[GRASS-SVN] r51590 - grass-addons/grass6/raster/LandDyn/r.soildepth.py
Thu May 3 16:11:43 EDT 2012
Author: isaacullah
Date: 2012-05-03 13:11:43 -0700 (Thu, 03 May 2012)
New Revision: 51590
   grass-addons/grass6/raster/LandDyn/r.soildepth.py/r.soildepth.py
Updates to the core algorithm of the script to allow better approximation of soil depths from slopes and curvatures. This requires two new input variable. This version of the script is compatible with new versions of AP-Sim ABM (from April 2012 onward).
Modified: grass-addons/grass6/raster/LandDyn/r.soildepth.py/r.soildepth.py
--- grass-addons/grass6/raster/LandDyn/r.soildepth.py/r.soildepth.py	2012-05-03 20:09:47 UTC (rev 51589)
+++ grass-addons/grass6/raster/LandDyn/r.soildepth.py/r.soildepth.py	2012-05-03 20:11:43 UTC (rev 51590)
@@ -7,7 +7,7 @@
 # PURPOSE:		Create soil depth map based on hillslope curvature.
 # ACKNOWLEDGEMENTS:	National Science Foundation Grant #BCS0410269
 #			Based on equations from Heimsath et al, 1997
-# COPYRIGHT:		(C) 2011 by Isaac Ullah, Michael Barton, Claudine Gravel-Miguel Arizona State University
+# COPYRIGHT:		(C) 2012 by Isaac Ullah, Michael Barton, Claudine Gravel-Miguel Arizona State University
 #			This program is free software under the GNU General Public
 #			License (>=v2). Read the file COPYING that comes with GRASS
 #			for details.
@@ -42,20 +42,49 @@
 #%option
 #% key: min
 #% type: double
-#% description: What are the actual (empircal) minimum soil depths in this area (in meters)?
+#% description: What are the actual (empircal) minimum soil depths in this area (in meters)? (NOTE: The smoothing operation will trim extreme values, so resulting soildepth map may not have minimum depths exactly equal to this number)
 #% answer: 0.0001
 #% required : yes
 #%END
 #%option
 #% key: max
 #% type: double
-#% description: What are the actual (empircal) maximum soil depths in this area (in meters)?
-#% answer: 5.0
+#% description: What are the actual (empircal) maximum soil depths in this area (in meters)? (NOTE: The smoothing operation will trim extreme values, so resulting soildepth map may not have maximum depths exactly equal to this number)
+#% answer: 20.0
 #% required : yes
 #%END
+#%option
+#% key: slopebreaks
+#% type: string
+#% description: Slope remapping pairs in the form: "x1,y1;x2,y2" where x is a slope value (in degrees), and y is a number between 0 and 1 to rescale to. (Two pairs are needed, in order, lower slope then higher slope.)
+#% answer: 15,0.5;45,0.15
+#% required : yes
+#%END
+#%option
+#% key: curvebreaks
+#% type: string
+#% description: Breakpoints in mean curvature values for maximum and minimum soil depths in the form of: "x1,y1;x2,y2" where x1 and x2 are the concavity and convexity value breakpoints respectively, y1 is a number between 0 and -1 and y2 is a number between 0 and 1. (Note: if x1 and/orx2 are too large, the real max and/or min curvaturewill be used.)
