[GRASS-SVN] r51685 - in grass/trunk/temporal: . t.info
t.rast.aggregate t.rast.aggregate.ds t.rast.export
t.rast.extract t.rast.gapfill t.rast.import t.rast.list
t.rast.mapcalc t.rast.out.vtk t.rast.series t.rast.to.rast3
t.rast.univar t.rast3d.extract t.rast3d.list t.rast3d.mapcalc
t.rast3d.univar t.register t.sample t.support t.topology
t.vect.extract t.vect.list t.vect.observe.strds t.vect.univar
t.vect.what.strds
svn_grass at osgeo.org
Wed May 23 13:30:50 EDT 2012
Author: huhabla
Date: 2012-05-23 10:30:50 -0700 (Wed, 23 May 2012)
New Revision: 51685
grass/trunk/temporal/run_all_tests.sh
grass/trunk/temporal/t.info/test.t.info.sh
grass/trunk/temporal/t.rast.aggregate.ds/test.t.rast.aggregate.ds.sh
grass/trunk/temporal/t.rast.aggregate/test.t.rast.aggregate.relative_time.sh
grass/trunk/temporal/t.rast.aggregate/test.t.rast.aggregate.sh
grass/trunk/temporal/t.rast.export/test.t.rast.export.sh
grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh
grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh
grass/trunk/temporal/t.rast.import/test.t.rast.import.sh
grass/trunk/temporal/t.rast.list/test.t.rast.list.sh
grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh
grass/trunk/temporal/t.rast.out.vtk/test.t.rast.out.vtk.sh
grass/trunk/temporal/t.rast.series/test.t.rast.series.sh
grass/trunk/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh
grass/trunk/temporal/t.rast.univar/test.t.rast.univar.sh
grass/trunk/temporal/t.rast3d.extract/test.t.rast3d.extract.sh
grass/trunk/temporal/t.rast3d.list/test.t.rast3d.list.sh
grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh
grass/trunk/temporal/t.rast3d.univar/test.t.rast3d.univar.sh
grass/trunk/temporal/t.register/test.t.register.raster.file.reltime.sh
grass/trunk/temporal/t.register/test.t.register.raster.file.sh
grass/trunk/temporal/t.register/test.t.register.raster.sh
grass/trunk/temporal/t.register/test.t.register.raster3d.sh
grass/trunk/temporal/t.register/test.t.register.vector.file.layer.sh
grass/trunk/temporal/t.register/test.t.register.vector.sh
grass/trunk/temporal/t.sample/test.t.sample.sh
grass/trunk/temporal/t.support/test.t.support.sh
grass/trunk/temporal/t.topology/test.t.topology.abstime.sh
grass/trunk/temporal/t.topology/test.t.topology.reltime.sh
grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh
grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh
grass/trunk/temporal/t.vect.list/test.t.vect.list.layer.sh
grass/trunk/temporal/t.vect.list/test.t.vect.list.sh
grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh
grass/trunk/temporal/t.vect.univar/test.t.vect.univar.sh
grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh
grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh
Added shell header to test files
Modified: grass/trunk/temporal/run_all_tests.sh
--- grass/trunk/temporal/run_all_tests.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/run_all_tests.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,4 +1,4 @@
-#!/usr/bin/env bash
+#!/bin/sh
# This scripts runs all tests available in the temporal module directory
# Logs a written to "run.log"
@@ -6,14 +6,14 @@
echo "Logfile\n\n" > $LOG_FILE
# For each directory
-for dir in `ls -d t*` ; do
- if [ -d $dir ] ; then
- echo $dir
- cd $dir
- for file in `ls test.* | grep -v '~'` ; do
- bash $file >> $LOG_FILE 2>&1
+for mydir in `ls -d t*` ; do
+ if [ -d $mydir ] ; then
+ echo $mydir
+ cd $mydir
+ for myfile in `ls test.* | grep -v '~'` ; do
+ sh $myfile >> $LOG_FILE 2>&1
done
- cd -
+ cd ..
fi
done
-cp $LOG_FILE .
+mv $LOG_FILE .
Modified: grass/trunk/temporal/t.info/test.t.info.sh
--- grass/trunk/temporal/t.info/test.t.info.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.info/test.t.info.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
# Test the info output
# We need to set a specific region in the
Modified: grass/trunk/temporal/t.rast.aggregate/test.t.rast.aggregate.relative_time.sh
--- grass/trunk/temporal/t.rast.aggregate/test.t.rast.aggregate.relative_time.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast.aggregate/test.t.rast.aggregate.relative_time.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,4 +1,5 @@
