[GRASS-SVN] r51754 - in grass/branches/releasebranch_6_4: locale/po
raster/r.lake
svn_grass at osgeo.org
Fri May 25 10:42:54 EDT 2012
Author: neteler
Date: 2012-05-25 07:42:53 -0700 (Fri, 25 May 2012)
New Revision: 51754
grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po
grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po
grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
grass/branches/releasebranch_6_4/locale/po/grassmods_el.po
grass/branches/releasebranch_6_4/locale/po/grassmods_es.po
grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po
grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po
grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po
grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po
grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po
grass/branches/releasebranch_6_4/locale/po/grassmods_th.po
grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po
grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po
grass/branches/releasebranch_6_4/raster/r.lake/main.c
improve module description
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -13171,7 +13171,7 @@
msgstr "%-5d dig_att ÙØ±Ø§Ø¡Ø© Ù
ÙÙ...\n"
#: ../raster/r.lake/main.c:149
-msgid "Fills lake from seed at given level."
+msgid "Fills lake at given point to given level."
msgstr ""
#: ../raster/r.lake/main.c:154
@@ -13195,7 +13195,7 @@
#: ../raster/r.lake/main.c:185
#, fuzzy
-msgid "Name of raster map with seed (at least 1 cell > 0)"
+msgid "Name of raster map with given starting point(s) (at least 1 cell > 0)"
msgstr "<%s> اسÙ
اÙÙ
Ù٠اÙÙ
ستخدÙ
ÙÙ"
#: ../raster/r.lake/main.c:193
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -13200,7 +13200,7 @@
msgstr "Chyba pøi zápisu øádku rastrové mapy %d"
msgstr "Vytvoøí jezero ze zadaného bodu dané hloubky"
@@ -13220,7 +13220,7 @@
msgstr "Poèáteèní mapové souøadnice"
msgstr "Rastrová mapa s poèátkem (alespoò jedna buòka > 0)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_de.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_de.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -12177,7 +12177,7 @@
msgstr "Schreiben der Zeile <%d> der Rasterkarte fehlgeschlagen."
msgstr "Fülle den See vom Startpunkt am definierten Level."
@@ -12197,7 +12197,7 @@
msgstr "Koordinaten der Startpunkte"
msgstr "Name der Rasterkarte mit Startpunkten (mindestens eine Zelle > 0)."
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_el.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_el.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_el.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -12538,7 +12538,7 @@
msgstr ""
msgstr ""
@@ -12558,7 +12558,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_es.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_es.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_es.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -13305,7 +13305,7 @@
msgstr "Fallo al escribir la fila %d del mapa raster"
msgstr ""
@@ -13325,7 +13325,7 @@
msgstr "Coordenadas de puntos seed"
msgstr "Nombre del mapa ráster con seed (como mínimo 1 celda>0)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -13204,7 +13204,7 @@
#, fuzzy
msgstr "Remplit le lac à partir du germe jusqu'à un niveau donné"
# c-format
@@ -13232,7 +13232,7 @@
#, fuzzy
msgstr "Couche raster avec le germe (au moins 1 cellule > 0)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -13478,7 +13478,7 @@
msgstr "n"
msgstr ""
@@ -13502,7 +13502,7 @@
#, fuzzy
msgstr "à¤à¤¾"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_it.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_it.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -12115,7 +12115,7 @@
msgstr "Scrittura del raster di output non riuscita alla riga %d"
msgstr "Riempie un lago a parire da un punto seed ad un dato livello"
@@ -12135,7 +12135,7 @@
msgstr "Coordinate del punto seed"
msgstr "Nome della mappa raster con seed (almeno 1 cella > 0)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po 2012-05-25 14:42:53 UTC (rev 51754)
msgstr "æå®ããã©ã¹ã¿ã¼ãããã®è¡ %d ã¯æ¸ãè¾¼ã¿å¤±æãã¾ãã"
msgstr "æå®ã¬ãã«ã®é¢èå¥ç¹ããæ¹æ°´ã¾ã§ãæºãã "
msgstr "ã·ã¼ããã¤ã³ã座æ¨"
msgstr "ã·ã¼ãä»ãã©ã¹ã¿ã¼ãããå (å°ãªãã¨ã 1ã»ã«>0)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -12677,7 +12677,7 @@
msgstr "ì¶ë ¥í ëì¤í°ë§µ"
msgstr ""
@@ -12700,7 +12700,7 @@
#, fuzzy
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -12996,7 +12996,7 @@
#, fuzzy
msgstr "Piepilda ezeru no viena punkta lÄ«dz norÄdÄ«tajam lÄ«menim"
@@ -13019,7 +13019,7 @@
#, fuzzy
msgstr "Rastra karte ar sÄkuma punktu (vismaz 1 šūnu > 0)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -12752,7 +12752,7 @@
msgstr "'%s'. डà¥à¤°à¤¾à¤à¤µà¤° à¤à¤¾à¤²à¥ हà¥à¤¤ नाहà¥"
msgstr ""
@@ -12775,7 +12775,7 @@
#, fuzzy
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -12933,7 +12933,7 @@
msgstr ""
msgstr "WypeÅnia jeziora z wartoÅci próbki na zadanym poziomie."
