[GRASS-SVN] r51690 - in grass-addons/grass7/raster/r.modis: .
libmodis r.modis.download r.modis.import
svn_grass at osgeo.org
Thu May 24 04:38:10 EDT 2012
Author: lucadelu
Date: 2012-05-24 01:38:08 -0700 (Thu, 24 May 2012)
New Revision: 51690
Added:
grass-addons/grass7/raster/r.modis/libmodis/convertmodis.py
grass-addons/grass7/raster/r.modis/libmodis/downmodis.py
grass-addons/grass7/raster/r.modis/libmodis/parsemodis.py
Removed:
grass-addons/grass7/raster/r.modis/libmodis/modis.py
grass-addons/grass7/raster/r.modis/Makefile
grass-addons/grass7/raster/r.modis/libmodis/Makefile
grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py
grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
add newer pymodis library and fix some problems
Modified: grass-addons/grass7/raster/r.modis/Makefile
--- grass-addons/grass7/raster/r.modis/Makefile 2012-05-24 08:32:08 UTC (rev 51689)
+++ grass-addons/grass7/raster/r.modis/Makefile 2012-05-24 08:38:08 UTC (rev 51690)
@@ -3,9 +3,9 @@
PGM = r.modis
SUBDIRS = \
- r.modis.download \
- r.modis.import \
- libmodis
+ r.modis.download \
+ r.modis.import \
+ libmodis
include $(MODULE_TOPDIR)/include/Make/Dir.make
Modified: grass-addons/grass7/raster/r.modis/libmodis/Makefile
--- grass-addons/grass7/raster/r.modis/libmodis/Makefile 2012-05-24 08:32:08 UTC (rev 51689)
+++ grass-addons/grass7/raster/r.modis/libmodis/Makefile 2012-05-24 08:38:08 UTC (rev 51690)
@@ -3,7 +3,7 @@
include $(MODULE_TOPDIR)/include/Make/Other.make
include $(MODULE_TOPDIR)/include/Make/Python.make
-MODULES = modis rmodislib
+MODULES = downmodis rmodislib convertmodis parsemodis
DSTDIR = $(ETC)/r.modis
Added: grass-addons/grass7/raster/r.modis/libmodis/convertmodis.py
--- grass-addons/grass7/raster/r.modis/libmodis/convertmodis.py (rev 0)
+++ grass-addons/grass7/raster/r.modis/libmodis/convertmodis.py 2012-05-24 08:38:08 UTC (rev 51690)
@@ -0,0 +1,221 @@
+#!/usr/bin/env python
+# class to convert/process modis data
+# (c) Copyright Luca Delucchi 2010
+# Authors: Luca Delucchi
+# Email: luca dot delucchi at iasma dot it
+# This MODIS Python class is licensed under the terms of GNU GPL 2.
+# This program is free software; you can redistribute it and/or
+# modify it under the terms of the GNU General Public License as
+# published by the Free Software Foundation; either version 2 of
+# the License, or (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
+# See the GNU General Public License for more details.
+from datetime import *
+import string
+import os
+import sys
+import glob
+import logging
+import socket
+from ftplib import FTP
+import ftplib
+class convertModis:
+ """A class to convert modis data from hdf to tif using resample (from MRT tools)
+ def __init__(self, hdfname, confile, mrtpath):
+ """Initialization function :
+ hdfname = the full path to the hdf file
+ confile = the full path to the paramater file
+ mrtpath = the full path to mrt directory where inside you have bin and
+ data directories
+ # check if the hdf file exists
+ if os.path.exists(hdfname):
+ self.name = hdfname
+ else:
+ raise IOError('%s not exists' % hdfname)
+ # check if confile exists
+ if os.path.exists(confile):
+ self.conf = confile
+ else:
+ raise IOError('%s not exists' % confile)
+ # check if mrtpath and subdirectories exists and set environment variables
+ if os.path.exists(mrtpath):
+ if os.path.exists(os.path.join(mrtpath,'bin')):
+ self.mrtpathbin = os.path.join(mrtpath,'bin')
+ os.environ['PATH'] = "%s:%s" % (os.environ['PATH'],os.path.join(mrtpath,
+ 'data'))
+ else:
+ raise IOError('The path %s not exists' % os.path.join(mrtpath,'bin'))
+ if os.path.exists(os.path.join(mrtpath,'data')):
+ self.mrtpathdata = os.path.join(mrtpath,'data')
+ os.environ['MRTDATADIR'] = os.path.join(mrtpath,'data')
+ else:
+ raise IOError('The path %s not exists' % os.path.join(mrtpath,'data'))
+ else:
+ raise IOError('The path %s not exists' % mrtpath)
+ def executable(self):
+ """Return the executable of resample MRT software
+ if sys.platform.count('linux') != -1:
+ if os.path.exists(os.path.join(self.mrtpathbin,'resample')):
+ return os.path.join(self.mrtpathbin,'resample')
+ elif sys.platform.count('win32') != -1:
+ if os.path.exists(os.path.join(self.mrtpathbin,'resample.exe')):
+ return os.path.join(self.mrtpath,'resample.exe')
+ def run(self):
+ """Exec the process"""
+ import subprocess
+ execut = self.executable()
+ if not os.path.exists(execut):
+ raise IOError('The path %s not exists, could be an erroneus path or '\
+ + 'software') % execut
+ else:
+ subprocess.call([execut,'-p',self.conf])
+ return "The hdf file %s was converted" % self.name
+class createMosaic:
+ """A class to convert a mosaic of different modis tiles"""
+ listfile,
+ outprefix,
+ mrtpath,
+ subset = False
+ if os.path.exists(listfile):
+ self.basepath = os.path.split(listfile)[0]
+ self.listfiles = listfile
+ self.HDFfiles = open(listfile).readlines()
+ else:
+ 'data'))
+ else:
+ else:
+ else:
+ self.out = os.path.join(self.basepath, outprefix + '.hdf')
+ self.outxml = os.path.join(self.basepath, self.out + '.xml')
+ self.subset = subset
+ def write_mosaic_xml(self):
+ from parsemodis import parseModisMulti
+ listHDF = []
+ for i in self.HDFfiles:
+ if i.find(self.basepath) == -1:
+ print "Attection maybe you have the not full path in the HDF file list"
+ listHDF.append(os.path.join(self.basepath,i.strip()))
+ else:
+ listHDF.append(i.strip())
+ pmm = parseModisMulti(listHDF)
+ pmm.writexml(self.outxml)
+ """Return the executable of mrtmosaic MRT software
+ if os.path.exists(os.path.join(self.mrtpathbin,'mrtmosaic')):
+ return os.path.join(self.mrtpathbin,'mrtmosaic')
+ if os.path.exists(os.path.join(self.mrtpathbin,'mrtmosaic.exe')):
+ return os.path.join(self.mrtpath,'mrtmosaic.exe')
+ def run(self):
+ """Exect the mosaic process"""
+ import subprocess
+ else:
+ self.write_mosaic_xml()
+ if self.subset:
+ subprocess.call([execut,'-i',self.listfiles,'-o',self.out,'-s',self.subset],
+ stderr = subprocess.STDOUT)
+ else:
+ subprocess.call([execut,'-i',self.listfiles,'-o',self.out], stderr =
+ subprocess.STDOUT)
+ return "The mosaic file %s is created" % self.out
+class processModis:
+ """A class to process raw modis data from hdf to tif using swath2grid (from MRT Swath tools)
+ hdfname, confile, mrtpath,
+ inputhdf = None, outputhdf = None, geolocfile = None
+ data directories
+ else:
+ else:
+ 'data'))
+ else:
+ else:
+ else:
+ if os.path.exists(os.path.join(self.mrtpathbin,'swath2grid')):
+ return os.path.join(self.mrtpathbin,'swath2grid')
+ if os.path.exists(os.path.join(self.mrtpathbin,'swath2grid.exe')):
+ return os.path.join(self.mrtpath,'swath2grid.exe')
+ def run(self):
+ import subprocess
+ else:
+ subprocess.call([execut,'-pf=%s' % self.conf])
Added: grass-addons/grass7/raster/r.modis/libmodis/downmodis.py
--- grass-addons/grass7/raster/r.modis/libmodis/downmodis.py (rev 0)
+++ grass-addons/grass7/raster/r.modis/libmodis/downmodis.py 2012-05-24 08:38:08 UTC (rev 51690)
@@ -0,0 +1,378 @@
+# class to download modis data
+import string
+import os
+import sys
+import glob
+import logging
+import socket
+import ftplib
+class downModis:
+ """A class to download MODIS data from NASA FTP repository"""
+ password,
+ destinationFolder,
+ user = "anonymous",
+ url = "e4ftl01u.ecs.nasa.gov",
+ tiles = None,
+ path = "MOLT/MOD11A1.005",
+ today = None,
+ enddate = None,
+ delta = 10,
+ jpg = False,
+ debug = False
+ password = is your password, usually your email address
+ destinationFolder = where the files will be stored
+ user = your username, by default anonymous
+ url = the url where to download the MODIS data
+ path = the directory where the data that you want to download are
+ stored on the ftp server
+ tiles = a list of tiles that you want to download, None == all tiles
+ today = the day to start downloading; in order to pass a date different from
+ today use the format YYYY-MM-DD
+ delta = timelag i.e. the number of days starting from today
+ (backwards
+ Creates a ftp instance, connects user to ftp server and goes into the
+ directory where the MODIS data are stored
+ # url modis
+ self.url = url
+ # user for download
+ self.user = user
+ # password for download
+ self.password = password
+ # directory where data are collected
+ self.path = path
+ # tiles to downloads
+ if tiles:
+ self.tiles = tiles.split(',')
+ else:
+ # set destination folder
+ if os.access(destinationFolder,os.W_OK):
+ self.writeFilePath = destinationFolder
+ else:
+ raise IOError("Folder to store downloaded files does not exist or is not" \
+ + "writeable")
+ # return the name of product
+ if len(self.path.split('/')) == 2:
+ self.product = self.path.split('/')[1]
+ elif len(self.path.split('/')) == 3:
+ self.product = self.path.split('/')[2]
+ # write a file with the name of file downloaded
+ self.filelist = open(os.path.join(self.writeFilePath, 'listfile' \
+ + self.product + '.txt'),'w')
+ # set jpg download
+ self.jpeg = jpg
+ # today
+ self.today = today
+ # force the last day
+ self.enday = enddate
+ # delta of days
+ self.delta = delta
+ # status of tile download
+ self.status = True
+ # for debug, you can download only xml files
+ self.debug = debug
+ # for logging
+ LOG_FILENAME = os.path.join(self.writeFilePath, 'modis' \
+ + self.product + '.log')
+ LOGGING_FORMAT='%(asctime)s - %(levelname)s - %(message)s'
+ logging.basicConfig(filename=LOG_FILENAME, level=logging.DEBUG, \
+ format=LOGGING_FORMAT)
+ def connectFTP(self):
+ """ Set connection to ftp server, move to path where data are stored
+ and create a list of directory for all days"""
+ try:
+ # connect to ftp server
+ self.ftp = FTP(self.url)
+ self.ftp.login(self.user,self.password)
+ # enter in directory
+ self.ftp.cwd(self.path)
+ self.dirData = []
+ # return data inside directory
+ self.ftp.dir(self.dirData.append)
+ # reverse order of data for have first the nearest to today
+ self.dirData.reverse()
+ # check if dirData contain only directory, delete all files
+ self.dirData = [elem.split()[-1] for elem in self.dirData if elem.startswith("d")]
+ if self.debug==True:
+ logging.debug("Open connection %s" % self.url)
+ except EOFError:
+ logging.error('Error in connection')
+ self.connectFTP()
+ def closeFTP(self):
+ """ Close ftp connection """
+ self.ftp.quit()
+ self.filelist.close()
+ logging.debug("Close connection %s" % self.url)
+ def setDirectoryIn(self,day):
+ """ Enter in the directory of the day """
+ try:
+ self.ftp.cwd(day)
+ except (ftplib.error_reply,socket.error), e:
+ logging.error("Error %s entering in directory %s" % e, day)
+ self.setDirectoryIn(day)
+ def setDirectoryOver(self):
+ """ Come back to old path """
+ try:
+ self.ftp.cwd('..')
