols);
+	/* now, write this row to disk */
+    if(G_put_raster_row (map_fd, cell_buf, CELL_TYPE) < 0) {
+	  G_fatal_error ("Failed to convert output submatrices ");
+	/* progress display */
+	if (! terse) {
+		G_percent ((signed) row, (signed) nrows-1,2);
+  G_free (null_flags);
+/* Close files */
+  close (seg_fd);
+void Close_segmented_tmpfile (char *seg_name, int seg_fd, SEGMENT *seg)
+  /* Close files */
+  close (seg_fd);
+/* this routine creates four segment files on disk, then stores */
+/* a raster map in them */
+/* store a raster map in a mem segment on disk */
+void Segment_infile (char* map_name, char* mapset, char* search_mapset, int* map_fd,
+		char* seg_name, int* seg_fd, SEGMENT* seg, void *cell_buf, int fract,
+    int nrows, row;
+    strcpy (mapset, G_find_cell (map_name, search_mapset));
+    if (mapset == NULL)
+	  G_fatal_error ("Can't find displayed data layer ");
+    if ((*map_fd = G_open_cell_old (map_name, mapset)) < 0)
+	  G_fatal_error ("Can't open displayed data layer ");
+    nrows = G_window_rows ();
+	/* next line creates the actual segment, returns name of disk file */
+    strcpy (seg_name, Create_segment_file (nrows, fract, data_type));
+    *seg_fd = open (seg_name, O_RDWR);
+    if (*seg_fd < 0)
+	  G_fatal_error ("Cannot open segment disk file ");
+    segment_init (seg, *seg_fd, 4);
+	/* store map data in segment file IGNORE MASK */
+	/* cell_buf must be pre-allocated by caller! */
+    for (row = 0; row < nrows; row++) {
+	    if (G_get_raster_row_nomask (*map_fd, cell_buf, row, data_type) < 0) {
+	        G_fatal_error ("Unable to read data layer into segment file ");
+	    segment_put_row (seg, cell_buf, row); /* store raster map in segment file */
+void Segment_outfile (char* map_name, char* mapset, int* map_fd,
+		         char* seg_name, int* seg_fd, SEGMENT* seg, char* prompt, int fract,
+    int nrows;
+    char* mapset_address;
+    mapset_address = G_ask_cell_new (prompt, map_name);
+	if (mapset_address == NULL)
+	  G_fatal_error ("Can't continue without filename ");
+    strcpy (mapset, mapset_address);
+	if ((*map_fd = G_open_cell_new (map_name)) < 0)
+	  G_fatal_error ("Can't create output layer ");
+    *seg_fd = open (seg_name, 2);
+	if (*seg_fd < 0)
+	  G_fatal_error ("Can't open segment disk file ");
+void Segment_named_outfile (char* map_name, char* mapset, int* map_fd,
+			           char* seg_name, int* seg_fd, SEGMENT* seg, int overwrite,
+                       int terse, int fract, RASTER_MAP_TYPE data_type)
+    int nrows;
+    char message [64];
+    mapset_address = G_find_cell (map_name, G_mapset ());
+    strcpy (mapset, G_mapset ());
+    if (mapset_address != NULL)
+      if (!overwrite)
+	  sprintf (message, "Raster map '%s' exists ", map_name);
+      else
+	  if (!terse)
+	    fprintf (stdout, "\nOverwriting raster map '%s' ", map_name);
+    else
+	if (!terse)
+	  fprintf (stdout, "\nCreating raster map '%s' ", map_name);
+    if (*seg_fd < 0)
+void Segment_tmpfile (char* seg_name, int* seg_fd, SEGMENT* seg, int fract,
+    int nrows;
+    if (*seg_fd < 0)
+	/* get a handle to read segment file data values */
+	/* dimensions of segment and size of stored items are read */
+	/* automatically from the file header and stored in 'seg' */
+/* Private functions                                                      */
+char* Create_segment_file (int nrows, int fract, RASTER_MAP_TYPE data_type)
+    int seg_fd;
+    char* seg_name;
+    int ncols;
+    int submatrix_rows, submatrix_cols;
