[GRASS-SVN] r51818 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Sun May 27 04:26:36 PDT 2012
Author: neteler
Date: 2012-05-27 04:26:36 -0700 (Sun, 27 May 2012)
New Revision: 51818
grass/branches/develbranch_6/locale/po/grassmods_ar.po
grass/branches/develbranch_6/locale/po/grassmods_cs.po
grass/branches/develbranch_6/locale/po/grassmods_de.po
grass/branches/develbranch_6/locale/po/grassmods_el.po
grass/branches/develbranch_6/locale/po/grassmods_es.po
grass/branches/develbranch_6/locale/po/grassmods_fr.po
grass/branches/develbranch_6/locale/po/grassmods_hi.po
grass/branches/develbranch_6/locale/po/grassmods_it.po
grass/branches/develbranch_6/locale/po/grassmods_ja.po
grass/branches/develbranch_6/locale/po/grassmods_ko.po
grass/branches/develbranch_6/locale/po/grassmods_lv.po
grass/branches/develbranch_6/locale/po/grassmods_mr.po
grass/branches/develbranch_6/locale/po/grassmods_pl.po
grass/branches/develbranch_6/locale/po/grassmods_pt.po
grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
grass/branches/develbranch_6/locale/po/grassmods_ru.po
grass/branches/develbranch_6/locale/po/grassmods_sl.po
grass/branches/develbranch_6/locale/po/grassmods_th.po
grass/branches/develbranch_6/locale/po/grassmods_tr.po
grass/branches/develbranch_6/locale/po/grassmods_vi.po
grass/branches/develbranch_6/locale/po/grassmods_zh.po
fix typo (r51809)
Modified: grass/branches/develbranch_6/locale/po/grassmods_ar.po
--- grass/branches/develbranch_6/locale/po/grassmods_ar.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_ar.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -2062,7 +2062,7 @@
#: ../misc/m.nviz.image/args.c:1045
#, c-format
-msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d"
+msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d)"
msgstr ""
#: ../misc/m.nviz.image/volume.c:42 ../misc/m.nviz.image/volume.c:125
@@ -2090,7 +2090,7 @@
#: ../misc/m.nviz.image/volume.c:162 ../misc/m.nviz.image/volume.c:173
#: ../misc/m.nviz.image/volume.c:180
#, fuzzy, c-format
-msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
+msgid "Unable to set isosurface (%d) attribute (%d) of volume %d)"
msgstr "ÙÙ
ÙÙ
ÙÙ Ø§Ø®ØªÙØ§Ø± Ø§ÙØ¨ÙØ§ÙØ§Øª Ù
Ù Ø§ÙØ¬Ø¯ÙÙ"
#: ../misc/m.nviz.image/volume.c:144 ../misc/m.nviz.image/surface.c:129
Modified: grass/branches/develbranch_6/locale/po/grassmods_cs.po
--- grass/branches/develbranch_6/locale/po/grassmods_cs.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_cs.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -2049,7 +2049,7 @@
#, c-format
msgstr ""
@@ -2077,7 +2077,7 @@
#, fuzzy, c-format
msgstr "Nelze získat atributové data pro cat= %d"
Modified: grass/branches/develbranch_6/locale/po/grassmods_de.po
--- grass/branches/develbranch_6/locale/po/grassmods_de.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_de.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -1945,7 +1945,7 @@
#, c-format
msgstr "Inkonsistente Attributanzahl (<%s/%s> %d: <%s> %d, <%s> %d."
@@ -1973,7 +1973,7 @@
#, c-format
msgstr "Kann die Isofläche (%d) Attribut (%d) des Volumens %d nicht setzten."