+ logging.error("Error %s when try to come back" % e)
+ self.setDirectoryOver()
+ def str2date(self,strin):
+ """Return a date object from a string"""
+ todaySplit = strin.split('-')
+ return date(int(todaySplit[0]), int(todaySplit[1]),int(todaySplit[2]))
+ def getToday(self):
+ """Return the first day for start to download"""
+ if self.today == None:
+ # set today variable to today
+ self.today = date.today()
+ else:
+ # set today variable to data pass from user
+ self.today = self.str2date(self.today)
+ # set enday variable to data
+ if self.enday != None:
+ self.enday = self.str2date(self.enday)
+ def getListDays(self):
+ """ Return a list of all selected days """
+ self.getToday()
+ today_s = self.today.strftime("%Y.%m.%d")
+ # dirData is reverse sorted
+ for i, d in enumerate(self.dirData):
+ if d <= today_s:
+ today_avail = d
+ today_index = i
+ break
+ else:
+ logging.error("No data available for requested days")
+ import sys
+ sys.exit()
+ days = self.dirData[today_index:][:self.delta]
+ # this is useful for 8/16 days data, delta could download more images
+ # that you want
+ enday_s = self.enday.strftime("%Y.%m.%d")
+ delta = 0
+ # it make a for cicle from the last value and find the internal delta
+ #to remove file outside temporaly range
+ for i in range(-(len(days)),0):
+ if days[i] < enday_s:
+ break
+ else:
+ delta = delta + 1
+ # remove days outside new delta
+ days = days[:delta]
+ return days
+ def getFilesList(self):
+ """ Create a list of files to download, it is possible choose to download
+ also the jpeg files or only the hdf files"""
+ def cicle_file(jpeg=False,tile=True):
+ finalList = []
+ for i in self.listfiles:
+ File = i.split('.')
+ # distinguish jpeg files from hdf files by the number of index
+ # where find the tile index
+ if not tile and not (File.count('jpg') or File.count('BROWSE')):
+ finalList.append(i)
+ if tile and self.tiles.count(File[3]) == 1 and jpeg: #is a jpeg of tiles number
+ if tile and self.tiles.count(File[2]) == 1: #is a hdf of tiles number
+ return finalList
+ # return the file's list inside the directory of each day
+ try:
+ self.listfiles = self.ftp.nlst()
+ # download also jpeg
+ if self.jpeg:
+ # finallist is ugual to all file with jpeg file
+ if not self.tiles:
+ finalList = self.listfiles
+ # finallist is ugual to tiles file with jpeg file
+ else:
+ finalList = cicle_file(jpeg=True)
+ # not download jpeg
+ else:
+ finalList = cicle_file(tile=False)
+ else:
+ finalList = cicle_file()
+ logging.debug("The number of file to download is: %i" % len(finalList))
+ return finalList
+ logging.error("Error %s when try to receive list of files" % e)
+ self.getFilesList()
+ def checkDataExist(self,listNewFile, move = 0):
+ """ Check if a data already exists in the directory of download
+ Move serve to know if function is called from download or move function"""
+ fileInPath = []
+ # add all files in the directory where we will save new modis data
+ for f in os.listdir(self.writeFilePath):
+ if os.path.isfile(os.path.join(self.writeFilePath, f)):
+ fileInPath.append(f)
+ # different return if this method is used from downloadsAllDay() or
+ # moveFile()
+ if move == 0:
+ listOfDifferent = list(set(listNewFile) - set(fileInPath))
+ elif move == 1:
+ listOfDifferent = list(set(fileInPath) - set(listNewFile))
+ return listOfDifferent
+ def getNewerVersion(self,oldFile,newFile):
+ """ Return newer version of a file"""
+ oldFileSplit = oldFile.split('.')
+ newFileSplit = newFile.split('.')
+ if oldFileSplit[4] > newFileSplit[4]:
+ return oldFile
+ else:
+ return newFile
+ def downloadFile(self,filDown,filSave):
+ """Download the single file"""
+ #try to download file
+ try:
+ self.ftp.retrbinary("RETR " + filDown, filSave.write)
+ self.filelist.write("%s\n" % filDown)
+ logging.debug("File %s downloaded" % filDown)
+ #if it have an error it try to download again the file
+ logging.error("Cannot download %s, retry.." % filDown)
+ self.connectFTP()
+ self.downloadFile(filDown,filSave)
+ def dayDownload(self,listFilesDown):
+ """ Downloads tiles are in files_hdf_consider """
+ # for each file in files' list
+ for i in listFilesDown:
+ fileSplit = i.split('.')
+ filePrefix = fileSplit[0] + '.' + fileSplit[1] + '.' + fileSplit[2] \
+ + '.' + fileSplit[3]
+ #for debug, download only xml
+ if (self.debug and fileSplit[-1] == 'xml') or not self.debug:
+ # check data exists in the return directory, if it doesn't exists
+ oldFile = glob.glob1(self.writeFilePath, filePrefix + "*" \
+ + fileSplit[-1])
+ numFiles = len(oldFile)
+ if numFiles == 0:
+ file_hdf = open(os.path.join(self.writeFilePath,i), "wb")
+ elif numFiles == 1:
+ # check the version of file
+ fileDown = self.getNewerVersion(oldFile[0],i)
+ if fileDown != oldFile[0]:
+ os.remove(os.path.join(self.writeFilePath,oldFile[0]))
+ file_hdf = open(os.path.join(self.writeFilePath,fileDown), "wb")
+ elif numFiles > 1:
+ logging.error("There are to much files for %s" % i)
+ #raise EOFError("There are to much file with the same prefix")
+ if numFiles == 0 or (numFiles == 1 and fileDown != oldFile[0]):
+ self.downloadFile(i,file_hdf)
+ def downloadsAllDay(self):
+ """ Downloads all the tiles considered """
+ #return the days to download
+ days = self.getListDays()
+ logging.debug("The number of days to download is: %i" % len(days))
+ #for each day
+ for day in days:
+ #enter in the directory of day
+ #obtain list of all files
+ listAllFiles = self.getFilesList()
+ #obtain list of files to download
+ listFilesDown = self.checkDataExist(listAllFiles)
+ #download files for a day
+ self.dayDownload(listFilesDown)
+ self.closeFTP()
+ logging.debug("Download terminated")
+ return 0
+ def debugLog(self):
+ # create logger
+ logger = logging.getLogger("PythonLibModis debug")
+ logger.setLevel(logging.DEBUG)
+ # create console handler and set level to debug
+ ch = logging.StreamHandler()
+ ch.setLevel(logging.DEBUG)
+ # create formatter
+ formatter = logging.Formatter("%(asctime)s - %(name)s - " \
+ + "%(levelname)s - %(message)s")
+ # add formatter to ch
+ ch.setFormatter(formatter)
+ # add ch to logger
+ logger.addHandler(ch)
+ return logger
+ def debugDays(self):
+ """This function is useful to debug the number of days"""
+ logger = debugLog()
+ # if lenght of list of days and the delta of day they are different
+ if len(days) != self.delta:
+ # for each day
+ for i in range(1,self.delta+1):
+ # calculate the current day
+ delta = timedelta(days = i)
+ day = self.today - delta
+ day = day.strftime("%Y.%m.%d")
+ # check if day is in the days list
+ if day not in days:
+ logger.critical("This day %s is not present on list" % day)
+ # the lenght of list of days and delta are ugual
+ else:
+ logger.info("All right!!")
+ def debugMaps(self):
+ """This function is useful to debug the number of maps to download for
+ each day"""
+ for day in days:
+ string = day + ": " + str(len(listAllFiles)) + "\n"
+ logger.debug(string)
Deleted: grass-addons/grass7/raster/r.modis/libmodis/modis.py
--- grass-addons/grass7/raster/r.modis/libmodis/modis.py 2012-05-24 08:32:08 UTC (rev 51689)
+++ grass-addons/grass7/raster/r.modis/libmodis/modis.py 2012-05-24 08:38:08 UTC (rev 51690)
@@ -1,1334 +0,0 @@
-#!/usr/bin/env python
-# -*- coding: utf-8 -*-
-# class to download modis data
-# (c) Copyright Luca Delucchi 2010
-# Authors: Luca Delucchi
-# Email: luca dot delucchi at iasma dot it
-# This MODIS Python class is licensed under the terms of GNU GPL 2.
-# This program is free software; you can redistribute it and/or
-# modify it under the terms of the GNU General Public License as
-# published by the Free Software Foundation; either version 2 of
-# the License, or (at your option) any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
-# See the GNU General Public License for more details.
-# History
-# 0.4.0 Fix a lot of bugs, add convertModis class to convert hdf to other
-# format and projection system (To release)
-# 0.3.0 Fixed the choosing of days, change name modisClass to downModis
-# and add parseModis (2011-05-24)
-# 0.2.1 Little change in the logging option (2011-01-21)
-# 0.2.0 Added logging and change something in debug methods (2010-12-01)
-# 0.1.3 Correct a little problem with "Connection timed out"
-# 0.1.2 Added two debug methods (2010-13-08)
-# 0.1.1 Added moveFile method (2010-07-02)
-# 0.1.0 First Version of MODIS Python Class (2010-06-19)
-# tilesUsed="h17v04,h17v05,h18v02,h18v03,h18v05,h19v04,h19v05"
-# writePath="/home/luca/test_modis"
-__version__ = '0.4.0'
-from datetime import *
-import string
-import os
-import sys
-import glob
-import logging
-import socket
-from ftplib import FTP
-import ftplib
-from xml.etree import ElementTree
-class downModis:
- """A class to download MODIS data from NASA FTP repository"""
- def __init__(self,
- password,
- destinationFolder,
- user = "anonymous",
- url = "e4ftl01u.ecs.nasa.gov",
- tiles = None,
- path = "MOLT/MOD11A1.005",
- today = None,
- enddate = None,
- delta = 10,
- jpg = False,
- debug = False
- """Initialization function :
- password = is your password, usually your email address
- destinationFolder = where the files will be stored
- user = your username, by default anonymous
- url = the url where to download the MODIS data
- path = the directory where the data that you want to download are
- stored on the ftp server
- tiles = a list of tiles that you want to download, None == all tiles
- today = the day to start downloading; in order to pass a date different from
- today use the format YYYY-MM-DD
- delta = timelag i.e. the number of days starting from today
- (backwards
- Creates a ftp instance, connects user to ftp server and goes into the
- directory where the MODIS data are stored
- # url modis
- self.url = url
- # user for download
- self.user = user
- # password for download
- self.password = password
- # directory where data are collected
- self.path = path
- # tiles to downloads
- if tiles:
- self.tiles = tiles.split(',')
- else:
- # set destination folder
- if os.access(destinationFolder,os.W_OK):
- self.writeFilePath = destinationFolder
- else:
- raise IOError("Folder to store downloaded files does not exist or is not" \
- + "writeable")
- # return the name of product
- if len(self.path.split('/')) == 2:
- self.product = self.path.split('/')[1]
- elif len(self.path.split('/')) == 3:
- self.product = self.path.split('/')[2]
- # write a file with the name of file downloaded
- self.filelist = open(os.path.join(self.writeFilePath, 'listfile' \
- + self.product + '.txt'),'w')
- # set jpg download
- self.jpeg = jpg
- # today
- self.today = today
- # force the last day
- self.enday = enddate
- # delta of days
- self.delta = delta
- # status of tile download
- self.status = True
- # for debug, you can download only xml files
- self.debug = debug
- # for logging
- LOG_FILENAME = os.path.join(self.writeFilePath, 'modis' \
- + self.product + '.log')
- LOGGING_FORMAT='%(asctime)s - %(levelname)s - %(message)s'
- logging.basicConfig(filename=LOG_FILENAME, level=logging.DEBUG, \
- format=LOGGING_FORMAT)
- def connectFTP(self):
- """ Set connection to ftp server, move to path where data are stored
- and create a list of directory for all days"""
- try:
- # connect to ftp server
- self.ftp = FTP(self.url)
- self.ftp.login(self.user,self.password)
- # enter in directory
- self.ftp.cwd(self.path)
- self.dirData = []
- # return data inside directory
- self.ftp.dir(self.dirData.append)
- # reverse order of data for have first the nearest to today
- self.dirData.reverse()
- # check if dirData contain only directory, delete all files
- self.dirData = [elem.split()[-1] for elem in self.dirData if elem.startswith("d")]
- if self.debug==True:
- logging.debug("Open connection %s" % self.url)
- except EOFError:
- logging.error('Error in connection')
- self.connectFTP()
- def closeFTP(self):
- """ Close ftp connection """
- self.ftp.quit()
- self.filelist.close()
- logging.debug("Close connection %s" % self.url)
- def _setDirectoryIn(self,day):
- """ Enter in the directory of the day """
- try:
- self.ftp.cwd(day)
- except (ftplib.error_reply,socket.error), e:
- logging.error("Error %s entering in directory %s" % e, day)
- self._setDirectoryIn(day)
- def _setDirectoryOver(self):
- """ Come back to old path """
- try:
- self.ftp.cwd('..')
