[GRASS-SVN] r51708 - in grass-addons/grass6/vector: . v.in.ovl
v.out.kml
svn_grass at osgeo.org
Thu May 24 10:12:34 EDT 2012
Author: gisix
Date: 2012-05-24 07:12:33 -0700 (Thu, 24 May 2012)
New Revision: 51708
Added:
grass-addons/grass6/vector/v.in.ovl/
grass-addons/grass6/vector/v.in.ovl/grass.smlogo.gif
grass-addons/grass6/vector/v.in.ovl/index.html
grass-addons/grass6/vector/v.in.ovl/v.in.ovl.pl
grass-addons/grass6/vector/v.out.kml/
grass-addons/grass6/vector/v.out.kml/grass.smlogo.gif
grass-addons/grass6/vector/v.out.kml/index.html
grass-addons/grass6/vector/v.out.kml/v.out.kml.sh
check-in v.in.ovl / v.out.kml / r.mandelbrot / r.out.cfad / r.in.mdv
Added: grass-addons/grass6/vector/v.in.ovl/grass.smlogo.gif
(Binary files differ)
Property changes on: grass-addons/grass6/vector/v.in.ovl/grass.smlogo.gif
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: grass-addons/grass6/vector/v.in.ovl/index.html
--- grass-addons/grass6/vector/v.in.ovl/index.html (rev 0)
+++ grass-addons/grass6/vector/v.in.ovl/index.html 2012-05-24 14:12:33 UTC (rev 51708)
@@ -0,0 +1,69 @@
+<html><head>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+<meta name="GENERATOR" content="Microsoft FrontPage Express 2.0">
+<title>v.in.ovl 101</title></head>
+<body bgcolor="#ffffff">
+<p><img src="./grass.smlogo.gif"> </p>
+<hr size="6" noshade="noshade">
+<h2>NAME</h2>
+<p><b><i>v.in.ovl</i></b> - A Perl-script to import ascii OVL-files into
+a GRASS location. <br>
+<i>(GRASS 6 Vector Program)</i> </p>
+<h2>SYNOPSIS</h2>
+<p><b>v.in.ovl</b> <br>
+<b>v.in.ovl </b>input=OVL-File [output=GRASS-Vector] <br>
+<h2>DESCRIPTION</h2>
+<p><i>v.in.ovl</i> imports vector data from an ascii OVl file
+into a (lat lon/EPS:4326) GRASS location. <br>
+If no parameters are provided, <i>v.in.ovl</i> will ask for the input file
+and the name of the vector layer to be created. <br>
+An OVL file can contain multiple vector geometries, such as polygons, lines
+and several varieties of point data with specific attributes (different
+icons, text, size, orientation) <br>
+All geometries of the OVL are imported into the GRASS vector layer. All OVL
+attributes (colors, size, orientation, text, etc.) are stored in the vectors database table. </p>
+<h3>Parameters</h3>
+<dl><dt><b><i>input</i></b></dt><dd>Input ascii OVL file.
+</dd><dt><b><i>output</i></b></dt><dd>
+ Name of the new GRASS vector. <br>
+ </dd></dl>
+<h2>Notes</h2>
+<p>This script will not work on binary OVL files. Make sure that ASCII OVL
+is exported. <br>
+<p>OVL files can be created from german TOP[10|25|50|100] products, austrian
+AUSTRIA MAP products and the swiss SWISSMAP 100. </p>
+<br>
+<p>
+The script automatically converts the line-end characters from windows to
+un*x-style.
+</p>
+<h2>Extended Mapping Opportunity</h2>
+<p>It might be interesting to know that the SWISSMAP 100 CDROM includes a
+general map (low res) of central europe which allows to create OVLs also for
+parts of France, Italy and other countries. <br>
+ </p>
+<h2>DOWNLOAD THE CODE</h2>
+<p><a
+href="http://grasslab.gisix.com/scripts/v.in.ovl/v.in.ovl.pl">v.in.ovl.pl</a> </p>
+<h2>AUTHOR</h2>
+<p>Peter Löwe </p>
+<p><i>Last changed: $Date: 2007/17/06 $</i> </p>
+</body></html>
\ No newline at end of file
Added: grass-addons/grass6/vector/v.in.ovl/v.in.ovl.pl
--- grass-addons/grass6/vector/v.in.ovl/v.in.ovl.pl (rev 0)
+++ grass-addons/grass6/vector/v.in.ovl/v.in.ovl.pl 2012-05-24 14:12:33 UTC (rev 51708)
@@ -0,0 +1,463 @@
+#!/usr/bin/perl
+# MODULE: v.in.ovl
+# AUTHOR(S): Peter Loewe
+# PURPOSE: Import content from a OVL ASCII into a GRASS GIS vector layer.
+# COPYRIGHT: (c) 2006, 2007 Peter Loewe
+# This program is free software under the GNU General Public
+# Licence (>= v2). Read the file COPYING that comes with GRASS
+# for further details.
+# Notes:
+# June 2007 (PL): Minor beautification & clean up
+#REQUIREMENTS:
+# Perl
+#%Module
+#% description: v.in.ovl Script to import ascii ovl-files generated by german TOP[25/50/200]-CDROMS
+#%End
+#%option
+#% key: input
+#% type: string
+# #% gisprompt: old,vector,vector
+#% description: vector input map
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% description: optional name for output vector
+#% required : no
+#%end
+#GRASS up and running ?
