[GRASS-SVN] r51671 - grass/trunk/lib/vector/rtree
Wed May 23 08:14:07 EDT 2012
Author: mmetz
Date: 2012-05-23 05:14:06 -0700 (Wed, 23 May 2012)
New Revision: 51671
   grass/trunk/lib/vector/rtree/Makefile
   grass/trunk/lib/vector/rtree/card.c
   grass/trunk/lib/vector/rtree/card.h
   grass/trunk/lib/vector/rtree/index.h
   grass/trunk/lib/vector/rtree/rtree.h
rtreelib: clean up headers
Modified: grass/trunk/lib/vector/rtree/Makefile
--- grass/trunk/lib/vector/rtree/Makefile	2012-05-23 12:13:19 UTC (rev 51670)
+++ grass/trunk/lib/vector/rtree/Makefile	2012-05-23 12:14:06 UTC (rev 51671)
@@ -4,9 +4,7 @@
 include $(MODULE_TOPDIR)/include/Make/Lib.make
-RTLINC = $(ARCH_INCDIR)/rtree
-HEADERS := $(RTLINC)/card.h $(RTLINC)/index.h $(RTLINC)/split.h \
-	$(ARCH_INCDIR)/rtree.h
+HEADERS := $(ARCH_INCDIR)/rtree.h
 default: headers
 	$(MAKE) lib
Modified: grass/trunk/lib/vector/rtree/card.c
--- grass/trunk/lib/vector/rtree/card.c	2012-05-23 12:13:19 UTC (rev 51670)
+++ grass/trunk/lib/vector/rtree/card.c	2012-05-23 12:14:06 UTC (rev 51671)
@@ -19,9 +19,6 @@
 #include "index.h"
 #include "card.h"
-int NODECARD = MAXCARD;
-int LEAFCARD = MAXCARD;
 static int set_max(int *which, int new_max)
     if (2 > new_max || new_max > MAXCARD)
Modified: grass/trunk/lib/vector/rtree/card.h
--- grass/trunk/lib/vector/rtree/card.h	2012-05-23 12:13:19 UTC (rev 51670)
+++ grass/trunk/lib/vector/rtree/card.h	2012-05-23 12:14:06 UTC (rev 51671)
@@ -19,9 +19,6 @@
 #ifndef __CARD__
 #define __CARD__
-extern int NODECARD;
-extern int LEAFCARD;
 /* balance criteria for node splitting */
 /* NOTE: can be changed if needed but
  * must be >= 2 and <= (t)->[nodecard|leafcard] / 2 */
Modified: grass/trunk/lib/vector/rtree/index.h
--- grass/trunk/lib/vector/rtree/index.h	2012-05-23 12:13:19 UTC (rev 51670)
+++ grass/trunk/lib/vector/rtree/index.h	2012-05-23 12:14:06 UTC (rev 51671)
@@ -15,146 +15,22 @@
 *               License (>=v2). Read the file COPYING that comes with GRASS
 *               for details.
-#ifndef _INDEX_
-#define _INDEX_
+#ifndef _R_TREE_INDEX_H_
+#define _R_TREE_INDEX_H_
-#include <stdio.h>
-#include <sys/types.h>
-#include <grass/config.h>
+#include "rtree.h"
+/* internal definitions and functions */
 /* PGSIZE is normally the natural page size of the machine */
 #define PGSIZE	512
-#define NUMDIMS	3		/* maximum number of dimensions */
-typedef double RectReal;
-| Global definitions.
-#ifndef TRUE
-#define TRUE 1
-#endif
-#ifndef FALSE
-#define FALSE 0
-#endif
-#define NUMSIDES 2*NUMDIMS
-/* max branching factor of a node */
-/* was (PGSIZE-(2 * sizeof(int))) / sizeof(struct Branch)
- * this is LFS dependent, not good
- * on 32 bit without LFS this is 9.69
- * on 32 bit with LFS and on 64 bit this is 9 */
-#define MAXCARD 9
 /* R*-tree: number of branches to be force-reinserted when adding a branch */
 #define FORCECARD 3
-/* maximum no of levels = tree depth */
-#define MAXLEVEL 20        /* 8^MAXLEVEL items are guaranteed to fit into the tree */
 #define NODETYPE(l, fd) ((l) == 0 ? 0 : ((fd) < 0 ? 1 : 2))
-struct RTree_Rect
-    RectReal boundary[NUMSIDES];	/* xmin,ymin,...,xmax,ymax,... */
-struct RTree_Node;               /* node for spatial index */
-union RTree_Child
-    int id;              /* child id */
-    struct RTree_Node *ptr;    /* pointer to child node */
-    off_t pos;           /* position of child node in file */
-struct RTree_Branch              /* branch for spatial index */
-    struct RTree_Rect rect;
-    union RTree_Child child;
-struct RTree_Node             /* node for spatial index */
-    int count;          /* number of branches */
-    int level;		/* 0 is leaf, others positive */
-    struct RTree_Branch branch[MAXCARD];
- * If passed to a tree search, this callback function will be called
- * with the ID of each data rect that overlaps the search rect
- * plus whatever user specific pointer was passed to the search.
