[GRASS-SVN] r51902 - in grass/trunk: include/defs include/vect lib/vector/Vlib lib/vector/diglib
Thu May 31 05:47:12 PDT 2012
Author: martinl
Date: 2012-05-31 05:47:11 -0700 (Thu, 31 May 2012)
New Revision: 51902
   grass/trunk/include/defs/vector.h
   grass/trunk/include/vect/dig_structs.h
   grass/trunk/lib/vector/Vlib/build.c
   grass/trunk/lib/vector/Vlib/close_pg.c
   grass/trunk/lib/vector/Vlib/open.c
   grass/trunk/lib/vector/Vlib/open_pg.c
   grass/trunk/lib/vector/Vlib/read.c
   grass/trunk/lib/vector/Vlib/read_pg.c
   grass/trunk/lib/vector/Vlib/read_sfa.c
   grass/trunk/lib/vector/Vlib/rewind.c
   grass/trunk/lib/vector/diglib/frmt.c
   grass/trunk/lib/vector/diglib/spindex_rw.c
vlib: first steps for full PostGIS topology support
      untabify for given files
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h	2012-05-31 12:32:19 UTC (rev 51901)
+++ grass/trunk/include/defs/vector.h	2012-05-31 12:47:11 UTC (rev 51902)
@@ -11,44 +11,44 @@
 int Vect_line_insert_point(struct line_pnts *, int, double, double, double);
 int Vect_line_delete_point(struct line_pnts *, int);
 int Vect_line_get_point(const struct line_pnts *, int ,
-			double *, double *, double *);
+                        double *, double *, double *);
 int Vect_get_num_line_points(const struct line_pnts *);
 int Vect_line_prune(struct line_pnts *);
 int Vect_line_prune_thresh(struct line_pnts *, double);
 void Vect_line_reverse(struct line_pnts *);
 int Vect_copy_xyz_to_pnts(struct line_pnts *, const double *, const double *, const double *,
-			  int);
+                          int);
 int Vect_copy_pnts_to_xyz(const struct line_pnts *, double *, double *, double *,
-			  int *);
+                          int *);
 void Vect_reset_line(struct line_pnts *);
 void Vect_destroy_line_struct(struct line_pnts *);
 int Vect_point_on_line(const struct line_pnts *, double, double *, double *,
 int Vect_line_segment(const struct line_pnts *, double, double, struct line_pnts *);
 double Vect_line_length(const struct line_pnts *);
 double Vect_area_perimeter(const struct line_pnts *);
 double Vect_line_geodesic_length(const struct line_pnts *);
 int Vect_line_distance(const struct line_pnts *, double, double, double, int,
-		       double *, double *, double *, double *, double *,
-		       double *);
+                       double *, double *, double *, double *, double *,
+                       double *);
 void Vect_line_box(const struct line_pnts *, struct bound_box *);
 void Vect_line_parallel(struct line_pnts *, double, double, int,
-			struct line_pnts *);
+                        struct line_pnts *);
 void Vect_line_parallel2(struct line_pnts *, double, double,
-			 double, int, int, double,
+                         double, int, int, double,
 void Vect_line_buffer(const struct line_pnts *, double, double, struct line_pnts *);
 void Vect_line_buffer2(const struct line_pnts *, double, double,
-		       struct line_pnts **,
-		       struct line_pnts ***, int *);
+                       struct line_pnts **,
+                       struct line_pnts ***, int *);
 void Vect_area_buffer2(const struct Map_info *, int, double, double,
 void Vect_point_buffer2(double, double, double, double,
-			double, int, double,
-			struct line_pnts **);
+                        double, int, double,
+                        struct line_pnts **);
 /* Categories */
@@ -75,28 +75,28 @@
 /* Vector array */
 struct varray *Vect_new_varray(int);
 int Vect_set_varray_from_cat_string(const struct Map_info *, int, const char *, int,
-				    int, struct varray *);
+                                    int, struct varray *);
 int Vect_set_varray_from_cat_list(const struct Map_info *, int, struct cat_list *,
-				  int, int, struct varray *);
+                                  int, int, struct varray *);
 int Vect_set_varray_from_db(const struct Map_info *, int, const char *, int, int,
-			    struct varray *);
+                            struct varray *);
 /* DB connection - field info */
 struct dblinks *Vect_new_dblinks_struct(void);
 void Vect_reset_dblinks(struct dblinks *);
 int Vect_add_dblink(struct dblinks *, int, const char *,
-		    const char *, const char *, const char *, const char *);
+                    const char *, const char *, const char *, const char *);
 int Vect_check_dblink(const struct dblinks *, int, const char *);
 int Vect_map_add_dblink(struct Map_info *, int, const char *,
-			const char *);
+                        const char *);
 int Vect_map_del_dblink(struct Map_info *, int);
 void Vect_copy_map_dblinks(const struct Map_info *, struct Map_info *, int);
 int Vect_map_check_dblink(const struct Map_info *, int, const char *);
 int Vect_read_dblinks(struct Map_info *);
 int Vect_write_dblinks(struct Map_info *);
 struct field_info *Vect_default_field_info(struct Map_info *, int,
-					   const char *, int);
+                                           const char *, int);
 struct field_info *Vect_get_dblink(const struct Map_info *, int);
 struct field_info *Vect_get_field(const struct Map_info *, int);
 struct field_info *Vect_get_field_by_name(const struct Map_info *, const char *);
@@ -143,10 +143,10 @@
 int Vect_cidx_get_num_cats_by_index(const struct Map_info *, int);
 int Vect_cidx_get_num_types_by_index(const struct Map_info *, int);
 int Vect_cidx_get_type_count_by_index(const struct Map_info *, int, int, int *,
-				      int *);
+                                      int *);
 int Vect_cidx_get_type_count(const struct Map_info *, int, int);
 int Vect_cidx_get_cat_by_index(const struct Map_info *, int, int, int *, int *,
-			       int *);
+                               int *);
 int Vect_cidx_find_next(const struct Map_info *, int, int, int, int, int *, int *);
 void Vect_cidx_find_all(const struct Map_info *, int, int, int, struct ilist *);
 int Vect_cidx_dump(const struct Map_info *, FILE *);
@@ -227,7 +227,7 @@
 int Vect_get_built(const struct Map_info *);
 int Vect_build_partial(struct Map_info *, int);
 int Vect_set_constraint_region(struct Map_info *, double, double, double,
-				double, double, double);
+                                double, double, double);
 int Vect_set_constraint_type(struct Map_info *, int);
 int Vect_set_constraint_field(struct Map_info *, int);
 void  Vect_remove_constraints(struct Map_info *);
@@ -239,17 +239,17 @@
 /* Level 1 and 2 */
 int Vect_get_next_line_id(const struct Map_info *);
 int Vect_read_next_line(const struct Map_info *, struct line_pnts *,
-			struct line_cats *);
+                        struct line_cats *);
 off_t Vect_write_line(struct Map_info *, int, const struct line_pnts *,
-		      const struct line_cats *);
+                      const struct line_cats *);
 int Vect_get_num_dblinks(const struct Map_info *);
 /* Level 2 only */
 int Vect_read_line(const struct Map_info *, struct line_pnts *, struct line_cats *,
-		   int);
+                   int);
 off_t Vect_rewrite_line(struct Map_info *, int, int, const struct line_pnts *,
 int Vect_delete_line(struct Map_info *, int);
 int Vect_restore_line(struct Map_info *, int, off_t);
@@ -297,34 +297,34 @@
 /* Selecting features */
 int Vect_select_lines_by_box(struct Map_info *, const struct bound_box *,
-			 int, struct boxlist *);
+                         int, struct boxlist *);
 int Vect_select_areas_by_box(struct Map_info *, const struct bound_box *, struct boxlist *);
 int Vect_select_isles_by_box(struct Map_info *, const struct bound_box *, struct boxlist *);
 int Vect_select_nodes_by_box(struct Map_info *, const struct bound_box *, struct ilist *);
 int Vect_find_node(struct Map_info *, double, double, double, double, int);
 int Vect_find_line(struct Map_info *, double, double, double, int, double,
-		   int, int);
+                   int, int);
 int Vect_find_line_list(struct Map_info *, double, double, double, int,
-			double, int, const struct ilist *, struct ilist *);
+                        double, int, const struct ilist *, struct ilist *);
 int Vect_find_area(struct Map_info *, double, double);
 int Vect_find_island(struct Map_info *, double, double);
 int Vect_select_lines_by_polygon(struct Map_info *, struct line_pnts *, int,
-				 struct line_pnts **, int, struct ilist *);
+                                 struct line_pnts **, int, struct ilist *);
 int Vect_select_areas_by_polygon(struct Map_info *, struct line_pnts *, int,
-				 struct line_pnts **, struct ilist *);
+                                 struct line_pnts **, struct ilist *);
 /* Analysis */
 int Vect_tin_get_z(struct Map_info *, double, double, double *, double *,
-		   double *);
+                   double *);
 /* int Vect_point_in_islands (struct Map_info *, int, double, double); */
 int Vect_find_poly_centroid(const struct line_pnts *, double *, double *);
 int Vect__intersect_line_with_poly(const struct line_pnts *, double,
 int Vect_get_point_in_area(const struct Map_info *, int, double *, double *);
 int Vect_get_point_in_poly(const struct line_pnts *, double *, double *);
 int Vect_get_point_in_poly_isl(const struct line_pnts *, const struct line_pnts **, int,
-			       double *, double *);
+                               double *, double *);
 int Vect_point_in_area(double, double, const struct Map_info *, int, struct bound_box);
 int Vect_point_in_area_outer_ring(double, double, const struct Map_info *, int, struct bound_box);
 int Vect_point_in_island(double, double, const struct Map_info *, int, struct bound_box);
@@ -333,36 +333,36 @@
 /* Cleaning */
 void Vect_break_lines(struct Map_info *, int, struct Map_info *);
 int Vect_break_lines_list(struct Map_info *, struct ilist *, struct ilist *,
-			  int, struct Map_info *);
+                          int, struct Map_info *);
 int Vect_check_line_breaks(struct Map_info *, int, struct Map_info *);
 int Vect_check_line_breaks_list(struct Map_info *, struct ilist *, struct ilist *,
 int Vect_merge_lines(struct Map_info *, int, int *, struct Map_info *);
 void Vect_break_polygons(struct Map_info *, int, struct Map_info *);
 void Vect_remove_duplicates(struct Map_info *, int, struct Map_info *);
 int Vect_line_check_duplicate(const struct line_pnts *,
-			      const struct line_pnts *, int);
+                              const struct line_pnts *, int);
 void Vect_snap_lines(struct Map_info *, int, double, struct Map_info *);
 void Vect_snap_lines_list(struct Map_info *, const struct ilist *, double,
-			  struct Map_info *);
+                          struct Map_info *);
 void Vect_remove_dangles(struct Map_info *, int, double, struct Map_info *);
 void Vect_chtype_dangles(struct Map_info *, double, struct Map_info *);
 void Vect_select_dangles(struct Map_info *, int, double, struct ilist *);
 void Vect_remove_bridges(struct Map_info *, struct Map_info *);
 void Vect_chtype_bridges(struct Map_info *, struct Map_info *);
 int Vect_remove_small_areas(struct Map_info *, double, struct Map_info *,
-			    double *);
+                            double *);
 int Vect_clean_small_angles_at_nodes(struct Map_info *, int,
 /* Overlay */
 int Vect_overlay_str_to_operator(const char *);
 int Vect_overlay(struct Map_info *, int, struct ilist *, struct ilist *,
-		 struct Map_info *, int, struct ilist *, struct ilist *,
+                 struct Map_info *, int, struct ilist *, struct ilist *,
