[GRASS-SVN] r51625 - in grass/trunk/raster3d: . r3.out.netcdf
r3.out.netcdf/test_suite
svn_grass at osgeo.org
Tue May 15 09:47:44 EDT 2012
Author: huhabla
Date: 2012-05-15 06:47:44 -0700 (Tue, 15 May 2012)
New Revision: 51625
Added:
grass/trunk/raster3d/r3.out.netcdf/
grass/trunk/raster3d/r3.out.netcdf/Makefile
grass/trunk/raster3d/r3.out.netcdf/main.c
grass/trunk/raster3d/r3.out.netcdf/r3.out.netcdf.html
grass/trunk/raster3d/r3.out.netcdf/test_suite/
grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh
Incomplete but working version of a netcdf 3d raster map export module.
This module exports spatial voxel cubes and space time voxel cubes.
Added: grass/trunk/raster3d/r3.out.netcdf/Makefile
--- grass/trunk/raster3d/r3.out.netcdf/Makefile (rev 0)
+++ grass/trunk/raster3d/r3.out.netcdf/Makefile 2012-05-15 13:47:44 UTC (rev 51625)
@@ -0,0 +1,14 @@
+MODULE_TOPDIR = ../..
+PGM=r3.out.netcdf
+LIBES = $(RASTER3DLIB) $(GISLIB) $(GPROJLIB)
+DEPENDENCIES = $(RASTER3DDEP) $(GISDEP) $(GPROJDEP)
+EXTRA_INC = $(PROJINC)
+EXTRA_LIBS = -lnetcdf
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass/trunk/raster3d/r3.out.netcdf/main.c
--- grass/trunk/raster3d/r3.out.netcdf/main.c (rev 0)
+++ grass/trunk/raster3d/r3.out.netcdf/main.c 2012-05-15 13:47:44 UTC (rev 51625)
@@ -0,0 +1,360 @@
+ * MODULE: r3.out.netcdf
+ * AUTHOR(S): Soeren Gebbert
+ * PURPOSE: Export a 3D raster map as netcdf file
+ * COPYRIGHT: (C) 2012 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+ * TODO: Add time zone support to time variable
+ * TODO: Implement support for coordinate reference system defined here:
+ * http://cf-pcmdi.llnl.gov/documents/cf-conventions/1.6/cf-conventions.html#coordinate-system
+ * https://cf-pcmdi.llnl.gov/trac/wiki/Cf2CrsWkt
+ * http://trac.osgeo.org/gdal/wiki/NetCDF_ProjectionTestingStatus
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <netcdf.h>
+#include <grass/gis.h>
+#include <grass/raster3d.h>
+#include <grass/glocale.h>
+#include <grass/gprojects.h>
+#define NDIMS 3
+#define LONG_NAME "long_name"
+#define STANDARD_NAME "standard_name"
+#define LAT_NAME "latitude"
+#define LAT_LONG_NAME "Latitude values"
+#define LON_NAME "longitude"
+#define LON_LONG_NAME "Longitude values"
+#define TIME_NAME "time"
+#define X_NAME "x"
+#define X_LONG_NAME "x-axsis coordinates"
+#define Y_NAME "y"
+#define Y_LONG_NAME "y-axsis coordinates"
+#define Z_NAME "z"
+#define Z_LONG_NAME "z-axsis coordinates"
+#define UNITS "units"
+#define DEGREES_EAST "degrees_east"
+#define DEGREES_NORTH "degrees_north"
+#define ERR(e) {fatalError(nc_strerror(e));}
+/* structs */
+typedef struct {
+ struct Option *input, *output;
+ struct Flag *mask;
+} paramType;
+RASTER3D_Map *map;
+paramType param;
+/* Simple error handling routine, will eventually replace this with
+ * RASTER3D_fatalError.
