[GRASS-SVN] r51758 - in grass/trunk/gui/wxpython: core mapdisp
Fri May 25 11:10:48 EDT 2012
Author: annakrat
Date: 2012-05-25 08:10:47 -0700 (Fri, 25 May 2012)
New Revision: 51758
   grass/trunk/gui/wxpython/core/render.py
   grass/trunk/gui/wxpython/mapdisp/main.py
   grass/trunk/gui/wxpython/mapdisp/mapwindow.py
wxGUI: map frame/map renderer refactoring - dmon related code in one place (author Vaclav Petras)
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py	2012-05-25 14:59:56 UTC (rev 51757)
+++ grass/trunk/gui/wxpython/core/render.py	2012-05-25 15:10:47 UTC (rev 51758)
@@ -332,14 +332,10 @@
         self.id = id
 class Map(object):
-    def __init__(self, gisrc = None, cmdfile = None, mapfile = None, envfile = None, monitor = None):
+    def __init__(self, gisrc = None):
         """!Map composition (stack of map layers and overlays)
         @param gisrc alternative gisrc (used eg. by georectifier)
-        @param cmdline full path to the cmd file (defined by d.mon)
-        @param mapfile full path to the map file (defined by d.mon)
-        @param envfile full path to the env file (defined by d.mon)
-        @param monitor name of monitor (defined by d.mon)
         # region/extent settigns
         self.wind      = dict() # WIND settings (wind file)
@@ -355,36 +351,17 @@
         # environment settings
         self.env   = dict()
         # path to external gisrc
         self.gisrc = gisrc
-        self.cmdfile = cmdfile
-        self.envfile = envfile
-        self.monitor = monitor
-        if mapfile:
-            self.mapfileCmd = mapfile
-            self.maskfileCmd = os.path.splitext(mapfile)[0] + '.pgm'
         # generated file for g.pnmcomp output for rendering the map
         self.mapfile = grass.tempfile(create = False) + '.ppm'
         # setting some initial env. variables
         self._initGisEnv() # g.gisenv
         self.GetWindow()
-        # GRASS environment variable (for rendering)
-        env = {"GRASS_BACKGROUNDCOLOR" : "FFFFFF",
-               "GRASS_COMPRESSION"     : "0",
-               "GRASS_TRUECOLOR"       : "TRUE",
-               "GRASS_TRANSPARENT"     : "TRUE",
-               "GRASS_PNG_READ"        : "FALSE",
-        self._writeEnvFile(env)
-        self._writeEnvFile({"GRASS_PNG_READ" : "TRUE"})
-        for k, v in env.iteritems():
-            os.environ[k] = v
         # projection info
         self.projinfo = self._projInfo()
@@ -544,31 +521,6 @@
             self.region['n'] = min(self.region['n'], 90.0)
             self.region['s'] = max(self.region['s'], -90.0)
-    def _writeEnvFile(self, data):
-        """!Write display-related variable to the file (used for
-        standalone app)
-        if not self.envfile:
-            return
-        try:
-            fd = open(self.envfile, "r")
-            for line in fd.readlines():
-                key, value = line.split('=')
-                if key not in data.keys():
-                    data[key] = value
-            fd.close()
-            fd = open(self.envfile, "w")
-            for k, v in data.iteritems():
-                fd.write('%s=%s\n' % (k.strip(), str(v).strip()))
-        except IOError, e:
-            grass.warning(_("Unable to open file '%(file)s' for writting. Details: %(det)s") % \
-                              { 'cmd' : self.envfile, 'det' : e })
-            return
-        fd.close()
     def ChangeMapSize(self, (width, height)):
         """!Change size of rendered map.