 int Vect_overlay_and(struct Map_info *, int, struct ilist *,
-		     struct ilist *, struct Map_info *, int,
-		     struct ilist *, struct ilist *, struct Map_info *);
+                     struct ilist *, struct Map_info *, int,
+                     struct ilist *, struct ilist *, struct Map_info *);
 /* Graph */
 void Vect_graph_init(dglGraph_s *, int);
@@ -373,50 +373,50 @@
 /* Network (graph) */
 int Vect_net_build_graph(struct Map_info *, int, int, int, const char *,
-			 const char *, const char *, int, int);
+                         const char *, const char *, int, int);
 int Vect_net_shortest_path(struct Map_info *, int, int, struct ilist *,
-			   double *);
+                           double *);
 int Vect_net_get_line_cost(const struct Map_info *, int, int, double *);
 int Vect_net_get_node_cost(const struct Map_info *, int, double *);
 int Vect_net_nearest_nodes(struct Map_info *, double, double, double, int,
-			   double, int *, int *, int *, double *, double *,
-			   struct line_pnts *, struct line_pnts *, double *);
+                           double, int *, int *, int *, double *, double *,
+                           struct line_pnts *, struct line_pnts *, double *);
 int Vect_net_shortest_path_coor(struct Map_info *, double, double, double,
-				double, double, double, double, double,
-				double *, struct line_pnts *, struct ilist *,
+                                double, double, double, double, double,
+                                double *, struct line_pnts *, struct ilist *,
 int Vect_net_shortest_path_coor2(struct Map_info *, double, double, double,
-				double *, struct line_pnts *, struct ilist *, struct ilist *,
+                                double *, struct line_pnts *, struct ilist *, struct ilist *,
 /* Miscellaneous */
 int Vect_topo_dump(const struct Map_info *, FILE *);
 double Vect_points_distance(double, double, double, double, double, double,
-			    int);
+                            int);
 int Vect_option_to_types(const struct Option *);
 int Vect_copy_map_lines(struct Map_info *, struct Map_info *);
 int Vect_copy_map_lines_field(struct Map_info *, int, struct Map_info *);
 int Vect_copy(const char *, const char *, const char *);
 int Vect_rename(const char *, const char *);
 int Vect_copy_table(const struct Map_info *, struct Map_info *, int, int,
 int Vect_copy_table_by_cats(const struct Map_info *, struct Map_info *, int, int,
-			    const char *, int, int *, int);
+                            const char *, int, int *, int);
 int Vect_copy_tables(const struct Map_info *, struct Map_info *, int);
 int Vect_delete(const char *);
 int Vect_segment_intersection(double, double, double, double, double, double,
-			      double, double, double, double, double, double,
-			      double *, double *, int);
+                              double, double, double, double, double, double,
+                              double *, double *, int);
 int Vect_line_intersection(struct line_pnts *, struct line_pnts *,
-			   struct line_pnts ***, struct line_pnts ***, int *,
-			   int *, int);
+                           struct line_pnts ***, struct line_pnts ***, int *,
+                           int *, int);
 int Vect_line_check_intersection(struct line_pnts *, struct line_pnts *, int);
 int Vect_line_get_intersections(struct line_pnts *, struct line_pnts *,
-				struct line_pnts *, int);
+                                struct line_pnts *, int);
 char *Vect_subst_var(const char *, const struct Map_info *);
 /* Custom spatial index */
@@ -430,9 +430,9 @@
 int Vect_read_ascii(FILE *, struct Map_info *);
 int Vect_read_ascii_head(FILE *, struct Map_info *);
 int Vect_write_ascii(FILE *, FILE *, struct Map_info *, int,
-		     int, int, char *, int, int,
-		     int, const struct cat_list *, const char*,
-		     const char **, int);
+                     int, int, char *, int, int,
+                     int, const struct cat_list *, const char*,
+                     const char **, int);
 void Vect_write_ascii_head(FILE *, struct Map_info *);
 /* Simple Features */
@@ -456,6 +456,7 @@
 const char *Vect_maptype_info(const struct Map_info *);
 int Vect_maptype(const struct Map_info *);
 int Vect_open_topo(struct Map_info *, int);
+int Vect_open_topo_pg(struct Map_info *, int);
 int Vect_save_topo(struct Map_info *);
 int Vect_open_sidx(struct Map_info *, int);
 int Vect_save_sidx(struct Map_info *);
@@ -492,27 +493,29 @@
 /* Read/write lines (internal use only) */
 int V1_read_line_nat(struct Map_info *, struct line_pnts *,
-		     struct line_cats *, off_t);
+                     struct line_cats *, off_t);
 int V1_read_line_ogr(struct Map_info *, struct line_pnts *,
 int V1_read_line_pg(struct Map_info *, struct line_pnts *,
 int V2_read_line_nat(struct Map_info *, struct line_pnts *,
-		     struct line_cats *, int);
+                     struct line_cats *, int);
 int V2_read_line_sfa(struct Map_info *, struct line_pnts *,
+int V3_read_line_pg(struct Map_info *, struct line_pnts *,
 int V1_read_next_line_nat(struct Map_info *, struct line_pnts *,
 int V1_read_next_line_ogr(struct Map_info *, struct line_pnts *,
 int V1_read_next_line_pg(struct Map_info *, struct line_pnts *,
 int V2_read_next_line_nat(struct Map_info *, struct line_pnts *,
 int V2_read_next_line_ogr(struct Map_info *, struct line_pnts *,
 int V2_read_next_line_pg(struct Map_info *, struct line_pnts *,
 int V1_delete_line_nat(struct Map_info *, off_t);
 int V1_delete_line_ogr(struct Map_info *, off_t);
 int V1_delete_line_pg(struct Map_info *, off_t);
@@ -521,25 +524,25 @@
 int V1_restore_line_nat(struct Map_info *, off_t);
 int V2_restore_line_nat(struct Map_info *, int, off_t);
 off_t V1_write_line_nat(struct Map_info *, int, const struct line_pnts *,
 off_t V1_write_line_ogr(struct Map_info *, int, const struct line_pnts *,
 off_t V1_write_line_pg(struct Map_info *, int, const struct line_pnts *,
 off_t V2_write_line_nat(struct Map_info *, int, const struct line_pnts *,
 off_t V2_write_line_sfa(struct Map_info *, int, const struct line_pnts *,
 off_t V1_rewrite_line_nat(struct Map_info *, int, int, off_t,
-			  const struct line_pnts *, const struct line_cats *);
+                          const struct line_pnts *, const struct line_cats *);
 off_t V1_rewrite_line_ogr(struct Map_info *, int, int, off_t,
 off_t V1_rewrite_line_pg(struct Map_info *, int, int, off_t,
 off_t V2_rewrite_line_nat(struct Map_info *, int, int, off_t,
 off_t V2_rewrite_line_sfa(struct Map_info *, int, int, off_t,
     /* Build topology */
 int Vect_build_nat(struct Map_info *, int);
Modified: grass/trunk/include/vect/dig_structs.h
--- grass/trunk/include/vect/dig_structs.h	2012-05-31 12:32:19 UTC (rev 51901)
+++ grass/trunk/include/vect/dig_structs.h	2012-05-31 12:47:11 UTC (rev 51902)
@@ -660,6 +660,16 @@
       \brief Offset list used for building pseudo-topology
     struct Format_info_offset offset;
+    /* Full-topology support */
+      \brief TopoGeometry column
+    char    *topogeom_column;
+      \brief Topology schema name
+    char    *toposchema_name;
@@ -1434,11 +1444,14 @@
       \brief Number of attached lines (size of
       lines, angle)
-      If 0, then is degenerate node, for snappingi ???
+      If 0, then is degenerate node, for snapping ???
     plus_t n_lines;
       \brief List of connected lines
+      Line id can be positive (for lines which starts at the node) or
+      negative (for lines which ends at the node).
     plus_t *lines;
@@ -1446,7 +1459,8 @@
       Angles for lines/boundaries are in radians between -PI and
       PI. Value for points or lines with identical points
-      (degenerated) is set to -9.
+      (degenerated) is set to -9. See dig_calc_begin_angle() and
+      dig_calc_end_angle() for details.
     float *angles;
@@ -1551,12 +1565,17 @@
     char type;
       \brief Offset in coor file for line
+      OGR-links: offset array index
+      PG-links: node/edge id
-    off_t offset;
+    off_t offset;
       \brief Topology info
+      NULL for points
-    void *topo;
+    void *topo;
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c	2012-05-31 12:32:19 UTC (rev 51901)
+++ grass/trunk/lib/vector/Vlib/build.c	2012-05-31 12:47:11 UTC (rev 51902)
@@ -13,12 +13,15 @@
    \author Original author CERL, probably Dave Gerdes or Mike Higgins.
    \author Update to GRASS 5.7 Radim Blazek and David D. Gray.
 #include <stdlib.h>
 #include <stdio.h>
 #include <stdarg.h>
 #include <unistd.h>
+#include <math.h>
+#include <grass/vector.h>
 #include <grass/glocale.h>
-#include <grass/vector.h>
 #define SEP "-----------------------------------\n"
@@ -884,6 +887,7 @@
 int Vect_topo_dump(const struct Map_info *Map, FILE *out)
     int i, j, line, isle;
+    float angle_deg;
     struct P_node *Node;
     struct P_line *Line;
     struct P_area *Area;
@@ -914,8 +918,11 @@
 	for (j = 0; j < Node->n_lines; j++) {
 	    line = Node->lines[j];
 	    Line = plus->Line[abs(line)];
-	    fprintf(out, "  line = %3d, type = %d, angle = %f\n", line,
-		    Line->type, Node->angles[j]);
+            angle_deg = (Node->angles[j] * 180) / M_PI;
+            if (angle_deg < 0)
+                angle_deg += 360;
+	    fprintf(out, "  line = %3d, type = %d, angle = %f (%.4f)\n", line,
+		    Line->type, Node->angles[j], angle_deg);
Modified: grass/trunk/lib/vector/Vlib/close_pg.c
--- grass/trunk/lib/vector/Vlib/close_pg.c	2012-05-31 12:32:19 UTC (rev 51901)
+++ grass/trunk/lib/vector/Vlib/close_pg.c	2012-05-31 12:47:11 UTC (rev 51902)
@@ -80,6 +80,12 @@
     G_free(pg_info->geom_column);
     G_free(pg_info->fid_column);
+    if (pg_info->toposchema_name)
+        G_free(pg_info->toposchema_name);
+    if (pg_info->topogeom_column)
+        G_free(pg_info->topogeom_column);
     return 0;
 #else
     G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2012-05-31 12:32:19 UTC (rev 51901)
+++ grass/trunk/lib/vector/Vlib/open.c	2012-05-31 12:47:11 UTC (rev 51902)
@@ -97,7 +97,7 @@
 static int open_old(struct Map_info *, const char *, const char *,
-		    const char *, int, int);
+                    const char *, int, int);
   \brief Predetermine level at which a vector map will be opened for
@@ -122,10 +122,10 @@
     Open_level = level;
     if (Open_level < 1 || Open_level > MAX_OPEN_LEVEL) {
-	G_warning(_("Programmer requested unknown access level %d"),
-		  Open_level);
-	Open_level = 0;
-	return 1;
+        G_warning(_("Programmer requested unknown access level %d"),
+                  Open_level);
+        Open_level = 0;
+        return 1;
     return 0;
@@ -146,10 +146,10 @@
  \return -1 in error
 int open_old(struct Map_info *Map, const char *name, const char *mapset,
-	     const char *layer, int update, int head_only)
+             const char *layer, int update, int head_only)
     char buf[GNAME_MAX + 10], buf2[GMAPSET_MAX + 10], xname[GNAME_MAX],
-	xmapset[GMAPSET_MAX];
+        xmapset[GMAPSET_MAX];
     FILE *fp;
     int level, level_request;
     int format, ret;
@@ -157,7 +157,7 @@
     const char *fmapset;
     G_debug(1, "Vect__open_old(): name='%s' mapset='%s' layer='%s' update=%d",
-	    name, mapset, layer, update);
+            name, mapset, layer, update);
     /* zero Map_info structure */
     G_zero(Map, sizeof(struct Map_info));
@@ -178,54 +178,54 @@
     /* check OGR mapset */
     ogr_mapset = FALSE;
