[GRASS-SVN] r51606 - in grass/branches/develbranch_6/raster/r.watershed: ram seg
Wed May 9 06:18:57 EDT 2012
Author: mmetz
Date: 2012-05-09 03:18:57 -0700 (Wed, 09 May 2012)
New Revision: 51606
   grass/branches/develbranch_6/raster/r.watershed/ram/def_basin.c
   grass/branches/develbranch_6/raster/r.watershed/ram/do_cum.c
   grass/branches/develbranch_6/raster/r.watershed/seg/def_basin.c
   grass/branches/develbranch_6/raster/r.watershed/seg/do_cum.c
r.watershed: fix drainage directions
Modified: grass/branches/develbranch_6/raster/r.watershed/ram/def_basin.c
--- grass/branches/develbranch_6/raster/r.watershed/ram/def_basin.c	2012-05-09 10:18:03 UTC (rev 51605)
+++ grass/branches/develbranch_6/raster/r.watershed/ram/def_basin.c	2012-05-09 10:18:57 UTC (rev 51606)
@@ -18,7 +18,7 @@
 	    for (c = col - 1, cc = 0; cc < 3; c++, cc++) {
 		if (r >= 0 && c >= 0 && r < nrows && c < ncols) {
 		    value = asp[SEG_INDEX(asp_seg, r, c)];
-		    if (value < -1)
+		    if (value < 0)
 			value = -value;
 		    if (value == drain[rr][cc]) {
 			value = FLAG_GET(swale, r, c);
Modified: grass/branches/develbranch_6/raster/r.watershed/ram/do_cum.c
--- grass/branches/develbranch_6/raster/r.watershed/ram/do_cum.c	2012-05-09 10:18:03 UTC (rev 51605)
+++ grass/branches/develbranch_6/raster/r.watershed/ram/do_cum.c	2012-05-09 10:18:57 UTC (rev 51606)
@@ -108,7 +108,7 @@
     int r_nbr, c_nbr, r_max, c_max, ct_dir, np_side;
     double dx, dy;
     CELL ele, ele_nbr, aspect, is_worked;
-    double prop, max_acc;
+    double prop, max_val;
     int workedon, edge, flat;
     SHORT asp_r[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
     SHORT asp_c[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
@@ -259,7 +259,7 @@
 	    /* set flow accumulation for neighbours */
-	    max_acc = -1;
+	    max_val = -1;
 	    if (mfd_cells > 1) {
 		prop = 0.0;
@@ -276,6 +276,13 @@
 			    nbr_index = SEG_INDEX(wat_seg, r_nbr, c_nbr);
+			    /* get main drainage direction */
+			    if (weight[ct_dir] > max_val) {
+				max_val = weight[ct_dir];
+				r_max = r_nbr;
+				c_max = c_nbr;
 			    weight[ct_dir] = weight[ct_dir] / sum_weight;
 			    /* check everything sums up to 1.0 */
 			    prop += weight[ct_dir];
@@ -294,13 +301,6 @@
 				    valued = value * weight[ct_dir] - valued;
 			    wat[nbr_index] = valued;
-			    /* get main drainage direction */
-			    if (ABS(valued) >= max_acc) {
-				max_acc = ABS(valued);
-				r_max = r_nbr;
-				c_max = c_nbr;
 			else if (ct_dir == np_side) {
 			    /* check for consistency with A * path */
Modified: grass/branches/develbranch_6/raster/r.watershed/seg/def_basin.c
--- grass/branches/develbranch_6/raster/r.watershed/seg/def_basin.c	2012-05-09 10:18:03 UTC (rev 51605)
+++ grass/branches/develbranch_6/raster/r.watershed/seg/def_basin.c	2012-05-09 10:18:57 UTC (rev 51606)
@@ -19,7 +19,7 @@
 		    cseg_get(&asp, &value, r, c);
-		    if (value < -1)
+		    if (value < 0)
 			value = -value;
 			bseg_get(&swale, &value, r, c);
Modified: grass/branches/develbranch_6/raster/r.watershed/seg/do_cum.c
--- grass/branches/develbranch_6/raster/r.watershed/seg/do_cum.c	2012-05-09 10:18:03 UTC (rev 51605)
+++ grass/branches/develbranch_6/raster/r.watershed/seg/do_cum.c	2012-05-09 10:18:57 UTC (rev 51606)
@@ -113,7 +113,7 @@
     double dx, dy;
     CELL ele, ele_nbr, asp_val, asp_val2, cvalue, *worked_nbr;
@@ -275,7 +275,7 @@
-	    max_acc = -1;
+	    max_val = -1;
 		prop = 0.0;
@@ -290,6 +290,13 @@
 			/* bseg_get(&worked, &is_worked, r_nbr, c_nbr); */
 			if (worked_nbr[ct_dir] == 0) {
+				r_max = r_nbr;
+				c_max = c_nbr;
@@ -308,13 +315,6 @@
 			    valued = wat_nbr[ct_dir];
 			    dseg_put(&wat, &valued, r_nbr, c_nbr);
-			    if (ABS(wat_nbr[ct_dir]) >= max_acc) {
-				max_acc = ABS(wat_nbr[ct_dir]);
-				r_max = r_nbr;
-				c_max = c_nbr;