@@ -12953,7 +12953,7 @@
msgstr "Podaj wspóÅrzÄdne punktu"
msgstr ""
"Nazwa mapy rastrowej która ma byÄ użyta jako maska (co najmniej 1 komórka >0)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -13625,7 +13625,7 @@
#, fuzzy
msgstr "nível"
@@ -13650,7 +13650,7 @@
#, fuzzy
msgstr "Varredura mapear célula"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -13469,7 +13469,7 @@
msgstr "Falha ao escrever linha %d no mapa raster de saída"
msgstr "Preenche lago a partir da origem num dado nível."
@@ -13490,7 +13490,7 @@
msgstr "Coordenadas do ponto de origem"
msgstr "Nome do mapa raster com origem (pelo menos uma célula > 0)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -13234,7 +13234,7 @@
msgstr "ÐÑибка в запиÑи ÑÑда %d ÑаÑÑÑового ÑлоÑ"
msgstr "Ðаполнение озеÑа из заÑÑавки до заданного ÑÑовнÑ"
@@ -13254,7 +13254,7 @@
msgstr "ÐооÑдинаÑÑ Ð·Ð°ÑÑавки"
msgstr "ÐÐ¼Ñ ÑаÑÑÑового ÑÐ»Ð¾Ñ Ñ Ð·Ð°ÑÑавкой (по кÑайней меÑе одна ÑÑейка > 0)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -13358,7 +13358,7 @@
msgstr "Berem dig_att datoteko...\n"
msgstr ""
@@ -13383,7 +13383,7 @@
#, fuzzy
msgstr "Ime rastrskega sloja, ki bo uporabljen za <%s>"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_th.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_th.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_th.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -13068,7 +13068,7 @@
#, fuzzy
msgstr "à¹à¸à¸´à¸¡ lake à¸à¸²à¸ seed à¸à¸µà¹à¸£à¸°à¸à¸±à¸ à¸à¸µà¹à¸à¹à¸à¸à¸à¸²à¸£"
@@ -13091,7 +13091,7 @@
#, fuzzy
msgstr "à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าภà¸à¸µà¹à¸¡à¸µ seed (à¸à¸¢à¹à¸²à¸à¸à¹à¸à¸¢ 1 cell > 0)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -12669,7 +12669,7 @@
msgstr "Raster harita %d satırı yazmada hata"
msgstr ""
@@ -12690,7 +12690,7 @@
msgstr "Kaynak noktası koordinatları"
msgstr "KaynaÄı içeren raster haritanın adı (en az 1 hücre >0)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -13210,7 +13210,7 @@
msgstr "Thất bại khi Äang ghi bản Äá» raster Äầu ra hà ng %d"
msgstr "Lấp Äầy há» từ 'hạt gieo' tại mức cho trưá»c."
@@ -13230,7 +13230,7 @@
msgstr "Tá»a Äá» Äiá»m 'gieo'"
msgstr "Bản Äá» raster vá»i 'hạt gieo' (Ãt nhất là 1 ô > 0)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po 2012-05-25 14:42:53 UTC (rev 51754)
@@ -13173,7 +13173,7 @@
msgstr "读åæ
æ ¼æä»¶ [%s] æ¶åçé误ã"
msgstr ""
@@ -13202,7 +13202,7 @@
#, fuzzy
msgstr "æ
æ ¼å°å¾çåç§° <%s>"
Modified: grass/branches/releasebranch_6_4/raster/r.lake/main.c
--- grass/branches/releasebranch_6_4/raster/r.lake/main.c 2012-05-25 14:39:28 UTC (rev 51753)
+++ grass/branches/releasebranch_6_4/raster/r.lake/main.c 2012-05-25 14:42:53 UTC (rev 51754)
@@ -146,7 +146,7 @@
module = G_define_module();
module->keywords = _("raster, hydrology");
- module->description = _("Fills lake from seed at given level.");
+ module->description = _("Fills lake at given point to given level.");
tmap_opt = G_define_option();
tmap_opt->key = "dem";
@@ -182,7 +182,7 @@
smap_opt->key = "seed";
smap_opt->key_desc = "name";
smap_opt->description =
- _("Name of raster map with seed (at least 1 cell > 0)");
+ _("Name of raster map with given starting point(s) (at least 1 cell > 0)");
smap_opt->type = TYPE_STRING;
smap_opt->gisprompt = "old,cell,raster";
smap_opt->required = NO;
