[GRASS-SVN] r51681 - grass/trunk/display/d.rast.num
svn_grass at osgeo.org
Wed May 23 12:33:38 EDT 2012
Author: martinl
Date: 2012-05-23 09:33:37 -0700 (Wed, 23 May 2012)
New Revision: 51681
grass/trunk/display/d.rast.num/main.c
d.rast.num: minor clean up (named opts variables)
error message more clear for the user
Modified: grass/trunk/display/d.rast.num/main.c
--- grass/trunk/display/d.rast.num/main.c 2012-05-23 16:17:17 UTC (rev 51680)
+++ grass/trunk/display/d.rast.num/main.c 2012-05-23 16:33:37 UTC (rev 51681)
@@ -4,7 +4,7 @@
* MODULE: d.rast.num
* AUTHOR(S): Raghavan Srinivasan, Agricultural Engineering, Purdue University
* PURPOSE: Print numbers of category for raster cells
- * COPYRIGHT: (C) 2000 by the GRASS Development Team
+ * COPYRIGHT: (C) 2000, 2012 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -59,8 +59,12 @@
struct Cell_head window;
struct Colors colors;
struct GModule *module;
- struct Option *opt1, *opt2, *opt3, *prec;
- struct Flag *text_color, *align;
+ struct _opt {
+ struct Option *map, *grid_color, *text_color, *prec;
+ } opt;
+ struct _flg {
+ struct Flag *text_color, *align;
+ } flg;
RASTER_MAP_TYPE map_type, inmap_type;
double t, b, l, r;
@@ -71,58 +75,52 @@
G_add_keyword(_("display"));
G_add_keyword(_("raster"));
module->description =
- _("Overlays cell category values on a raster map layer "
- "displayed to the graphics monitor.");
+ _("Overlays cell category values on a raster map "
+ "displayed in the active graphics frame.");
- opt1 = G_define_standard_option(G_OPT_R_MAP);
+ opt.map = G_define_standard_option(G_OPT_R_MAP);
- opt2 = G_define_option();
- opt2->key = "grid_color";
- opt2->type = TYPE_STRING;
- opt2->required = NO;
- opt2->answer = "gray";
- opt2->gisprompt = "old_color,color,color_none";
- opt2->key_desc = "color";
- opt2->description = _("Color for drawing grid, or \"none\"");
+ opt.grid_color = G_define_standard_option(G_OPT_C_BG);
+ opt.grid_color->key = "grid_color";
+ opt.grid_color->answer = "gray";
+ opt.grid_color->description = _("Color for drawing grid, or \"none\"");
+ opt.grid_color->guisection = _("Colors");
- opt3 = G_define_option();
- opt3->key = "text_color";
- opt3->type = TYPE_STRING;
- opt3->required = NO;
- opt3->answer = DEFAULT_FG_COLOR;
- opt3->gisprompt = "old_color,color,color";
- opt3->key_desc = "color";
- opt3->description = _("Color for drawing text");
- prec = G_define_option();
- prec->key = "dp";
- prec->type = TYPE_INTEGER;
- prec->required = NO;
- prec->answer = "1";
- prec->options = "0,1,2,3,4,5,6,7,8,9";
- prec->description =
+ opt.text_color = G_define_standard_option(G_OPT_C_FG);
+ opt.text_color->key = "text_color";
+ opt.text_color->description = _("Color for drawing text");
+ opt.text_color->guisection = _("Colors");
+ opt.prec = G_define_option();
+ opt.prec->key = "dp";
+ opt.prec->type = TYPE_INTEGER;
+ opt.prec->required = NO;
+ opt.prec->answer = "1";
+ opt.prec->options = "0,1,2,3,4,5,6,7,8,9";
+ opt.prec->description =
_("Number of significant digits (floating point only)");
- align = G_define_flag();
- align->key = 'a';
- align->description = _("Align grids with raster cells");
+ flg.align = G_define_flag();
+ flg.align->key = 'a';
+ flg.align->description = _("Align grids with raster cells");
- text_color = G_define_flag();
- text_color->key = 'f';
- text_color->description = _("Get text color from cell color value");
+ flg.text_color = G_define_flag();
+ flg.text_color->key = 'f';
+ flg.text_color->description = _("Get text color from cell color value");
+ flg.text_color->guisection = _("Colors");
/* Check command line */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- map_name = opt1->answer;
+ map_name = opt.map->answer;
- if (strcmp("none", opt2->answer) == 0)
+ if (strcmp("none", opt.grid_color->answer) == 0)
grid_color = -1;
else
- grid_color = D_translate_color(opt2->answer);
+ grid_color = D_translate_color(opt.grid_color->answer);
- if (text_color->answer)
+ if (flg.text_color->answer)
fixed_color = 0;
else
fixed_color = 1;
@@ -131,7 +129,7 @@
G_get_window(&window);
- if (align->answer) {
+ if (flg.align->answer) {
struct Cell_head wind;
Rast_get_cellhd(map_name, "", &wind);
@@ -173,18 +171,14 @@
/* number of rows and cols in window */
if ((nrows > 75) || (ncols > 75)) {
- G_warning("!!!");
- G_message(_("Current window size:"));
- G_message(_("rows: %d"), nrows);
- G_message(_("columns: %d"), ncols);
- G_message(_("\nYour current window setting may be too large."
- " Cells displayed on your graphics window may be too"
- " small for cell category number to be visible."));
- G_message(" ");
+ G_warning(_("Current window size: %dx%d\n"
+ "Your current window setting may be too large. "
+ "Cells displayed on your graphics window may be too "
+ "small for cell category number to be visible."),
+ nrows, ncols);
if ((nrows > 200) || (ncols > 200)) {
- G_fatal_error(_("Aborting."));
+ G_fatal_error(_("Aborting (windows larger then 200x200 is not allowed)"));
/* Setup driver and check important information */
@@ -199,7 +193,7 @@
D_ew = fabs(D_get_u_to_d_xconv());
/*set the number of significant digits */
- sscanf(prec->answer, "%i", &digits);
+ sscanf(opt.prec->answer, "%i", &digits);
if (grid_color > 0) { /* ie not "none" */
/* Set grid color */
@@ -223,7 +217,7 @@
/* fixed text color */
if (fixed_color == 1)
- D_use_color(D_translate_color(opt3->answer));
+ D_use_color(D_translate_color(opt.text_color->answer));
/* loop through cells, find value, and draw text for value */
for (row = 0; row < nrows; row++) {