+#% answer: -0.015,-0.5;0.015,0.5
+#% required : yes
+#%END
+#%option
+#% key: smoothingtype
+#% type: string
+#% description: Type of smoothing to perform ("median" is recommended)
+#% answer: median
+#% options: average,median,mode,minimum,maximum
+#% required : yes
+#%END
+#%option
+#% key: smoothingsize
+#% type: integer
+#% description: Size (in cells) of the smoother's moving window
+#% answer: 3
+#% required : yes
+#%END
 #%flag
 #% key: k
-#% description: -k Keep the soil rate map (map name will be the same as specified in input option 'bedrock" with suffix "_rate" appended to it)
+#% description: -k Keep the soil depth "potential" map (map name will be the same as specified in input option 'bedrock" with suffix "_depth_potential" appended to it)
 #%END
 #%flag
 #% key: s
@@ -71,17 +100,24 @@
 import grass.script as grass
 def main():
+    soildepth = "temp.soildepth"
+    tempsdepth = "temp.soildepth2"
     if os.getenv('GIS_OPT_soildepth') == None:
-        soildepth = "temp.soildepth"
+        soildepth2 = "temp.soildepth3"
     else:
-        soildepth = os.getenv('GIS_OPT_soildepth')
+        soildepth2 = os.getenv('GIS_OPT_soildepth')
     elev = os.getenv('GIS_OPT_elev')
     bedrock = os.getenv('GIS_OPT_bedrock')
-    min = os.getenv('GIS_OPT_min')
-    max = os.getenv('GIS_OPT_max')
+    smoothingtype = os.getenv('GIS_OPT_smoothingtype')
+    smoothingsize = os.getenv('GIS_OPT_smoothingsize')
+    slopebreaks = os.getenv('GIS_OPT_slopebreaks').split(";")
+    curvebreaks = os.getenv('GIS_OPT_curvebreaks').split(";")
+    smin = os.getenv('GIS_OPT_min')
+    smax = os.getenv('GIS_OPT_max')
     slope = "temp_slope_deletable"
     pc = "temp_pc_deletable"
     tc = "temp_tc_deletable"
+    mc = "temp_mc_deletable"
     temprate = "temp_rate_deletable"
     #let's grab the current resolution
     res = grass.region()['nsres']
@@ -89,41 +125,56 @@
     sdcolors = tempfile.NamedTemporaryFile()
     sdcolors.write('100% 0:249:47\n20% 78:151:211\n6% 194:84:171\n0% 227:174:217')
     sdcolors.flush()
-    grass.message('STEP 1, calculating profile and tangental curvatures\n')
-    grass.run_command('r.slope.aspect', quiet = "True", overwrite = "True", format='percent', elevation=elev, slope=slope, pcurv=pc, tcurv=tc)
-    grass.message('STEP 2, Calculating soil depth ratios across the landscape\n')
-    grass.mapcalc("${temprate}=eval(x = (-1.000*(${pc} + ${tc})), y = (if(${slope} < 1.000, 1.000, ${slope})), ((50.000*x)+50.000)/y)", quiet = "True", temprate = temprate, pc = pc, tc = tc, slope = slope)
+    grass.message('STEP 1, Calculating curvatures\n')
+    grass.run_command('r.slope.aspect', quiet = "True", overwrite = "True", elevation=elev, slope=slope, pcurv=pc, tcurv=tc)
+    #creat meancurvature map (in a manner compatible with older versions of grass6), and then grab some stats from it for the later rescale operation
+    grass.mapcalc("${mc}=(${tc}+${pc})/2", quiet = "True", mc = mc, tc = tc, pc = pc)
+    mcdict = grass.parse_command('r.univar', flags = "g", map=mc)
+    #figuring out if user-supplied curvature breakpoints exceed actual limits of curvature in the map, and adjusting if necessary
+    if mcdict['min'] < curvebreaks[0].split(',')[0]:
+        y1 = mcdict['min'] + ',' + curvebreaks[0].split(',')[1]
+    else:
+        y1 = curvebreaks[0]
+    if mcdict['max'] > curvebreaks[1].split(',')[0]:
+        y2 = mcdict['max'] + ',' + curvebreaks[1].split(',')[1]
+    else:
+        y2 = curvebreaks[1]
+    grass.message('STEP 2, Calculating "depth potential" across the landscape\n')
+    #nested rescale of first slope (to percentage of maximum soil depth potential), and then curvature (to percentage offset from slope function), and then combining the two measures to make final estimation of soil depth potential. Final output depth potential map will be scaled between 0 and 1, which maps to lowest depth potential to highest depth potential.
+    grass.mapcalc("${temprate}=eval(x=graph( ${slope}, 0,1 , ${x1}, ${x2}, 90,0), y=graph(${mc}, ${y1}, 0,0, ${y2}), z=if(y < 0, x+(x*y), x+((1-x)*y)), if(z < 0, 0, if(z > 1, 1, z)))", quiet = "True", temprate = temprate, slope = slope, x1 = slopebreaks[0], x2 = slopebreaks[1], mc = mc, y1 = y1, y2 = y2)
+    grass.message('STEP 3, Calculating actual soil depths across the landscape (based on user input min and max soil depth values)\n')
     # create dictionary to record max and min rate so we can rescale it according the user supplied max and min desired soil depths
-    ratedict = grass.parse_command('r.info', flags = 'r', map=temprate)
-    grass.message('STEP 3, Calculating actual soil depths across the landscape (based on user input min and max soil depth values)\n')
-    #creating and running a linear regression to scale the calculated landform soil depth ratios into real soil dpeths using user specified min and max soil depth values
-    #grass_com('r.mapcalc "' + soildepth + '=eval(x = ((' + ratedict['max'] + '-' + max +')/(' + ratedict['min'] + '-' + min + ')), y = (' + ratedict['max'] + '-(y*' + ratedict['min'] + ')), (y*' + temprate + ')+x)"')  #####this is the discreet way using mapcalc, I thik the r.recode way (below) may be faster
-    recode =  tempfile.NamedTemporaryFile()
-    recode.write('%s:%s:%s:%s' % (ratedict['min'] , ratedict['max'] ,  min,  max))
-    recode.flush()
-    grass.run_command('r.recode', quiet = "True", input=temprate, output=soildepth, rules=recode.name)
-    recode.close()
+    ratedict = grass.parse_command('r.univar', flags = "g", map=temprate)
+    #creating and running a linear regression to scale the calculated landform soil depth potential into real soil depths using user specified min and max soil depth values
+    grass.mapcalc('${soildepth}=graph(${temprate}, ${rmin},${smin}, ${rmax},${smax})', quiet = "True", soildepth = soildepth, temprate = temprate, rmin = ratedict['min'], rmax = ratedict['max'], smin = smin, smax = smax)
+    unsmodict = grass.parse_command('r.univar', flags = "g", map=soildepth)
+    grass.run_command('r.neighbors', quiet = "True", input=soildepth, output=tempsdepth, size=smoothingsize, method=smoothingtype)
+    #fix shrinking edge caused by eighborhood operation (and r.slope.aspect above) by filling in the null areas. We do this by 0.98 * smax, since the null cells are all the cells of the actual drainage divide with slope basically = 0, and very mildly convex curvatures. This basically blends them in nicely with the neighboring cells.
+    grass.mapcalc('${soildepth_real}=if(isnull(${input_sdepth}) && isnull(${elev}), null(), if(isnull(${input_sdepth}), 0.98*${smax},${input_sdepth}))', quiet = 'True',  input_sdepth = tempsdepth , soildepth_real = soildepth2, elev = elev, smax = smax)
     #grab some stats if asked to
     if os.getenv('GIS_FLAG_s') == '1':
-        depthdict = grass.parse_command('r.univar', flags = "ge", map=soildepth, percentile=90)
+        depthdict = grass.parse_command('r.univar', flags = "ge", map=soildepth2, percentile=90)
     grass.message('STEP 4, calculating bedrock elevation map\n')
-    grass.mapcalc("${bedrock}=(${elev} - ${soildepth})", quiet = "True", bedrock = bedrock, elev = elev, soildepth = soildepth)
+    grass.mapcalc("${bedrock}=eval(x=(${elev} - ${soildepth}), if(isnull(x), ${elev}, x))", quiet = "True", bedrock = bedrock, elev = elev, soildepth = soildepth)
     grass.message('Cleaning up...')
+    grass.run_command('g.remove', quiet = "true", rast = [pc, tc, mc, slope, soildepth, tempsdepth])
     if os.getenv('GIS_FLAG_k') == '1':
-        grass.run_command('g.remove', quiet = "true", rast = [pc, tc, slope])
-        grass.run_command('g.rename', quiet = "true", rast = "%s,%s%s_rate" % (temprate, temprate, bedrock))
+        grass.run_command('g.rename', quiet = "true", rast = "%s,%s_depth_potential" % (temprate, bedrock))
     else:
-        grass.run_command('g.remove', quiet = "True", rast = [pc, tc, temprate, slope])
+        grass.run_command('g.remove', quiet = "True", rast = temprate)
     if os.getenv('GIS_OPT_soildepth') is None:
-        grass.run_command('g.remove', quiet = "true", rast = soildepth)
+        grass.run_command('g.remove', quiet = "true", rast = soildepth2)
     else:
-        grass.run_command('r.colors', quiet = "True", map=soildepth, rules=sdcolors.name)
+        grass.run_command('r.colors', quiet = "True", map=soildepth2, rules=sdcolors.name)
     grass.message('\nDONE!\n')
-        # have to figure that part out!
+        grass.message("min, max, and mean before smoothing: " + unsmodict['min']  + ", " + unsmodict['max'] + ", " + unsmodict['mean'])
         for key in depthdict.keys():
             grass.message('%s=%s' % (key,  depthdict[key]))
-        grass.message('Total volume of soil is %s cubic meters' % (float(depthdict['sum'])*res))
+        grass.message('Total volume of soil is %s cubic meters' % (float(depthdict['sum'])*res*res))
     return
 # here is where the code in "main" actually gets executed. This way of programming is neccessary for the way g.parser needs to run.
