[GRASS-SVN] r51820 - in grass/trunk: locale/po misc/m.nviz.image
svn_grass at osgeo.org
Sun May 27 04:32:59 PDT 2012
Author: neteler
Date: 2012-05-27 04:32:59 -0700 (Sun, 27 May 2012)
New Revision: 51820
grass/trunk/locale/po/grassmods_ar.po
grass/trunk/locale/po/grassmods_cs.po
grass/trunk/locale/po/grassmods_de.po
grass/trunk/locale/po/grassmods_el.po
grass/trunk/locale/po/grassmods_es.po
grass/trunk/locale/po/grassmods_fr.po
grass/trunk/locale/po/grassmods_hi.po
grass/trunk/locale/po/grassmods_it.po
grass/trunk/locale/po/grassmods_ja.po
grass/trunk/locale/po/grassmods_ko.po
grass/trunk/locale/po/grassmods_lv.po
grass/trunk/locale/po/grassmods_mr.po
grass/trunk/locale/po/grassmods_pl.po
grass/trunk/locale/po/grassmods_pt.po
grass/trunk/locale/po/grassmods_pt_br.po
grass/trunk/locale/po/grassmods_ru.po
grass/trunk/locale/po/grassmods_sl.po
grass/trunk/locale/po/grassmods_th.po
grass/trunk/locale/po/grassmods_tr.po
grass/trunk/locale/po/grassmods_vi.po
grass/trunk/locale/po/grassmods_zh.po
grass/trunk/misc/m.nviz.image/args.c
fix typos (r51809)
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_ar.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2239,7 +2239,7 @@
#: ../misc/m.nviz.image/args.c:1110
#, c-format
-msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d"
+msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d)"
msgstr ""
#: ../misc/m.nviz.image/volume.c:92 ../misc/m.nviz.image/volume.c:231
@@ -2262,7 +2262,7 @@
#: ../misc/m.nviz.image/volume.c:162 ../misc/m.nviz.image/volume.c:173
#: ../misc/m.nviz.image/volume.c:180
#, fuzzy, c-format
-msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
+msgid "Unable to set isosurface (%d) attribute (%d) of volume %d)"
msgstr "ÙÙ
ÙÙ
ÙÙ Ø§Ø®ØªÙØ§Ø± Ø§ÙØ¨ÙØ§ÙØ§Øª Ù
Ù Ø§ÙØ¬Ø¯ÙÙ"
#: ../misc/m.nviz.image/volume.c:144 ../misc/m.nviz.image/surface.c:128
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_cs.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2249,7 +2249,7 @@
#, c-format
msgstr ""
@@ -2272,7 +2272,7 @@
#, fuzzy, c-format
msgstr "Nelze získat atributové data pro cat= %d"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_de.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2153,7 +2153,7 @@
#, c-format
msgstr "Inkonsistente Attributanzahl (<%s/%s> %d: <%s> %d, <%s> %d."
@@ -2176,7 +2176,7 @@
#, c-format
msgstr "Kann die Isofläche (%d) Attribut (%d) des Volumens %d nicht setzten."
