[GRASS-SVN] r51908 - grass/trunk/include/Make
svn_grass at osgeo.org
Thu May 31 07:47:25 PDT 2012
Author: martinl
Date: 2012-05-31 07:47:24 -0700 (Thu, 31 May 2012)
New Revision: 51908
grass/trunk/include/Make/Doxyfile_arch_html.in
grass/trunk/include/Make/Doxyfile_arch_latex.in
update doxygen files by `doxygen -u`
Modified: grass/trunk/include/Make/Doxyfile_arch_html.in
--- grass/trunk/include/Make/Doxyfile_arch_html.in 2012-05-31 13:40:10 UTC (rev 51907)
+++ grass/trunk/include/Make/Doxyfile_arch_html.in 2012-05-31 14:47:24 UTC (rev 51908)
@@ -1,593 +1,874 @@
-# Doxyfile 1.3.9.1
+# Doxyfile 1.8.1
# This file describes the settings to be used by the documentation system
-# doxygen (www.doxygen.org) for a project
+# doxygen (www.doxygen.org) for a project.
-# All text after a hash (#) is considered a comment and will be ignored
+# All text after a hash (#) is considered a comment and will be ignored.
# The format is:
# TAG = value [value, ...]
# For lists items can also be appended using:
# TAG += value [value, ...]
-# Values that contain spaces should be placed between quotes (" ")
+# Values that contain spaces should be placed between quotes (" ").
# Project related configuration options
-# The PROJECT_NAME tag is a single word (or a sequence of words surrounded
-# by quotes) that should identify the project.
+# This tag specifies the encoding used for all characters in the config file
+# that follow. The default is UTF-8 which is also the encoding used for all
+# text before the first occurrence of this tag. Doxygen uses libiconv (or the
+# iconv built into libc) for the transcoding. See
+# http://www.gnu.org/software/libiconv for the list of possible encodings.
+DOXYFILE_ENCODING = UTF-8
+# The PROJECT_NAME tag is a single word (or sequence of words) that should
+# identify the project. Note that if you do not use Doxywizard you need
+# to put quotes around the project name if it contains spaces.
PROJECT_NAME = "GRASS Programmer's Manual"
-# The PROJECT_NUMBER tag can be used to enter a project or revision number.
-# This could be handy for archiving the generated documentation or
+# The PROJECT_NUMBER tag can be used to enter a project or revision number.
+# This could be handy for archiving the generated documentation or
# if some version control system is used.
-PROJECT_NUMBER = @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@ (@GRASS_VERSION_DATE@) - r at GRASS_VERSION_SVN@
+PROJECT_NUMBER = @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@(@GRASS_VERSION_DATE@)-r at GRASS_VERSION_SVN@
-# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
-# base path where the generated documentation will be put.
-# If a relative path is entered, it will be relative to the location
+# Using the PROJECT_BRIEF tag one can provide an optional one line description
+# for a project that appears at the top of each page and should give viewer
+# a quick idea about the purpose of the project. Keep the description short.
+PROJECT_BRIEF =
+# With the PROJECT_LOGO tag one can specify an logo or icon that is
+# included in the documentation. The maximum height of the logo should not
+# exceed 55 pixels and the maximum width should not exceed 200 pixels.
+# Doxygen will copy the logo to the output directory.
+PROJECT_LOGO =
+# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
+# base path where the generated documentation will be put.
+# If a relative path is entered, it will be relative to the location
# where doxygen was started. If left blank the current directory will be used.
OUTPUT_DIRECTORY = .
-# If the CREATE_SUBDIRS tag is set to YES, then doxygen will create
-# 4096 sub-directories (in 2 levels) under the output directory of each output
-# format and will distribute the generated files over these directories.
-# Enabling this option can be useful when feeding doxygen a huge amount of source
-# files, where putting all generated files in the same directory would otherwise
-# cause performance problems for the file system.
+# If the CREATE_SUBDIRS tag is set to YES, then doxygen will create
+# 4096 sub-directories (in 2 levels) under the output directory of each output
+# format and will distribute the generated files over these directories.
+# Enabling this option can be useful when feeding doxygen a huge amount of
+# source files, where putting all generated files in the same directory would
+# otherwise cause performance problems for the file system.
CREATE_SUBDIRS = NO
-# The OUTPUT_LANGUAGE tag is used to specify the language in which all
-# documentation generated by doxygen is written. Doxygen will use this
-# information to generate all constant output in the proper language.
-# The default language is English, other supported languages are:
-# Brazilian, Catalan, Chinese, Chinese-Traditional, Croatian, Czech, Danish,
-# Dutch, Finnish, French, German, Greek, Hungarian, Italian, Japanese,
-# Japanese-en (Japanese with English messages), Korean, Korean-en, Norwegian,
-# Polish, Portuguese, Romanian, Russian, Serbian, Slovak, Slovene, Spanish,
-# Swedish, and Ukrainian.
+# The OUTPUT_LANGUAGE tag is used to specify the language in which all
+# documentation generated by doxygen is written. Doxygen will use this
+# information to generate all constant output in the proper language.
+# The default language is English, other supported languages are:
+# Afrikaans, Arabic, Brazilian, Catalan, Chinese, Chinese-Traditional,
+# Croatian, Czech, Danish, Dutch, Esperanto, Farsi, Finnish, French, German,
+# Greek, Hungarian, Italian, Japanese, Japanese-en (Japanese with English
+# messages), Korean, Korean-en, Lithuanian, Norwegian, Macedonian, Persian,
+# Polish, Portuguese, Romanian, Russian, Serbian, Serbian-Cyrillic, Slovak,
+# Slovene, Spanish, Swedish, Ukrainian, and Vietnamese.
OUTPUT_LANGUAGE = English
-# This tag can be used to specify the encoding used in the generated output.
-# The encoding is not always determined by the language that is chosen,
-# but also whether or not the output is meant for Windows or non-Windows users.
-# In case there is a difference, setting the USE_WINDOWS_ENCODING tag to YES
-# forces the Windows encoding (this is the default for the Windows binary),
-# whereas setting the tag to NO uses a Unix-style encoding (the default for
-# all platforms other than Windows).
-USE_WINDOWS_ENCODING = NO
-# If the BRIEF_MEMBER_DESC tag is set to YES (the default) Doxygen will
-# include brief member descriptions after the members that are listed in
-# the file and class documentation (similar to JavaDoc).
+# If the BRIEF_MEMBER_DESC tag is set to YES (the default) Doxygen will
+# include brief member descriptions after the members that are listed in
+# the file and class documentation (similar to JavaDoc).
# Set to NO to disable this.
BRIEF_MEMBER_DESC = YES
-# If the REPEAT_BRIEF tag is set to YES (the default) Doxygen will prepend
-# the brief description of a member or function before the detailed description.
-# Note: if both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
+# If the REPEAT_BRIEF tag is set to YES (the default) Doxygen will prepend
+# the brief description of a member or function before the detailed description.
+# Note: if both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
# brief descriptions will be completely suppressed.
REPEAT_BRIEF = YES
-# This tag implements a quasi-intelligent brief description abbreviator
-# that is used to form the text in various listings. Each string
-# in this list, if found as the leading text of the brief description, will be
-# stripped from the text and the result after processing the whole list, is used
-# as the annotated text. Otherwise, the brief description is used as-is. If left
-# blank, the following values are used ("$name" is automatically replaced with the
-# name of the entity): "The $name class" "The $name widget" "The $name file"
-# "is" "provides" "specifies" "contains" "represents" "a" "an" "the"
+# This tag implements a quasi-intelligent brief description abbreviator
+# that is used to form the text in various listings. Each string
+# in this list, if found as the leading text of the brief description, will be
+# stripped from the text and the result after processing the whole list, is
+# used as the annotated text. Otherwise, the brief description is used as-is.
+# If left blank, the following values are used ("$name" is automatically
+# replaced with the name of the entity): "The $name class" "The $name widget"
+# "The $name file" "is" "provides" "specifies" "contains"
+# "represents" "a" "an" "the"
-ABBREVIATE_BRIEF =
+ABBREVIATE_BRIEF =
-# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
-# Doxygen will generate a detailed section even if there is only a brief
+# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
+# Doxygen will generate a detailed section even if there is only a brief
# description.
ALWAYS_DETAILED_SEC = NO
-# If the INLINE_INHERITED_MEMB tag is set to YES, doxygen will show all inherited
-# members of a class in the documentation of that class as if those members were
-# ordinary class members. Constructors, destructors and assignment operators of
-# the base classes will not be shown.
+# If the INLINE_INHERITED_MEMB tag is set to YES, doxygen will show all
+# inherited members of a class in the documentation of that class as if those
+# members were ordinary class members. Constructors, destructors and assignment
+# operators of the base classes will not be shown.
INLINE_INHERITED_MEMB = NO
-# If the FULL_PATH_NAMES tag is set to YES then Doxygen will prepend the full
-# path before files name in the file list and in the header files. If set
+# If the FULL_PATH_NAMES tag is set to YES then Doxygen will prepend the full
+# path before files name in the file list and in the header files. If set
# to NO the shortest path that makes the file name unique will be used.
FULL_PATH_NAMES = NO
-# If the FULL_PATH_NAMES tag is set to YES then the STRIP_FROM_PATH tag
-# can be used to strip a user-defined part of the path. Stripping is
-# only done if one of the specified strings matches the left-hand part of
-# the path. The tag can be used to show relative paths in the file list.
-# If left blank the directory from which doxygen is run is used as the
+# If the FULL_PATH_NAMES tag is set to YES then the STRIP_FROM_PATH tag
+# can be used to strip a user-defined part of the path. Stripping is
+# only done if one of the specified strings matches the left-hand part of
+# the path. The tag can be used to show relative paths in the file list.
+# If left blank the directory from which doxygen is run is used as the
# path to strip.
-STRIP_FROM_PATH =
+STRIP_FROM_PATH =
-# The STRIP_FROM_INC_PATH tag can be used to strip a user-defined part of
-# the path mentioned in the documentation of a class, which tells
-# the reader which header file to include in order to use a class.
-# If left blank only the name of the header file containing the class
-# definition is used. Otherwise one should specify the include paths that
+# The STRIP_FROM_INC_PATH tag can be used to strip a user-defined part of
+# the path mentioned in the documentation of a class, which tells
+# the reader which header file to include in order to use a class.
+# If left blank only the name of the header file containing the class
+# definition is used. Otherwise one should specify the include paths that
# are normally passed to the compiler using the -I flag.
-STRIP_FROM_INC_PATH =
+STRIP_FROM_INC_PATH =
-# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter
-# (but less readable) file names. This can be useful is your file systems
+# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter
+# (but less readable) file names. This can be useful if your file system
# doesn't support long names like on DOS, Mac, or CD-ROM.
SHORT_NAMES = NO
-# If the JAVADOC_AUTOBRIEF tag is set to YES then Doxygen
-# will interpret the first line (until the first dot) of a JavaDoc-style
-# comment as the brief description. If set to NO, the JavaDoc
-# comments will behave just like the Qt-style comments (thus requiring an
-# explicit @brief command for a brief description.
+# If the JAVADOC_AUTOBRIEF tag is set to YES then Doxygen
+# will interpret the first line (until the first dot) of a JavaDoc-style
+# comment as the brief description. If set to NO, the JavaDoc
+# comments will behave just like regular Qt-style comments
+# (thus requiring an explicit @brief command for a brief description.)
JAVADOC_AUTOBRIEF = NO
-# The MULTILINE_CPP_IS_BRIEF tag can be set to YES to make Doxygen
-# treat a multi-line C++ special comment block (i.e. a block of //! or ///
-# comments) as a brief description. This used to be the default behaviour.
-# The new default is to treat a multi-line C++ comment block as a detailed
+# If the QT_AUTOBRIEF tag is set to YES then Doxygen will
+# interpret the first line (until the first dot) of a Qt-style
+# comment as the brief description. If set to NO, the comments
+# will behave just like regular Qt-style comments (thus requiring
+# an explicit \brief command for a brief description.)
+QT_AUTOBRIEF = NO
+# The MULTILINE_CPP_IS_BRIEF tag can be set to YES to make Doxygen
+# treat a multi-line C++ special comment block (i.e. a block of //! or ///
+# comments) as a brief description. This used to be the default behaviour.
+# The new default is to treat a multi-line C++ comment block as a detailed
# description. Set this tag to YES if you prefer the old behaviour instead.
MULTILINE_CPP_IS_BRIEF = NO
-# If the DETAILS_AT_TOP tag is set to YES then Doxygen
-# will output the detailed description near the top, like JavaDoc.
-# If set to NO, the detailed description appears after the member
-# documentation.
-DETAILS_AT_TOP = NO
-# If the INHERIT_DOCS tag is set to YES (the default) then an undocumented
-# member inherits the documentation from any documented member that it
+# If the INHERIT_DOCS tag is set to YES (the default) then an undocumented
+# member inherits the documentation from any documented member that it
# re-implements.
INHERIT_DOCS = YES
-# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
-# tag is set to YES, then doxygen will reuse the documentation of the first
-# member in the group (if any) for the other members of the group. By default
-# all members of a group must be documented explicitly.
+# If the SEPARATE_MEMBER_PAGES tag is set to YES, then doxygen will produce
+# a new page for each member. If set to NO, the documentation of a member will
+# be part of the file/class/namespace that contains it.
-DISTRIBUTE_GROUP_DOC = NO
+SEPARATE_MEMBER_PAGES = NO
-# The TAB_SIZE tag can be used to set the number of spaces in a tab.
+# The TAB_SIZE tag can be used to set the number of spaces in a tab.
# Doxygen uses this value to replace tabs by spaces in code fragments.
TAB_SIZE = 8
-# This tag can be used to specify a number of aliases that acts
-# as commands in the documentation. An alias has the form "name=value".
-# For example adding "sideeffect=\par Side Effects:\n" will allow you to
-# put the command \sideeffect (or @sideeffect) in the documentation, which
-# will result in a user-defined paragraph with heading "Side Effects:".
+# This tag can be used to specify a number of aliases that acts
+# as commands in the documentation. An alias has the form "name=value".
+# For example adding "sideeffect=\par Side Effects:\n" will allow you to
+# put the command \sideeffect (or @sideeffect) in the documentation, which
+# will result in a user-defined paragraph with heading "Side Effects:".
# You can put \n's in the value part of an alias to insert newlines.
-ALIASES =
+ALIASES =
-# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C sources
-# only. Doxygen will then generate output that is more tailored for C.
-# For instance, some of the names that are used will be different. The list
+# This tag can be used to specify a number of word-keyword mappings (TCL only).
+# A mapping has the form "name=value". For example adding
+# "class=itcl::class" will allow you to use the command class in the
+# itcl::class meaning.
+TCL_SUBST =
+# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C
+# sources only. Doxygen will then generate output that is more tailored for C.
+# For instance, some of the names that are used will be different. The list
# of all members will be omitted, etc.
OPTIMIZE_OUTPUT_FOR_C = YES
-# Set the OPTIMIZE_OUTPUT_JAVA tag to YES if your project consists of Java sources
-# only. Doxygen will then generate output that is more tailored for Java.
-# For instance, namespaces will be presented as packages, qualified scopes
-# will look different, etc.
+# Set the OPTIMIZE_OUTPUT_JAVA tag to YES if your project consists of Java
+# Java. For instance, namespaces will be presented as packages, qualified
+# scopes will look different, etc.