Modified: grass/branches/develbranch_6/locale/po/grassmods_el.po
--- grass/branches/develbranch_6/locale/po/grassmods_el.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_el.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -1977,7 +1977,7 @@
#, c-format
msgstr ""
@@ -2005,7 +2005,7 @@
#, c-format
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_es.po
--- grass/branches/develbranch_6/locale/po/grassmods_es.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_es.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -2010,7 +2010,7 @@
#, c-format
msgstr "Número de atributos incoherente (<%s/%s> %d: <%s> %d, <%s> %d"
@@ -2038,7 +2038,7 @@
#, fuzzy, c-format
msgstr "No se pueden seleccionar los atributos de los puntos de <%s>"
Modified: grass/branches/develbranch_6/locale/po/grassmods_fr.po
--- grass/branches/develbranch_6/locale/po/grassmods_fr.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_fr.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -2117,7 +2117,7 @@
#, c-format
msgstr "Nombre d'attributs incohérent (<%s/%s> %d: <%s> %d, <%s> %d"
@@ -2145,7 +2145,7 @@
#, fuzzy, c-format
msgstr "Impossible de sélectionner des données dans la table attributaire"
Modified: grass/branches/develbranch_6/locale/po/grassmods_hi.po
--- grass/branches/develbranch_6/locale/po/grassmods_hi.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_hi.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -2110,7 +2110,7 @@
#, c-format
msgstr ""
@@ -2138,7 +2138,7 @@
#, fuzzy, c-format
msgstr "à¤à¥ लिà¤"
Modified: grass/branches/develbranch_6/locale/po/grassmods_it.po
--- grass/branches/develbranch_6/locale/po/grassmods_it.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_it.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -1956,7 +1956,7 @@
#, c-format
msgstr ""
@@ -1984,7 +1984,7 @@
#, c-format
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_ja.po
--- grass/branches/develbranch_6/locale/po/grassmods_ja.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_ja.po 2012-05-27 11:26:36 UTC (rev 51818)
#, c-format
msgstr "屿§æ°ãä¸è´ãã¦ãã¾ãã (<%s/%s> %d: <%s> %d, <%s> %d "
#, c-format
msgstr "ç°æ§æ²é¢ (%d) 屿§ (%d) ï¼ããªã¥ã¼ã %d ã®ï¼ ãè¨å®ã§ãã¾ãã"
Modified: grass/branches/develbranch_6/locale/po/grassmods_ko.po
--- grass/branches/develbranch_6/locale/po/grassmods_ko.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_ko.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -1998,7 +1998,7 @@
#, c-format
msgstr ""
@@ -2026,7 +2026,7 @@
#, fuzzy, c-format
msgstr "ì¶ë ¥í ëì¤í°ë§µ"
Modified: grass/branches/develbranch_6/locale/po/grassmods_lv.po
--- grass/branches/develbranch_6/locale/po/grassmods_lv.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_lv.po 2012-05-27 11:26:36 UTC (rev 51818)
#, c-format
msgstr ""
@@ -2066,7 +2066,7 @@
#, fuzzy, c-format
msgstr "Nevar iatlasīt datus no tabulas"
Modified: grass/branches/develbranch_6/locale/po/grassmods_mr.po
--- grass/branches/develbranch_6/locale/po/grassmods_mr.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_mr.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -2007,7 +2007,7 @@
#, c-format
msgstr ""
@@ -2035,7 +2035,7 @@
#, fuzzy, c-format
msgstr "डà¥à¤à¤¾à¤¬à¥à¤¸à¤à¥ यादॠदाà¤à¤µà¤¤à¤¾ यà¥à¤£à¤¾à¤° नाहà¥"
Modified: grass/branches/develbranch_6/locale/po/grassmods_pl.po
--- grass/branches/develbranch_6/locale/po/grassmods_pl.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_pl.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -1966,7 +1966,7 @@
#, c-format
msgstr ""
@@ -1994,7 +1994,7 @@
#, fuzzy, c-format
msgstr "Nie mozna otworzyÄ pliku wejÅciowego <%s@%s>."