     if (G_name_is_fully_qualified(name, xname, xmapset)) {
-	if (strcasecmp(xmapset, "ogr") == 0) {
-	    /* unique OGR mapset detected */
-	    G_debug(1, "OGR mapset detected");
-	    ogr_mapset = TRUE;
-	    Map->fInfo.ogr.dsn = G_store(xname);
-	    if (layer) {
-		Map->fInfo.ogr.layer_name = G_store(layer); /* no layer to be open */
-	else {
-	    sprintf(buf,  "%s/%s", GV_DIRECTORY, xname);
-	    sprintf(buf2, "%s@%s", GV_COOR_ELEMENT, xmapset);
-	Map->name = G_store(xname);
-	Map->mapset = G_store(xmapset);
+        if (strcasecmp(xmapset, "ogr") == 0) {
+            /* unique OGR mapset detected */
+            G_debug(1, "OGR mapset detected");
+            ogr_mapset = TRUE;
+            Map->fInfo.ogr.dsn = G_store(xname);
+            if (layer) {
+                Map->fInfo.ogr.layer_name = G_store(layer); /* no layer to be open */
+        else {
+            sprintf(buf,  "%s/%s", GV_DIRECTORY, xname);
+            sprintf(buf2, "%s@%s", GV_COOR_ELEMENT, xmapset);
+        Map->name = G_store(xname);
+        Map->mapset = G_store(xmapset);
     else {
-	sprintf(buf, "%s/%s", GV_DIRECTORY, name);
-	sprintf(buf2, "%s",   GV_COOR_ELEMENT);
-	Map->name = G_store(name);
+        sprintf(buf, "%s/%s", GV_DIRECTORY, name);
+        sprintf(buf2, "%s",   GV_COOR_ELEMENT);
+        Map->name = G_store(name);
-	if (mapset)
-	    Map->mapset = G_store(mapset);
-	else
-	    Map->mapset = G_store("");
+        if (mapset)
+            Map->mapset = G_store(mapset);
+        else
+            Map->mapset = G_store("");
     if (!ogr_mapset) {
-	/* try to find vector map (not for OGR mapset) */
-	fmapset = G_find_vector2(Map->name, Map->mapset);
-	if (fmapset == NULL) {
-	    if (mapset && strcmp(mapset, G_mapset()) == 0)
-		G_fatal_error(_("Vector map <%s> not found in current mapset"),
-			      Vect_get_name(Map));
-	    else
-		G_fatal_error(_("Vector map <%s> not found"),
-			      Vect_get_full_name(Map));
-	    return -1;
-	Map->mapset = G_store(fmapset);
+        /* try to find vector map (not for OGR mapset) */
+        fmapset = G_find_vector2(Map->name, Map->mapset);
+        if (fmapset == NULL) {
+            if (mapset && strcmp(mapset, G_mapset()) == 0)
+                G_fatal_error(_("Vector map <%s> not found in current mapset"),
+                              Vect_get_name(Map));
+            else
+                G_fatal_error(_("Vector map <%s> not found"),
+                              Vect_get_full_name(Map));
+            return -1;
+        Map->mapset = G_store(fmapset);
     Map->location = G_store(G_location());
     Map->gisdbase = G_store(G_gisdbase());
     if (update && !ogr_mapset && (0 != strcmp(Map->mapset, G_mapset()))) {
-	G_warning(_("Vector map which is not in the current mapset cannot be opened for update"));
-	return -1;
+        G_warning(_("Vector map which is not in the current mapset cannot be opened for update"));
+        return -1;
     G_debug(1, "Map name: %s", Map->name);
@@ -233,41 +233,41 @@
     /* Read vector format information */
     if (ogr_mapset) {
-	format = GV_FORMAT_OGR_DIRECT;
+        format = GV_FORMAT_OGR_DIRECT;
     else {
-	format = 0;
-	sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
-	G_debug(1, "open format file: '%s/%s/%s'", Map->mapset, buf,
-		GV_FRMT_ELEMENT);
-	fp = G_fopen_old(buf, GV_FRMT_ELEMENT, Map->mapset);
-	if (fp == NULL) {
-	    G_debug(1, "Vector format: %d (native)", format);
-	    format = GV_FORMAT_NATIVE;
-	else {
-	    format = dig_read_frmt_ascii(fp, &(Map->fInfo));
-	    fclose(fp);
-	    G_debug(1, "Vector format: %d (non-native)", format);
-	    if (format < 0) {
-		G_fatal_error(_("Unable to open vector map <%s>"),
-		return -1;
+        format = 0;
+        sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
+        G_debug(1, "open format file: '%s/%s/%s'", Map->mapset, buf,
+                GV_FRMT_ELEMENT);
+        fp = G_fopen_old(buf, GV_FRMT_ELEMENT, Map->mapset);
+        if (fp == NULL) {
+            G_debug(1, "Vector format: %d (native)", format);
+            format = GV_FORMAT_NATIVE;
+        else {
+            format = dig_read_frmt_ascii(fp, &(Map->fInfo));
+            fclose(fp);
+            G_debug(1, "Vector format: %d (non-native)", format);
+            if (format < 0) {
+                G_fatal_error(_("Unable to open vector map <%s>"),
+                return -1;
     Map->format = format;
     /* read vector head (ignored for OGR mapset) */
     if (!ogr_mapset && Vect__read_head(Map) != 0) {
-	G_fatal_error(_("Unable to read header file of vector map <%s>"),
+        G_fatal_error(_("Unable to read header file of vector map <%s>"),
     /* projection is not written to head but zone ??? */
     if (Vect_get_zone(Map) == -1)
-	Vect_set_zone(Map, G_zone());
+        Vect_set_zone(Map, G_zone());
     Vect_set_proj(Map, G_projection());
     G_debug(1, "Level request = %d", level_request);
@@ -282,124 +282,140 @@
     /* Try to open support files if level was not requested or
      * requested level is 2 (format independent) */
     if (level_request == 0 || level_request == 2) {
-	level = 2;		/* we expect success */
-	/* open topo */
-	ret = Vect_open_topo(Map, head_only);
-	if (ret == 1) {		/* topo file is not available */
-	    G_debug(1, "topo file for vector '%s' not available.",
-	    level = 1;
-	else if (ret == -1) {
-	    G_fatal_error(_("Unable to open topology file for vector map <%s>"),
-	/* open spatial index */
-	if (level == 2) {
-	    ret = Vect_open_sidx(Map, (update != 0));
-	    if (ret == 1) {	/* sidx file is not available */
-		G_debug(1, "sidx file for vector '%s' not available.",
-		level = 1;
-		G_fatal_error(_("Unable to open spatial index file for vector map <%s>"),
-	    /* check with_z consistency */
-	    if ((Map->plus.with_z != 0 && Map->plus.spidx_with_z == 0) ||
-	        (Map->plus.with_z == 0 && Map->plus.spidx_with_z != 0)) {
-		    G_warning("Vector map <%s>: topology is %s, but spatial index is %s",
-		    Vect_get_full_name(Map), (Map->plus.with_z != 0 ? "3D" : "2D"),
-		    (Map->plus.spidx_with_z != 0 ? "3D" : "2D"));
-		    level = 1;
-	/* open category index */
-	if (level == 2) {
-	    ret = Vect_cidx_open(Map, head_only);
-	    if (ret == 1) {	/* category index is not available */
-		G_debug(1,
-			"cidx file for vector '%s' not available.",
-		dig_free_plus(&(Map->plus));	/* free topology */
-		dig_spidx_free(&(Map->plus));	/* free spatial index */
-		level = 1;
-	    else if (ret == -1) {	/* file exists, but cannot be opened */
-		G_fatal_error(_("Unable to open category index file for vector map <%s>"),
+        level = 2;              /* we expect success */
+        /* open topo */
+        ret = -1;
+        if (Map->format == GV_FORMAT_POSTGIS)
+            /* try to read full-topology for PostGIS links */
+            ret = Vect_open_topo_pg(Map, head_only);
+        if (ret != 0) {
+            /* read topology for native format
+               read pseudo-topology for OGR/PostGIS links */
+            ret = Vect_open_topo(Map, head_only);
+            if (ret == 1) { /* topo file is not available */
+                G_debug(1, "topo file for vector '%s' not available.",
+                level = 1;
+            else if (ret == -1) {
+                G_fatal_error(_("Unable to open topology file for vector map <%s>"),
+        else {
+            level = 3; /* PostGIS topology available */
+        /* open spatial index */
+        if (level >= 2) {
+            ret = Vect_open_sidx(Map, (update != 0));
+            if (ret == 1) {     /* sidx file is not available */
+                G_debug(1, "sidx file for vector '%s' not available.",
+                level = 1;
+                G_fatal_error(_("Unable to open spatial index file for vector map <%s>"),
+            /* check with_z consistency */
+            if ((Map->plus.with_z != 0 && Map->plus.spidx_with_z == 0) ||
+                (Map->plus.with_z == 0 && Map->plus.spidx_with_z != 0)) {
+                    G_warning("Vector map <%s>: topology is %s, but spatial index is %s",
+                    Vect_get_full_name(Map), (Map->plus.with_z != 0 ? "3D" : "2D"),
+                    (Map->plus.spidx_with_z != 0 ? "3D" : "2D"));
+                    level = 1;
+        /* open category index */
+        if (level >= 2) {
+            ret = Vect_cidx_open(Map, head_only);
+            if (ret == 1) {     /* category index is not available */
+                G_debug(1,
+                        "cidx file for vector '%s' not available.",
+                dig_free_plus(&(Map->plus));    /* free topology */
+                dig_spidx_free(&(Map->plus));   /* free spatial index */
+                level = 1;
+            else if (ret == -1) {       /* file exists, but cannot be opened */
+                G_fatal_error(_("Unable to open category index file for vector map <%s>"),
 #ifdef HAVE_OGR
-	/* open OGR specific support files */
-	if (level == 2 && Map->format == GV_FORMAT_OGR) {
-	    if (V2_open_old_ogr(Map) < 0) {
-		dig_cidx_free(&(Map->plus));
-		level = 1;
+        /* open OGR specific support files */
+        if (level == 2 && Map->format == GV_FORMAT_OGR) {
+            if (V2_open_old_ogr(Map) < 0) {
+                dig_cidx_free(&(Map->plus));
+                level = 1;
 #endif
 #ifdef HAVE_POSTGRES
-	if (level == 2 && Map->format == GV_FORMAT_POSTGIS) {
-	    if (V2_open_old_pg(Map) < 0) {
-		level = 1;
+        /* open OGR (pseudo-topology access only) specific support
+         * files */
+        if (level == 2 && Map->format == GV_FORMAT_POSTGIS) {
+            if (V2_open_old_pg(Map) < 0) {
+                level = 1;
 #endif
-	if (level_request == 2 && level < 2) {
-	    if (!ogr_mapset) {
-		/* for direct OGR read access is built pseudo-topology on the fly */
-		G_warning(_("Unable to open vector map <%s> on level %d. "
-			    "Try to rebuild vector topology by v.build."),
-			  Vect_get_full_name(Map), level_request);
-		return -1;
+        if (level_request == 2 && level < 2) {
+            if (!ogr_mapset) {
+                /* for direct OGR read access is built pseudo-topology on the fly */
+                G_warning(_("Unable to open vector map <%s> on level %d. "
+                            "Try to rebuild vector topology by v.build."),
+                          Vect_get_full_name(Map), level_request);
+                return -1;
     else {
-	level = 1;		/* i.e. requested level is 1 */
+        level = 1;              /* i.e. requested level is 1 */
     /* open level 1 files / sources (format specific) */
     if (!head_only || ogr_mapset || format == GV_FORMAT_POSTGIS) {
-	/* no need to open coordinates */
-	if (0 != (*Open_old_array[format][1]) (Map, update)) {	/* cannot open */
-	    if (level == 2) {	/* support files opened */
-	    if (level_request == 0)
-	    else
-		G_fatal_error(_("Unable to open vector map <%s> on level %d. "
-	    return -1;
-	if (ogr_mapset && !head_only && level_request != 1) {
-	    /* build pseudo-topology on the fly */
-	    int verbose;
-	    verbose = G_verbose();
-	    G_message(_("Building topology for OGR layer <%s> from datasource '%s'..."),
-		      Map->fInfo.ogr.layer_name, Map->fInfo.ogr.dsn);
-	    G_set_verbose(0);
-	    if (Vect_build(Map)) {
-		level = 2;
-	    G_set_verbose(verbose);
-	    if (level < level_request)