+static void fatalError(const char *errorMsg)
+ if (map != NULL) {
+ /* should unopen map here! */
+ if (!Rast3d_close(map))
+ fatalError(_("Unable to close 3D raster map"));
+ G_fatal_error("%s", errorMsg);
+/* Convenient way to set up the arguments we are expecting
+static void setParams()
+ param.input = G_define_standard_option(G_OPT_R3_INPUTS);
+ param.output = G_define_standard_option(G_OPT_F_OUTPUT);
+ param.output->key = "output";
+ param.output->description = _("Name for netcdf output file");
+ param.mask = G_define_flag();
+ param.mask->key = 'm';
+ param.mask->description = _("Use 3D raster mask (if exists) with input map");
+static void write_netcdf_header(int ncid, RASTER3D_Region *region, int *varid)
+ int retval, typeIntern, time;
+ size_t i;
+ int is_time = 0;
+ float c;
+ int lat_dimid = 0, lon_dimid = 0, time_dimid = 0;
+ int lat_varid = 0, lon_varid = 0, time_varid = 0;
+ struct Key_Value *pkv, *ukv;
+ int dimids[NDIMS];
+ struct Cell_head window;
+ G_get_window(&window);
+ typeIntern = Rast3d_tile_type_map(map);
+ if (window.proj == PROJECTION_LL) {
+ if ((retval = nc_def_dim(ncid, LON_NAME, region->cols, &lon_dimid))) ERR(retval);
+ if ((retval = nc_def_dim(ncid, LAT_NAME, region->rows, &lat_dimid))) ERR(retval);
+ if ((retval = nc_def_var(ncid, LON_NAME, NC_FLOAT, 1, &lon_dimid, &lon_varid))) ERR(retval);
+ if ((retval = nc_def_var(ncid, LAT_NAME, NC_FLOAT, 1, &lat_dimid, &lat_varid))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lon_varid, UNITS, strlen(DEGREES_EAST), DEGREES_EAST))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lon_varid, LONG_NAME, strlen(LON_LONG_NAME), LON_LONG_NAME))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lon_varid, STANDARD_NAME, strlen(LON_NAME), LON_NAME))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lat_varid, UNITS, strlen(DEGREES_NORTH), DEGREES_NORTH))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lat_varid, LONG_NAME, strlen(LAT_LONG_NAME), LAT_LONG_NAME))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lat_varid, STANDARD_NAME, strlen(LAT_NAME), LAT_NAME))) ERR(retval);
+ } else {
+ if ((retval = nc_def_dim(ncid, X_NAME, region->cols, &lon_dimid))) ERR(retval);
+ if ((retval = nc_def_dim(ncid, Y_NAME, region->rows, &lat_dimid))) ERR(retval);
+ if ((retval = nc_def_var(ncid, X_NAME, NC_FLOAT, 1, &lon_dimid, &lon_varid))) ERR(retval);
+ if ((retval = nc_def_var(ncid, Y_NAME, NC_FLOAT, 1, &lat_dimid, &lat_varid))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lon_varid, UNITS, strlen("meter"), "meter"))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lon_varid, LONG_NAME, strlen(X_LONG_NAME), X_LONG_NAME))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lon_varid, STANDARD_NAME, strlen(X_NAME), X_NAME))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lat_varid, UNITS, strlen("meter"), "meter"))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lat_varid, LONG_NAME, strlen(Y_LONG_NAME), Y_LONG_NAME))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lat_varid, STANDARD_NAME, strlen(Y_NAME), Y_NAME))) ERR(retval);
+ is_time = 0;
+ if(Rast3d_get_vertical_unit(map) && G_strncasecmp(Rast3d_get_vertical_unit(map), "units", 5) != 0) {
+ /* Time handling */
+ if(G_is_units_type_temporal(Rast3d_get_vertical_unit2(map))) {
+ is_time = 1;
+ char long_name[1024];
+ char time_unit[1024];
+ G_snprintf(long_name, 1024, "Time in %s", Rast3d_get_vertical_unit(map));
+ if ((retval = nc_def_dim(ncid, TIME_NAME, region->depths, &time_dimid))) ERR(retval);
+ if ((retval = nc_def_var(ncid, TIME_NAME, NC_INT, 1, &time_dimid, &time_varid))) ERR(retval);
+ /* Temporal unit */
+ if(G_has_raster3d_timestamp(map->fileName, map->mapset)) {
+ struct TimeStamp ts;
+ G_read_raster3d_timestamp(map->fileName, map->mapset, &ts);
