[GRASS-SVN] r51618 - in grass/trunk/vector: . v.what.rast3
	v.what.rast3/test_suite
    svn_grass at osgeo.org
    Mon May 14 04:08:54 EDT 2012
Author: huhabla
Date: 2012-05-14 01:08:53 -0700 (Mon, 14 May 2012)
New Revision: 51618
Added:
   grass/trunk/vector/v.what.rast3/
   grass/trunk/vector/v.what.rast3/Makefile
   grass/trunk/vector/v.what.rast3/local_proto.h
   grass/trunk/vector/v.what.rast3/main.c
   grass/trunk/vector/v.what.rast3/search.c
   grass/trunk/vector/v.what.rast3/test_suite/
   grass/trunk/vector/v.what.rast3/test_suite/random_points.ref
   grass/trunk/vector/v.what.rast3/test_suite/random_points.txt
   grass/trunk/vector/v.what.rast3/test_suite/random_points_db.ref
   grass/trunk/vector/v.what.rast3/test_suite/test.v.what.rast3.sh
   grass/trunk/vector/v.what.rast3/v.what.rast3.html
   grass/trunk/vector/Makefile
Added a new module to sample 3d raster maps with vector points.
Modified: grass/trunk/vector/Makefile
--- grass/trunk/vector/Makefile	2012-05-14 07:57:51 UTC (rev 51617)
+++ grass/trunk/vector/Makefile	2012-05-14 08:08:53 UTC (rev 51618)
@@ -90,6 +90,7 @@
 	v.voronoi \
 	v.what \
 	v.what.rast \
+	v.what.rast3 \
 	v.vect.stats \
 	v.vol.rst \
 	v.out.ogr \
Added: grass/trunk/vector/v.what.rast3/Makefile
--- grass/trunk/vector/v.what.rast3/Makefile	                        (rev 0)
+++ grass/trunk/vector/v.what.rast3/Makefile	2012-05-14 08:08:53 UTC (rev 51618)
@@ -0,0 +1,14 @@
+MODULE_TOPDIR = ../..
+PGM=v.what.rast3
+LIBES = $(VECTORLIB) $(DBMILIB) $(RASTER3DLIB) $(GISLIB)
+DEPENDENCIES = $(VECTORDEP) $(DBMIDEP) $(RASTER3DDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass/trunk/vector/v.what.rast3/local_proto.h
--- grass/trunk/vector/v.what.rast3/local_proto.h	                        (rev 0)
+++ grass/trunk/vector/v.what.rast3/local_proto.h	2012-05-14 08:08:53 UTC (rev 51618)
@@ -0,0 +1,16 @@
+#include <grass/gis.h>
+struct order
+    int cat;			/* point category */
+    int count;			/* nuber of points with category 'cat' */
+    double x;
+    double y;
+    double z;
+    FCELL fvalue;
+    DCELL dvalue;
+/* search.c */
+int by_cat(const void *, const void *);
+int srch_cat(const void *, const void *);
Added: grass/trunk/vector/v.what.rast3/main.c
--- grass/trunk/vector/v.what.rast3/main.c	                        (rev 0)
+++ grass/trunk/vector/v.what.rast3/main.c	2012-05-14 08:08:53 UTC (rev 51618)
@@ -0,0 +1,333 @@
+ * MODULE:       v.what.rast3
+ * AUTHOR(S):    Soeren Gebbert, this code is based on a slightly modified version of
+ *               v.what.rast from Radim Blazek and Michael Shapiro
+ *  PURPOSE:      Uploads 3d raster values at positions of vector points to the table
+ *  COPYRIGHT:    (C) 2001, 2011 by the GRASS Development Team
+ *                This program is free software under the GNU General
+ *                Public License (>=v2).  Read the file COPYING that
+ *                comes with GRASS for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/raster3d.h>
+#include <grass/dbmi.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+int main(int argc, char *argv[])
+    int i, j, nlines, type, field, cat;
+    char buf[2048];
+    struct {
+	struct Option *vect, *rast3d, *field, *col, *where;
+    } opt;
+    int Cache_size;
+    struct order *cache;
+    struct GModule *module;
+    RASTER3D_Region region;
+    RASTER3D_Map *map;
+    struct Map_info Map;
+    struct line_pnts *Points;
+    struct line_cats *Cats;
+    int point;
+    int point_cnt;		/* number of points in cache */
+    int outside_cnt;		/* points outside region */
+    int nocat_cnt;		/* points inside region but without category */
+    int dupl_cnt;		/* duplicate categories */
+    int typeIntern;
+    int is_empty;
+    struct bound_box box;
+    int *catexst, *cex;
+    struct field_info *Fi;
+    dbString stmt;
+    dbDriver *driver;
+    int select, norec_cnt, update_cnt, upderr_cnt, col_type;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("vector"));
+    G_add_keyword(_("raster"));
+    G_add_keyword(_("position"));
+    G_add_keyword(_("querying"));
+    G_add_keyword(_("attribute table"));
+    module->description =
+	_("Uploads 3d raster values at positions of vector points to the table.");
+    opt.vect = G_define_standard_option(G_OPT_V_MAP);
+    opt.vect->label =
+	_("Name of vector points map for which to edit attributes");
+    opt.field = G_define_standard_option(G_OPT_V_FIELD);
+    opt.rast3d = G_define_standard_option(G_OPT_R3_MAP);
+    opt.rast3d->key = "raster3d";
+    opt.rast3d->description = _("Name of existing 3d raster map to be queried");
+    opt.col = G_define_standard_option(G_OPT_DB_COLUMN);
+    opt.col->required = YES;
+    opt.col->description =
+	_("Name of attribute column to be updated with the query result");
+    opt.where = G_define_standard_option(G_OPT_DB_WHERE);
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    db_init_string(&stmt);
+    Points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    /* Initiate the default settings */
+    Rast3d_init_defaults();
+    /* Figure out the current region settings */
+    Rast3d_get_window(®ion);
+    box.N = region.north;
+    box.S = region.south;
+    box.E = region.east;
+    box.W = region.west;
+    box.T = region.top;
+    box.B = region.bottom;
+    /* Open vector */
+    Vect_set_open_level(2);
+    Vect_open_old2(&Map, opt.vect->answer, "", opt.field->answer);
+    field = Vect_get_field_number(&Map, opt.field->answer);
+    Fi = Vect_get_field(&Map, field);
+    if (Fi == NULL)
+	G_fatal_error(_("Database connection not defined for layer %d"),
+		      field);
+    /* Open driver */
+    driver = db_start_driver_open_database(Fi->driver, Fi->database);
+    if (driver == NULL) {
+	G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+		      Fi->database, Fi->driver);
+    map = Rast3d_open_cell_old(opt.rast3d->answer, G_find_raster3d(opt.rast3d->answer, ""), ®ion,
+                          RASTER3D_TILE_SAME_AS_FILE, RASTER3D_USE_CACHE_DEFAULT);
+    if (map == NULL)
+        G_fatal_error(_("Error opening 3d raster map <%s>"), opt.rast3d->answer);
+    /* Check column type */
+    col_type = db_column_Ctype(driver, Fi->table, opt.col->answer);
+    if (col_type == -1)
+	G_fatal_error(_("Column <%s> not found"), opt.col->answer);
+    if (col_type != DB_C_TYPE_DOUBLE)
+	G_fatal_error(_("Column type not supported, please use a column with double type"));
+    /* Read vector points to cache */
+    Cache_size = Vect_get_num_primitives(&Map, GV_POINT);
+    /* Note: Some space may be wasted (outside region or no category) */
+    cache = (struct order *)G_calloc(Cache_size, sizeof(struct order));
+    point_cnt = outside_cnt = nocat_cnt = 0;
+    nlines = Vect_get_num_lines(&Map);
+    G_debug(1, "Reading %d vector features from map", nlines);
+    G_important_message(_("Reading features from vector map..."));
+    for (i = 1; i <= nlines; i++) {
+	type = Vect_read_line(&Map, Points, Cats, i);
+	G_debug(4, "line = %d type = %d", i, type);
+	G_percent(i, nlines, 2);
+	/* check type */
+	if (!(type & GV_POINT))
+	    continue;		/* Points only */
+	/* check region */
+	if (!Vect_point_in_box(Points->x[0], Points->y[0], Points->z[0], &box)) {
+	    outside_cnt++;
+	    continue;
+	Vect_cat_get(Cats, field, &cat);
+	if (cat < 0) {		/* no category of given field */
+	    nocat_cnt++;
+	    continue;
+	G_debug(4, "    cat = %d", cat);
+	cache[point_cnt].x = Points->x[0];
+	cache[point_cnt].y = Points->y[0];
+	cache[point_cnt].z = Points->z[0];
+	cache[point_cnt].cat = cat;
+	cache[point_cnt].count = 1;
+	point_cnt++;
+    Vect_set_db_updated(&Map);
+    Vect_hist_command(&Map);
+    Vect_close(&Map);
+    G_debug(1, "Read %d vector points", point_cnt);
+    /* Cache may contain duplicate categories, sort by cat, find and remove duplicates
+     * and recalc count and decrease point_cnt  */
+    qsort(cache, point_cnt, sizeof(struct order), by_cat);
+    G_debug(1, "Points are sorted, starting duplicate removal loop");
+    for (i = 0, j = 1; j < point_cnt; j++)
+	if (cache[i].cat != cache[j].cat)
+	    cache[++i] = cache[j];
+	else
+	    cache[i].count++;
+    point_cnt = i + 1;
+    G_debug(1, "%d vector points left after removal of duplicates",
+	    point_cnt);
+    /* Report number of points not used */
+    if (outside_cnt)
+	G_warning(_("%d points outside current region were skipped"),
+		  outside_cnt);
+    if (nocat_cnt)
+	G_warning(_("%d points without category were skipped"), nocat_cnt);
+    /* Extract raster values from file and store in cache */
+    G_debug(1, "Extracting raster values");
+    typeIntern = Rast3d_tile_type_map(map);
+    /* Sample the 3d raster map */
+    for (point = 0; point < point_cnt; point++) {
+	if (cache[point].count > 1)
+	    continue;		/* duplicate cats */
+        if(typeIntern == FCELL_TYPE) {
+            Rast3d_get_window_value(map, cache[point].y, cache[point].x, cache[point].z,
+                       &cache[point].fvalue, FCELL_TYPE);
+        } else {
+                       &cache[point].dvalue, DCELL_TYPE);
+    Rast3d_close(map);
+    /* Update table from cache */
+    G_debug(1, "Updating db table");
+    /* select existing categories to array (array is sorted) */
+    select = db_select_int(driver, Fi->table, Fi->key, NULL, &catexst);
+    db_begin_transaction(driver);
+    norec_cnt = update_cnt = upderr_cnt = dupl_cnt = 0;
+    G_message("Update vector attributes...");
+	if (cache[point].count > 1) {
+	    G_warning(_("More points (%d) of category %d, value set to 'NULL'"),
+		      cache[point].count, cache[point].cat);
+	    dupl_cnt++;
+	G_percent(point, point_cnt, 2);
+	/* category exist in DB ? */
+	cex =
+	    (int *)bsearch((void *)&(cache[point].cat), catexst, select,
+			   sizeof(int), srch_cat);
+	if (cex == NULL) {	/* cat does not exist in DB */
+	    norec_cnt++;
+	    G_warning(_("No record for category %d in table <%s>"),
+		      cache[point].cat, Fi->table);
+	    continue;
+	G_snprintf(buf, 2048, "update %s set %s = ", Fi->table, opt.col->answer);
+	db_set_string(&stmt, buf);
+        is_empty = 0;
+            is_empty = 1;
+            is_empty = Rast3d_is_null_value_num(&cache[point].fvalue, FCELL_TYPE);
+        if(typeIntern == DCELL_TYPE)
+            is_empty = Rast3d_is_null_value_num(&cache[point].dvalue, DCELL_TYPE);
+        if (is_empty) {
+            G_snprintf(buf, 2048, "NULL");
+        }else {
+                G_snprintf(buf, 2048, "%.10f", cache[point].fvalue);