@@ -583,8 +535,6 @@
         Debug.msg(2, "Map.ChangeMapSize(): width=%d, height=%d" % \
                       (self.width, self.height))
-        self._writeEnvFile({'GRASS_WIDTH' : self.width,
-                            'GRASS_HEIGHT' : self.height})
     def GetRegion(self, rast = [], zoom = False, vect = [], regionName = None,
                   n = None, s = None, e = None, w = None, default = False,
@@ -909,109 +859,14 @@
             ilayer += 1
         return maps, masks, opacities
-    def GetLayersFromCmdFile(self):
-        """!Get list of map layers from cmdfile
-        if not self.cmdfile:
-            return
-        nlayers = 0
-        try:
-            fd = open(self.cmdfile, 'r')
-                cmd = utils.split(line.strip())
-                ltype = None
-                if cmd[0] == 'd.rast':
-                    ltype = 'raster'
-                elif cmd[0] == 'd.vect':
-                    ltype = 'vector'
-                name = utils.GetLayerNameFromCmd(cmd, fullyQualified = True,
-                                                 layerType = ltype)[0]
-                self.AddLayer(type = ltype, command = cmd, l_active = False, name = name)
-                nlayers += 1
-            grass.warning(_("Unable to read cmdfile '%(cmd)s'. Details: %(det)s") % \
-                              { 'cmd' : self.cmdfile, 'det' : e })
-            return
+    def GetMapsMasksAndOpacities(self, force, guiFrame, windres):
+        Used by Render function.
-        fd.close()
-        Debug.msg(1, "Map.GetLayersFromCmdFile(): cmdfile=%s" % self.cmdfile)
-        Debug.msg(1, "                            nlayers=%d" % nlayers)
-    def _parseCmdFile(self):
-        """!Parse cmd file for standalone application
+        @return maps, masks, opacities
-        nlayers = 0
-        try:
-            grass.try_remove(self.mapfile)
-            cmdLines = fd.readlines()
-            RunCommand('g.gisenv',
-                       set = 'MONITOR_%s_CMDFILE=' % self.monitor)
-            for cmd in cmdLines:
-                cmdStr = utils.split(cmd.strip())
-                cmd = utils.CmdToTuple(cmdStr)
-                RunCommand(cmd[0], **cmd[1])
-                nlayers += 1
-                       set = 'MONITOR_%s_CMDFILE=%s' % (self.monitor, self.cmdfile))
-            return
-        fd.close()
-        Debug.msg(1, "Map.__parseCmdFile(): cmdfile=%s" % self.cmdfile)
-        return nlayers
-    def _renderCmdFile(self, force, windres):
-        if not force:
-            return ([self.mapfileCmd],
-                    [self.maskfileCmd],
-                    ['1.0'])
-        region = os.environ["GRASS_REGION"] = self.SetRegion(windres)
-        self._writeEnvFile({'GRASS_REGION' : region})
-        currMon = grass.gisenv()['MONITOR']
-        if currMon != self.monitor:
-                       set = 'MONITOR=%s' % self.monitor)
-        grass.try_remove(self.mapfileCmd) # GRASS_PNG_READ is TRUE
-        nlayers = self._parseCmdFile()
-        if self.overlays:
-                       unset = 'MONITOR') # GRASS_RENDER_IMMEDIATE doesn't like monitors
-            driver = UserSettings.Get(group = 'display', key = 'driver', subkey = 'type')
-            if driver == 'png':
-                os.environ["GRASS_RENDER_IMMEDIATE"] = "png"
-            else:
-                os.environ["GRASS_RENDER_IMMEDIATE"] = "cairo"
-            self._renderLayers(overlaysOnly = True)
-            del os.environ["GRASS_RENDER_IMMEDIATE"]
-                       set = 'MONITOR=%s' % currMon)
-        if nlayers > 0:
-                    ['1.0'])
-        else:
-            return ([], [], [])
+        return self._renderLayers(force, guiFrame)
     def Render(self, force = False, mapWindow = None, windres = False):
         """!Creates final image composite
@@ -1020,7 +875,7 @@
         should be avaliable in wxPython library
         @param force force rendering
-        @param reference for MapFrame instance (for progress bar)
+        @param mapWindow reference for MapFrame or similar instance for progress bar
         @param windres use region resolution (True) otherwise display resolution
         @return name of file with rendered image or None
@@ -1041,10 +896,7 @@