- logging.error("Error %s when try to come back" % e)
- self._setDirectoryOver()
- def _str2date(self,strin):
- """Return a date object from a string"""
- todaySplit = strin.split('-')
- return date(int(todaySplit[0]), int(todaySplit[1]),int(todaySplit[2]))
- def _getToday(self):
- """Return the first day for start to download"""
- if self.today == None:
- # set today variable to today
- self.today = date.today()
- else:
- # set today variable to data pass from user
- self.today = self._str2date(self.today)
- # set enday variable to data
- if self.enday != None:
- self.enday = self._str2date(self.enday)
- def getListDays(self):
- """ Return a list of all selected days """
- self._getToday()
- today_s = self.today.strftime("%Y.%m.%d")
- # dirData is reverse sorted
- for i, d in enumerate(self.dirData):
- if d <= today_s:
- today_avail = d
- today_index = i
- break
- else:
- logging.error("No data available for requested days")
- import sys
- sys.exit()
- days = self.dirData[today_index:][:self.delta]
- # this is useful for 8/16 days data, delta could download more images
- # that you want
- enday_s = self.enday.strftime("%Y.%m.%d")
- delta = 0
- # it make a for cicle from the last value and find the internal delta
- #to remove file outside temporaly range
- for i in range(-(len(days)),0):
- if days[i] < enday_s:
- break
- else:
- delta = delta + 1
- # remove days outside new delta
- days = days[:delta]
- return days
- def getFilesList(self):
- """ Create a list of files to download, it is possible choose to download
- also the jpeg files or only the hdf files"""
- def cicle_file(jpeg=False,tile=True):
- finalList = []
- for i in self.listfiles:
- File = i.split('.')
- # distinguish jpeg files from hdf files by the number of index
- # where find the tile index
- if not tile and not (File.count('jpg') or File.count('BROWSE')):
- finalList.append(i)
- if tile and self.tiles.count(File[3]) == 1 and jpeg: #is a jpeg of tiles number
- if tile and self.tiles.count(File[2]) == 1: #is a hdf of tiles number
- return finalList
- # return the file's list inside the directory of each day
- try:
- self.listfiles = self.ftp.nlst()
- # download also jpeg
- if self.jpeg:
- # finallist is ugual to all file with jpeg file
- if not self.tiles:
- finalList = self.listfiles
- # finallist is ugual to tiles file with jpeg file
- else:
- finalList = cicle_file(jpeg=True)
- # not download jpeg
- else:
- finalList = cicle_file(tile=False)
- else:
- finalList = cicle_file()
- logging.debug("The number of file to download is: %i" % len(finalList))
- return finalList
- logging.error("Error %s when try to receive list of files" % e)
- self.getFilesList()
- def _checkDataExist(self,listNewFile, move = 0):
- """ Check if a data already exists in the directory of download
- Move serve to know if function is called from download or move function"""
- fileInPath = []
- # add all files in the directory where we will save new modis data
- for f in os.listdir(self.writeFilePath):
- if os.path.isfile(os.path.join(self.writeFilePath, f)):
- fileInPath.append(f)
- # different return if this method is used from downloadsAllDay() or
- # moveFile()
- if move == 0:
- listOfDifferent = list(set(listNewFile) - set(fileInPath))
- elif move == 1:
- listOfDifferent = list(set(fileInPath) - set(listNewFile))
- return listOfDifferent
- def _getNewerVersion(self,oldFile,newFile):
- """ Return newer version of a file"""
- oldFileSplit = oldFile.split('.')
- newFileSplit = newFile.split('.')
- if oldFileSplit[4] > newFileSplit[4]:
- return oldFile
- else:
- return newFile
- def downloadFile(self,filDown,filSave):
- """Download the single file"""
- #try to download file
- try:
- self.ftp.retrbinary("RETR " + filDown, filSave.write)
- self.filelist.write("%s\n" % filDown)
- logging.debug("File %s downloaded" % filDown)
- #if it have an error it try to download again the file
- logging.error("Cannot download %s, retry.." % filDown)
- self.connectFTP()
- self.downloadFile(filDown,filSave)
- def dayDownload(self,listFilesDown):
- """ Downloads tiles are in files_hdf_consider """
- # for each file in files' list
- for i in listFilesDown:
- fileSplit = i.split('.')
- filePrefix = fileSplit[0] + '.' + fileSplit[1] + '.' + fileSplit[2] \
- + '.' + fileSplit[3]
- #for debug, download only xml
- if (self.debug and fileSplit[-1] == 'xml') or not self.debug:
- # check data exists in the return directory, if it doesn't exists
- oldFile = glob.glob1(self.writeFilePath, filePrefix + "*" \
- + fileSplit[-1])
- numFiles = len(oldFile)
- if numFiles == 0:
- file_hdf = open(os.path.join(self.writeFilePath,i), "wb")
- elif numFiles == 1:
- # check the version of file
- fileDown = self._getNewerVersion(oldFile[0],i)
- if fileDown != oldFile[0]:
- os.remove(os.path.join(self.writeFilePath,oldFile[0]))
- file_hdf = open(os.path.join(self.writeFilePath,fileDown), "wb")
- elif numFiles > 1:
- logging.error("There are to much files for %s" % i)
- #raise EOFError("There are to much file with the same prefix")
- if numFiles == 0 or (numFiles == 1 and fileDown != oldFile[0]):
- self.downloadFile(i,file_hdf)
- def downloadsAllDay(self):
- """ Downloads all the tiles considered """
- #return the days to download
- days = self.getListDays()
- logging.debug("The number of days to download is: %i" % len(days))
- #for each day
- for day in days:
- #enter in the directory of day
- #obtain list of all files
- listAllFiles = self.getFilesList()
- #obtain list of files to download
- listFilesDown = self._checkDataExist(listAllFiles)
- #download files for a day
- self.dayDownload(listFilesDown)
- self.closeFTP()
- logging.debug("Download terminated")
- return 0
- def debugLog(self):
- # create logger
- logger = logging.getLogger("PythonLibModis debug")
- logger.setLevel(logging.DEBUG)
- # create console handler and set level to debug
- ch = logging.StreamHandler()
- ch.setLevel(logging.DEBUG)
- # create formatter
- formatter = logging.Formatter("%(asctime)s - %(name)s - " \
- + "%(levelname)s - %(message)s")
- # add formatter to ch
- ch.setFormatter(formatter)
- # add ch to logger
- logger.addHandler(ch)
- return logger
- def debugDays(self):
- """This function is useful to debug the number of days"""
- logger = debugLog()
- # if lenght of list of days and the delta of day they are different
- if len(days) != self.delta:
- # for each day
- for i in range(1,self.delta+1):
- # calculate the current day
- delta = timedelta(days = i)
- day = self.today - delta
- day = day.strftime("%Y.%m.%d")
- # check if day is in the days list
- if day not in days:
- logger.critical("This day %s is not present on list" % day)
- # the lenght of list of days and delta are ugual
- else:
- logger.info("All right!!")
