[GRASS-SVN] r51791 - in grass-addons/grass7/vector: .
v.in.geopaparazzi
svn_grass at osgeo.org
Sat May 26 10:42:15 EDT 2012
Author: lucadelu
Date: 2012-05-26 07:42:14 -0700 (Sat, 26 May 2012)
New Revision: 51791
Added:
grass-addons/grass7/vector/v.in.geopaparazzi/
grass-addons/grass7/vector/v.in.geopaparazzi/Makefile
grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.html
grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.py
add v.in.geopaparazzi
Added: grass-addons/grass7/vector/v.in.geopaparazzi/Makefile
--- grass-addons/grass7/vector/v.in.geopaparazzi/Makefile (rev 0)
+++ grass-addons/grass7/vector/v.in.geopaparazzi/Makefile 2012-05-26 14:42:14 UTC (rev 51791)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.in.geopaparazzi
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.html
--- grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.html (rev 0)
+++ grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.html 2012-05-26 14:42:14 UTC (rev 51791)
@@ -0,0 +1,15 @@
+<h2>DESCRIPTION</h2>
+<em>v.in.geopaparazzi</em> imports all elements saved into Geopaparazzi. You can import bookmarks, images (warning the path to images it's relative of Android device), notes (one layer for each category) and tracks.
+<h2>REFERENCES</h2>
+<a href="http://code.google.com/p/geopaparazzi/">Geopaparazzi</a>
+<br>
+<a href="http://code.google.com/p/geopaparazzi/wiki/DbTables">Geopaparazzi Tables schema</a>
+<h2>AUTHORS</h2>
+Luca Delucchi
+<p><i>Last changed: $Date: 2012-05-26 16:35:22 +0100 (Sat, 26 May 2012) $</i>
Added: grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.py
--- grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.py (rev 0)
+++ grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.py 2012-05-26 14:42:14 UTC (rev 51791)
@@ -0,0 +1,349 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: v.in.geopaparazzi
+# AUTHOR(S): Luca Delucchi
+# PURPOSE: Import data from Geopaparazzi database
+# COPYRIGHT: (C) 2012 by the GRASS Development Team
+# This program is free software under the GNU General
+# Public License (>=v2). Read the file COPYING that
+# comes with GRASS for details.
+#%module
+#% description: Return the barycenter of a cloud of point.
+#% keywords: vector
+#%end
+#%flag
+#% key: b
+#% description: Import bookmarks
+#%end
+#%flag
+#% key: i
+#% description: Import images
+#%end
+#%flag
+#% key: n
+#% description: Import notes
+#%end
+#%flag
+#% key: t
+#% description: Import tracks
+#%end
+#%flag
+#% key: z
+#% description: Create a 3D line from 3 column data
+#%end
+#%option G_OPT_DB_DATABASE
+#% description: Input Geopaparazzi database
+#%end
+#%option
+#% key: basename
+#% type: string
+#% gisprompt: new_file,file,output
+#% description: Base name for output file
+#% required : yes
+#%end
+import sys, os
+import shutil
+from grass.script import core as grass
+from grass.script import db as grassdb
+import json
+import pdb
+def returnClear(c,query):
+ """Funtion to return a list of value from a query"""
+ c.execute(query)
+ bad = c.fetchall()
+ good = []
+ for b in bad:
+ good.append(b[0])
+ return good
+def returnAll(c,query):
+ """Function to return all the values from a query"""
+ c.execute(query)
+ return c.fetchall()
+def checkEle(c,table):
+ """Function to return the number of elements in a table"""
+ c.execute("select count(_id) from %s" % table)
+ return c.fetchone()[0]
+def returnFormKeys(attr):
+ """Function to return a string with the columns' name and type of form"""
+ js=json.loads(attr[0][3])
+ values=js['form']['formitems']
+ res = ''
+ for v in values:
+ if v['type'].lower() == 'double':
+ typ = 'double'
+ elif v['type'].lower() == 'int' or v['type'].lower() == 'integer':
+ typ = 'int'
+ elif v['type'].lower() == 'boolean':
+ typ = 'boolean'
+ else:
+ typ = 'text'
+ res += ", %s %s" % (v['key'].replace(' ', '_'), typ)
+ return res