OPTIMIZE_OUTPUT_JAVA = NO
-# Set the SUBGROUPING tag to YES (the default) to allow class member groups of
-# the same type (for instance a group of public functions) to be put as a
-# subgroup of that type (e.g. under the Public Functions section). Set it to
-# NO to prevent subgrouping. Alternatively, this can be done per class using
+# Set the OPTIMIZE_FOR_FORTRAN tag to YES if your project consists of Fortran
+# Fortran.
+OPTIMIZE_FOR_FORTRAN = NO
+# Set the OPTIMIZE_OUTPUT_VHDL tag to YES if your project consists of VHDL
+# sources. Doxygen will then generate output that is tailored for
+# VHDL.
+OPTIMIZE_OUTPUT_VHDL = NO
+# Doxygen selects the parser to use depending on the extension of the files it
+# parses. With this tag you can assign which parser to use for a given extension.
+# Doxygen has a built-in mapping, but you can override or extend it using this
+# tag. The format is ext=language, where ext is a file extension, and language
+# is one of the parsers supported by doxygen: IDL, Java, Javascript, CSharp, C,
+# C++, D, PHP, Objective-C, Python, Fortran, VHDL, C, C++. For instance to make
+# doxygen treat .inc files as Fortran files (default is PHP), and .f files as C
+# (default is Fortran), use: inc=Fortran f=C. Note that for custom extensions
+# you also need to set FILE_PATTERNS otherwise the files are not read by doxygen.
+EXTENSION_MAPPING =
+# If MARKDOWN_SUPPORT is enabled (the default) then doxygen pre-processes all
+# comments according to the Markdown format, which allows for more readable
+# documentation. See http://daringfireball.net/projects/markdown/ for details.
+# The output of markdown processing is further processed by doxygen, so you
+# can mix doxygen, HTML, and XML commands with Markdown formatting.
+# Disable only in case of backward compatibilities issues.
+MARKDOWN_SUPPORT = YES
+# If you use STL classes (i.e. std::string, std::vector, etc.) but do not want
+# to include (a tag file for) the STL sources as input, then you should
+# set this tag to YES in order to let doxygen match functions declarations and
+# definitions whose arguments contain STL classes (e.g. func(std::string); v.s.
+# func(std::string) {}). This also makes the inheritance and collaboration
+# diagrams that involve STL classes more complete and accurate.
+BUILTIN_STL_SUPPORT = NO
+# If you use Microsoft's C++/CLI language, you should set this option to YES to
+# enable parsing support.
+CPP_CLI_SUPPORT = NO
+# Set the SIP_SUPPORT tag to YES if your project consists of sip sources only.
+# Doxygen will parse them like normal C++ but will assume all classes use public
+# instead of private inheritance when no explicit protection keyword is present.
+SIP_SUPPORT = NO
+# For Microsoft's IDL there are propget and propput attributes to indicate getter
+# and setter methods for a property. Setting this option to YES (the default)
+# will make doxygen replace the get and set methods by a property in the
+# documentation. This will only work if the methods are indeed getting or
+# setting a simple type. If this is not the case, or you want to show the
+# methods anyway, you should set this option to NO.
+IDL_PROPERTY_SUPPORT = YES
+# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
+# tag is set to YES, then doxygen will reuse the documentation of the first
+# member in the group (if any) for the other members of the group. By default
+# all members of a group must be documented explicitly.
+DISTRIBUTE_GROUP_DOC = NO
+# Set the SUBGROUPING tag to YES (the default) to allow class member groups of
+# the same type (for instance a group of public functions) to be put as a
+# subgroup of that type (e.g. under the Public Functions section). Set it to
+# NO to prevent subgrouping. Alternatively, this can be done per class using
# the \nosubgrouping command.
SUBGROUPING = YES
+# When the INLINE_GROUPED_CLASSES tag is set to YES, classes, structs and
+# unions are shown inside the group in which they are included (e.g. using
+# @ingroup) instead of on a separate page (for HTML and Man pages) or
+# section (for LaTeX and RTF).
+INLINE_GROUPED_CLASSES = NO
+# When the INLINE_SIMPLE_STRUCTS tag is set to YES, structs, classes, and
+# unions with only public data fields will be shown inline in the documentation
+# of the scope in which they are defined (i.e. file, namespace, or group
+# documentation), provided this scope is documented. If set to NO (the default),
+# structs, classes, and unions are shown on a separate page (for HTML and Man
+# pages) or section (for LaTeX and RTF).
+INLINE_SIMPLE_STRUCTS = NO
+# When TYPEDEF_HIDES_STRUCT is enabled, a typedef of a struct, union, or enum
+# is documented as struct, union, or enum with the name of the typedef. So
+# typedef struct TypeS {} TypeT, will appear in the documentation as a struct
+# with name TypeT. When disabled the typedef will appear as a member of a file,
+# namespace, or class. And the struct will be named TypeS. This can typically
+# be useful for C code in case the coding convention dictates that all compound
+# types are typedef'ed and only the typedef is referenced, never the tag name.
+TYPEDEF_HIDES_STRUCT = NO
+# The SYMBOL_CACHE_SIZE determines the size of the internal cache use to
+# determine which symbols to keep in memory and which to flush to disk.
+# When the cache is full, less often used symbols will be written to disk.
+# For small to medium size projects (<1000 input files) the default value is
+# probably good enough. For larger projects a too small cache size can cause
+# doxygen to be busy swapping symbols to and from disk most of the time
+# causing a significant performance penalty.
+# If the system has enough physical memory increasing the cache will improve the
+# performance by keeping more symbols in memory. Note that the value works on
+# a logarithmic scale so increasing the size by one will roughly double the
+# memory usage. The cache size is given by this formula:
+# 2^(16+SYMBOL_CACHE_SIZE). The valid range is 0..9, the default is 0,
+# corresponding to a cache size of 2^16 = 65536 symbols.
+SYMBOL_CACHE_SIZE = 0
+# Similar to the SYMBOL_CACHE_SIZE the size of the symbol lookup cache can be
+# set using LOOKUP_CACHE_SIZE. This cache is used to resolve symbols given
+# their name and scope. Since this can be an expensive process and often the
+# same symbol appear multiple times in the code, doxygen keeps a cache of
+# pre-resolved symbols. If the cache is too small doxygen will become slower.
+# If the cache is too large, memory is wasted. The cache size is given by this
+# formula: 2^(16+LOOKUP_CACHE_SIZE). The valid range is 0..9, the default is 0,
+LOOKUP_CACHE_SIZE = 0
# Build related configuration options
-# If the EXTRACT_ALL tag is set to YES doxygen will assume all entities in
-# documentation are documented, even if no documentation was available.
-# Private class members and static file members will be hidden unless
+# If the EXTRACT_ALL tag is set to YES doxygen will assume all entities in
+# documentation are documented, even if no documentation was available.
+# Private class members and static file members will be hidden unless
# the EXTRACT_PRIVATE and EXTRACT_STATIC tags are set to YES
EXTRACT_ALL = YES
-# If the EXTRACT_PRIVATE tag is set to YES all private members of a class
+# If the EXTRACT_PRIVATE tag is set to YES all private members of a class
# will be included in the documentation.
EXTRACT_PRIVATE = NO
-# If the EXTRACT_STATIC tag is set to YES all static members of a file
+# If the EXTRACT_PACKAGE tag is set to YES all members with package or internal scope will be included in the documentation.
+EXTRACT_PACKAGE = NO
+# If the EXTRACT_STATIC tag is set to YES all static members of a file
EXTRACT_STATIC = NO
-# If the EXTRACT_LOCAL_CLASSES tag is set to YES classes (and structs)
-# defined locally in source files will be included in the documentation.
+# If the EXTRACT_LOCAL_CLASSES tag is set to YES classes (and structs)
+# defined locally in source files will be included in the documentation.
# If set to NO only classes defined in header files are included.
EXTRACT_LOCAL_CLASSES = YES
-# This flag is only useful for Objective-C code. When set to YES local
-# methods, which are defined in the implementation section but not in
-# the interface are included in the documentation.
+# This flag is only useful for Objective-C code. When set to YES local
+# methods, which are defined in the implementation section but not in
+# the interface are included in the documentation.
# If set to NO (the default) only methods in the interface are included.
EXTRACT_LOCAL_METHODS = NO
-# If the HIDE_UNDOC_MEMBERS tag is set to YES, Doxygen will hide all
-# undocumented members of documented classes, files or namespaces.
-# If set to NO (the default) these members will be included in the
-# various overviews, but no documentation section is generated.
+# If this flag is set to YES, the members of anonymous namespaces will be
+# extracted and appear in the documentation as a namespace called
+# 'anonymous_namespace{file}', where file will be replaced with the base
+# name of the file that contains the anonymous namespace. By default
+# anonymous namespaces are hidden.
+EXTRACT_ANON_NSPACES = NO
+# If the HIDE_UNDOC_MEMBERS tag is set to YES, Doxygen will hide all
+# undocumented members of documented classes, files or namespaces.
+# If set to NO (the default) these members will be included in the
+# various overviews, but no documentation section is generated.
# This option has no effect if EXTRACT_ALL is enabled.
HIDE_UNDOC_MEMBERS = NO
-# If the HIDE_UNDOC_CLASSES tag is set to YES, Doxygen will hide all
-# undocumented classes that are normally visible in the class hierarchy.
-# If set to NO (the default) these classes will be included in the various
+# If the HIDE_UNDOC_CLASSES tag is set to YES, Doxygen will hide all
+# undocumented classes that are normally visible in the class hierarchy.
+# If set to NO (the default) these classes will be included in the various
# overviews. This option has no effect if EXTRACT_ALL is enabled.
HIDE_UNDOC_CLASSES = NO
-# If the HIDE_FRIEND_COMPOUNDS tag is set to YES, Doxygen will hide all
-# friend (class|struct|union) declarations.
-# If set to NO (the default) these declarations will be included in the
+# If the HIDE_FRIEND_COMPOUNDS tag is set to YES, Doxygen will hide all
+# friend (class|struct|union) declarations.
+# If set to NO (the default) these declarations will be included in the
# documentation.
HIDE_FRIEND_COMPOUNDS = NO
-# If the HIDE_IN_BODY_DOCS tag is set to YES, Doxygen will hide any
-# documentation blocks found inside the body of a function.
-# If set to NO (the default) these blocks will be appended to the
+# If the HIDE_IN_BODY_DOCS tag is set to YES, Doxygen will hide any
+# documentation blocks found inside the body of a function.
+# If set to NO (the default) these blocks will be appended to the
# function's detailed documentation block.
HIDE_IN_BODY_DOCS = NO
-# The INTERNAL_DOCS tag determines if documentation
-# that is typed after a \internal command is included. If the tag is set
-# to NO (the default) then the documentation will be excluded.
+# The INTERNAL_DOCS tag determines if documentation
+# that is typed after a \internal command is included. If the tag is set
+# to NO (the default) then the documentation will be excluded.
# Set it to YES to include the internal documentation.
INTERNAL_DOCS = NO
-# If the CASE_SENSE_NAMES tag is set to NO then Doxygen will only generate
-# file names in lower-case letters. If set to YES upper-case letters are also
-# allowed. This is useful if you have classes or files whose names only differ
-# in case and if your file system supports case sensitive file names. Windows
+# If the CASE_SENSE_NAMES tag is set to NO then Doxygen will only generate
+# file names in lower-case letters. If set to YES upper-case letters are also
+# allowed. This is useful if you have classes or files whose names only differ
+# in case and if your file system supports case sensitive file names. Windows
# and Mac users are advised to set this option to NO.
CASE_SENSE_NAMES = YES
-# If the HIDE_SCOPE_NAMES tag is set to NO (the default) then Doxygen
-# will show members with their full class and namespace scopes in the
+# If the HIDE_SCOPE_NAMES tag is set to NO (the default) then Doxygen
+# will show members with their full class and namespace scopes in the
# documentation. If set to YES the scope will be hidden.
HIDE_SCOPE_NAMES = NO
-# If the SHOW_INCLUDE_FILES tag is set to YES (the default) then Doxygen
-# will put a list of the files that are included by a file in the documentation
+# If the SHOW_INCLUDE_FILES tag is set to YES (the default) then Doxygen
+# will put a list of the files that are included by a file in the documentation
# of that file.
SHOW_INCLUDE_FILES = YES
-# If the INLINE_INFO tag is set to YES (the default) then a tag [inline]
+# If the FORCE_LOCAL_INCLUDES tag is set to YES then Doxygen
+# will list include files with double quotes in the documentation
+# rather than with sharp brackets.
+FORCE_LOCAL_INCLUDES = NO
+# If the INLINE_INFO tag is set to YES (the default) then a tag [inline]
# is inserted in the documentation for inline members.
INLINE_INFO = YES
-# If the SORT_MEMBER_DOCS tag is set to YES (the default) then doxygen
-# will sort the (detailed) documentation of file and class members
-# alphabetically by member name. If set to NO the members will appear in
+# If the SORT_MEMBER_DOCS tag is set to YES (the default) then doxygen
+# will sort the (detailed) documentation of file and class members
+# alphabetically by member name. If set to NO the members will appear in
# declaration order.
SORT_MEMBER_DOCS = YES
-# If the SORT_BRIEF_DOCS tag is set to YES then doxygen will sort the
-# brief documentation of file, namespace and class members alphabetically
-# by member name. If set to NO (the default) the members will appear in
+# If the SORT_BRIEF_DOCS tag is set to YES then doxygen will sort the
+# brief documentation of file, namespace and class members alphabetically
+# by member name. If set to NO (the default) the members will appear in
SORT_BRIEF_DOCS = NO
-# If the SORT_BY_SCOPE_NAME tag is set to YES, the class list will be
-# sorted by fully-qualified names, including namespaces. If set to
-# NO (the default), the class list will be sorted only by class name,
-# not including the namespace part.
+# If the SORT_MEMBERS_CTORS_1ST tag is set to YES then doxygen
+# will sort the (brief and detailed) documentation of class members so that
+# constructors and destructors are listed first. If set to NO (the default)
+# the constructors will appear in the respective orders defined by
+# SORT_MEMBER_DOCS and SORT_BRIEF_DOCS.
+# This tag will be ignored for brief docs if SORT_BRIEF_DOCS is set to NO
+# and ignored for detailed docs if SORT_MEMBER_DOCS is set to NO.
+SORT_MEMBERS_CTORS_1ST = NO
+# If the SORT_GROUP_NAMES tag is set to YES then doxygen will sort the
+# hierarchy of group names into alphabetical order. If set to NO (the default)
+# the group names will appear in their defined order.
+SORT_GROUP_NAMES = NO
+# If the SORT_BY_SCOPE_NAME tag is set to YES, the class list will be
+# sorted by fully-qualified names, including namespaces. If set to
+# NO (the default), the class list will be sorted only by class name,
+# not including the namespace part.
# Note: This option is not very useful if HIDE_SCOPE_NAMES is set to YES.
-# Note: This option applies only to the class list, not to the
+# Note: This option applies only to the class list, not to the
# alphabetical list.
SORT_BY_SCOPE_NAME = NO
-# The GENERATE_TODOLIST tag can be used to enable (YES) or
-# disable (NO) the todo list. This list is created by putting \todo
+# If the STRICT_PROTO_MATCHING option is enabled and doxygen fails to
+# do proper type resolution of all parameters of a function it will reject a
+# match between the prototype and the implementation of a member function even
+# if there is only one candidate or it is obvious which candidate to choose
+# by doing a simple string match. By disabling STRICT_PROTO_MATCHING doxygen
+# will still accept a match between prototype and implementation in such cases.