+    int length_data_item = 0;
+    int seg_error;
+    ncols = G_window_cols ();
+	if (data_type == CELL_TYPE) length_data_item = sizeof (CELL);
+	if (data_type == FCELL_TYPE) length_data_item = sizeof (FCELL);
+	if (data_type == DCELL_TYPE) length_data_item = sizeof (DCELL);
+    submatrix_rows = nrows/fract + 1;
+    submatrix_cols = ncols/fract + 1;
+    seg_name = G_tempfile ();
+    seg_fd = creat (seg_name, 0666);
+	/* create a new segment file on disk */
+	/* size of data items (CELL, DCELL, FCELL ...) is stored in the file header */
+    seg_error = segment_format (seg_fd, nrows, ncols,
+		    submatrix_rows, submatrix_cols, length_data_item);
+	if ( seg_error != 1 ) {
+		G_fatal_error ("Cannot create segment file(s).\nCheck available diskspace and access rights.");
+    close (seg_fd);
+    return seg_name;
+int Init_segment_file (char* seg_name, SEGMENT* seg)
+    int seg_fd;
+    seg_fd = open (seg_name, 2);
+    if (seg_fd < 0)
+	G_fatal_error ("Cannot open segment disk file");
+    segment_init (seg, seg_fd, 4);
+    return seg_fd;
Added: grass-addons/grass6/raster/r.cva/segment_file.h
--- grass-addons/grass6/raster/r.cva/segment_file.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/segment_file.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,27 @@
+#ifndef __SEGMENT_FILE_H__
+#define __SEGMENT_FILE_H__
+                       int terse, int fract, RASTER_MAP_TYPE data_type);
+void Close_segmented_tmpfile (char *seg_name, int seg_fd, SEGMENT *seg);
+void Close_segmented_infile (int map_fd, char* seg_name, int seg_fd, SEGMENT* seg);
+                         SEGMENT* elevation_seg, RASTER_MAP_TYPE data_type, int make_nulls);
+#endif
Added: grass-addons/grass6/raster/r.cva/systematic_sample.c
--- grass-addons/grass6/raster/r.cva/systematic_sample.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/systematic_sample.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,216 @@
+  systematic_sample.c
+  CONTAINS
+  1) systematic_sample                                                 */
+  systematic_sample
+  Called from:
+  1) main                   main.c
+  Calls:
+#include <math.h>
+#include "point.h"
+void systematic_sample (int nrows, int ncols,
+			int terse,
+			int absolute,
+  int mask;
+  int null_value;
+  int null_count;
+  CELL cell_no, actual_cells;
+  double row_increment, col_increment;
+  double no_cells_to_sample, actual_cells_to_sample, cells_in_map;
+  double side_of_square_sample;
+  double ratio_of_sides, rows_in_sample, cols_in_sample;
+  double sample_row, sample_col;
+  CELL c_value;
+  FCELL f_value;
+  DCELL d_value;
+  /*  Calculate the row and col spacings */
+    no_cells_to_sample = (long int) sample;
+  else
+    no_cells_to_sample =  sample / 100.0 * (double) nrows * (double) ncols;
+  side_of_square_sample = sqrt (no_cells_to_sample);
+  ratio_of_sides = (double) nrows / (double) ncols;
+  rows_in_sample = ratio_of_sides * side_of_square_sample;
+  if (fmod (rows_in_sample, (double) 1) < 0.5)
+    rows_in_sample = floor (rows_in_sample);
+  else
+    rows_in_sample = ceil (rows_in_sample);
+  cols_in_sample = (1 / ratio_of_sides) * side_of_square_sample;
+  if (fmod (cols_in_sample, (double) 1) < 0.5)
+    cols_in_sample = floor (cols_in_sample);
+  else
+    cols_in_sample = ceil (cols_in_sample);
+  row_increment = nrows / rows_in_sample;
+  col_increment = ncols / cols_in_sample;
+  actual_cells_to_sample = rows_in_sample * cols_in_sample;
+  null_count = 0;
