[GRASS-SVN] r51595 - in grass/trunk: include/defs lib/python/ctypes
lib/python/temporal lib/vector/Vlib
svn_grass at osgeo.org
Fri May 4 21:57:37 EDT 2012
Author: huhabla
Date: 2012-05-04 18:57:37 -0700 (Fri, 04 May 2012)
New Revision: 51595
Added:
grass/trunk/lib/vector/Vlib/rtree_search.c
grass/trunk/include/defs/vector.h
grass/trunk/lib/python/ctypes/Makefile
grass/trunk/lib/python/temporal/spatial_extent.py
grass/trunk/lib/python/temporal/unit_tests.py
Added the rtree library to ctypes Python wrapper and vector support functions
to be used by the temporal GIS framework for efficient spatio-temporal topology creation.
Added a new RTreeSearch function to use an ilist to store rectangle ids.
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h 2012-05-04 22:53:24 UTC (rev 51594)
+++ grass/trunk/include/defs/vector.h 2012-05-05 01:57:37 UTC (rev 51595)
@@ -566,4 +566,7 @@
int Vect_remove_colors(const char *, const char *);
void Vect_write_colors(const char *, const char *, struct Colors *);
+/* Simplified RTree search using an ilist to store rectangle ids */
+int RTreeSearch2(struct RTree *, struct RTree_Rect *, struct ilist *);
#endif /* GRASS_VECTORDEFS_H */
Modified: grass/trunk/lib/python/ctypes/Makefile
--- grass/trunk/lib/python/ctypes/Makefile 2012-05-04 22:53:24 UTC (rev 51594)
+++ grass/trunk/lib/python/ctypes/Makefile 2012-05-05 01:57:37 UTC (rev 51595)
@@ -35,7 +35,7 @@
gmath_HDRS = gmath.h defs/gmath.h
proj_HDRS = gprojects.h defs/gprojects.h
imagery_HDRS = imagery.h defs/imagery.h
-vector_HDRS = vector.h defs/vector.h vect/dig_structs.h vect/dig_defines.h
+vector_HDRS = vector.h defs/vector.h vect/dig_structs.h vect/dig_defines.h vect/dig_externs.h rtree/index.h
display_HDRS = display.h defs/display.h
stats_HDRS = stats.h defs/stats.h
dbmi_HDRS = dbmi.h defs/dbmi.h
Modified: grass/trunk/lib/python/temporal/spatial_extent.py
--- grass/trunk/lib/python/temporal/spatial_extent.py 2012-05-04 22:53:24 UTC (rev 51594)
+++ grass/trunk/lib/python/temporal/spatial_extent.py 2012-05-05 01:57:37 UTC (rev 51595)
@@ -678,7 +678,7 @@
return True
def meet(self,extent):
- """ Check if self and extent meet other in three dimensions"""
+ """ Check if self and extent meet each other in three dimensions"""
eN = extent.get_north()
eS = extent.get_south()
eE = extent.get_east()
Modified: grass/trunk/lib/python/temporal/unit_tests.py
--- grass/trunk/lib/python/temporal/unit_tests.py 2012-05-04 22:53:24 UTC (rev 51594)
+++ grass/trunk/lib/python/temporal/unit_tests.py 2012-05-05 01:57:37 UTC (rev 51595)
@@ -27,6 +27,9 @@
from datetime_math import *
from space_time_datasets import *
+import grass.lib.vector as vector
+from ctypes import *
# Uncomment this to detect the error
#core.set_raise_on_error(True)
@@ -1565,17 +1568,59 @@
if new_list[2] != map_list[2]:
core.fatal("Sorting by end time failed")
+def test_rtree():
+ """Testing the rtree ctypes wrapper"""
+ tree = vector.RTreeNewIndex(-1, 0, 1)
+ for i in xrange(50):
+ rect = vector.RTree_Rect()
+ vector.RTreeInitRect(byref(rect))
+ rect.boundary[0] = i - 3.75
+ rect.boundary[1] = 0
+ rect.boundary[2] = 0
+ rect.boundary[3] = i + 3.75
+ rect.boundary[4] = 0
+ rect.boundary[5] = 0
+ # vector.RTreePrintRect(byref(rect), 0)
+ vector.RTreeInsertRect(byref(rect), i + 1, tree)
+ i = 25
+ _list = vector.ilist()
+ num = vector.RTreeSearch2(tree, byref(rect), byref(_list))
+ # print rectanlge ids
+ print "Number of overlapping rectangles", num
+ for i in xrange(_list.n_values):
+ print "id", _list.value[i]
if __name__ == "__main__":
test_increment_datetime_by_string()
test_adjust_datetime_to_granularity()
test_spatial_extent_intersection()
- ##test_compute_relative_time_granularity()
+ #test_compute_relative_time_granularity()
test_compute_absolute_time_granularity()
test_compute_datetime_delta()
test_spatial_relations()
test_temporal_topology_builder()
test_map_list_sorting()
\ No newline at end of file
+ test_rtree()
Added: grass/trunk/lib/vector/Vlib/rtree_search.c
--- grass/trunk/lib/vector/Vlib/rtree_search.c (rev 0)
+++ grass/trunk/lib/vector/Vlib/rtree_search.c 2012-05-05 01:57:37 UTC (rev 51595)
@@ -0,0 +1,46 @@
+ \file lib/vector/Vlib/rtree_search.c
+ \brief Vector library - simplified rtree search
+ Higher level functions for reading/writing/manipulating vectors.
+ (C) 2012 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Soeren Gebbert
+#include <assert.h>
+#include <grass/vector.h>
+/* Function to add the ids of overlapping rectangles to an ilist
+ * This function is a callback function used in RTreeSearch2()
+static int add_id_to_list(int id, struct RTree_Rect rect, void *list)
+ struct ilist *l = (struct ilist*)list;
+ dig_list_add(l, id);
+ return 1;
+ * Search in an index tree for all data retangles that
+ * overlap the argument rectangle.
+ * \param t: The RTree
+ * \param r: The argument rectangle
+ * \param list: The list to store the ids of overlapping rectangles
+ * \return the number of qualifying data rects.
+int RTreeSearch2(struct RTree *t, struct RTree_Rect *r, struct ilist *list)
+ assert(r && t);
+ dig_init_list(list);
+ return t->search_rect(t, r, add_id_to_list, (void*)list);
