[GRASS-SVN] r51801 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat May 26 11:22:01 EDT 2012
Author: mmetz
Date: 2012-05-26 08:22:00 -0700 (Sat, 26 May 2012)
New Revision: 51801
grass/trunk/lib/vector/Vlib/select.c
adjust Vlib to changed rtree
Modified: grass/trunk/lib/vector/Vlib/select.c
--- grass/trunk/lib/vector/Vlib/select.c 2012-05-26 15:21:35 UTC (rev 51800)
+++ grass/trunk/lib/vector/Vlib/select.c 2012-05-26 15:22:00 UTC (rev 51801)
@@ -62,8 +62,14 @@
void Vect_spatial_index_add_item(struct spatial_index * si, int id,
const struct bound_box * box)
- struct RTree_Rect rect;
+ static struct RTree_Rect rect;
+ static int rect_init = 0;
+ if (!rect_init) {
+ rect.boundary = G_malloc(si->si_tree->nsides_alloc * sizeof(RectReal));
+ rect_init = si->si_tree->nsides_alloc;
G_debug(3, "Vect_spatial_index_add_item(): id = %d", id);
rect.boundary[0] = box->W;
@@ -87,8 +93,14 @@
int ret;
+ if (!rect_init) {
G_debug(3, "Vect_spatial_index_del_item(): id = %d", id);
@@ -125,8 +137,14 @@
Vect_spatial_index_select(const struct spatial_index * si, const struct bound_box * box,
struct ilist *list)
+ if (!rect_init) {
G_debug(3, "Vect_spatial_index_select()");
Vect_reset_list(list);
