[GRASS-SVN] r51888 - grass/trunk/lib/python/temporal
Wed May 30 06:25:03 PDT 2012
Author: huhabla
Date: 2012-05-30 06:25:01 -0700 (Wed, 30 May 2012)
New Revision: 51888
   grass/trunk/lib/python/temporal/abstract_dataset.py
   grass/trunk/lib/python/temporal/abstract_map_dataset.py
Removed redundant id build method
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py	2012-05-30 13:24:09 UTC (rev 51887)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py	2012-05-30 13:25:01 UTC (rev 51888)
@@ -96,30 +96,6 @@
 	"""!Return the mapset"""
         return self.base.get_mapset()
-    def build_id(name, mapset, layer=None):
-	"""!Build and return the id (primary key) based on name, mapset and layer of a dataset.
-	   @param name: The name of the map
-	   @param mapset: The name of the mapset
-	   @param layer: The name of the layer (optional)
-	   Return None in case the name can not be build (name or mapset are None)
-	if not name or not mapset:
-	    return None
-	# Make sure to extract the pure mapname
-	pure_name = name.split("@")[0].split(":")[0]
-	if layer:
-	    return "%s:%s@%s"%(name, layer, mapset)
-	else:
-	    return "%s@%s"%(name, mapset)
-	return None
     def get_valid_time(self):
         """!Returns a tuple of the start, the end valid time, this can be either datetime or double values
            @return A tuple of (start_time, end_time)
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py	2012-05-30 13:24:09 UTC (rev 51887)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py	2012-05-30 13:25:01 UTC (rev 51888)
@@ -442,7 +442,6 @@
         # Check if the name includes any mapset
 	if name.find("@") >= 0:
-	    print name
 	    name, mapset = name.split("@")
         # Check for layer number in map name