+if ( !$ENV{'GISBASE'} ) {
+ printf(STDERR "You must be in GRASS GIS to run this program.\n");
+ exit 1;
+#Call up GUI if no parameters are provided
+if( $ARGV[0] ne '@ARGS_PARSED@' ){
+ my $arg = "";
+ for (my $i=0; $i < @ARGV;$i++) {
+ $arg .= " $ARGV[$i] ";
+ system("$ENV{GISBASE}/bin/g.parser $0 $arg");
+ exit;
+$ykoo_min=10000000000;
+$ykoo_max=0;
+$xkoo_min=10000000000;
+$xkoo_max=0;
+$gisdbase ="";
+$mapset ="";
+$location_name ="";
+$monitor ="";
+$grass_gui ="";
+ at gml_content=();
+ at xkoo_stack=();
+ at ykoo_stack=();
+ at struct_stack=();
+#a list of all structs read from the file
+ at the_struct=();
+#the current struct
+$sammel_hash={};
+# a hash for all variables ever occuring in all structs
+$GRASS_LAYER = $ENV{'GIS_OPT_OUTPUT'};
+if ($GRASS_LAYER eq "") {die "ERROR: Missing output file\n";}
+$GML_OUTPUT=`g.tempfile pid=$$`;
+chomp($GML_OUTPUT);
+#This file must be removed later on
+$dateiname=s(^.*/)($ENV{'GIS_OPT_INPUT'});
+unless (open(INPUT,$ENV{'GIS_OPT_INPUT'}))
+{die "ERROR: No input file provided"}
+$event = 0;
+while (<INPUT>)
+ s/\r\n/\n/;
+ if (/^\[Symbol/) {
+ ## [Symbol]-event: A geometry-objects begins
+ ##1=ikone 3=line 4=area 5=square 6=circle 7=triangle 2=text
+ $event++;
+ #crank up counter for geometry objects
+ $the_symbol0 = $_;
+ if ($event > 1)
+ geometry_processing();
+ push(@struct_stack,$derhash);
+ @the_struct=();
+ @xkoo_stack=();
+ @ykoo_stack=();
+ undef $derhash;
+ else
+ {undef $derhash;
+ #if a geometry-objects have already been handled, they are saved now. The last one /only one is handled/saved outside the loop.
+ elsif (/=/) {
+ #a line of data
+ @zeile = split /=/ ;
+ chomp $zeile[1];
+ datenzeile();
+ else
+ ## it is one of the other structs
+ $foo = 42;
+close(INPUT);
+geometry_processing();
+push(@struct_stack,$derhash);
+##This code is necessary if there is only one struct in the file
+## or we have processed all lest the last one.
+## The last remaining structs is not dealt with.
+#hashtest();
+gml_out();
+open(GML,"> $GML_OUTPUT")or die "Could not write out $GML_OUTPUT !\n";
+foreach $content (@gml_content) {
+print GML $content;
+#dsnXXX is a tempfile which has to be created.
+$vogr="v.in.ogr -o dsn=$GML_OUTPUT output=$GRASS_LAYER ";
+ print "$vogr\n";
+#gisenv();
+system($vogr);
+print "Das wars\n";
+#Suggestion: If no name for the output file is provided, use the source layer name.
+###SUBS##################################
+sub gisenv {
+# my $gisdbase ="";
+# my $mapset ="";
+# my $location_name ="";
+# my $monitor ="";
+# my $grass_gui ="";
+ my @gisenv=`g.gisenv`;
+ my %gisenv;
+ foreach $giszeile (@gisenv) {
+ @gisvar = split(/=/, $giszeile );
+ chomp $gisvar[1];
+ $gisvar[1]=~s/'//g;
+ $gisvar[1]=~s/;//g;
+ $gisenv{$gisvar[0]}=$gisvar[1];
+ #print "$gisvar[0] -- $gisvar[1]\n";
+ $gisbase=$gisenv{"GISDBASE"};
+ $mapset=$gisenv{"MAPSET"};
+ $location_name=$gisenv{"LOCATION_NAME"};
+ $monitor=$gisenv{"MONITOR"};
+ $grass_gui=$gisenv{"GRASS_GUI"};
+sub gml_out {
+ vorlauf();
+ middle();
+ nachlauf();
+sub coordinate_string {
+ my $composite = "";
+ my $tupelx,$tupely;
+ for ($i; $i <= $#xkoo_stack; $i++ ){
+ $tupelx = $xkoo_stack[$i];
+ $tupely = $ykoo_stack[$i];
+ $composite="$composite $tupelx,$tupely";}
+ return $composite;
+sub point_string {
+ my $tupelx="";
+ my $tupely="";;
+ my $linestring;
+ my $open="<gml:Point><gml:coordinates>";
+ my $close="</gml:coordinates></gml:Point>";
+ $mymagic=magic();
+ $linestring=$open.$mymagic.$close;
+ return ${\($linestring)};
+sub magic {
+ my $mymagic = "";
+ my $mtupelx = "";
+ my $mtupely = "";
+ for ($i=0; $i <= $#xkoo_stack; $i++ ){
+ $mtupelx = $xkoo_stack[$i];
+ $mtupely = $ykoo_stack[$i];
+ $mymagic="${\($mymagic)} ${\($mtupelx)},${\($mtupely)}";
+ return $mymagic;
+sub line_string {
+ my $linestring="";
+ my $open = "<gml:LineString><gml:coordinates>";
+ my $close = "</gml:coordinates></gml:LineString>";
+ $composite = magic();
+ $linestring="$open$composite$close";
+ return $linestring;
+sub polygon_string {
+ my $linestring;
+ my $open="<gml:Polygon><gml:OuterBoundaryIs><gml:LinearRing><gml:coordinates>";
+ my $close="</gml:coordinates></gml:LinearRing></gml:OuterBoundaryIs></gml:Polygon>";
+ $composite=magic();
+sub vorlauf{
+ $zeile1_xml=qq(<?xml version="1.0" encoding="utf-8" ?> \n);
+ $zeile2_ogr_featurecollection=qq(<ogr:FeatureCollection