+STRICT_PROTO_MATCHING = NO
+# The GENERATE_TODOLIST tag can be used to enable (YES) or
+# disable (NO) the todo list. This list is created by putting \todo
# commands in the documentation.
GENERATE_TODOLIST = YES
-# The GENERATE_TESTLIST tag can be used to enable (YES) or
-# disable (NO) the test list. This list is created by putting \test
+# The GENERATE_TESTLIST tag can be used to enable (YES) or
+# disable (NO) the test list. This list is created by putting \test
GENERATE_TESTLIST = YES
-# The GENERATE_BUGLIST tag can be used to enable (YES) or
-# disable (NO) the bug list. This list is created by putting \bug
+# The GENERATE_BUGLIST tag can be used to enable (YES) or
+# disable (NO) the bug list. This list is created by putting \bug
GENERATE_BUGLIST = YES
-# The GENERATE_DEPRECATEDLIST tag can be used to enable (YES) or
-# disable (NO) the deprecated list. This list is created by putting
+# The GENERATE_DEPRECATEDLIST tag can be used to enable (YES) or
+# disable (NO) the deprecated list. This list is created by putting
# \deprecated commands in the documentation.
GENERATE_DEPRECATEDLIST= YES
-# The ENABLED_SECTIONS tag can be used to enable conditional
+# The ENABLED_SECTIONS tag can be used to enable conditional
# documentation sections, marked by \if sectionname ... \endif.
-ENABLED_SECTIONS =
+ENABLED_SECTIONS =
-# The MAX_INITIALIZER_LINES tag determines the maximum number of lines
-# the initial value of a variable or define consists of for it to appear in
-# the documentation. If the initializer consists of more lines than specified
-# here it will be hidden. Use a value of 0 to hide initializers completely.
-# The appearance of the initializer of individual variables and defines in the
-# documentation can be controlled using \showinitializer or \hideinitializer
+# The MAX_INITIALIZER_LINES tag determines the maximum number of lines
+# the initial value of a variable or macro consists of for it to appear in
+# the documentation. If the initializer consists of more lines than specified
+# here it will be hidden. Use a value of 0 to hide initializers completely.
+# The appearance of the initializer of individual variables and macros in the
+# documentation can be controlled using \showinitializer or \hideinitializer
# command in the documentation regardless of this setting.
MAX_INITIALIZER_LINES = 30
-# Set the SHOW_USED_FILES tag to NO to disable the list of files generated
-# at the bottom of the documentation of classes and structs. If set to YES the
+# Set the SHOW_USED_FILES tag to NO to disable the list of files generated
+# at the bottom of the documentation of classes and structs. If set to YES the
# list will mention the files that were used to generate the documentation.
SHOW_USED_FILES = YES
-# If the sources in your project are distributed over multiple directories
-# then setting the SHOW_DIRECTORIES tag to YES will show the directory hierarchy
-# in the documentation.
+# Set the SHOW_FILES tag to NO to disable the generation of the Files page.
+# This will remove the Files entry from the Quick Index and from the
+# Folder Tree View (if specified). The default is YES.
-SHOW_DIRECTORIES = YES
+SHOW_FILES = YES
+# Set the SHOW_NAMESPACES tag to NO to disable the generation of the
+# Namespaces page.
+# This will remove the Namespaces entry from the Quick Index
+# and from the Folder Tree View (if specified). The default is YES.
+SHOW_NAMESPACES = YES
+# The FILE_VERSION_FILTER tag can be used to specify a program or script that
+# doxygen should invoke to get the current version for each file (typically from
+# the version control system). Doxygen will invoke the program by executing (via
+# popen()) the command <command> <input-file>, where <command> is the value of
+# the FILE_VERSION_FILTER tag, and <input-file> is the name of an input file
+# provided by doxygen. Whatever the program writes to standard output
+# is used as the file version. See the manual for examples.
+FILE_VERSION_FILTER =
+# The LAYOUT_FILE tag can be used to specify a layout file which will be parsed
+# by doxygen. The layout file controls the global structure of the generated
+# output files in an output format independent way. The create the layout file
+# that represents doxygen's defaults, run doxygen with the -l option.
+# You can optionally specify a file name after the option, if omitted
+# DoxygenLayout.xml will be used as the name of the layout file.
+LAYOUT_FILE =
+# The CITE_BIB_FILES tag can be used to specify one or more bib files
+# containing the references data. This must be a list of .bib files. The
+# .bib extension is automatically appended if omitted. Using this command
+# requires the bibtex tool to be installed. See also
+# http://en.wikipedia.org/wiki/BibTeX for more info. For LaTeX the style
+# of the bibliography can be controlled using LATEX_BIB_STYLE. To use this
+# feature you need bibtex and perl available in the search path.
+CITE_BIB_FILES =
# configuration options related to warning and progress messages
-# The QUIET tag can be used to turn on/off the messages that are generated
+# The QUIET tag can be used to turn on/off the messages that are generated
# by doxygen. Possible values are YES and NO. If left blank NO is used.
QUIET = NO
-# The WARNINGS tag can be used to turn on/off the warning messages that are
-# generated by doxygen. Possible values are YES and NO. If left blank
+# The WARNINGS tag can be used to turn on/off the warning messages that are
+# generated by doxygen. Possible values are YES and NO. If left blank
# NO is used.
WARNINGS = YES
-# If WARN_IF_UNDOCUMENTED is set to YES, then doxygen will generate warnings
-# for undocumented members. If EXTRACT_ALL is set to YES then this flag will
+# If WARN_IF_UNDOCUMENTED is set to YES, then doxygen will generate warnings
+# for undocumented members. If EXTRACT_ALL is set to YES then this flag will
# automatically be disabled.
WARN_IF_UNDOCUMENTED = YES
-# If WARN_IF_DOC_ERROR is set to YES, doxygen will generate warnings for
-# potential errors in the documentation, such as not documenting some
-# parameters in a documented function, or documenting parameters that
+# If WARN_IF_DOC_ERROR is set to YES, doxygen will generate warnings for
+# potential errors in the documentation, such as not documenting some
+# parameters in a documented function, or documenting parameters that
# don't exist or using markup commands wrongly.
WARN_IF_DOC_ERROR = YES
-# The WARN_FORMAT tag determines the format of the warning messages that
-# doxygen can produce. The string should contain the $file, $line, and $text
-# tags, which will be replaced by the file and line number from which the
-# warning originated and the warning text.
+# The WARN_NO_PARAMDOC option can be enabled to get warnings for
+# functions that are documented, but have no documentation for their parameters
+# or return value. If set to NO (the default) doxygen will only warn about
+# wrong or incomplete parameter documentation, but not about the absence of
+# documentation.
+WARN_NO_PARAMDOC = NO
+# The WARN_FORMAT tag determines the format of the warning messages that
+# doxygen can produce. The string should contain the $file, $line, and $text
+# tags, which will be replaced by the file and line number from which the
+# warning originated and the warning text. Optionally the format may contain
+# $version, which will be replaced by the version of the file (if it could
+# be obtained via FILE_VERSION_FILTER)
WARN_FORMAT = "$file:$line: $text"
-# The WARN_LOGFILE tag can be used to specify a file to which warning
-# and error messages should be written. If left blank the output is written
+# The WARN_LOGFILE tag can be used to specify a file to which warning
+# and error messages should be written. If left blank the output is written
# to stderr.
-WARN_LOGFILE =
+WARN_LOGFILE =
# configuration options related to the input files
-# The INPUT tag can be used to specify the files and/or directories that contain
-# documented source files. You may enter file names like "myfile.cpp" or
-# directories like "/usr/src/myproject". Separate the files or directories
+# The INPUT tag can be used to specify the files and/or directories that contain
+# documented source files. You may enter file names like "myfile.cpp" or
+# directories like "/usr/src/myproject". Separate the files or directories
# with spaces.
INPUT = .
-# If the value of the INPUT tag contains directories, you can use the
-# FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
-# and *.h) to filter out the source-files in the directories. If left
-# blank the following patterns are tested:
-# *.c *.cc *.cxx *.cpp *.c++ *.java *.ii *.ixx *.ipp *.i++ *.inl *.h *.hh *.hxx *.hpp
-# *.h++ *.idl *.odl *.cs *.php *.php3 *.inc *.m *.mm
+# This tag can be used to specify the character encoding of the source files
+# that doxygen parses. Internally doxygen uses the UTF-8 encoding, which is
+# also the default input encoding. Doxygen uses libiconv (or the iconv built
+# into libc) for the transcoding. See http://www.gnu.org/software/libiconv for
+# the list of possible encodings.
+INPUT_ENCODING = UTF-8
+# If the value of the INPUT tag contains directories, you can use the
+# FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
+# and *.h) to filter out the source-files in the directories. If left
+# blank the following patterns are tested:
+# *.c *.cc *.cxx *.cpp *.c++ *.d *.java *.ii *.ixx *.ipp *.i++ *.inl *.h *.hh
+# *.hxx *.hpp *.h++ *.idl *.odl *.cs *.php *.php3 *.inc *.m *.mm *.dox *.py
+# *.f90 *.f *.for *.vhd *.vhdl
FILE_PATTERNS = *.h \
*.c \
- *.i \
+ *.i \
*.py \
*.dox
-# The RECURSIVE tag can be used to turn specify whether or not subdirectories
-# should be searched for input files as well. Possible values are YES and NO.
+# The RECURSIVE tag can be used to turn specify whether or not subdirectories
+# should be searched for input files as well. Possible values are YES and NO.
# If left blank NO is used.
RECURSIVE = YES
-# The EXCLUDE tag can be used to specify files and/or directories that should
-# excluded from the INPUT source files. This way you can easily exclude a
+# The EXCLUDE tag can be used to specify files and/or directories that should be
+# excluded from the INPUT source files. This way you can easily exclude a
# subdirectory from a directory tree whose root is specified with the INPUT tag.
+# Note that relative paths are relative to the directory from which doxygen is
+# run.
EXCLUDE = bin. at ARCH@ \
- db \
- debian \
- demolocation \
- display \
- dist. at ARCH@ \
- doc \
- general \
- gui/scripts \
- gui/wxpython/compat \
- gui/wxpython/icons \
- gui/wxpython/scripts \
- gui/wxpython/tools \
- imagery \
- include/defs \
- lib/btree/test \
- lib/db/dbmi_base/test \
- lib/db/sqlp/test \
- lib/gmath/test \
- lib/gpde/test \
- lib/linkm/test \
- lib/raster3d/test \
+ db \
+ debian \
+ demolocation \
+ display \
+ dist. at ARCH@ \
+ doc \
+ general \
+ gui/scripts \
+ gui/wxpython/compat \
+ gui/wxpython/icons \
+ gui/wxpython/scripts \
+ gui/wxpython/tools \
+ imagery \
+ include/defs \
+ lib/btree/test \
+ lib/db/dbmi_base/test \
+ lib/db/sqlp/test \
+ lib/gmath/test \
+ lib/gpde/test \
+ lib/linkm/test \
+ lib/raster3d/test \
lib/python/ctypes \
- lib/vector/dglib/examples \
- lib/vector/rtree/docs \
- locale \
- macosx \
- man \
- misc \
- mswindows \
- ps \
- raster \
- raster3d \
- rpm \
- scripts \
- sites \
- temporal \
- testsuite \
- tools \
- vector \
- visualization
+ lib/vector/dglib/examples \
+ lib/vector/rtree/docs \
+ locale \
+ macosx \
+ man \
+ misc \
+ mswindows \
+ ps \
+ raster \
+ raster3d \
+ rpm \
+ scripts \
+ sites \
+ temporal \
+ testsuite \
+ tools \
+ vector \
+ visualization
-# The EXCLUDE_SYMLINKS tag can be used select whether or not files or directories
-# that are symbolic links (a Unix filesystem feature) are excluded from the input.
+# The EXCLUDE_SYMLINKS tag can be used to select whether or not files or
+# directories that are symbolic links (a Unix file system feature) are excluded
+# from the input.
EXCLUDE_SYMLINKS = NO
-# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
-# certain files from those directories.
+# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
+# certain files from those directories. Note that the wildcards are matched
+# against the file with absolute path, so to exclude all test directories
+# for example use the pattern */test/*
-EXCLUDE_PATTERNS =
+EXCLUDE_PATTERNS =
-# The EXAMPLE_PATH tag can be used to specify one or more files or
-# directories that contain example code fragments that are included (see
+# The EXCLUDE_SYMBOLS tag can be used to specify one or more symbol names
+# (namespaces, classes, functions, etc.) that should be excluded from the
+# output. The symbol name can be a fully qualified name, a word, or if the
+# wildcard * is used, a substring. Examples: ANamespace, AClass,
+# AClass::ANamespace, ANamespace::*Test
+EXCLUDE_SYMBOLS =
+# The EXAMPLE_PATH tag can be used to specify one or more files or
+# directories that contain example code fragments that are included (see
# the \include command).
-EXAMPLE_PATH =
+EXAMPLE_PATH =
-# If the value of the EXAMPLE_PATH tag contains directories, you can use the
-# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
+# If the value of the EXAMPLE_PATH tag contains directories, you can use the
+# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
# blank all files are included.
-EXAMPLE_PATTERNS =
+EXAMPLE_PATTERNS =
-# If the EXAMPLE_RECURSIVE tag is set to YES then subdirectories will be
-# searched for input files to be used with the \include or \dontinclude
-# commands irrespective of the value of the RECURSIVE tag.
+# If the EXAMPLE_RECURSIVE tag is set to YES then subdirectories will be
+# searched for input files to be used with the \include or \dontinclude
+# commands irrespective of the value of the RECURSIVE tag.
# Possible values are YES and NO. If left blank NO is used.
EXAMPLE_RECURSIVE = NO
-# The IMAGE_PATH tag can be used to specify one or more files or
-# directories that contain image that are included in the documentation (see
+# The IMAGE_PATH tag can be used to specify one or more files or
+# directories that contain image that are included in the documentation (see
# the \image command).
IMAGE_PATH = .
-# The INPUT_FILTER tag can be used to specify a program that doxygen should
-# invoke to filter for each input file. Doxygen will invoke the filter program
-# by executing (via popen()) the command <filter> <input-file>, where <filter>
-# is the value of the INPUT_FILTER tag, and <input-file> is the name of an
-# input file. Doxygen will then use the output that the filter program writes
-# to standard output. If FILTER_PATTERNS is specified, this tag will be
+# The INPUT_FILTER tag can be used to specify a program that doxygen should
+# invoke to filter for each input file. Doxygen will invoke the filter program
+# by executing (via popen()) the command <filter> <input-file>, where <filter>
+# is the value of the INPUT_FILTER tag, and <input-file> is the name of an
+# input file. Doxygen will then use the output that the filter program writes
+# to standard output.
+# If FILTER_PATTERNS is specified, this tag will be
# ignored.
-INPUT_FILTER =
+INPUT_FILTER =
-# The FILTER_PATTERNS tag can be used to specify filters on a per file pattern
-# basis. Doxygen will compare the file name with each pattern and apply the
-# filter if there is a match. The filters are a list of the form:
-# pattern=filter (like *.cpp=my_cpp_filter). See INPUT_FILTER for further
-# info on how filters are used. If FILTER_PATTERNS is empty, INPUT_FILTER
-# is applied to all files.
+# The FILTER_PATTERNS tag can be used to specify filters on a per file pattern
+# basis.
+# Doxygen will compare the file name with each pattern and apply the
+# filter if there is a match.
+# The filters are a list of the form:
+# pattern=filter (like *.cpp=my_cpp_filter). See INPUT_FILTER for further
+# info on how filters are used. If FILTER_PATTERNS is empty or if
+# non of the patterns match the file name, INPUT_FILTER is applied.