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_el.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2158,7 +2158,7 @@
#, c-format
msgstr ""
@@ -2181,7 +2181,7 @@
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_es.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2195,7 +2195,7 @@
#, c-format
msgstr "Número de atributos incoherente (<%s/%s> %d: <%s> %d, <%s> %d"
@@ -2218,7 +2218,7 @@
#, fuzzy, c-format
msgstr "No se pueden seleccionar los atributos de los puntos de <%s>"
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_fr.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2289,7 +2289,7 @@
#, c-format
msgstr "Nombre d'attributs incohérent (<%s/%s> %d: <%s> %d, <%s> %d"
@@ -2312,7 +2312,7 @@
#, fuzzy, c-format
msgstr "Impossible de sélectionner des données dans la table attributaire"
Modified: grass/trunk/locale/po/grassmods_hi.po
--- grass/trunk/locale/po/grassmods_hi.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_hi.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2293,7 +2293,7 @@
#, c-format
msgstr ""
@@ -2316,7 +2316,7 @@
#, fuzzy, c-format
msgstr "à¤à¥ लिà¤"
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_it.po 2012-05-27 11:32:59 UTC (rev 51820)
#, c-format
msgstr ""
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_ja.po 2012-05-27 11:32:59 UTC (rev 51820)
#, c-format
msgstr "屿§æ°ãä¸è´ãã¦ãã¾ãã (<%s/%s> %d: <%s> %d, <%s> %d "
#, c-format
msgstr "ç°æ§æ²é¢ (%d) 屿§ (%d) ï¼ããªã¥ã¼ã %d ã®ï¼ ãè¨å®ã§ãã¾ãã"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_ko.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2171,7 +2171,7 @@
#, c-format
msgstr ""
@@ -2194,7 +2194,7 @@
#, fuzzy, c-format
msgstr "ì¶ë ¥í ëì¤í°ë§µ"
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_lv.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2210,7 +2210,7 @@
#, c-format
msgstr ""
@@ -2233,7 +2233,7 @@
#, fuzzy, c-format
msgstr "Nevar iatlasīt datus no tabulas"
Modified: grass/trunk/locale/po/grassmods_mr.po
--- grass/trunk/locale/po/grassmods_mr.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_mr.po 2012-05-27 11:32:59 UTC (rev 51820)
#, c-format
msgstr ""
@@ -2204,7 +2204,7 @@
#, fuzzy, c-format
msgstr "डà¥à¤à¤¾à¤¬à¥à¤¸à¤à¥ यादॠदाà¤à¤µà¤¤à¤¾ यà¥à¤£à¤¾à¤° नाहà¥"
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_pl.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2164,7 +2164,7 @@
#, c-format
msgstr ""
@@ -2187,7 +2187,7 @@
#, fuzzy, c-format
msgstr "Nie mozna otworzyÄ pliku wejÅciowego <%s@%s>."
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_pt.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2277,7 +2277,7 @@
#, c-format
msgstr ""
@@ -2300,7 +2300,7 @@
#, fuzzy, c-format
msgstr "Não consegui selecionar atributo."
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_pt_br.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2244,7 +2244,7 @@
#, c-format
msgstr ""
@@ -2267,7 +2267,7 @@
#, fuzzy, c-format
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_ru.po 2012-05-27 11:32:59 UTC (rev 51820)
#, c-format
msgstr "ÐеÑооÑвеÑÑÑвÑÑÑее ÑиÑло аÑÑибÑÑов (<%s/%s> %d: <%s> %d, <%s> %d"
#, c-format
msgstr "Ðевозможно задаÑÑ Ð¸Ð·Ð¾Ð¿Ð¾Ð²ÐµÑÑ
ноÑÑÑ (%d) аÑÑибÑÑ (%d) обÑема %d"
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_sl.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2253,7 +2253,7 @@
#, c-format
msgstr ""
@@ -2276,7 +2276,7 @@
#, fuzzy, c-format
msgstr "Ne morem izbrati (select) podatkov iz tabele"
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_th.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2240,7 +2240,7 @@
#, c-format
msgstr ""
@@ -2263,7 +2263,7 @@
#, fuzzy, c-format