+ xmlns:xsi="http://www.w3c.org/2001/XMLSchema instance"
+ xsi:schemaLocation=". FOOO.xsd"
+ xmlns:ogr="http://ogr.maptools.org/"
+ xmlns="http://ogr.maptools.org/"
+ xmlns:gml="http://www.opengis.net/gml">\n);
+ $ogr_geometry_property_A=q(<ogr:geometryProperty>);
+ $ogr_geometry_property_Z=q(</ogr:geometryProperty>);
+ $gml_linestring_A=q(<gml:LineString>);
+ $gml_linestring_Z=q(</gml:LineString>);
+ $gml_coordinates_A=q(<gml:coordinates>);
+ $gml_coordinates_Z=q(</gml:coordinates>);
+ $gml_box_A=q(<gml:Box>);
+ $gml_box_Z=q(</gml:Box>);
+ $gml_boundedby_A=q(<gml:boundedBy>);
+ $gml_boundedby_Z=q(<gml:boundedBy>);
+ $gml_coord_A=q(<gml:coord>);
+ $gml_coord_Z=q(</gml:coord>);
+ push(@gml_content,$zeile1_xml);
+ push(@gml_content,$zeile2_ogr_featurecollection);
+ push(@gml_content,"<gml:boundedBy>\n");
+ push(@gml_content,"<gml:Box>\n");
+ push(@gml_content,"<gml:coord>\n");
+ push(@gml_content,"<gml:X>$xkoo_min</gml:X> \n<gml:Y>$ykoo_min</gml:Y>\n");
+ push(@gml_content,"</gml:coord>\n");
+ push(@gml_content,"<gml:X>$xkoo_max</gml:X> \n<gml:Y>$ykoo_max</gml:Y>\n");
+ push(@gml_content,"</gml:Box>\n");
+ push(@gml_content,"</gml:boundedBy>\n");
+sub nachlauf{
+ #Schliesst die GML-Datei
+ push(@gml_content,"</ogr:FeatureCollection>\n");
+sub middle{
+ my $count=0;
+ my $gml_feature_open="<gml:featureMember>\n";
+ my $gml_feature_close="</gml:featureMember>\n";
+ my $FID_open_a=q(<test_wege fid=");
+ my $FID_open_b=q(">);
+ my $FID_close=" </test_wege>\n";
+ my $CAT_open="<cat>";
+ my $CAT_close="</cat>\n";
+ my $cleaned_content;
+ foreach $href (@struct_stack) {
+ push(@gml_content,$gml_feature_open);
+ push(@gml_content," $FID_open_a$count$FID_open_b\n");
+ $count++;
+ push(@gml_content," $CAT_open$count$CAT_close");
+ while (($schluessel, $wert) = each(%$href)){
+ $cleaned_content = $wert;
+ # Get rid off Umlauts as v.in.ogr-XML input does not like them
+ $cleaned_content =~ s/Ä/Ae/g;
+ $cleaned_content =~ s/ä/ae/g;
+ $cleaned_content =~ s/Ö/Oe/g;
+ $cleaned_content =~ s/ö/oe/g;
+ $cleaned_content =~ s/Ü/Ue/g;
+ $cleaned_content =~ s/ü/ue/g;
+ $cleaned_content =~ s/ß/ss/g;
+ push(@gml_content," <$schluessel>$cleaned_content </$schluessel>\n");
+ push(@gml_content,$FID_close);
+ push(@gml_content,$gml_feature_close);
+sub hashtest {
+print "------------------------------------------\n";
+print "STRUCTSTACKLAENGE= ($#struct_stack + 1)\n";
+$jj=0;
+ $jj++;
+ print "bbb".%$href."vvv\n";
+ $hh=0;
+while (($key, $value) = each(%{$href})) {
+ $hh++;
+ print "=$jj=$hh=> $key $value\n";
+my %dh=$href;
+my $dhf=$href;
+print "DH-Hash#=_".$#dhf."_\n";
+print "DH-1=_".$dhf{"ogr:geometryProperty"}."_\n";
+if (ref{$dh} ne 'HASH' ){ die "DH IST KEIN HASH";} else {print "DH IST HASH\n";}
+print "HREF=".$href."\n";
+print "DH=".$dhf."\n";
+print "HASHTEST ENDS. \n";
+die;
+sub geometry_processing {
+if ($derhash->{"Typ"} eq "3") {
+ $cs = line_string(); }
+elsif ($derhash->{"Typ"} eq "4") {
+ $cs = polygon_string(); }
+elsif ((((($derhash->{"Typ"} eq "5") || ($derhash->{"Typ"} eq "6")) || ($derhash->{"Typ"} eq "7")|| ($derhash->{"Typ"} eq "1") ) ||($derhash->{"Typ"} eq "2") )) {
+ $cs = point_string();
+else
+ $cs = coordinate_string();
+ print "UNKOWN GEOMETRY TYPE !: ";
+ print "$the_symbol0\n";
+ print"__";
+ print $derhash{"Typ"};
+ print "--";
+ print "\n";
+ die;
+$derhash->{"ogr:geometryProperty"} = $cs;
+sub datenzeile {
+ chomp $zeile[1];
+ #hier bei koords die min und max in x und y suchen
+ if ($zeile[0] =~ /YKoord/) {
+ push(@ykoo_stack,$zeile[1]);
+ if ($zeile[1] < $ykoo_min) {$ykoo_min = $zeile[1];}
+ if ($zeile[1] > $ykoo_max) {$ykoo_max = $zeile[1];}
+ elsif ($zeile[0] =~ /XKoord/) {
+ push(@xkoo_stack,$zeile[1]);
+ if ($zeile[1] < $xkoo_min) {$xkoo_min = $zeile[1];}
+ if ($zeile[1] > $xkoo_max) {$xkoo_max = $zeile[1];}
+ else {
+ $derhash->{$zeile[0]} = $zeile[1];
+ #das tupel der zeile wandert in den stack für das geometrieobjekt
+ if (! exists $sammel_hash{$zeile[0]}){
+ $sammel_hash{$zeile[0]} = 1;
+ #Das Tag wird auch in die große Liste geschrieben,
+ #falls es nicht eh schon drin steht.
+#Erledigen:
+#Evtl schon beim Import anwählen, welche OVL-Primitve gezogen werden sollen ?
+#Also: Ikonen, Rechtecke, etc Angabe über Plaintext oder Nummern
+#Import in GRASS:
+#temporären Namen für das GML nehmen. ODer gleich im Speicher halten ?
+#von dort dann in die aktuelle Location reinziehen.
