[GRASS-SVN] r51630 - grass/trunk/raster3d/r3.out.netcdf
svn_grass at osgeo.org
Tue May 15 18:56:21 EDT 2012
Author: huhabla
Date: 2012-05-15 15:56:21 -0700 (Tue, 15 May 2012)
New Revision: 51630
grass/trunk/raster3d/r3.out.netcdf/main.c
Added spatial coordinates reference system metadata to netcdf files
to fulfill CF-1.6 and gdal needs.
Modified: grass/trunk/raster3d/r3.out.netcdf/main.c
--- grass/trunk/raster3d/r3.out.netcdf/main.c 2012-05-15 20:43:10 UTC (rev 51629)
+++ grass/trunk/raster3d/r3.out.netcdf/main.c 2012-05-15 22:56:21 UTC (rev 51630)
@@ -38,14 +38,18 @@
#define LON_LONG_NAME "Longitude values"
#define TIME_NAME "time"
#define X_NAME "x"
-#define X_LONG_NAME "x-axsis coordinates"
+#define X_STANDARD_NAME "projection_x_coordinate"
+#define X_LONG_NAME "x coordinate of projection"
#define Y_NAME "y"
-#define Y_LONG_NAME "y-axsis coordinates"
+#define Y_LONG_NAME "y coordinate of projection"
+#define Y_STANDARD_NAME "projection_y_coordinate"
#define Z_NAME "z"
-#define Z_LONG_NAME "z-axsis coordinates"
+#define Z_LONG_NAME "z coordinate of projection"
#define UNITS "units"
#define DEGREES_EAST "degrees_east"
#define DEGREES_NORTH "degrees_north"
+#define HISTORY_TEXT "GRASS GIS 7 NetCDF export of r3.out.netcdf"
+#define CF_SUPPORT "CF-1.5"
#define ERR(e) {fatalError(nc_strerror(e));}
@@ -98,12 +102,55 @@
float c;
int lat_dimid = 0, lon_dimid = 0, time_dimid = 0;
int lat_varid = 0, lon_varid = 0, time_varid = 0;
- struct Key_Value *pkv, *ukv;
int dimids[NDIMS];
struct Cell_head window;
+ /* global attributes */
+ if ((retval = nc_put_att_text(ncid, NC_GLOBAL, "Conventions", strlen(CF_SUPPORT), CF_SUPPORT))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, NC_GLOBAL, "history", strlen(HISTORY_TEXT), HISTORY_TEXT))) ERR(retval);
G_get_window(&window);
+ /* Projection parameter */
+ if(window.proj != PROJECTION_XY) {
+ struct Key_Value *pkv, *ukv;
+ struct pj_info pjinfo;
+ char *proj4, *proj4mod;
+ const char *unfact;
+ int crs_dimid = 0, crs_varid;
+ if ((retval = nc_def_var(ncid, "crs", NC_CHAR, 0, &crs_dimid, &crs_varid))) ERR(retval);
+ pkv = G_get_projinfo();
+ ukv = G_get_projunits();
+ pj_get_kv(&pjinfo, pkv, ukv);
+ proj4 = pj_get_def(pjinfo.pj, 0);
+ pj_free(pjinfo.pj);
+#ifdef HAVE_OGR
+ /* We support the CF suggestion crs_wkt and the gdal spatil_ref attribute */
+ if ((retval = nc_put_att_text(ncid, crs_varid, "crs_wkt", strlen(GPJ_grass_to_wkt(pkv, ukv, 0, 0)), GPJ_grass_to_wkt(pkv, ukv, 0, 0)))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, crs_varid, "spatial_ref", strlen(GPJ_grass_to_wkt(pkv, ukv, 0, 0)), GPJ_grass_to_wkt(pkv, ukv, 0, 0)))) ERR(retval);
+#endif
+ /* Code from g.proj:
+ * GRASS-style PROJ.4 strings don't include a unit factor as this is
+ * handled separately in GRASS - must include it here though */
+ unfact = G_find_key_value("meters", ukv);
+ if (unfact != NULL && (strcmp(pjinfo.proj, "ll") != 0))
+ G_asprintf(&proj4mod, "%s +to_meter=%s", proj4, unfact);
+ else
+ proj4mod = G_store(proj4);
+ pj_dalloc(proj4);
+ if ((retval = nc_put_att_text(ncid, crs_varid, "crs_proj4", strlen(proj4mod), proj4mod))) ERR(retval);
+ if(pkv)
+ G_free_key_value(pkv);
+ if(ukv)
+ G_free_key_value(ukv);
typeIntern = Rast3d_tile_type_map(map);