-# Test the extraction of a subset of a space time raster input
+#!/bin/sh
+# Space time raster dataset aggregation
# @preprocess step of this test.
Modified: grass/trunk/temporal/t.rast.aggregate/test.t.rast.aggregate.sh
--- grass/trunk/temporal/t.rast.aggregate/test.t.rast.aggregate.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast.aggregate/test.t.rast.aggregate.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,5 +1,5 @@
+#!/bin/sh
# The region setting should work for UTM and LL test locations
Modified: grass/trunk/temporal/t.rast.aggregate.ds/test.t.rast.aggregate.ds.sh
--- grass/trunk/temporal/t.rast.aggregate.ds/test.t.rast.aggregate.ds.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast.aggregate.ds/test.t.rast.aggregate.ds.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,9 +1,8 @@
+#!/bin/sh
+# Aggregate a dataset by a second one
-# @preprocess step of this test. We generate
-# raster with r.mapcalc and create two space time raster inputs
-# with relative and absolute time
+# @preprocess step of this test.
g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
Modified: grass/trunk/temporal/t.rast.export/test.t.rast.export.sh
--- grass/trunk/temporal/t.rast.export/test.t.rast.export.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast.export/test.t.rast.export.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,8 +1,8 @@
+#!/bin/sh
# Export of space time raster datasets
-# raster with r.mapcalc and create a space time raster datasets
Modified: grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh
--- grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
Modified: grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh
--- grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,5 @@
+#!/bin/sh
+# Fill the gaps in a space time raster dataset
Modified: grass/trunk/temporal/t.rast.import/test.t.rast.import.sh
--- grass/trunk/temporal/t.rast.import/test.t.rast.import.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast.import/test.t.rast.import.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,4 +1,5 @@
-# This is a test to list raster maps of a space time raster dataset
+#!/bin/sh
+# Test the import of space time raster datasets
Modified: grass/trunk/temporal/t.rast.list/test.t.rast.list.sh
--- grass/trunk/temporal/t.rast.list/test.t.rast.list.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast.list/test.t.rast.list.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
Modified: grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh
--- grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
# Test for t.rast.mapcalc
Modified: grass/trunk/temporal/t.rast.out.vtk/test.t.rast.out.vtk.sh
--- grass/trunk/temporal/t.rast.out.vtk/test.t.rast.out.vtk.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast.out.vtk/test.t.rast.out.vtk.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
# This is a test to export space time raster datasets as VTK time series data
Modified: grass/trunk/temporal/t.rast.series/test.t.rast.series.sh
--- grass/trunk/temporal/t.rast.series/test.t.rast.series.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast.series/test.t.rast.series.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,5 @@
+#!/bin/sh
+# Simple r.series wrapper
Modified: grass/trunk/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh
--- grass/trunk/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,7 +1,7 @@
+#!/bin/sh
+# Convert space time raster datasets into space time voxel cubes
g.region s=0 n=80 w=0 e=120 b=0 t=1 res=10 res3=1 -p3
Modified: grass/trunk/temporal/t.rast.univar/test.t.rast.univar.sh
--- grass/trunk/temporal/t.rast.univar/test.t.rast.univar.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast.univar/test.t.rast.univar.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,4 +1,5 @@
+#!/bin/sh
+# Test univariate statistics for space time raster datasets
Modified: grass/trunk/temporal/t.rast3d.extract/test.t.rast3d.extract.sh
--- grass/trunk/temporal/t.rast3d.extract/test.t.rast3d.extract.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast3d.extract/test.t.rast3d.extract.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,8 +1,8 @@
+#!/bin/sh
# Test the extraction of a subset of a space time raster3d input
Modified: grass/trunk/temporal/t.rast3d.list/test.t.rast3d.list.sh
--- grass/trunk/temporal/t.rast3d.list/test.t.rast3d.list.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast3d.list/test.t.rast3d.list.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,8 +1,8 @@
+#!/bin/sh
+# This is a test to list 3draster maps of a space time raster3d dataset
Modified: grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh
--- grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,8 +1,8 @@
-# Test for t.rast.mapcalc
+#!/bin/sh
+# Test for t.rast3d.mapcalc
-# raster with r.mapcalc and create several space time raster datasets
Modified: grass/trunk/temporal/t.rast3d.univar/test.t.rast3d.univar.sh
--- grass/trunk/temporal/t.rast3d.univar/test.t.rast3d.univar.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.rast3d.univar/test.t.rast3d.univar.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
# Univariate statitsics for space time raster3d datasets
Modified: grass/trunk/temporal/t.register/test.t.register.raster.file.reltime.sh
--- grass/trunk/temporal/t.register/test.t.register.raster.file.reltime.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.register/test.t.register.raster.file.reltime.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