+##option: eine neu zu schaffende Location vorwählen
Property changes on: grass-addons/grass6/vector/v.in.ovl/v.in.ovl.pl
Added: svn:executable
Added: grass-addons/grass6/vector/v.out.kml/grass.smlogo.gif
Property changes on: grass-addons/grass6/vector/v.out.kml/grass.smlogo.gif
Added: grass-addons/grass6/vector/v.out.kml/index.html
--- grass-addons/grass6/vector/v.out.kml/index.html (rev 0)
+++ grass-addons/grass6/vector/v.out.kml/index.html 2012-05-24 14:12:33 UTC (rev 51708)
@@ -0,0 +1,127 @@
+#<html><head>
+<title>v.out.kml 101</title></head>
+<h2>NAME</h2>
+<p><b><i>v.out.kml</i></b> - A shell script to generate KML files (Google Earth) from GRASS vector layers. <br>
+<h2>SYNOPSIS</h2>
+<p><b>v.out.kml</b> <br>
+<b>v.out.kml </b> lots of flags and parameters... use "v.out.kml help" for details <br>
+<p><i>v.out.kml</i> creates KML files from GRASS vector data,
+including color, fillcolor, transparency and icons.<br>
+If no parameters are provided, <i>v.out.kml</i> will ask for the source vector layer and all other parameters. <br>
+The script allows to select wether polygons will be reduced to lines or kept as polygons.<br>
+Transparency values can be set seperately for both lines and polygon area fills.<br>
+Icons for point data can be referenced by ID numbers from the Google Earth web site or by individual URLs.<br>
+The color values can also be randomized. The random-color-flag overrides any additional color settings.<br>
+</p>
+<h3>Flags</h3>
+<dl>
+<dt><b><i> -l </i></b></dt><dd> Force line-vector export: Areas are exported as lines/polylines
+(default) without a fillcolor. </dd>
+<dt><b><i> -y</i></b></dt><dd> Force polygon export: Areas are exported as polygons with a fillcolor
+ and fill-transparency. </dd>
+<dt><b><i> -p</i></b></dt><dd> Point-vector (sites) export: Point data will be exported. </dd>
+<dt><b><i> -r </i></b></dt><dd> Random colors: All line and area colors (if needed) are set to
+random values </dd>
+</dl>
+<dl><dt><b><i>vector</i></b></dt><dd>Vector input map.
+</dd>
+<dt><b><i>output</i></b></dt><dd> Name/path of kml output. </dd>
+<dt><b><i>ogrpath</i></b></dt><dd> optional path to ogr2ogr. </dd>
+<dt><b><i>color</i></b></dt><dd> integer triplet for
+line color (blue:green:red 00:00:00-255:255:255). </dd>
+<dt><b><i>transparency</i></b></dt><dd> integer for vector line
+transparency (0=invisible 255=opaque) Standard: 255. </dd>
+<dt><b><i>fcolor</i></b></dt><dd> integer triplet for polygon fill
+color (blue:green:red 00:00:00-255:255:255). </dd>
+<dt><b><i>ftransparency</i></b></dt><dd> integer for polygon transparency
+(00=invisible 255=opaque)
+ Standard: 255. </dd>
+<dt><b><i>size</i></b></dt><dd>width of the vector lines
+(default is 1). </dd>
+<dt><b><i>iconcode</i></b></dt><dd> Select an icons number within its
+palette for point-vectors. Options: 1-45. </dd>
+<dt><b><i>iconpalette</i></b></dt><dd> Select a KML palette of
+icons for point-vectors. Options: 1-20 . </dd>
+<dt><b><i>iconcolor</i></b></dt><dd> hexcode color triplet for point-vectors
+(blue:green:red 00:00:00-255:255:255) Standard: 00:200:00. </dd>
+<dt><b><i>icontransparency</i></b></dt><dd> integer for point-vector
+transparency (0=invisible 255=opaque 0-255) Standard: 255. </dd>
+<dt><b><i>iconurl</i></b></dt><dd> Provide a URL pointing to a symbol for point-vectors
+. </dd>
+<dt><b><i>linecolumn</i></b></dt><dd>The name of a database column
+providing the line color as an integer triplet (blue:green:red 0:0:0 - 255:255:255) </dd>
+<dt><b><i>linetranscolumn</i></b></dt><dd>The name of a database column providing the line
+transparency as an integer value (0-255 0=invisible 255=opaque)</dd>
+<dt><b><i>fillcolumn</i></b></dt><dd>The name of a database column
+<dt><b><i>filltranscolumn</i></b></dt><dd>The name of a database column providing the line
+</dl>
+<h2>Notes</h2>
+<p>The script only works for data layers of the current mapset. If "user" is
+the current mapset, trying to access vectors from other mapsets (like
+"PERMANENT") will cause ungraceful script termination.</p><br>
+<!-- <p>Worldwind can import KML files, yet it can (currently) only display icons
+(aka point data). Line vectors, polygons etc are (currently) only supported
+by Google Earth. </p><br> -->
+<p>The scrip requires an installation of GDAL/OGR supporting GML (Geographic Markup Language).
+If for some reason this is not available, or the local GDAL/OGR does not provide GML, install
+the famous FWTools from http://fwtools.maptools.org. They provide GML support.
+To point the script to such a FWtools installation, use the ogrpath-parameter (pointing to ogr2ogr in FWtools).
+Once started with this option, the script will remember the path for the current mapset, so this ordeal is only necessary once. </p><br>
+<h2>To be done</h2><br><p> Currently lacking database support for point data (color/transparency)</p>
+<br>
+<p>The same random value will be applied to all instances of a [transparency|geometry]-class.</p><br>
+<p>This is a humble shell-script. It will be certainly out-performed by the mightily improved next version in C.</p><br>
+<p>There might be a slight offset between the generic EPSG 4326 and the "lat
+lon" used by Google Earth. The author would be grateful for feedback on this
+issue.<p><br>
+<p>
+</p>
+<p><a
+href="http://grasslab.gisix.com/scripts/v.out.kml/v.out.kml.sh">v.out.kml</a> </p>
+<h2>AUTHOR</h2>
+<p>Peter Löwe </p>
+</body></html>
Added: grass-addons/grass6/vector/v.out.kml/v.out.kml.sh
--- grass-addons/grass6/vector/v.out.kml/v.out.kml.sh (rev 0)
+++ grass-addons/grass6/vector/v.out.kml/v.out.kml.sh 2012-05-24 14:12:33 UTC (rev 51708)
@@ -0,0 +1,782 @@
+#!/bin/sh
+# MODULE: v.out.kml
+# AUTHOR(S): Peter Loewe <peter.loewe AT grass-verein.de>
+# PURPOSE: Export GRASS point/line/area-vectors into a KML file in
+# geographic coordinates (lat lon).
+# COPYRIGHT: (c) 2007 Peter Loewe and the GRASS DEVELOPMENT TEAM
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# updates:
+# 7 July 2007 (PL): added support for database-columns
+#10 July 2007 (PL): typos fixed
+#28 July 2007 (PL): improvement of cleanup operations: Thanks to Jean-Noel Candau
+#%Module
+#% description: Creates a KML-file from GRASS point/line/polygon vectors
+#%End
+#%flag
+#% key: l
+#% description: Force line-vector export: Areas are exported as lines/polylines (default).
+#%end
+#%flag
+#% key: y
+#% description: Force polygon export: Areas are exported as polygons with a fillcolor and fill-transparency.
+#%end
+#%flag
+#% key: p
+#% description: Point-vector (sites) export: Point data are exported.
