[GRASS-SVN] r51600 - grass/trunk/lib/gmath
svn_grass at osgeo.org
Tue May 8 07:31:58 EDT 2012
Author: mmetz
Date: 2012-05-08 04:31:58 -0700 (Tue, 08 May 2012)
New Revision: 51600
grass/trunk/lib/gmath/blas_level_2.c
grass/trunk/lib/gmath/blas_level_3.c
gmath lib: fix typos
Modified: grass/trunk/lib/gmath/blas_level_2.c
--- grass/trunk/lib/gmath/blas_level_2.c 2012-05-05 08:58:18 UTC (rev 51599)
+++ grass/trunk/lib/gmath/blas_level_2.c 2012-05-08 11:31:58 UTC (rev 51600)
@@ -126,7 +126,7 @@
- * \brief Compute the dyadic product of twMo vectors.
+ * \brief Compute the dyadic product of two vectors.
* The result is stored in the matrix A.
* This function is multi-threaded with OpenMP and can be called within a parallel OpenMP region.
Modified: grass/trunk/lib/gmath/blas_level_3.c
--- grass/trunk/lib/gmath/blas_level_3.c 2012-05-05 08:58:18 UTC (rev 51599)
+++ grass/trunk/lib/gmath/blas_level_3.c 2012-05-08 11:31:58 UTC (rev 51600)
@@ -157,7 +157,7 @@
* A must be of size rows_A * cols_A
* B must be of size rows_B * cols_B with rows_B == cols_A
- * C must be of size rows_A * rows_B
+ * C must be of size rows_A * cols_B
@@ -167,18 +167,18 @@
* \param C (double **)
* \param rows_A (int)
* \param cols_A (int)
- * \param rows_B (int)
+ * \param cols_B (int)
* \return (void)
void G_math_d_AB(double **A, double **B, double **C, int rows_A,
- int cols_A, int rows_B)
+ int cols_A, int cols_B)
int i, j, k;
#pragma omp for schedule (static) private(i, j, k)
for (i = 0; i < rows_A; i++) {
- for (j = 0; j < rows_B; j++) {
+ for (j = 0; j < cols_B; j++) {
C[i][j] = 0.0;
for (k = cols_A - 1; k >= 0; k--) {
C[i][j] += A[i][k] * B[k][j];
@@ -198,7 +198,7 @@
@@ -208,18 +208,18 @@
* \param C (float **)
* \return (void)
void G_math_f_AB(float **A, float **B, float **C, int rows_A,
int i, j, k;
C[i][j] = 0.0;