-FILTER_PATTERNS =
+FILTER_PATTERNS =
-# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
-# INPUT_FILTER) will be used to filter the input files when producing source
+# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
+# INPUT_FILTER) will be used to filter the input files when producing source
# files to browse (i.e. when SOURCE_BROWSER is set to YES).
FILTER_SOURCE_FILES = NO
+# The FILTER_SOURCE_PATTERNS tag can be used to specify source filters per file
+# pattern. A pattern will override the setting for FILTER_PATTERN (if any)
+# and it is also possible to disable source filtering for a specific pattern
+# using *.ext= (so without naming a filter). This option only has effect when
+# FILTER_SOURCE_FILES is enabled.
+FILTER_SOURCE_PATTERNS =
# configuration options related to source browsing
-# If the SOURCE_BROWSER tag is set to YES then a list of source files will
-# be generated. Documented entities will be cross-referenced with these sources.
-# Note: To get rid of all source code in the generated output, make sure also
+# If the SOURCE_BROWSER tag is set to YES then a list of source files will
+# be generated. Documented entities will be cross-referenced with these sources.
+# Note: To get rid of all source code in the generated output, make sure also
# VERBATIM_HEADERS is set to NO.
SOURCE_BROWSER = YES
-# Setting the INLINE_SOURCES tag to YES will include the body
+# Setting the INLINE_SOURCES tag to YES will include the body
# of functions and classes directly in the documentation.
INLINE_SOURCES = NO
-# Setting the STRIP_CODE_COMMENTS tag to YES (the default) will instruct
-# doxygen to hide any special comment blocks from generated source code
+# Setting the STRIP_CODE_COMMENTS tag to YES (the default) will instruct
+# doxygen to hide any special comment blocks from generated source code
# fragments. Normal C and C++ comments will always remain visible.
STRIP_CODE_COMMENTS = YES
-# If the REFERENCED_BY_RELATION tag is set to YES (the default)
-# then for each documented function all documented
+# If the REFERENCED_BY_RELATION tag is set to YES
+# then for each documented function all documented
# functions referencing it will be listed.
REFERENCED_BY_RELATION = YES
-# If the REFERENCES_RELATION tag is set to YES (the default)
-# then for each documented function all documented entities
+# If the REFERENCES_RELATION tag is set to YES
+# then for each documented function all documented entities
# called/used by that function will be listed.
REFERENCES_RELATION = YES
-# If the VERBATIM_HEADERS tag is set to YES (the default) then Doxygen
-# will generate a verbatim copy of the header file for each class for
+# If the REFERENCES_LINK_SOURCE tag is set to YES (the default)
+# and SOURCE_BROWSER tag is set to YES, then the hyperlinks from
+# functions in REFERENCES_RELATION and REFERENCED_BY_RELATION lists will
+# link to the source code.
+# Otherwise they will link to the documentation.
+REFERENCES_LINK_SOURCE = YES
+# If the USE_HTAGS tag is set to YES then the references to source code
+# will point to the HTML generated by the htags(1) tool instead of doxygen
+# built-in source browser. The htags tool is part of GNU's global source
+# tagging system (see http://www.gnu.org/software/global/global.html). You
+# will need version 4.8.6 or higher.
+USE_HTAGS = NO
+# If the VERBATIM_HEADERS tag is set to YES (the default) then Doxygen
+# will generate a verbatim copy of the header file for each class for
# which an include is specified. Set to NO to disable this.
VERBATIM_HEADERS = YES
@@ -596,279 +877,547 @@
# configuration options related to the alphabetical class index
-# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index
-# of all compounds will be generated. Enable this if the project
+# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index
+# of all compounds will be generated. Enable this if the project
# contains a lot of classes, structs, unions or interfaces.
ALPHABETICAL_INDEX = NO
-# If the alphabetical index is enabled (see ALPHABETICAL_INDEX) then
-# the COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns
+# If the alphabetical index is enabled (see ALPHABETICAL_INDEX) then
+# the COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns
# in which this list will be split (can be a number in the range [1..20])
COLS_IN_ALPHA_INDEX = 5
-# In case all classes in a project start with a common prefix, all
-# classes will be put under the same header in the alphabetical index.
-# The IGNORE_PREFIX tag can be used to specify one or more prefixes that
+# In case all classes in a project start with a common prefix, all
+# classes will be put under the same header in the alphabetical index.
+# The IGNORE_PREFIX tag can be used to specify one or more prefixes that
# should be ignored while generating the index headers.
-IGNORE_PREFIX =
+IGNORE_PREFIX =
# configuration options related to the HTML output
-# If the GENERATE_HTML tag is set to YES (the default) Doxygen will
+# If the GENERATE_HTML tag is set to YES (the default) Doxygen will
# generate HTML output.
GENERATE_HTML = YES
-# The HTML_OUTPUT tag is used to specify where the HTML docs will be put.
-# If a relative path is entered the value of OUTPUT_DIRECTORY will be
+# The HTML_OUTPUT tag is used to specify where the HTML docs will be put.
+# If a relative path is entered the value of OUTPUT_DIRECTORY will be
# put in front of it. If left blank `html' will be used as the default path.
-HTML_OUTPUT =
+HTML_OUTPUT =
-# The HTML_FILE_EXTENSION tag can be used to specify the file extension for
-# each generated HTML page (for example: .htm,.php,.asp). If it is left blank
+# The HTML_FILE_EXTENSION tag can be used to specify the file extension for
+# each generated HTML page (for example: .htm,.php,.asp). If it is left blank
# doxygen will generate files with .html extension.
HTML_FILE_EXTENSION =
-# The HTML_HEADER tag can be used to specify a personal HTML header for
-# each generated HTML page. If it is left blank doxygen will generate a
-# standard header.
+# The HTML_HEADER tag can be used to specify a personal HTML header for
+# each generated HTML page. If it is left blank doxygen will generate a
+# standard header. Note that when using a custom header you are responsible
+# for the proper inclusion of any scripts and style sheets that doxygen
+# needs, which is dependent on the configuration options used.
+# It is advised to generate a default header using "doxygen -w html
+# header.html footer.html stylesheet.css YourConfigFile" and then modify
+# that header. Note that the header is subject to change so you typically
+# have to redo this when upgrading to a newer version of doxygen or when
+# changing the value of configuration settings such as GENERATE_TREEVIEW!
-HTML_HEADER =
+HTML_HEADER =
-# The HTML_FOOTER tag can be used to specify a personal HTML footer for
+# The HTML_FOOTER tag can be used to specify a personal HTML footer for
# standard footer.
-HTML_FOOTER =
+HTML_FOOTER =
-# The HTML_STYLESHEET tag can be used to specify a user-defined cascading
-# style sheet that is used by each HTML page. It can be used to
-# fine-tune the look of the HTML output. If the tag is left blank doxygen
-# will generate a default style sheet. Note that doxygen will try to copy
-# the style sheet file to the HTML output directory, so don't put your own
-# stylesheet in the HTML output directory as well, or it will be erased!
+# The HTML_STYLESHEET tag can be used to specify a user-defined cascading
+# style sheet that is used by each HTML page. It can be used to
+# fine-tune the look of the HTML output. If the tag is left blank doxygen
+# will generate a default style sheet. Note that doxygen will try to copy
+# the style sheet file to the HTML output directory, so don't put your own
+# style sheet in the HTML output directory as well, or it will be erased!
-HTML_STYLESHEET =
+HTML_STYLESHEET =
-# If the HTML_ALIGN_MEMBERS tag is set to YES, the members of classes,
-# files or namespaces will be aligned in HTML using tables. If set to
-# NO a bullet list will be used.
+# The HTML_EXTRA_FILES tag can be used to specify one or more extra images or
+# other source files which should be copied to the HTML output directory. Note
+# that these files will be copied to the base HTML output directory. Use the
+# $relpath$ marker in the HTML_HEADER and/or HTML_FOOTER files to load these
+# files. In the HTML_STYLESHEET file, use the file name only. Also note that
+# the files will be copied as-is; there are no commands or markers available.
-HTML_ALIGN_MEMBERS = YES
+HTML_EXTRA_FILES =
-# If the GENERATE_HTMLHELP tag is set to YES, additional index files
-# will be generated that can be used as input for tools like the
-# Microsoft HTML help workshop to generate a compressed HTML help file (.chm)
+# The HTML_COLORSTYLE_HUE tag controls the color of the HTML output.
+# Doxygen will adjust the colors in the style sheet and background images
+# according to this color. Hue is specified as an angle on a colorwheel,
+# see http://en.wikipedia.org/wiki/Hue for more information.
+# For instance the value 0 represents red, 60 is yellow, 120 is green,
+# 180 is cyan, 240 is blue, 300 purple, and 360 is red again.
+# The allowed range is 0 to 359.
+HTML_COLORSTYLE_HUE = 220
+# The HTML_COLORSTYLE_SAT tag controls the purity (or saturation) of
+# the colors in the HTML output. For a value of 0 the output will use
+# grayscales only. A value of 255 will produce the most vivid colors.
+HTML_COLORSTYLE_SAT = 100
+# The HTML_COLORSTYLE_GAMMA tag controls the gamma correction applied to
+# the luminance component of the colors in the HTML output. Values below
+# 100 gradually make the output lighter, whereas values above 100 make
+# the output darker. The value divided by 100 is the actual gamma applied,
+# so 80 represents a gamma of 0.8, The value 220 represents a gamma of 2.2,
+# and 100 does not change the gamma.
+HTML_COLORSTYLE_GAMMA = 80
+# If the HTML_TIMESTAMP tag is set to YES then the footer of each generated HTML
+# page will contain the date and time when the page was generated. Setting
+# this to NO can help when comparing the output of multiple runs.
+HTML_TIMESTAMP = YES
+# If the HTML_DYNAMIC_SECTIONS tag is set to YES then the generated HTML
+# documentation will contain sections that can be hidden and shown after the
+# page has loaded.
+HTML_DYNAMIC_SECTIONS = NO
+# With HTML_INDEX_NUM_ENTRIES one can control the preferred number of
+# entries shown in the various tree structured indices initially; the user
+# can expand and collapse entries dynamically later on. Doxygen will expand
+# the tree to such a level that at most the specified number of entries are
+# visible (unless a fully collapsed tree already exceeds this amount).
+# So setting the number of entries 1 will produce a full collapsed tree by
+# default. 0 is a special value representing an infinite number of entries
+# and will result in a full expanded tree by default.
+HTML_INDEX_NUM_ENTRIES = 100
+# If the GENERATE_DOCSET tag is set to YES, additional index files
+# will be generated that can be used as input for Apple's Xcode 3
+# integrated development environment, introduced with OSX 10.5 (Leopard).
+# To create a documentation set, doxygen will generate a Makefile in the
+# HTML output directory. Running make will produce the docset in that
+# directory and running "make install" will install the docset in
+# ~/Library/Developer/Shared/Documentation/DocSets so that Xcode will find
+# it at startup.
+# See http://developer.apple.com/tools/creatingdocsetswithdoxygen.html
+# for more information.
+GENERATE_DOCSET = NO
+# When GENERATE_DOCSET tag is set to YES, this tag determines the name of the
+# feed. A documentation feed provides an umbrella under which multiple
+# documentation sets from a single provider (such as a company or product suite)
+# can be grouped.
+DOCSET_FEEDNAME = "Doxygen generated docs"
+# When GENERATE_DOCSET tag is set to YES, this tag specifies a string that
+# should uniquely identify the documentation set bundle. This should be a
+# reverse domain-name style string, e.g. com.mycompany.MyDocSet. Doxygen
+# will append .docset to the name.
+DOCSET_BUNDLE_ID = org.doxygen.Project
+# When GENERATE_PUBLISHER_ID tag specifies a string that should uniquely identify
+# the documentation publisher. This should be a reverse domain-name style
+# string, e.g. com.mycompany.MyDocSet.documentation.
+DOCSET_PUBLISHER_ID = org.doxygen.Publisher
+# The GENERATE_PUBLISHER_NAME tag identifies the documentation publisher.
+DOCSET_PUBLISHER_NAME = Publisher
+# If the GENERATE_HTMLHELP tag is set to YES, additional index files
+# will be generated that can be used as input for tools like the
+# Microsoft HTML help workshop to generate a compiled HTML help file (.chm)
# of the generated HTML documentation.
GENERATE_HTMLHELP = NO
-# If the GENERATE_HTMLHELP tag is set to YES, the CHM_FILE tag can
-# be used to specify the file name of the resulting .chm file. You
-# can add a path in front of the file if the result should not be
+# If the GENERATE_HTMLHELP tag is set to YES, the CHM_FILE tag can
+# be used to specify the file name of the resulting .chm file. You
+# can add a path in front of the file if the result should not be
# written to the html output directory.
-CHM_FILE =
+CHM_FILE =
-# If the GENERATE_HTMLHELP tag is set to YES, the HHC_LOCATION tag can
-# be used to specify the location (absolute path including file name) of
-# the HTML help compiler (hhc.exe). If non-empty doxygen will try to run
+# If the GENERATE_HTMLHELP tag is set to YES, the HHC_LOCATION tag can
+# be used to specify the location (absolute path including file name) of
+# the HTML help compiler (hhc.exe). If non-empty doxygen will try to run
# the HTML help compiler on the generated index.hhp.
-HHC_LOCATION =
+HHC_LOCATION =
-# If the GENERATE_HTMLHELP tag is set to YES, the GENERATE_CHI flag
-# controls if a separate .chi index file is generated (YES) or that
+# If the GENERATE_HTMLHELP tag is set to YES, the GENERATE_CHI flag
+# controls if a separate .chi index file is generated (YES) or that
# it should be included in the master .chm file (NO).
GENERATE_CHI = NO
-# If the GENERATE_HTMLHELP tag is set to YES, the BINARY_TOC flag
-# controls whether a binary table of contents is generated (YES) or a
+# If the GENERATE_HTMLHELP tag is set to YES, the CHM_INDEX_ENCODING
+# is used to encode HtmlHelp index (hhk), content (hhc) and project file
+# content.
+CHM_INDEX_ENCODING =
+# If the GENERATE_HTMLHELP tag is set to YES, the BINARY_TOC flag
+# controls whether a binary table of contents is generated (YES) or a
# normal table of contents (NO) in the .chm file.
BINARY_TOC = NO
-# The TOC_EXPAND flag can be set to YES to add extra items for group members
+# The TOC_EXPAND flag can be set to YES to add extra items for group members
# to the contents of the HTML help documentation and to the tree view.
TOC_EXPAND = NO
-# The DISABLE_INDEX tag can be used to turn on/off the condensed index at
-# top of each HTML page. The value NO (the default) enables the index and
-# the value YES disables it.
+# If the GENERATE_QHP tag is set to YES and both QHP_NAMESPACE and
+# QHP_VIRTUAL_FOLDER are set, an additional index file will be generated
+# that can be used as input for Qt's qhelpgenerator to generate a
+# Qt Compressed Help (.qch) of the generated HTML documentation.
-DISABLE_INDEX = NO
+GENERATE_QHP = NO
-# This tag can be used to set the number of enum values (range [1..20])
-# that doxygen will group on one line in the generated HTML documentation.
+# If the QHG_LOCATION tag is specified, the QCH_FILE tag can
+# be used to specify the file name of the resulting .qch file.
+# The path specified is relative to the HTML output folder.
