[GRASS-SVN] r51673 - grass/trunk/lib/vector/rtree
Wed May 23 08:56:04 EDT 2012
Author: mmetz
Date: 2012-05-23 05:56:03 -0700 (Wed, 23 May 2012)
New Revision: 51673
   grass/trunk/lib/vector/rtree/index.c
   grass/trunk/lib/vector/rtree/index.h
   grass/trunk/lib/vector/rtree/indexf.c
   grass/trunk/lib/vector/rtree/node.c
   grass/trunk/lib/vector/rtree/rect.c
   grass/trunk/lib/vector/rtree/rtree.h
   grass/trunk/lib/vector/rtree/split.c
rtreelib: update header, change node init
Modified: grass/trunk/lib/vector/rtree/index.c
--- grass/trunk/lib/vector/rtree/index.c	2012-05-23 12:29:50 UTC (rev 51672)
+++ grass/trunk/lib/vector/rtree/index.c	2012-05-23 12:56:03 UTC (rev 51673)
@@ -43,6 +43,11 @@
     new_rtree->rootpos = rootpos;
     new_rtree->ndims = ndims;
     new_rtree->nsides = 2 * ndims;
+    /* hack to keep compatibility */
+    if (ndims < 3)
+	new_rtree->nsides_alloc = 6;
+    else
+	new_rtree->nsides_alloc = 2 * ndims;
     new_rtree->rectsize = sizeof(struct RTree_Rect);
Modified: grass/trunk/lib/vector/rtree/index.h
--- grass/trunk/lib/vector/rtree/index.h	2012-05-23 12:29:50 UTC (rev 51672)
+++ grass/trunk/lib/vector/rtree/index.h	2012-05-23 12:56:03 UTC (rev 51673)
@@ -80,7 +80,8 @@
 void RTreeTabIn(int);
 /* rect.c */
-void RTreeInitRect(struct RTree_Rect *);
+void RTreeNewRect(struct RTree_Rect *, struct RTree *);
+void RTreeInitRect(struct RTree_Rect *, struct RTree *);
 struct RTree_Rect RTreeNullRect(void);
 RectReal RTreeRectArea(struct RTree_Rect *, struct RTree *);
 RectReal RTreeRectSphericalVolume(struct RTree_Rect *, struct RTree *);
@@ -88,7 +89,6 @@
 RectReal RTreeRectMargin(struct RTree_Rect *, struct RTree *);
 struct RTree_Rect RTreeCombineRect(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
 int RTreeCompareRect(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
-int RTreeOverlap(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
 void RTreePrintRect(struct RTree_Rect *, int);
 /* split.c */
Modified: grass/trunk/lib/vector/rtree/indexf.c
--- grass/trunk/lib/vector/rtree/indexf.c	2012-05-23 12:29:50 UTC (rev 51672)
+++ grass/trunk/lib/vector/rtree/indexf.c	2012-05-23 12:56:03 UTC (rev 51673)
@@ -252,7 +252,7 @@
 	RTreeGetNode(&oldroot, t->rootpos, t->rootlevel, t);
 	/* grow a new root, & tree taller */
 	t->rootlevel++;
-	RTreeInitNode(&newroot, NODETYPE(t->rootlevel, t->fd));
+	RTreeInitNode(t, &newroot, NODETYPE(t->rootlevel, t->fd));
 	newroot.level = t->rootlevel;
 	/* branch for old root */
 	b.rect = RTreeNodeCover(&oldroot, t);
@@ -284,7 +284,7 @@
 		t->rootlevel++;
Modified: grass/trunk/lib/vector/rtree/node.c
--- grass/trunk/lib/vector/rtree/node.c	2012-05-23 12:29:50 UTC (rev 51672)
+++ grass/trunk/lib/vector/rtree/node.c	2012-05-23 12:56:03 UTC (rev 51673)
@@ -31,23 +31,23 @@
 /* Initialize one branch cell in an internal node. */
-static void RTreeInitNodeBranchM(struct RTree_Branch *b)
+static void RTreeInitNodeBranchM(struct RTree *t, struct RTree_Branch *b)
-    RTreeInitRect(&(b->rect));
+    RTreeInitRect(&(b->rect), t);
     b->child.ptr = NULL;
-static void RTreeInitNodeBranchF(struct RTree_Branch *b)
+static void RTreeInitNodeBranchF(struct RTree *t, struct RTree_Branch *b)
     b->child.pos = -1;
 /* Initialize one branch cell in a leaf node. */
-static void RTreeInitLeafBranch(struct RTree_Branch *b)
+static void RTreeInitLeafBranch(struct RTree *t, struct RTree_Branch *b)
     b->child.id = 0;
@@ -57,7 +57,7 @@
 /* Initialize a Node structure. */
 /* type = 1: leaf, type = 2: internal, memory, type = 3: internal, file */
-void RTreeInitNode(struct RTree_Node *n, int type)
+void RTreeInitNode(struct RTree *t, struct RTree_Node *n, int type)
     int i;
@@ -65,7 +65,7 @@
     n->level = -1;
     for (i = 0; i < MAXCARD; i++)
-	RTreeInitBranch[type](&(n->branch[i]));
+	RTreeInitBranch[type](&(n->branch[i]), t);
 /* Make a new node and initialize to have all branch cells empty. */
@@ -75,7 +75,7 @@
     n = (struct RTree_Node *)malloc((size_t) t->nodesize);
     assert(n);
-    RTreeInitNode(n, NODETYPE(level, t->fd));
+    RTreeInitNode(t, n, NODETYPE(level, t->fd));
     return n;
@@ -94,7 +94,7 @@
     int i, first_time = 1;