- def debugMaps(self):
- """This function is useful to debug the number of maps to download for
- each day"""
- for day in days:
- string = day + ": " + str(len(listAllFiles)) + "\n"
- logger.debug(string)
-class parseModis:
- """Class to parse MODIS xml files, it also can create the parameter
- configuration file for resampling with the MRT software
- def __init__(self, filename):
- filename = the name of MODIS hdf file
- if os.path.exists(filename):
- # hdf name
- self.hdfname = filename
- else:
- raise IOError('%s not exists' % self.hdfname)
- if os.path.exists(self.hdfname + '.xml'):
- # xml hdf name
- self.xmlname = self.hdfname + '.xml'
- else:
- raise IOError('%s not exists' % self.hdfname + '.xml')
- # tif name for the output file for resample MRT software
- self.tifname = self.hdfname.replace('.hdf','.tif')
- with open(self.xmlname) as f:
- self.tree = ElementTree.parse(f)
- # return the code of tile for conf file
- self.code = os.path.split(self.hdfname)[1].split('.')[-2]
- self.path = os.path.split(self.hdfname)[0]
- ## lists of parameters accepted by resample MRT software
- # projections
- self.proj_list = ('GEO', 'HAM', 'IGH', 'ISIN', 'LA', 'LCC', 'MOL', 'PS',
- 'SIN','TM', 'UTM', 'MERCAT')
- # resampling
- self.resam_list = ('NEAREST_NEIGHBOR', 'BILINEAR', 'CUBIC_CONVOLUTION')
- self.resam_list_swath = ('NN', 'BI', 'CC')
- # datum
- self.datum_list = ('NONE', 'NAD27', 'NAD83', 'WGS66', 'WGS72', 'WGS84', 'NoDatum')
- self.sphere_list = (1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20)
- def __str__(self):
- """Print the file without xml tags"""
- retString = ""
- try:
- for node in self.tree.iter():
- if node.text.strip() != '':
- retString = "%s = %s\n" % (node.tag,node.text)
- except:
- for node in self.tree.getiterator():
- return retString
- def _getRoot(self):
- """Set the root element"""
- self.rootree = self.tree.getroot()
- def retDTD(self):
- """Return the DTDVersion element"""
- self._getRoot()
- return self.rootree.find('DTDVersion').text
- def retDataCenter(self):
- """Return the DataCenterId element"""
- self._getRoot()
- return self.rootree.find('DataCenterId').text
- def _getGranule(self):
- """Set the GranuleURMetaData element"""
- self._getRoot()
- self.granule = self.rootree.find('GranuleURMetaData')
- def retGranuleUR(self):
- """Return the GranuleUR element"""
- self._getGranule()
- return self.granule.find('GranuleUR').text
- def retDbID(self):
- """Return the DbID element"""
- return self.granule.find('DbID').text
- def retInsertTime(self):
- return self.granule.find('InsertTime').text
- def retLastUpdate(self):
- return self.granule.find('LastUpdate').text
- def retCollectionMetaData(self):
- """Return the CollectionMetaData element"""
- collect = {}
- for i in self.granule.find('CollectionMetaData').getiterator():
- if i.text.strip() != '':
- collect[i.tag] = i.text
- return collect
- def retDataFiles(self):
- """Return the DataFiles element"""
- collect = {}
- datafiles = self.granule.find('DataFiles')
- for i in datafiles.find('DataFileContainer').getiterator():
- return collect
- def retDataGranule(self):
- """Return the ECSDataGranule elements"""
- datagran = {}
- for i in self.granule.find('ECSDataGranule').getiterator():
- if i.text:
- datagran[i.tag] = i.text
- return datagran
- def retPGEVersion(self):
- """Return the PGEVersion element"""
- return self.granule.find('PGEVersionClass').find('PGEVersion').text
- def retRangeTime(self):
- """Return the RangeDateTime elements inside a dictionary with the element
- name like dictionary key
- rangeTime = {}
- for i in self.granule.find('RangeDateTime').getiterator():
- if i.text:
- rangeTime[i.tag] = i.text
- return rangeTime
- def retBoundary(self):
- """Return the maximum extent of the MODIS file inside a dictionary"""
- self.boundary = []
- lat = []
- lon = []
- spatialContainer = self.granule.find('SpatialDomainContainer')
- horizontal = spatialContainer.find('HorizontalSpatialDomainContainer')
- boundary = horizontal.find('GPolygon').find('Boundary')
- for i in boundary.findall('Point'):
- lo = float(i.find('PointLongitude').text)
- la = float(i.find('PointLatitude').text)
- lon.append(lo)
- lat.append(la)
- self.boundary.append({'lat': la, 'lon':lo})
- extent = {'min_lat':min(lat),'max_lat':max(lat),'min_lon':min(lon),
- 'max_lon':max(lon)}
- return extent
- def retMeasure(self,flag = True):
- """Return statistics inside a dictionary"""
- value = {}
- mes = self.granule.find('MeasuredParameter')
- mespc = mes.find('MeasuredParameterContainer')
- value['ParameterName'] = mespc.find('ParameterName').text
- meStat = mespc.find('QAStats')
- qastat = {}
- for i in meStat.getiterator():
- if i.tag != 'QAStats':
- qastat[i.tag] = i.text
- value['QAStats'] = qastat
- if flag:
- meFlag = mespc.find('QAFlags')
- flagstat = {}
- for i in meFlag.getiterator():
- if i.tag != 'QAFlags':
- flagstat[i.tag] = i.text
- value['QAFlags'] = flagstat
- return value
- def retPlatform(self):
- """Return the platform values inside a dictionary."""
- value = {}
- plat = self.granule.find('Platform')
- value['PlatformShortName'] = plat.find('PlatformShortName').text
- instr = plat.find('Instrument')
- value['InstrumentShortName'] = instr.find('InstrumentShortName').text
- sensor = instr.find('Sensor')
- value['SensorShortName'] = sensor.find('SensorShortName').text
- return value
- def retPSA(self):
- """Return the PSA values inside a dictionary, the PSAName is the key and
- and PSAValue is the value
- value = {}
- psas = self.granule.find('PSAs')
- for i in psas.findall('PSA'):
- value[i.find('PSAName').text] = i.find('PSAValue').text
- return value
- def retInputGranule(self):
- """Return the input files used to process the considered file"""
- value = []
- for i in self.granule.find('InputGranule').getiterator():
- if i.tag != 'InputGranule':
- value.append(i.text)
- return value
- def retBrowseProduct(self):
- return self.granule.find('BrowseProduct').find('BrowseGranuleId').text
- def metastring(self):
- """Return a string with some metadata. The output it's used on GRASS GIS
- to set the metadata with r.support command
- date = self.retRangeTime()
- qa = self.retMeasure(False)
- pge = self.retPGEVersion()
- daynight = self.retDataGranule()
- stri = "Date:%s;BeginningTime:%s;EndingTime:%s;DayNightFlag:%s;"
- stri += "QAPercentCloudCover:%s;QAPercentMissingData:%s;PGEVersion:%s"
- out = stri % ( date['RangeBeginningDate'], date['RangeBeginningTime'],
- date['RangeEndingTime'], daynight['DayNightFlag'],
- qa['QAStats']['QAPercentCloudCover'],
- qa['QAStats']['QAPercentMissingData'], pge)
- return out
- def confResample(self, spectral, res = None, output = None, datum = 'WGS84',
- resampl = 'NEAREST_NEIGHBOR', projtype = 'GEO', utm = None,
- projpar = '( 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 )',
- """Create the parameter file to use with resample MRT software to create
- tif file
- spectral = the spectral subset to use, look the product table to
- understand the layer that you want use.
- For example:
- - NDVI ( 1 1 1 0 0 0 0 0 0 0 0 0) copy only layer NDVI, EVI
- and QA VI the other layers are not used
- - LST ( 1 1 0 0 1 1 0 0 0 0 0 0 ) copy only layer daily and
- nightly temperature and QA
- res = the resolution for the output file, it must be set in the map
- unit of output projection system. The software will use the original
- resolution of input file if res it isn't set
- output = the output name, if it doesn't set will use the prefix name of
- input hdf file
- utm = the UTM zone if projection system is UTM
- resampl = the type of resampling, the valid values are: NN (nearest
- neighbor), BI (bilinear), CC (cubic convolution)
- projtype = the output projection system, the valid values are: AEA
- (Albers Equal Area), ER (Equirectangular), GEO (Geographic
- Latitude/Longitude), HAM (Hammer), ISIN (Integerized Sinusoidal),
- IGH (Interrupted Goode Homolosine), LA (Lambert Azimuthal Equal Area),
- LCC (LambertConformal Conic), MERCAT (Mercator), MOL (Mollweide),
- PS (Polar Stereographic), SIN ()Sinusoidal), UTM (Universal
- TransverseMercator)
- datum = the datum to use, the valid values are: NAD27, NAD83, WGS66,
- WGS76, WGS84, NONE
- projpar = a list of projection parameters
- # output name
- if not output:
- fileout = self.tifname
- else:
- if output.find('.tif') == -1:
- fileout = os.path.join(self.path, output + '.tif')
- else:
- fileout = os.path.join(self.path, output)
- # the name of the output parameters files for resample MRT software
- filename = os.path.join(self.path,'%s_mrt_resample.conf' % self.code)
- # if the file already exists it remove it
- os.remove(filename)
- # open the file
- conFile = open(filename, 'w')
- conFile.write("INPUT_FILENAME = %s\n" % self.hdfname)
- conFile.write("SPECTRAL_SUBSET = %s\n" % spectral)
- conFile.write("SPATIAL_SUBSET_TYPE = INPUT_LAT_LONG\n")
- # return the boundary from the input xml file
- bound = self.retBoundary()
- # Order: UL: N W - LR: S E
- conFile.write("SPATIAL_SUBSET_UL_CORNER = ( %f %f )\n" % (bound['max_lat'],
- bound['min_lon']))
- conFile.write("SPATIAL_SUBSET_LR_CORNER = ( %f %f )\n" % (bound['min_lat'],
- bound['max_lon']))
- conFile.write("OUTPUT_FILENAME = %s\n" % fileout)
- # if resampl is in resam_list set the parameter otherwise return an error
- if resampl in self.resam_list:
- conFile.write("RESAMPLING_TYPE = %s\n" % resampl)
- else:
- raise IOError('The resampling type %s is not supported.\n' \
- 'The resampling type supported are %s' % (resampl,resam_list))
- # if projtype is in proj_list set the parameter otherwise return an error
- if projtype in self.proj_list:
- conFile.write("OUTPUT_PROJECTION_TYPE = %s\n" % projtype)
- else:
- raise IOError('The projection type %s is not supported.\n' \
- 'The projections supported are %s' % (projtype,proj_list))
- conFile.write("OUTPUT_PROJECTION_PARAMETERS = %s\n" % projpar)
- # if datum is in datum_list set the parameter otherwise return an error
- if datum in self.datum_list:
- conFile.write("DATUM = %s\n" % datum)
- else:
- raise IOError('The datum %s is not supported.\n' \
- 'The datum supported are %s' % (datum,datum_list))
- # if utm is not None write the UTM_ZONE parameter in the file
- if utm:
- conFile.write("UTM_ZONE = %s\n" % utm)
- # if res is not None write the OUTPUT_PIXEL_SIZE parameter in the file
- if res:
- conFile.write("OUTPUT_PIXEL_SIZE = %i\n" % res)
- conFile.close()
- return filename
- def confResample_swath(self, sds, geoloc, res, output = None,
- sphere = '8', resampl = 'NN', projtype = 'GEO', utm = None,
- projpar = '0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0',
- tif file
- sds = Name of band/s (Science Data Set) to resample
- geoloc = Name geolocation file (example MOD3, MYD3)
- input hdf file
- sphere = Output sphere number. Valid options are:
- 0=Clarke 1866, 1=Clarke 1880, 2=Bessel, 3=International 1967,
- 4=International 1909, 5=WGS 72, 6=Everest, 7=WGS 66,
- 8=GRS1980/WGS 84, 9=Airy, 10=Modified Everest, 11=Modified Airy,
- 12=Walbeck, 13=Southeast Asia, 14=Australian National,
- 15=Krassovsky, 16=Hough, 17=Mercury1960, 18=Modified Mercury1968,
- 19=Sphere 19 (Radius 6370997), 20=MODIS Sphere (Radius 6371007.181)