# This is a test to register and unregister raster maps in
# space time raster input.
# The raster maps will be registered in different space time raster
@@ -6,7 +7,7 @@
+# with relative
Modified: grass/trunk/temporal/t.register/test.t.register.raster.file.sh
--- grass/trunk/temporal/t.register/test.t.register.raster.file.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.register/test.t.register.raster.file.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
@@ -6,7 +7,7 @@
+# with absolute time
Modified: grass/trunk/temporal/t.register/test.t.register.raster.sh
--- grass/trunk/temporal/t.register/test.t.register.raster.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.register/test.t.register.raster.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
Modified: grass/trunk/temporal/t.register/test.t.register.raster3d.sh
--- grass/trunk/temporal/t.register/test.t.register.raster3d.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.register/test.t.register.raster3d.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
# This is a test to register and unregister raster3d maps in
# space time raster3d datasets
# The raster3d maps will be registered in different space time raster3d
@@ -6,7 +7,7 @@
# 3d raster with r3.mapcalc and create two space time raster3d datasets
Modified: grass/trunk/temporal/t.register/test.t.register.vector.file.layer.sh
--- grass/trunk/temporal/t.register/test.t.register.vector.file.layer.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.register/test.t.register.vector.file.layer.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,7 +1,11 @@
-# This is a test to absolute time for vector maps with layer support
+#!/bin/sh
+# This is a test to register and unregister vector maps with layer support in
+# space time vector input.
-# vector with v.random.
+# vector with v.random and create several space time vector inputs
Modified: grass/trunk/temporal/t.register/test.t.register.vector.sh
--- grass/trunk/temporal/t.register/test.t.register.vector.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.register/test.t.register.vector.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,7 +1,6 @@
+#!/bin/sh
# This is a test to register and unregister vector maps in
-# The vector maps will be registered in different space time vector
-# inputs
Modified: grass/trunk/temporal/t.sample/test.t.sample.sh
--- grass/trunk/temporal/t.sample/test.t.sample.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.sample/test.t.sample.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,8 +1,8 @@
+#1/bin/sh
# This is a test to sample a space time raster dataset with a space time vector dataset
Modified: grass/trunk/temporal/t.support/test.t.support.sh
--- grass/trunk/temporal/t.support/test.t.support.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.support/test.t.support.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,9 @@
+#!/bin/sh
+# Tests the support module of space time datasets
+# We need to set a specific region in the
+# The region setting should work for UTM and LL test locations
r.mapcalc --o expr="prec_1 = rand(0, 550)"
Modified: grass/trunk/temporal/t.topology/test.t.topology.abstime.sh
--- grass/trunk/temporal/t.topology/test.t.topology.abstime.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.topology/test.t.topology.abstime.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,12 +1,8 @@
-# This is a test to register and unregister raster maps in
-# space time raster input.
-# The raster maps will be registered in different space time raster
-# inputs
+#!/bin/sh
+# Tests the temporaly topology module of space time datasets
Modified: grass/trunk/temporal/t.topology/test.t.topology.reltime.sh
--- grass/trunk/temporal/t.topology/test.t.topology.reltime.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.topology/test.t.topology.reltime.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,12 +1,8 @@
-# inputs
+#!/bin/sh
-# with relative and relolute time
Modified: grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh
--- grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,7 +1,9 @@
-# Test the temporal and spatial sampling of raster maps by vector point maps
+#!/bin/sh
+# Test the extraction of a subset of a space time vector input with
+# time stamped layer
-# The region setting should work for UTM and LL test locations
r.mapcalc --o expr="prec_1 = 100.0"
Modified: grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh
--- grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,7 +1,8 @@
+#!/bin/sh
v.random --o -z output=soil_1 n=100 zmin=0 zmax=100 column=height seed=1
v.random --o -z output=soil_2 n=100 zmin=0 zmax=100 column=height seed=2
Modified: grass/trunk/temporal/t.vect.list/test.t.vect.list.layer.sh
--- grass/trunk/temporal/t.vect.list/test.t.vect.list.layer.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.vect.list/test.t.vect.list.layer.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
# This is a test to list vecter maps of a space time vecter dataset
Modified: grass/trunk/temporal/t.vect.list/test.t.vect.list.sh
--- grass/trunk/temporal/t.vect.list/test.t.vect.list.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.vect.list/test.t.vect.list.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
Modified: grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh
--- grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,4 +1,5 @@
+#!/bin/sh
+# Test the temporal and spatial sampling/observation of raster maps by vector point maps
Modified: grass/trunk/temporal/t.vect.univar/test.t.vect.univar.sh
--- grass/trunk/temporal/t.vect.univar/test.t.vect.univar.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.vect.univar/test.t.vect.univar.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
# Test the univar statistics of space time vector datasets
Modified: grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh
--- grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
# using timetamped vector tables
Modified: grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh
--- grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh 2012-05-23 16:54:31 UTC (rev 51684)
+++ grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh 2012-05-23 17:30:50 UTC (rev 51685)
@@ -1,3 +1,4 @@
+#!/bin/sh
