[GRASS-SVN] r51218 - in grass-addons/grass6/vector: . v.ldm
svn_grass at osgeo.org
Sat Mar 31 05:01:09 EDT 2012
Author: amuriy
Date: 2012-03-31 02:01:09 -0700 (Sat, 31 Mar 2012)
New Revision: 51218
Added:
grass-addons/grass6/vector/v.ldm/
grass-addons/grass6/vector/v.ldm/Makefile
grass-addons/grass6/vector/v.ldm/description.html
grass-addons/grass6/vector/v.ldm/v.ldm
grass-addons/grass6/vector/Makefile
<v.ldm> added to grass6/vector; grass6/vector/Makefile edited
Modified: grass-addons/grass6/vector/Makefile
--- grass-addons/grass6/vector/Makefile 2012-03-31 08:56:38 UTC (rev 51217)
+++ grass-addons/grass6/vector/Makefile 2012-03-31 09:01:09 UTC (rev 51218)
@@ -12,6 +12,7 @@
v.in.mbsys_fnv \
v.in.ncdc \
v.in.postgis \
+ v.ldm \
v.out.ascii.db \
v.out.ascii.mat \
v.out.gmt \
Added: grass-addons/grass6/vector/v.ldm/Makefile
--- grass-addons/grass6/vector/v.ldm/Makefile (rev 0)
+++ grass-addons/grass6/vector/v.ldm/Makefile 2012-03-31 09:01:09 UTC (rev 51218)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.ldm
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass6/vector/v.ldm/description.html
--- grass-addons/grass6/vector/v.ldm/description.html (rev 0)
+++ grass-addons/grass6/vector/v.ldm/description.html 2012-03-31 09:01:09 UTC (rev 51218)
@@ -0,0 +1,68 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>GRASS GIS manual: v.ldm</title>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+<link rel="stylesheet" href="grassdocs.css" type="text/css">
+</head>
+<body bgcolor="white">
+<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
+<h2>NAME</h2>
+<em><b>v.ldm</b></em> - Compute "Linear Directional Mean" of vector lines, displays arrow on the graphic monitor, save to vector line and update attribute table with LDM parameters.
+<h2>KEYWORDS</h2>
+display, graphics, vector, symbology
+<h2>SYNOPSIS</h2>
+<b>v.ldm</b><br>
+<b>v.ldm help</b><br>
+<b>v.ldm</b> [-<b>nslg</b>] <b>map</b>=<em>name</em> [<b>layer</b>=<em>integer</em>] [<b>output</b>=<em>name</em>] [<b>width</b>=<em>integer</em>] [<b>color</b>=<em>string</em>] [<b>graph</b>=<em>name</em>] [--<b>overwrite</b>] [--<b>verbose</b>] [--<b>quiet</b>]
+<h3>Flags:</h3>
+<DL>
+<DT><b>-n</b></DT>
+<DD>Don't show LDM graphics on the screen</DD>
+<DT><b>-s</b></DT>
+<DD>Save LDM graphics to file (for use with d.graph)</DD>
+<DT><b>-l</b></DT>
+<DD>Save LDM line as vector map and create attribute table with LDM parameters</DD>
+<DT><b>-g</b></DT>
+<DD>Print in shell script style</DD>
+<DT><b>--overwrite</b></DT>
+<DD>Allow output files to overwrite existing files</DD>
+<DT><b>--verbose</b></DT>
+<DD>Verbose module output</DD>
+<DT><b>--quiet</b></DT>
+<DD>Quiet module output</DD>
+</DL>
+<h3>Parameters:</h3>
+<DL>
+<DT><b>map</b>=<em>name</em></DT>
+<DD>Name of input vector map</DD>
+<DT><b>layer</b>=<em>integer</em></DT>
+<DD>Layer number</DD>
+<DD>Default: <em>1</em></DD>
+<DT><b>output</b>=<em>name</em></DT>
+<DD>Name of output vector map</DD>
+<DT><b>width</b>=<em>integer</em></DT>
+<DD>Width of LDM line with arrow</DD>
+<DD>Default: <em>5</em></DD>
+<DT><b>color</b>=<em>string</em></DT>
+<DD>Color for LDM line with arrow (standard color name or R:G:B)</DD>
+<DD>Default: <em>black</em></DD>
+<DT><b>graph</b>=<em>name</em></DT>
+<DD>Output file to save Linear Directional Mean graphics</DD>
+</DL>
+</body>
+</html>
Added: grass-addons/grass6/vector/v.ldm/v.ldm
--- grass-addons/grass6/vector/v.ldm/v.ldm (rev 0)
+++ grass-addons/grass6/vector/v.ldm/v.ldm 2012-03-31 09:01:09 UTC (rev 51218)
@@ -0,0 +1,411 @@
+#!/bin/sh
+# MODULE: v.ldm
+# AUTHOR(S): Alexander Muriy
+# (Institute of Environmental Geoscience, Moscow, Russia)
+# e-mail: amuriy AT gmail DOT com
+# PURPOSE: Compute "Linear Directional Mean" of vector lines, display arrow
+# on the graphic monitor, save to vector line and update attribute table
+# with LDM parameters.
+# COPYRIGHT: (C) 2011 Alexander Muriy / GRASS Development Team
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+#%Module
+#% description: Compute "Linear Directional Mean" of vector lines, displays arrow on the graphic monitor, save to vector line and update attribute table with LDM parameters.
+#% keywords: display, graphics, vector, symbology
+#%End
+#%Option
+#% key: map
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name of input vector map
+#% gisprompt: old,vector,vector
+#%End
+#%Option
+#% key: layer
+#% type: integer
+#% required: no
+#% description: Layer number
+#% answer: 1
+#%End
+#%Option
+#% key: output
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name of output vector map
+#% gisprompt: new,vector,vector
+#%End
+#%Option
+#% key: width
+#% type: integer
+#% required: no
+#% description: Width of LDM line with arrow
+#% answer: 5
+#%End
+#%Option
+#% key: color
+#% type: string
+#% required: no
+#% description: Color for LDM line with arrow (standard color name or R:G:B)
+#% answer: black
+#% gisprompt: old_color,color,color
+#%End
+#%Option
+#% key: graph
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Output file to save Linear Directional Mean graphics
+#% gisprompt: new_file,file,output
+#%End
+#%Flag
+#% key: n
+#% description: Don't show LDM graphics on the screen
+#%End
+#%Flag
+#% key: s
+#% description: Save LDM graphics to file (for use with d.graph)
+#%End
+#%Flag
+#% key: l
+#% description: Save LDM line as vector map and create attribute table with LDM parameters
+#%End
+#%Flag
+#% key: g
+#% description: Print in shell script style
+#%End
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." 1>&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+## set environment so that awk works properly in all languages ##
+unset LC_ALL
+export LC_NUMERIC=C
+cleanup()
+ g.mremove -f vect=V_LDM_HULL --q
+ rm -f $TMP1*
+## what to do in case of user break:
+exitprocedure()
+ echo "User break!"
+ cleanup
+ exit 1
+## shell check for user break (signal list: trap -l)
+trap "exitprocedure" 2 3 15
+## check for awk
+if [ ! -x "$(which awk)" ] ; then
+ g.message -e "<awk> required, please install <awk> or <gawk> first"
+ exit 1
+fi
+## check for cs2cs
+if [ ! -x "$(which cs2cs)" ] ; then
+ g.message -e "cs2cs required, please install <cs2cs> package first"
+ exit 1
+fi
+## does map exist?
+eval "$(g.gisenv)"
+eval "$(g.findfile mapset="$MAPSET" element=vector file="$GIS_OPT_MAP")"
+if [ ! "$file" ]; then
+ g.message -e "Vector map <"$GIS_OPT_MAP"> not found"
+ exit 1
+fi
+## check for lines in input map
+eval "$(v.info -t "$GIS_OPT_MAP")"
+if [ "$lines" -eq 0 ]; then
+ g.message -e "Input vector map not contain lines"
+ exit 1
+fi
+# for vars in "$(v.info -t "$GIS_OPT_MAP" | cut -d"=" -f1)"; do
+# unset -v "$vars"
+# done
+## setup temporary files ##
+# create temporary file
+TMP1="$(g.tempfile pid=$$)"
+if [ "$?" -ne 0 ] || [ -z "$TMP1" ] ; then
+ g.message -e "ERROR: Unable to create temporary files."
+ exit 1
+fi
+## DO IT
+## compute LDM characteristics and print them
+## make convex hull around lines
+v.hull -a in=$GIS_OPT_MAP out=V_LDM_HULL --q > /dev/null 2>&1
+CENTER_COORDS=$(v.to.db -p V_LDM_HULL opt=coor type=centroid --q | cut -d'|' -f2,3 | tr '|' ' ')
+CENTER_X=$(echo $CENTER_COORDS | cut -d' ' -f1 | awk '{printf "%0.6f\n",$1}')
+CENTER_Y=$(echo $CENTER_COORDS | cut -d' ' -f2 | awk '{printf "%0.6f\n",$1}')
+# CENTER_COORDS=$(g.region -u vect=$GIS_OPT_MAP -cg | cut -d"=" -f2 | tr '\n' ' ')
+# CENTER_X=$(echo ${CENTER_COORDS} | cut -d" " -f1)
+# CENTER_Y=$(echo ${CENTER_COORDS} | cut -d" " -f2)
+if [ "$GIS_FLAG_G" -eq 1 ]; then
+ echo "mean_center=$(echo $CENTER_COORDS | tr ' ' ',')"
+else
+ echo "Mean Center: $(echo $CENTER_COORDS | tr ' ' ',')"
+fi
+END_AZIM=$(v.to.db -p $GIS_OPT_MAP layer=$GIS_OPT_LAYER opt=azimuth units=radians --q | awk -F"|" -v count=${VECT_COUNT} '{
+s1=sin($2); c1=cos($2);
+print s1,c1}' | awk '{
+s2 += $1; c2 += $2}
+END {a1=atan2(s2,c2);
+a2=a1*57.2958;
+print a2}')
+COMPASS_ANGLE=$(v.to.db -p $GIS_OPT_MAP layer=$GIS_OPT_LAYER opt=azimuth units=radians --q | awk -F"|" -v count=${VECT_COUNT} '{
+a2=a1*57.2958;
+if (a2 < 0) a3=-a2;
+if (a2 > 0) a3=a2;
+if (s2>0 && c2>0) ca=a3;
+if (s2>0 && c2<0) ca=a3;
+if (s2<0 && c2>0) ca=360-a3;
+if (s2<0 && c2<0) ca=360-a3;
+print ca}' )
+ echo "compass_angle=$(echo $COMPASS_ANGLE)"
+else
+ echo "Compass Angle: $(echo $COMPASS_ANGLE)"
+fi
+LDM=$(v.to.db -p $GIS_OPT_MAP layer=$GIS_OPT_LAYER opt=azimuth units=radians --q | awk -F"|" -v count=${VECT_COUNT} '{
+a2=a1*57.2958;
+if (a2 > 0) a3=a2;
+if (s2>0 && c2>0) ldm=90-a3;
+if (s2>0 && c2<0) ldm=450-a3;
+if (s2<0 && c2>0) ldm=90+a3;
+if (s2<0 && c2<0) ldm=90+a3;
+print ldm}' )
+ echo "directional_mean=$(echo $LDM)"
+else
+ echo "Directional Mean: $(echo $LDM)"
+fi
+VECT_COUNT=$(v.to.db -pc $GIS_OPT_MAP layer=$GIS_OPT_LAYER opt=count --q | cut -d":" -f2 | tr -d [[:blank:]])
+CIRC_VAR=$(v.to.db -p $GIS_OPT_MAP layer=$GIS_OPT_LAYER opt=azimuth units=radians --q | awk -F"|" '{
+print s1,c1}' | awk -v count="$VECT_COUNT" '{
+END {s3=s2^2; c3=c2^2;
+cv=1-((sqrt(s3+c3))/count);
+print cv}')
+if [ $VECT_COUNT -gt "1" ]; then
+ if [ "$GIS_FLAG_G" -eq 1 ]; then
+ echo "circular_variance=$(echo $CIRC_VAR)"
+ else
+ echo "Circular Variance: $(echo $CIRC_VAR)"
+ fi
+fi
+### find start/end points of "mean" line
+END_AZIM_DMS=$(echo "${END_AZIM}" | cs2cs +proj=latlong +to +proj=latlong | sed -e 's/d/:/g' -e "s/'/:/g" -e 's/"//g' | tr -d [[:alpha:]] | tr -d [[:blank:]] | sed 's/:0.000//g')
+END_AZIM_NEG=$(echo $END_AZIM | cut -c1)
+if [ $END_AZIM_NEG = "-" ]; then
+ END_AZIM_DMS=$(echo "-"${END_AZIM_DMS})
+fi
+START_AZIM=$(echo $END_AZIM | awk '{print 180-$1}')
+START_AZIM_DMS=$(echo "${START_AZIM}" | cs2cs +proj=latlong +to +proj=latlong | sed -e 's/d/:/g' -e "s/'/:/g" -e 's/"//g' | tr -d [[:alpha:]] | tr -d [[:blank:]] | sed 's/:0.000//g')
+MEAN_LENGTH=$(v.to.db -p $GIS_OPT_MAP layer=$GIS_OPT_LAYER option=length --q | awk -F"|" ' {s1 = NR} {s2 += $2} {x = s2/s1} END {print x}')
+ echo "mean_length=$(echo $MEAN_LENGTH)"
+else
+ echo "Mean Length: $(echo $MEAN_LENGTH)"
+fi
+HALF_MEAN_LENGTH=$(echo $MEAN_LENGTH | awk '{print $1/2}')
+echo "N ${END_AZIM_DMS} E ${HALF_MEAN_LENGTH}" > $TMP1.end.cogo
+END_COORDS=$(m.cogo in=$TMP1.end.cogo coord=$(echo ${CENTER_COORDS} | tr ' ' ','))
+echo "N ${START_AZIM_DMS} W ${HALF_MEAN_LENGTH}" > $TMP1.start.cogo
+START_COORDS=$(m.cogo in=$TMP1.start.cogo coord=$(echo ${CENTER_COORDS} | tr ' ' ','))
+if [ "$GIS_FLAG_N" -eq 0 ]; then
+## make "arrowhead" symbol (if not exist)
+ echo "VERSION 1.0
+BOX -0.5 -0.5 0.5 0.5
+POLYGON
+ RING
+ FCOLOR NONE
+ LINE
+ 0 0
+ 0.3 -1
+ END
+ END
+POLYGON
+ RING
+ FCOLOR NONE
+ LINE
+ 0 0
+ -0.3 -1
+ END
+ END
+END" > $TMP1.arrowhead_1
+eval $(g.gisenv)
+symbol_path="$GISDBASE"/"$LOCATION_NAME"/"$MAPSET"/symbol/arrows
+if [ ! -d "$symbol_path" ]; then
+ mkdir -p "$symbol_path"
+ cp -f $TMP1.arrowhead_1 "$symbol_path"/arrowhead_1
+fi
+## write LDM graph file and display line of LDM with the arrow
+echo "move $(echo ${START_COORDS})" > $TMP1.ldm.graph
+echo "width $(echo ${GIS_OPT_WIDTH})" >> $TMP1.ldm.graph
+ARROW_SIZE=$(echo ${GIS_OPT_WIDTH} | awk '{print $1*7}')
+ARROW_AZIM=$(echo ${END_AZIM} | awk '{print 360-$1}')
+echo "color $(echo ${GIS_OPT_COLOR})" >> $TMP1.ldm.graph
+echo "draw $(echo ${END_COORDS})" >> $TMP1.ldm.graph
+echo "" >> $TMP1.ldm.graph
+echo "rotation $(echo ${ARROW_AZIM})" >> $TMP1.ldm.graph
+echo "symbol "arrows/arrowhead_1" $(echo ${ARROW_SIZE}) $(echo ${END_COORDS}) $(echo ${GIS_OPT_COLOR})" >> $TMP1.ldm.graph
+if [ "$GIS_FLAG_S" -eq 0 ] && [ -n "$GIS_OPT_GRAPH" ]; then
+ g.message -e "Please use flag <"-s"> to save LDM graphics in file <"$GIS_OPT_GRAPH">"
+ cleanup
+ exit 1
+fi
+if [ "$GIS_FLAG_S" -eq 1 ]; then
+ if [ -n "$GIS_OPT_GRAPH" ]; then
+ cp -f $TMP1.ldm.graph "${GIS_OPT_GRAPH}"
+ d.graph -m input="${GIS_OPT_GRAPH}" > /dev/null 2>&1
+ else
+ eval $(g.gisenv)
+ GIS_OPT_GRAPH=""${GISDBASE}"/"${LOCATION_NAME}"/"${GIS_OPT_MAP}"_ldm.graph"
+ cat $TMP1.ldm.graph > ${GIS_OPT_GRAPH}
+ d.graph -m input="${GIS_OPT_GRAPH}" color=none > /dev/null 2>&1
+ fi
+else
+ cat $TMP1.ldm.graph | d.graph -m > /dev/null 2>&1
+fi
+fi
+## save LDM line to vector if flag "-l" set
+if [ "$GIS_FLAG_L" -eq 1 ]; then
+ if [ -n "$GIS_OPT_OUTPUT" ]; then
+ echo ${START_COORDS} > $TMP1.line.coords
+ echo ${END_COORDS} >> $TMP1.line.coords
+ v.in.lines input="$TMP1.line.coords" output=${GIS_OPT_OUTPUT} fs=" " --q --o
+ v.category in=${GIS_OPT_OUTPUT} out=${GIS_OPT_OUTPUT}_cats --q
+ g.rename vect=${GIS_OPT_OUTPUT}_cats,${GIS_OPT_OUTPUT} --o --q > /dev/null 2>&1
+ if [ -z "$CIRC_VAR" ]; then
+ v.db.addtable map=${GIS_OPT_OUTPUT} col="CompassA double,DirMean double,AveX double, \
+AveY double,AveLen double" --q
+ else
+ v.db.addtable map=${GIS_OPT_OUTPUT} col="CompassA double,DirMean double,CirVar double, \
+AveX double,AveY double,AveLen double" --q
+ fi
+ echo "UPDATE ${GIS_OPT_OUTPUT} SET CompassA = ${COMPASS_ANGLE};" > $TMP1.ldm.sql
+ echo "UPDATE ${GIS_OPT_OUTPUT} SET DirMean = ${LDM};" >> $TMP1.ldm.sql
+ if [ -n "$CIRC_VAR" ]; then
+ echo "UPDATE ${GIS_OPT_OUTPUT} SET CirVar = ${CIRC_VAR};" >> $TMP1.ldm.sql
+ fi
+ echo "UPDATE ${GIS_OPT_OUTPUT} SET AveX = ${CENTER_X};" >> $TMP1.ldm.sql
+ echo "UPDATE ${GIS_OPT_OUTPUT} SET AveY = ${CENTER_Y};" >> $TMP1.ldm.sql
+ echo "UPDATE ${GIS_OPT_OUTPUT} SET AveLen = ${MEAN_LENGTH};" >> $TMP1.ldm.sql
+ cat $TMP1.ldm.sql | db.execute
+ else
+ g.message -e "Please specify <output> file to save LDM vector line"
+ cleanup
+ exit 1
+ fi
+elif [ "$GIS_FLAG_L" -eq 0 ] && [ -n "$GIS_OPT_OUTPUT" ]; then
+ g.message -e "Please use <"-l"> flag to save LDM vector line to <output> file"
+ cleanup
+ exit 1
+fi
+cleanup
+exit 0
Property changes on: grass-addons/grass6/vector/v.ldm/v.ldm
___________________________________________________________________
Added: svn:executable