+#%end
+#%flag
+#% key: r
+#% description: Random colors: All line and area colors (if needed) are set to random values.
+#%end
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new_file,file,file
+#% description: name/path of kml output
+#% required : no
+#%end
+#%option
+#% key: ogrpath
+#% type: string
+#% gisprompt: old_file,file,file
+#% description: optional path to ogr2ogr
+#% required : no
+#%end
+#%option
+#% key: color
+#% type: string
+#% gisprompt: color,grass,color
+#% description: hexcode triplet for line color (blue:green:red 00:00:00-255:255:255)
+#% answer : 00:200:00
+#% required : no
+#%end
+#%option
+#% key: transparency
+#% type: string
+#% description: integer for vector line transparency (0=invisible 255=opaque)
+#% answer : 255
+#% required : no
+#%end
+#%option
+#% key: fcolor
+#% type: string
+#% description: hexcode triplet for polygon fill color (blue:green:red 00:00:00-255:255:255)
+#% answer : 00:100:00
+#% required : no
+#%end
+#%option
+#% key: ftransparency
+#% type: string
+#% description: integer for polygon transparency (00=invisible 255=opaque)
+#% answer : 255
+#% required : no
+#%end
+#%option
+#% key: size
+#% type: string
+#% description: width of the vector lines (default is 1)
+#% options: 0.5,1,1.5,2,2.5,3,3.5,4,4.5,5,5.5,6,6.5,7,7.5,8,8.5,9,9.5,10
+#% answer : 1
+#% required : no
+#%end
+#%option
+#% key: iconcode
+#% type: string
+#% description: Select an icons number within its palette for point-vectors
+#% options: 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45
+#% answer : 1
+#% required : no
+#%end
+#%option
+#% key: iconpalette
+#% type: string
+#% description: Select a KML palette of icons for point-vectors
+#% answer : 1
+#% required :no
+#%end
+#%option
+#% key: iconcolor
+#% type: string
+#% description: hexcode color triplet for point-vectors (blue:green:red 00:00:00-255:255:255)
+#% required : no
+#%end
+#%option
+#% key: icontransparency
+#% type: string
+#% description: integer for point-vector transparency (0=invisible 255=opaque 0-255)
+#% answer : 255
+#% required : no
+#%end
+#%option
+#% key: iconurl
+#% type: string
+#% description: Provide a URL pointing to a symbol for point-vectors
+#% required : no
+#%end
+#%option
+#% key: linecolumn
+#% type: string
+#% description: column name string for line color ([xxx]:xxx:xxx:xxx). Transparency should be provided as first value, unless 3-Flag is set.
+#% required : no
+#%end
+#%option
+#% key: fillcolumn
+#% type: string
+#% description: column name string for area fill color ([xxx]:xxx:xxx:xxx). Transparency should be provided as first value, unless 3-Flag is set.
+#% required : no
+#%end
+#%option
+#% key: linetranscolumn
+#% type: string
+#% description: column name string for line transparency (xxx). This option is overridden by the 'transparency'-option.
+#% required : no
+#%end
+#%option
+#% key: filltranscolumn
+#% type: string
+#% description: column name string for fill transparency (xxx). This option is overridden by the 'transparency'-option.
+#% required : no
+#%end
+### Let's seperate the Flag and Option-Names from the variables used in the script.
+### This is good practice if we have to change terms in the GUI/frontend.
+FLAG_FORCE_LINE_EXPORT=${GIS_FLAG_L}
+FLAG_FORCE_POLYGON_EXPORT=${GIS_FLAG_Y}
+FLAG_POINT_EXPORT=${GIS_FLAG_P}
+FLAG_RANDOM_COLORS=${GIS_FLAG_R}
+OPT_MAP=${GIS_OPT_MAP}
+OPT_OUTPUT=${GIS_OPT_OUTPUT}
+OPT_OGRPATH=${GIS_OPT_OGRPATH}
+OPT_LINE_COLOR=${GIS_OPT_COLOR}
+OPT_LINE_TRANS=${GIS_OPT_TRANSPARENCY}
+OPT_FILL_COLOR=${GIS_OPT_FCOLOR}
+OPT_FILL_TRANS=${GIS_OPT_FTRANSPARENCY}
+OPT_LINE_SIZE=${GIS_OPT_SIZE}
+OPT_ICON_CODE=${GIS_OPT_ICONCODE}
+OPT_ICON_PALETTE=${GIS_OPT_ICONPALETTE}
+OPT_ICON_COLOR=${GIS_OPT_ICONCOLOR}
+OPT_ICON_TRANS=${GIS_OPT_ICONTRANSPARENCY}
+OPT_ICON_URL=${GIS_OPT_ICONURL}
+OPT_COLUMN_LINE_COLOR=${GIS_OPT_LINECOLUMN}
+OPT_COLUMN_LINE_TRANS=${GIS_OPT_LINETRANSCOLUMN}
+OPT_COLUMN_FILL_COLOR=${GIS_OPT_FILLCOLUMN}
+OPT_COLUMN_FILL_TRANS=${GIS_OPT_FILLTRANSCOLUMN}
+TMPDIR=`g.gisenv get="GISDBASE"`
+#TMPDIR is used to create the inner temporary latlon location
+# name: CLEANUP_TEMPFILES
+# purpose: Removes all temporary files which might have been created.
+# usage: CLEANUP_TEMPFILES
+function CLEANUP_TEMPFILES ()
+ rm $TMPDIR/.grassrc6_$TEMP_LOCATION
+ rm $THE_VECTOR.shp
+ rm $THE_VECTOR.shx
+ rm $THE_VECTOR.prj
+ rm $THE_VECTOR.dbf
+ rm $VECTOR_KML.raw
+ rm $VECTOR_KML.cat_poly
+ rm $VECTOR_KML.cat_point
+ rm $VECTOR_KML.prepoint
+ rm -rf $GISDBASE/$TEMP_LOCATION/PERMANENT
+ rmdir $GISDBASE/$TEMP_LOCATION
+ rm -rf $VECTOR_KML.raw2
+# name: exitprocedure
+# purpose: removes all temporary files
+exitprocedure ()
+ message 0 "User break!"