+                G_snprintf(buf, 2048, "%.15f", cache[point].dvalue);
+	db_append_string(&stmt, buf);
+	G_snprintf(buf, 2048, " where %s = %d", Fi->key, cache[point].cat);
+	/* user provides where condition: */
+	if (opt.where->answer) {
+	    G_snprintf(buf, 2048, " AND %s", opt.where->answer);
+	G_debug(3, db_get_string(&stmt));
+	/* Update table */
+	if (db_execute_immediate(driver, &stmt) == DB_OK) {
+	    update_cnt++;
+	else {
+	    upderr_cnt++;
+    G_percent(1, 1, 1);
+    G_debug(1, "Committing DB transaction");
+    db_commit_transaction(driver);
+    G_free(catexst);
+    db_close_database_shutdown_driver(driver);
+    db_free_string(&stmt);
+    /* Report */
+    G_verbose_message(_("%d categories loaded from table"), select);
+    G_verbose_message(_("%d categories loaded from vector"), point_cnt);
+    G_verbose_message(_("%d categories from vector missing in table"), norec_cnt);
+    if (dupl_cnt > 0)
+	G_message(_("%d duplicate categories in vector"), dupl_cnt);
+    if (upderr_cnt > 0)
+	G_warning(_("%d update errors"), upderr_cnt);
+    G_done_msg(_("%d records updated."), update_cnt);
+    exit(EXIT_SUCCESS);
Added: grass/trunk/vector/v.what.rast3/search.c
--- grass/trunk/vector/v.what.rast3/search.c	                        (rev 0)
+++ grass/trunk/vector/v.what.rast3/search.c	2012-05-14 08:08:53 UTC (rev 51618)
@@ -0,0 +1,22 @@
+/* for qsort, order list by cat */
+int by_cat(const void *ii, const void *jj)
+    const struct order *i = ii, *j = jj;
+    return i->cat - j->cat;
+/* for bsearch, find cat */
+int srch_cat(const void *pa, const void *pb)
+    int *p1 = (int *)pa;
+    int *p2 = (int *)pb;
+    if (*p1 < *p2)
+	return -1;
+    if (*p1 > *p2)
+	return 1;
+    return 0;
Added: grass/trunk/vector/v.what.rast3/test_suite/random_points.ref
--- grass/trunk/vector/v.what.rast3/test_suite/random_points.ref	                        (rev 0)
+++ grass/trunk/vector/v.what.rast3/test_suite/random_points.ref	2012-05-14 08:08:53 UTC (rev 51618)
@@ -0,0 +1,40 @@
+ORGANIZATION:
+DIGIT DATE:
+DIGIT NAME:   soeren
+MAP NAME:
+MAP DATE:     Sun May 13 00:35:59 2012
+MAP SCALE:    1
+OTHER INFO:
+ZONE:         0
+MAP THRESH:   0.000000
+VERTI:
+P  1 1
+ 15.98122828  27.60680488  39.15496119
+ 1     1
+P  1 1
+ 20.15599665  63.81531506  9.87756846
+ 1     2
+P  1 1
+ 66.47772443  53.77607164  13.88873554
+ 1     3
+P  1 1
+ 44.60300442  33.41779363  31.44354624
+ 1     4
+P  1 1
+ 63.52155272  35.93806371  47.61148626
+ 1     5
+P  1 1
+ 8.3804932    44.49982096  35.86484647
+ 1     6
+P  1 1
+ 85.83974446  42.48782134  0.81502858
+ 1     7
+P  1 1
+ 75.71132294  9.60621038   40.20883771
+ 1     8
+P  1 1
+ 84.33209107  28.0661076   6.48952234
+ 1     9
+P  1 1
+ 89.1191198   69.92471626  10.91284527
+ 1     10
Added: grass/trunk/vector/v.what.rast3/test_suite/random_points.txt
--- grass/trunk/vector/v.what.rast3/test_suite/random_points.txt	                        (rev 0)
+++ grass/trunk/vector/v.what.rast3/test_suite/random_points.txt	2012-05-14 08:08:53 UTC (rev 51618)
@@ -0,0 +1,40 @@
+ORGANIZATION:
+DIGIT DATE:
+DIGIT NAME:   soeren
+MAP NAME:
+MAP SCALE:    1
+OTHER INFO:
+ZONE:         0
+VERTI:
+P  1 1
+ 1     1
+P  1 1
+ 1     2
+P  1 1
+ 1     3
+P  1 1
+ 1     4
+P  1 1
+ 1     5
+P  1 1
+ 1     6
+P  1 1
+ 1     7
+P  1 1
+ 1     8
+P  1 1
+ 1     9
+P  1 1
+ 1     10
Added: grass/trunk/vector/v.what.rast3/test_suite/random_points_db.ref
--- grass/trunk/vector/v.what.rast3/test_suite/random_points_db.ref	                        (rev 0)
