[GRASS-SVN] r51852 - in grass/trunk/gui/wxpython: gui_core lmgr
svn_grass at osgeo.org
Mon May 28 05:18:48 PDT 2012
Author: lucadelu
Date: 2012-05-28 05:18:47 -0700 (Mon, 28 May 2012)
New Revision: 51852
grass/trunk/gui/wxpython/gui_core/ghelp.py
grass/trunk/gui/wxpython/lmgr/frame.py
new version of translation status, it has a bug for the scroll
Modified: grass/trunk/gui/wxpython/gui_core/ghelp.py
--- grass/trunk/gui/wxpython/gui_core/ghelp.py 2012-05-28 11:52:53 UTC (rev 51851)
+++ grass/trunk/gui/wxpython/gui_core/ghelp.py 2012-05-28 12:18:47 UTC (rev 51852)
@@ -44,6 +44,15 @@
from gui_core.widgets import GNotebook, StaticWrapText, ItemTree, ScrolledPanel
from core.debug import Debug
+# add for folderpanel in languages status
+try:
+ from agw import foldpanelbar as fpb
+except ImportError: # if it's not there locally, try the wxPython lib.
+ try:
+ import wx.lib.agw.foldpanelbar as fpb
+ except ImportError:
+ import wx.lib.foldpanelbar as fpb # versions <=2.5.5.1
class SearchModuleWindow(wx.Panel):
"""!Search module window (used in MenuTreeWindow)"""
def __init__(self, parent, id = wx.ID_ANY, cmdPrompt = None,
@@ -725,6 +734,45 @@
return translatorswin
+ def _langString(self, k, v):
+ """Return string for the status of translation"""
+ allStr = "%s :" % k.upper()
+ try:
+ allStr += _(" %d translated" % v['good'])
+ except:
+ pass
+ try:
+ allStr += _(" %d fuzzy" % v['fuzzy'])
+ except:
+ pass
+ try:
+ allStr += _(" %d untranslated" % v['bad'])
+ except:
+ pass
+ return allStr
+ def _langPanel(self, parent, js):
+ """Create panel for each languages"""
+ panel = wx.Panel(parent = parent, id = wx.ID_ANY)
+ pageSizer = wx.BoxSizer(wx.VERTICAL)
+ for k,v in js.iteritems():
+ if k != 'total':
+ text = self._langString(k,v)
+ statstext = wx.StaticText(panel, id = wx.ID_ANY,
+ label = text)
+ pageSizer.Add(item = statstext, proportion = 1,
+ flag = wx.EXPAND | wx.ALL, border = 3)
+ panel.SetSizer(pageSizer)
+ panel.Layout()
+ panel.Fit()
+ return panel
+ def OnPressCaption(self, event):
+ """!When foldpanel item collapsed/expanded, update scrollbars"""
+ foldpanel = event.GetBar().GetGrandParent().GetParent()
+ wx.CallAfter(self.UpdateScrolling, (foldpanel,))
+ event.Skip()
def _pageStats(self):
"""Translation statistics info"""
fname = "translation_status.json"
@@ -738,45 +786,43 @@
statswin = ScrolledPanel(self)
statswin.SetAutoLayout(True)
statswin.SetupScrolling()
- statswin.sizer = wx.BoxSizer(wx.VERTICAL)
+ try:# wxpython <= 2.8.10
+ foldpanelAppear = fpb.FoldPanelBar(parent = statswin, id = wx.ID_ANY,
+ style = fpb.FPB_DEFAULT_STYLE,
+ extraStyle = fpb.FPB_SINGLE_FOLD)
+ except:
+ try:# wxpython >= 2.8.11
+ agwStyle = fpb.FPB_SINGLE_FOLD)
+ except: # to be sure
+ style = fpb.FPB_SINGLE_FOLD)
+ statswin.Bind(fpb.EVT_CAPTIONBAR, self.OnPressCaption)
if not jsStats:
Debug.msg(5, _("File <%s> not found") % fname)
+ sizer = wx.BoxSizer(wx.VERTICAL)
statstext = wx.StaticText(statswin, id = wx.ID_ANY,
label = _('%s file missing') % fname)
- statswin.sizer.Add(item = statstext, proportion = 1,
+ sizer.Add(item = statstext, proportion = 1,
+ #statswin.SetSizer(statswin.sizer)
else:
- statsBox = wx.FlexGridSizer(cols = 4, vgap = 5, hgap = 5)
- statsBox.Add(item = wx.StaticText(parent = statswin, id = wx.ID_ANY,
- label = _('Language')))
- label = _('Translated')))
- label = _('Fuzzy')))
- label = _('Untranslated')))
languages = jsStats['langs'].keys()
languages.sort()
for lang in languages:
- v = jsStats['langs'][lang]
- style = wx.ALIGN_CENTRE,
- label = lang.upper()))
- label = str(v['total']['good'])))
- label = str(v['total']['fuzzy'])))
- label = str(v['total']['bad'])))
+ v = jsStats['langs'][lang]
+ text = self._langString(lang, v['total'])
+ panel = foldpanelAppear.AddFoldPanel(text, collapsed = True)
+ foldpanelAppear.AddFoldPanelWindow(panel,
+ window = self._langPanel(parent = panel, js = v),
+ flags = fpb.FPB_ALIGN_WIDTH)
- statswin.sizer.Add(item = statsBox, proportion = 1,
- flag = wx.EXPAND | wx.ALL, border = 2)
+ sizer.Add(foldpanelAppear, proportion = 1, flag = wx.EXPAND)
- statswin.SetSizer(statswin.sizer)
+ statswin.SetSizer(sizer)
statswin.Layout()
return statswin
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2012-05-28 11:52:53 UTC (rev 51851)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2012-05-28 12:18:47 UTC (rev 51852)
@@ -376,6 +376,36 @@
win.Show()
+ def OnRLiSetup(self, event):
+ """!Launch r.li.setup
+ #try:
+ from scripts.rlisetup import RLiSetupFrame
+ #except:
+ #gcmd.GError(parent = self.parent, message = _("r.li.setup is not available."))
+ #return
+ win = RLiSetupFrame(parent = self)
+ win.CentreOnScreen()
+ win.Show()
+ def OnRStream(self, event):
+ """!GSoC's r.stream.* interface for testing
+ try:
+ from gui_modules import rstream
+ except:
+ gcmd.GError(parent = self.parent,
+ message = _("RStream Utility is not available. You can install it by %s") % \
+ 'g.extension -s extension=wx.stream')
+ return
+ win = rstream.RStreamFrame(parent = self)
+ win.Show()
def OnDone(self, cmd, returncode):
"""Command execution finised"""
if hasattr(self, "model"):
