[GRASS-SVN] r51632 - grass-addons/grass7/raster/r.gdd
Wed May 16 11:48:08 EDT 2012
Author: mmetz
Date: 2012-05-16 08:48:08 -0700 (Wed, 16 May 2012)
New Revision: 51632
Added:
   grass-addons/grass7/raster/r.gdd/r.gdd.html
Removed:
   grass-addons/grass7/raster/r.gdd/r.series.html
   grass-addons/grass7/raster/r.gdd/test_suite/
   grass-addons/grass7/raster/r.gdd/Makefile
   grass-addons/grass7/raster/r.gdd/main.c
new r.gdd
Modified: grass-addons/grass7/raster/r.gdd/Makefile
--- grass-addons/grass7/raster/r.gdd/Makefile	2012-05-16 15:45:46 UTC (rev 51631)
+++ grass-addons/grass7/raster/r.gdd/Makefile	2012-05-16 15:48:08 UTC (rev 51632)
@@ -1,10 +1,13 @@
 MODULE_TOPDIR = ../..
-PGM = r.series
+PGM = r.gdd
-LIBES = $(STATSLIB) $(RASTERLIB) $(GISLIB)
-DEPENDENCIES = $(STATSDEP) $(RASTERDEP) $(GISDEP)
+LIBES = $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+EXTRA_LIBS = $(OMPLIB)
+EXTRA_CFLAGS = $(OMPCFLAGS)
 include $(MODULE_TOPDIR)/include/Make/Module.make
 default: cmd
Modified: grass-addons/grass7/raster/r.gdd/main.c
--- grass-addons/grass7/raster/r.gdd/main.c	2012-05-16 15:45:46 UTC (rev 51631)
+++ grass-addons/grass7/raster/r.gdd/main.c	2012-05-16 15:48:08 UTC (rev 51632)
@@ -1,12 +1,11 @@
- * MODULE:       r.series
- * AUTHOR(S):    Glynn Clements <glynn gclements.plus.com> (original contributor)
- *               Hamish Bowman <hamish_b yahoo.com>, Jachym Cepicky <jachym les-ejk.cz>,
- *               Martin Wegmann <wegmann biozentrum.uni-wuerzburg.de>
- * PURPOSE:
- * COPYRIGHT:    (C) 2002-2008 by the GRASS Development Team
+ * MODULE:       r.gdd
+ * AUTHOR(S):    Markus Metz
+ *               based on r.series
+ * PURPOSE:      Calculate Growing Degree Days (GDDs)
+ * COPYRIGHT:    (C) 2012 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -22,235 +21,43 @@
 #include <grass/gis.h>
 #include <grass/raster.h>
 #include <grass/glocale.h>
-#include <grass/stats.h>
-struct menu
-    stat_func *method;		/* routine to compute new value */
-    stat_func_w *method_w;	/* routine to compute new value (weighted) */
-    int is_int;			/* result is an integer */
-    char *name;			/* method name */
-    char *text;			/* menu display - full description */
-} menu[] = {
-    {c_ave,    w_ave,    0, "average",    "average value"},
-    {c_count,  NULL,     1, "count",      "count of non-NULL cells"},
-    {c_median, w_median, 0, "median",     "median value"},
-    {c_mode,   w_mode,   0, "mode",       "most frequently occuring value"},
-    {c_min,    NULL,     0, "minimum",    "lowest value"},
-    {c_minx,   NULL,     1, "min_raster", "raster with lowest value"},
-    {c_max,    NULL,     0, "maximum",    "highest value"},
-    {c_maxx,   NULL,     1, "max_raster", "raster with highest value"},
-    {c_stddev, w_stddev, 0, "stddev",     "standard deviation"},
-    {c_range,  NULL,     0, "range",      "range of values"},
-    {c_sum,    w_sum,    0, "sum",        "sum of values"},
-    {c_var,    w_var,    0, "variance",   "statistical variance"},
-    {c_divr,   NULL,     1, "diversity",  "number of different values"},
-    {c_reg_m,  NULL,     0, "slope",      "linear regression slope"},
-    {c_reg_c,  NULL,     0, "offset",     "linear regression offset"},
-    {c_reg_r2, NULL,     0, "detcoeff",   "linear regression coefficient of determination"},
