[GRASS-SVN] r51849 - grass/branches/releasebranch_6_4/vector/v.buffer2
svn_grass at osgeo.org
Mon May 28 03:51:35 PDT 2012
Author: mmetz
Date: 2012-05-28 03:51:34 -0700 (Mon, 28 May 2012)
New Revision: 51849
grass/branches/releasebranch_6_4/vector/v.buffer2/main.c
v.buffer2: go thru all lines if points/lines are requested
Modified: grass/branches/releasebranch_6_4/vector/v.buffer2/main.c
--- grass/branches/releasebranch_6_4/vector/v.buffer2/main.c 2012-05-28 10:50:20 UTC (rev 51848)
+++ grass/branches/releasebranch_6_4/vector/v.buffer2/main.c 2012-05-28 10:51:34 UTC (rev 51849)
@@ -387,11 +387,13 @@
Vect_spatial_index_init(&si);
/* Lines (and Points) */
- if ((type & GV_POINTS) || (type & GV_LINES)) {
+ if (nlines > 0) {
int ltype;
- if (nlines > 0)
- G_message(_("Buffering lines..."));
+ G_message(_("Buffering lines..."));
+ nlines = Vect_get_num_lines(&In);
for (line = 1; line <= nlines; line++) {
int cat;