+  /* Loop through sample of cells and perform
+       line of sight analysis from each */
+  if (! terse)
+  actual_cells = 0;
+  cell_no = 0;
+  sample_row = ((double) nrows - ((rows_in_sample - 1) * row_increment)) / 2;
+  while (sample_row < nrows) {
+    sample_col = ((double) ncols - ((cols_in_sample - 1) * col_increment)) / 2;
+	while (sample_col < ncols) {
+	    row_viewpt = floor (sample_row);
+	    col_viewpt = floor (sample_col);
+	    cell_no ++;
+	    if (patt_flag_v) {
+	    } else
+	        mask = 1;
+	    if (mask) {
+	      actual_cells ++;
+	      /* value = (char*) &read_viewpt_elev; */
+		  null_value = 0;
+				null_value = 1;
+				null_count ++;
+				null_value = 1;
+				null_count ++;
+				null_value = 1;
+				null_count ++;
+	    		if (SPOT_SET) {
+	       			if (ADJUST) {
+	       			} else {
+	      		if (! from_cells)
+		    		count_visible_cells (cell_no, row_viewpt, col_viewpt, seg_out_1_p, seg_out_2_p,
+		                         seg_patt_p, heads);
+	        	else
+		      		cumulate_visible_cells (cell_no, row_viewpt, col_viewpt, seg_out_1_p, seg_out_2_p,
+	  	if (! terse) {
+		  G_percent (actual_cells, (int) actual_cells_to_sample, 1);
+	  sample_col += col_increment;
+	} /* END (while (sample_col < ncols) */
+    sample_row += row_increment;
+  } /* END ( while (sample_row < nrows) ) */
+  actual_cells = actual_cells - null_count;
+  if (absolute) {
+  	*attempted_sample = actual_cells_to_sample;
+  	*actual_sample = actual_cells;
+  } else {
+  	*attempted_sample = 100.0 / cells_in_map * actual_cells_to_sample;
+  	*actual_sample = 100.0 / cells_in_map * actual_cells;
Added: grass-addons/grass6/raster/r.cva/systematic_sample.h
--- grass-addons/grass6/raster/r.cva/systematic_sample.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/systematic_sample.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,17 @@
+#ifndef __SYSTEMATIC_SAMPLE_H__
+#define __SYSTEMATIC_SAMPLE_H__
+			int terse,
+			int absolute,
+#endif
Added: grass-addons/grass6/raster/r.cva/version
--- grass-addons/grass6/raster/r.cva/version	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/version	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1 @@
+0.9.5
Added: grass-addons/grass6/raster/r.cva/zufall.c
--- grass-addons/grass6/raster/r.cva/zufall.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/zufall.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,183 @@
+#include<stdio.h>
+#include<math.h>
+#include"zufall.h"
+ * portable lagged Fibonacci series uniform random number generator with
+ * "lags" -273 und -607:
+ *        t    = u(i-273)+buff(i-607)  (floating pt.)
+ *        u(i) = t - float(int(t))
+ * W.P. Petersen, IPS, ETH Zuerich, 19 Mar. 92
+struct klotz0 klotz0_1;
+struct klotz1 klotz1_1;
+int zufall (int n, double *a)
+  static int buffsz = 607;
+  int left, aptr, bptr, aptr0, i, k, q, nn, vl, qq, k273, k607;
+  double t;
+  extern struct klotz0 klotz0_1;
+  --a;
+  aptr = 0;
+  nn = n;
+L1:
+  if (nn <= 0)
+    return 0;
+  q = (nn - 1) / 607;		/* factor nn = q*607 + r */
+  left = buffsz - klotz0_1.ptr;
+  if (q <= 1)
+  {				/* only one or fewer full segments */
+    if (nn < left)
+      for (i = 1; i <= nn; ++i)
+	a[i + aptr] = klotz0_1.buff[klotz0_1.ptr + i - 1];
+      klotz0_1.ptr += nn;
+      return 0;
+    else
+      for (i = 1; i <= left; ++i)
+      klotz0_1.ptr = 0;
+      aptr += left;
+      nn -= left;
+      /* buff -> buff case */
+      vl = 273;
+      k273 = 334;
+      k607 = 0;