+ #rm -f ${TMP}*
+ #rm $TMPDIR/.grassrc6_$TEMP_LOCATION
+ #rm -rf $GISDBASE/$TEMP_LOCATION
+ CLEANUP_TEMPFILES
+ exit 1
+trap "exitprocedure" 2 3 15
+BC="bc"
+BCARGS="-l"
+export GIS_LOCK=$$
+# name: error_routine
+# purpose: If an error occurs, exit gracefully.
+error_routine () {
+echo "ERROR: $1"
+exit 1
+# is GRASS running ? if not: abort
+if [ -z "$GISBASE" ] ; then
+ error_routine "You must be in GRASS to run this program."
+fi
+# if no paramters are provided by the user fire up the gui
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec $GISBASE/bin/g.parser "$0" "$@"
+fi
+# Database
+ # We need a string of all the column names in the layers database
+ DB_RESULT=`v.db.connect -c map=$OPT_MAP`
+ DB_COLUMN_NAMES=`echo $DB_RESULT |sed 's/^[A-Z]*|//g' | sed 's/[A-Z]*|/ /g'`
+# name: OGR_PATH_USER_OVERRIDE
+# purpose: if the user provides a path to a specific version of OGR it will be used.
+# usage: OGR_PATH_USER_OVERRIDE
+function OGR_PATH_USER_OVERRIDE ()
+ if [ "${OPT_OGRPATH}" != "" ] ; then
+ #ensure that the path-string properly ends with the file name
+ OGR_ENDING=`echo ${OPT_OGRPATH} | grep "/ogr2ogr$" `
+ if [ "$OGR_ENDING" == "" ] ; then
+ OPT_OGRPATH="${OPT_OGRPATH}/ogr2ogr"
+ fi
+ if [ -f ${OPT_OGRPATH} ]; then
+ #store this path as a GRASS variable for further use
+ THE_OGR_PATH=$OPT_OGRPATH
+ `g.gisenv set="GML_OGR_PATH"=${OPT_OGRPATH}`
+ else
+ error_routine "Invalid path to OGR: ${THE_OGR_PATH}"
+ fi
+ fi
+# name: ENSURE_COLUMN
+# purpose: Verify that string $1 equals the name of column of the maps database.
+# usage: ENSURE_COLUMN string-for-column-name
+function ENSURE_COLUMN () {
+#1: $COLUMN NAME to be verified
+ echo $DB_COLUMN_NAMES |grep -q "$1"
+ if [ $? != 0 ] ; then
+ error_routine "$1 is not a database column."
+ fi
+# name: SET__HEX_COLORS
+# purpose: create new string variables for R,G,B as 2byte hex numbers from a R:G:B string (can be hex, decimal or other).
+# usage: SET_HEX_COLORS value-string-variable R-variable-name G-variable-name B-variable-name R-hex-default G-hex-default B-hex-default
+function SET_HEX_COLORS
+if [ "$1" != "(null)" ] ; then
+ RED_D=`echo ${1} | cut -d: -f 1 `
+ eval "$2"=`printf "%02x" $RED_D`
+ GREEN_D=`echo ${1} | cut -d: -f 2 `
+ eval "$3"=`printf "%02x" $GREEN_D`
+ BLUE_D=`echo ${1} | cut -d: -f 3 `
+ eval "$4"=`printf "%02x" $BLUE_D`
+else
+ eval "$3=$5"
+ eval "$3=$6"
+ eval "$4=$7"
+fi
+if [ "${GIS_FLAG_r}" = 1 ] ; then
+ # the flag for random colors is set
+ RCOLOR=`expr ${RANDOM} % 255`
+ eval "$2"=`printf "%02x" $RCOLOR`
+ eval "$4"=`printf "%02x" $RCOLOR`
+ eval "$3"=`printf "%02x" $RCOLOR`
+fi
+# name: SET_HEX_VALUE
+# purpose: create a new string variable with the value $2 as a 2byte hex number, or a default value $3.
+# usage: SET_HEX_VALUE grass_parameter-variable new-variable-name default-value
+function SET_HEX_VALUE () {
+#1: $OPT_LINE_SIZE 2:GMLSIZE 3:1
+ eval "$2"=`printf "%02x" $1`
+ else
+ eval "$2"="$3"
+fi
+### Verify correct column names
+### if they are provided, they are needed further below
+ if [ "${OPT_COLUMN_LINE_TRANS}" != "" ] ; then
+ ENSURE_COLUMN "${OPT_COLUMN_LINE_TRANS}"
+ fi
+ if [ "${OPT_COLUMN_FILL_TRANS}" != "" ] ; then
+ ENSURE_COLUMN "${OPT_COLUMN_FILL_TRANS}"
+ fi
+ fi
+ fi
+# Has a value for line color been provided by the user ?
+# Otherwise use grass-green as the default.
+SET_HEX_COLORS ${OPT_LINE_COLOR} "GMLRED" "GMLGREEN" "GMLBLUE" "0" "ff" "0"
+### Has a value for a polygon fill color been provided by the user ?
+SET_HEX_COLORS "${OPT_FILL_COLOR}" "GMLFILLRED" "GMLFILLGREEN" "GMLFILLBLUE" "0" "ff" "0"
+### Has a value for a icon color been provided by the user ?
+SET_HEX_COLORS "${OPT_ICON_COLOR}" "GMLICONRED" "GMLICONGREEN" "GMLICONBLUE" "0" "ff" "0"
+### Has a transparency value been provided by the user ?
+# Otherwise use full opacity as the default.
+SET_HEX_VALUE "${OPT_LINE_TRANS}" "GMLTRANSPARENCY" "ff"
+### Has a fill-transparency value been provided by the user ?
+### Otherwise use full opacity as the default.
+SET_HEX_VALUE "${OPT_FILL_TRANS}" "GMLFILLTRANSPARENCY" "ff"
+## Has a icon-transparency value been provided by the user ?
+## Otherwise use full opacity as the default.
+SET_HEX_VALUE "${OPT_ICON_TRANS}" "GMLICONTRANSPARENCY" "ff"
+## Has a line-size value been provided by the user ?
+## Otherwise use 1 as the default.
+SET_HEX_VALUE "$OPT_LINE_SIZE" "GMLSIZE" "1"
+# Ensure that the output file has the proper .kml-extension
+# if no output file has been named, fall back to the name of the map.
+if [ -z "${OPT_OUTPUT}" ] ; then
+ VECTOR_KML=${OPT_MAP}.kml
+ else
+ VECTOR_KML=${OPT_OUTPUT}
+fi
+KML_ENDING=`echo $VECTOR_KML | grep ".kml$" `
+if [ -z "$KML_ENDING" ] ; then
+ VECTOR_KML=$VECTOR_KML.kml
+fi
+# Is ogr2ogr installed and available ?