-	      G_fatal_error(_("Unable to open vector map <%s> on level %d"),
-			    Map->fInfo.ogr.layer_name, level_request);
+        /* no need to open coordinates */
+        if (0 != (*Open_old_array[format][1]) (Map, update)) {  /* cannot open */
+            if (level >= 2) {   /* support files opened */
+            if (level_request == 0)
+            else
+                G_fatal_error(_("Unable to open vector map <%s> on level %d. "
+            return -1;
+        if (ogr_mapset && !head_only && level_request != 1) {
+            /* build pseudo-topology on the fly */
+            int verbose;
+            verbose = G_verbose();
+            G_message(_("Building topology for OGR layer <%s> from datasource '%s'..."),
+                      Map->fInfo.ogr.layer_name, Map->fInfo.ogr.dsn);
+            G_set_verbose(0);
+            if (Vect_build(Map)) {
+                level = 2;
+            G_set_verbose(verbose);
+            if (level < level_request)
+              G_fatal_error(_("Unable to open vector map <%s> on level %d"),
+                            Map->fInfo.ogr.layer_name, level_request);
 	if (level < 2 && Map->head.with_z) {
 	    /* topo has been initialized as 2D, update to 3D */
@@ -421,27 +437,27 @@
     Map->head_only = head_only;
     Map->support_updated = FALSE;
     if (update) {
-	Map->mode = GV_MODE_RW;
-	Map->plus.mode = GV_MODE_RW;
+        Map->mode = GV_MODE_RW;
+        Map->plus.mode = GV_MODE_RW;
     else {
-	Map->mode = GV_MODE_READ;
-	Map->plus.mode = GV_MODE_READ;
+        Map->mode = GV_MODE_READ;
+        Map->plus.mode = GV_MODE_READ;
     if (head_only) {
-	Map->head_only = TRUE;
+        Map->head_only = TRUE;
     else {
-	Map->head_only = FALSE;
+        Map->head_only = FALSE;
     G_debug(1, "Vect_open_old(): vector opened on level %d", level);
-    if (level == 1) {		/* without topology */
-	Map->plus.built = GV_BUILD_NONE;
+    if (level == 1) {           /* without topology */
+        Map->plus.built = GV_BUILD_NONE;
-    else {			/* level 2, with topology */
-	Map->plus.built = GV_BUILD_ALL;	/* highest level of topology for level 2 */
+    else {                      /* level 2, with topology */
+        Map->plus.built = GV_BUILD_ALL; /* highest level of topology for level 2 */
     Map->plus.uplist.do_uplist = FALSE;
@@ -452,56 +468,56 @@
     /* open history file */
-    if (update && !ogr_mapset) {		/* native only */
-	Map->hist_fp = G_fopen_modify(buf, GV_HIST_ELEMENT);
-	if (Map->hist_fp == NULL) {
-	    G_warning(_("Unable to open history file for vector map <%s>"),
-	    return -1;
-	G_fseek(Map->hist_fp, (off_t) 0, SEEK_END);
-	Vect_hist_write(Map,
-			"---------------------------------------------------------------------------------\n");
+    if (update && !ogr_mapset) {                /* native only */
+        Map->hist_fp = G_fopen_modify(buf, GV_HIST_ELEMENT);
+        if (Map->hist_fp == NULL) {
+            G_warning(_("Unable to open history file for vector map <%s>"),
+            return -1;
+        G_fseek(Map->hist_fp, (off_t) 0, SEEK_END);
+        Vect_hist_write(Map,
+                        "---------------------------------------------------------------------------------\n");
     else {
-	if (Map->format == GV_FORMAT_NATIVE || Map->format == GV_FORMAT_OGR ||
-	    Map->format == GV_FORMAT_POSTGIS) {
-	    Map->hist_fp = G_fopen_old(buf, GV_HIST_ELEMENT, Map->mapset);
-	    /* If NULL (does not exist) then Vect_hist_read() handle that */
-	else {
-	    Map->hist_fp = NULL;
+        if (Map->format == GV_FORMAT_NATIVE || Map->format == GV_FORMAT_OGR ||
+            Map->format == GV_FORMAT_POSTGIS) {
+            Map->hist_fp = G_fopen_old(buf, GV_HIST_ELEMENT, Map->mapset);
+            /* If NULL (does not exist) then Vect_hist_read() handle that */
+        else {
+            Map->hist_fp = NULL;
-    if (!head_only) {		/* cannot rewind if not fully opened */
-	Vect_rewind(Map);
+    if (!head_only) {           /* cannot rewind if not fully opened */
+        Vect_rewind(Map);
     /* delete support files if native format was opened for update (not head_only) */
     if (update && !head_only) {
-	char file_path[GPATH_MAX];
+        char file_path[GPATH_MAX];
-	G_file_name(file_path, buf, GV_TOPO_ELEMENT, G_mapset());
-	if (access(file_path, F_OK) == 0)	/* topo file exists? */
-	    unlink(file_path);
+        G_file_name(file_path, buf, GV_TOPO_ELEMENT, G_mapset());
+        if (access(file_path, F_OK) == 0)       /* topo file exists? */
+            unlink(file_path);
-	G_file_name(file_path, buf, GV_SIDX_ELEMENT, G_mapset());
-	if (access(file_path, F_OK) == 0)	/* sidx file exists? */
+        G_file_name(file_path, buf, GV_SIDX_ELEMENT, G_mapset());
+        if (access(file_path, F_OK) == 0)       /* sidx file exists? */
-	G_file_name(file_path, buf, GV_CIDX_ELEMENT, G_mapset());
-	if (access(file_path, F_OK) == 0)	/* cidx file exists? */
+        G_file_name(file_path, buf, GV_CIDX_ELEMENT, G_mapset());
+        if (access(file_path, F_OK) == 0)       /* cidx file exists? */
-	if (format == GV_FORMAT_OGR || format == GV_FORMAT_POSTGIS) {
-	    G_file_name(file_path, buf, GV_FIDX_ELEMENT, G_mapset());
-	    if (access(file_path, F_OK) == 0)	/* fidx file exists? */
+        if (format == GV_FORMAT_OGR || format == GV_FORMAT_POSTGIS) {
+            G_file_name(file_path, buf, GV_FIDX_ELEMENT, G_mapset());
+            if (access(file_path, F_OK) == 0)   /* fidx file exists? */
     return level;
@@ -543,7 +559,7 @@
   \return -1 on error
 int Vect_open_old2(struct Map_info *Map, const char *name, const char *mapset,
-		   const char *layer)
+                   const char *layer)
     return open_old(Map, name, mapset, layer, 0, 0);
@@ -639,7 +655,7 @@
   \return -1 on error
 int Vect_open_old_head2(struct Map_info *Map, const char *name, const char *mapset,
     return open_old(Map, name, mapset, layer, 0, 1);
@@ -656,7 +672,7 @@
   \return -1 on error
 int Vect_open_update_head(struct Map_info *Map, const char *name,
-			  const char *mapset)
+                          const char *mapset)
     return open_old(Map, name, mapset, NULL, 1, 1);
@@ -688,129 +704,129 @@
     Vect__init_head(Map);
-	if (strcmp(xmapset, G_mapset()) != 0) {
-	    G_fatal_error(_("<%s> is not the current mapset (%s)"), name,
-			  G_mapset());
-	    return -1;
-	name = xname;
+        if (strcmp(xmapset, G_mapset()) != 0) {
+            G_fatal_error(_("<%s> is not the current mapset (%s)"), name,
+                          G_mapset());
+            return -1;
+        name = xname;
     /* check for [A-Za-z][A-Za-z0-9_]* in name */
     if (Vect_legal_filename(name) < 0) {
-	G_fatal_error(_("Vector map name is not SQL compliant"));
-	return -1;
+        G_fatal_error(_("Vector map name is not SQL compliant"));
+        return -1;
     /* determine output format native or ogr */
     Map->format = GV_FORMAT_NATIVE;
     if (strcmp(G_program_name(), "v.external") != 0) {
-	if (G_find_file2("", "OGR", G_mapset())) {
-	    /* OGR */
-	    FILE *fp;
-	    const char *p;
-	    struct Key_Value *key_val;
-	    struct Format_info_ogr *ogr_info;
-	    G_debug(2, " using OGR format");
-	    Map->format = GV_FORMAT_OGR_DIRECT;
-	    fp = G_fopen_old("", "OGR", G_mapset());
-	    if (!fp) {
-		G_fatal_error(_("Unable to open OGR file"));
-	    key_val = G_fread_key_value(fp);
-	    fclose(fp);
-	    ogr_info = &(Map->fInfo.ogr);
-	    /* format */
-	    p = G_find_key_value("format", key_val);
-	    if (p)
-		ogr_info->driver_name = G_store(p);
-	    /* dsn */
-	    p = G_find_key_value("dsn", key_val);
-	    if (p)
-		ogr_info->dsn = G_store(p);
-	    /* options */
-	    p = G_find_key_value("options", key_val);
-	    if (p)
-		ogr_info->layer_options = G_tokenize(p, ",");
-	    ogr_info->layer_name = G_store(name);
-	if (G_find_file2("", "PG", G_mapset())) {
-	    /* PostGIS */
-	    if (Map->fInfo.ogr.driver_name) {
-		G_warning(_("OGR output also detected, using OGR"));
-	    else {
-		FILE *fp;
-		const char *p;
-		struct Format_info_pg *pg_info;
-		G_debug(2, " using PostGIS format");
-		Map->format = GV_FORMAT_POSTGIS;
-		fp = G_fopen_old("", "PG", G_mapset());
-		if (!fp) {
-		    G_fatal_error(_("Unable to open PG file"));
-		fclose(fp);
-		pg_info = &(Map->fInfo.pg);
-		/* conninfo */
-		p = G_find_key_value("conninfo", key_val);
-		if (p) {
-		    pg_info->conninfo = G_store(p);
-		    G_debug(1, "PG: conninfo = '%s'", pg_info->conninfo);
-		/* schema (default: public) */
-		p = G_find_key_value("schema", key_val);
-		if (p)
-		    pg_info->schema_name = G_store(p);
-		else
-		    pg_info->schema_name = G_store("public");
-		G_debug(1, "PG: schema_name = '%s'", pg_info->schema_name);
-		/* fid column (default: ogc_fid) */
-		p = G_find_key_value("fid", key_val);
-		if (p)
-		    pg_info->fid_column = G_store(p);
-		else
-		    pg_info->fid_column = G_store("ogc_fid");
-		G_debug(1, "PG: fid_column = '%s'", pg_info->fid_column);
-		/* geometry column (default: wkb_geometry) */
-		p = G_find_key_value("geometry_name", key_val);
-		if (p)
-		    pg_info->geom_column = G_store(p);
-		else
-		    pg_info->geom_column = G_store("wkb_geometry");
-		G_debug(1, "PG: geom_column = '%s'", pg_info->geom_column);
+        if (G_find_file2("", "OGR", G_mapset())) {
+            /* OGR */
+            FILE *fp;
+            const char *p;
+            struct Key_Value *key_val;
+            struct Format_info_ogr *ogr_info;
+            G_debug(2, " using OGR format");
+            Map->format = GV_FORMAT_OGR_DIRECT;
+            fp = G_fopen_old("", "OGR", G_mapset());
+            if (!fp) {
+                G_fatal_error(_("Unable to open OGR file"));
+            key_val = G_fread_key_value(fp);
+            fclose(fp);
+            ogr_info = &(Map->fInfo.ogr);
+            /* format */
+            p = G_find_key_value("format", key_val);
+            if (p)
+                ogr_info->driver_name = G_store(p);
+            /* dsn */
+            p = G_find_key_value("dsn", key_val);
+            if (p)
+                ogr_info->dsn = G_store(p);
+            /* options */
+            p = G_find_key_value("options", key_val);
+            if (p)
+                ogr_info->layer_options = G_tokenize(p, ",");
+            ogr_info->layer_name = G_store(name);
+        if (G_find_file2("", "PG", G_mapset())) {
+            /* PostGIS */
+            if (Map->fInfo.ogr.driver_name) {
+                G_warning(_("OGR output also detected, using OGR"));
+            else {
+                FILE *fp;
+                const char *p;
+                struct Format_info_pg *pg_info;
+                G_debug(2, " using PostGIS format");
+                Map->format = GV_FORMAT_POSTGIS;
+                fp = G_fopen_old("", "PG", G_mapset());
+                if (!fp) {
+                    G_fatal_error(_("Unable to open PG file"));
+                fclose(fp);
+                pg_info = &(Map->fInfo.pg);
+                /* conninfo */
+                p = G_find_key_value("conninfo", key_val);
+                if (p) {
+                    pg_info->conninfo = G_store(p);
+                    G_debug(1, "PG: conninfo = '%s'", pg_info->conninfo);
+                /* schema (default: public) */
+                p = G_find_key_value("schema", key_val);
+                if (p)