-    {c_quart1, w_quart1, 0, "quart1",     "first quartile"},
-    {c_quart3, w_quart3, 0, "quart3",     "third quartile"},
-    {c_perc90, w_perc90, 0, "perc90",     "ninetieth percentile"},
-    {c_quant,  w_quant,  0, "quantile",   "arbitrary quantile"},
-    {c_skew,   w_skew,   0, "skewness",   "skewness"},
-    {c_kurt,   w_kurt,   0, "kurtosis",   "kurtosis"},
-    {NULL,     NULL,     0, NULL,         NULL}
-static double f_box(double x)
-    return (x > 1) ? 0
-	: 1;
-static double f_bartlett(double x)
-	: 1 - x;
-static double f_hermite(double x)
-	: (2 * x - 3) * x * x + 1;
-static double f_gauss(double x)
-    return exp(-2 * x * x) * sqrt(2 / M_PI);
-static double f_normal(double x)
-    return f_gauss(x / 2) / 2;
-static double f_sinc(double x)
-    return (x == 0) ? 1 : sin(M_PI * x) / (M_PI * x);
-static double lanczos(double x, int a)
-    return (x > a) ? 0
-	: f_sinc(x) * f_sinc(x / a);
-static double f_lanczos1(double x)
-    return lanczos(x, 1);
-static double f_lanczos2(double x)
-    return lanczos(x, 2);
-static double f_lanczos3(double x)
-    return lanczos(x, 3);
-static double f_hann(double x)
-    return cos(M_PI * x) / 2 + 0.5;
-static double f_hamming(double x)
-    return 0.46 * cos(M_PI * x) + 0.54;
-static double f_blackman(double x)
-    return cos(M_PI * x) / 2 + 0.08 * cos(2 * M_PI * x) + 0.42;
-struct window_type {
-    const char *name;
-    double (*func)(double);
-    int radius;
-} w_menu[] = {
-    {"box",       f_box,       1},
-    {"bartlett",  f_bartlett,  1},
-    {"gauss",     f_gauss,     4},
-    {"normal",    f_normal,    8},
-    {"hermite",   f_hermite,   1},
-    {"sinc",      f_sinc,      0},
-    {"lanczos1",  f_lanczos1,  1},
-    {"lanczos2",  f_lanczos2,  2},
-    {"lanczos3",  f_lanczos3,  3},
-    {"hann",      f_hann,      0},
-    {"hamming",   f_hamming,   0},
-    {"blackman",  f_blackman,  0},
-    {NULL},
-static char *build_window_list(void)
-    char *buf = G_malloc(1024);
-    char *p = buf;
-    int i;
-    for (i = 0; w_menu[i].name; i++) {
-	const char *q;
-	if (i)
-	    *p++ = ',';
-	for (q = w_menu[i].name; *q; p++, q++)
-	    *p = *q;
-    *p = '\0';
-    return buf;
-static int find_window(const char *name)
-    int i;
-	if (strcmp(w_menu[i].name, name) == 0)
-	    return i;
-    G_fatal_error(_("Unknown window <%s>"), name);
-    return -1;
 struct input
     const char *name;
     int fd;
-    DCELL *buf;
+    FCELL *buf;
 struct output
     const char *name;
     int fd;
-    DCELL *buf;
-    stat_func *method_fn;
-    stat_func_w *method_fn_w;
-    double quantile;
+    FCELL *buf;
-static char *build_method_list(void)
-    char *p = buf;
-    int i;
-    for (i = 0; menu[i].name; i++) {
-	char *q;
-	if (i)
-	    *p++ = ',';
-	for (q = menu[i].name; *q; p++, q++)
-	    *p = *q;
-    *p = '\0';
-    return buf;
-static int find_method(const char *method_name)
-    int i;
-	if (strcmp(menu[i].name, method_name) == 0)
-	    return i;
-    G_fatal_error(_("Unknown method <%s>"), method_name);
-    return -1;
 int main(int argc, char *argv[])
     struct GModule *module;
     struct
-	struct Option *input, *file, *output, *method, *quantile, *range, *weight;
+	struct Option *input, *gdd, *file, *output, *range,
+	              *scale, *shift, *baseline, *cutoff;
     } parm;
     struct