- AEA (Albers Equal Area), ER (Equirectangular),
- GEO (Geographic Latitude/Longitude), HAM (Hammer),
- ISIN (Integerized Sinusoidal),IGH (Interrupted Goode Homolosine),
- LA (Lambert Azimuthal Equal Area), LCC (LambertConformal Conic),
- MERCAT (Mercator), MOL (Mollweide), PS (Polar Stereographic),
- SIN ()Sinusoidal), UTM (Universal TransverseMercator)
- # output name
- if not output:
- else:
- fileout = output
- filename = os.path.join(self.path,'%s_mrt_resample.prm' % self.code)
- # open the file
- conFile.write("GEOLOCATION_FILENAME = %s\n" % geoloc)
- conFile.write("INPUT_SDS_NAME = %s\n" % sds)
- conFile.write("OUTPUT_SPATIAL_SUBSET_TYPE = LAT_LONG\n")
- conFile.write("OUTPUT_SPACE_UPPER_LEFT_CORNER (LONG LAT) = %f %f\n" % (bound['max_lat'],
- conFile.write("OUTPUT_SPACE_LOWER_RIGHT_CORNER (LONG LAT) = %f %f\n" % (bound['min_lat'],
- conFile.write("OUTPUT_FILE_FORMAT = GEOTIFF_FMT\n")
- if resampl in self.resam_list_swath:
- conFile.write("KERNEL_TYPE (CC/BI/NN) = %s\n" % resampl)
- else:
- raise IOError('The resampling type %s is not supportet.\n' \
- 'The resampling type supported are %s' % (resampl,self.resam_list_swath))
- conFile.write("OUTPUT_PROJECTION_NUMBER = %s\n" % projtype)
- else:
- conFile.write("OUTPUT_PROJECTION_PARAMETER = %s\n" % projpar)
- # if sphere is in sphere_list set the parameter otherwise return an error
- if int(sphere) in self.sphere_list:
- conFile.write("OUTPUT_PROJECTION_SPHERE = %s\n" % sphere)
- else:
- raise IOError('The sphere %s is not supported.\n' \
- 'The spheres supported are %s' % (sphere,self.sphere_list))
- if utm:
- if utm < '-60' or utm > '60':
- raise IOError('The valid UTM zone are -60 to 60')
- else:
- conFile.write("OUTPUT_PROJECTION_ZONE = %s\n" % utm)
- if res:
- conFile.write("OUTPUT_PIXEL_SIZE = %f\n" % res)
- conFile.close()
- return filename
-class parseModisMulti:
- """A class to some variable for the xml file of a mosaic
- def __init__(self,hdflist):
- self.ElementTree = ElementTree
- self.hdflist = hdflist
- self.parModis = []
- self.nfiles = 0
- for i in hdflist:
- self.parModis.append(parseModis(i))
- self.nfiles += 1
- def _retValues(self, funct):
- values = []
- for i in self.parModis:
- values.append(getattr(i,funct)())
- return values
- def _checkval(self, vals, one=False, key = None):
- """Internal function to return the different values from a list"""
- if vals.count(vals[0]) == self.nfiles:
- return [vals[0]]
- if vals.count(vals[0]) != self.nfiles and one == True:
- raise IOError('Something strange reading XML files, %s parameters have ' \
- 'different values' % key)
- else:
- outvals = []
- for i in vals:
- if outvals.count(i) == 0:
- outvals.append(i)
- return outvals
- def _checkvaldict(self,vals):
- """Internal function to return the different values from a dict"""
- keys = vals[0].keys()
- outvals = {}
- for k in keys:
- valtemp = []
- for v in vals:
- valtemp.append(v[k])
- if valtemp.count(valtemp[0]) == self.nfiles:
- outvals[k] = valtemp[0]
- else:
- if string.count(k,'Ending') != -1 or string.count(k,'End') != -1:
- outvals[k] = self._maxval(valtemp)
- elif string.count(k,'Beginning') != -1 or string.count(k,'Start') != -1:
- outvals[k] = self._minval(valtemp)
- else:
- raise IOError('Something wrong reading XML files')
- return outvals
- def _minval(self, vals):
- """Internal function to return the minimun value"""
- outval = vals[0]
- for i in range(1,len(vals)):
- if outval > vals[i]:
- outval = vals[i]
- return outval
- def _maxval(self, vals):
- """Internal function to return the maximum value"""
- outval = vals[0]
- if outval < vals[i]:
- outval = vals[i]
- return outval
- def _meanval(self,vals):
- """Internal function to return the mean value"""
- out = 0
- for v in vals:
- out += float(v)
- return out/len(vals)
- def _cicle_values(self, ele,values):
- """Function to add values from a dictionary"""
- for k,v in values.iteritems():
- elem = self.ElementTree.SubElement(ele,k)
- elem.text = v
- def _moreValues(self, obj, fun, ele):
- """Funtion to add elemets to the xml from a list"""
- values = self._retValues(fun)
- for i in self._checkval(values):
- dtd = self.ElementTree.SubElement(obj,ele)
- dtd.text = i
- def _moreValuesCicle(self, obj, fun):
- """Funtion to add elemets to the xml from a dict"""
- self._cicle_values(obj,self._checkvaldict(values))
- def _valInsertTime(self, obj):
- """Function to add InsertTime value"""
- values = self._retValues('retInsertTime')
- time = self.ElementTree.SubElement(obj,'InsertTime')
- minimum = self._minval(values)
- time.text = minimum
- def _valLastUpdate(self, obj):
- values = self._retValues('retLastUpdate')
- time = self.ElementTree.SubElement(obj,'LastUpdate')
- minimum = self._maxval(values)
- def _valDataFiles(self, obj):
- """Function to add DataFileContainer values"""
- values = self._retValues('retDataFiles')
- for i in values:
- dfc = self.ElementTree.SubElement(obj, 'DataFileContainer')
- self._cicle_values(dfc,i)
- def _valECSDataGranule(self, obj):
- values = {}
- # add all keys
- keys = self.parModis[0].retDataGranule().keys()
- for i in keys:
- values[i] = []
- # for each key create a list of values
- for k,v in i.retDataGranule().iteritems():
- values[k].append(v)
- elem = self.ElementTree.SubElement(obj,'SizeMBECSDataGranule')
- elem.text = str(self._meanval(values['SizeMBECSDataGranule']))
- for i in ['ReprocessingPlanned','ReprocessingActual','DayNightFlag','LocalVersionID']:
- elem = self.ElementTree.SubElement(obj,i)
- elem.text = self._checkval(values[i], True, i)[0]
- for k in ['LocalGranuleID', 'ProductionDateTime']:
- for i in values[k]:
- elem = self.ElementTree.SubElement(obj,k)
- elem.text = i
- def _valPGEVersion(self,obj):
- """Function to add PGEVersion values"""
- values = self._retValues('retPGEVersion')
- pge = self.ElementTree.SubElement(obj,'PGEVersion')
- pge.text = i
- def _valBound(self):
- """Return the maximun extent of mosaic"""
- boundary = self.parModis[0].retBoundary()
- for i in range(1,len(self.parModis)):
- bound = self.parModis[i].retBoundary()
- if bound['min_lat'] < boundary['min_lat']:
- boundary['min_lat'] = bound['min_lat']
- if bound['min_lon'] < boundary['min_lon']:
- boundary['min_lon'] = bound['min_lon']
- if bound['max_lat'] > boundary['max_lat']:
- boundary['max_lat'] = bound['max_lat']
- if bound['max_lon'] > boundary['max_lon']:
- boundary['max_lon'] = bound['max_lon']
- self.boundary = boundary
- def _addPoint(self,obj,lon,lat):
- """Function to add a single point of maximum extent"""
- pt = self.ElementTree.SubElement(obj, 'Point')
- ptlon = self.ElementTree.SubElement(pt, 'PointLongitude')
- ptlon.text = str(self.boundary[lon])
- ptlat = self.ElementTree.SubElement(pt, 'PointLatitude')
- ptlat.text = str(self.boundary[lat])
- def _valMeasuredParameter(self,obj):
- """Function to add MeasuredParameter values"""
- valuesQAStats = {}
- valuesQAFlags = {}
- valuesParameter = []
- keysQAStats = self.parModis[0].retMeasure()['QAStats'].keys()
- for i in keysQAStats:
- valuesQAStats[i] = []
- keysQAFlags = self.parModis[0].retMeasure()['QAFlags'].keys()
- for i in keysQAFlags:
- valuesQAFlags[i] = []
- for k,v in i.retMeasure()['QAStats'].iteritems():
- valuesQAStats[k].append(v)
- for k,v in i.retMeasure()['QAFlags'].iteritems():
- valuesQAFlags[k].append(v)
- valuesParameter.append(i.retMeasure()['ParameterName'])
- for i in self._checkval(valuesParameter):
- pn = self.ElementTree.SubElement(obj,'ParameterName')
- pn.text = i
- qstats = self.ElementTree.SubElement(obj,'QAStats')
- for k, v in valuesQAStats.iteritems():
- qstat = self.ElementTree.SubElement(qstats,k)
- qstat.text = str(self._meanval(v))
- def _valInputPointer(self,obj):
- """Function to add InputPointer values"""
- for v in i.retInputGranule():
- ip = self.ElementTree.SubElement(obj,'InputPointer')
- ip.text = v
- def _valPlatform(self, obj):
- """Function to add Platform values"""
- valuesSName = []
- valuesInstr = []
- valuesSensor = []
- valuesSName.append(i.retPlatform()['PlatformShortName'])
- valuesInstr.append(i.retPlatform()['InstrumentShortName'])
- valuesSensor.append(i.retPlatform()['SensorShortName'])
- for i in self._checkval(valuesSName):
- pn = self.ElementTree.SubElement(obj,'PlatformShortName')
- pn.text = i
- valInstr = self._checkval(valuesInstr)
- valSens = self._checkval(valuesSensor)
- if len(valInstr) != len(valSens):
- else:
- for i in range(len(valInstr)):
- ins = self.ElementTree.SubElement(obj,'Instrument')
- pn = self.ElementTree.SubElement(ins,'InstrumentShortName')
- pn.text = valInstr[i]
- sens = self.ElementTree.SubElement(ins,'Sensor')
- ps = self.ElementTree.SubElement(sens,'SensorShortName')
- ps.text = valSens[i]
- def _valPSA(self, obj):
- """Function to add PSA values"""
- values = {}
- # add all keys
- keys = self.parModis[0].retPSA().keys()
- for i in keys:
- values[i] = []
- for k,v in i.retPSA().iteritems():
- # these values could be different so they must be added all
- valApp = ['TileID','HORIZONTALTILENUMBER','VERTICALTILENUMBER']
- for v in valApp:
- for i in values[v]:
- psa = self.ElementTree.SubElement(obj,'PSA')
- psaname = self.ElementTree.SubElement(psa, 'PSAName')
- psaname.text = v
- psavalue = self.ElementTree.SubElement(psa, 'PSAValue')
- psavalue.text = i
- # add CLOUD_CONTAMINATED_LST_SCREENED, if one of values is NO set NO otherwise YES
- try:
- psaname.text = 'CLOUD_CONTAMINATED_LST_SCREENED'
- if values['CLOUD_CONTAMINATED_LST_SCREENED'].count('NO') == 0:
- psavalue.text = 'NO'
- else:
- psavalue.text = 'YES'
- except:
- pass
- # for these values calculate the mean value
- valMean = ['QAFRACTIONGOODQUALITY', 'QAPERCENTNOTPRODUCEDOTHER', 'N_GRAN_POINTERS',
- 'QAFRACTIONNOTPRODUCEDCLOUD','QAPERCENTOTHERQUALITY','QAFRACTIONNOTPRODUCEDOTHER',
- 'QAPERCENTNOTPRODUCEDCLOUD','QAFRACTIONOTHERQUALITY','QAPERCENTGOODQUALITY']
- for v in valMean:
- if v in values.keys():
- psaname.text = v
- psavalue.text = str(self._meanval(values[v]))
- def writexml(self,outputname):
- """Return a xml file for a mosaic"""
- # the root element
- granule = self.ElementTree.Element('GranuleMetaDataFile')
- # add DTDVersion
- self._moreValues(granule, 'retDTD', 'DTDVersion')
- # add DataCenterId
- self._moreValues(granule, 'retDataCenter', 'DataCenterId')
- # add GranuleURMetaData
- gurmd = self.ElementTree.SubElement(granule,'GranuleURMetaData')
- # add GranuleUR
- self._moreValues(granule, 'retGranuleUR', 'GranuleUR')
- # add dbID
- self._moreValues(granule, 'retDbID', 'DbID')
- self._valInsertTime(granule)
- self._valLastUpdate(granule)
- # CHECK InsertTime LastUpdate
- # add CollectionMetaData
- cmd = self.ElementTree.SubElement(gurmd,'CollectionMetaData')
- self._moreValuesCicle(cmd,'retCollectionMetaData')
- # add DataFiles
- df = self.ElementTree.SubElement(gurmd,'DataFiles')
- self._valDataFiles(df)
- # add ECSDataGranule
- ecs = self.ElementTree.SubElement(gurmd,'ECSDataGranule')
- self._valECSDataGranule(ecs)
- # add PGEVersionClass
- pgevc = self.ElementTree.SubElement(gurmd,'PGEVersionClass')
- self._valPGEVersion(pgevc)
- # add RangeDateTime
- rdt = self.ElementTree.SubElement(gurmd,'RangeDateTime')
- self._moreValuesCicle(rdt,'retRangeTime')
- # SpatialDomainContainer
- sdc = self.ElementTree.SubElement(gurmd,'SpatialDomainContainer')
- hsdc = self.ElementTree.SubElement(sdc,'HorizontalSpatialDomainContainer')
- gp = self.ElementTree.SubElement(hsdc,'GPolygon')
- bound = self.ElementTree.SubElement(gp,'Boundary')
- self._valBound()
- self._addPoint(bound,'min_lon','max_lat')
- self._addPoint(bound,'max_lon','max_lat')
- self._addPoint(bound,'min_lon','min_lat')
- self._addPoint(bound,'max_lon','min_lat')
- # add MeasuredParameter
- mp = self.ElementTree.SubElement(gurmd,'MeasuredParameter')
- mpc = self.ElementTree.SubElement(mp,'MeasuredParameterContainer')
- self._valMeasuredParameter(mpc)
- # TODO ADD qflags
- # Platform
- pl = self.ElementTree.SubElement(gurmd,'Platform')
- self._valPlatform(pl)
- # add PSAs
- psas = self.ElementTree.SubElement(gurmd,'PSAs')
- self._valPSA(psas)
- # add InputGranule and InputPointer
- ig = self.ElementTree.SubElement(gurmd,'InputGranule')
- self._valInputPointer(ig)
- # add BrowseProduct
- bp = self.ElementTree.SubElement(gurmd,'BrowseProduct')
- self._moreValues(bp, 'retBrowseProduct', 'BrowseGranuleId')
- # write output file
- output = open(outputname, 'w')
- output.write('<?xml version="1.0" encoding="UTF-8"?>')
- output.write('<!DOCTYPE GranuleMetaDataFile SYSTEM "http://ecsinfo.gsfc.nasa.gov/ECSInfo/ecsmetadata/dtds/DPL/ECS/ScienceGranuleMetadata.dtd">')
- output.write(self.ElementTree.tostring(granule))
- output.close()
-class convertModis:
- """A class to convert modis data from hdf to tif using resample (from MRT tools)
- def __init__(self, hdfname, confile, mrtpath):
- hdfname = the full path to the hdf file
- confile = the full path to the paramater file
- mrtpath = the full path to mrt directory where inside you have bin and
- data directories
- # check if the hdf file exists
- if os.path.exists(hdfname):
- self.name = hdfname
- else:
- raise IOError('%s not exists' % hdfname)
- # check if confile exists
- if os.path.exists(confile):
- self.conf = confile
- else:
- raise IOError('%s not exists' % confile)
- # check if mrtpath and subdirectories exists and set environment variables
- if os.path.exists(mrtpath):
- if os.path.exists(os.path.join(mrtpath,'bin')):
- self.mrtpathbin = os.path.join(mrtpath,'bin')
- os.environ['PATH'] = "%s:%s" % (os.environ['PATH'],os.path.join(mrtpath,
- 'data'))
- else:
- raise IOError('The path %s not exists' % os.path.join(mrtpath,'bin'))
- if os.path.exists(os.path.join(mrtpath,'data')):
- self.mrtpathdata = os.path.join(mrtpath,'data')
- os.environ['MRTDATADIR'] = os.path.join(mrtpath,'data')
- else:
- raise IOError('The path %s not exists' % os.path.join(mrtpath,'data'))
- else:
- raise IOError('The path %s not exists' % mrtpath)
- def _executable(self):
- """Return the executable of resample MRT software
- if sys.platform.count('linux') != -1:
- if os.path.exists(os.path.join(self.mrtpathbin,'resample')):
- return os.path.join(self.mrtpathbin,'resample')
- elif sys.platform.count('win32') != -1:
- if os.path.exists(os.path.join(self.mrtpathbin,'resample.exe')):
- return os.path.join(self.mrtpath,'resample.exe')
- def run(self):
- """Exec the process"""
- import subprocess
- execut = self._executable()
- if not os.path.exists(execut):
- raise IOError('The path %s not exists, could be an erroneus path or '\
- + 'software') % execut
- else:
- subprocess.call([execut,'-p',self.conf])
- return "The hdf file %s was converted" % self.name
-class createMosaic:
- """A class to convert a mosaic of different modis tiles"""
- listfile,
- outprefix,
- mrtpath,
- subset = False
- if os.path.exists(listfile):
- self.basepath = os.path.split(listfile)[0]
- self.listfiles = listfile
- self.HDFfiles = open(listfile).readlines()
- else:
- 'data'))
- else:
- else:
- else:
- self.out = os.path.join(self.basepath, outprefix + '.hdf')
- self.outxml = os.path.join(self.basepath, self.out + '.xml')
- self.subset = subset
- def _write_mosaic_xml(self):
- self.finalfile = open(os.path.join(self.basepath,'mosaic%i' % os.getpid()),'w')
- listHDF = []
- for i in self.HDFfiles:
- if i.find(self.basepath) == -1:
- print "Attection maybe you are not using full path in the HDF file list"
- listHDF.append(os.path.join(self.basepath,i.strip()))
- self.finalfile.write("%s\n" % os.path.join(self.basepath,i.strip()))
- else:
- listHDF.append(i.strip())
- self.finalfile.write("%s\n" % i.strip())
- self.finalfile.close()
- pmm = parseModisMulti(listHDF)
- pmm.writexml(self.outxml)
- """Return the executable of mrtmosaic MRT software
- if os.path.exists(os.path.join(self.mrtpathbin,'mrtmosaic')):
- return os.path.join(self.mrtpathbin,'mrtmosaic')
- if os.path.exists(os.path.join(self.mrtpathbin,'mrtmosaic.exe')):
- return os.path.join(self.mrtpath,'mrtmosaic.exe')
- def run(self):
- """Exect the mosaic process"""
- import subprocess
- else:
- self._write_mosaic_xml()
- if self.subset:
- subprocess.call([execut,'-i',self.finalfile.name,'-o',self.out,'-s',self.subset],
- stderr = subprocess.STDOUT)
- else:
- subprocess.call([execut,'-i',self.finalfile.name,'-o',self.out], stderr =
- subprocess.STDOUT)
- #os.remove(self.finalfile)
- return "The mosaic file %s is created" % self.out
-class processModis:
- """A class to process raw modis data from hdf to tif using swath2grid (from MRT Swath tools)
- hdfname, confile, mrtpath,
- inputhdf = None, outputhdf = None, geolocfile = None
- data directories
- else:
- else:
- 'data'))
- else:
- else:
- else:
- if os.path.exists(os.path.join(self.mrtpathbin,'swath2grid')):
- return os.path.join(self.mrtpathbin,'swath2grid')
- if os.path.exists(os.path.join(self.mrtpathbin,'swath2grid.exe')):
- return os.path.join(self.mrtpath,'swath2grid.exe')
- def run(self):
- import subprocess
- else:
- subprocess.call([execut,'-pf=%s' % self.conf])
Added: grass-addons/grass7/raster/r.modis/libmodis/parsemodis.py
--- grass-addons/grass7/raster/r.modis/libmodis/parsemodis.py (rev 0)
+++ grass-addons/grass7/raster/r.modis/libmodis/parsemodis.py 2012-05-24 08:38:08 UTC (rev 51690)
@@ -0,0 +1,699 @@
+# class to parse modis data
+import string
+import os
+import sys
+import glob
+import logging
+import socket
+import ftplib
+## lists of parameters accepted by resample MRT software
+# projections
+PROJ_LIST = ['AEA','GEO', 'HAM', 'IGH', 'ISIN', 'LA', 'LCC', 'MOL', 'PS',
+ 'SIN','TM', 'UTM', 'MERCAT']
+# resampling
+RESAM_LIST = ['NEAREST_NEIGHBOR', 'BICUBIC', 'CUBIC_CONVOLUTION', 'NONE']
+RESAM_LIST_SWATH = ['NN', 'BI', 'CC']
+# datum
+DATUM_LIST = ['NODATUM', 'NAD27', 'NAD83', 'WGS66', 'WGS72', 'WGS84']
+SPHERE_LIST = [1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20]
+class parseModis:
+ """Class to parse MODIS xml files, it also can create the parameter
+ configuration file for resampling with the MRT software
+ def __init__(self, filename):
+ filename = the name of MODIS hdf file
+ from xml.etree import ElementTree
+ if os.path.exists(filename):
+ # hdf name
+ self.hdfname = filename
+ else:
+ raise IOError('%s not exists' % self.hdfname)
+ if os.path.exists(self.hdfname + '.xml'):
+ # xml hdf name
+ self.xmlname = self.hdfname + '.xml'
+ else:
+ raise IOError('%s not exists' % self.hdfname + '.xml')
+ # tif name for the output file for resample MRT software
+ self.tifname = self.hdfname.replace('.hdf','.tif')
+ with open(self.xmlname) as f:
+ self.tree = ElementTree.parse(f)
+ # return the code of tile for conf file
+ self.code = os.path.split(self.hdfname)[1].split('.')[-2]
+ self.path = os.path.split(self.hdfname)[0]
+ def __str__(self):
+ """Print the file without xml tags"""
+ retString = ""
+ try:
+ for node in self.tree.iter():
+ if node.text.strip() != '':
+ retString = "%s = %s\n" % (node.tag,node.text)
+ except:
+ for node in self.tree.getiterator():
+ return retString
+ def getRoot(self):
+ """Set the root element"""
+ self.rootree = self.tree.getroot()
+ def retDTD(self):
+ """Return the DTDVersion element"""
+ self.getRoot()
+ return self.rootree.find('DTDVersion').text
+ def retDataCenter(self):
+ """Return the DataCenterId element"""
+ self.getRoot()
+ return self.rootree.find('DataCenterId').text
+ def getGranule(self):
+ """Set the GranuleURMetaData element"""
+ self.getRoot()
+ self.granule = self.rootree.find('GranuleURMetaData')
+ def retGranuleUR(self):
+ """Return the GranuleUR element"""
+ self.getGranule()
+ return self.granule.find('GranuleUR').text
+ def retDbID(self):
+ """Return the DbID element"""
+ self.getGranule()
+ return self.granule.find('DbID').text
+ def retInsertTime(self):
+ self.getGranule()
+ return self.granule.find('InsertTime').text
+ def retLastUpdate(self):
+ self.getGranule()
+ return self.granule.find('LastUpdate').text
+ def retCollectionMetaData(self):
+ """Return the CollectionMetaData element"""
+ self.getGranule()
+ collect = {}
+ for i in self.granule.find('CollectionMetaData').getiterator():
+ if i.text.strip() != '':
+ collect[i.tag] = i.text
+ return collect
+ def retDataFiles(self):
+ """Return the DataFiles element"""
+ self.getGranule()
+ collect = {}
+ datafiles = self.granule.find('DataFiles')
+ for i in datafiles.find('DataFileContainer').getiterator():
+ return collect
+ def retDataGranule(self):
+ """Return the ECSDataGranule elements"""
+ self.getGranule()
+ datagran = {}
+ for i in self.granule.find('ECSDataGranule').getiterator():
+ datagran[i.tag] = i.text
+ return datagran
+ def retPGEVersion(self):
+ """Return the PGEVersion element"""
+ self.getGranule()
+ return self.granule.find('PGEVersionClass').find('PGEVersion').text
+ def retRangeTime(self):
+ """Return the RangeDateTime elements inside a dictionary with the element
+ name like dictionary key
+ self.getGranule()
+ rangeTime = {}
+ for i in self.granule.find('RangeDateTime').getiterator():
+ rangeTime[i.tag] = i.text
+ return rangeTime
+ def retBoundary(self):
+ """Return the maximum extend of the MODIS file inside a dictionary"""
+ self.getGranule()
+ self.boundary = []
+ lat = []
+ lon = []
+ spatialContainer = self.granule.find('SpatialDomainContainer')
+ horizontal = spatialContainer.find('HorizontalSpatialDomainContainer')
+ boundary = horizontal.find('GPolygon').find('Boundary')
+ for i in boundary.findall('Point'):
+ la = float(i.find('PointLongitude').text)
+ lo = float(i.find('PointLatitude').text)
+ lon.append(la)
+ lat.append(lo)
+ self.boundary.append({'lat': la, 'lon':lo})
+ extent = {'min_lat':min(lat),'max_lat':max(lat),'min_lon':min(lon),
+ 'max_lon':max(lon)}
+ return extent
+ def retMeasure(self):
+ """Return statistics inside a dictionary"""
+ value = {}
+ self.getGranule()
+ mes = self.granule.find('MeasuredParameter')
+ mespc = mes.find('MeasuredParameterContainer')
+ value['ParameterName'] = mespc.find('ParameterName').text
+ meStat = mespc.find('QAStats')
+ qastat = {}
+ for i in meStat.getiterator():
+ if i.tag != 'QAStats':
+ qastat[i.tag] = i.text
+ value['QAStats'] = qastat
+ meFlag = mespc.find('QAFlags')
+ flagstat = {}
+ for i in meFlag.getiterator():
+ if i.tag != 'QAFlags':
+ flagstat[i.tag] = i.text
+ value['QAFlags'] = flagstat
+ return value
+ def retPlatform(self):
+ """Return the platform values inside a dictionary."""