if (window.proj == PROJECTION_LL) {
@@ -128,10 +175,10 @@
if ((retval = nc_put_att_text(ncid, lon_varid, UNITS, strlen("meter"), "meter"))) ERR(retval);
if ((retval = nc_put_att_text(ncid, lon_varid, LONG_NAME, strlen(X_LONG_NAME), X_LONG_NAME))) ERR(retval);
- if ((retval = nc_put_att_text(ncid, lon_varid, STANDARD_NAME, strlen(X_NAME), X_NAME))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lon_varid, STANDARD_NAME, strlen(X_STANDARD_NAME), X_STANDARD_NAME))) ERR(retval);
if ((retval = nc_put_att_text(ncid, lat_varid, UNITS, strlen("meter"), "meter"))) ERR(retval);
if ((retval = nc_put_att_text(ncid, lat_varid, LONG_NAME, strlen(Y_LONG_NAME), Y_LONG_NAME))) ERR(retval);
- if ((retval = nc_put_att_text(ncid, lat_varid, STANDARD_NAME, strlen(Y_NAME), Y_NAME))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lat_varid, STANDARD_NAME, strlen(Y_STANDARD_NAME), Y_STANDARD_NAME))) ERR(retval);
is_time = 0;
@@ -175,9 +222,18 @@
if ((retval = nc_put_att_text(ncid, time_varid, UNITS, strlen("meter"), "meter"))) ERR(retval);
if ((retval = nc_put_att_text(ncid, time_varid, LONG_NAME, strlen(Z_LONG_NAME), Z_LONG_NAME))) ERR(retval);
- /* z - axsis orientation */
+ /* z - axis orientation */
if ((retval = nc_put_att_text(ncid, time_varid, "positive", strlen("up"), "up"))) ERR(retval);
+ /* Axis identifier attributes */
+ if ((retval = nc_put_att_text(ncid, lon_varid, "axis", 1, "X"))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, lat_varid, "axis", 1, "Y"))) ERR(retval);
+ if(is_time) {
+ if ((retval = nc_put_att_text(ncid, time_varid, "axis", 1, "T"))) ERR(retval);
+ } else {
+ if ((retval = nc_put_att_text(ncid, time_varid, "axis", 1, "Z"))) ERR(retval);
dimids[0] = time_dimid;
dimids[1] = lat_dimid;
dimids[2] = lon_dimid;
@@ -187,11 +243,17 @@
} else {
if ((retval = nc_def_var(ncid, param.input->answer, NC_DOUBLE, NDIMS, dimids, varid))) ERR(retval);
+ if ((retval = nc_put_att_text(ncid, *varid, "grid_mapping", strlen("crs"), "crs"))) ERR(retval);
/* End define mode. */
if ((retval = nc_enddef(ncid))) ERR(retval);
- /* Build coordinates, we need to use the cell center in case of spatial dimensions */
+ * Build coordinates, we need to use the cell center in case of spatial dimensions
for(i = 0; i < region->cols; i++) {
c = region->west + i*region->ew_res + 0.5*region->ew_res;
nc_put_var1_float(ncid, lon_varid, &i, &c);
@@ -203,35 +265,15 @@
for(i = 0; i < region->depths; i++) {
- if(is_time)
+ if(is_time) {
c = region->bottom + i*region->tb_res;
- else
+ time = (int)c;
+ nc_put_var1_int(ncid, time_varid, &i, &time);
+ } else {
c = region->bottom + i*region->tb_res + 0.5*region->tb_res;
- time = (int)c;
- if(is_time)
- nc_put_var1_int(ncid, time_varid, &i, &time);
- else
nc_put_var1_float(ncid, time_varid, &i, &c);
- /* Lets try to specify the projection information */
- pkv = G_get_projinfo();
- ukv = G_get_projunits();
- if(pkv && ukv) {
- for(i = 0; i < pkv->nitems; i++)
- fprintf(stderr, "%s : %s\n", pkv->key[i], pkv->value[i]);
- for(i = 0; i < ukv->nitems; i++)
- fprintf(stderr, "%s : %s\n", ukv->key[i], ukv->value[i]);
- if(window.proj != PROJECTION_XY)
- ; // Do projection
- if(pkv)
- G_free_key_value(pkv);
- if(ukv)
- G_free_key_value(ukv);