+                    pg_info->schema_name = G_store(p);
+                else
+                    pg_info->schema_name = G_store("public");
+                G_debug(1, "PG: schema_name = '%s'", pg_info->schema_name);
+                /* fid column (default: ogc_fid) */
+                p = G_find_key_value("fid", key_val);
+                if (p)
+                    pg_info->fid_column = G_store(p);
+                else
+                    pg_info->fid_column = G_store("ogc_fid");
+                G_debug(1, "PG: fid_column = '%s'", pg_info->fid_column);
+                /* geometry column (default: wkb_geometry) */
+                p = G_find_key_value("geometry_name", key_val);
+                if (p)
+                    pg_info->geom_column = G_store(p);
+                else
+                    pg_info->geom_column = G_store("wkb_geometry");
+                G_debug(1, "PG: geom_column = '%s'", pg_info->geom_column);
                 /* table name */
-		Map->fInfo.pg.table_name = G_store(name);
+                Map->fInfo.pg.table_name = G_store(name);
     if (Map->format == GV_FORMAT_NATIVE) {
-	/* native */
-	G_debug(2, " using native format");
+        /* native */
+        G_debug(2, " using native format");
-	/* check if map already exists */
-	if (G_find_vector2(name, G_mapset()) != NULL) {
-	    G_warning(_("Vector map <%s> already exists and will be overwritten"),
-		      name);
-	    ret = Vect_delete(name);
-	    if (ret == -1) {
-		G_warning(_("Unable to delete vector map <%s>"), name);
-		return -1;
+        /* check if map already exists */
+        if (G_find_vector2(name, G_mapset()) != NULL) {
+            G_warning(_("Vector map <%s> already exists and will be overwritten"),
+                      name);
+            ret = Vect_delete(name);
+            if (ret == -1) {
+                G_warning(_("Unable to delete vector map <%s>"), name);
+                return -1;
@@ -822,20 +838,20 @@
     Map->plus.spidx_with_z = Map->plus.with_z = Map->head.with_z = (with_z != 0);
     if ((*Open_new_array[Map->format][1]) (Map, name, with_z) < 0) {
-	G_fatal_error(_("Unable to create vector map <%s>"),
-		      name);
-	return -1;
+        G_fatal_error(_("Unable to create vector map <%s>"),
+                      name);
+        return -1;
         /* Open history file */
-	Map->hist_fp = G_fopen_new(buf, GV_HIST_ELEMENT);
-	    G_warning(_("Unable to open history file of vector map <%s>"),
-		      name);
-	    return -1;
+        Map->hist_fp = G_fopen_new(buf, GV_HIST_ELEMENT);
+            G_warning(_("Unable to open history file of vector map <%s>"),
+                      name);
+            return -1;
     Open_level = 0;
@@ -879,38 +895,38 @@
     switch (Map->format) {
     case GV_FORMAT_NATIVE:
-	G_file_name(path, buf, GV_COOR_ELEMENT, Map->mapset);
-	G_debug(1, "get coor info: %s", path);
-	if (0 != stat(path, &stat_buf)) {
-	    G_warning(_("Unable to stat file <%s>"), path);
-	    Info->size = -1L;
-	    Info->mtime = -1L;
-	else {
-	    Info->size = (off_t)stat_buf.st_size;      /* file size */
-	    Info->mtime = (long)stat_buf.st_mtime;     /* last modified time */
+        G_file_name(path, buf, GV_COOR_ELEMENT, Map->mapset);
+        G_debug(1, "get coor info: %s", path);
+        if (0 != stat(path, &stat_buf)) {
+            G_warning(_("Unable to stat file <%s>"), path);
+            Info->size = -1L;
+            Info->mtime = -1L;
+        else {
+            Info->size = (off_t)stat_buf.st_size;      /* file size */
+            Info->mtime = (long)stat_buf.st_mtime;     /* last modified time */
         /* stat does not give correct size on MINGW
          * if the file is opened */
 #ifdef __MINGW32__
-	if (Map->open == VECT_OPEN_CODE) {
-	    dig_fseek(&(Map->dig_fp), 0L, SEEK_END);
-	    G_debug(2, "dig_ftell = %d", dig_ftell(&(Map->dig_fp)));
-	    Info->size = dig_ftell(&(Map->dig_fp));
+        if (Map->open == VECT_OPEN_CODE) {
+            dig_fseek(&(Map->dig_fp), 0L, SEEK_END);
+            G_debug(2, "dig_ftell = %d", dig_ftell(&(Map->dig_fp)));
+            Info->size = dig_ftell(&(Map->dig_fp));
 #endif
-	break;
+        break;
     case GV_FORMAT_OGR:
     case GV_FORMAT_OGR_DIRECT:
     case GV_FORMAT_POSTGIS:
-	Info->size = 0L;
-	Info->mtime = 0L;
-	break;
+        Info->size = 0L;
+        Info->mtime = 0L;
+        break;
     G_debug(1, "Info->size = %lu, Info->mtime = %ld",
-	    (unsigned long)Info->size, Info->mtime);
+            (unsigned long)Info->size, Info->mtime);
     return 1;
@@ -937,18 +953,18 @@
-	sprintf(maptype, "native");
-	break;
+        sprintf(maptype, "native");
+        break;
     case GV_FORMAT_OGR:
-	sprintf(maptype, "OGR");
-	break;
+        sprintf(maptype, "OGR");
+        break;
-	sprintf(maptype, "PostGIS");
-	break;
+        sprintf(maptype, "PostGIS");
+        break;
     default:
-	sprintf(maptype, _("unknown %d (update Vect_maptype_info)"),
-		Map->format);
+        sprintf(maptype, _("unknown %d (update Vect_maptype_info)"),
+                Map->format);
     return G_store(maptype);
@@ -991,23 +1007,23 @@
     struct Plus_head *Plus;
     G_debug(1, "Vect_open_topo(): name = %s mapset= %s", Map->name,
-	    Map->mapset);
+            Map->mapset);
     Plus = &(Map->plus);
     G_file_name(file_path, buf, GV_TOPO_ELEMENT, Map->mapset);
-    if (access(file_path, F_OK) != 0)	/* does not exist */
-	return 1;
+    if (access(file_path, F_OK) != 0)   /* does not exist */
+        return 1;
     dig_file_init(&fp);
     fp.file = G_fopen_old(buf, GV_TOPO_ELEMENT, Map->mapset);
-    if (fp.file == NULL) {	/* topo file is not available */
-	G_debug(1, "Cannot open topo file for vector '%s@%s'.",
-		Map->name, Map->mapset);
-	return -1;
+    if (fp.file == NULL) {      /* topo file is not available */
+        G_debug(1, "Cannot open topo file for vector '%s@%s'.",
+                Map->name, Map->mapset);
+        return -1;
     /* get coor info */
@@ -1016,16 +1032,16 @@
     /* load head */
     if (dig_Rd_Plus_head(&fp, Plus) == -1)
-	return -1;
+        return -1;
     G_debug(1, "Topo head: coor size = %lu, coor mtime = %ld",
-	    (unsigned long)Plus->coor_size, Plus->coor_mtime);
+            (unsigned long)Plus->coor_size, Plus->coor_mtime);
     /* do checks */
     err = 0;
     if (CInfo.size != Plus->coor_size) {
-	G_warning(_("Size of 'coor' file differs from value saved in topology file"));
-	err = 1;
+        G_warning(_("Size of 'coor' file differs from value saved in topology file"));
+        err = 1;
     /* Do not check mtime because mtime is changed by copy */
@@ -1035,9 +1051,9 @@
     if (err) {
-	G_warning(_("Please rebuild topology for vector map <%s@%s>"),
-	return -1;
+        G_warning(_("Please rebuild topology for vector map <%s@%s>"),
+        return -1;
     /* load file to the memory */
@@ -1050,7 +1066,7 @@
     /* dig_file_free ( &fp); */
     if (ret == 0)
-	return -1;
+        return -1;
     return 0;
@@ -1072,11 +1088,11 @@
     G_debug(1, "Vect_open_sidx(): name = %s mapset= %s mode = %s", Map->name,
-	    Map->mapset, mode == 0 ? "old" : (mode == 1 ? "update" : "new"));
+            Map->mapset, mode == 0 ? "old" : (mode == 1 ? "update" : "new"));
     if (Map->plus.Spidx_built == TRUE) {
-	G_warning("Spatial index already opened");
-	return 0;
+        G_warning("Spatial index already opened");
+        return 0;
@@ -1084,80 +1100,80 @@
     dig_file_init(&(Map->plus.spidx_fp));
     if (mode < 2) {
-	G_file_name(file_path, buf, GV_SIDX_ELEMENT, Map->mapset);
+        G_file_name(file_path, buf, GV_SIDX_ELEMENT, Map->mapset);
-	    return 1;
+            return 1;
-	Map->plus.spidx_fp.file =
-	    G_fopen_old(buf, GV_SIDX_ELEMENT, Map->mapset);
+        Map->plus.spidx_fp.file =
+            G_fopen_old(buf, GV_SIDX_ELEMENT, Map->mapset);
-	if (Map->plus.spidx_fp.file == NULL) {	/* sidx file is not available */
-	    G_debug(1, "Cannot open spatial index file for vector '%s@%s'.",
-	    return -1;
+        if (Map->plus.spidx_fp.file == NULL) {  /* sidx file is not available */
+            G_debug(1, "Cannot open spatial index file for vector '%s@%s'.",
+            return -1;
-	/* get coor info */
-	/* NOTE: coor file not yet opened */
-	Vect_coor_info(Map, &CInfo);
+        /* get coor info */
+        /* NOTE: coor file not yet opened */
+        Vect_coor_info(Map, &CInfo);
-	/* initialize spatial index */
-	Map->plus.Spidx_new = FALSE;
+        /* initialize spatial index */
+        Map->plus.Spidx_new = FALSE;
-	/* load head */
-	if (dig_Rd_spidx_head(&(Map->plus.spidx_fp), Plus) == -1) {
-	    fclose(Map->plus.spidx_fp.file);
-	    return -1;
+        /* load head */
+        if (dig_Rd_spidx_head(&(Map->plus.spidx_fp), Plus) == -1) {
+            fclose(Map->plus.spidx_fp.file);
+            return -1;
-	G_debug(1, "Sidx head: coor size = %lu, coor mtime = %ld",
+        G_debug(1, "Sidx head: coor size = %lu, coor mtime = %ld",
-	/* do checks */
-	err = 0;
-	if (CInfo.size != Plus->coor_size) {
-	    G_warning(_("Size of 'coor' file differs from value saved in sidx file"));
-	    err = 1;
-	/* Do not check mtime because mtime is changed by copy */
-	   if ( CInfo.mtime != Plus->coor_mtime ) {
-	   G_warning ( "Time of last modification for 'coor' file differs from value saved in topo file.\n");
-	   err = 1;
-	if (err) {
-	    return -1;
+        /* do checks */
+        err = 0;
+        if (CInfo.size != Plus->coor_size) {
+            G_warning(_("Size of 'coor' file differs from value saved in sidx file"));
+            err = 1;
+        /* Do not check mtime because mtime is changed by copy */
+           if ( CInfo.mtime != Plus->coor_mtime ) {
+           G_warning ( "Time of last modification for 'coor' file differs from value saved in topo file.\n");
+           err = 1;
+        if (err) {
+            return -1;
     if (mode) {
-	/* open new spatial index */
-	Map->plus.Spidx_new = TRUE;
-	/* file based or memory based */
-	if (getenv("GRASS_VECTOR_LOWMEM")) {
-	    /* free old indices */
-	    dig_spidx_free(Plus);
-	    /* initialize file based indices */
-	    Map->plus.Spidx_file = 1;
-	    dig_spidx_init(Plus);
-	G_debug(1, "%s based spatial index",
-	           Map->plus.Spidx_file == 0 ? "Memory" : "File");
+        /* open new spatial index */
+        Map->plus.Spidx_new = TRUE;
+        /* file based or memory based */
+        if (getenv("GRASS_VECTOR_LOWMEM")) {
+            /* free old indices */
+            dig_spidx_free(Plus);
+            /* initialize file based indices */
+            Map->plus.Spidx_file = 1;
+            dig_spidx_init(Plus);
+        G_debug(1, "%s based spatial index",
+                   Map->plus.Spidx_file == 0 ? "Memory" : "File");
-	if (mode == 1) {
-	    /* load spatial index for update */
-	    if (dig_Rd_spidx(&(Map->plus.spidx_fp), Plus) == -1) {
-		return -1;
+        if (mode == 1) {
+            /* load spatial index for update */
+            if (dig_Rd_spidx(&(Map->plus.spidx_fp), Plus) == -1) {
+                return -1;
     Map->plus.Spidx_built = TRUE;
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c	2012-05-31 12:32:19 UTC (rev 51901)
+++ grass/trunk/lib/vector/Vlib/open_pg.c	2012-05-31 12:47:11 UTC (rev 51902)
@@ -11,7 +11,7 @@
    (>=v2). Read the file COPYING that comes with GRASS for details.