-ENUM_VALUES_PER_LINE = 4
+QCH_FILE =
-# If the GENERATE_TREEVIEW tag is set to YES, a side panel will be
-# generated containing a tree-like index structure (just like the one that
-# is generated for HTML Help). For this to work a browser that supports
-# JavaScript, DHTML, CSS and frames is required (for instance Mozilla 1.0+,
-# Netscape 6.0+, Internet explorer 5.0+, or Konqueror). Windows users are
-# probably better off using the HTML help feature.
+# The QHP_NAMESPACE tag specifies the namespace to use when generating
+# Qt Help Project output. For more information please see
+# http://doc.trolltech.com/qthelpproject.html#namespace
+QHP_NAMESPACE = org.doxygen.Project
+# The QHP_VIRTUAL_FOLDER tag specifies the namespace to use when generating
+# http://doc.trolltech.com/qthelpproject.html#virtual-folders
+QHP_VIRTUAL_FOLDER = doc
+# If QHP_CUST_FILTER_NAME is set, it specifies the name of a custom filter to
+# add. For more information please see
+# http://doc.trolltech.com/qthelpproject.html#custom-filters
+QHP_CUST_FILTER_NAME =
+# The QHP_CUST_FILT_ATTRS tag specifies the list of the attributes of the
+# custom filter to add. For more information please see
+# <a href="http://doc.trolltech.com/qthelpproject.html#custom-filters">
+# Qt Help Project / Custom Filters</a>.
+QHP_CUST_FILTER_ATTRS =
+# The QHP_SECT_FILTER_ATTRS tag specifies the list of the attributes this
+# project's
+# filter section matches.
+# <a href="http://doc.trolltech.com/qthelpproject.html#filter-attributes">
+# Qt Help Project / Filter Attributes</a>.
+QHP_SECT_FILTER_ATTRS =
+# If the GENERATE_QHP tag is set to YES, the QHG_LOCATION tag can
+# be used to specify the location of Qt's qhelpgenerator.
+# If non-empty doxygen will try to run qhelpgenerator on the generated
+# .qhp file.
+QHG_LOCATION =
+# If the GENERATE_ECLIPSEHELP tag is set to YES, additional index files
+# will be generated, which together with the HTML files, form an Eclipse help
+# plugin. To install this plugin and make it available under the help contents
+# menu in Eclipse, the contents of the directory containing the HTML and XML
+# files needs to be copied into the plugins directory of eclipse. The name of
+# the directory within the plugins directory should be the same as
+# the ECLIPSE_DOC_ID value. After copying Eclipse needs to be restarted before
+# the help appears.
+GENERATE_ECLIPSEHELP = NO
+# A unique identifier for the eclipse help plugin. When installing the plugin
+# the directory name containing the HTML and XML files should also have
+# this name.
+ECLIPSE_DOC_ID = org.doxygen.Project
+# The DISABLE_INDEX tag can be used to turn on/off the condensed index (tabs)
+# at top of each HTML page. The value NO (the default) enables the index and
+# the value YES disables it. Since the tabs have the same information as the
+# navigation tree you can set this option to NO if you already set
+# GENERATE_TREEVIEW to YES.
+DISABLE_INDEX = NO
+# The GENERATE_TREEVIEW tag is used to specify whether a tree-like index
+# structure should be generated to display hierarchical information.
+# If the tag value is set to YES, a side panel will be generated
+# containing a tree-like index structure (just like the one that
+# is generated for HTML Help). For this to work a browser that supports
+# JavaScript, DHTML, CSS and frames is required (i.e. any modern browser).
+# Windows users are probably better off using the HTML help feature.
+# Since the tree basically has the same information as the tab index you
+# could consider to set DISABLE_INDEX to NO when enabling this option.
GENERATE_TREEVIEW = YES
-# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
-# used to set the initial width (in pixels) of the frame in which the tree
+# The ENUM_VALUES_PER_LINE tag can be used to set the number of enum values
+# (range [0,1..20]) that doxygen will group on one line in the generated HTML
+# documentation. Note that a value of 0 will completely suppress the enum
+# values from appearing in the overview section.
+ENUM_VALUES_PER_LINE = 4
+# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
+# used to set the initial width (in pixels) of the frame in which the tree
# is shown.
TREEVIEW_WIDTH = 250
+# When the EXT_LINKS_IN_WINDOW option is set to YES doxygen will open
+# links to external symbols imported via tag files in a separate window.
+EXT_LINKS_IN_WINDOW = NO
+# Use this tag to change the font size of Latex formulas included
+# as images in the HTML documentation. The default is 10. Note that
+# when you change the font size after a successful doxygen run you need
+# to manually remove any form_*.png images from the HTML output directory
+# to force them to be regenerated.
+FORMULA_FONTSIZE = 10
+# Use the FORMULA_TRANPARENT tag to determine whether or not the images
+# generated for formulas are transparent PNGs. Transparent PNGs are
+# not supported properly for IE 6.0, but are supported on all modern browsers.
+# Note that when changing this option you need to delete any form_*.png files
+# in the HTML output before the changes have effect.
+FORMULA_TRANSPARENT = YES
+# Enable the USE_MATHJAX option to render LaTeX formulas using MathJax
+# (see http://www.mathjax.org) which uses client side Javascript for the
+# rendering instead of using prerendered bitmaps. Use this if you do not
+# have LaTeX installed or if you want to formulas look prettier in the HTML
+# output. When enabled you may also need to install MathJax separately and
+# configure the path to it using the MATHJAX_RELPATH option.
+USE_MATHJAX = NO
+# When MathJax is enabled you need to specify the location relative to the
+# HTML output directory using the MATHJAX_RELPATH option. The destination
+# directory should contain the MathJax.js script. For instance, if the mathjax
+# directory is located at the same level as the HTML output directory, then
+# MATHJAX_RELPATH should be ../mathjax. The default value points to
+# the MathJax Content Delivery Network so you can quickly see the result without
+# installing MathJax.
+# However, it is strongly recommended to install a local
+# copy of MathJax from http://www.mathjax.org before deployment.
+MATHJAX_RELPATH = http://cdn.mathjax.org/mathjax/latest
+# The MATHJAX_EXTENSIONS tag can be used to specify one or MathJax extension
+# names that should be enabled during MathJax rendering.
+MATHJAX_EXTENSIONS =
+# When the SEARCHENGINE tag is enabled doxygen will generate a search box
+# for the HTML output. The underlying search engine uses javascript
+# and DHTML and should work on any modern browser. Note that when using
+# HTML help (GENERATE_HTMLHELP), Qt help (GENERATE_QHP), or docsets
+# (GENERATE_DOCSET) there is already a search function so this one should
+# typically be disabled. For large projects the javascript based search engine
+# can be slow, then enabling SERVER_BASED_SEARCH may provide a better solution.
+SEARCHENGINE = YES
+# When the SERVER_BASED_SEARCH tag is enabled the search engine will be
+# implemented using a PHP enabled web server instead of at the web client
+# using Javascript. Doxygen will generate the search PHP script and index
+# file to put on the web server. The advantage of the server
+# based approach is that it scales better to large projects and allows
+# full text search. The disadvantages are that it is more difficult to setup
+# and does not have live searching capabilities.
+SERVER_BASED_SEARCH = NO
# configuration options related to the LaTeX output
-# If the GENERATE_LATEX tag is set to YES (the default) Doxygen will
+# If the GENERATE_LATEX tag is set to YES (the default) Doxygen will
# generate Latex output.
GENERATE_LATEX = YES
-# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put.
+# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put.
# put in front of it. If left blank `latex' will be used as the default path.
LATEX_OUTPUT = latex
-# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
+# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
# invoked. If left blank `latex' will be used as the default command name.
+# Note that when enabling USE_PDFLATEX this option is only used for
+# generating bitmaps for formulas in the HTML output, but not in the
+# Makefile that is written to the output directory.
LATEX_CMD_NAME = latex
-# The MAKEINDEX_CMD_NAME tag can be used to specify the command name to
-# generate index for LaTeX. If left blank `makeindex' will be used as the
+# The MAKEINDEX_CMD_NAME tag can be used to specify the command name to
+# generate index for LaTeX. If left blank `makeindex' will be used as the
# default command name.
MAKEINDEX_CMD_NAME = makeindex
-# If the COMPACT_LATEX tag is set to YES Doxygen generates more compact
-# LaTeX documents. This may be useful for small projects and may help to
+# If the COMPACT_LATEX tag is set to YES Doxygen generates more compact
+# LaTeX documents. This may be useful for small projects and may help to
# save some trees in general.
COMPACT_LATEX = NO
-# The PAPER_TYPE tag can be used to set the paper type that is used
-# by the printer. Possible values are: a4, a4wide, letter, legal and
+# The PAPER_TYPE tag can be used to set the paper type that is used
+# by the printer. Possible values are: a4, letter, legal and
# executive. If left blank a4wide will be used.
PAPER_TYPE = a4
-# The EXTRA_PACKAGES tag can be to specify one or more names of LaTeX
+# The EXTRA_PACKAGES tag can be to specify one or more names of LaTeX
# packages that should be included in the LaTeX output.
-EXTRA_PACKAGES =
+EXTRA_PACKAGES =
-# The LATEX_HEADER tag can be used to specify a personal LaTeX header for
-# the generated latex document. The header should contain everything until
-# the first chapter. If it is left blank doxygen will generate a
+# The LATEX_HEADER tag can be used to specify a personal LaTeX header for
+# the generated latex document. The header should contain everything until
+# the first chapter. If it is left blank doxygen will generate a
# standard header. Notice: only use this tag if you know what you are doing!
-LATEX_HEADER =
+LATEX_HEADER =
-# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated
-# is prepared for conversion to pdf (using ps2pdf). The pdf file will
-# contain links (just like the HTML output) instead of page references
+# The LATEX_FOOTER tag can be used to specify a personal LaTeX footer for
+# the generated latex document. The footer should contain everything after
+# the last chapter. If it is left blank doxygen will generate a
+# standard footer. Notice: only use this tag if you know what you are doing!
+LATEX_FOOTER =
+# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated
+# is prepared for conversion to pdf (using ps2pdf). The pdf file will
+# contain links (just like the HTML output) instead of page references
# This makes the output suitable for online browsing using a pdf viewer.
PDF_HYPERLINKS = NO
-# If the USE_PDFLATEX tag is set to YES, pdflatex will be used instead of
-# plain latex in the generated Makefile. Set this option to YES to get a
+# If the USE_PDFLATEX tag is set to YES, pdflatex will be used instead of
+# plain latex in the generated Makefile. Set this option to YES to get a
# higher quality PDF documentation.
USE_PDFLATEX = NO
-# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \\batchmode.
-# command to the generated LaTeX files. This will instruct LaTeX to keep
-# running if errors occur, instead of asking the user for help.
+# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \\batchmode.
+# command to the generated LaTeX files. This will instruct LaTeX to keep
+# running if errors occur, instead of asking the user for help.
# This option is also used when generating formulas in HTML.
LATEX_BATCHMODE = NO
-# If LATEX_HIDE_INDICES is set to YES then doxygen will not
-# include the index chapters (such as File Index, Compound Index, etc.)
+# If LATEX_HIDE_INDICES is set to YES then doxygen will not
+# include the index chapters (such as File Index, Compound Index, etc.)
# in the output.
LATEX_HIDE_INDICES = NO
+# If LATEX_SOURCE_CODE is set to YES then doxygen will include
+# source code with syntax highlighting in the LaTeX output.
+# Note that which sources are shown also depends on other settings
+# such as SOURCE_BROWSER.
+LATEX_SOURCE_CODE = NO
+# The LATEX_BIB_STYLE tag can be used to specify the style to use for the
+# bibliography, e.g. plainnat, or ieeetr. The default style is "plain". See
+LATEX_BIB_STYLE = plain
# configuration options related to the RTF output
-# If the GENERATE_RTF tag is set to YES Doxygen will generate RTF output
-# The RTF output is optimized for Word 97 and may not look very pretty with
+# If the GENERATE_RTF tag is set to YES Doxygen will generate RTF output
+# The RTF output is optimized for Word 97 and may not look very pretty with
# other RTF readers or editors.
GENERATE_RTF = NO
-# The RTF_OUTPUT tag is used to specify where the RTF docs will be put.
+# The RTF_OUTPUT tag is used to specify where the RTF docs will be put.
# put in front of it. If left blank `rtf' will be used as the default path.
RTF_OUTPUT = rtf
-# If the COMPACT_RTF tag is set to YES Doxygen generates more compact
-# RTF documents. This may be useful for small projects and may help to
+# If the COMPACT_RTF tag is set to YES Doxygen generates more compact
+# RTF documents. This may be useful for small projects and may help to
COMPACT_RTF = NO
-# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated
-# will contain hyperlink fields. The RTF file will
-# contain links (just like the HTML output) instead of page references.
-# This makes the output suitable for online browsing using WORD or other
-# programs which support those fields.
+# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated
+# will contain hyperlink fields. The RTF file will
+# contain links (just like the HTML output) instead of page references.
+# This makes the output suitable for online browsing using WORD or other
+# programs which support those fields.
# Note: wordpad (write) and others do not support links.
RTF_HYPERLINKS = NO
-# Load stylesheet definitions from file. Syntax is similar to doxygen's
-# config file, i.e. a series of assignments. You only have to provide
+# Load style sheet definitions from file. Syntax is similar to doxygen's
+# config file, i.e. a series of assignments. You only have to provide
# replacements, missing definitions are set to their default value.
-RTF_STYLESHEET_FILE =
+RTF_STYLESHEET_FILE =
-# Set optional variables used in the generation of an rtf document.
+# Set optional variables used in the generation of an rtf document.
# Syntax is similar to doxygen's config file.
-RTF_EXTENSIONS_FILE =
+RTF_EXTENSIONS_FILE =
# configuration options related to the man page output
-# If the GENERATE_MAN tag is set to YES (the default) Doxygen will
+# If the GENERATE_MAN tag is set to YES (the default) Doxygen will
# generate man pages
GENERATE_MAN = NO
-# The MAN_OUTPUT tag is used to specify where the man pages will be put.
+# The MAN_OUTPUT tag is used to specify where the man pages will be put.
# put in front of it. If left blank `man' will be used as the default path.
MAN_OUTPUT = man
-# The MAN_EXTENSION tag determines the extension that is added to
+# The MAN_EXTENSION tag determines the extension that is added to
# the generated man pages (default is the subroutine's section .3)
MAN_EXTENSION = .3
-# If the MAN_LINKS tag is set to YES and Doxygen generates man output,
-# then it will generate one additional man file for each entity
-# documented in the real man page(s). These additional files
-# only source the real man page, but without them the man command
+# If the MAN_LINKS tag is set to YES and Doxygen generates man output,
+# then it will generate one additional man file for each entity
+# documented in the real man page(s). These additional files
+# only source the real man page, but without them the man command
# would be unable to find the correct page. The default is NO.
MAN_LINKS = NO
@@ -877,33 +1426,33 @@
# configuration options related to the XML output
-# If the GENERATE_XML tag is set to YES Doxygen will
-# generate an XML file that captures the structure of
+# If the GENERATE_XML tag is set to YES Doxygen will
+# generate an XML file that captures the structure of
# the code including all documentation.
GENERATE_XML = NO
-# The XML_OUTPUT tag is used to specify where the XML pages will be put.
+# The XML_OUTPUT tag is used to specify where the XML pages will be put.
