[GRASS-SVN] r51844 - grass/trunk/locale
svn_grass at osgeo.org
Mon May 28 02:25:47 PDT 2012
Author: lucadelu
Date: 2012-05-28 02:25:46 -0700 (Mon, 28 May 2012)
New Revision: 51844
grass/trunk/locale/grass_po_stats.py
output file write in GISBASE instead GISBASE/locale because if --nls it's not used return an error
Modified: grass/trunk/locale/grass_po_stats.py
--- grass/trunk/locale/grass_po_stats.py 2012-05-28 09:22:19 UTC (rev 51843)
+++ grass/trunk/locale/grass_po_stats.py 2012-05-28 09:25:46 UTC (rev 51844)
@@ -19,7 +19,7 @@
def main():
directory = 'po/'
- outfile = os.path.join(os.environ['GISBASE'],'locale','translation_status.json')
+ outfile = os.path.join(os.environ['GISBASE'],'translation_status.json')
try:
os.remove(outfile)
except:
