[GRASS-SVN] r51700 - grass-addons/grass7/raster/r.in.wms2
svn_grass at osgeo.org
Thu May 24 06:56:36 EDT 2012
Author: turek
Date: 2012-05-24 03:56:36 -0700 (Thu, 24 May 2012)
New Revision: 51700
grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html
grass-addons/grass7/raster/r.in.wms2/wms_base.py
grass-addons/grass7/raster/r.in.wms2/wms_drv.py
grass-addons/grass7/raster/r.in.wms2/wms_gdal_drv.py
Improved support of WMS 1.3.0 (flip of geograph. coords) Added examples into manual.
Modified: grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html
--- grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html 2012-05-24 10:44:38 UTC (rev 51699)
+++ grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html 2012-05-24 10:56:36 UTC (rev 51700)
@@ -30,14 +30,31 @@
<h3>CUZK download</h3>
+World extend data:
<div class="code"><pre>
+r.in.wms2 mapserver=http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms layers=bluemarble,landsat_1_01 styles=default,default output=landsat srs=4326 format=png
+</pre></div>
+* Server supports only WMS 1.1.1 <br>
+<div class="code"><pre>
+r.in.wms2 mapserver=http://132.156.97.59/cgi-bin/worldmin_en-ca_ows layers=GSC:WORLD_PrecambrianDomains output=pokus srs=4326 format=jpeg
+</pre></div>
+<br>
+<br>
+Data in extend of Czech Republic:
r.in.wms2 output=kn mapserver=http://wms.cuzk.cz/wms.asp layers=prehledka_kraju-linie srs=4326 format=png
</pre></div>
<h2>TODO</h2>
<ul>
- <li>Add more examples...</li>
<li>Implement Tiled WMS</li>
</ul>
Modified: grass-addons/grass7/raster/r.in.wms2/wms_base.py
--- grass-addons/grass7/raster/r.in.wms2/wms_base.py 2012-05-24 10:44:38 UTC (rev 51699)
+++ grass-addons/grass7/raster/r.in.wms2/wms_base.py 2012-05-24 10:56:36 UTC (rev 51700)
@@ -193,24 +193,28 @@
cap_lines = cap.readlines()
for line in cap_lines:
- grass.message(line)
+ print line
def _computeBbox(self):
"""!Get region extent for WMS query (bbox)
self._debug("_computeBbox", "started")
- bbox = {'n' : None, 's' : None, 'e' : None, 'w' : None}
+ bbox_region_items = {'maxy' : 'n', 'miny' : 's', 'maxx' : 'e', 'minx' : 'w'}
+ bbox = {}
if self.proj_srs == self.proj_location: # TODO: do it better
- for param in bbox:
- bbox[param] = self.region[param]
+ for bbox_item, region_item in bbox_region_items.iteritems():
+ bbox[bbox_item] = self.region[region_item]
# if location projection and wms query projection are
# different, corner points of region are transformed into wms
# projection and then bbox is created from extreme coordinates
# of the transformed points
else:
+ bbox[bbox_item] = None
temp_region = self._tempfile()
try:
@@ -239,25 +243,36 @@
for point in points:
point = map(float, point.split("|"))
- if not bbox['n']:
- bbox['n'] = point[1]
- bbox['s'] = point[1]
- bbox['e'] = point[0]
- bbox['w'] = point[0]
+ if not bbox['maxy']:
+ bbox['maxy'] = point[1]
+ bbox['miny'] = point[1]
+ bbox['maxx'] = point[0]
+ bbox['minx'] = point[0]
continue
- if bbox['n'] < point[1]:
- elif bbox['s'] > point[1]:
+ if bbox['maxy'] < point[1]:
+ elif bbox['miny'] > point[1]:
- if bbox['e'] < point[0]:
- elif bbox['w'] > point[0]:
+ if bbox['maxx'] < point[0]:
+ elif bbox['minx'] > point[0]:
self._debug("_computeBbox", "finished -> %s" % bbox)
+ # Ordering of coordinates axis of geographic coordinate
+ # systems in WMS 1.3.0 is fliped. If self.flip_coords is
+ # True, coords in bbox need to be flipped in WMS query.
+ self.flip_coords = False
+ hasLongLat = self.proj_srs.find("+proj=longlat")
+ hasLatLong = self.proj_srs.find("+proj=latlong")
+ if (hasLongLat != -1 or hasLatLong != -1) and self.o_wms_version == "1.3.0":
+ self.flip_coords = True
return bbox
def _createOutputMap(self):
@@ -346,6 +361,25 @@
grass.try_remove(temp_warpmap)
grass.try_remove(self.temp_map)
+ def _flipBbox(self, bbox):
+ flips items in dictionary
+ value flips between this keys:
+ maxy -> maxx
+ maxx -> maxy
+ miny -> minx
+ minx -> miny
+ @return copy of bbox with fliped cordinates
+ temp_bbox = dict(bbox)
+ new_bbox = {}
+ new_bbox['maxy'] = temp_bbox['maxx']
+ new_bbox['miny'] = temp_bbox['minx']
+ new_bbox['maxx'] = temp_bbox['maxy']
+ new_bbox['minx'] = temp_bbox['miny']
+ return new_bbox
def _tempfile(self):
"""!Create temp_file and append list self.temp_files_to_cleanup
with path of file
Modified: grass-addons/grass7/raster/r.in.wms2/wms_drv.py
--- grass-addons/grass7/raster/r.in.wms2/wms_drv.py 2012-05-24 10:44:38 UTC (rev 51699)
+++ grass-addons/grass7/raster/r.in.wms2/wms_drv.py 2012-05-24 10:56:36 UTC (rev 51700)
@@ -21,6 +21,7 @@
grass.message(_("Downloading data from WMS server..."))
proj = self.projection_name + "=EPSG:"+ str(self.o_srs)
url = self.o_mapserver_url + "REQUEST=GetMap&VERSION=%s&LAYERS=%s&WIDTH=%s&HEIGHT=%s&STYLES=%s&BGCOLOR=%s&TRANSPARENT=%s" %\
(self.o_wms_version, self.o_layers, self.tile_cols, self.tile_rows, self.o_styles, self.o_bgcolor, self.transparent)
@@ -35,7 +36,7 @@
# computes parameters of tiles
num_tiles_x = cols / self.tile_cols
last_tile_x_size = cols % self.tile_cols
- tile_x_length = float(self.tile_cols) / float(cols ) * (self.bbox['e'] - self.bbox['w'])
+ tile_x_length = float(self.tile_cols) / float(cols ) * (self.bbox['maxx'] - self.bbox['minx'])
last_tile_x = False
if last_tile_x_size != 0:
@@ -44,7 +45,7 @@
num_tiles_y = rows / self.tile_rows
last_tile_y_size = rows % self.tile_rows
- tile_y_length = float(self.tile_rows) / float(rows) * (self.bbox['n'] - self.bbox['s'])
+ tile_y_length = float(self.tile_rows) / float(rows) * (self.bbox['maxy'] - self.bbox['miny'])
last_tile_y = False
if last_tile_y_size != 0:
@@ -53,34 +54,40 @@
# each tile is downloaded and written into temp_map
tile_bbox = dict(self.bbox)
- tile_bbox['e'] = self.bbox['w'] + tile_x_length
+ tile_bbox['maxx'] = self.bbox['minx'] + tile_x_length
tile_to_temp_map_size_x = self.tile_cols
for i_x in range(num_tiles_x):
# set bbox for tile i_x,i_y (E, W)
if i_x != 0:
- tile_bbox['e'] += tile_x_length
- tile_bbox['w'] += tile_x_length
+ tile_bbox['maxx'] += tile_x_length
+ tile_bbox['minx'] += tile_x_length
if i_x == num_tiles_x - 1 and last_tile_x:
tile_to_temp_map_size_x = last_tile_x_size
- tile_bbox['n'] = self.bbox['n']
- tile_bbox['s'] = self.bbox['n'] - tile_y_length
+ tile_bbox['maxy'] = self.bbox['maxy']
+ tile_bbox['miny'] = self.bbox['maxy'] - tile_y_length
tile_to_temp_map_size_y = self.tile_rows
for i_y in range(num_tiles_y):
# set bbox for tile i_x,i_y (N, S)
if i_y != 0:
- tile_bbox['s'] -= tile_y_length
- tile_bbox['n'] -= tile_y_length
+ tile_bbox['miny'] -= tile_y_length
+ tile_bbox['maxy'] -= tile_y_length
if i_y == num_tiles_y - 1 and last_tile_y:
tile_to_temp_map_size_y = last_tile_y_size
- # bbox for tile defined
- query_url = url + "&" + "BBOX=%s,%s,%s,%s" % (tile_bbox['w'], tile_bbox['s'], tile_bbox['e'], tile_bbox['n'])
+ if self.flip_coords:
+ # flips coordinates if WMS strandard is 1.3.0 and
+ # projection is geographic (see:wms_base.py _computeBbox)
+ query_bbox = dict(self._flipBbox(tile_bbox))
+ else:
+ query_bbox = tile_bbox
+ query_url = url + "&" + "BBOX=%s,%s,%s,%s" % ( query_bbox['minx'], query_bbox['miny'], query_bbox['maxx'], query_bbox['maxy'])
+ grass.debug(query_url)
try:
wms_data = urlopen(query_url)
except IOError:
@@ -158,9 +165,11 @@
epsg =self.o_srs).rstrip('\n')
temp_map_dataset.SetProjection(projection)
- pixel_x_length = (self.bbox['e'] - self.bbox['w']) / int(cols)
- pixel_y_length = (self.bbox['s'] - self.bbox['n']) / int(rows)
- geo_transform = [ self.bbox['w'] , pixel_x_length , 0.0 , self.bbox['n'] , 0.0 , pixel_y_length ]
+ pixel_x_length = (self.bbox['maxx'] - self.bbox['minx']) / int(cols)
+ pixel_y_length = (self.bbox['miny'] - self.bbox['maxy']) / int(rows)
+ geo_transform = [ self.bbox['minx'] , pixel_x_length , 0.0 , self.bbox['maxy'] , 0.0 , pixel_y_length ]
temp_map_dataset.SetGeoTransform(geo_transform )
temp_map_dataset = None
Modified: grass-addons/grass7/raster/r.in.wms2/wms_gdal_drv.py
--- grass-addons/grass7/raster/r.in.wms2/wms_gdal_drv.py 2012-05-24 10:44:38 UTC (rev 51699)
+++ grass-addons/grass7/raster/r.in.wms2/wms_gdal_drv.py 2012-05-24 10:56:36 UTC (rev 51700)
@@ -53,16 +53,16 @@
data_window = etree.SubElement(gdal_wms, "DataWindow")
upper_left_x = etree.SubElement(data_window, "UpperLeftX")
- upper_left_x.text = str(self.bbox['w'])
+ upper_left_x.text = str(self.bbox['minx'])
upper_left_y = etree.SubElement(data_window, "UpperLeftY")
- upper_left_y.text = str(self.bbox['n'])
+ upper_left_y.text = str(self.bbox['maxy'])
lower_right_x = etree.SubElement(data_window, "LowerRightX")
- lower_right_x.text = str(self.bbox['e'])
+ lower_right_x.text = str(self.bbox['maxx'])
lower_right_y = etree.SubElement(data_window, "LowerRightY")
- lower_right_y.text = str(self.bbox['s'])
+ lower_right_y.text = str(self.bbox['miny'])
size_x = etree.SubElement(data_window, "SizeX")
size_x.text = str(self.region['cols'])
@@ -95,10 +95,17 @@
@return temp_map with stored downloaded data
grass.message("Downloading data from WMS server...")
+ # GDAL WMS driver does not flip geographic coordinates
+ # according to WMS standard 1.3.0.
+ if self.flip_coords and self.o_wms_version == "1.3.0":
+ grass.warning(_("If module will not be able to fetch the data in this\
+ geographic projection, \n try flag -d or use WMS version 1.1.1."))
self._debug("_download", "started")
- temp_map = self._tempfile()
+ temp_map = self._tempfile()
xml_file = self._createXML()
wms_dataset = gdal.Open(xml_file, gdal.GA_ReadOnly)
grass.try_remove(xml_file)
