[GRASS-SVN] r51785 - grass/trunk/raster/r.lake
svn_grass at osgeo.org
Sat May 26 10:09:12 EDT 2012
Author: neteler
Date: 2012-05-26 07:09:12 -0700 (Sat, 26 May 2012)
New Revision: 51785
grass/trunk/raster/r.lake/
grass/trunk/raster/r.lake/r.lake.html
example added
Property changes on: grass/trunk/raster/r.lake
___________________________________________________________________
Modified: svn:ignore
- OBJ.*
+ OBJ.*
*.tmp.html
Modified: grass/trunk/raster/r.lake/r.lake.html
--- grass/trunk/raster/r.lake/r.lake.html 2012-05-26 14:08:45 UTC (rev 51784)
+++ grass/trunk/raster/r.lake/r.lake.html 2012-05-26 14:09:12 UTC (rev 51785)
@@ -71,12 +71,37 @@
<li>The entire map is loaded into RAM.</li>
<li>The module is NOT large file safe. (due to the previous point)</li>
<li>A completely negative seed map will not work! At least one cell must have
- a value >0. Output from <em>r.lake -n</em> can NOT be used as input in the next run.</li>
+ a value > 0. Output from <em>r.lake -n</em> can NOT be used as input in the next run.</li>
</ul>
+<h2>EXAMPLE</h2>
+Example of small flooding along a street (North Carolina sample dataset):
+<div class="code"><pre>
+g.region rast=elev_lid792_1m -p
+# water accumulation next to street dam
+r.lake elev_lid792_1m xy=638759.3,220264.1 wl=113.4 lake=flooding
+# draw resulting lake map over shaded terrain map
+r.shaded.relief elev_lid792_1m
+d.rast elev_lid792_1m.shade
+d.rast -o flooding
+d.vect streets_wake
+d.vect bldg_cmcl_pol type=area
+</pre></div>
+<p>
+<center>
+<img src="r_lake_lidar_dem.png" border=1><br>
+Small flooding along a street (<em>r.lake</em>, using Lidar 1m DEM)
+</center>
<h2>SEE ALSO</h2>
-<em><a href="r.mapcalc.html">r.mapcalc</a>,
+<em>
+<a href="r.mapcalc.html">r.mapcalc</a>,
<a href="r.grow.html">r.grow</a>,
<a href="r.plane.html">r.plane</a></em>