+ G_snprintf(time_unit, 1024, "%s since %d-%02d-%02d %02d:%02d:%02.0f",
+ Rast3d_get_vertical_unit(map), ts.dt[0].year, ts.dt[0].month, ts.dt[0].day,
+ ts.dt[0].hour,ts.dt[0].minute,ts.dt[0].second);
+ } else {
+ G_snprintf(time_unit, 1024, "%s since %s", Rast3d_get_vertical_unit(map), "1900-01-01 00:00:00");
+ if ((retval = nc_put_att_text(ncid, time_varid, UNITS, strlen(time_unit), time_unit))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, time_varid, LONG_NAME, strlen(long_name), long_name))) ERR(retval)
+ if ((retval = nc_put_att_text(ncid, time_varid, "calendar", strlen("gregorian"), "gregorian"))) ERR(retval);
+ } else {
+ if ((retval = nc_def_dim(ncid, Z_NAME, region->depths, &time_dimid))) ERR(retval);;
+ if ((retval = nc_def_var(ncid, Z_NAME, NC_FLOAT, 1, &time_dimid, &time_varid))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, time_varid, UNITS, strlen(Rast3d_get_vertical_unit(map)), Rast3d_get_vertical_unit(map)))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, time_varid, LONG_NAME, strlen(Z_LONG_NAME), Z_LONG_NAME))) ERR(retval);
+ }else {
+ if ((retval = nc_put_att_text(ncid, time_varid, UNITS, strlen("meter"), "meter"))) ERR(retval);
+ /* z - axsis orientation */
+ if ((retval = nc_put_att_text(ncid, time_varid, "positive", strlen("up"), "up"))) ERR(retval);
+ dimids[0] = time_dimid;
+ dimids[1] = lat_dimid;
+ dimids[2] = lon_dimid;
+ if(typeIntern == FCELL_TYPE) {
+ if ((retval = nc_def_var(ncid, param.input->answer, NC_FLOAT, NDIMS, dimids, varid))) ERR(retval);
+ } else {
+ if ((retval = nc_def_var(ncid, param.input->answer, NC_DOUBLE, NDIMS, dimids, varid))) ERR(retval);
+ /* End define mode. */
+ if ((retval = nc_enddef(ncid))) ERR(retval);
+ /* Build coordinates, we need to use the cell center in case of spatial dimensions */
+ for(i = 0; i < region->cols; i++) {
+ c = region->west + i*region->ew_res + 0.5*region->ew_res;
+ nc_put_var1_float(ncid, lon_varid, &i, &c);
+ for(i = 0; i < region->rows; i++) {
+ c = region->south + i*region->ns_res + 0.5*region->ns_res;
+ nc_put_var1_float(ncid, lat_varid, &i, &c);
+ for(i = 0; i < region->depths; i++) {
+ if(is_time)
+ c = region->bottom + i*region->tb_res;
+ else
+ c = region->bottom + i*region->tb_res + 0.5*region->tb_res;
+ time = (int)c;
+ if(is_time)
+ nc_put_var1_int(ncid, time_varid, &i, &time);
+ else
+ nc_put_var1_float(ncid, time_varid, &i, &c);
+ /* Lets try to specify the projection information */
+ pkv = G_get_projinfo();
+ ukv = G_get_projunits();
+ if(pkv && ukv) {
+ for(i = 0; i < pkv->nitems; i++)
+ fprintf(stderr, "%s : %s\n", pkv->key[i], pkv->value[i]);
+ for(i = 0; i < ukv->nitems; i++)
+ fprintf(stderr, "%s : %s\n", ukv->key[i], ukv->value[i]);
+ if(window.proj != PROJECTION_XY)
+ ; // Do projection
+ if(pkv)
+ G_free_key_value(pkv);
+ if(ukv)
+ G_free_key_value(ukv);
+static void write_netcdf_data(int ncid, RASTER3D_Region *region, int varid)
+ DCELL dvalue;
+ FCELL fvalue;
+ int x, y, z;
+ size_t coords[3];
+ int rows, cols, depths, typeIntern;
+ rows = region->rows;
+ cols = region->cols;
+ depths = region->depths;
+ for (z = 0; z < depths; z++) {
+ G_percent(z, depths, 1);
+ for (y = rows - 1; y >= 0; y--) { /* rows count from south to north */
+ for (x = 0; x < cols; x++) {
+ coords[0] = z;
+ coords[1] = y;
+ coords[2] = x;
+ if (typeIntern == FCELL_TYPE) {
+ Rast3d_get_value(map, x, y, z, &fvalue, FCELL_TYPE);
+ if (!Rast3d_is_null_value_num(&fvalue, FCELL_TYPE)) {
+ nc_put_var1_float(ncid, varid, coords, &fvalue);
+ } else {
+ Rast3d_get_value(map, x, y, z, &dvalue, DCELL_TYPE);
+ if (!Rast3d_is_null_value_num(&dvalue, DCELL_TYPE)) {
+ nc_put_var1_double(ncid, varid, coords, &dvalue);
+ G_percent(1, 1, 1);
+ G_percent_reset();
+int main(int argc, char *argv[])