- * It can terminate the search early by returning 0 in which case
- * the search will return the number of hits found up to that point.
-typedef int SearchHitCallback(int id, struct RTree_Rect rect, void *arg);
-struct RTree;
-typedef int rt_search_fn(struct RTree *, struct RTree_Rect *,
-                         SearchHitCallback *, void *);
-typedef int rt_insert_fn(struct RTree_Rect *, union RTree_Child, int, struct RTree *);
-typedef int rt_delete_fn(struct RTree_Rect *, union RTree_Child, struct RTree *);
-typedef int rt_valid_child_fn(union RTree_Child *);
-struct RTree
-    /* RTree setup info */
-    int fd;                 /* file descriptor */
-    unsigned char ndims;    /* number of dimensions */
-    unsigned char nsides;   /* number of sides = 2 * ndims */
-    int nodesize;           /* node size in bytes */
-    int branchsize;         /* branch size in bytes */
-    int rectsize;           /* rectangle size in bytes */
-    /* RTree info, useful to calculate space requirements */
-    int n_nodes;            /* number of nodes */
-    int n_leafs;            /* number of data items (level 0 leafs) */
-    int rootlevel;          /* root level = tree depth */
-    /* settings for RTree building */
-    int nodecard;           /* max number of childs in node */
-    int leafcard;           /* max number of childs in leaf */
-    int min_node_fill;      /* balance criteria for node removal */
-    int min_leaf_fill;      /* balance criteria for leaf removal */
-    int minfill_node_split; /* balance criteria for splitting */
-    int minfill_leaf_split; /* balance criteria for splitting */
-    /* free node positions for recycling */
-    struct _recycle {
-        int avail;          /* number of available positions */
-        int alloc;          /* number of allcoated positions in *pos */
-        off_t *pos;         /* array of available positions */
-    } free_nodes;
-    /* node buffer for file-based index, three nodes per level
-     * more than three nodes per level would require too complex cache management */
-    struct NodeBuffer
-	struct RTree_Node n;	    /* buffered node */
-	off_t pos;	    /* file position of buffered node */
-	char dirty;         /* node in buffer was modified */
-    } nb[MAXLEVEL][3];
-    /* usage order of buffered nodes per level
-     * used[level][0] = most recently used
-     * used[level][2] = least recently used */
-    char used[MAXLEVEL][3];
-    /* insert, delete, search */
-    rt_insert_fn *insert_rect;
-    rt_delete_fn *delete_rect;
-    rt_search_fn *search_rect;
-    rt_valid_child_fn *valid_child;
-    struct RTree_Node *root;     /* pointer to root node */
-    off_t rootpos;         /* root node position in file */
 struct RTree_ListNode
     struct RTree_ListNode *next;
@@ -175,67 +51,60 @@
 /* index.c */
-extern int RTreeSearch(struct RTree *, struct RTree_Rect *, SearchHitCallback *,
-		       void *);
-extern int RTreeInsertRect(struct RTree_Rect *, int, struct RTree *);
-extern int RTreeDeleteRect(struct RTree_Rect *, int, struct RTree *);
-extern struct RTree *RTreeNewIndex(int, off_t, int);
-extern void RTreeFreeIndex(struct RTree *);
-extern struct RTree_ListNode *RTreeNewListNode(void);
-extern void RTreeFreeListNode(struct RTree_ListNode *);
-extern void RTreeReInsertNode(struct RTree_Node *, struct RTree_ListNode **);
-extern void RTreeFreeListBranch(struct RTree_ListBranch *);
+struct RTree_ListNode *RTreeNewListNode(void);
+void RTreeFreeListNode(struct RTree_ListNode *);
+void RTreeReInsertNode(struct RTree_Node *, struct RTree_ListNode **);
+void RTreeFreeListBranch(struct RTree_ListBranch *);
 /* indexm.c */
-extern int RTreeSearchM(struct RTree *, struct RTree_Rect *, SearchHitCallback *,