+# Search for ogr2ogr command in user's path
+for i in `echo $PATH | sed 's/^:/.:/
+ s/::/:.:/g
+ s/:$/:./
+ s/:/ /g'`
+ do
+ if [ -f $i/ogr2ogr ] ; then
+ OGR_AVAILABLE=1
+ THE_OGR_PATH="$i/ogr2ogr"
+ break
+ fi
+ done
+# has a custom ogr2ogr path already been provided on this machine (like in previous GRASS sessions) ?
+# in any case, if the user explicitly provides a ogr2ogr path from the command line,
+# this one will override any defaults or previous settings
+ PREVIOUS_SESSION_OGR=`g.gisenv get="GML_OGR_PATH"`
+if [ "${PREVIOUS_SESSION_OGR}" ] ; then
+ # if a ogr setting has been stored from former sessions then use it.
+ THE_OGR_PATH=${PREVIOUS_SESSION_OGR}
+ OGR_PATH_USER_OVERRIDE
+ #Even if we have a path to OGR provided by the system, the user can override it.
+else
+ # this might be the first session ever, so lets stick to the user-provided path
+ if [ "${THE_OGR_PATH}" == "" ]; then
+ error_routine " ogr2ogr is not found in your default search-path. Is it installed ? You might provide a path to ogr2ogr as a second argument to this program."
+ fi
+ #So we have ogr2ogr, but can it deal with KML ?
+ echo "$THE_OGR_PATH --formats"
+ OGR_KML=`$THE_OGR_PATH --formats |grep "KML"`
+ if [ -z "$OGR_KML" ]; then
+ error_routine " $THE_OGR_PATH is lacking KML support."
+ fi
+fi
+# Setting the Line/Poly flags
+# Only one of both flags can be set:
+if [ "${FLAG_FORCE_LINE_EXPORT}" = 1 ] && [ "${FLAG_FORCE_POLYGON_EXPORT}" = 1 ] ; then
+ error_routine "Conflicting flag settings: -l and -y can not be used together."
+fi
+# Get the name of the vector layer to be converted
+THE_VECTOR=${OPT_MAP}
+# create a name fpr the temporary location
+TEMP_LOCATION=latlon_location_$$
+# Create a new temporary latlon location
+g.proj -c proj4='+init=epsg:4326' location=$TEMP_LOCATION
+#Set variables
+GISDBASE=`g.gisenv get=GISDBASE`
+OUTER_LOCATION=`g.gisenv get=LOCATION_NAME`
+OUTER_MAPSET=`g.gisenv get=MAPSET`
+#Keep the path to the settings file for the original location
+export OUTER_GISRC=$GISRC
+##generate GRASS_settings-file for lat lon location:
+echo "GISDBASE: $GISDBASE " > $TMPDIR/.grassrc6_$TEMP_LOCATION
+echo "LOCATION_NAME: $TEMP_LOCATION " >> $TMPDIR/.grassrc6_$TEMP_LOCATION
+echo "MAPSET: PERMANENT " >> $TMPDIR/.grassrc6_$TEMP_LOCATION
+echo "GRASS_GUI: text " >> $TMPDIR/.grassrc6_$TEMP_LOCATION
+##switch over to lat lon location
+export GISRC=$TMPDIR/.grassrc6_$TEMP_LOCATION
+#use process ID (PID) as lock file number:
+export GIS_LOCK=$$
+# Import the vector data into the lat lon location
+v.proj input=$THE_VECTOR location=$OUTER_LOCATION mapset=$OUTER_MAPSET
+## VECTOR FEATURE EXPORT OR POLYGON FEATURE EXPORT
+if [ "${FLAG_FORCE_LINE_EXPORT}" == 1 ] ; then
+ GEOMETRY="kernel,line,boundary"
+fi
+if [ "${FLAG_FORCE_POLYGON_EXPORT}" == 1 ] ; then
+ GEOMETRY="area"
+fi
+if [ "${FLAG_POINT_EXPORT}" == 1 ] ; then
+ if [ "$GEOMETRY" != "" ] ; then
+ GEOMETRY="$GEOMETRY,point"
+ else
+ GEOMETRY="point"
+ fi
+fi
+v.out.ogr input=$THE_VECTOR type=$GEOMETRY dsn=. olayer=$THE_VECTOR
+#Switch back to the original location
+export GISRC=$OUTER_GISRC
+GISRC=$OUTER_GISRC
+### Shape to KML Conversion
+echo "$OGR_PATH -f KML $VECTOR_KML.raw $THE_VECTOR.sh"
+`$THE_OGR_PATH -f KML $VECTOR_KML.raw $THE_VECTOR.shp` || error_routine "$OGR_PATH aborted."
+## Blend color, transparency and icons into the KML by updating the style-tag
+# create indicators for points and lines
+cat $VECTOR_KML.raw | grep PolyStyle > $VECTOR_KML.cat_poly
+cat $VECTOR_KML.raw | grep Point > $VECTOR_KML.cat_point
+## Add colors and transparency for polygons and lines
+if [ -s "$VECTOR_KML.cat_poly" ]; then
+ sed "s/<color>........<\/color>/<size>${GMLSIZE}<\/size><color>${GMLTRANSPARENCY}${GMLBLUE}${GMLGREEN}${GMLRED}<\/color>/g" $VECTOR_KML.raw > $VECTOR_KML.raw2
+ sed "s/<fill>0<\/fill>/<color>${GMLFILLTRANSPARENCY}${GMLFILLBLUE}${GMLFILLGREEN}${GMLFILLRED}<\/color>/g" $VECTOR_KML.raw2 > $VECTOR_KML.prepoint
+ else
+ sed "s/<\/LineString>/<\/LineString><Style><LineStyle><size>${GMLSIZE}<\/size><color>${GMLTRANSPARENCY}${GMLBLUE}${GMLGREEN}${GMLRED}<\/color><\/LineStyle><\/Style>/g" $VECTOR_KML.raw > $VECTOR_KML.prepoint
+fi
+## Add color, transparency and icon for points
+if [ -s "$VECTOR_KML.cat_point" ] && [ "${GIS_FLAG_P}" = 1 ] ; then
+# There are point-vectors in the file AND we want to deal with them
+ POINT_BEGIN="<Style><IconStyle><color>${GMLICONTRANSPARENCY}${GMLICONBLUE}${GMLICONGREEN}${GMLICONRED}<\/color><Icon><href>"
+ POINT_END="<\/href><\/Icon><\/IconStyle><\/Style>"
+ if [ "${OPT_ICON_URL}" ] ; then
+ # an URL has been provided by the user
+ ICONURL=` echo ${OPT_ICON_URL} | sed "s|\/|\\\\\/|g"`
+ POINT_STYLE="${POINT_BEGIN}${ICONURL}${POINT_END}"
+ sed "s/<\/Point>/<\/Point>${POINT_STYLE}/g" $VECTOR_KML.prepoint > $VECTOR_KML
+ else
+ if [ -z "${OPT_ICON_CODE}" ] || [ -z "${OPT_ICON_PALETTE}" ] ; then
+ error_routine "GML ICON PROBLEM: ICON=${OPT_ICON_CODE} PALETTE=${OPT_ICON_PALETTE}."