-	struct Flag *nulls, *lazy, *outlier;
+	struct Flag *nulls, *lazy, *avg;
     } flag;
     int i;
-    int num_inputs;
+    int num_inputs, max_inputs, gdd_in;
     struct input *inputs = NULL;
-    int num_outputs;
-    struct output *outputs = NULL;
+    struct output *out = NULL;
     struct History history;
-    DCELL *values = NULL, *values_tmp = NULL;
-    DCELL (*values_w)[2], (*values_tmp_w)[2];	/* list of neighborhood values and weights */
-    double *weights;
+    struct Colors colors;
     int nrows, ncols;
     int row, col;
-    double lo, hi;
+    double lo, hi, tscale, tshift, baseline, cutoff;
+    FCELL fnull;
     G_gisinit(argv[0]);
@@ -265,44 +72,57 @@
     parm.input = G_define_standard_option(G_OPT_R_INPUTS);
     parm.input->required = NO;
+    parm.gdd = G_define_standard_option(G_OPT_R_INPUT);
+    parm.gdd->key = "gdd";
+    parm.gdd->description = _("Existing GDD map to be added to output");
+    parm.gdd->required = NO;
     parm.file = G_define_standard_option(G_OPT_F_INPUT);
     parm.file->key = "file";
     parm.file->description = _("Input file with raster map names, one per line");
     parm.file->required = NO;
     parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
-    parm.output->multiple = YES;
+    parm.output->multiple = NO;
-    parm.method = G_define_option();
-    parm.method->key = "method";
-    parm.method->type = TYPE_STRING;
-    parm.method->required = YES;
-    parm.method->options = build_method_list();
-    parm.method->description = _("Aggregate operation");
-    parm.method->multiple = YES;
+    parm.scale = G_define_option();
+    parm.scale->key = "scale";
+    parm.scale->type = TYPE_DOUBLE;
+    parm.scale->answer = "1.0";
+    parm.scale->required = NO;
+    parm.scale->description = _("Scale factor for input");
-    parm.weight = G_define_option();
-    parm.weight->key = "window";
-    parm.weight->type = TYPE_STRING;
-    parm.weight->required = NO;
-    parm.weight->multiple = NO;
-    parm.weight->description = _("weighing window");
-    parm.weight->options = build_window_list();
+    parm.shift = G_define_option();
+    parm.shift->key = "shift";
+    parm.shift->type = TYPE_DOUBLE;
+    parm.shift->answer = "0.0";
+    parm.shift->required = NO;
+    parm.shift->description = _("Shift factor for input");
-    parm.quantile = G_define_option();
-    parm.quantile->key = "quantile";
-    parm.quantile->type = TYPE_DOUBLE;
-    parm.quantile->required = NO;
-    parm.quantile->description = _("Quantile to calculate for method=quantile");
-    parm.quantile->options = "0.0-1.0";
-    parm.quantile->multiple = YES;
+    parm.baseline = G_define_option();
+    parm.baseline->key = "baseline";
+    parm.baseline->type = TYPE_DOUBLE;
+    parm.baseline->required = NO;
+    parm.baseline->answer = "10";
+    parm.baseline->description = _("Baseline temperature");
+    parm.cutoff = G_define_option();
+    parm.cutoff->key = "cutoff";
+    parm.cutoff->type = TYPE_DOUBLE;
+    parm.cutoff->required = NO;
+    parm.cutoff->answer = "30";
+    parm.cutoff->description = _("Cutoff temperature");
     parm.range = G_define_option();
     parm.range->key = "range";
     parm.range->type = TYPE_DOUBLE;
     parm.range->key_desc = "lo,hi";
     parm.range->description = _("Ignore values outside this range");