# put in front of it. If left blank `xml' will be used as the default path.
XML_OUTPUT = xml
-# The XML_SCHEMA tag can be used to specify an XML schema,
-# which can be used by a validating XML parser to check the
+# The XML_SCHEMA tag can be used to specify an XML schema,
+# which can be used by a validating XML parser to check the
# syntax of the XML files.
-XML_SCHEMA =
+XML_SCHEMA =
-# The XML_DTD tag can be used to specify an XML DTD,
+# The XML_DTD tag can be used to specify an XML DTD,
-XML_DTD =
+XML_DTD =
-# If the XML_PROGRAMLISTING tag is set to YES Doxygen will
-# dump the program listings (including syntax highlighting
-# and cross-referencing information) to the XML output. Note that
+# If the XML_PROGRAMLISTING tag is set to YES Doxygen will
+# dump the program listings (including syntax highlighting
+# and cross-referencing information) to the XML output. Note that
# enabling this will significantly increase the size of the XML output.
XML_PROGRAMLISTING = YES
@@ -912,10 +1461,10 @@
# configuration options for the AutoGen Definitions output
-# If the GENERATE_AUTOGEN_DEF tag is set to YES Doxygen will
-# generate an AutoGen Definitions (see autogen.sf.net) file
-# that captures the structure of the code including all
-# documentation. Note that this feature is still experimental
+# If the GENERATE_AUTOGEN_DEF tag is set to YES Doxygen will
+# generate an AutoGen Definitions (see autogen.sf.net) file
+# that captures the structure of the code including all
+# documentation. Note that this feature is still experimental
# and incomplete at the moment.
GENERATE_AUTOGEN_DEF = NO
@@ -924,282 +1473,366 @@
# configuration options related to the Perl module output
-# If the GENERATE_PERLMOD tag is set to YES Doxygen will
-# generate a Perl module file that captures the structure of
-# the code including all documentation. Note that this
-# feature is still experimental and incomplete at the
+# If the GENERATE_PERLMOD tag is set to YES Doxygen will
+# generate a Perl module file that captures the structure of
+# the code including all documentation. Note that this
+# feature is still experimental and incomplete at the
# moment.
GENERATE_PERLMOD = NO
-# If the PERLMOD_LATEX tag is set to YES Doxygen will generate
-# the necessary Makefile rules, Perl scripts and LaTeX code to be able
+# If the PERLMOD_LATEX tag is set to YES Doxygen will generate
+# the necessary Makefile rules, Perl scripts and LaTeX code to be able
# to generate PDF and DVI output from the Perl module output.
PERLMOD_LATEX = NO
-# If the PERLMOD_PRETTY tag is set to YES the Perl module output will be
-# nicely formatted so it can be parsed by a human reader. This is useful
-# if you want to understand what is going on. On the other hand, if this
-# tag is set to NO the size of the Perl module output will be much smaller
+# If the PERLMOD_PRETTY tag is set to YES the Perl module output will be
+# nicely formatted so it can be parsed by a human reader.
+# This is useful
+# if you want to understand what is going on.
+# On the other hand, if this
+# tag is set to NO the size of the Perl module output will be much smaller
# and Perl will parse it just the same.
PERLMOD_PRETTY = YES
-# The names of the make variables in the generated doxyrules.make file
-# are prefixed with the string contained in PERLMOD_MAKEVAR_PREFIX.
-# This is useful so different doxyrules.make files included by the same
+# The names of the make variables in the generated doxyrules.make file
+# are prefixed with the string contained in PERLMOD_MAKEVAR_PREFIX.
+# This is useful so different doxyrules.make files included by the same
# Makefile don't overwrite each other's variables.
-PERLMOD_MAKEVAR_PREFIX =
+PERLMOD_MAKEVAR_PREFIX =
-# Configuration options related to the preprocessor
+# Configuration options related to the preprocessor
-# If the ENABLE_PREPROCESSING tag is set to YES (the default) Doxygen will
-# evaluate all C-preprocessor directives found in the sources and include
+# If the ENABLE_PREPROCESSING tag is set to YES (the default) Doxygen will
+# evaluate all C-preprocessor directives found in the sources and include
# files.
ENABLE_PREPROCESSING = YES
-# If the MACRO_EXPANSION tag is set to YES Doxygen will expand all macro
-# names in the source code. If set to NO (the default) only conditional
-# compilation will be performed. Macro expansion can be done in a controlled
+# If the MACRO_EXPANSION tag is set to YES Doxygen will expand all macro
+# names in the source code. If set to NO (the default) only conditional
+# compilation will be performed. Macro expansion can be done in a controlled
# way by setting EXPAND_ONLY_PREDEF to YES.
MACRO_EXPANSION = NO
-# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES
-# then the macro expansion is limited to the macros specified with the
-# PREDEFINED and EXPAND_AS_PREDEFINED tags.
+# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES
+# then the macro expansion is limited to the macros specified with the
+# PREDEFINED and EXPAND_AS_DEFINED tags.
EXPAND_ONLY_PREDEF = NO
-# If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
-# in the INCLUDE_PATH (see below) will be search if a #include is found.
+# If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
+# pointed to by INCLUDE_PATH will be searched when a #include is found.
SEARCH_INCLUDES = YES
-# The INCLUDE_PATH tag can be used to specify one or more directories that
-# contain include files that are not input files but should be processed by
+# The INCLUDE_PATH tag can be used to specify one or more directories that
+# contain include files that are not input files but should be processed by
# the preprocessor.
INCLUDE_PATH = include
-# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
-# patterns (like *.h and *.hpp) to filter out the header-files in the
-# directories. If left blank, the patterns specified with FILE_PATTERNS will
+# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
+# patterns (like *.h and *.hpp) to filter out the header-files in the
+# directories. If left blank, the patterns specified with FILE_PATTERNS will
# be used.
INCLUDE_FILE_PATTERNS =
-# The PREDEFINED tag can be used to specify one or more macro names that
-# are defined before the preprocessor is started (similar to the -D option of
-# gcc). The argument of the tag is a list of macros of the form: name
-# or name=definition (no spaces). If the definition and the = are
-# omitted =1 is assumed. To prevent a macro definition from being
-# undefined via #undef or recursively expanded use the := operator
+# The PREDEFINED tag can be used to specify one or more macro names that
+# are defined before the preprocessor is started (similar to the -D option of
+# gcc). The argument of the tag is a list of macros of the form: name
+# or name=definition (no spaces). If the definition and the = are
+# omitted =1 is assumed. To prevent a macro definition from being
+# undefined via #undef or recursively expanded use the := operator
# instead of the = operator.
-PREDEFINED = HAVE_OGR HAVE_TIFFIO_H HAVE_GEOS
+PREDEFINED = HAVE_OGR \
+ HAVE_TIFFIO_H \
+ HAVE_GEOS
-# If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then
-# this tag can be used to specify a list of macro names that should be expanded.
-# The macro definition that is found in the sources will be used.
-# Use the PREDEFINED tag if you want to use a different macro definition.
+# If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then
+# this tag can be used to specify a list of macro names that should be expanded.
+# The macro definition that is found in the sources will be used.
+# Use the PREDEFINED tag if you want to use a different macro definition that
+# overrules the definition found in the source code.
-EXPAND_AS_DEFINED =
+EXPAND_AS_DEFINED =
-# If the SKIP_FUNCTION_MACROS tag is set to YES (the default) then
-# doxygen's preprocessor will remove all function-like macros that are alone
-# on a line, have an all uppercase name, and do not end with a semicolon. Such
-# function macros are typically used for boiler-plate code, and will confuse the
-# parser if not removed.
+# If the SKIP_FUNCTION_MACROS tag is set to YES (the default) then
+# doxygen's preprocessor will remove all references to function-like macros
+# that are alone on a line, have an all uppercase name, and do not end with a
+# semicolon, because these will confuse the parser if not removed.
SKIP_FUNCTION_MACROS = YES
-# Configuration::additions related to external references
+# Configuration::additions related to external references
-# The TAGFILES option can be used to specify one or more tagfiles.
-# Optionally an initial location of the external documentation
-# can be added for each tagfile. The format of a tag file without
-# this location is as follows:
-# TAGFILES = file1 file2 ...
-# Adding location for the tag files is done as follows:
-# TAGFILES = file1=loc1 "file2 = loc2" ...
-# where "loc1" and "loc2" can be relative or absolute paths or
-# URLs. If a location is present for each tag, the installdox tool
-# does not have to be run to correct the links.
-# Note that each tag file must have a unique name
-# (where the name does NOT include the path)
-# If a tag file is not located in the directory in which doxygen
-# is run, you must also specify the path to the tagfile here.
+# The TAGFILES option can be used to specify one or more tagfiles. For each
+# tag file the location of the external documentation should be added. The
+# format of a tag file without this location is as follows:
+# TAGFILES = file1 file2 ...
+# Adding location for the tag files is done as follows:
+# TAGFILES = file1=loc1 "file2 = loc2" ...
+# where "loc1" and "loc2" can be relative or absolute paths
+# or URLs. Note that each tag file must have a unique name (where the name does
+# NOT include the path). If a tag file is not located in the directory in which
+# doxygen is run, you must also specify the path to the tagfile here.
-TAGFILES =
+TAGFILES =
-# When a file name is specified after GENERATE_TAGFILE, doxygen will create
+# When a file name is specified after GENERATE_TAGFILE, doxygen will create
# a tag file that is based on the input files it reads.
-GENERATE_TAGFILE =
+GENERATE_TAGFILE =
-# If the ALLEXTERNALS tag is set to YES all external classes will be listed
-# in the class index. If set to NO only the inherited external classes
+# If the ALLEXTERNALS tag is set to YES all external classes will be listed
+# in the class index. If set to NO only the inherited external classes
# will be listed.
ALLEXTERNALS = NO
-# If the EXTERNAL_GROUPS tag is set to YES all external groups will be listed
-# in the modules index. If set to NO, only the current project's groups will
+# If the EXTERNAL_GROUPS tag is set to YES all external groups will be listed
+# in the modules index. If set to NO, only the current project's groups will
# be listed.
EXTERNAL_GROUPS = YES
-# The PERL_PATH should be the absolute path and name of the perl script
+# The PERL_PATH should be the absolute path and name of the perl script
# interpreter (i.e. the result of `which perl').
PERL_PATH = /usr/bin/perl
-# Configuration options related to the dot tool
+# Configuration options related to the dot tool
-# If the CLASS_DIAGRAMS tag is set to YES (the default) Doxygen will
-# generate a inheritance diagram (in HTML, RTF and LaTeX) for classes with base or
-# super classes. Setting the tag to NO turns the diagrams off. Note that this
-# option is superseded by the HAVE_DOT option below. This is only a fallback. It is
-# recommended to install and use dot, since it yields more powerful graphs.
+# If the CLASS_DIAGRAMS tag is set to YES (the default) Doxygen will
+# generate a inheritance diagram (in HTML, RTF and LaTeX) for classes with base
+# or super classes. Setting the tag to NO turns the diagrams off. Note that
+# this option also works with HAVE_DOT disabled, but it is recommended to
+# install and use dot, since it yields more powerful graphs.
CLASS_DIAGRAMS = YES
-# If set to YES, the inheritance and collaboration graphs will hide
-# inheritance and usage relations if the target is undocumented
+# You can define message sequence charts within doxygen comments using the \msc
+# command. Doxygen will then run the mscgen tool (see
+# http://www.mcternan.me.uk/mscgen/) to produce the chart and insert it in the
+# documentation. The MSCGEN_PATH tag allows you to specify the directory where
+# the mscgen tool resides. If left empty the tool is assumed to be found in the
+# default search path.
+MSCGEN_PATH =
+# If set to YES, the inheritance and collaboration graphs will hide
+# inheritance and usage relations if the target is undocumented
# or is not a class.
HIDE_UNDOC_RELATIONS = YES
-# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
-# available from the path. This tool is part of Graphviz, a graph visualization
-# toolkit from AT&T and Lucent Bell Labs. The other options in this section
+# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
+# available from the path. This tool is part of Graphviz, a graph visualization
+# toolkit from AT&T and Lucent Bell Labs. The other options in this section
# have no effect if this option is set to NO (the default)
HAVE_DOT = YES
-# If the CLASS_GRAPH and HAVE_DOT tags are set to YES then doxygen
-# will generate a graph for each documented class showing the direct and
-# indirect inheritance relations. Setting this tag to YES will force the
-# the CLASS_DIAGRAMS tag to NO.
+# The DOT_NUM_THREADS specifies the number of dot invocations doxygen is
+# allowed to run in parallel. When set to 0 (the default) doxygen will
+# base this on the number of processors available in the system. You can set it
+# explicitly to a value larger than 0 to get control over the balance
+# between CPU load and processing speed.
+DOT_NUM_THREADS = 0
+# By default doxygen will use the Helvetica font for all dot files that
+# doxygen generates. When you want a differently looking font you can specify
+# the font name using DOT_FONTNAME. You need to make sure dot is able to find
+# the font, which can be done by putting it in a standard location or by setting
+# the DOTFONTPATH environment variable or by setting DOT_FONTPATH to the
+# directory containing the font.
+DOT_FONTNAME = Helvetica
+# The DOT_FONTSIZE tag can be used to set the size of the font of dot graphs.
+# The default size is 10pt.
+DOT_FONTSIZE = 10
+# By default doxygen will tell dot to use the Helvetica font.
+# If you specify a different font using DOT_FONTNAME you can use DOT_FONTPATH to
+# set the path where dot can find it.
+DOT_FONTPATH =
+# If the CLASS_GRAPH and HAVE_DOT tags are set to YES then doxygen
+# will generate a graph for each documented class showing the direct and
+# indirect inheritance relations. Setting this tag to YES will force the
+# CLASS_DIAGRAMS tag to NO.
CLASS_GRAPH = YES
-# If the COLLABORATION_GRAPH and HAVE_DOT tags are set to YES then doxygen
-# indirect implementation dependencies (inheritance, containment, and
+# If the COLLABORATION_GRAPH and HAVE_DOT tags are set to YES then doxygen
+# indirect implementation dependencies (inheritance, containment, and
# class references variables) of the class with other documented classes.
COLLABORATION_GRAPH = YES
-# If the UML_LOOK tag is set to YES doxygen will generate inheritance and
-# collaboration diagrams in a style similar to the OMG's Unified Modeling
+# If the GROUP_GRAPHS and HAVE_DOT tags are set to YES then doxygen
+# will generate a graph for groups, showing the direct groups dependencies
+GROUP_GRAPHS = YES
+# If the UML_LOOK tag is set to YES doxygen will generate inheritance and
+# collaboration diagrams in a style similar to the OMG's Unified Modeling
# Language.
UML_LOOK = NO
-# If set to YES, the inheritance and collaboration graphs will show the
+# If the UML_LOOK tag is enabled, the fields and methods are shown inside
+# the class node. If there are many fields or methods and many nodes the
+# graph may become too big to be useful. The UML_LIMIT_NUM_FIELDS
+# threshold limits the number of items for each type to make the size more
+# managable. Set this to 0 for no limit. Note that the threshold may be
+# exceeded by 50% before the limit is enforced.
+UML_LIMIT_NUM_FIELDS = 10
+# If set to YES, the inheritance and collaboration graphs will show the
# relations between templates and their instances.
TEMPLATE_RELATIONS = NO
-# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDE_GRAPH, and HAVE_DOT
-# tags are set to YES then doxygen will generate a graph for each documented
-# file showing the direct and indirect include dependencies of the file with
+# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDE_GRAPH, and HAVE_DOT
+# tags are set to YES then doxygen will generate a graph for each documented
+# file showing the direct and indirect include dependencies of the file with
# other documented files.
INCLUDE_GRAPH = YES
-# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDED_BY_GRAPH, and
-# HAVE_DOT tags are set to YES then doxygen will generate a graph for each
-# documented header file showing the documented files that directly or
+# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDED_BY_GRAPH, and
+# HAVE_DOT tags are set to YES then doxygen will generate a graph for each
+# documented header file showing the documented files that directly or
# indirectly include this file.
INCLUDED_BY_GRAPH = YES
-# If the CALL_GRAPH and HAVE_DOT tags are set to YES then doxygen will
-# generate a call dependency graph for every global function or class method.