+int RTreeSearchM(struct RTree *, struct RTree_Rect *, SearchHitCallback *,
 		       void *);
-extern int RTreeInsertRectM(struct RTree_Rect *, union RTree_Child, int, struct RTree *);
-extern int RTreeDeleteRectM(struct RTree_Rect *, union RTree_Child, struct RTree *);
-extern int RTreeValidChildM(union RTree_Child *child);
+int RTreeInsertRectM(struct RTree_Rect *, union RTree_Child, int, struct RTree *);
+int RTreeDeleteRectM(struct RTree_Rect *, union RTree_Child, struct RTree *);
+int RTreeValidChildM(union RTree_Child *child);
 /* indexf.c */
-extern int RTreeSearchF(struct RTree *, struct RTree_Rect *, SearchHitCallback *,
+int RTreeSearchF(struct RTree *, struct RTree_Rect *, SearchHitCallback *,
 		       void *);
-extern int RTreeInsertRectF(struct RTree_Rect *, union RTree_Child, int, struct RTree *);
-extern int RTreeDeleteRectF(struct RTree_Rect *, union RTree_Child, struct RTree *);
-extern int RTreeValidChildF(union RTree_Child *child);
+int RTreeInsertRectF(struct RTree_Rect *, union RTree_Child, int, struct RTree *);
+int RTreeDeleteRectF(struct RTree_Rect *, union RTree_Child, struct RTree *);
+int RTreeValidChildF(union RTree_Child *child);
 /* node.c */
-extern struct RTree_Node *RTreeNewNode(struct RTree *, int);
-extern void RTreeInitNode(struct RTree_Node *, int);
-extern void RTreeFreeNode(struct RTree_Node *);
-extern void RTreeDestroyNode(struct RTree_Node *, int);
-extern struct RTree_Rect RTreeNodeCover(struct RTree_Node *, struct RTree *);
-extern int RTreeAddBranch(struct RTree_Branch *, struct RTree_Node *, struct RTree_Node **,
+struct RTree_Rect RTreeNodeCover(struct RTree_Node *, struct RTree *);
+int RTreeAddBranch(struct RTree_Branch *, struct RTree_Node *, struct RTree_Node **,
             struct RTree_ListBranch **, struct RTree_Rect *, int *, struct RTree *);
-extern int RTreePickBranch(struct RTree_Rect *, struct RTree_Node *, struct RTree *);
-extern void RTreeDisconnectBranch(struct RTree_Node *, int, struct RTree *);
-extern void RTreePrintNode(struct RTree_Node *, int, struct RTree *);
-extern void RTreeTabIn(int);
+int RTreePickBranch(struct RTree_Rect *, struct RTree_Node *, struct RTree *);
+void RTreeDisconnectBranch(struct RTree_Node *, int, struct RTree *);
+void RTreePrintNode(struct RTree_Node *, int, struct RTree *);
+void RTreeTabIn(int);
 /* rect.c */
-extern void RTreeInitRect(struct RTree_Rect *);
-extern struct RTree_Rect RTreeNullRect(void);
-extern RectReal RTreeRectArea(struct RTree_Rect *, struct RTree *);
-extern RectReal RTreeRectSphericalVolume(struct RTree_Rect *, struct RTree *);
-extern RectReal RTreeRectVolume(struct RTree_Rect *, struct RTree *);
-extern RectReal RTreeRectMargin(struct RTree_Rect *, struct RTree *);
-extern struct RTree_Rect RTreeCombineRect(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
-extern int RTreeCompareRect(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
-extern int RTreeOverlap(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
-extern void RTreePrintRect(struct RTree_Rect *, int);
+void RTreeInitRect(struct RTree_Rect *);
+struct RTree_Rect RTreeNullRect(void);
+RectReal RTreeRectArea(struct RTree_Rect *, struct RTree *);
+RectReal RTreeRectSphericalVolume(struct RTree_Rect *, struct RTree *);
+RectReal RTreeRectVolume(struct RTree_Rect *, struct RTree *);
+RectReal RTreeRectMargin(struct RTree_Rect *, struct RTree *);
+struct RTree_Rect RTreeCombineRect(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
+int RTreeCompareRect(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
+int RTreeOverlap(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
+void RTreePrintRect(struct RTree_Rect *, int);
 /* split.c */