+def returnFormValues(attr):
+ """Function to return a string with the values of form"""
+ js=json.loads(attr)
+ return','.join("'%s'" % v['value'] for v in values)
+def importGeom(vname, typ, c, owrite, z, cat = None):
+ psel = "SELECT lat, lon"
+ if z == 'z':
+ psel += ", altim"
+ zcol = 3
+ else:
+ zcol = 0
+ psel += " from %s" % typ
+ if cat:
+ psel += " where cat = '%s' order by _id" % cat
+ points = returnAll(c, psel)
+ wpoi = '\n'.join(['|'.join([str(col) for col in row]) for row in points])
+ # import points using v.in.ascii
+ if grass.write_command('v.in.ascii', flags = 't%s' % z, input='-',
+ output = vname, stdin = wpoi, z = zcol,
+ overwrite = owrite, quiet = True) != 0:
+ grass.fatal(_("Error importing %s" % vname))
+ return points
+def main():
+ indb = options['database']
+ prefix = options['basename']
+ env = grass.gisenv()
+ # check if 3d or not
+ if flags['z']:
+ d3 = 'z'
+ else:
+ d3 = ''
+ owrite = grass.overwrite()
+ # check if location it is latlong
+ if grass.locn_is_latlong():
+ locn = True
+ else:
+ locn = False
+ # connection to sqlite geopaparazzi database
+ import sqlite3
+ conn = sqlite3.connect(indb)
+ curs = conn.cursor()
+ # if it is not a latlong location create a latlong location on the fly
+ if not locn:
+ # create new location and move to it creating new gisrc file
+ new_loc = grass.basename(grass.tempfile(create=False))
+ grass.create_location(dbase = env['GISDBASE'],
+ location = 'geopaparazzi_%s' % new_loc,
+ epsg = '4326',
+ desc = 'Temporary location for v.in.geopaparazzi')
+ grc = os.getenv('GISRC')
+ shutil.copyfile(grc,grc+'.old')
+ newrc = open(grc,'w')
+ newrc.write('GISDBASE: %s\n' % env['GISDBASE'])
+ newrc.write('LOCATION_NAME: geopaparazzi_%s\n' % new_loc)
+ newrc.write('MAPSET: PERMANENT\n')
+ newrc.write('GRASS_GUI: text\n')
+ newrc.close()
+ # load bookmarks
+ if flags['b']:
+ # check if elements in bookmarks table are more the 0
+ if checkEle(curs, 'bookmarks') != 0:
+ bookname = prefix + '_book'
+ pois = importGeom(bookname, 'bookmarks', curs, owrite, '')
+ sql = 'CREATE TABLE %s (cat int, text text)' % bookname
+ grass.write_command('db.execute', input='-', stdin = sql)
+ # select attributes
+ sql = "select text from bookmarks order by _id"
+ allattri = returnClear(curs,sql)
+ # add values using insert statement
+ idcat = 1
+ for row in allattri:
+ values = "%d,'%s'" % (idcat,str(row))
+ sql = "insert into %s values(%s)" % (bookname, values)
+ idcat += 1
+ # at the end connect table to vector
+ grass.run_command('v.db.connect', map = bookname,
+ table = bookname, quiet = True)
+ else:
+ grass.warning(_("No bookmarks found, escape them"))
+ # load images
+ if flags['i']:
+ # check if elements in images table are more the 0
+ if checkEle(curs, 'images') != 0:
+ imagename = prefix + '_image'
+ pois = importGeom(imagename, 'images', curs, owrite, d3)
+ sql = 'CREATE TABLE %s (cat int, azim int, ' % imagename
+ sql += 'path text, ts text, text text)'
+ sql = "select azim, path, ts, text from images order by _id"
+ allattri = returnAll(curs,sql)
+ idcat = 1
+ values = "%d,'%d','%s','%s','%s'" % (idcat,row[0],
+ str(row[1]), str(row[2]), str(row[3]))
+ sql = "insert into %s values(%s)" % (imagename, values)
+ idcat += 1
+ grass.run_command('v.db.connect', map = imagename,
+ table = imagename, quiet = True)
+ else:
+ grass.warning(_("No images found, escape them"))
+ # if tracks or nodes should be imported create a connection with sqlite3
+ # load notes
+ if flags['n']:
+ # check if elements in notes table are more the 0
+ if checkEle(curs, 'notes') != 0:
+ # select each categories
+ categories = returnClear(curs,"select cat from notes group by cat")
+ # for each category
+ for cat in categories:
+ # select lat, lon for create point layer
+ catname = prefix + '_notes_' + cat
+ pois = importGeom(catname, 'notes', curs, owrite, d3, cat )