    \author Martin Landa <landa.martin gmail.com>
 #include <string.h>
 #include <stdlib.h>
@@ -23,11 +23,27 @@
 #include "pg_local_proto.h"
+static struct edge_data {
+    int id;
+    int start_node;
+    int end_node;
+    int left_face;
+    int right_face;
 static char *get_key_column(struct Format_info_pg *);
 static SF_FeatureType ftype_from_string(const char *);
 static int drop_table(struct Format_info_pg *);
 static int check_schema(const struct Format_info_pg *);
 static int create_table(struct Format_info_pg *, const struct field_info *);
+static void connect_db(struct Format_info_pg *);
+static int parse_bbox(const char *, struct bound_box *, int);
+static int num_of_records(const struct Format_info_pg *, const char *);
+static int read_p_node(struct Plus_head *, int, int, struct Format_info_pg *);
+static int read_p_line(struct Plus_head *, int, const struct edge_data *, struct Format_info_pg *);
+static int read_p_area(struct Plus_head *, int, int, struct Format_info_pg *);
+static int load_plus_head(struct Format_info_pg *, PGresult *, struct Plus_head *);
+static int load_plus(struct Format_info_pg *, PGresult *, struct Plus_head *);
 #endif
@@ -67,13 +83,9 @@
             pg_info->conninfo, pg_info->table_name);
     /* connect database */
-    pg_info->conn = PQconnectdb(pg_info->conninfo);
-    G_debug(2, "   PQconnectdb(): %s", pg_info->conninfo);
-    if (PQstatus(pg_info->conn) == CONNECTION_BAD)
-        G_fatal_error("%s\n%s",
-                      _("Connection ton PostgreSQL database failed."),
-                      PQerrorMessage(pg_info->conn));
+    if (!pg_info->conn)
+        connect_db(pg_info);
     /* get DB name */
     pg_info->db_name = G_store(PQdb(pg_info->conn));
     if (!pg_info->db_name) {
@@ -81,11 +93,6 @@
         return -1;
-    /* if schema not defined, use 'public' */
-    if (!pg_info->schema_name) {
     /* get fid and geometry column */
     sprintf(stmt, "SELECT f_geometry_column, coord_dimension, srid, type "
             "FROM geometry_columns WHERE f_table_schema = '%s' AND "
@@ -365,7 +372,73 @@
 #endif
+  \brief Read full-topology for PostGIS links
+  Note: Only 2D topological primitives are currently supported
+  \param[in,out] Map pointer to Map_info structure
+  \param head_only TRUE to read only header
+  \return 0 on success
+  \return 1 topology layer does not exist
+  \return -1 on error
+int Vect_open_topo_pg(struct Map_info *Map, int head_only)
+    char stmt[DB_SQL_MAX];
+    struct Plus_head *plus;
+    PGresult *res;
+    plus = &(Map->plus);
+    /* connect database */
+    /* check if topology layer/schema exists */
+    sprintf(stmt,
+            "SELECT t.name,t.hasz,l.feature_column FROM topology.layer "
+            "AS l JOIN topology.topology AS t ON l.topology_id = t.id "
+            "WHERE schema_name = '%s' AND table_name = '%s'",
+            pg_info->schema_name, pg_info->table_name);
+    G_debug(2, "SQL: %s", stmt);
+    res = PQexec(pg_info->conn, stmt);
+    if (!res || PQresultStatus(res) != PGRES_TUPLES_OK ||
+        PQntuples(res) != 1) {
+        G_debug(1, "Topology layers for '%s.%s' not found (%s)",
+                pg_info->schema_name, pg_info->table_name,
+                PQerrorMessage(pg_info->conn));
+        if (res)
+            PQclear(res);
+        return 1;
+    pg_info->toposchema_name = G_store(PQgetvalue(res, 0, 0));
+    pg_info->topogeom_column = G_store(PQgetvalue(res, 0, 2));
+    /* free and init plus structure */
+    dig_init_plus(plus);
+    if (load_plus_head(pg_info, res, plus) != 0)
+        return -1;
+    if (head_only)
+        return 0;
+    return load_plus(pg_info, res, plus);
+#else
+    G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
+    return -1;
+#endif
+#ifdef HAVE_POSTGRES
 char *get_key_column(struct Format_info_pg *pg_info)
     char *key_column;
@@ -686,4 +759,599 @@
     return 0;
+void connect_db(struct Format_info_pg *pg_info)
+    pg_info->conn = PQconnectdb(pg_info->conninfo);
+    G_debug(2, "   PQconnectdb(): %s", pg_info->conninfo);
+    if (PQstatus(pg_info->conn) == CONNECTION_BAD)
+        G_fatal_error("%s\n%s",
+                      _("Connection ton PostgreSQL database failed."),
+  \brief Parse BBOX string
+  \param value string buffer
+  \param[out] bbox pointer to output bound_box struct
+int parse_bbox(const char *value, struct bound_box *bbox, int with_z)
+    unsigned int i;
+    size_t length, prefix_length;
+    char **tokens, **tokens_coord, *coord;
+    prefix_length = strlen("box3d(");
+    if (G_strncasecmp(value, "box3d(", prefix_length) != 0)
+        return -1;
+    /* strip off "bbox3d(...)" */
+    length = strlen(value);
+    coord = G_malloc(length - prefix_length);
+    for (i = prefix_length; i < length; i++)
+        coord[i-prefix_length] = value[i];
+    coord[length-prefix_length-1] = '\0';
+    tokens = G_tokenize(coord, ",");
+    G_free(coord);
+    if (G_number_of_tokens(tokens) != 2) {
+        G_free_tokens(tokens);
+        return -1;
+    /* parse bbox LL corner */
+    tokens_coord = G_tokenize(tokens[0], " ");
+    if (G_number_of_tokens(tokens_coord) != 3) {
+        G_free_tokens(tokens_coord);
+    bbox->W = atof(tokens_coord[0]);
+    bbox->S = atof(tokens_coord[1]);
+    bbox->B = atof(tokens_coord[2]);
+    /* parse bbox UR corner */
+    tokens_coord = G_tokenize(tokens[1], " ");
+    bbox->E = atof(tokens_coord[0]);
+    bbox->N = atof(tokens_coord[1]);
+    bbox->T = atof(tokens_coord[2]);
+    return 0;
+  \brief Get number of records for given SQL statement
+  \param stmt string buffer with SQL statement
+  \return number of returned records
+int num_of_records(const struct Format_info_pg *pg_info,
+                   const char *stmt)
+    int result;
+    PGresult *res;
+        G_warning(_("Unable to get number of records for:\n%s"), stmt);
+        if (res)
+            PQclear(res);
+        return -1;
+    result = atoi(PQgetvalue(res, 0, 0));
+    PQclear(res);
+    return result;
+  \brief Read P_node structure
+  See dig_Rd_P_node() for reference.
+  \param plus pointer to Plus_head structure
+  \param n index (starts at 1)
+  \param id node id (table "node")
+  \param pg_info pointer to Format_info_pg sttucture
+  \return -1 on failure
+int read_p_node(struct Plus_head *plus, int n, int id,
+                struct Format_info_pg *pg_info)
+    int i, cnt;
+    struct P_node *node;
+    PGresult *res;
+    /* get lines connected to the node */
+    sprintf(stmt,
+            "SELECT edge_id,'s' as node,"
+            "ST_Azimuth(ST_StartPoint(geom), ST_PointN(geom, 2)) AS angle"
+            " FROM \"%s\".edge WHERE start_node = %d UNION ALL "
+            "SELECT edge_id,'e' as node,"
+            "ST_Azimuth(ST_EndPoint(geom), ST_PointN(geom, ST_NumPoints(geom) - 1)) AS angle"
+            " FROM \"%s\".edge WHERE end_node = %d"
+            " ORDER BY angle DESC",
+            pg_info->toposchema_name, id,
+            pg_info->toposchema_name, id);
+    if (!res || PQresultStatus(res) != PGRES_TUPLES_OK) {
+        G_warning(_("Unable to read node %d"), id);
+        if (res)
+            PQclear(res);
+        return -1;
+    cnt = PQntuples(res);
+    if (cnt == 0) { /* dead ??? */
+        plus->Node[n] = NULL;
+        return 0;
+    node = dig_alloc_node();
+    node->n_lines = cnt;
+    G_debug(4, "read_p_node(): id = %d, n_lines = %d", id, cnt);
+    if (dig_node_alloc_line(node, node->n_lines) == -1)
+        return -1;
+    /* lines / angles */
+    for (i = 0; i < node->n_lines; i++) {
+        node->lines[i] = atoi(PQgetvalue(res, i, 0));
+        if (strcmp(PQgetvalue(res, i, 1), "s") != 0) {
+            /* end node */
+            node->lines[i] *= -1;
+        node->angles[i] = M_PI / 2 - atof(PQgetvalue(res, i, 2));
+        /* angles range <-PI; PI> */
+        if (node->angles[i] > M_PI)
+            node->angles[i] = node->angles[i] - 2 * M_PI;
+        if (node->angles[i] < -1.0 * M_PI)
+            node->angles[i] = node->angles[i] + 2 * M_PI;
+        G_debug(5, "\tline = %d angle = %f", node->lines[i],
+                node->angles[i]);
+    PQclear(res);
+    if (plus->with_z)
+    if (0 >= dig__fread_port_P(&n_edges, 1, fp))
+    /* get node coordinates */
+    sprintf(stmt,
+            "SELECT ST_X(geom),ST_Y(geom),ST_Z(geom) FROM \"%s\".node "
+            "WHERE node_id = %d",
+        if (res)
+            PQclear(res);
+        return -1;
+    node->x = atof(PQgetvalue(res, 0, 0));
+    node->y = atof(PQgetvalue(res, 0, 1));
+    if (plus->with_z)
+        node->z = atof(PQgetvalue(res, 0, 2));
+    else
+        node->z = 0;
+    PQclear(res);
+    plus->Node[n] = node;
+    return 0;
+  \brief Read P_line structure
+  See dig_Rd_P_line() for reference.
+  Supported feature types:
+   - GV_POINT
+   - GV_LINE
+   - GV_BOUNDARY
+  \param data edge data (id, start/end node, left/right face, ...)
+int read_p_line(struct Plus_head *plus, int n,
+                const struct edge_data *data,
+    int tp;
+    struct P_line *line;
+    if (data->start_node == 0 && data->end_node == 0) {
+        if (data->left_face == 0)
+            tp = GV_POINT;
+        else
+            tp = GV_CENTROID;
+    else if (data->left_face == 0 && data->right_face == 0) {
+        tp = GV_LINE;
+    else {
+        tp = GV_BOUNDARY;
+    if (tp == 0) { /* dead ??? */
+        plus->Line[n] = NULL;
+        return 0;
+    line = dig_alloc_line();
+    /* type & offset ( = id) */
+    line->type = tp;
+    line->offset = data->id;
+    G_debug(4, "read_p_line(): id/offset = %d type = %d", data->id, line->type);
+    /* topo */
+    if (line->type == GV_POINT) {
+        line->topo = NULL;
+    else {
+        line->topo = dig_alloc_topo(line->type);
+        /* lines */
+        if (line->type == GV_LINE) {
+            struct P_topo_l *topo = (struct P_topo_l *)line->topo;
+            topo->N1 = data->start_node;
+            topo->N2 = data->end_node;
+        /* boundaries */
+        else if (line->type == GV_BOUNDARY) {
+            struct P_topo_b *topo = (struct P_topo_b *)line->topo;
+            topo->left  = data->left_face == 0 ? -1 : data->left_face;
+            topo->right = data->right_face == 0 ? -1 : data->right_face;
+        /* centroids */
+        else if (line->type == GV_CENTROID) {
+            struct P_topo_c *topo = (struct P_topo_c *)line->topo;
+            topo->area  = data->left_face;
+        /* TODO: faces | kernels */
+    plus->Line[n] = line;
+    return 0;
+  \brief Read P_area structure
+  See dig_Rd_P_area() for reference.