+ fi
+ if [ "${OPT_ICON_CODE}" -a "${OPT_ICON_PALETTE}" ] ; then
+ ICONURL="http:\/\/maps.google.com\/mapfiles\/kml\/pal${OPT_ICON_PALETTE}\/icon${OPT_ICON_CODE}.png"
+ else
+ cp $VECTOR_KML.prepoint $VECTOR_KML
+ # let handle googleearth the icon rendering
+ fi
+ fi
+else
+ #no points around so the results from the line/polygon-conversion are to be used
+fi # cat_points && gis_flag_p ende
+## The files for the transparenices have to be defined prior to pumping the awk-content
+## into the strings -> the transparency values are integrated into the awk-strings
+# ENSURE_COLUMN "${OPT_COLUMN_LINE_TRANS}"
+ AWK_LINE_TRANS_QUERY="/^.*${OPT_COLUMN_LINE_TRANS}.*$/ { parse_event=1; print \$0; split(\$2,a1,\">\"); split(a1[2],a2,\"<\"); LINETRANS=a2[1];} "
+ else
+ AWK_LINE_TRANS_QUERY=""
+ fi
+ # a database column for line-transparency has explicitly been set
+ # ENSURE_COLUMN "${OPT_COLUMN_FILL_TRANS}"
+ AWK_FILL_TRANS_QUERY="/^.*${OPT_COLUMN_FILL_TRANS}.*$/ { parse_event=1; print \$0; split(\$2,a1,\">\"); split(a1[2],a2,\"<\"); FILLTRANS=a2[1];} "
+ else
+ AWK_FILL_TRANS_QUERY=""
+ fi
+################### AWK-Code for LINE ####################################
+awktemp_line=/tmp/awk.prog.line.$$
+cat > $awktemp_line <<END
+BEGIN {
+ hex_fallback=sprintf("%2.2x%2.2x%2.2x",16,16,16);
+ hex_line_trans=LINETRANS;
+/^.*$OPT_COLUMN_LINE_COLOR.*$/ {
+ print \$0;
+ parse_event=1;
+ rgb_provided=1;
+ split(\$2,array1,">");
+ split(array1[2],array2,"<");
+ grassrgb=array2[1];
+ split(grassrgb,colors,":");
+ hex_rgb=sprintf("%2.2x%2.2x%2.2x",colors[1],colors[2],colors[3]);
+$AWK_LINE_TRANS_QUERY
+/^.*<Style>.*$/ {
+ if (rgb_provided == 1)
+ the_rgb=hex_rgb;
+ rgb_provided=0;
+ else
+ the_rgb=hex_fallback;
+ # LINETRANS can either be inserted from the GRASS_DB by a $AWK_LINE_TRANS_QUERY or when the script is called up.
+ parse_event=1;
+ the_line=\$0;
+ gsub(/\<color\>........\<\/color\>\<\/LineStyle\>/,"<color>"hex_line_trans the_rgb"</color></LineStyle>", the_line);
+ print the_line;
+ {if (parse_event == 0) {print \$0;}
+ else { parse_event=0; }
+END
+##################### AWK-Code for FILL:###################################
+awktemp_fill=/tmp/awk.prog.fill.$$
+cat > $awktemp_fill <<END
+BEGIN {
+ hex_fallback=sprintf("%2.2x%2.2x%2.2x",32,32,32);
+ hex_fill_trans=FILLTRANS;
+/^.*$OPT_COLUMN_FILL_COLOR.*$/ {
+ parse_event=1;
+ rgb_provided=1;
+$AWK_FILL_TRANS_QUERY
+/^.*<Style>.*$/ {
+ parse_event=1
+ the_line=\$0;
+ the_rgb=hex_rgb;
+ rgb_provided=0;
+ else
+ gsub(/\<color\>........\<\/color\>\<\/PolyStyle\>/,"<color>"hex_fill_trans the_rgb"</color></PolyStyle>",the_line);
+ print the_line;
+END
+#apply AWK-Codes if necessary (aka database columns have been provided):
+ if [ "${OPT_COLUMN_LINE_COLOR}" != "" ] ; then
+ AWK_LINE_RGB=${OPT_COLUMN_LINE_COLOR}
+ awk -f $awktemp_line -v LINETRANS=$GMLTRANSPARENCY $VECTOR_KML > $VECTOR_KML.awk
+ echo "awk -f $awktemp_line -v LINETRANS=$GMLTRANSPARENCY $VECTOR_KML > $VECTOR_KML.awk"
+ mv $VECTOR_KML $VECTOR_KML.preline
+ mv $VECTOR_KML.awk $VECTOR_KML
+ fi
+ if [ "${OPT_COLUMN_FILL_COLOR}" != "" ] ; then
+ # a column for fill colors has been explicitly set
+ AWK_FILL_RGB=${OPT_COLUMN_FILL_COLOR}
+ echo "awk -f $awktemp_fill -v FILLTRANS=$GMLFILLTRANSPARENCY $VECTOR_KML > $VECTOR_KML.awk"
+ awk -f $awktemp_fill -v FILLTRANS=$GMLFILLTRANSPARENCY $VECTOR_KML > $VECTOR_KML.awk
+ mv $VECTOR_KML $VECTOR_KML.prefill
+ fi
+#cleanup: remove location & files
+CLEANUP_TEMPFILES
+#That's all, folks. (PL)