-extern void RTreeSplitNode(struct RTree_Node *, struct RTree_Branch *, struct RTree_Node *, struct RTree *);
+void RTreeSplitNode(struct RTree_Node *, struct RTree_Branch *, struct RTree_Node *, struct RTree *);
 /* card.c */
-extern int RTreeSetNodeMax(int, struct RTree *);
-extern int RTreeSetLeafMax(int, struct RTree *);
-extern int RTreeGetNodeMax(struct RTree *);
-extern int RTreeGetLeafMax(struct RTree *);
+int RTreeSetNodeMax(int, struct RTree *);
+int RTreeSetLeafMax(int, struct RTree *);
+int RTreeGetNodeMax(struct RTree *);
+int RTreeGetLeafMax(struct RTree *);
 /* fileio.c */
-extern void RTreeGetNode(struct RTree_Node *, off_t, int, struct RTree *);
-extern size_t RTreeReadNode(struct RTree_Node *, off_t, struct RTree *);
-extern void RTreePutNode(struct RTree_Node *, off_t, struct RTree *);
-extern size_t RTreeWriteNode(struct RTree_Node *, struct RTree *);
-extern size_t RTreeRewriteNode(struct RTree_Node *, off_t, struct RTree *);
-extern void RTreeUpdateRect(struct RTree_Rect *, struct RTree_Node *, off_t, int, struct RTree *);
-extern void RTreeAddNodePos(off_t, int, struct RTree *);
-extern off_t RTreeGetNodePos(struct RTree *);
-extern void RTreeFlushBuffer(struct RTree *);
+void RTreeGetNode(struct RTree_Node *, off_t, int, struct RTree *);
+void RTreePutNode(struct RTree_Node *, off_t, struct RTree *);
+size_t RTreeRewriteNode(struct RTree_Node *, off_t, struct RTree *);
+void RTreeUpdateRect(struct RTree_Rect *, struct RTree_Node *, off_t, int, struct RTree *);
+void RTreeAddNodePos(off_t, int, struct RTree *);
 #endif /* _INDEX_ */
Modified: grass/trunk/lib/vector/rtree/rtree.h
--- grass/trunk/lib/vector/rtree/rtree.h	2012-05-23 12:13:19 UTC (rev 51670)
+++ grass/trunk/lib/vector/rtree/rtree.h	2012-05-23 12:14:06 UTC (rev 51671)
@@ -9,13 +9,167 @@
 * PURPOSE:      Multidimensional index
-* COPYRIGHT:    (C) 2010 by the GRASS Development Team
+* COPYRIGHT:    (C) 2010-2012 by the GRASS Development Team
 *               This program is free software under the GNU General Public
 *               for details.
+#ifndef _R_TREE_H_
+#define _R_TREE_H_
-#include <grass/rtree/card.h>
-#include <grass/rtree/index.h>
-#include <grass/rtree/split.h>
+#include <stdio.h>
+#include <sys/types.h>
+#include <grass/config.h> /* needed for LFS */
+#define NUMDIMS	3		/* maximum number of dimensions */
+typedef double RectReal;
+| Global definitions.
+#ifndef TRUE
+#define TRUE 1
+#endif
+#ifndef FALSE
+#define FALSE 0
+#endif
+#define NUMSIDES 2*NUMDIMS
+/* max branching factor of a node */
+/* was (PGSIZE-(2 * sizeof(int))) / sizeof(struct Branch)
+ * this is LFS dependent, not good
+ * on 32 bit without LFS this is 9.69
+ * on 32 bit with LFS and on 64 bit this is 9 */
+#define MAXCARD 9
+#define NODECARD MAXCARD
+#define LEAFCARD MAXCARD
+/* maximum no of levels = tree depth */
+#define MAXLEVEL 20        /* 8^MAXLEVEL items are guaranteed to fit into the tree */
+struct RTree_Rect
+    RectReal boundary[NUMSIDES];	/* xmin,ymin,...,xmax,ymax,... */
+struct RTree_Node;               /* node for spatial index */
+union RTree_Child
+    int id;              /* child id */
+    struct RTree_Node *ptr;    /* pointer to child node */
+    off_t pos;           /* position of child node in file */
+struct RTree_Branch              /* branch for spatial index */
+    struct RTree_Rect rect;
+    union RTree_Child child;
+struct RTree_Node             /* node for spatial index */
+    int count;          /* number of branches */
+    int level;		/* 0 is leaf, others positive */
+    struct RTree_Branch branch[MAXCARD];
+ * If passed to a tree search, this callback function will be called
+ * with the ID of each data rect that overlaps the search rect
+ * plus whatever user specific pointer was passed to the search.