+  \param face_id face id (see 'face' table)
+int read_p_area(struct Plus_head *plus, int n, int face_id, struct Format_info_pg *pg_info)
+    int i, cnt;
+    PGresult *res;
+    struct P_area *area;
+    sprintf(stmt,
+            "SELECT edge from ST_GetFaceEdges('%s', %d)",
+            pg_info->toposchema_name, face_id);
+        G_warning(_("Unable to read face %d"), face_id);
+        if (res)
+            PQclear(res);
+        return -1;
+    if (cnt == 0) { /* dead */
+        plus->Area[n] = NULL;
+        return 0;
+    area = dig_alloc_area();
+    /* boundaries */
+    area->n_lines = cnt;
+    if (dig_area_alloc_line(area, area->n_lines) == -1)
+        return -1;
+    area->lines = (plus_t *)G_realloc(area->lines, sizeof(plus_t) * area->n_lines);
+    for (i = 0; i < area->n_lines; i++) {
+        /* GRASS   Topo model: lines in clockwise order
+           PosTGIS Topo model: lines in counter clockwise order */
+        area->lines[i] = -1 * atoi(PQgetvalue(res, i, 0));
+    /* isles */
+    /* TODO */
+    /* centroid */
+    area->centroid = plus->n_lines - plus->n_clines + i;
+    plus->Area[n] = area;
+    PQclear(res);
+    return 0;
+  \brief Read topo header info only
+  \param[in,out] plus pointer to Plus_head struct
+int load_plus_head(struct Format_info_pg *pg_info, PGresult *res, struct Plus_head *plus)
+    plus->off_t_size = -1;
+    /* check for 3D */
+    if (strcmp(PQgetvalue(res, 0, 1), "t") == 0)
+        plus->with_z = WITH_Z;
+    PQclear(res);
+    /* get map bounding box */
+    sprintf(stmt,
+            "SELECT ST_3DExtent(%s) FROM \"%s\".\"%s\"",
+            pg_info->topogeom_column, pg_info->schema_name, pg_info->table_name);
+        G_warning(_("Unable to get map bounding box from topology"));
+        if (res)
+            PQclear(res);
+        return -1;
+    if (parse_bbox(PQgetvalue(res, 0, 0), &(plus->box), plus->with_z) != 0) {
+        G_warning(_("Unable to parse map bounding box:\n%s"),
+                  PQgetvalue(res, 0, 0));
+        return -1;
+    PQclear(res);
+    /* number of topological primitives */
+    /* nodes
+       note: isolated nodes are registered in GRASS Topology model */
+    sprintf(stmt,
+            "SELECT COUNT(DISTINCT node) FROM (SELECT start_node AS node "
+            "FROM \"%s\".edge GROUP BY start_node UNION ALL SELECT end_node "
+            "AS node FROM \"%s\".edge GROUP BY end_node) AS foo",
+            pg_info->toposchema_name, pg_info->toposchema_name);
+    plus->n_nodes = num_of_records(pg_info, stmt);
+    G_debug(3, "Vect_open_topo_pg(): n_nodes=%d", plus->n_nodes);
+    /* lines (edges in PostGIS Topology model) */
+    sprintf(stmt,
+            "SELECT COUNT(*) FROM \"%s\".edge",
+            pg_info->toposchema_name);
+    /* + isolated nodes as points
+       + centroids */
+    plus->n_lines = num_of_records(pg_info, stmt);
+    /* areas (faces in PostGIS Topology model) */
+    sprintf(stmt,
+            "SELECT COUNT(*) FROM \"%s\".face WHERE mbr IS NOT NULL",
+    plus->n_areas = num_of_records(pg_info, stmt);
+    G_debug(3, "Vect_open_topo_pg(): n_areas=%d", plus->n_areas);
+    /* TODO: n_isles | n_volumes | n_holes */
+    /* number of features group by type */
+    /* points */
+    sprintf(stmt,
+            "SELECT COUNT(*) FROM \"%s\".node WHERE node_id NOT IN "
+            "(SELECT node FROM (SELECT start_node AS node FROM \"%s\".edge "
+            "GROUP BY start_node UNION ALL SELECT end_node AS node FROM "
+            "\"%s\".edge GROUP BY end_node) AS foo)",
+            pg_info->toposchema_name, pg_info->toposchema_name,
+    plus->n_plines = num_of_records(pg_info, stmt);
+    G_debug(3, "Vect_open_topo_pg(): n_plines=%d", plus->n_plines);
+    /* lines */
+    sprintf(stmt,
+            "SELECT COUNT(*) FROM \"%s\".edge WHERE "
+            "left_face = 0 AND right_face = 0",
+    plus->n_llines = num_of_records(pg_info, stmt);
+    G_debug(3, "Vect_open_topo_pg(): n_llines=%d", plus->n_llines);
+    /* boundaries */
+    sprintf(stmt,
+            "left_face != 0 OR right_face != 0",
+    plus->n_blines = num_of_records(pg_info, stmt);
+    G_debug(3, "Vect_open_topo_pg(): n_blines=%d", plus->n_blines);
+    /* centroids */
+    sprintf(stmt,
+    plus->n_clines = num_of_records(pg_info, stmt);
+    plus->n_lines += plus->n_plines; /* register isolated nodes as points */
+    G_debug(3, "Vect_open_topo_pg(): n_clines=%d", plus->n_clines);
+    /* TODO: nflines | n_klines */
+    /* lines - register isolated nodes as points and centroids */
+    plus->n_lines += plus->n_plines + plus->n_clines;
+    G_debug(3, "Vect_open_topo_pg(): n_lines=%d", plus->n_lines);
+    return 0;
+  \brief Read topo info
+int load_plus(struct Format_info_pg *pg_info, PGresult *res, struct Plus_head *plus)
+    int i, id, ntuples;
+    struct edge_data line_data;
+    /* read nodes (GRASS Topo)
+       note: standalone nodes are ignored
+    sprintf(stmt,
+            "SELECT node_id FROM \"%s\".node WHERE node_id IN "
+        PQntuples(res) != plus->n_nodes) {
+        G_warning(_("Unable to read nodes"));
+        if (res)
+            PQclear(res);
+        return -1;
+    dig_alloc_nodes(plus, plus->n_nodes);
+    for (i = 1; i <= plus->n_nodes; i++) {
+        id = atoi(PQgetvalue(res, i - 1, 0));
+        read_p_node(plus, i, id, pg_info);
+    PQclear(res);
+    /* read lines (GRASS Topo)
+       - standalone nodes -> points
+       - edges -> lines/bouindaries
+    dig_alloc_lines(plus, plus->n_lines);
+    /* read PostGIS Topo standalone nodes */
+    sprintf(stmt,
+            "SELECT node_id FROM \"%s\".node WHERE node_id NOT IN "
+        PQntuples(res) > plus->n_lines) {
+        G_warning(_("Unable to read lines"));
+        if (res)
+            PQclear(res);
+        return -1;
+    ntuples = PQntuples(res); /* plus->n_plines */
+    G_zero(&line_data, sizeof(struct edge_data));
+    for (i = 0; i < ntuples; i++) {
+        /* process standalone nodes (PostGIS Topo) */
+        line_data.id = atoi(PQgetvalue(res, i, 0));
+        read_p_line(plus, i + 1, &line_data, pg_info);
+    PQclear(res);
+    /* read PostGIS Topo edges */
+    sprintf(stmt,
+            "SELECT edge_id,start_node,end_node,left_face,right_face "
+            "FROM \"%s\".edge",
+        if (res)
+            PQclear(res);
+        return -1;
+        /* process edges (PostGIS Topo) */
+        line_data.start_node = atoi(PQgetvalue(res, i, 1));
+        line_data.end_node   = atoi(PQgetvalue(res, i, 2));
+        line_data.left_face  = atoi(PQgetvalue(res, i, 3));
+        line_data.right_face = atoi(PQgetvalue(res, i, 4));
+        read_p_line(plus, plus->n_plines + i + 1, &line_data, pg_info);
+    PQclear(res);
+    /* read areas (GRASS Topo) */
+    sprintf(stmt,
+            "SELECT face_id from \"%s\".face WHERE mbr IS NOT NULL",
+        PQntuples(res) != plus->n_areas) {
+        G_warning(_("Unable to read areas"));
+        if (res)
+            PQclear(res);
+        return -1;
+    dig_alloc_areas(plus, plus->n_areas);
+    for (i = 1; i <= plus->n_areas; i++) {
+        line_data.id = line_data.left_face = atoi(PQgetvalue(res, i - 1, 0));
+        read_p_area(plus, i, line_data.id, pg_info);
+        /* add centroids */
+        read_p_line(plus, plus->n_lines - plus->n_clines + i,
+                    &line_data, pg_info);
+    PQclear(res);
+    /* read isle (GRASS Topo) */
+    return 0;
 #endif
Modified: grass/trunk/lib/vector/Vlib/read.c
--- grass/trunk/lib/vector/Vlib/read.c	2012-05-31 12:32:19 UTC (rev 51901)
+++ grass/trunk/lib/vector/Vlib/read.c	2012-05-31 12:47:11 UTC (rev 51902)
@@ -34,42 +34,49 @@
 #endif
-static int (*Read_next_line_array[][3]) () = {
+static int (*Read_next_line_array[][4]) () = {
-	read_dummy, V1_read_next_line_nat, V2_read_next_line_nat}
+	read_dummy, V1_read_next_line_nat, V2_read_next_line_nat, read_dummy}
 #ifdef HAVE_OGR
-	read_dummy, V1_read_next_line_ogr, V2_read_next_line_ogr}
+	read_dummy, V1_read_next_line_ogr, V2_read_next_line_ogr, read_dummy}
 #else
-	read_dummy, format, format}
+	read_dummy, format, format, format}
 #endif
-	read_dummy, V1_read_next_line_pg, V2_read_next_line_pg}
+	read_dummy, V1_read_next_line_pg, V2_read_next_line_pg, V2_read_next_line_pg}
 #else
 #endif
-static int (*Read_line_array[]) () = {
-    V2_read_line_nat
+static int (*Read_line_array[][2]) () = {
+        V2_read_line_nat, read_dummy}
 #ifdef HAVE_OGR
-    , V2_read_line_sfa
+        V2_read_line_sfa, read_dummy}
 #else
-    , format
-    , format
+        format, format}
+        format, format}
 #endif
+        V2_read_line_sfa, V3_read_line_pg}
 #else
-    , format
+        format, format}
 #endif
@@ -169,7 +176,7 @@
 			"(max features in vector map <%s>: %d)"),
 		      line, Vect_get_full_name(Map), Map->plus.n_lines);
-    ret = (*Read_line_array[Map->format]) (Map, line_p, line_c, line);
+    ret = (*Read_line_array[Map->format][Map->level == 3 ? 1 : 0]) (Map, line_p, line_c, line);
     if (ret == -1)
Modified: grass/trunk/lib/vector/Vlib/read_pg.c
--- grass/trunk/lib/vector/Vlib/read_pg.c	2012-05-31 12:32:19 UTC (rev 51901)
+++ grass/trunk/lib/vector/Vlib/read_pg.c	2012-05-31 12:47:11 UTC (rev 51902)
@@ -32,7 +32,7 @@
 static int read_next_line_pg(struct Map_info *,
                              struct line_pnts *, struct line_cats *, int);
-SF_FeatureType get_feature(struct Format_info_pg *, int);
+SF_FeatureType get_feature(struct Format_info_pg *, int, const char *);
 static unsigned char *hex_to_wkb(const char *, int *);
 static int point_from_wkb(const unsigned char *, int, int, int,
                           struct line_pnts *);
@@ -47,6 +47,7 @@
 static int set_initial_query();
 static void reallocate_cache(struct Format_info_cache *, int);
 static void add_fpart(struct feat_parts *, SF_FeatureType, int, int);
+static int read_centroid_pg(struct Format_info_pg *, int, struct line_pnts *);
 #endif
@@ -248,7 +249,7 @@
         G_debug(3, "read (%s) feature (fid = %ld) to cache",
                 pg_info->table_name, fid);
-        get_feature(pg_info, fid);
+        get_feature(pg_info, fid, NULL);
         if (pg_info->cache.sf_type == SF_NONE) {
             G_warning(_("Feature %d without geometry skipped"), fid);
@@ -282,7 +283,77 @@
 #endif
+int V3_read_line_pg(struct Map_info *Map, struct line_pnts *line_p,
+                    struct line_cats *line_c, int line)
+    int type;
+    char *topotable_name;
+    struct P_line *Line;
+    Line = Map->plus.Line[line];
+    if (Line == NULL) {
+        G_warning(_("Attempt to read dead feature %d"), line);
+        return -1;
+    G_debug(4, "V3_read_line_pg() line = %d type = %d offset = %llu",
+            line, Line->type, Line->offset);
+    if (!line_p && !line_c)
+        return Line->type;
+    if (line_p != NULL)
+        Vect_reset_line(line_p);
+    if (line_c != NULL)
+        Vect_reset_cats(line_c);
+    if (line_c)
+        Vect_cat_set(line_c, 1, (int) Line->offset);
+    if (Line->type == GV_POINT)
+        topotable_name = "node";
+    else if (Line->type & GV_LINES)
+        topotable_name = "edge";
+    else if (Line->type == GV_CENTROID) {
+        return read_centroid_pg(pg_info, (int) Line->offset, line_p);
+    else {
+        G_warning(_("Unsupported feature type %d"), Line->type);
+        return -1;
+    get_feature(pg_info, Line->offset, topotable_name);
+    if (pg_info->cache.sf_type == SF_NONE) {
+        G_warning(_("Feature %d without geometry skipped"), Line->offset);
+        return -1;
+    type = (int)pg_info->cache.sf_type;
+    if (type < 0)           /* -1 || - 2 */
+        return type;
+    if (Line->type == GV_BOUNDARY && type == GV_LINE)
+        type = GV_BOUNDARY;
+    if (line_p)
+        Vect_append_points(line_p, pg_info->cache.lines[0], GV_FORWARD);
+    return type;
+#else
+    return -1;
+#endif
    \brief Read next feature from PostGIS layer.
@@ -325,7 +396,7 @@
         /* read feature to cache if necessary */
         while (pg_info->cache.lines_next == pg_info->cache.lines_num) {
             /* cache feature -> line_p & line_c */
-            sf_type = get_feature(pg_info, -1);
+            sf_type = get_feature(pg_info, -1, NULL);
             if (sf_type == SF_NONE) {
                 G_warning(_("Feature %d without geometry skipped"), line);
@@ -389,17 +460,18 @@
    \param[in,out] pg_info pointer to Format_info_pg struct
    \param fid feature id to be read (-1 for next)
-   \param[out] line_c pointer to line_cats structure (or NULL)
+   \param topotable_name table name for topological access (NULL for pseudo-topological access) - "node" or "edge"
    \return simple feature type (SF_POINT, SF_LINESTRING, ...)
