[GRASS-SVN] r51779 - grass/trunk/temporal/t.rast.to.rast3
svn_grass at osgeo.org
Sat May 26 08:43:48 EDT 2012
Author: huhabla
Date: 2012-05-26 05:43:48 -0700 (Sat, 26 May 2012)
New Revision: 51779
grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
grass/trunk/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh
Using temporal information to scale the z-axis of space time voxel cubes.
Modified: grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
--- grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2012-05-26 12:39:10 UTC (rev 51778)
+++ grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2012-05-26 12:43:48 UTC (rev 51779)
@@ -30,6 +30,7 @@
import os
import grass.script as grass
import grass.temporal as tgis
+from datetime import datetime
@@ -55,22 +56,59 @@
grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
sp.select()
+ grass.use_temp_region()
maps = sp.get_registered_maps_as_objects_by_granularity()
+ num_maps = len(maps)
# Get the granularity and set bottom, top and top-bottom resolution
granularity = sp.get_granularity()
+ # This is the reference time to scale the z coordinate
+ reftime = datetime(1900, 1, 1)
+ # We set top and bottom according to the start time in relation to the date 1900-01-01 00:00:00
+ # In case of days, hours, minutes and seconds, a double number is used to represent days and fracs of a day
+ # Space time voxel cubes with montly or yearly granularity can not be mixed with other temporal units
+ # Compatible temporal units are : days, hours, minutes and seconds
+ # Incompatible are years and moths
+ start, end = sp.get_valid_time()
if sp.is_time_absolute():
unit = granularity.split(" ")[1]
granularity = int(granularity.split(" ")[0])
+ if unit == "years":
+ bottom = start.year - 1900
+ top = granularity * num_maps
+ elif unit == "months":
+ bottom = (start.year - 1900) * 12 + start.month
+ else:
+ bottom = tgis.time_delta_to_relative_time(start - reftime)
+ days = 0
+ hours = 0
+ minutes = 0
+ seconds = 0
+ if unit == "days":
+ days = granularity
+ if unit == "hours":
+ hours = granularity
+ if unit == "minutes":
+ minutes = granularity
+ if unit == "seconds":
+ seconds = granularity
+ granularity = days + hours/24.0 + minutes/1440.0 + seconds/86400.0
else:
unit = sp.get_relative_time_unit()
+ bottom = start
- num_maps = len(maps)
- bottom = 0
- top = granularity * num_maps
+ top = bottom + granularity * num_maps
ret = grass.run_command("g.region", t=top, b=bottom, tbres=granularity)
if ret != 0:
Modified: grass/trunk/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh
--- grass/trunk/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh 2012-05-26 12:39:10 UTC (rev 51778)
+++ grass/trunk/temporal/t.rast.to.rast3/test.t.rast.to.rast3.sh 2012-05-26 12:43:48 UTC (rev 51779)
@@ -3,7 +3,7 @@
# We need to set a specific region in the
# @preprocess step of this test.
# The region setting should work for UTM and LL test locations
-g.region s=0 n=80 w=0 e=120 b=0 t=1 res=10 res3=1 -p3
+g.region s=0 n=80 w=0 e=120 b=0 t=1 res=10 res3=10 -p3
r.mapcalc --o expr="prec_1 = 100"
r.mapcalc --o expr="prec_2 = 200"
@@ -18,14 +18,49 @@
t.create --o type=strds temporaltype=absolute output=precip_abs title="A test" descr="A test"
t.create --o type=strds temporaltype=relative output=precip_rel title="A test" descr="A test"
-t.register --o --v -i type=rast input=precip_abs maps=prec_1,prec_2,prec_3 start="2001-01-01" increment="1 months"
+t.register --o --v -i type=rast input=precip_abs maps=prec_1,prec_2,prec_3 start="2001-01-01" increment="3 years"
t.info type=strds input=precip_abs
t.rast.to.rast3 --o input=precip_abs output=precipitation
t.info type=rast3d input=precipitation
r3.info precipitation
-t.register --o --v -i type=rast input=precip_rel maps=prec_4,prec_5,prec_6 start=0 increment=100 unit=years
+t.register --o --v -i type=rast input=precip_abs maps=prec_1,prec_2,prec_3 start="2001-01-01" increment="2 months"
+t.info type=strds input=precip_abs
+t.rast.to.rast3 --o input=precip_abs output=precipitation
+t.info type=rast3d input=precipitation
+r3.info precipitation
+t.register --o --v -i type=rast input=precip_abs maps=prec_1,prec_2,prec_3 start="2001-01-01" increment="8 days"
+t.register --o --v -i type=rast input=precip_abs maps=prec_1,prec_2,prec_3 start="2001-01-01" increment="6 hours"
+t.register --o --v -i type=rast input=precip_abs maps=prec_1,prec_2,prec_3 start="2001-01-01" increment="30 minutes"
+t.register --o --v -i type=rast input=precip_abs maps=prec_1,prec_2,prec_3 start="2001-01-01" increment="1 seconds"
+t.register --o --v -i type=rast input=precip_rel maps=prec_4,prec_5,prec_6 start=1000 increment=100 unit=years
t.info type=strds input=precip_rel
t.rast.to.rast3 --o input=precip_rel output=precipitation