-# Note that enabling this option will significantly increase the time of a run.
-# So in most cases it will be better to enable call graphs for selected
-# functions only using the \callgraph command.
+# If the CALL_GRAPH and HAVE_DOT options are set to YES then
+# doxygen will generate a call dependency graph for every global function
+# or class method. Note that enabling this option will significantly increase
+# the time of a run. So in most cases it will be better to enable call graphs
+# for selected functions only using the \callgraph command.
CALL_GRAPH = NO
-# If the GRAPHICAL_HIERARCHY and HAVE_DOT tags are set to YES then doxygen
-# will graphical hierarchy of all classes instead of a textual one.
+# If the CALLER_GRAPH and HAVE_DOT tags are set to YES then
+# doxygen will generate a caller dependency graph for every global function
+# the time of a run. So in most cases it will be better to enable caller
+# graphs for selected functions only using the \callergraph command.
+CALLER_GRAPH = NO
+# If the GRAPHICAL_HIERARCHY and HAVE_DOT tags are set to YES then doxygen
+# will generate a graphical hierarchy of all classes instead of a textual one.
GRAPHICAL_HIERARCHY = YES
-# The DOT_IMAGE_FORMAT tag can be used to set the image format of the images
-# generated by dot. Possible values are png, jpg, or gif
-# If left blank png will be used.
+# If the DIRECTORY_GRAPH and HAVE_DOT tags are set to YES
+# then doxygen will show the dependencies a directory has on other directories
+# in a graphical way. The dependency relations are determined by the #include
+# relations between the files in the directories.
+DIRECTORY_GRAPH = YES
+# The DOT_IMAGE_FORMAT tag can be used to set the image format of the images
+# generated by dot. Possible values are svg, png, jpg, or gif.
+# If left blank png will be used. If you choose svg you need to set
+# HTML_FILE_EXTENSION to xhtml in order to make the SVG files
+# visible in IE 9+ (other browsers do not have this requirement).
DOT_IMAGE_FORMAT = png
-# The tag DOT_PATH can be used to specify the path where the dot tool can be
-# found. If left blank, it is assumed the dot tool can be found on the path.
+# If DOT_IMAGE_FORMAT is set to svg, then this option can be set to YES to
+# enable generation of interactive SVG images that allow zooming and panning.
+# Note that this requires a modern browser other than Internet Explorer.
+# Tested and working are Firefox, Chrome, Safari, and Opera. For IE 9+ you
+# need to set HTML_FILE_EXTENSION to xhtml in order to make the SVG files
+# visible. Older versions of IE do not have SVG support.
-DOT_PATH =
+INTERACTIVE_SVG = NO
-# The DOTFILE_DIRS tag can be used to specify one or more directories that
-# contain dot files that are included in the documentation (see the
+# The tag DOT_PATH can be used to specify the path where the dot tool can be
+# found. If left blank, it is assumed the dot tool can be found in the path.
+DOT_PATH =
+# The DOTFILE_DIRS tag can be used to specify one or more directories that
+# contain dot files that are included in the documentation (see the
# \dotfile command).
-DOTFILE_DIRS =
+DOTFILE_DIRS =
-# The MAX_DOT_GRAPH_WIDTH tag can be used to set the maximum allowed width
-# (in pixels) of the graphs generated by dot. If a graph becomes larger than
-# this value, doxygen will try to truncate the graph, so that it fits within
-# the specified constraint. Beware that most browsers cannot cope with very
-# large images.
+# The MSCFILE_DIRS tag can be used to specify one or more directories that
+# contain msc files that are included in the documentation (see the
+# \mscfile command).
-MAX_DOT_GRAPH_WIDTH = 2000
+MSCFILE_DIRS =
-# The MAX_DOT_GRAPH_HEIGHT tag can be used to set the maximum allows height
-# large images.
+# The DOT_GRAPH_MAX_NODES tag can be used to set the maximum number of
+# nodes that will be shown in the graph. If the number of nodes in a graph
+# becomes larger than this value, doxygen will truncate the graph, which is
+# visualized by representing a node as a red box. Note that doxygen if the
+# number of direct children of the root node in a graph is already larger than
+# DOT_GRAPH_MAX_NODES then the graph will not be shown at all. Also note
+# that the size of a graph can be further restricted by MAX_DOT_GRAPH_DEPTH.
-MAX_DOT_GRAPH_HEIGHT = 2000
+DOT_GRAPH_MAX_NODES = 50
-# The MAX_DOT_GRAPH_DEPTH tag can be used to set the maximum depth of the
-# graphs generated by dot. A depth value of 3 means that only nodes reachable
-# from the root by following a path via at most 3 edges will be shown. Nodes that
-# lay further from the root node will be omitted. Note that setting this option to
-# 1 or 2 may greatly reduce the computation time needed for large code bases. Also
-# note that a graph may be further truncated if the graph's image dimensions are
-# not sufficient to fit the graph (see MAX_DOT_GRAPH_WIDTH and MAX_DOT_GRAPH_HEIGHT).
-# If 0 is used for the depth value (the default), the graph is not depth-constrained.
+# The MAX_DOT_GRAPH_DEPTH tag can be used to set the maximum depth of the
+# graphs generated by dot. A depth value of 3 means that only nodes reachable
+# from the root by following a path via at most 3 edges will be shown. Nodes
+# that lay further from the root node will be omitted. Note that setting this
+# option to 1 or 2 may greatly reduce the computation time needed for large
+# code bases. Also note that the size of a graph can be further restricted by
+# DOT_GRAPH_MAX_NODES. Using a depth of 0 means no depth restriction.
MAX_DOT_GRAPH_DEPTH = 0
-# If the GENERATE_LEGEND tag is set to YES (the default) Doxygen will
-# generate a legend page explaining the meaning of the various boxes and
+# Set the DOT_TRANSPARENT tag to YES to generate images with a transparent
+# background. This is disabled by default, because dot on Windows does not
+# seem to support this out of the box. Warning: Depending on the platform used,
+# enabling this option may lead to badly anti-aliased labels on the edges of
+# a graph (i.e. they become hard to read).
+DOT_TRANSPARENT = NO
+# Set the DOT_MULTI_TARGETS tag to YES allow dot to generate multiple output
+# files in one run (i.e. multiple -o and -T options on the command line). This
+# makes dot run faster, but since only newer versions of dot (>1.8.10)
+# support this, this feature is disabled by default.
+DOT_MULTI_TARGETS = YES
+# If the GENERATE_LEGEND tag is set to YES (the default) Doxygen will
+# generate a legend page explaining the meaning of the various boxes and
# arrows in the dot generated graphs.
GENERATE_LEGEND = YES
-# If the DOT_CLEANUP tag is set to YES (the default) Doxygen will
-# remove the intermediate dot files that are used to generate
+# If the DOT_CLEANUP tag is set to YES (the default) Doxygen will
+# remove the intermediate dot files that are used to generate
# the various graphs.
DOT_CLEANUP = YES
-# Configuration::additions related to the search engine
-# The SEARCHENGINE tag specifies whether or not a search engine should be
-# used. If set to NO the values of all tags below this one will be ignored.
-SEARCHENGINE = YES
Modified: grass/trunk/include/Make/Doxyfile_arch_latex.in
--- grass/trunk/include/Make/Doxyfile_arch_latex.in 2012-05-31 13:40:10 UTC (rev 51907)
+++ grass/trunk/include/Make/Doxyfile_arch_latex.in 2012-05-31 14:47:24 UTC (rev 51908)
@@ -1,593 +1,874 @@
-# Doxyfile 1.3.9.1
+# Doxyfile 1.8.1
# This file describes the settings to be used by the documentation system
-# doxygen (www.doxygen.org) for a project
+# doxygen (www.doxygen.org) for a project.
-# All text after a hash (#) is considered a comment and will be ignored
+# All text after a hash (#) is considered a comment and will be ignored.
# The format is:
# TAG = value [value, ...]
# For lists items can also be appended using:
# TAG += value [value, ...]
-# Values that contain spaces should be placed between quotes (" ")
+# Values that contain spaces should be placed between quotes (" ").
# Project related configuration options
-# The PROJECT_NAME tag is a single word (or a sequence of words surrounded
-# by quotes) that should identify the project.
+# This tag specifies the encoding used for all characters in the config file
+# that follow. The default is UTF-8 which is also the encoding used for all
+# text before the first occurrence of this tag. Doxygen uses libiconv (or the
+# iconv built into libc) for the transcoding. See
+# http://www.gnu.org/software/libiconv for the list of possible encodings.
+DOXYFILE_ENCODING = UTF-8
+# The PROJECT_NAME tag is a single word (or sequence of words) that should
+# identify the project. Note that if you do not use Doxywizard you need
+# to put quotes around the project name if it contains spaces.
PROJECT_NAME = "GRASS Programmer's Manual"
-# The PROJECT_NUMBER tag can be used to enter a project or revision number.
-# This could be handy for archiving the generated documentation or
+# The PROJECT_NUMBER tag can be used to enter a project or revision number.
+# This could be handy for archiving the generated documentation or
# if some version control system is used.
-PROJECT_NUMBER = @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@ (@GRASS_VERSION_DATE@) - r at GRASS_VERSION_SVN@
+PROJECT_NUMBER = @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@(@GRASS_VERSION_DATE@)-r at GRASS_VERSION_SVN@
-# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
-# base path where the generated documentation will be put.
-# If a relative path is entered, it will be relative to the location
+# Using the PROJECT_BRIEF tag one can provide an optional one line description
+# for a project that appears at the top of each page and should give viewer
+# a quick idea about the purpose of the project. Keep the description short.
+PROJECT_BRIEF =
+# With the PROJECT_LOGO tag one can specify an logo or icon that is
+# included in the documentation. The maximum height of the logo should not
+# exceed 55 pixels and the maximum width should not exceed 200 pixels.
+# Doxygen will copy the logo to the output directory.
+PROJECT_LOGO =
+# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
+# base path where the generated documentation will be put.
+# If a relative path is entered, it will be relative to the location
# where doxygen was started. If left blank the current directory will be used.
OUTPUT_DIRECTORY = .
-# If the CREATE_SUBDIRS tag is set to YES, then doxygen will create
-# 4096 sub-directories (in 2 levels) under the output directory of each output
-# format and will distribute the generated files over these directories.
-# Enabling this option can be useful when feeding doxygen a huge amount of source
-# files, where putting all generated files in the same directory would otherwise
-# cause performance problems for the file system.
+# If the CREATE_SUBDIRS tag is set to YES, then doxygen will create
+# 4096 sub-directories (in 2 levels) under the output directory of each output
+# format and will distribute the generated files over these directories.
+# Enabling this option can be useful when feeding doxygen a huge amount of
+# source files, where putting all generated files in the same directory would
+# otherwise cause performance problems for the file system.
CREATE_SUBDIRS = NO
-# The OUTPUT_LANGUAGE tag is used to specify the language in which all
-# documentation generated by doxygen is written. Doxygen will use this
-# information to generate all constant output in the proper language.
-# The default language is English, other supported languages are:
-# Brazilian, Catalan, Chinese, Chinese-Traditional, Croatian, Czech, Danish,
-# Dutch, Finnish, French, German, Greek, Hungarian, Italian, Japanese,
-# Japanese-en (Japanese with English messages), Korean, Korean-en, Norwegian,
-# Polish, Portuguese, Romanian, Russian, Serbian, Slovak, Slovene, Spanish,
-# Swedish, and Ukrainian.
+# The OUTPUT_LANGUAGE tag is used to specify the language in which all
+# documentation generated by doxygen is written. Doxygen will use this
+# information to generate all constant output in the proper language.
+# The default language is English, other supported languages are:
+# Afrikaans, Arabic, Brazilian, Catalan, Chinese, Chinese-Traditional,
+# Croatian, Czech, Danish, Dutch, Esperanto, Farsi, Finnish, French, German,
+# Greek, Hungarian, Italian, Japanese, Japanese-en (Japanese with English
+# messages), Korean, Korean-en, Lithuanian, Norwegian, Macedonian, Persian,
+# Polish, Portuguese, Romanian, Russian, Serbian, Serbian-Cyrillic, Slovak,
+# Slovene, Spanish, Swedish, Ukrainian, and Vietnamese.
OUTPUT_LANGUAGE = English
-# This tag can be used to specify the encoding used in the generated output.
-# The encoding is not always determined by the language that is chosen,
-# but also whether or not the output is meant for Windows or non-Windows users.
-# In case there is a difference, setting the USE_WINDOWS_ENCODING tag to YES
-# forces the Windows encoding (this is the default for the Windows binary),
-# whereas setting the tag to NO uses a Unix-style encoding (the default for
-# all platforms other than Windows).
-USE_WINDOWS_ENCODING = NO
-# If the BRIEF_MEMBER_DESC tag is set to YES (the default) Doxygen will
-# include brief member descriptions after the members that are listed in
-# the file and class documentation (similar to JavaDoc).
+# If the BRIEF_MEMBER_DESC tag is set to YES (the default) Doxygen will
+# include brief member descriptions after the members that are listed in
+# the file and class documentation (similar to JavaDoc).
# Set to NO to disable this.
BRIEF_MEMBER_DESC = YES
-# If the REPEAT_BRIEF tag is set to YES (the default) Doxygen will prepend
-# the brief description of a member or function before the detailed description.
-# Note: if both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
+# If the REPEAT_BRIEF tag is set to YES (the default) Doxygen will prepend
+# the brief description of a member or function before the detailed description.
+# Note: if both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
# brief descriptions will be completely suppressed.
REPEAT_BRIEF = YES
-# This tag implements a quasi-intelligent brief description abbreviator
-# that is used to form the text in various listings. Each string
-# in this list, if found as the leading text of the brief description, will be
-# stripped from the text and the result after processing the whole list, is used
-# as the annotated text. Otherwise, the brief description is used as-is. If left
-# blank, the following values are used ("$name" is automatically replaced with the
-# name of the entity): "The $name class" "The $name widget" "The $name file"
-# "is" "provides" "specifies" "contains" "represents" "a" "an" "the"
+# This tag implements a quasi-intelligent brief description abbreviator
+# that is used to form the text in various listings. Each string
+# in this list, if found as the leading text of the brief description, will be
+# stripped from the text and the result after processing the whole list, is
+# used as the annotated text. Otherwise, the brief description is used as-is.
+# If left blank, the following values are used ("$name" is automatically
+# replaced with the name of the entity): "The $name class" "The $name widget"
+# "The $name file" "is" "provides" "specifies" "contains"
+# "represents" "a" "an" "the"
-ABBREVIATE_BRIEF =
+ABBREVIATE_BRIEF =
-# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
-# Doxygen will generate a detailed section even if there is only a brief
+# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
+# Doxygen will generate a detailed section even if there is only a brief
# description.
ALWAYS_DETAILED_SEC = NO
-# If the INLINE_INHERITED_MEMB tag is set to YES, doxygen will show all inherited
-# members of a class in the documentation of that class as if those members were
-# ordinary class members. Constructors, destructors and assignment operators of
-# the base classes will not be shown.
+# If the INLINE_INHERITED_MEMB tag is set to YES, doxygen will show all
+# inherited members of a class in the documentation of that class as if those
+# members were ordinary class members. Constructors, destructors and assignment
+# operators of the base classes will not be shown.