+    flag.avg = G_define_flag();
+    flag.avg->key = 'a';
+    flag.avg->description = _("Use average instead of min, max");
     flag.nulls = G_define_flag();
     flag.nulls->key = 'n';
     flag.nulls->description = _("Propagate NULLs");
@@ -311,36 +131,45 @@
     flag.lazy->key = 'z';
     flag.lazy->description = _("Don't keep files open");
-    flag.outlier = G_define_flag();
-    flag.outlier->key = 'o';
-    flag.outlier->description = _("Remove outliers");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
+    lo = -1.0 / 0.0;
+    hi = 1.0 / 0.0;
     if (parm.range->answer) {
 	lo = atof(parm.range->answers[0]);
 	hi = atof(parm.range->answers[1]);
+    if (parm.scale->answer)
+	tscale = atof(parm.scale->answer);
+    else
+	tscale = 1.;
+    if (parm.shift->answer)
+	tshift = atof(parm.shift->answer);
+    else
+	tshift = 0.;
+    baseline = atof(parm.baseline->answer);
+    cutoff = atof(parm.cutoff->answer);
     if (parm.input->answer && parm.file->answer)
         G_fatal_error(_("input= and file= are mutually exclusive"));
     if (!parm.input->answer && !parm.file->answer)
         G_fatal_error(_("Please specify input= or file="));
+    max_inputs = 0;
     /* process the input maps from the file */
     if (parm.file->answer) {
 	FILE *in;
-	int max_inputs;
 	in = fopen(parm.file->answer, "r");
 	if (!in)
 	    G_fatal_error(_("Unable to open input file <%s>"), parm.file->answer);
 	num_inputs = 0;
-	max_inputs = 0;
 	for (;;) {
 	    char buf[GNAME_MAX];
@@ -364,7 +193,7 @@
 	    p->name = G_store(name);
 	    G_verbose_message(_("Reading raster map <%s>..."), p->name);
-	    p->buf = Rast_allocate_d_buf();
+	    p->buf = Rast_allocate_f_buf();
 	    if (!flag.lazy->answer)
 		p->fd = Rast_open_old(p->name, "");
@@ -389,86 +218,42 @@
 	    p->name = parm.input->answers[i];
+	max_inputs = num_inputs;
-    /* set the weights */
-    if (parm.weight->answer) {
-	int method = find_window(parm.weight->answer);
-	double (*func)(double) = w_menu[method].func;
-	double radius = (num_inputs - 1) / 2.0;
-	values_w = (DCELL(*)[2]) G_malloc(num_inputs * 2 * sizeof(DCELL));
-	values_tmp_w = (DCELL(*)[2]) G_malloc(num_inputs * 2 * sizeof(DCELL));
-	weights = (DCELL *) G_malloc(num_inputs * sizeof(DCELL));
+    if (parm.gdd->answer) {
+	struct input *p;
-	for (i = 0; i < num_inputs; i++) {
-	    double x = fabs((i - radius) / radius);
-	    if (w_menu[method].radius > 1)
-		x *= w_menu[method].radius;
-	    weights[i] = (*func)(x);
+	gdd_in = 1;
+	if (num_inputs + 1 >= max_inputs) {
+	    max_inputs += 2;
+	    inputs = G_realloc(inputs, max_inputs * sizeof(struct input));
+	p = &inputs[num_inputs];
+	p->name = parm.gdd->answer;
+	G_verbose_message(_("Reading raster map <%s>..."), p->name);
+	if (!flag.lazy->answer)
+	    p->fd = Rast_open_old(p->name, "");
-    else {
-	values_w = NULL;
-	values_tmp_w = NULL;
-	weights = NULL;
+    else
+	gdd_in = 0;
-    /* process the output maps */
-    for (i = 0; parm.output->answers[i]; i++)
-    num_outputs = i;
+    out = G_calloc(1, sizeof(struct output));
-    for (i = 0; parm.method->answers[i]; i++)
-    if (num_outputs != i)
-	G_fatal_error(_("output= and method= must have the same number of values"));
+    out->name = parm.output->answer;
-    outputs = G_calloc(num_outputs, sizeof(struct output));
+    out->buf = Rast_allocate_f_buf();