+ # select form to understand the number
+ forms = returnClear(curs,"select _id from notes where cat = '%s' " \
+ "and form is not null order by _id" % cat)
+ # if number of form is different from 0 and number of point
+ # remove the vector because some form it is different
+ if len(forms) != 0 and len(forms) != len(pois):
+ grass.run_command('g.remove', vect = catname, quiet = True)
+ grass.warning(_("Vector %s not imported because number of " \
+ "points and form is different"))
+ # if form it's 0 there is no form
+ elif len(forms) == 0:
+ # create table without form
+ sql = 'CREATE TABLE %s (cat int, ts text, ' % catname
+ sql += 'text text, geopap_cat text)'
+ sql = "select ts, text, cat from notes where "\
+ "cat='%s' order by _id" % cat
+ idcat = 1
+ values = "%d,'%s','%s','%s'" % (idcat,str(row[0]),
+ str(row[1]), str(row[2]))
+ sql = "insert into %s values(%s)" % (catname, values)
+ idcat += 1
+ grass.run_command('v.db.connect', map = catname,
+ table = catname, quiet = True)
+ # create table with form
+ else:
+ # select all the attribute
+ sql = "select ts, text, cat, form from notes where "\
+ # return string of form's categories too create table
+ keys = returnFormKeys(allattri)
+ sql += 'text text, geopap_cat text %s)' % keys
+ # it's for the number of categories
+ idcat = 1
+ # for each feature insert value
+ values = "%d,'%s','%s','%s'," % (idcat,str(row[0]),
+ values += returnFormValues(row[3])
+ idcat += 1
+ # at the end connect table with vector
+ else:
+ grass.warning(_("No notes found, escape them"))
+ # load tracks
+ if flags['t']:
+ if checkEle(curs, 'gpslogs') != 0:
+ tracksname = prefix + '_tracks'
+ # define string for insert data at the end
+ tracks = ''
+ # return ids of tracks
+ ids = returnClear(curs,"select _id from gpslogs")
+ # for each track
+ for i in ids:
+ # select all the points coordinates
+ tsel = "select lon, lat"
+ if flags['z']:
+ tsel += ", altim"
+ tsel += " from gpslog_data where logid=%s order by _id" % i
+ trackpoints = returnAll(curs,tsel)
+ wpoi = '\n'.join(['|'.join([str(col) for col in row]) for row in trackpoints])
+ tracks += "%s\n" % wpoi
+ if flags['z']:
+ tracks += 'NaN|NaN|Nan\n'
+ else:
+ tracks += 'NaN|Nan\n'
+ # import lines
+ if grass.write_command('v.in.lines', flags = d3, input = '-',
+ out = tracksname, stdin = tracks,
+ grass.fatal(_("Error importing %s" % tracksname))
+ # create table for line
+ sql = 'CREATE TABLE %s (cat int, startts text, endts text, ' % tracksname
+ sql += ' text text, color text, width int)'
+ sql = "select logid, startts, endts, text, color, width from gpslogs, "\
+ "gpslogsproperties where gpslogs._id=gpslogsproperties.logid"
+ # return attributes
+ # for each line insert attribute
+ values = "%d,'%s','%s','%s','%s',%d" % (row[0],str(row[1]),
+ str(row[2]), str(row[3]), str(row[4]), row[5])
+ sql = "insert into %s values(%s)" % (tracksname, values)
+ # at the end connect map with table
+ grass.run_command('v.db.connect', map = tracksname,
+ table = tracksname, quiet = True)
+ else:
+ grass.warning(_("No tracks found, escape them"))
+ # if location it's not latlong reproject it
+ if not locn:
+ # copy restore the original location
+ shutil.copyfile(grc+'.old',grc)
+ # reproject bookmarks
+ if flags['b'] and checkEle(curs, 'bookmarks') != 0:
+ grass.run_command('v.proj', quiet = True, input = bookname,
+ mapset = 'PERMANENT')
+ # reproject images
+ if flags['i'] and checkEle(curs, 'images') != 0:
+ grass.run_command('v.proj', quiet = True, input = imagename,
+ # reproject notes
+ if flags['n'] and checkEle(curs, 'notes') != 0:
+ catname = prefix + '_node_' + cat
+ grass.run_command('v.proj', quiet = True, input = catname,
+ # reproject track
+ if flags['t'] and checkEle(curs, 'gpslogs') != 0:
+ grass.run_command('v.proj', quiet = True, input = tracksname,
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
