[GRASS-SVN] r51646 - grass/branches/develbranch_6/vector/v.type
svn_grass at osgeo.org
Thu May 17 22:16:57 EDT 2012
Author: hamish
Date: 2012-05-17 19:16:57 -0700 (Thu, 17 May 2012)
New Revision: 51646
grass/branches/develbranch_6/vector/v.type/main.c
rip out grass7 stuff now that we have branched
Modified: grass/branches/develbranch_6/vector/v.type/main.c
--- grass/branches/develbranch_6/vector/v.type/main.c 2012-05-17 20:28:13 UTC (rev 51645)
+++ grass/branches/develbranch_6/vector/v.type/main.c 2012-05-18 02:16:57 UTC (rev 51646)
@@ -15,9 +15,6 @@
* for details.
-#ifdef FOR_GRASS7
-#include <string.h>
-#endif
#include <stdlib.h>
#include <grass/gis.h>
@@ -32,16 +29,10 @@
int type;
char *mapset;
struct GModule *module;
-#ifdef FOR_GRASS7
- struct Option *in_opt, *out_opt, *to_opt, *from_opt;
- int from_type, to_type;
-#else
int i, j;
struct Option *in_opt, *out_opt, *type_opt;
int types[100]; /* array of input,output types */
int ntypes; /* number of types (number of pairs * 2) */
-#endif
module = G_define_module();
module->keywords = _("vector, geometry");
@@ -50,27 +41,6 @@
in_opt = G_define_standard_option(G_OPT_V_INPUT);
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
-#ifdef FOR_GRASS7
- from_opt = G_define_option();
- from_opt->type = TYPE_STRING;
- from_opt->key = "from";
- from_opt->key_desc = "type";
- from_opt->options = "point,line,boundary,centroid,face,kernel";
- from_opt->answer = "boundary";
- from_opt->required = YES;
- from_opt->multiple = NO;
- from_opt->description = _("Feature type to convert from");
- to_opt = G_define_option();
- to_opt->type = TYPE_STRING;
- to_opt->key = "to";
- to_opt->key_desc = "type";
- to_opt->options = "point,line,boundary,centroid,face,kernel";
- to_opt->answer = "line";
- to_opt->required = YES;
- to_opt->multiple = NO;
- to_opt->description = _("Feature type to convert to");
-#else
type_opt = G_define_standard_option(G_OPT_V_TYPE);
type_opt->options = "point,line,boundary,centroid,face,kernel";
type_opt->answer = "line,boundary,point,centroid";
@@ -79,7 +49,6 @@
_("<input_type1>,<output_type1>,<input_type2>,<output_type2>,...\n"
"\t\tExample1: line,boundary\n"
"\t\tExample2: line,boundary,point,centroid");
-#endif
G_gisinit(argv[0]);
@@ -87,60 +56,6 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
-#ifdef FOR_GRASS7
- if (!strcmp(from_opt->answer, to_opt->answer))
- G_fatal_error(_("Nothing to do"));
- switch (from_opt->answer[0]) {
- case 'p':
- from_type = GV_POINT;
- break;
- case 'l':
- from_type = GV_LINE;
- break;
- case 'b':
- from_type = GV_BOUNDARY;
- break;
- case 'c':
- from_type = GV_CENTROID;
- break;
- case 'f':
- from_type = GV_FACE;
- break;
- case 'k':
- from_type = GV_KERNEL;
- break;
- switch (to_opt->answer[0]) {
- case 'p':
- to_type = GV_POINT;
- break;
- case 'l':
- to_type = GV_LINE;
- break;
- case 'b':
- to_type = GV_BOUNDARY;
- break;
- case 'c':
- to_type = GV_CENTROID;
- break;
- case 'f':
- to_type = GV_FACE;
- break;
- case 'k':
- to_type = GV_KERNEL;
- break;
- /* check type compatibility */
- if (((from_type & (GV_POINT | GV_CENTROID | GV_KERNEL)) &&
- (to_type & (GV_LINE | GV_BOUNDARY | GV_FACE))
- ) || ((from_type & (GV_LINE | GV_BOUNDARY | GV_FACE)) &&
- (to_type & (GV_POINT | GV_CENTROID | GV_KERNEL))
- G_fatal_error(_("Incompatible types"));
-#else
i = 0;
j = 0;
while (type_opt->answers[i]) {
@@ -189,7 +104,6 @@
G_fatal_error(_("Odd number of types"));
ntypes = i;
-#endif
Vect_check_input_output_name(in_opt->answer, out_opt->answer,
GV_FATAL_EXIT);
@@ -216,17 +130,12 @@
Vect_hist_command(&Out);
while ((type = Vect_read_next_line(&In, Points, Cats)) > 0) {
-#ifdef FOR_GRASS7
- if (type == from_type)
- type = to_type;
-#else
for (i = 0; i < ntypes; i += 2) {
if (type == types[i]) {
type = types[i + 1];
break;
-#endif
Vect_write_line(&Out, type, Points, Cats);