+++ grass/trunk/vector/v.what.rast3/test_suite/random_points_db.ref	2012-05-14 08:08:53 UTC (rev 51618)
@@ -0,0 +1,11 @@
+cat|concentration
+1|11
+2|5
+3|11
+4|13
+5|16
+6|8
+7|13
+8|20
+9|15
+10|12
Added: grass/trunk/vector/v.what.rast3/test_suite/test.v.what.rast3.sh
--- grass/trunk/vector/v.what.rast3/test_suite/test.v.what.rast3.sh	                        (rev 0)
+++ grass/trunk/vector/v.what.rast3/test_suite/test.v.what.rast3.sh	2012-05-14 08:08:53 UTC (rev 51618)
@@ -0,0 +1,24 @@
+# This script tests v.what.rast3d
+# We specific a small region in the
+# @preprocess step
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=70 w=0 e=100 b=0 t=50 res=10 res3=10 -p3
+# Create the volume and the sampling vector map
+r3.mapcalc --o expr="plume = double(col() + row() + depth())"
+# This is how the input data was created
+# v.random --o -z seed=1 output=random_points n=10 zmin=0  zmax=50
+# v.out.ascii --o format=standard input=random_points output=random_points.txt
+v.in.ascii --o -z format=standard input=random_points.txt output=random_points
+v.db.addtable --o map=random_points column="concentration double precision"
+# @test the voxel sampling with vector points
+v.what.rast3 map=random_points raster3d=plume column=concentration
+# Some data export commands for reference data creation and visual validation
+#v.out.ascii --o format=standard input=random_points output=random_points.ref
+#v.db.select map=random_points > random_points_db.ref
+#r3.out.vtk --o input=plume output=plume.vtk null=0
+#v.out.vtk --o -n input=random_points output=random_points.vtk
Added: grass/trunk/vector/v.what.rast3/v.what.rast3.html
--- grass/trunk/vector/v.what.rast3/v.what.rast3.html	                        (rev 0)
+++ grass/trunk/vector/v.what.rast3/v.what.rast3.html	2012-05-14 08:08:53 UTC (rev 51618)
@@ -0,0 +1,57 @@
+<h2>DESCRIPTION</h2>
+<em>v.what.rast3</em> reads 3d raster value for each point in the vector and updates <b>col</b>
+column in vector attribute table by this value. The column should be type double. This module is based on
+<a href="v.what.rast.html">v.what.rast</a>.
+<br>
+If more points have the same category, attribute value is set to NULL.
+If 3d raster values is NULL, attribute value is set to NULL.
+<h2>NOTES</h2>
+<h2>EXAMPLES</h2>
+A) Reading values from 3d raster map at position of vector points, writing these values
+   into a column of the attribute table connected to the vector map:
+<br>
+<div class="code"><pre>
+v.what.rast3 map=pnts raster3d=plume column=concentration
+</pre></div>
+<p>
+B) In case of a vector map without attached attribute table, first add
+a new attribute table. This table is then populated with values
+queried from the raster map:
+<br>
+# create new random 3d vector points map
+v.random -z output=pnts n=100 zmin=0  zmax=50
+# add new table, link to map
+v.db.addtable map=pnts column="concentration double precision"
+# query raster map and upload values to vector table into specified column
+g.region rast3d=plume -p
+# verify new attribute table:
+v.db.select map=pnts
+# verify statistics of uploaded values:
+v.univar map=pnts column=concentration type=point
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.what.rast.html">v.what.rast</a>,
+<a href="v.db.addtable.html">v.db.addtable</a>,
+<a href="v.db.select.html">v.db.select</a>,
+<a href="v.univar.html">v.univar</a>
+</em>
+<h2>AUTHOR</h2>
+Soeren Gebbert, heavily based on v.what.rast by Radim Blazed
+<p>
+<i>Last changed: $Date: 2012-02-08 22:40:06 +0100 (Mi, 08 Feb 2012) $</i>
