[GRASS-SVN] r51893 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Wed May 30 09:49:58 PDT 2012
Author: huhabla
Date: 2012-05-30 09:49:57 -0700 (Wed, 30 May 2012)
New Revision: 51893
grass/trunk/lib/python/temporal/datetime_math.py
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
Better increment format check
Modified: grass/trunk/lib/python/temporal/datetime_math.py
--- grass/trunk/lib/python/temporal/datetime_math.py 2012-05-30 15:54:44 UTC (rev 51892)
+++ grass/trunk/lib/python/temporal/datetime_math.py 2012-05-30 16:49:57 UTC (rev 51893)
@@ -79,8 +79,12 @@
incparts = increment.split(",")
for incpart in incparts:
inclist.append(incpart.strip().split(" "))
for inc in inclist:
+ if len(inc) < 2:
+ core.error(_("Wrong increment format: %s") % (increment))
+ return None
if inc[1].find("seconds") >= 0:
seconds = mult * int(inc[0])
elif inc[1].find("minutes") >= 0:
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-05-30 15:54:44 UTC (rev 51892)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-05-30 16:49:57 UTC (rev 51893)
@@ -295,8 +295,12 @@
# Add the increment
if increment:
start_time = increment_datetime_by_string(start_time, increment, mult)
+ if start_time == None:
+ core.fatal(_("Error in increment computation"))
if interval:
end_time = increment_datetime_by_string(start_time, increment, 1)
+ if end_time == None:
if map.get_layer():
core.verbose(_("Set absolute valid time for map <%s> with layer %s to %s - %s") % (map.get_map_id(), map.get_layer(), str(start_time), str(end_time)))
else:
