[GRASS-SVN] r51587 - grass/trunk/vector/v.net.salesman
svn_grass at osgeo.org
Wed May 2 05:20:28 EDT 2012
Author: mmetz
Date: 2012-05-02 02:20:27 -0700 (Wed, 02 May 2012)
New Revision: 51587
grass/trunk/vector/v.net.salesman/main.c
avoid buffer overflow, fix sequence lists
Modified: grass/trunk/vector/v.net.salesman/main.c
--- grass/trunk/vector/v.net.salesman/main.c 2012-05-01 23:11:07 UTC (rev 51586)
+++ grass/trunk/vector/v.net.salesman/main.c 2012-05-02 09:20:27 UTC (rev 51587)
@@ -74,7 +74,27 @@
+/* like Vect_list_append(), but allows duplicates */
+int tsp_list_append(struct ilist *list, int val)
+ size_t size;
+ if (list == NULL)
+ return 1;
+ if (list->n_values == list->alloc_values) {
+ size = (list->n_values + 1000) * sizeof(int);
+ list->value = (int *)G_realloc((void *)list->value, size);
+ list->alloc_values = list->n_values + 1000;
+ list->value[list->n_values] = val;
+ list->n_values++;
+ return 0;
int main(int argc, char **argv)
int i, j, k, ret, city, city1;
@@ -95,7 +115,7 @@
struct line_cats *Cats;
struct line_pnts *Points;
const char *dstr;
- char buf[2000], buf2[2000];
+/* char buf[2000], buf2[2000]; */
FILE *fp;
/* Initialize the GIS calls */
@@ -218,7 +238,7 @@
if (!(Vect_cat_get(Cats, tfield, &cat)))
continue;
if (Vect_cat_in_cat_list(cat, Clist)) {
- Vect_list_append(TList, node);
+ tsp_list_append(TList, node);
@@ -267,8 +287,10 @@
G_percent(i, ncities, 2);
k = 0;
for (j = 0; j < ncities; j++) {
+ cost_cache[i][j] = 0.0;
if (i == j)
continue;
ret =
Vect_net_shortest_path(&Map, cities[i], cities[j], NULL,
&cost);
@@ -407,6 +429,8 @@
add_city(city, city1);
+ /* TODO: optimize tour (some Lin–Kernighan method) */
if (debug_level >= 2) {
/* debug print */
@@ -423,16 +447,16 @@
node1 = cities[cycle[i]];
node2 = cities[cycle[i + 1]];
G_debug(2, " %d -> %d", node1, node2);
- ret = Vect_net_shortest_path(&Map, node1, node2, List, &tmpcost);
- cost += tmpcost;
+ ret = Vect_net_shortest_path(&Map, node1, node2, List, NULL);
+ cost += cost_cache[cycle[i]][cycle[i + 1]];
for (j = 0; j < List->n_values; j++) {
line = abs(List->value[j]);
- Vect_list_append(StArcs, line);
- Vect_get_line_nodes(&Map, line, &node1, &node2);
/* Vect_list_append() appends only if value not yet present !!!
* this breaks the correct sequence */
- Vect_list_append(StNodes, node1);
- Vect_list_append(StNodes, node2);
+ tsp_list_append(StArcs, line);
+ Vect_get_line_nodes(&Map, line, &node1, &node2);
+ tsp_list_append(StNodes, node1);
+ tsp_list_append(StNodes, node2);
@@ -440,8 +464,8 @@
Vect_open_new(&Out, output->answer, Vect_is_3d(&Map));
Vect_hist_command(&Out);
- G_verbose_message(_("Cycle with total cost %f:"), cost);
- G_verbose_message(_("Arcs' categories (layer %d, %d arcs):"), afield,
+ G_verbose_message(_("Cycle with total cost %.3f"), cost);
+ G_debug(2, "Arcs' categories (layer %d, %d arcs):", afield,
StArcs->n_values);
for (i = 0; i < StArcs->n_values; i++) {
@@ -449,15 +473,8 @@
ltype = Vect_read_line(&Map, Points, Cats, line);
Vect_write_line(&Out, ltype, Points, Cats);
Vect_cat_get(Cats, afield, &cat);
- if (i > 0) {
- sprintf(buf2, ", %d", cat);
- strcat(buf, buf2);
- else
- sprintf(buf, "%d", cat);
+ G_debug(2, "%d. arc: cat %d", i + 1, cat);
- /* buffer overflow in buf for many cities */
- G_verbose_message("%s\n\n", buf);
if (seq->answer) {
if (strcmp(seq->answer, "-")) {
@@ -469,13 +486,15 @@
else
fp = stdout;
- fprintf(fp, "sequence;category\n");
+ fprintf(fp, "sequence;category;cost_to_next\n");
else
fp = NULL;
k = 0;
/* this writes out only user-selected nodes, not all visited nodes */
+ G_debug(2, "Nodes' categories (layer %d, %d nodes):", tfield,
+ ncities);
for (i = 0; i < ncities; i++) {
double coor_x, coor_y, coor_z;
@@ -492,20 +511,13 @@
continue;
- if (k > 0) {
+ k++;
+ if (fp) {
+ fprintf(fp, "%d;%d;%.3f\n", k, cat, cost_cache[cycle[i]][cycle[i + 1]]);
- else
- k++;
- if (fp)
- fprintf(fp, "%d;%d\n", k, cat);
+ G_debug(2, "%d. node: cat %d", k, cat);
- G_verbose_message(_("Nodes' categories (layer %d, %d nodes):"), tfield,
- ncities);
if (fp && fp != stdout)
fclose(fp);