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -2101,7 +2101,7 @@
#, c-format
msgstr ""
@@ -2129,7 +2129,7 @@
#, fuzzy, c-format
msgstr "Não consegui selecionar atributo."
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -2060,7 +2060,7 @@
#, c-format
msgstr ""
@@ -2088,7 +2088,7 @@
#, fuzzy, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_ru.po
--- grass/branches/develbranch_6/locale/po/grassmods_ru.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_ru.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -2003,7 +2003,7 @@
#, c-format
msgstr "ÐеÑооÑвеÑÑÑвÑÑÑее ÑиÑло аÑÑибÑÑов (<%s/%s> %d: <%s> %d, <%s> %d"
@@ -2031,7 +2031,7 @@
#, c-format
msgstr "Ðевозможно задаÑÑ Ð¸Ð·Ð¾Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑÑ (%d) аÑÑибÑÑ (%d) обÑема %d"
Modified: grass/branches/develbranch_6/locale/po/grassmods_sl.po
--- grass/branches/develbranch_6/locale/po/grassmods_sl.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_sl.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -2074,7 +2074,7 @@
#, c-format
msgstr ""
@@ -2102,7 +2102,7 @@
#, fuzzy, c-format
msgstr "Ne morem izbrati (select) podatkov iz tabele"
Modified: grass/branches/develbranch_6/locale/po/grassmods_th.po
--- grass/branches/develbranch_6/locale/po/grassmods_th.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_th.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -2050,7 +2050,7 @@
#, c-format
msgstr ""
@@ -2078,7 +2078,7 @@
#, fuzzy, c-format
msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸¥à¸·à¸à¸ à¸à¸¸à¸à¸£à¸²à¸¢à¸¥à¸°à¹à¸à¸µà¸¢à¸ à¸à¸²à¸ <%s>"
Modified: grass/branches/develbranch_6/locale/po/grassmods_tr.po
--- grass/branches/develbranch_6/locale/po/grassmods_tr.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_tr.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -1989,7 +1989,7 @@
#, c-format
msgstr ""
@@ -2017,7 +2017,7 @@
#, c-format
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_vi.po
--- grass/branches/develbranch_6/locale/po/grassmods_vi.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_vi.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -1972,13 +1972,13 @@
#: ../misc/m.nviz.image/args.c:912
#, c-format
-msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
-msgstr "Sá» lượng thuá»c tÃnh không nhất quán (<%s/%s> %d: <%s> %d"
+msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
+msgstr "Sá» lượng thuá»c tÃnh không nhất quán (<%s/%s> %d: <%s> %d)"
#: ../misc/m.nviz.image/args.c:947
#, fuzzy, c-format
msgid "Inconsistent number of attributes (<%s> %d: <%s> %d x 3)"
-msgstr "Sá» lượng thuá»c tÃnh không nhất quán (<%s> %d: <%s> %d)"
+msgstr "Sá» lượng thuá»c tÃnh không nhất quán (<%s> %d: <%s> %d x 3)"
#: ../misc/m.nviz.image/args.c:952 ../misc/m.nviz.image/args.c:957
#: ../misc/m.nviz.image/args.c:968 ../misc/m.nviz.image/args.c:982
#, c-format
msgstr "Sá» lượng thuá»c tÃnh không nhất quán (<%s/%s> %d: <%s> %d, <%s> %d"
Modified: grass/branches/develbranch_6/locale/po/grassmods_zh.po
--- grass/branches/develbranch_6/locale/po/grassmods_zh.po 2012-05-27 11:22:31 UTC (rev 51817)
+++ grass/branches/develbranch_6/locale/po/grassmods_zh.po 2012-05-27 11:26:36 UTC (rev 51818)
@@ -2070,7 +2070,7 @@
#, c-format
msgstr ""
@@ -2098,7 +2098,7 @@
#, fuzzy, c-format
msgstr "æ æ³éæ©å±æ§ã"