+ value = {}
+ self.getGranule()
+ plat = self.granule.find('Platform')
+ value['PlatformShortName'] = plat.find('PlatformShortName').text
+ instr = plat.find('Instrument')
+ value['InstrumentShortName'] = instr.find('InstrumentShortName').text
+ sensor = instr.find('Sensor')
+ value['SensorShortName'] = sensor.find('SensorShortName').text
+ return value
+ def retPSA(self):
+ """Return the PSA values inside a dictionary, the PSAName is he key and
+ and PSAValue is the value
+ value = {}
+ self.getGranule()
+ psas = self.granule.find('PSAs')
+ for i in psas.findall('PSA'):
+ value[i.find('PSAName').text] = i.find('PSAValue').text
+ return value
+ def retInputGranule(self):
+ """Return the input files used to process the considered file"""
+ value = []
+ self.getGranule()
+ for i in self.granule.find('InputGranule').getiterator():
+ if i.tag != 'InputGranule':
+ value.append(i.text)
+ return value
+ def retBrowseProduct(self):
+ self.getGranule()
+ try:
+ value = self.granule.find('BrowseProduct').find('BrowseGranuleId').text
+ except:
+ value = None
+ return value
+ def confResample(self, spectral, res = None, output = None, datum = 'WGS84',
+ resampl = 'NEAREST_NEIGHBOR', projtype = 'GEO', utm = None,
+ projpar = '( 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 )',
+ """Create the parameter file to use with resample MRT software to create
+ tif file
+ spectral = the spectral subset to use, look the product table to
+ understand the layer that you want use.
+ For example:
+ - NDVI ( 1 1 1 0 0 0 0 0 0 0 0 0) copy only layer NDVI, EVI
+ and QA VI the other layers are not used
+ - LST ( 1 1 0 0 1 1 0 0 0 0 0 0 ) copy only layer daily and
+ nightly temperature and QA
+ res = the resolution for the output file, it must be set in the map
+ unit of output projection system. The software will use the original
+ resolution of input file if res it isn't set
+ output = the output name, if it doesn't set will use the prefix name of
+ input hdf file
+ utm = the UTM zone if projection system is UTM
+ resampl = the type of resampling, the valid values are: NN (nearest
+ neighbor), BI (bilinear), CC (cubic convolution)
+ projtype = the output projection system, the valid values are: AEA
+ (Albers Equal Area), ER (Equirectangular), GEO (Geographic
+ Latitude/Longitude), HAM (Hammer), ISIN (Integerized Sinusoidal),
+ IGH (Interrupted Goode Homolosine), LA (Lambert Azimuthal),
+ LCC (LambertConformal Conic), MERCAT (Mercator), MOL (Mollweide),
+ PS (Polar Stereographic), SIN ()Sinusoidal), UTM (Universal
+ TransverseMercator)
+ datum = the datum to use, the valid values are: NAD27, NAD83, WGS66,
+ WGS76, WGS84, NODATUM
+ projpar = a list of projection parameters, for more info check the
+ "Appendix C" of MODIS reprojection tool user’s manual
+ https://lpdaac.usgs.gov/content/download/4831/22895/file/mrt41_usermanual_032811.pdf
+ #check if spectral it's write with correct construct ( value )
+ if string.find(spectral, '(') == -1 or string.find(spectral, ')') == -1:
+ raise IOError('ERROR: The spectral string should be similar to: ( 1 0 )')
+ # output name
+ if not output:
+ fileout = self.tifname
+ else:
+ fileout = output
+ # the name of the output parameters files for resample MRT software
+ filename = os.path.join(self.path,'%s_mrt_resample.conf' % self.code)
+ # if the file already exists it remove it
+ os.remove(filename)
+ # open the file
+ conFile = open(filename, 'w')
+ conFile.write("INPUT_FILENAME = %s\n" % self.hdfname)
+ conFile.write("SPECTRAL_SUBSET = %s\n" % spectral)
+ conFile.write("SPATIAL_SUBSET_TYPE = INPUT_LAT_LONG\n")
+ # return the boundary from the input xml file
+ bound = self.retBoundary()
+ # Order: UL: N W - LR: S E
+ conFile.write("SPATIAL_SUBSET_UL_CORNER = ( %f %f )\n" % (bound['max_lat'],
+ bound['min_lon']))
+ conFile.write("SPATIAL_SUBSET_LR_CORNER = ( %f %f )\n" % (bound['min_lat'],
+ bound['max_lon']))
+ conFile.write("OUTPUT_FILENAME = %s\n" % fileout)
+ # if resampl is in resam_list set the parameter otherwise return an error
+ if resampl in RESAM_LIST:
+ conFile.write("RESAMPLING_TYPE = %s\n" % resampl)
+ else:
+ raise IOError('The resampling type %s is not supportet.\n' \
+ 'The resampling type supported are %s' % (resampl,RESAM_LIST))
+ # if projtype is in proj_list set the parameter otherwise return an error
+ if projtype in PROJ_LIST:
+ conFile.write("OUTPUT_PROJECTION_TYPE = %s\n" % projtype)
+ else:
+ raise IOError('The projection type %s is not supported.\n' \
+ 'The projections supported are %s' % (projtype,PROJ_LIST))
+ conFile.write("OUTPUT_PROJECTION_PARAMETERS = %s\n" % projpar)
+ # if datum is in datum_list set the parameter otherwise return an error
+ if datum in DATUM_LIST:
+ conFile.write("DATUM = %s\n" % datum)
+ else:
+ raise IOError('The datum %s is not supported.\n' \
+ 'The datum supported are %s' % (datum,DATUM_LIST))
+ # if utm is not None write the UTM_ZONE parameter in the file
+ if utm:
+ conFile.write("UTM_ZONE = %s\n" % utm)
+ # if res is not None write the OUTPUT_PIXEL_SIZE parameter in the file
+ if res:
+ conFile.write("OUTPUT_PIXEL_SIZE = %i\n" % res)
+ conFile.close()
+ return filename
+ def confResample_swath(self, sds, geoloc, res, output = None,
+ sphere = '8', resampl = 'NN', projtype = 'GEO', utm = None,
+ projpar = '0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0',
+ tif file
+ sds = Name of band/s (Science Data Set) to resample
+ geoloc = Name geolocation file (example MOD3, MYD3)
+ input hdf file
+ sphere = Output sphere number. Valid options are:
+ 0=Clarke 1866, 1=Clarke 1880, 2=Bessel, 3=International 1967,
+ 4=International 1909, 5=WGS 72, 6=Everest, 7=WGS 66,
+ 8=GRS1980/WGS 84, 9=Airy, 10=Modified Everest, 11=Modified Airy,
+ 12=Walbeck, 13=Southeast Asia, 14=Australian National,
+ 15=Krassovsky, 16=Hough, 17=Mercury1960, 18=Modified Mercury1968,
+ 19=Sphere 19 (Radius 6370997), 20=MODIS Sphere (Radius 6371007.181)
+ AEA (Albers Equal Area), ER (Equirectangular),
+ GEO (Geographic Latitude/Longitude), HAM (Hammer),
+ ISIN (Integerized Sinusoidal),IGH (Interrupted Goode Homolosine),
+ LA (Lambert Azimuthal), LCC (LambertConformal Conic),
+ MERCAT (Mercator), MOL (Mollweide), PS (Polar Stereographic),
+ SIN ()Sinusoidal), UTM (Universal TransverseMercator)
+ # output name
+ if not output:
+ else:
+ fileout = output
+ filename = os.path.join(self.path,'%s_mrt_resample.prm' % self.code)
+ # open the file
+ conFile.write("GEOLOCATION_FILENAME = %s\n" % geoloc)
+ conFile.write("INPUT_SDS_NAME = %s\n" % sds)
+ conFile.write("OUTPUT_SPATIAL_SUBSET_TYPE = LAT_LONG\n")
+ conFile.write("OUTPUT_SPACE_UPPER_LEFT_CORNER (LONG LAT) = %f %f\n" % (bound['max_lat'],
+ conFile.write("OUTPUT_SPACE_LOWER_RIGHT_CORNER (LONG LAT) = %f %f\n" % (bound['min_lat'],
+ conFile.write("OUTPUT_FILE_FORMAT = GEOTIFF_FMT\n")
+ if resampl in RESAM_LIST_SWATH:
+ conFile.write("KERNEL_TYPE (CC/BI/NN) = %s\n" % resampl)
+ else:
+ 'The resampling type supported are %s' % (resampl,RESAM_LIST_SWATH))
+ conFile.write("OUTPUT_PROJECTION_NUMBER = %s\n" % projtype)
+ else:
+ conFile.write("OUTPUT_PROJECTION_PARAMETER = %s\n" % projpar)
+ # if sphere is in sphere_list set the parameter otherwise return an error
+ if int(sphere) in SPHERE_LIST:
+ conFile.write("OUTPUT_PROJECTION_SPHERE = %s\n" % sphere)
+ else:
+ raise IOError('The sphere %s is not supported.\n' \
+ 'The spheres supported are %s' % (sphere,SPHERE_LIST))
+ if utm:
+ if utm < '-60' or utm > '60':
+ raise IOError('The valid UTM zone are -60 to 60')
+ else:
+ conFile.write("OUTPUT_PROJECTION_ZONE = %s\n" % utm)
+ if res:
+ conFile.write("OUTPUT_PIXEL_SIZE = %f\n" % res)
+ conFile.close()
+ return filename
+class parseModisMulti:
+ """A class to some variable for the xml file of a mosaic
+ def __init__(self,hdflist):
+ """hdflist = python list containing the hdf files"""
+ self.ElementTree = ElementTree
+ self.hdflist = hdflist
+ self.parModis = []
+ self.nfiles = 0
+ # for each hdf files create a parseModis object
+ for i in hdflist:
+ self.parModis.append(parseModis(i))
+ self.nfiles += 1
+ def _checkval(self,vals):
+ """Internal function to return values from list"""
+ if vals.count(vals[0]) == self.nfiles:
+ return [vals[0]]
+ else:
+ outvals = []
+ for i in vals:
+ if outvals.count(i) == 0:
+ outvals.append(i)
+ return outvals
+ def _checkvaldict(self,vals):
+ """Internal function to return values from dictionary"""
+ keys = vals[0].keys()
+ outvals = {}
+ for k in keys:
+ valtemp = []
+ for v in vals:
+ valtemp.append(v[k])
+ if valtemp.count(valtemp[0]) == self.nfiles:
+ outvals[k] = valtemp[0]
+ else:
+ raise IOError('Something wrong reading XML files')
+ return outvals
+ def _minval(self, vals):
+ """Internal function to return the minimum value"""
+ outval = vals[0]
+ for i in range(1,len(vals)):
+ if outval > i:
+ outval = i
+ return outval
+ def _maxval(self, vals):
+ """Internal function to return the maximum value"""
+ outval = vals[0]