+ * It can terminate the search early by returning 0 in which case
+ * the search will return the number of hits found up to that point.
+typedef int SearchHitCallback(int id, struct RTree_Rect rect, void *arg);
+struct RTree;
+typedef int rt_search_fn(struct RTree *, struct RTree_Rect *,
+                         SearchHitCallback *, void *);
+typedef int rt_insert_fn(struct RTree_Rect *, union RTree_Child, int, struct RTree *);
+typedef int rt_delete_fn(struct RTree_Rect *, union RTree_Child, struct RTree *);
+typedef int rt_valid_child_fn(union RTree_Child *);
+struct RTree
+    /* RTree setup info */
+    int fd;                 /* file descriptor */
+    unsigned char ndims;    /* number of dimensions */
+    unsigned char nsides;   /* number of sides = 2 * ndims */
+    int nodesize;           /* node size in bytes */
+    int branchsize;         /* branch size in bytes */
+    int rectsize;           /* rectangle size in bytes */
+    /* RTree info, useful to calculate space requirements */
+    int n_nodes;            /* number of nodes */
+    int n_leafs;            /* number of data items (level 0 leafs) */
+    int rootlevel;          /* root level = tree depth */
+    /* settings for RTree building */
+    int nodecard;           /* max number of childs in node */
+    int leafcard;           /* max number of childs in leaf */
+    int min_node_fill;      /* balance criteria for node removal */
+    int min_leaf_fill;      /* balance criteria for leaf removal */
+    int minfill_node_split; /* balance criteria for splitting */
+    int minfill_leaf_split; /* balance criteria for splitting */
+    /* free node positions for recycling */
+    struct _recycle {
+        int avail;          /* number of available positions */
+        int alloc;          /* number of allcoated positions in *pos */
+        off_t *pos;         /* array of available positions */
+    } free_nodes;
+    /* node buffer for file-based index, three nodes per level
+     * more than three nodes per level would require too complex cache management */
+    struct NodeBuffer
+	struct RTree_Node n;	    /* buffered node */
+	off_t pos;	    /* file position of buffered node */
+	char dirty;         /* node in buffer was modified */
+    } nb[MAXLEVEL][3];
+    /* usage order of buffered nodes per level
+     * used[level][0] = most recently used
+     * used[level][2] = least recently used */
+    char used[MAXLEVEL][3];
+    /* insert, delete, search */
+    rt_insert_fn *insert_rect;
+    rt_delete_fn *delete_rect;
+    rt_search_fn *search_rect;
+    rt_valid_child_fn *valid_child;
+    struct RTree_Node *root;     /* pointer to root node */
+    off_t rootpos;         /* root node position in file */
+/* RTree main functions */
+int RTreeSearch(struct RTree *, struct RTree_Rect *, SearchHitCallback *,
+		       void *);
+int RTreeInsertRect(struct RTree_Rect *, int, struct RTree *);
+int RTreeDeleteRect(struct RTree_Rect *, int, struct RTree *);
+struct RTree *RTreeNewIndex(int, off_t, int);
+void RTreeFreeIndex(struct RTree *);
+/* RTree node management */
+struct RTree_Node *RTreeNewNode(struct RTree *, int);
+void RTreeInitNode(struct RTree_Node *, int);
+void RTreeFreeNode(struct RTree_Node *);
+void RTreeDestroyNode(struct RTree_Node *, int);
+/* RTree IO */
+size_t RTreeReadNode(struct RTree_Node *, off_t, struct RTree *);
+size_t RTreeWriteNode(struct RTree_Node *, struct RTree *);
+off_t RTreeGetNodePos(struct RTree *);
+void RTreeFlushBuffer(struct RTree *);
+#endif