    \return -1 on error
-SF_FeatureType get_feature(struct Format_info_pg * pg_info, int fid)
+SF_FeatureType get_feature(struct Format_info_pg *pg_info, int fid,
+                           const char *topotable_name)
     char *data;
-    if (!pg_info->geom_column) {
+    if (!topotable_name && !pg_info->geom_column) {
         G_warning(_("No geometry column defined"));
         return -1;
@@ -411,7 +483,7 @@
     else {
-        if (!pg_info->fid_column) {
+        if (!topotable_name && !pg_info->fid_column) {
             G_warning(_("Random access not supported. "
                         "Primary key not defined."));
             return -1;
@@ -420,11 +492,22 @@
         if (execute(pg_info->conn, "BEGIN") == -1)
             return -1;
-        sprintf(stmt,
-                "DECLARE %s_%s%p CURSOR FOR SELECT %s FROM \"%s\".\"%s\" "
-                "WHERE %s = %d", pg_info->schema_name, pg_info->table_name,
-                pg_info->conn, pg_info->geom_column, pg_info->schema_name,
-                pg_info->table_name, pg_info->fid_column, fid);
+        if (!topotable_name) {
+            /* simple feature access */
+            sprintf(stmt,
+                    "DECLARE %s_%s%p CURSOR FOR SELECT %s FROM \"%s\".\"%s\" "
+                    "WHERE %s = %d", pg_info->schema_name, pg_info->table_name,
+                    pg_info->conn, pg_info->geom_column, pg_info->schema_name,
+                    pg_info->table_name, pg_info->fid_column, fid);
+        else {
+            /* topological access */
+            sprintf(stmt,
+                    "DECLARE %s_%s%p CURSOR FOR SELECT geom FROM \"%s\".\"%s\" "
+                    "WHERE %s_id = %d", pg_info->schema_name, pg_info->table_name,
+                    pg_info->conn, pg_info->toposchema_name,
+                    topotable_name, topotable_name, fid);
         if (execute(pg_info->conn, stmt) == -1)
             return -1;
@@ -437,6 +520,7 @@
     if (!pg_info->res || PQresultStatus(pg_info->res) != PGRES_TUPLES_OK) {
         PQclear(pg_info->res);
+        G_warning(_("Reading failed: %s"), PQerrorMessage(pg_info->conn));
         pg_info->res = NULL;
         return -1;              /* reading failed */
@@ -1142,4 +1226,37 @@
     fparts->n_parts++;
+int read_centroid_pg(struct Format_info_pg *pg_info,
+                     int centroid, struct line_pnts *line_p)
+    char *data;
+    PGresult *res;
+    sprintf(stmt,
+            "SELECT ST_PointOnSurface(geom) AS geom FROM "
+            "ST_GetFaceGeometry('%s', %d) as geom",
+            pg_info->toposchema_name, centroid);
+        G_warning(_("Unable to read centroid %d: %s"),
+                  centroid, PQerrorMessage(pg_info->conn));
+        if (res)
+            PQclear(res);
+        return -1;
+    data = (char *)PQgetvalue(res, 0, 0);
+    PQclear(res);
+    if (GV_POINT != cache_feature(data, FALSE, &(pg_info->cache), NULL))
+        return -1;
+    return GV_CENTROID;
 #endif
Modified: grass/trunk/lib/vector/Vlib/read_sfa.c
--- grass/trunk/lib/vector/Vlib/read_sfa.c	2012-05-31 12:32:19 UTC (rev 51901)
+++ grass/trunk/lib/vector/Vlib/read_sfa.c	2012-05-31 12:47:11 UTC (rev 51902)
@@ -36,7 +36,7 @@
 int V2_read_line_sfa(struct Map_info *Map, struct line_pnts *line_p,
-		     struct line_cats *line_c, int line)
 #if defined HAVE_OGR || defined HAVE_POSTGRES
     int type;
@@ -46,69 +46,69 @@
     if (Line == NULL) {
-	G_warning(_("Attempt to read dead feature %d"), line);
-	return -1;
+        return -1;
-	/* read centroid for topo */
-	if (line_p != NULL) {
-	    int i, found;
-	    struct bound_box box;
-	    struct boxlist list;
-	    struct P_topo_c *topo = (struct P_topo_c *)Line->topo;
+        /* read centroid for topo */
+        if (line_p != NULL) {
+            int i, found;
+            struct bound_box box;
+            struct boxlist list;
+            struct P_topo_c *topo = (struct P_topo_c *)Line->topo;
-	    G_debug(4, "Centroid: area = %d", topo->area);
-	    Vect_reset_line(line_p);
-	    if (topo->area > 0 && topo->area <= Map->plus.n_areas) {
-		/* get area bbox */
-		Vect_get_area_box(Map, topo->area, &box);
-		/* search in spatial index for centroid with area bbox */
-		dig_init_boxlist(&list, TRUE);
-		Vect_select_lines_by_box(Map, &box, Line->type, &list);
-		found = -1;
-		for (i = 0; i < list.n_values; i++) {
-		    if (list.id[i] == line) {
-			found = i;
-			break;
-		if (found > -1) {
-		    Vect_append_point(line_p, list.box[found].E, list.box[found].N, 0.0);
-		else {
-		    G_warning(_("Unable to construct centroid for area %d. Skipped."),
-			      topo->area);
-	    else {
-		G_warning(_("Centroid %d: invalid area %d"), line, topo->area);
+            G_debug(4, "Centroid: area = %d", topo->area);
+            if (topo->area > 0 && topo->area <= Map->plus.n_areas) {
+                /* get area bbox */
+                Vect_get_area_box(Map, topo->area, &box);
+                /* search in spatial index for centroid with area bbox */
+                dig_init_boxlist(&list, TRUE);
+                Vect_select_lines_by_box(Map, &box, Line->type, &list);
+                found = -1;
+                for (i = 0; i < list.n_values; i++) {
+                    if (list.id[i] == line) {
+                        found = i;
+                        break;
+                if (found > -1) {
+                    Vect_append_point(line_p, list.box[found].E, list.box[found].N, 0.0);
+                else {
+                    G_warning(_("Unable to construct centroid for area %d. Skipped."),
+                              topo->area);
+            else {
+                G_warning(_("Centroid %d: invalid area %d"), line, topo->area);
-	if (line_c != NULL) {
-	  /* cat = fid and offset = fid for centroid */
-	  Vect_reset_cats(line_c);
-	  Vect_cat_set(line_c, 1, (int) Line->offset);
-	return GV_CENTROID;
+        if (line_c != NULL) {
+          /* cat = fid and offset = fid for centroid */
-	return Line->type;
-	type = V1_read_line_pg(Map, line_p, line_c, Line->offset);
+        type = V1_read_line_pg(Map, line_p, line_c, Line->offset);
     else
-	type = V1_read_line_ogr(Map, line_p, line_c, Line->offset);
+        type = V1_read_line_ogr(Map, line_p, line_c, Line->offset);
     if (type != Line->type)
-	G_fatal_error(_("Unexpected feature type (%s) - should be (%d)"),
-		      type, Line->type);
+        G_fatal_error(_("Unexpected feature type (%s) - should be (%d)"),
+                      type, Line->type);
     return type;
 #else
Modified: grass/trunk/lib/vector/Vlib/rewind.c
--- grass/trunk/lib/vector/Vlib/rewind.c	2012-05-31 12:32:19 UTC (rev 51901)
+++ grass/trunk/lib/vector/Vlib/rewind.c	2012-05-31 12:47:11 UTC (rev 51902)
@@ -5,13 +5,14 @@
    Higher level functions for reading/writing/manipulating vectors.
-   (C) 2001-2009, 2011 by the GRASS Development Team
+   (C) 2001-2009, 2011-2012 by the GRASS Development Team
    This program is free software under the GNU General Public License
+   \author Level 3 by Martin Landa <landa.martin gmail.com>
@@ -31,26 +32,26 @@
 #endif
-static int (*Rewind_array[][3]) () = {
+static int (*Rewind_array[][4]) () = {
-	rew_dummy, V1_rewind_nat, V2_rewind_nat}
+        rew_dummy, V1_rewind_nat, V2_rewind_nat, rew_dummy}
 #ifdef HAVE_OGR
-	rew_dummy, V1_rewind_ogr, V2_rewind_ogr}
+	rew_dummy, V1_rewind_ogr, V2_rewind_ogr, rew_dummy}
 #else
-	rew_dummy, format, format}
+	rew_dummy, format, format, rew_dummy}
 #endif
-	rew_dummy, V1_rewind_pg, V2_rewind_pg}
+	rew_dummy, V1_rewind_pg, V2_rewind_pg, V2_rewind_pg}
 #else
 #endif
@@ -67,7 +68,7 @@
     if (!VECT_OPEN(Map))
 	return -1;
-    G_debug(1, "Vect_Rewind(): name = %s", Map->name);
+    G_debug(1, "Vect_Rewind(): name = %s level = %d", Map->name, Map->level);
     return (*Rewind_array[Map->format][Map->level]) (Map);
Modified: grass/trunk/lib/vector/diglib/frmt.c
--- grass/trunk/lib/vector/diglib/frmt.c	2012-05-31 12:32:19 UTC (rev 51901)
+++ grass/trunk/lib/vector/diglib/frmt.c	2012-05-31 12:47:11 UTC (rev 51902)
@@ -39,36 +39,36 @@
     /* read first line which must be FORMAT: */
     if (G_getl2(buff, 2000, dascii)) {
-	G_chop(buff);
+        G_chop(buff);
-	if (!(ptr = strchr(buff, ':'))) {
-	    G_warning("Vector format not recognized: %s", buff);
-	    return (-1);
+        if (!(ptr = strchr(buff, ':'))) {
+            G_warning(_("Vector format not recognized: %s"), buff);
+            return -1;
-	strcpy(buf1, buff);
-	buf1[ptr - buff] = '\0';
+        strcpy(buf1, buff);
+        buf1[ptr - buff] = '\0';
-	ptr++;			/* Search for the start of text */
-	while (*ptr == ' ')
-	    ptr++;
+        ptr++;                  /* Search for the start of text */
+        while (*ptr == ' ')
+            ptr++;
-	if (strcmp(buf1, "FORMAT") == 0) {
+        if (strcmp(buf1, "FORMAT") == 0) {
 #ifdef HAVE_OGR
-	    if (G_strcasecmp(ptr, "ogr") == 0) {
-		frmt = GV_FORMAT_OGR;
+            if (G_strcasecmp(ptr, "ogr") == 0) {
+                frmt = GV_FORMAT_OGR;
 #endif
-	    if (G_strcasecmp(ptr, "postgis") == 0) {
-		frmt = GV_FORMAT_POSTGIS;
+            if (G_strcasecmp(ptr, "postgis") == 0) {
+                frmt = GV_FORMAT_POSTGIS;
 #endif
     if (frmt == -1) {
-	return -1;
+        return -1;
     /* init format info values */
@@ -76,8 +76,8 @@
     G_zero(&(finfo->ogr), sizeof(struct Format_info_ogr));
 #else
     if (frmt == GV_FORMAT_OGR) {
-	G_warning(_("Vector format '%s' not supported"), ptr);
-	return -1;
+        G_warning(_("Vector format '%s' not supported"), ptr);
+        return -1;
 #endif
@@ -85,46 +85,54 @@
     G_zero(&(finfo->pg), sizeof(struct Format_info_pg));
 #else
     if (frmt == GV_FORMAT_POSTGIS) {
-	return -1;
+        return -1;
 #endif
     while (G_getl2(buff, 2000, dascii)) {
-	G_chop(buff);
+        G_chop(buff);
-	    G_warning("Format definition is not correct: %s", buff);
-	    continue;
+            G_warning(_("Format definition is not correct: %s"), buff);
+            continue;
-	    ptr++;
+            ptr++;
 #ifdef HAVE_OGR
-	if (frmt == GV_FORMAT_OGR) {
-	    if (strcmp(buf1, "DSN") == 0)
-		finfo->ogr.dsn = G_store(ptr);
-	    if (strcmp(buf1, "LAYER") == 0)
-		finfo->ogr.layer_name = G_store(ptr);
+        if (frmt == GV_FORMAT_OGR) {
+            if (strcmp(buf1, "DSN") == 0)
+                finfo->ogr.dsn = G_store(ptr);
+            if (strcmp(buf1, "LAYER") == 0)
+                finfo->ogr.layer_name = G_store(ptr);
 #endif
-	if (frmt == GV_FORMAT_POSTGIS) {
-	    if (strcmp(buf1, "CONNINFO") == 0)
-		finfo->pg.conninfo = G_store(ptr);
-	    if (strcmp(buf1, "SCHEMA") == 0)
-		finfo->pg.schema_name = G_store(ptr);
-	    if (strcmp(buf1, "TABLE") == 0)
-		finfo->pg.table_name = G_store(ptr);
+        if (frmt == GV_FORMAT_POSTGIS) {
+            if (strcmp(buf1, "CONNINFO") == 0)
+                finfo->pg.conninfo = G_store(ptr);
+            if (strcmp(buf1, "SCHEMA") == 0)
+                finfo->pg.schema_name = G_store(ptr);
+            if (strcmp(buf1, "TABLE") == 0)
+                finfo->pg.table_name = G_store(ptr);
 #endif
+    /* if schema not defined, use 'public' */
+    if (frmt == GV_FORMAT_POSTGIS &&
+        !finfo->pg.schema_name) {
+        finfo->pg.schema_name = G_store("public");
+#endif
     return frmt;
Modified: grass/trunk/lib/vector/diglib/spindex_rw.c
--- grass/trunk/lib/vector/diglib/spindex_rw.c	2012-05-31 12:32:19 UTC (rev 51901)
+++ grass/trunk/lib/vector/diglib/spindex_rw.c	2012-05-31 12:47:11 UTC (rev 51902)
@@ -488,6 +488,8 @@
     /* ptr->Hole_spidx->rootpos = ptr->Hole_spidx_offset; */
     /* coor file size : bytes 110 - 113 (117) (LFS: 138 - 145) */
+    if (ptr->off_t_size == -1)
+        ptr->off_t_size = ptr->spidx_port.off_t_size;
     if (0 >= dig__fread_port_O(&(ptr->coor_size), 1, fp, ptr->off_t_size))
 	return (-1);
     G_debug(2, "  coor size %lu", (long unsigned)ptr->coor_size);
