[GRASS-SVN] r51661 - grass/trunk
svn_grass at osgeo.org
Tue May 22 06:30:28 EDT 2012
Author: neteler
Date: 2012-05-22 03:30:27 -0700 (Tue, 22 May 2012)
New Revision: 51661
grass/trunk/SUBMITTING
explain configure[.in] extensions
Modified: grass/trunk/SUBMITTING
--- grass/trunk/SUBMITTING 2012-05-20 21:01:27 UTC (rev 51660)
+++ grass/trunk/SUBMITTING 2012-05-22 10:30:27 UTC (rev 51661)
@@ -459,14 +459,19 @@
-31. Tell the other developers about the new code using the following e-mail:
+31. If you need to add support for a different library in the 'configure' script,
+ you should first seek consent in the grass-dev mailing list (see below), then
+ you need to expand 'configure.in' and run subsequently autoconf-2.13 (later
+ versions will not work) to re-generate 'configure'.
+32. Tell the other developers about the new code using the following e-mail:
grass-dev at lists.osgeo.org
To subscribe to this mailing list, see
http://lists.osgeo.org/mailman/listinfo/grass-dev
-32. In case of questions feel free to contact the developers at the above
+33. In case of questions feel free to contact the developers at the above
mailing list.
http://grass.osgeo.org/devel/index.php#submission