+    out->fd = Rast_open_new(out->name, FCELL_TYPE);
-    for (i = 0; i < num_outputs; i++) {
-	struct output *out = &outputs[i];
-	const char *output_name = parm.output->answers[i];
-	const char *method_name = parm.method->answers[i];
-	int method = find_method(method_name);
-	out->name = output_name;
-	if (weights) {
-	    if (menu[method].method_w) {
-		out->method_fn = NULL;
-		out->method_fn_w = menu[method].method_w;
-	    else {
-		G_warning(_("Method %s not compatible with weighing window, using unweighed version instead"),
-		          method_name);
-		out->method_fn = menu[method].method;
-		out->method_fn_w = NULL;
-	else {
-	out->quantile = (parm.quantile->answer && parm.quantile->answers[i])
-	    ? atof(parm.quantile->answers[i])
-	    : 0;
-	out->buf = Rast_allocate_d_buf();
-	out->fd = Rast_open_new(output_name,
-				menu[method].is_int ? CELL_TYPE : DCELL_TYPE);
-    /* initialise variables */
-    values = G_malloc(num_inputs * sizeof(DCELL));
-    values_tmp = G_malloc(num_inputs * sizeof(DCELL));
     nrows = Rast_window_rows();
     ncols = Rast_window_cols();
+    Rast_set_f_null_value(&fnull, 1);
     /* process the data */
     G_verbose_message(_("Percent complete..."));
@@ -478,108 +263,100 @@
 	if (flag.lazy->answer) {
 	    /* Open the files only on run time */
+	    for (i = 0; i < num_inputs + gdd_in; i++) {
 		inputs[i].fd = Rast_open_old(inputs[i].name, "");
-		Rast_get_d_row(inputs[i].fd, inputs[i].buf, row);
+		Rast_get_f_row(inputs[i].fd, inputs[i].buf, row);
 		Rast_close(inputs[i].fd);
 	else {
+        #pragma omp for schedule (static) private (col)
 	for (col = 0; col < ncols; col++) {
 	    int null = 0, non_null = 0;
+	    FCELL min, max, sum, gdd;
+	    min = fnull;
+	    max = fnull;
+	    sum = 0;
-		DCELL v = inputs[i].buf[col];
+		FCELL v = inputs[i].buf[col];
-		if (Rast_is_d_null_value(&v))
+		if (Rast_is_f_null_value(&v))
 		    null = 1;
-		else if (parm.range->answer && (v < lo || v > hi)) {
-		    Rast_set_d_null_value(&v, 1);
-		    null = 1;
-		else
-		    non_null++;
+		else {
+		    v = v * tscale + tshift;
+		    if (parm.range->answer && (v < lo || v > hi)) {
+			null = 1;
+		    else {
+			if (v < baseline)
+			    v = baseline;
+			if (v > cutoff)
+			    v = cutoff;
-		if (weights) {
-		    values_w[i][0] = v;
-		    values_w[i][1] = weights[i];
+			if (flag.avg->answer)
+			    sum += v;
+			else {
+			    if (Rast_is_f_null_value(&min) || min > v)
+				min = v;
+			    if (Rast_is_f_null_value(&max) || max < v)
+				max = v;
+			non_null++;
-		values[i] = v;
-	    if (flag.outlier->answer && non_null > 5) {
-		/* remove outlier */
-		/* lower bound = 1st_Quartile - 1.5 * (3rd_Quartile - 1st_Quartile) */
-		double quart1, quart3, lower_bound;
+	    if (!non_null || (null && flag.nulls->answer)) {
+		if (gdd_in)
+		    gdd = inputs[num_inputs].buf[col];
+		else
+		    gdd = fnull;
+	    else {
-		memcpy(values_tmp, values, num_inputs * sizeof(DCELL));
-		c_quart1(&quart1, values_tmp, num_inputs, NULL);
-		c_quart3(&quart3, values_tmp, num_inputs, NULL);
-		if (quart1 < quart3)
-		    lower_bound = quart1 - 0.5 * (quart3 - quart1);
+		    gdd = sum / non_null - baseline;
 		else
-		    lower_bound = -1e100;
+		    gdd = (min + max) / 2. - baseline;
-		    DCELL v = values[i];
+		if (gdd < 0.)