msgstr "à¹à¸¡à¹à¸ªà¸²à¸¡à¸²à¸£à¸à¹à¸¥à¸·à¸à¸ à¸à¸¸à¸à¸£à¸²à¸¢à¸¥à¸°à¹à¸à¸µà¸¢à¸ à¸à¸²à¸ <%s>"
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_tr.po 2012-05-27 11:32:59 UTC (rev 51820)
#, c-format
msgstr ""
#, c-format
msgstr ""
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_vi.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2163,7 +2163,7 @@
#: ../misc/m.nviz.image/args.c:971
#, c-format
-msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
+msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
msgstr "Sá» lượng thuá»c tÃnh không nhất quán (<%s/%s> %d: <%s> %d"
#: ../misc/m.nviz.image/args.c:1005
@@ -2181,13 +2181,13 @@
#: ../misc/m.nviz.image/args.c:1033
#, c-format
-msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
-msgstr "Sá» lượng thuá»c tÃnh không nhất quán (<%s> %d: <%s> %d"
+msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
+msgstr "Sá» lượng thuá»c tÃnh không nhất quán (<%s> %d: <%s> %d)"
#: ../misc/m.nviz.image/args.c:1077 ../misc/m.nviz.image/args.c:1086
#, fuzzy, c-format
-msgid "Inconsistent number of attributes (<%s> %d: <%s> %d, <%s> %d"
-msgstr "Sá» lượng thuá»c tÃnh không nhất quán (<%s/%s> %d: <%s> %d, <%s> %d"
+msgid "Inconsistent number of attributes (<%s> %d: <%s> %d, <%s> %d)"
+msgstr "Sá» lượng thuá»c tÃnh không nhất quán (<%s/%s> %d: <%s> %d, <%s> %d)"
#: ../misc/m.nviz.image/args.c:1099
#, fuzzy, c-format
@@ -2196,7 +2196,7 @@
#, c-format
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/locale/po/grassmods_zh.po 2012-05-27 11:32:59 UTC (rev 51820)
@@ -2243,7 +2243,7 @@
#, c-format
msgstr ""
@@ -2266,7 +2266,7 @@
#, fuzzy, c-format
msgstr "æ æ³éæ©å±æ§ã"
Modified: grass/trunk/misc/m.nviz.image/args.c
--- grass/trunk/misc/m.nviz.image/args.c 2012-05-27 11:28:39 UTC (rev 51819)
+++ grass/trunk/misc/m.nviz.image/args.c 2012-05-27 11:32:59 UTC (rev 51820)
@@ -872,6 +872,7 @@
params->north_arrow_color->guisection = _("Decoration");
params->north_arrow_color->answer = "black";
\brief Get number of answers of given option
@@ -968,7 +969,7 @@
nconsts = opt_get_num_answers(params->res_fine);
if (nconsts > 0 && nconsts != nelevs)
- G_fatal_error(_("Inconsistent number of attributes (<%s/%s> %d: <%s> %d"),
+ G_fatal_error(_("Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"),
params->elev_map->key, params->elev_const->key,
nelevs, params->res_fine->key, nconsts);
@@ -996,6 +997,7 @@
nelevs, params->wire_color->key, nconsts);
* Cutting planes
@@ -1014,7 +1016,7 @@
if (ncplanes > 0 && ncplanes != nconsts)
G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d)"),
params->cplane->key, ncplanes, params->cplane_tilt->key, nconsts);
* vector lines
@@ -1074,7 +1076,7 @@
nconsts = opt_get_num_answers(params->isosurf_transp_const);
if ((nmaps + nconsts > 0) && (nisosurf != nmaps + nconsts))
- G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d, <%s> %d"),
+ G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d, <%s> %d)"),
params->isosurf_level->key, nisosurf, params->isosurf_transp_map->key, nmaps,
params->isosurf_transp_const->key, nconsts);
@@ -1083,7 +1085,7 @@
nconsts = opt_get_num_answers(params->isosurf_shine_const);
params->isosurf_level->key, nisosurf, params->isosurf_shine_map->key, nmaps,
params->isosurf_shine_const->key, nconsts);
@@ -1107,7 +1109,7 @@
const char *map_name, const char *const_name)
if ((nmaps + nconsts > 0) && (nelevs != nmaps + nconsts))
- G_fatal_error(_("Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d"),
+ G_fatal_error(_("Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d)"),
elev_map, elev_const, nelevs, map_name, nmaps,
const_name, nconsts);