+ if outval < i:
+ outval = i
+ return outval
+ def _cicle_values(self, ele,values):
+ """Internal function to add values from a dictionary"""
+ for k,v in values.iteritems():
+ elem = self.ElementTree.SubElement(ele,k)
+ elem.text = v
+ def _addPoint(self,obj,lon,lat):
+ """Internal function to add a point in boundary xml tag"""
+ pt = self.ElementTree.SubElement(obj, 'Point')
+ ptlon = self.ElementTree.SubElement(pt, 'PointLongitude')
+ ptlon.text = str(self.boundary[lon])
+ ptlat = self.ElementTree.SubElement(pt, 'PointLatitude')
+ ptlat.text = str(self.boundary[lat])
+ def valDTD(self,obj):
+ """Function to add DTDVersion"""
+ values = []
+ for i in self.parModis:
+ values.append(i.retDTD())
+ for i in self._checkval(values):
+ dtd = self.ElementTree.SubElement(obj,'DTDVersion')
+ dtd.text = i
+ def valDataCenter(self,obj):
+ """Function to add DataCenter"""
+ values = []
+ values.append(i.retDataCenter())
+ dci = self.ElementTree.SubElement(obj,'DataCenterId')
+ dci.text = i
+ def valGranuleUR(self,obj):
+ """Function to add GranuleUR"""
+ values = []
+ values.append(i.retGranuleUR())
+ gur = self.ElementTree.SubElement(obj,'GranuleUR')
+ gur.text = i
+ def valDbID(self,obj):
+ """Function to add DbID"""
+ values = []
+ values.append(i.retDbID())
+ dbid = self.ElementTree.SubElement(obj,'DbID')
+ dbid.text = i
+ def valInsTime(self,obj):
+ """TODO"""
+ values = []
+ values.append(i.retInsertTime())
+ obj.text = self._minval(values)
+ def valCollectionMetaData(self,obj):
+ """Function to add CollectionMetaData"""
+ values = []
+ values.append(i.retCollectionMetaData())
+ self._cicle_values(obj,self._checkvaldict(values))
+ def valDataFiles(self, obj):
+ """Function to add DataFileContainer"""
+ values = []
+ values.append(i.retDataFiles())
+ for i in values:
+ dfc = self.ElementTree.SubElement(obj, 'DataFileContainer')
+ self._cicle_values(dfc,i)
+ def valPGEVersion(self,obj):
+ """Function to add PGEVersion"""
+ values = []
+ values.append(i.retPGEVersion())
+ pge = self.ElementTree.SubElement(obj,'PGEVersion')
+ pge.text = i
+ def valRangeTime(self,obj):
+ """Function to add RangeDateTime"""
+ values = []
+ values.append(i.retRangeTime())
+ def valBound(self):
+ """Function return the bounding box of mosaic"""
+ boundary = self.parModis[0].retBoundary()
+ for i in range(1,len(self.parModis)):
+ bound = self.parModis[i].retBoundary()
+ if bound['min_lat'] < boundary['min_lat']:
+ boundary['min_lat'] = bound['min_lat']
+ if bound['min_lon'] < boundary['min_lon']:
+ boundary['min_lon'] = bound['min_lon']
+ if bound['max_lat'] > boundary['max_lat']:
+ boundary['max_lat'] = bound['max_lat']
+ if bound['max_lon'] > boundary['max_lon']:
+ boundary['max_lon'] = bound['max_lon']
+ self.boundary = boundary
+ def valMeasuredParameter(self,obj):
+ """Function to add ParameterName"""
+ valuesQAStats = []
+ valuesQAFlags = []
+ valuesParameter = []
+ valuesQAStats.append(i.retMeasure()['QAStats'])
+ valuesQAFlags.append(i.retMeasure()['QAFlags'])
+ valuesParameter.append(i.retMeasure()['ParameterName'])
+ for i in self._checkval(valuesParameter):
+ pn = self.ElementTree.SubElement(obj,'ParameterName')
+ pn.text = i
+ def valInputPointer(self,obj):
+ """Function to add InputPointer"""
+ for v in i.retInputGranule():
+ ip = self.ElementTree.SubElement(obj,'InputPointer')
+ ip.text = v
+ def valPlatform(self, obj):
+ """Function to add Platform tags"""
+ valuesSName = []
+ valuesInstr = []
+ valuesSensor = []
+ valuesSName.append(i.retPlatform()['PlatformShortName'])
+ valuesInstr.append(i.retPlatform()['InstrumentShortName'])
+ valuesSensor.append(i.retPlatform()['SensorShortName'])
+ for i in self._checkval(valuesSName):
+ pn = self.ElementTree.SubElement(obj,'PlatformShortName')
+ pn.text = i
+ valInstr = self._checkval(valuesInstr)
+ valSens = self._checkval(valuesSensor)
+ if len(valInstr) != len(valSens):
+ else:
+ for i in range(len(valInstr)):
+ ins = self.ElementTree.SubElement(obj,'Instrument')
+ pn = self.ElementTree.SubElement(ins,'InstrumentShortName')
+ pn.text = valInstr[i]
+ sens = self.ElementTree.SubElement(ins,'Sensor')
+ ps = self.ElementTree.SubElement(sens,'SensorShortName')
+ ps.text = valSens[i]
+ def writexml(self,outputname):
+ """Return a xml file for a mosaic"""
+ # the root element
+ granule = self.ElementTree.Element('GranuleMetaDataFile')
+ # add DTDVersion
+ self.valDTD(granule)
+ # add DataCenterId
+ self.valDataCenter(granule)
+ # add GranuleURMetaData
+ gurmd = self.ElementTree.SubElement(granule,'GranuleURMetaData')
+ # add GranuleUR
+ self.valGranuleUR(gurmd)
+ # add dbID
+ self.valDbID(gurmd)
+ # TODO ADD InsertTime LastUpdate
+ # add CollectionMetaData
+ cmd = self.ElementTree.SubElement(gurmd,'CollectionMetaData')
+ self.valCollectionMetaData(cmd)
+ # add DataFiles
+ df = self.ElementTree.SubElement(gurmd,'DataFiles')
+ self.valDataFiles(df)
+ # TODO ADD ECSDataGranule
+ # add PGEVersionClass
+ pgevc = self.ElementTree.SubElement(gurmd,'PGEVersionClass')
+ self.valPGEVersion(pgevc)
+ # add RangeDateTime
+ rdt = self.ElementTree.SubElement(gurmd,'RangeDateTime')
+ self.valRangeTime(rdt)
+ # SpatialDomainContainer
+ sdc = self.ElementTree.SubElement(gurmd,'SpatialDomainContainer')
+ hsdc = self.ElementTree.SubElement(sdc,'HorizontalSpatialDomainContainer')
+ gp = self.ElementTree.SubElement(hsdc,'GPolygon')
+ bound = self.ElementTree.SubElement(gp,'Boundary')
+ self.valBound()
+ self._addPoint(bound,'min_lon','max_lat')
+ self._addPoint(bound,'max_lon','max_lat')
+ self._addPoint(bound,'min_lon','min_lat')
+ self._addPoint(bound,'max_lon','min_lat')
+ # add MeasuredParameter
+ mp = self.ElementTree.SubElement(gurmd,'MeasuredParameter')
+ mpc = self.ElementTree.SubElement(mp,'MeasuredParameterContainer')
+ self.valMeasuredParameter(mpc)
+ # Platform
+ pl = self.ElementTree.SubElement(gurmd,'Platform')
+ self.valPlatform(pl)
+ # add PSAs
+ psas = self.ElementTree.SubElement(gurmd,'PSAs')
+ # TODO ADD all PSA
+ # add InputGranule and InputPointer
+ ig = self.ElementTree.SubElement(gurmd,'InputGranule')
+ self.valInputPointer(ig)
+ # TODO ADD BrowseProduct
+ output = open(outputname, 'w')
+ output.write('<?xml version="1.0" encoding="UTF-8"?>')
+ output.write('<!DOCTYPE GranuleMetaDataFile SYSTEM "http://ecsinfo.gsfc.nasa.gov/ECSInfo/ecsmetadata/dtds/DPL/ECS/ScienceGranuleMetadata.dtd">')
+ output.write(self.ElementTree.tostring(granule))
+ output.close()
Modified: grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py
--- grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py 2012-05-24 08:32:08 UTC (rev 51689)
+++ grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py 2012-05-24 08:38:08 UTC (rev 51690)
@@ -83,18 +83,19 @@
# add the folder containing libraries to python path
if os.path.isdir(os.path.join(os.getenv('GISBASE'), 'etc', 'r.modis',os.sep)):
- libmodis = os.path.join(os.getenv('GISBASE'), 'etc', 'r.modis',os.sep)
+ libmodis = os.path.join(os.getenv('GISBASE'), 'etc', 'r.modis')
elif os.path.isdir(os.path.join(os.getenv('GRASS_ADDON_PATH'), 'etc', 'r.modis',os.sep)):
- libmodis = os.path.join(os.getenv('GRASS_ADDON_PATH'), 'etc', 'r.modis',os.sep)
+ libmodis = os.path.join(os.getenv('GRASS_ADDON_PATH'), 'etc', 'r.modis')
else:
print "ERROR: path to libraries not found"
sys.exit()
# try to import pymodis (modis) and some class for r.modis.download
+sys.path.append(libmodis)
try:
from rmodislib import product
- from modis import downModis
+ from downmodis import downModis
except ImportError:
- pass
+ grass.fatal(_("modis library not imported"))
def check(home):
""" Check if a folder it is writable by the user that launch the process
@@ -157,7 +158,7 @@
if options['folder'] != '':
if check(options['folder']):
fold = options['folder']
- user = raw_input(_('Insert username (usually anonymous): '))
+ user = 'anonymous'
passwd = raw_input(_('Insert password (your mail): '))
else:
grass.fatal(_("Set folder parameter when using stdin for passing the username " \
@@ -209,6 +210,7 @@
for produ in products:
prod = product(produ).returned()
#start modis class
modisOgg = downModis(url = prod['url'], user = user,password = passwd,
destinationFolder = fold, tiles = tiles, path = prod['folder'],
today = firstday, enddate = finalday, delta = delta, debug = debug_opt)
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2012-05-24 08:32:08 UTC (rev 51689)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2012-05-24 08:38:08 UTC (rev 51690)
@@ -94,9 +94,9 @@
else:
sys.exit()
@@ -105,9 +105,10 @@
# try to import pymodis (modis) and some classes for r.modis.download
try:
from rmodislib import resampling, product, get_proj, projection
- from modis import parseModis, convertModis, createMosaic
+ from convermodis import convertModis, createMosaic
+ from parsemodis import parseModis
except ImportError:
- pass
def list_files(opt, mosaik = False):
"""If used in function single(): Return a list of HDF files from the file list