+		    gdd = 0.;
+		if (gdd_in)
+		    gdd += inputs[num_inputs].buf[col];
-		    if (v <= lower_bound) {
-			null = 1;
-			/* non_null--; */
-			values[i] = v;
-			if (weights)
-		if (non_null < 2 || (null && flag.nulls->answer))
-		    Rast_set_d_null_value(&out->buf[col], 1);
-		else {
-		    if (out->method_fn_w) {
-			memcpy(values_tmp_w, values_w, num_inputs * 2 * sizeof(DCELL));
-			(*out->method_fn_w)(&out->buf[col], values_tmp_w, num_inputs, &out->quantile);
-		    else {
-			(*out->method_fn)(&out->buf[col], values_tmp, num_inputs, &out->quantile);
+	    out->buf[col] = gdd;
-	    Rast_put_d_row(outputs[i].fd, outputs[i].buf);
+	Rast_put_f_row(out->fd, out->buf);
     G_percent(row, nrows, 2);
-    /* close output maps */
+    /* close output map */
+    Rast_close(out->fd);
-	Rast_close(out->fd);
+    Rast_short_history(out->name, "raster", &history);
+    Rast_command_history(&history);
+    Rast_write_history(out->name, &history);
-	Rast_short_history(out->name, "raster", &history);
-	Rast_command_history(&history);
-	Rast_write_history(out->name, &history);
     /* Close input maps */
     if (!flag.lazy->answer) {
+    /* set gdd color table */
+    Rast_init_colors(&colors);
+    Rast_make_colors(&colors, "gdd", 0, 6000);
+    Rast_write_colors(out->name, NULL, &colors);
     exit(EXIT_SUCCESS);
Copied: grass-addons/grass7/raster/r.gdd/r.gdd.html (from rev 51631, grass-addons/grass7/raster/r.gdd/r.series.html)
--- grass-addons/grass7/raster/r.gdd/r.gdd.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.gdd/r.gdd.html	2012-05-16 15:48:08 UTC (rev 51632)
@@ -0,0 +1,99 @@
+<h2>DESCRIPTION</h2>
+<em>r.gdd</em> calculates (accumulated) growing degree days (GDDs) from
+several input maps with temperature data for different times of the day.
+<p>
+The formula for calculating GDDs is
+<div class="code"><pre>
+    gdd = (max + min) / 2 - baseline
+</pre></div>
+or using the average from all input maps
+    gdd = average - baseline
+</pre></div>
+with <em>min</em> being the minimum daily temperature, <em>max</em>
+the maximum daily temperature and <em>average</em> the average daily
+temperature. The <em>min</em>, <em>max</em> and <em>average</em> values
+are automatically calculated from the input temperature maps.
+<p>
+Negative GDD values are set to 0 (zero). All (scaled and shifted)
+temperature values above the <em>cutoff</em> value are set to
+<em>cutoff</em>, and all (scaled and shifted) temperature values below
+the <em>baseline</em> value are set to <em>baseline</em>.
+<p>
+If an existing GDD map is provided with the <em>gdd</em> option, the
+values of this GDD map are added to the output, thus accumulating GDDs.
+<h2>NOTES</h2>
+The <em>scale</em> and <em>shift</em> parameters are used to transform
+input values with
+    new = old * scale + shift
+</pre></div>
+<p>
+With the <em>-n</em> flag, any cell for which any of the
+corresponding input cells are NULL is automatically set to NULL
+(NULL propagation) and the GDD value is not calculated.
+<p>
+Without the <em>-n</em> flag, all non-NULL cells are used to
+calculate the current GDD.