+ RASTER3D_Region region;
+ int ncid;
+ int retval;
+ int varid;
+ int changemask = 0;
+ struct GModule *module;
+ /* Initialize GRASS */
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ G_add_keyword(_("raster3d"));
+ G_add_keyword(_("netcdf"));
+ G_add_keyword(_("export"));
+ module->description =
+ _("Export a 3D raster map as netcdf file.");
+ /* Get parameters from user */
+ setParams();
+ /* Have GRASS get inputs */
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ if (NULL == G_find_raster3d(param.input->answer, ""))
+ Rast3d_fatal_error(_("3D raster map <%s> not found"), param.input->answer);
+ /* Initiate the default settings */
+ Rast3d_init_defaults();
+ /* Figure out the current region settings */
+ Rast3d_get_window(®ion);
+ /* Open the map and use XY cache mode */
+ map = Rast3d_open_cell_old(param.input->answer, G_find_raster3d(param.input->answer, ""), ®ion,
+ RASTER3D_TILE_SAME_AS_FILE, RASTER3D_USE_CACHE_DEFAULT);
+ if (map == NULL)
+ G_fatal_error(_("Error opening 3d raster map <%s>"), param.input->answer);
+ /* Create netcdf file */
+ if ((retval = nc_create(param.output->answer, NC_CLOBBER, &ncid))) ERR(retval);
+ write_netcdf_header(ncid, ®ion, &varid);
+ /*if requested set the Mask on */
+ if (param.mask->answer) {
+ if (Rast3d_mask_file_exists()) {
+ changemask = 0;
+ if (Rast3d_mask_is_off(map)) {
+ Rast3d_mask_on(map);
+ changemask = 1;
+ write_netcdf_data(ncid, ®ion, varid);
+ /*We set the Mask off, if it was off bevor */
+ if (Rast3d_mask_is_on(map) && changemask)
+ Rast3d_mask_off(map);
+ /* Close files and exit */
+ /* Close the netcdf file */
+ if ((retval = nc_close(ncid))) ERR(retval);
+ return 0;
Added: grass/trunk/raster3d/r3.out.netcdf/r3.out.netcdf.html
--- grass/trunk/raster3d/r3.out.netcdf/r3.out.netcdf.html (rev 0)
+++ grass/trunk/raster3d/r3.out.netcdf/r3.out.netcdf.html 2012-05-15 13:47:44 UTC (rev 51625)
@@ -0,0 +1,15 @@
+<h2>DESCRIPTION</h2>
+EXport a 3D raster map as netcdf file.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r3.out.ascii.html">r3.in.ascii</a>,
+<a href="g.region.html">g.region</a>
+</em>
+<h2>AUTHORS</h2>
+Sören Gebbert
+<p><i>Last changed: $Date: 2011-11-08 22:24:20 +0100 (Di, 08 Nov 2011) $</i>
Added: grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh
--- grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh (rev 0)
+++ grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh 2012-05-15 13:47:44 UTC (rev 51625)
@@ -0,0 +1,24 @@
+# Tests for r3.out.netcdf and r3.in.netcdf
+# This script tests the export of voxel data using r3.out.netcdf
+# as well as the import of the generated data with r3.in.netcdf
+# We set up a specific region in the
+# @preprocess step of this test. We generate
+# voxel data with r3.mapcalc. The region setting
+# should work for UTM and LL test locations
+g.region s=-40 n=40 w=-20 e=100 b=-25 t=25 res=10 res3=10 -p3
+# We create several (float, double, null value) voxel map
+# with value = col + row + depth.
+r3.mapcalc --o expr="volume_float = float(col() + row() + depth())"
+r3.mapcalc --o expr="volume_double = double(col() + row() + depth())"
+r3.mapcalc --o expr="volume_time_double = double(col() + row() + depth())"
+r3.timestamp map=volume_time_double date='1 Jan 2001/5 Jan 2001'
+r3.support map=volume_time_double vunit="days"
+# @test
+r3.out.netcdf --o input=volume_float output=test_float.nc
+r3.out.netcdf --o input=volume_double output=test_double.nc
+r3.out.netcdf --o input=volume_time_double output=test_time_double.nc
+ncdump -h test_float.nc
+ncdump -h test_double.nc
+ncdump -h test_time_double.nc
\ No newline at end of file
Property changes on: grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh
___________________________________________________________________
Added: svn:executable
