[GRASS-SVN] r51858 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Mon May 28 15:52:20 PDT 2012
Author: lucadelu
Date: 2012-05-28 15:52:20 -0700 (Mon, 28 May 2012)
New Revision: 51858
grass/trunk/gui/wxpython/gui_core/ghelp.py
new version of translation status tab now using CollapsiblePane, to fix a problem with scrollbar that is not updated
Modified: grass/trunk/gui/wxpython/gui_core/ghelp.py
--- grass/trunk/gui/wxpython/gui_core/ghelp.py 2012-05-28 21:03:57 UTC (rev 51857)
+++ grass/trunk/gui/wxpython/gui_core/ghelp.py 2012-05-28 22:52:20 UTC (rev 51858)
@@ -44,15 +44,6 @@
from gui_core.widgets import GNotebook, StaticWrapText, ItemTree, ScrolledPanel
from core.debug import Debug
-# add for folderpanel in languages status
-try:
- from agw import foldpanelbar as fpb
-except ImportError: # if it's not there locally, try the wxPython lib.
- try:
- import wx.lib.agw.foldpanelbar as fpb
- except ImportError:
- import wx.lib.foldpanelbar as fpb # versions <=2.5.5.1
class SearchModuleWindow(wx.Panel):
"""!Search module window (used in MenuTreeWindow)"""
def __init__(self, parent, id = wx.ID_ANY, cmdPrompt = None,
@@ -758,28 +749,72 @@
except:
pass
return allStr
+ def _langBox(self, par, k, v):
+ """Return box"""
+ langBox = wx.FlexGridSizer(cols = 4, vgap = 5, hgap = 5)
+ tkey = wx.StaticText(parent = par, id = wx.ID_ANY,
+ label = k.upper())
+ langBox.Add(item = tkey)
+ try:
+ tgood = wx.StaticText(parent = par, id = wx.ID_ANY,
+ label = _("%d translated" % v['good']))
+ tgood.SetForegroundColour(wx.Colour(35, 142, 35))
+ langBox.Add(item = tgood)
+ except:
+ label = "")
+ try:
+ tfuzzy = wx.StaticText(parent = par, id = wx.ID_ANY,
+ label = _(" %d fuzzy" % v['fuzzy']))
+ tfuzzy.SetForegroundColour(wx.Colour(255, 142, 0))
+ langBox.Add(item = tfuzzy)
+ except:
+ label = "")
+ try:
+ tbad = wx.StaticText(parent = par, id = wx.ID_ANY,
+ label = _(" %d untranslated" % v['bad']))
+ tbad.SetForegroundColour(wx.Colour(255, 0, 0))
+ langBox.Add(item = tbad)
+ except:
+ label = "")
+ return langBox
- def _langPanel(self, parent, js):
+ def _langPanel(self, lang, js):
"""Create panel for each languages"""
- panel = wx.Panel(parent = parent, id = wx.ID_ANY)
+ text = self._langString(lang, js['total'])
+ panel = wx.CollapsiblePane(self.statswin, -1, label=text, style=wx.CP_DEFAULT_STYLE|wx.CP_NO_TLW_RESIZE)
+ panel.Bind(wx.EVT_COLLAPSIBLEPANE_CHANGED, self.OnPaneChanged)
+ win = panel.GetPane()
+ # TODO IT DOESN'T WORK
+ # TO ADD ONLY WHEN TAB IS OPENED
+ #if lang == self.langUsed.split('_')[0]:
+ #panel.Collapse(False)
+ #else:
+ #panel.Collapse(True)
pageSizer = wx.BoxSizer(wx.VERTICAL)
for k,v in js.iteritems():
if k != 'total':
- text = self._langString(k,v)
- statstext = wx.StaticText(panel, id = wx.ID_ANY,
- label = text)
- pageSizer.Add(item = statstext, proportion = 1,
+ box = self._langBox(win, k,v)
+ pageSizer.Add(item = box, proportion = 1,
flag = wx.EXPAND | wx.ALL, border = 3)
- panel.SetSizer(pageSizer)
- panel.Layout()
- panel.Fit()
+ win.SetSizer(pageSizer)
+ pageSizer.SetSizeHints(win)
return panel
- def OnPressCaption(self, event):
- """!When foldpanel item collapsed/expanded, update scrollbars"""
- foldpanel = event.GetBar().GetGrandParent().GetParent()
- wx.CallAfter(self.UpdateScrolling, (foldpanel,))
- event.Skip()
+ def OnPaneChanged(self, evt):
+ """Redo the layout"""
+ # TODO FIX THE REDO
+ self.Fit()
+ self.statswin.Refresh()
+ self.statswin.Layout()
def _pageStats(self):
"""Translation statistics info"""
@@ -791,57 +826,31 @@
jsStats = json.load(statsFile)
else:
jsStats = None
- statswin = ScrolledPanel(self, style = wx.TAB_TRAVERSAL|wx.VSCROLL)
- statswin.SetAutoLayout(True)
- try:# wxpython <= 2.8.10
- foldpanelAppear = fpb.FoldPanelBar(parent = statswin, id = wx.ID_ANY,
- style = fpb.FPB_DEFAULT_STYLE,
- extraStyle = fpb.FPB_SINGLE_FOLD)
- except:
- try:# wxpython >= 2.8.11
- agwStyle = fpb.FPB_SINGLE_FOLD)
- except: # to be sure
- style = fpb.FPB_SINGLE_FOLD)
- statswin.Bind(fpb.EVT_CAPTIONBAR, self.OnPressCaption)
+ self.statswin = ScrolledPanel(self)
+ self.statswin.SetAutoLayout(True)
if not jsStats:
Debug.msg(5, _("File <%s> not found") % fname)
- sizer = wx.BoxSizer(wx.VERTICAL)
- statstext = wx.StaticText(statswin, id = wx.ID_ANY,
+ self.statsSizer = wx.BoxSizer(wx.VERTICAL)
+ statstext = wx.StaticText(self.statswin, id = wx.ID_ANY,
label = _('%s file missing') % fname)
sizer.Add(item = statstext, proportion = 1,
else:
languages = jsStats['langs'].keys()
languages.sort()
- captStyle = fpb.CaptionBarStyle()
- captStyle.SetCaptionColour('BLACK')
- captStyle.SetCaptionStyle(fpb.CAPTIONBAR_FILLED_RECTANGLE)
- captStyle.SetFirstColour(wx.Colour(255,255,255, 255))
for lang in languages:
v = jsStats['langs'][lang]
- text = self._langString(lang, v['total'])
- if lang == self.langUsed.split('_')[0]:
- panel = foldpanelAppear.AddFoldPanel(text, collapsed = False,
- cbstyle = captStyle)
- else:
- panel = foldpanelAppear.AddFoldPanel(text, collapsed = True,
- foldpanelAppear.AddFoldPanelWindow(panel,
- window = self._langPanel(parent = panel, js = v),
- flags = fpb.FPB_ALIGN_WIDTH)
- sizer.Add(foldpanelAppear, proportion = 1, flag = wx.EXPAND)
+ panel = self._langPanel(lang, v)
+ self.statsSizer.Add(panel)
- statswin.SetSizer(sizer)
- statswin.SetupScrolling(scroll_x = False, scroll_y = True)
- statswin.Layout()
- statswin.Fit()
- return statswin
+ self.statswin.SetSizer(self.statsSizer)
+ self.statswin.SetupScrolling(scroll_x = False, scroll_y = True)
+ self.statswin.Fit()
+ return self.statswin
def OnCloseWindow(self, event):
"""!Close window"""