+<p>
+If the <em>range=</em> option is given, any values which fall outside
+that range will be treated as if they were NULL. Note that the range is
+applied to the scaled and shifted input data. The <em>range</em>
+parameter can be set to <em>low,high</em> thresholds:
+values outside of this range are treated as NULL (i.e., they will be
+ignored by most aggregates, or will cause the result to be NULL if -n
+is given). The <em>low,high</em> thresholds are floating point, so use
+<em>-inf</em> or <em>inf</em> for a single threshold (e.g.,
+<em>range=0,inf</em> to ignore negative values, or
+<em>range=-inf,-200.4</em> to ignore values above -200.4).
+<p>
+The number of raster maps to be processed is given by the limit of the
+operating system. For example, both the hard and soft limits are
+typically 1024. The soft limit can be changed with e.g.
+<tt>ulimit -n 1500</tt> (UNIX-based operating systems) but not higher
+than the hard limit. If it is too low, you can as superuser add an
+entry in
+/etc/security/limits.conf
+# &lt;domain&gt;      &lt;type&gt;  &lt;item&gt;         &lt;value&gt;
+your_username  hard    nofile          1500
+</pre></div>
+This would raise the hard limit to 1500 file. Be warned that more
+files open need more RAM.
+<p>
+Use the <em>file</em> option to analyze large amount of raster maps
+without hitting open files limit and the size limit of command line
+arguments. The computation is slower than the <em>input</em> option
+method. For every sinlge row in the output map(s) all input maps are
+opened and closed. The amount of RAM will rise linear with the
+number of specified input maps. The input and file options are
+mutually exclusive. Input is a text file with a new line separated
+list of raster map names and optional weights. As separator between
+the map name and the weight the charachter | must be used.
+<h2>EXAMPLES</h2>
+Example with MODIS Land Surface Temperature, transforming values from
+Kelvin * 50 to degrees Celsius:
+r.gdd in=MOD11A1.Day,MOD11A1.Night,MYD11A1.Day,MYD11A1.Night out=MCD11A1.GDD \
+      scale=0.02 shift=-273.15 baseline=10 cutoff=30
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="r.series.html">r.series</a></em>,
+<em><a href="g.mlist.html">g.mlist</a></em>,
+<em><a href="g.region.html">g.region</a></em>
+<h2>AUTHOR</h2>
+Glynn Clements
+<p><i>Last changed: $Date$</i>
Deleted: grass-addons/grass7/raster/r.gdd/r.series.html
--- grass-addons/grass7/raster/r.gdd/r.series.html	2012-05-16 15:45:46 UTC (rev 51631)
+++ grass-addons/grass7/raster/r.gdd/r.series.html	2012-05-16 15:48:08 UTC (rev 51632)
@@ -1,146 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.series</em> makes each output cell value a function of the values
-assigned to the corresponding cells in the input raster map layers.
-Following methods are available:
-<ul>
- <li>average: average value
- <li>count: count of non-NULL cells
- <li>median: median value
- <li>mode: most frequently occuring value
- <li>minimum: lowest value
- <li>maximum: highest value
- <li>range: range of values (max - min)
- <li>stddev: standard deviation
- <li>sum: sum of values
- <li>variance: statistical variance
- <li>diversity: number of different values
- <li>slope: linear regression slope
- <li>offset: linear regression offset
- <li>detcoeff: linear regression coefficient of determination
- <li>min_raster: raster map number with the minimum time-series value
- <li>max_raster: raster map number with the maximum time-series value
- </ul>
-<h2>NOTES</h2>
-With <em>-n</em> flag, any cell for which any of the corresponding input cells are
-NULL is automatically set to NULL (NULL propagation). The aggregate function is not
-called, so all methods behave this way with respect to the <em>-n</em> flag.
-<p>Without <em>-n</em> flag, the complete list of inputs for each cell (including
-NULLs) is passed to the aggregate function. Individual aggregates can
-handle data as they choose. Mostly, they just compute the aggregate
-over the non-NULL values, producing a NULL result only if all inputs
-are NULL.
-<p>The <em>min_raster</em> and <em>max_raster</em> methods generate a map with the
-number of the raster map that holds the minimum/maximum value of the
-time-series. The numbering starts at <em>0</em> up to <em>n</em> for the
-first and the last raster listed in <em>input=</em>, respectively.
-<p>If the <em>range=</em> option is given, any values which fall outside
-that range will be treated as if they were NULL.
-The <em>range</em> parameter can be set to <em>low,high</em> thresholds:
-values outside of this range are treated as NULL (i.e., they will be
-ignored by most aggregates, or will cause the result to be NULL if -n is given).
-The <em>low,high</em> thresholds are floating point, so use <em>-inf</em> or
-<em>inf</em> for a single threshold (e.g., <em>range=0,inf</em> to ignore
-negative values, or <em>range=-inf,-200.4</em> to ignore values above -200.4).
-<p>Linear regression (slope, offset, coefficient of determination) assumes equal time intervals.
-If the data have irregular time intervals, NULL raster maps can be inserted into time series
-to make time intervals equal (see example).
-<p>Number of raster maps to be processed is given by the limit of the
-operating system. For example, both the hard and soft limits are
-typically 1024. The soft limit can be changed with e.g. <tt>ulimit -n
-1500</tt> (UNIX-based operating systems) but not higher than the hard
-limit. If it is too low, you can as superuser add an entry in
-<div class="code"><pre>
-/etc/security/limits.conf
-# &lt;domain&gt;      &lt;type&gt;  &lt;item&gt;         &lt;value&gt;
-your_username  hard    nofile          1500
-</pre></div>
-This would raise the hard limit to 1500 file. Be warned that more
-files open need more RAM.
-For each map a weighting factor can be specified using the <em>weights</em> option.
-Using weights can be meaningful when computing sum or average of maps with different
-temporal extent. The default weight is 1.0. The number of weights must be identical
-with the number of input maps and must have the same order. Weights can also be specified in the
-input file.
-<p>Use the <em>file</em> option to analyze large amount of raster maps without
-hitting open files limit and the size limit of command line arguments.
-The computation is slower than the <em>input</em> option method.
-For every sinlge row in the output map(s)
-all input maps are opened and closed. The amount of RAM will rise linear
-with the number of specified input maps. The input and file options are mutually exclusive.
-Input is a text file with a new line separated list of raster map names and optional weights.
-As separator between the map name and the weight the charachter | must be used.
-<h2>EXAMPLES</h2>
-Using <em>r.series</em> with wildcards:
-<br>
-r.series input="`g.mlist pattern='insitu_data.*' sep=,`" \
-         output=insitu_data.stddev method=stddev
-</pre></div>
-<p>Note the <em>g.mlist</em> script also supports regular expressions for
-selecting map names.
-<p>Using <em>r.series</em> with NULL raster maps:
-<br>
-r.mapcalc "dummy = null()"
-r.series in=map2001,map2002,dummy,dummy,map2005,map2006,dummy,map2008 \
-         out=res_slope,res_offset,res_coeff meth=slope,offset,detcoeff
-</pre></div>
-<p>Example for multiple aggregates to be computed in one run (3 resulting aggregates
-from two input maps):
-r.series in=one,two out=result_avg,res_slope,result_count meth=sum,slope,count
-</pre></div>
-<p>Example to use the file option of r.series:
-cat > input.txt << EOF
-map1
-map2
-map3
-EOF
-r.series file=input.txt out=result_sum meth=sum
-</pre></div>
-<p>Example to use the file option of r.series including weights. The weight 0.75
-should be assigned to map2. As the other maps do not have weights we can leave it out:
-map1
-map2|0.75
-map3
-EOF
-</pre></div>
-<p>
-Example for counting the number of days above a certain temperature using
-daily average maps ('???' as DOY wildcard):
-r.series input=`g.mlist rast pat="temp_2003_???_avg" sep=,` \
-         output=temp_2003_days_over_25deg range=25.0,100.0 method=count
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="g.mlist.html">g.mlist</a></em>,
-<em><a href="g.region.html">g.region</a></em>
-<h2>AUTHOR</h2>
-Glynn Clements
-<p><i>Last changed: $Date$</i>
