[GRASS-SVN] r51648 - grass/branches/develbranch_6/imagery/i.pca
svn_grass at osgeo.org
Fri May 18 04:31:37 EDT 2012
Author: mmetz
Date: 2012-05-18 01:31:36 -0700 (Fri, 18 May 2012)
New Revision: 51648
grass/branches/develbranch_6/imagery/i.pca/support.c
fix history handling, check return values
Modified: grass/branches/develbranch_6/imagery/i.pca/support.c
--- grass/branches/develbranch_6/imagery/i.pca/support.c 2012-05-18 08:16:07 UTC (rev 51647)
+++ grass/branches/develbranch_6/imagery/i.pca/support.c 2012-05-18 08:31:36 UTC (rev 51648)
@@ -4,7 +4,7 @@
#include "local_proto.h"
/* function prototypes */
-static void write_history(int, char *, double **, double *);
+static int write_history(int, char *, double **, double *);
void write_support(int bands, char *outname, double **eigmat, double *eigval)
@@ -23,13 +23,14 @@
if (G_raster_map_is_fp(outname, mapset))
G_mark_colors_as_fp(&colors);
- G_write_colors(outname, mapset, &colors);
+ if (G_write_colors(outname, mapset, &colors) < 0)
+ G_message(_("Unable to write color table for raster map <%s>"), outname);
write_history(bands, outname, eigmat, eigval);
-static void write_history(int bands, char *outname, double **eigmat, double *eigval)
+static int write_history(int bands, char *outname, double **eigmat, double *eigval)
int i, j;
static int first_map = TRUE; /* write to stderr? */
@@ -69,10 +70,11 @@
fprintf(stdout, "%s\n", tmpeigen);
+ hist.edlinecnt = i + 1;
G_command_history(&hist);
/* only write to stderr the first time (this fn runs for every output map) */
first_map = FALSE;
- G_write_history(outname, &hist);
+ return G_write_history(outname, &hist);