     struct RTree_Rect r;
-    RTreeInitRect(&r);
+    RTreeInitRect(&r, t);
     if ((n)->level > 0) { /* internal node */
 	for (i = 0; i < t->nodecard; i++) {
 	    if (t->valid_child(&(n->branch[i].child))) {
@@ -234,14 +234,14 @@
 	assert(n && i >= 0 && i < t->nodecard);
 	assert(t->valid_child(&(n->branch[i].child)));
 	if (t->fd < 0)
-	    RTreeInitNodeBranchM(&(n->branch[i]));
+	    RTreeInitNodeBranchM(t, &(n->branch[i]));
 	else
-	    RTreeInitNodeBranchF(&(n->branch[i]));
+	    RTreeInitNodeBranchF(t, &(n->branch[i]));
     else {
 	assert(n && i >= 0 && i < t->leafcard);
 	assert(n->branch[i].child.id);
-	RTreeInitLeafBranch(&(n->branch[i]));
+	RTreeInitLeafBranch(t, &(n->branch[i]));
     n->count--;
@@ -536,7 +536,7 @@
 	else {
 	    if (t->fd > -1)
-		RTreeInitNode(*newnode, NODETYPE(n->level, t->fd));
+		RTreeInitNode(t, *newnode, NODETYPE(n->level, t->fd));
 	    else
 		*newnode = RTreeNewNode(t, (n)->level);
 	    RTreeSplitNode(n, b, *newnode, t);
Modified: grass/trunk/lib/vector/rtree/rect.c
--- grass/trunk/lib/vector/rtree/rect.c	2012-05-23 12:29:50 UTC (rev 51672)
+++ grass/trunk/lib/vector/rtree/rect.c	2012-05-23 12:56:03 UTC (rev 51673)
@@ -32,15 +32,27 @@
 #define MAX(a, b) ((a) > (b) ? (a) : (b))
+#if 0
+| Create a new rectangle for a given tree
+void RTreeNewRect(struct RTree_Rect *r, struct RTree *t)
+    r->boundary = (struct RTree_Rect *)malloc((size_t) t->nsides_alloc);
+    assert(r->boundary);
+    RTreeInitRect(r, t);
+#endif
 | Initialize a rectangle to have all 0 coordinates.
-void RTreeInitRect(struct RTree_Rect *R)
+void RTreeInitRect(struct RTree_Rect *r, struct RTree *t)
-    register struct RTree_Rect *r = R;
     register int i;
-    for (i = 0; i < NUMSIDES; i++)
+    for (i = 0; i < t->nsides; i++)
 	r->boundary[i] = (RectReal) 0;
Modified: grass/trunk/lib/vector/rtree/rtree.h
--- grass/trunk/lib/vector/rtree/rtree.h	2012-05-23 12:29:50 UTC (rev 51672)
+++ grass/trunk/lib/vector/rtree/rtree.h	2012-05-23 12:56:03 UTC (rev 51673)
@@ -24,6 +24,7 @@
 #define NUMDIMS	3		/* maximum number of dimensions */
+#define NUMSIDES 2*NUMDIMS
 typedef double RectReal;
@@ -38,8 +39,6 @@
 #define FALSE 0
 #endif
-#define NUMSIDES 2*NUMDIMS
 /* max branching factor of a node */
 /* was (PGSIZE-(2 * sizeof(int))) / sizeof(struct Branch)
  * this is LFS dependent, not good
@@ -100,12 +99,13 @@
 struct RTree
     /* RTree setup info */
-    int fd;                 /* file descriptor */
-    unsigned char ndims;    /* number of dimensions */
-    unsigned char nsides;   /* number of sides = 2 * ndims */
-    int nodesize;           /* node size in bytes */
-    int branchsize;         /* branch size in bytes */
-    int rectsize;           /* rectangle size in bytes */
+    int fd;                 	  /* file descriptor */
+    unsigned char ndims;    	  /* number of dimensions */
+    unsigned char nsides;   	  /* number of sides = 2 * ndims */
+    unsigned char nsides_alloc;   /* number of sides = 2 * ndims */
+    int nodesize;           	  /* node size in bytes */
+    int branchsize;         	  /* branch size in bytes */
+    int rectsize;           	  /* rectangle size in bytes */
     /* RTree info, useful to calculate space requirements */
     int n_nodes;            /* number of nodes */
@@ -159,10 +159,11 @@
 int RTreeDeleteRect(struct RTree_Rect *, int, struct RTree *);
 struct RTree *RTreeNewIndex(int, off_t, int);
 void RTreeFreeIndex(struct RTree *);
+int RTreeOverlap(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
 /* RTree node management */
 struct RTree_Node *RTreeNewNode(struct RTree *, int);
-void RTreeInitNode(struct RTree_Node *, int);
+void RTreeInitNode(struct RTree *, struct RTree_Node *, int);
 void RTreeFreeNode(struct RTree_Node *);
 void RTreeDestroyNode(struct RTree_Node *, int);
Modified: grass/trunk/lib/vector/rtree/split.c
--- grass/trunk/lib/vector/rtree/split.c	2012-05-23 12:29:50 UTC (rev 51672)
+++ grass/trunk/lib/vector/rtree/split.c	2012-05-23 12:56:03 UTC (rev 51673)
@@ -73,7 +73,7 @@
 	CoverSplitArea = RTreeRectSphericalVolume(&CoverSplit, t);
-    RTreeInitNode(n, NODETYPE(n->level, t->fd));
+    RTreeInitNode(t, n, NODETYPE(n->level, t->fd));
