[GRASS-SVN] r51620 - grass/trunk/gui/wxpython/location_wizard
svn_grass at osgeo.org
Mon May 14 06:06:24 EDT 2012
Author: hamish
Date: 2012-05-14 03:06:23 -0700 (Mon, 14 May 2012)
New Revision: 51620
grass/trunk/gui/wxpython/location_wizard/wizard.py
further support for swapping ellipse.table list with ellipse.table.solar.system list (#1513), not fully functional yet (assistance is welcome :)
Modified: grass/trunk/gui/wxpython/location_wizard/wizard.py
--- grass/trunk/gui/wxpython/location_wizard/wizard.py 2012-05-14 08:15:42 UTC (rev 51619)
+++ grass/trunk/gui/wxpython/location_wizard/wizard.py 2012-05-14 10:06:23 UTC (rev 51620)
@@ -990,15 +990,13 @@
# search box
self.searchb = wx.SearchCtrl(self, size = (200,-1),
style = wx.TE_PROCESS_ENTER)
-#todo: support for swapping ellipse.table list with ellipse.table.solar.system
# radio buttons
self.radio1 = wx.RadioButton(parent = self, id = wx.ID_ANY,
label = _("Earth based"),
style = wx.RB_GROUP)
self.radio2 = wx.RadioButton(parent = self, id = wx.ID_ANY,
label = _("Planetary bodies"))
# create list control for ellipse list
data = []
# extract code, desc
@@ -1020,11 +1018,10 @@
flag = wx.ALIGN_LEFT |
wx.ALIGN_CENTER_VERTICAL |
wx.ALL, border = 5, pos = (1, 2))
self.sizer.Add(item = self.radio1,
flag = wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.LEFT,
border = 25, pos = (1, 3))
self.sizer.Add(item = self.MakeLabel(_("Search in description:")),
flag = wx.ALIGN_RIGHT |
@@ -1033,11 +1030,10 @@
wx.ALL, border = 5, pos = (2, 2))
self.sizer.Add(item = self.radio2,
border = 25, pos = (2, 3))
self.sizer.AddGrowableRow(3)
self.sizer.Add(item = self.ellipselist,
flag = wx.EXPAND |
@@ -1049,10 +1045,10 @@
self.tellipse.Bind(wx.EVT_TEXT, self.OnText)
self.tellipse.Bind(wx.EVT_TEXT_ENTER, self.OnText)
self.searchb.Bind(wx.EVT_TEXT_ENTER, self.OnSearch)
self.radio1.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio1.GetId())
self.radio2.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio2.GetId())
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChanging)
@@ -1062,13 +1058,13 @@
wx.FindWindowById(wx.ID_FORWARD).Enable(False)
else:
wx.FindWindowById(wx.ID_FORWARD).Enable(True)
self.scope = 'earth'
event.Skip()
def OnPageChanging(self, event):
- if event.GetDirection() and self.ellipse not in self.parent.ellipsoids:
+ if event.GetDirection() \
+ and self.ellipse not in self.parent.ellipsoids \
+ and self.ellipse not in self.parent.planetary_ellipsoids:
event.Veto()
self.proj4params = ''
@@ -1076,11 +1072,14 @@
self.parent.datumpage.datumparams = ''
# self.GetNext().SetPrev(self) (???)
+ #FIXME: index number doesn't translate when you've given a valid name from the other list
def OnText(self, event):
"""!Ellipspoid code changed"""
self.ellipse = event.GetString()
nextButton = wx.FindWindowById(wx.ID_FORWARD)
- if len(self.ellipse) == 0 or self.ellipse not in self.parent.ellipsoids:
+ if len(self.ellipse) == 0 or \
+ (self.ellipse not in self.parent.ellipsoids and \
+ self.ellipse not in self.parent.planetary_ellipsoids):
nextButton.Enable(False)
self.ellipsedesc = ''
self.ellipseparams = ''
@@ -1089,13 +1088,20 @@
self.ellipsedesc = self.parent.ellipsoids[self.ellipse][0]
self.ellipseparams = self.parent.ellipsoids[self.ellipse][1]
nextButton.Enable(True)
+ elif self.ellipse in self.parent.planetary_ellipsoids:
+ self.ellipsedesc = self.parent.planetary_ellipsoids[self.ellipse][0]
+ self.ellipseparams = self.parent.planetary_ellipsoids[self.ellipse][1]
+ nextButton.Enable(True)
def OnSearch(self, event):
"""!Search ellipsoid by desc"""
try:
self.ellipse, self.ellipsedesc = \
self.ellipselist.Search(index=[0,1], pattern=event.GetString())
- self.ellipseparams = self.parent.ellipsoids[self.ellipse][1]
+ if self.scope is 'earth':
+ self.ellipseparams = self.parent.ellipsoids[self.ellipse][1]
+ else:
except:
self.ellipse = self.ellipsedesc = self.ellipseparams = ''
@@ -1110,21 +1116,23 @@
self.tellipse.SetValue(self.ellipse)
event.Skip()
- """ FIXME: how best to swap them out?
def SetVal(self, event):
- #Choose table to use
+ """!Choose table to use"""
+ self.ellipselist.DeleteAllItems()
+ data = []
if event.GetId() == self.radio1.GetId():
- data = []
for key in self.parent.ellipsoids.keys():
data.append([key, self.parent.ellipsoids[key][0]])
elif event.GetId() == self.radio2.GetId():
self.scope = 'planetary'
- data = []
for key in self.parent.planetary_ellipsoids.keys():
data.append([key, self.parent.planetary_ellipsoids[key][0]])
+ self.ellipselist.Populate(data = data, update = True)
class GeoreferencedFilePage(TitledPage):
"""!Wizard page for selecting georeferenced file to use
for setting coordinate system parameters"""
@@ -1938,7 +1946,7 @@
paramslist = params.split()
self.ellipsoids[ellipse] = (desc, paramslist)
f.close()
# read Planetary ellipsiod definitions
f = open(os.path.join(globalvar.ETCDIR, "proj", "ellipse.table.solar.system"), "r")
self.planetary_ellipsoids = {}
@@ -1954,7 +1962,7 @@
self.planetary_ellipsoids[ellipse] = (desc, paramslist)
f.close()
# read projection parameter description and parsing table
f = open(os.path.join(globalvar.ETCDIR, "proj", "desc.table"), "r")
self.paramdesc = {}