         else:
-        if self.cmdfile:
-            maps, masks, opacities = self._renderCmdFile(force, windres)
-        else:
-            maps, masks, opacities = self._renderLayers(force, mapWindow)
+        maps, masks, opacities = self.GetMapsMasksAndOpacities(force, mapWindow, windres)
         # ugly hack for MSYS
         if sys.platform != 'win32':
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py	2012-05-25 14:59:56 UTC (rev 51757)
+++ grass/trunk/gui/wxpython/mapdisp/main.py	2012-05-25 15:10:47 UTC (rev 51758)
@@ -29,10 +29,12 @@
 from core          import globalvar
 import wx
+from core          import utils
 from core.gcmd     import RunCommand
 from core.render   import Map
 from mapdisp.frame import MapFrame
 from grass.script  import core as grass
+from core.debug    import Debug
 # for standalone app
 monFile = { 'cmd' : None,
@@ -43,12 +45,201 @@
 monSize = list(globalvar.MAP_WINDOW_SIZE)
+class DMonMap(Map):
+    def __init__(self, gisrc = None, cmdfile = None, mapfile = None, envfile = None, monitor = None):
+        """!Map composition (stack of map layers and overlays)
+        @param cmdline full path to the cmd file (defined by d.mon)
+        @param mapfile full path to the map file (defined by d.mon)
+        @param envfile full path to the env file (defined by d.mon)
+        @param monitor name of monitor (defined by d.mon)
+        Map.__init__(self)
+        # environment settings
+        self.env   = dict()
+        self.cmdfile = cmdfile
+        self.envfile = envfile
+        self.monitor = monitor
+        if mapfile:
+            self.mapfileCmd = mapfile
+            self.maskfileCmd = os.path.splitext(mapfile)[0] + '.pgm'
+        # generated file for g.pnmcomp output for rendering the map
+        self.mapfile = grass.tempfile(create = False) + '.ppm'
+        # GRASS environment variable (for rendering)
+        env = {"GRASS_BACKGROUNDCOLOR" : "FFFFFF",
+               "GRASS_COMPRESSION"     : "0",
+               "GRASS_TRUECOLOR"       : "TRUE",
+               "GRASS_TRANSPARENT"     : "TRUE",
+               "GRASS_PNG_READ"        : "FALSE",
+        self._writeEnvFile(env)
+        self._writeEnvFile({"GRASS_PNG_READ" : "TRUE"})
+        for k, v in env.iteritems():
+            os.environ[k] = v
+    def GetLayersFromCmdFile(self):
+        """!Get list of map layers from cmdfile
+        if not self.cmdfile:
+            return
+        nlayers = 0
+        try:
+            fd = open(self.cmdfile, 'r')
+            for line in fd.readlines():
+                cmd = utils.split(line.strip())
+                ltype = None
+                if cmd[0] == 'd.rast':
+                    ltype = 'raster'
+                elif cmd[0] == 'd.vect':
+                    ltype = 'vector'
+                name = utils.GetLayerNameFromCmd(cmd, fullyQualified = True,
+                                                 layerType = ltype)[0]
+                self.AddLayer(type = ltype, command = cmd, l_active = False, name = name)
+                nlayers += 1
+        except IOError, e:
+            grass.warning(_("Unable to read cmdfile '%(cmd)s'. Details: %(det)s") % \
+                              { 'cmd' : self.cmdfile, 'det' : e })
+            return
+        fd.close()
+        Debug.msg(1, "Map.GetLayersFromCmdFile(): cmdfile=%s" % self.cmdfile)
+        Debug.msg(1, "                            nlayers=%d" % nlayers)
+    def _parseCmdFile(self):
+        """!Parse cmd file for standalone application
+        nlayers = 0
+        try:
+            grass.try_remove(self.mapfile)
+            cmdLines = fd.readlines()
+            RunCommand('g.gisenv',
+                       set = 'MONITOR_%s_CMDFILE=' % self.monitor)
+            for cmd in cmdLines:
+                cmdStr = utils.split(cmd.strip())
+                cmd = utils.CmdToTuple(cmdStr)
+                RunCommand(cmd[0], **cmd[1])
+                nlayers += 1
+                       set = 'MONITOR_%s_CMDFILE=%s' % (self.monitor, self.cmdfile))
+            return
+        fd.close()
+        Debug.msg(1, "Map.__parseCmdFile(): cmdfile=%s" % self.cmdfile)
+        return nlayers
+    def _renderCmdFile(self, force, windres):
+        if not force:
+            return ([self.mapfileCmd],
+                    [self.maskfileCmd],
+                    ['1.0'])
+        region = os.environ["GRASS_REGION"] = self.SetRegion(windres)
+        self._writeEnvFile({'GRASS_REGION' : region})
+        currMon = grass.gisenv()['MONITOR']
+        if currMon != self.monitor:
+                       set = 'MONITOR=%s' % self.monitor)
+        grass.try_remove(self.mapfileCmd) # GRASS_PNG_READ is TRUE
+        nlayers = self._parseCmdFile()
+        if self.overlays:
+                       unset = 'MONITOR') # GRASS_RENDER_IMMEDIATE doesn't like monitors
+            driver = UserSettings.Get(group = 'display', key = 'driver', subkey = 'type')
+            if driver == 'png':
+                os.environ["GRASS_RENDER_IMMEDIATE"] = "png"
+            else:
+                os.environ["GRASS_RENDER_IMMEDIATE"] = "cairo"
+            self._renderLayers(overlaysOnly = True)
+            del os.environ["GRASS_RENDER_IMMEDIATE"]
+                       set = 'MONITOR=%s' % currMon)
+        if nlayers > 0:
+                    ['1.0'])
+        else:
+            return ([], [], [])
+    def _writeEnvFile(self, data):
+        """!Write display-related variable to the file (used for
+        standalone app)
+        if not self.envfile:
+            return
+        try:
+            fd = open(self.envfile, "r")
+                key, value = line.split('=')
+                if key not in data.keys():
+                    data[key] = value
+            fd.close()
+            fd = open(self.envfile, "w")
+            for k, v in data.iteritems():
+                fd.write('%s=%s\n' % (k.strip(), str(v).strip()))
+            grass.warning(_("Unable to open file '%(file)s' for writting. Details: %(det)s") % \
+                              { 'cmd' : self.envfile, 'det' : e })
+            return
+        fd.close()
+    def ChangeMapSize(self, (width, height)):
+        """!Change size of rendered map.
+        @param width,height map size
+        Map.ChangeMapSize(self, (width, height))
+        self._writeEnvFile({'GRASS_WIDTH' : self.width,
+                            'GRASS_HEIGHT' : self.height})
+        return self._renderCmdFile(force, windres)
 class MapApp(wx.App):
     def OnInit(self):
         wx.InitAllImageHandlers()
         if __name__ == "__main__":
             self.cmdTimeStamp = os.path.getmtime(monFile['cmd'])
-            self.Map = Map(cmdfile = monFile['cmd'], mapfile = monFile['map'],
+            self.Map = DMonMap(cmdfile = monFile['cmd'], mapfile = monFile['map'],
                            envfile = monFile['env'], monitor = monName)
         else:
             self.Map = None
@@ -56,6 +247,7 @@
         self.mapFrm = MapFrame(parent = None, id = wx.ID_ANY, Map = self.Map,
                                size = monSize)
         # self.SetTopWindow(Map)
+        self.mapFrm.GetMapWindow().SetAlwaysRenderEnabled(True)
         self.mapFrm.Show()
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py	2012-05-25 14:59:56 UTC (rev 51757)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py	2012-05-25 15:10:47 UTC (rev 51758)
@@ -55,6 +55,7 @@
         # flags
         self.resize = False # indicates whether or not a resize event has taken place
         self.dragimg = None # initialize variable for map panning
+        self.alwaysRender = False # if it always sets render to True in self.UpdateMap()
         # variables for drawing on DC
         self.pen = None      # pen for drawing zoom boxes, etc.
@@ -525,6 +526,12 @@
         return img
+    def SetAlwaysRenderEnabled(self, alwaysRender = True):
+        self.alwaysRender = alwaysRender
+    def IsAlwaysRenderEnabled(self):
+        return self.alwaysRender
     def UpdateMap(self, render = True, renderVector = True):
         """!Updates the canvas anytime there is a change to the
         underlaying images or to the geometry of the canvas.
@@ -536,8 +543,9 @@
         self.resize = False
-        if not self.Map.cmdfile and self.img is None:
-            render = True
+        # was if self.Map.cmdfile and ...
+        if self.IsAlwaysRenderEnabled() and self.img is None:
+                render = True
         # initialize process bar (only on 'render')