+      for (k = 1; k <= 3; ++k)
+	/* dir$ ivdep */
+	/* vdir nodep */
+	/* VOCL LOOP, TEMP(t), NOVREC(buff) */
+	for (i = 1; i <= vl; ++i)
+	  t = klotz0_1.buff[k273 + i - 1] + klotz0_1.buff[k607 + i - 1];
+	  klotz0_1.buff[k607 + i - 1] = t - (float) ((int) t);
+	k607 += vl;
+	k273 += vl;
+	vl = 167;
+	if (k == 1)
+	  k273 = 0;
+      goto L1;
+  else
+    /* more than 1 full segment */
+    nn -= left;
+    klotz0_1.ptr = 0;
+    aptr += left;
+    /* buff -> a(aptr0) */
+    vl = 273;
+    k273 = 334;
+    k607 = 0;
+      if (k == 1)
+	/* VOCL LOOP, TEMP(t) */
+	  a[aptr + i] = t - (float) ((int) t);
+	k273 = aptr;
+	k607 += vl;
+	aptr += vl;
+	vl = 167;
+      else
+	/* dir$ ivdep */
+	/* vdir nodep */
+	  t = a[k273 + i] + klotz0_1.buff[k607 + i - 1];
+	k607 += vl;
+	k273 += vl;
+	aptr += vl;
+    nn += -607;
+    /* a(aptr-607) -> a(aptr) for last of the q-1 segments */
+    aptr0 = aptr - 607;
+    vl = 607;
+    /* vdir novector */
+    for (qq = 1; qq <= q - 2; ++qq)
+      k273 = aptr0 + 334;
+      /* dir$ ivdep */
+      /* vdir nodep */
+      /* VOCL LOOP, TEMP(t), NOVREC(a) */
+	t = a[k273 + i] + a[aptr0 + i];
+      nn += -607;
+      aptr += vl;
+      aptr0 += vl;
+    /* a(aptr0) -> buff, last segment before residual */
+    vl = 273;
+    k607 = aptr0;
+    bptr = 0;
+      if (k == 1)
+	  t = a[k273 + i] + a[k607 + i];
+	  klotz0_1.buff[bptr + i - 1] = t - (double) ((int) t);
+	k273 = 0;
+	k607 += vl;
+	bptr += vl;
+	vl = 167;
+      else
+	/* dir$ ivdep */
+	/* vdir nodep */
+	  t = klotz0_1.buff[k273 + i - 1] + a[k607 + i];
+	  klotz0_1.buff[bptr + i - 1] = t - (float) ((int) t);
+	k607 += vl;
+	k273 += vl;
+	bptr += vl;
+    goto L1;
+}				/* zufall */
Added: grass-addons/grass6/raster/r.cva/zufall.h
--- grass-addons/grass6/raster/r.cva/zufall.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/zufall.h	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,31 @@
+#define min(a,b) ((a) <= (b) ? (a) : (b))
+/* clock cycle for machine */
+/* #define CYCLE 2.9e-9 cycle for SX-3: */
+/* #define CYCLE 6.0e-9 cycle for Y-MP: */
+/* #define CYCLE 3.2e-9 cycle for VP2200 */
+# define MIN_SEED 0
+#define  MAX_SEED 31328
+struct klotz0 {
+    double buff[607];
+    int ptr;
+struct klotz1 {
+    double xbuff[1024];
+    int first, xptr;
+int normal00();
+int normalen();
+int normalrs();
+int normalsv();
+int fische();
+int zufall();
+int zufalli();
+int zufallrs();
+int zufallsv();
Added: grass-addons/grass6/raster/r.cva/zufalli.c
--- grass-addons/grass6/raster/r.cva/zufalli.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.cva/zufalli.c	2012-03-31 07:58:03 UTC (rev 51216)
@@ -0,0 +1,46 @@
+int zufalli(int seed)
+    static int kl = 9373;
+    static int ij = 1802;
+    static int i, j, k, l, m;
+    static double s, t;
+    static int ii, jj;
+/*  generates initial seed buffer by linear congruential */
+/*  method. Taken from Marsaglia, FSU report FSU-SCRI-87-50 */
+/*  variable seed should be 0 < seed <31328 */
+    if (seed != 0) {
+	ij = seed;
+    i = ij / 177 % 177 + 2;
+    j = ij % 177 + 2;
+    k = kl / 169 % 178 + 1;
+    l = kl % 169;
+    for (ii = 1; ii <= 607; ++ii) {
+	s = (float)0.;
+	t = (float).5;
+	for (jj = 1; jj <= 24; ++jj) {
+	    m = i * j % 179 * k % 179;
+	    i = j;
+	    j = k;
+	    k = m;
+	    l = (l * 53 + 1) % 169;
+	    if (l * m % 64 >= 32) {
+		s += t;
+	    t *= (float).5;
+/* L2: */
+        /*  printf("DIAG: s %g\n",s); */
+	klotz0_1.buff[ii - 1] = s;
+/* L1: */
+    return 0;
+} /* zufalli_ */
