[GRASS-SVN] r51714 - in grass/trunk/lib/raster3d: . test
Thu May 24 12:53:14 EDT 2012
Author: huhabla
Date: 2012-05-24 09:53:13 -0700 (Thu, 24 May 2012)
New Revision: 51714
   grass/trunk/lib/raster3d/cachehash.c
   grass/trunk/lib/raster3d/test/test_put_get_value.c
Hunting cache hash 3D raster bug
Modified: grass/trunk/lib/raster3d/cachehash.c
--- grass/trunk/lib/raster3d/cachehash.c	2012-05-24 16:47:45 UTC (rev 51713)
+++ grass/trunk/lib/raster3d/cachehash.c	2012-05-24 16:53:13 UTC (rev 51714)
@@ -52,15 +52,15 @@
     Rast3d_cache_hash *tmp;
-    tmp = Rast3d_malloc(sizeof(Rast3d_cache_hash));
+    tmp = (Rast3d_cache_hash *)Rast3d_malloc(sizeof(Rast3d_cache_hash));
     if (tmp == NULL) {
 	Rast3d_error("Rast3d_cache_hash_new: error in Rast3d_malloc");
 	return (void *)NULL;
     tmp->nofNames = nofNames;
-    tmp->index = Rast3d_malloc(sizeof(int) * tmp->nofNames);
-    tmp->active = Rast3d_malloc(sizeof(char) * tmp->nofNames);
+    tmp->index = (int*) Rast3d_malloc(tmp->nofNames * sizeof(int));
+    tmp->active = (char*) Rast3d_malloc(tmp->nofNames * sizeof(char));
     if ((tmp->index == NULL) || (tmp->active == NULL)) {
 	Rast3d_cache_hash_dispose(tmp);
@@ -77,10 +77,10 @@
 void Rast3d_cache_hash_remove_name(Rast3d_cache_hash * h, int name)
     if (name >= h->nofNames)
-	Rast3d_fatal_error("Rast3d_cache_hash_remove_name: name out of range");
+	Rast3d_fatal_error("Rast3d_cache_hash_remove_name: name %i out of range", name);
     if (h->active[name] == 0)
-	Rast3d_fatal_error("Rast3d_cache_hash_remove_name: name not in hashtable");
+	Rast3d_fatal_error("Rast3d_cache_hash_remove_name: name %i not in hashtable", name);
     h->active[name] = 0;
     if (name == h->lastName)
Modified: grass/trunk/lib/raster3d/test/test_put_get_value.c
--- grass/trunk/lib/raster3d/test/test_put_get_value.c	2012-05-24 16:47:45 UTC (rev 51713)
+++ grass/trunk/lib/raster3d/test/test_put_get_value.c	2012-05-24 16:53:13 UTC (rev 51714)
@@ -19,9 +19,11 @@
 #include "test_g3d_lib.h"
 #include "grass/interpf.h"
+static int test_large_file(void);
 static int test_put_get_value_dcell(void);
 static int test_put_get_value_fcell(void);
 static int test_put_get_value_resampling(void);
+static int test_get_value_region(RASTER3D_Map *map, int cols, int rows, int depths);
 static int test_resampling_dcell(RASTER3D_Map *map, double north, double east, double
                                  top, int col, int row, int depth, int fact);
 static int test_resampling_fcell(RASTER3D_Map *map, double north, double east, double
@@ -39,6 +41,7 @@
     sum += test_put_get_value_dcell();
     sum += test_put_get_value_fcell();
     sum += test_put_get_value_resampling();
+    sum += test_large_file();
     if (sum > 0)
@@ -551,4 +554,60 @@
     return sum;
\ No newline at end of file
+int test_large_file(void)
+     int sum = 0;
+    int x, y, z;
+    FCELL value;
+    FCELL value_ref;
+    G_message("Testing FCELL put function for large files");
+    RASTER3D_Region region;
+    RASTER3D_Map *map = NULL;
+    /* We need to set up a specific region for the new g3d map.
+     * First we safe the default region. */
+    Rast3d_get_window(&region);
+    region.bottom = 0.0;
+    region.top = 1000;
+    region.south = 1000;
+    region.north = 8500;
+    region.west = 5000;
+    region.east = 10000;
+    region.rows = 100;
+    region.cols = 100;
+    region.depths = 100;
+    Rast3d_adjust_region(&region);
+    map = Rast3d_open_new_opt_tile_size("test_put_get_value_fcell_large", RASTER3D_USE_CACHE_XY, &region, FCELL_TYPE, 1);
+    /* The window is the same as the map region ... of course */
+    Rast3d_set_window_map(map, &region);
+    for(z = 0; z < region.depths; z++) {
+        for(y = 0; y < region.rows; y++) {
+            for(x = 0; x < region.cols; x++) {
+                /* Add cols, rows and depths and put this in the map */
+                value = x + y + z;
+                Rast3d_put_value(map, x, y, z, &value, FCELL_TYPE);
+    /* Write everything to the disk */
+    Rast3d_flush_all_tiles(map);
+    Rast3d_close(map);
+    //G_remove("grid3", "test_put_get_value_dcell_large");
+    return sum;