INLINE_INHERITED_MEMB = NO
-# If the FULL_PATH_NAMES tag is set to YES then Doxygen will prepend the full
-# path before files name in the file list and in the header files. If set
+# If the FULL_PATH_NAMES tag is set to YES then Doxygen will prepend the full
+# path before files name in the file list and in the header files. If set
# to NO the shortest path that makes the file name unique will be used.
FULL_PATH_NAMES = NO
-# If the FULL_PATH_NAMES tag is set to YES then the STRIP_FROM_PATH tag
-# can be used to strip a user-defined part of the path. Stripping is
-# only done if one of the specified strings matches the left-hand part of
-# the path. The tag can be used to show relative paths in the file list.
-# If left blank the directory from which doxygen is run is used as the
+# If the FULL_PATH_NAMES tag is set to YES then the STRIP_FROM_PATH tag
+# can be used to strip a user-defined part of the path. Stripping is
+# only done if one of the specified strings matches the left-hand part of
+# the path. The tag can be used to show relative paths in the file list.
+# If left blank the directory from which doxygen is run is used as the
# path to strip.
-STRIP_FROM_PATH =
+STRIP_FROM_PATH =
-# The STRIP_FROM_INC_PATH tag can be used to strip a user-defined part of
-# the path mentioned in the documentation of a class, which tells
-# the reader which header file to include in order to use a class.
-# If left blank only the name of the header file containing the class
-# definition is used. Otherwise one should specify the include paths that
+# The STRIP_FROM_INC_PATH tag can be used to strip a user-defined part of
+# the path mentioned in the documentation of a class, which tells
+# the reader which header file to include in order to use a class.
+# If left blank only the name of the header file containing the class
+# definition is used. Otherwise one should specify the include paths that
# are normally passed to the compiler using the -I flag.
-STRIP_FROM_INC_PATH =
+STRIP_FROM_INC_PATH =
-# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter
-# (but less readable) file names. This can be useful is your file systems
+# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter
+# (but less readable) file names. This can be useful if your file system
# doesn't support long names like on DOS, Mac, or CD-ROM.
SHORT_NAMES = NO
-# If the JAVADOC_AUTOBRIEF tag is set to YES then Doxygen
-# will interpret the first line (until the first dot) of a JavaDoc-style
-# comment as the brief description. If set to NO, the JavaDoc
-# comments will behave just like the Qt-style comments (thus requiring an
-# explicit @brief command for a brief description.
+# If the JAVADOC_AUTOBRIEF tag is set to YES then Doxygen
+# will interpret the first line (until the first dot) of a JavaDoc-style
+# comment as the brief description. If set to NO, the JavaDoc
+# comments will behave just like regular Qt-style comments
+# (thus requiring an explicit @brief command for a brief description.)
JAVADOC_AUTOBRIEF = NO
-# The MULTILINE_CPP_IS_BRIEF tag can be set to YES to make Doxygen
-# treat a multi-line C++ special comment block (i.e. a block of //! or ///
-# comments) as a brief description. This used to be the default behaviour.
-# The new default is to treat a multi-line C++ comment block as a detailed
+# If the QT_AUTOBRIEF tag is set to YES then Doxygen will
+# interpret the first line (until the first dot) of a Qt-style
+# comment as the brief description. If set to NO, the comments
+# will behave just like regular Qt-style comments (thus requiring
+# an explicit \brief command for a brief description.)
+QT_AUTOBRIEF = NO
+# The MULTILINE_CPP_IS_BRIEF tag can be set to YES to make Doxygen
+# treat a multi-line C++ special comment block (i.e. a block of //! or ///
+# comments) as a brief description. This used to be the default behaviour.
+# The new default is to treat a multi-line C++ comment block as a detailed
# description. Set this tag to YES if you prefer the old behaviour instead.
MULTILINE_CPP_IS_BRIEF = NO
-# If the DETAILS_AT_TOP tag is set to YES then Doxygen
-# will output the detailed description near the top, like JavaDoc.
-# If set to NO, the detailed description appears after the member
-# documentation.
-DETAILS_AT_TOP = NO
-# If the INHERIT_DOCS tag is set to YES (the default) then an undocumented
-# member inherits the documentation from any documented member that it
+# If the INHERIT_DOCS tag is set to YES (the default) then an undocumented
+# member inherits the documentation from any documented member that it
# re-implements.
INHERIT_DOCS = YES
-# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
-# tag is set to YES, then doxygen will reuse the documentation of the first
-# member in the group (if any) for the other members of the group. By default
-# all members of a group must be documented explicitly.
+# If the SEPARATE_MEMBER_PAGES tag is set to YES, then doxygen will produce
+# a new page for each member. If set to NO, the documentation of a member will
+# be part of the file/class/namespace that contains it.
-DISTRIBUTE_GROUP_DOC = NO
+SEPARATE_MEMBER_PAGES = NO
-# The TAB_SIZE tag can be used to set the number of spaces in a tab.
+# The TAB_SIZE tag can be used to set the number of spaces in a tab.
# Doxygen uses this value to replace tabs by spaces in code fragments.
TAB_SIZE = 8
-# This tag can be used to specify a number of aliases that acts
-# as commands in the documentation. An alias has the form "name=value".
-# For example adding "sideeffect=\par Side Effects:\n" will allow you to
-# put the command \sideeffect (or @sideeffect) in the documentation, which
-# will result in a user-defined paragraph with heading "Side Effects:".
+# This tag can be used to specify a number of aliases that acts
+# as commands in the documentation. An alias has the form "name=value".
+# For example adding "sideeffect=\par Side Effects:\n" will allow you to
+# put the command \sideeffect (or @sideeffect) in the documentation, which
+# will result in a user-defined paragraph with heading "Side Effects:".
# You can put \n's in the value part of an alias to insert newlines.
-ALIASES =
+ALIASES =
-# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C sources
-# only. Doxygen will then generate output that is more tailored for C.
-# For instance, some of the names that are used will be different. The list
+# This tag can be used to specify a number of word-keyword mappings (TCL only).
+# A mapping has the form "name=value". For example adding
+# "class=itcl::class" will allow you to use the command class in the
+# itcl::class meaning.
+TCL_SUBST =
+# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C
+# sources only. Doxygen will then generate output that is more tailored for C.
+# For instance, some of the names that are used will be different. The list
# of all members will be omitted, etc.
OPTIMIZE_OUTPUT_FOR_C = YES
-# Set the OPTIMIZE_OUTPUT_JAVA tag to YES if your project consists of Java sources
-# only. Doxygen will then generate output that is more tailored for Java.
-# For instance, namespaces will be presented as packages, qualified scopes
-# will look different, etc.
+# Set the OPTIMIZE_OUTPUT_JAVA tag to YES if your project consists of Java
+# Java. For instance, namespaces will be presented as packages, qualified
+# scopes will look different, etc.
OPTIMIZE_OUTPUT_JAVA = NO
-# Set the SUBGROUPING tag to YES (the default) to allow class member groups of
-# the same type (for instance a group of public functions) to be put as a
-# subgroup of that type (e.g. under the Public Functions section). Set it to
-# NO to prevent subgrouping. Alternatively, this can be done per class using
+# Set the OPTIMIZE_FOR_FORTRAN tag to YES if your project consists of Fortran
+# Fortran.
+OPTIMIZE_FOR_FORTRAN = NO
+# Set the OPTIMIZE_OUTPUT_VHDL tag to YES if your project consists of VHDL
+# sources. Doxygen will then generate output that is tailored for
+# VHDL.
+OPTIMIZE_OUTPUT_VHDL = NO
+# Doxygen selects the parser to use depending on the extension of the files it
+# parses. With this tag you can assign which parser to use for a given extension.
+# Doxygen has a built-in mapping, but you can override or extend it using this
+# tag. The format is ext=language, where ext is a file extension, and language
+# is one of the parsers supported by doxygen: IDL, Java, Javascript, CSharp, C,
+# C++, D, PHP, Objective-C, Python, Fortran, VHDL, C, C++. For instance to make
+# doxygen treat .inc files as Fortran files (default is PHP), and .f files as C
+# (default is Fortran), use: inc=Fortran f=C. Note that for custom extensions
+# you also need to set FILE_PATTERNS otherwise the files are not read by doxygen.
+EXTENSION_MAPPING =
+# If MARKDOWN_SUPPORT is enabled (the default) then doxygen pre-processes all
+# comments according to the Markdown format, which allows for more readable
+# documentation. See http://daringfireball.net/projects/markdown/ for details.
+# The output of markdown processing is further processed by doxygen, so you
+# can mix doxygen, HTML, and XML commands with Markdown formatting.
+# Disable only in case of backward compatibilities issues.
+MARKDOWN_SUPPORT = YES
+# If you use STL classes (i.e. std::string, std::vector, etc.) but do not want
+# to include (a tag file for) the STL sources as input, then you should
+# set this tag to YES in order to let doxygen match functions declarations and
+# definitions whose arguments contain STL classes (e.g. func(std::string); v.s.
+# func(std::string) {}). This also makes the inheritance and collaboration
+# diagrams that involve STL classes more complete and accurate.
+BUILTIN_STL_SUPPORT = NO
+# If you use Microsoft's C++/CLI language, you should set this option to YES to
+# enable parsing support.
+CPP_CLI_SUPPORT = NO
+# Set the SIP_SUPPORT tag to YES if your project consists of sip sources only.
+# Doxygen will parse them like normal C++ but will assume all classes use public
+# instead of private inheritance when no explicit protection keyword is present.
+SIP_SUPPORT = NO
+# For Microsoft's IDL there are propget and propput attributes to indicate getter
+# and setter methods for a property. Setting this option to YES (the default)
+# will make doxygen replace the get and set methods by a property in the
+# documentation. This will only work if the methods are indeed getting or
+# setting a simple type. If this is not the case, or you want to show the
+# methods anyway, you should set this option to NO.
+IDL_PROPERTY_SUPPORT = YES
+# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
+# tag is set to YES, then doxygen will reuse the documentation of the first
+# member in the group (if any) for the other members of the group. By default
+# all members of a group must be documented explicitly.
+DISTRIBUTE_GROUP_DOC = NO
+# Set the SUBGROUPING tag to YES (the default) to allow class member groups of
+# the same type (for instance a group of public functions) to be put as a
+# subgroup of that type (e.g. under the Public Functions section). Set it to
+# NO to prevent subgrouping. Alternatively, this can be done per class using
# the \nosubgrouping command.
SUBGROUPING = YES
+# When the INLINE_GROUPED_CLASSES tag is set to YES, classes, structs and
+# unions are shown inside the group in which they are included (e.g. using
+# @ingroup) instead of on a separate page (for HTML and Man pages) or
+# section (for LaTeX and RTF).
+INLINE_GROUPED_CLASSES = NO
+# When the INLINE_SIMPLE_STRUCTS tag is set to YES, structs, classes, and
+# unions with only public data fields will be shown inline in the documentation
+# of the scope in which they are defined (i.e. file, namespace, or group
+# documentation), provided this scope is documented. If set to NO (the default),
+# structs, classes, and unions are shown on a separate page (for HTML and Man
+# pages) or section (for LaTeX and RTF).
+INLINE_SIMPLE_STRUCTS = NO
+# When TYPEDEF_HIDES_STRUCT is enabled, a typedef of a struct, union, or enum
+# is documented as struct, union, or enum with the name of the typedef. So
+# typedef struct TypeS {} TypeT, will appear in the documentation as a struct
+# with name TypeT. When disabled the typedef will appear as a member of a file,
+# namespace, or class. And the struct will be named TypeS. This can typically
+# be useful for C code in case the coding convention dictates that all compound
+# types are typedef'ed and only the typedef is referenced, never the tag name.
+TYPEDEF_HIDES_STRUCT = NO
+# The SYMBOL_CACHE_SIZE determines the size of the internal cache use to
+# determine which symbols to keep in memory and which to flush to disk.
+# When the cache is full, less often used symbols will be written to disk.
+# For small to medium size projects (<1000 input files) the default value is
+# probably good enough. For larger projects a too small cache size can cause
+# doxygen to be busy swapping symbols to and from disk most of the time
+# causing a significant performance penalty.
+# If the system has enough physical memory increasing the cache will improve the
+# performance by keeping more symbols in memory. Note that the value works on
+# a logarithmic scale so increasing the size by one will roughly double the
+# memory usage. The cache size is given by this formula:
+# 2^(16+SYMBOL_CACHE_SIZE). The valid range is 0..9, the default is 0,
+# corresponding to a cache size of 2^16 = 65536 symbols.
+SYMBOL_CACHE_SIZE = 0
+# Similar to the SYMBOL_CACHE_SIZE the size of the symbol lookup cache can be
+# set using LOOKUP_CACHE_SIZE. This cache is used to resolve symbols given
+# their name and scope. Since this can be an expensive process and often the
+# same symbol appear multiple times in the code, doxygen keeps a cache of
+# pre-resolved symbols. If the cache is too small doxygen will become slower.
+# If the cache is too large, memory is wasted. The cache size is given by this
+# formula: 2^(16+LOOKUP_CACHE_SIZE). The valid range is 0..9, the default is 0,
+LOOKUP_CACHE_SIZE = 0
# Build related configuration options
-# If the EXTRACT_ALL tag is set to YES doxygen will assume all entities in
-# documentation are documented, even if no documentation was available.
-# Private class members and static file members will be hidden unless
+# If the EXTRACT_ALL tag is set to YES doxygen will assume all entities in
+# documentation are documented, even if no documentation was available.
+# Private class members and static file members will be hidden unless
# the EXTRACT_PRIVATE and EXTRACT_STATIC tags are set to YES
EXTRACT_ALL = YES
-# If the EXTRACT_PRIVATE tag is set to YES all private members of a class
+# If the EXTRACT_PRIVATE tag is set to YES all private members of a class
# will be included in the documentation.
EXTRACT_PRIVATE = NO
-# If the EXTRACT_STATIC tag is set to YES all static members of a file
+# If the EXTRACT_PACKAGE tag is set to YES all members with package or internal scope will be included in the documentation.
+EXTRACT_PACKAGE = NO
+# If the EXTRACT_STATIC tag is set to YES all static members of a file
EXTRACT_STATIC = NO
-# If the EXTRACT_LOCAL_CLASSES tag is set to YES classes (and structs)
-# defined locally in source files will be included in the documentation.
+# If the EXTRACT_LOCAL_CLASSES tag is set to YES classes (and structs)
+# defined locally in source files will be included in the documentation.
# If set to NO only classes defined in header files are included.
EXTRACT_LOCAL_CLASSES = YES
-# This flag is only useful for Objective-C code. When set to YES local
-# methods, which are defined in the implementation section but not in
-# the interface are included in the documentation.
+# This flag is only useful for Objective-C code. When set to YES local
+# methods, which are defined in the implementation section but not in
+# the interface are included in the documentation.
# If set to NO (the default) only methods in the interface are included.
EXTRACT_LOCAL_METHODS = NO
-# If the HIDE_UNDOC_MEMBERS tag is set to YES, Doxygen will hide all
-# undocumented members of documented classes, files or namespaces.
-# If set to NO (the default) these members will be included in the
-# various overviews, but no documentation section is generated.
+# If this flag is set to YES, the members of anonymous namespaces will be
+# extracted and appear in the documentation as a namespace called
+# 'anonymous_namespace{file}', where file will be replaced with the base
+# name of the file that contains the anonymous namespace. By default
+# anonymous namespaces are hidden.
+EXTRACT_ANON_NSPACES = NO
+# If the HIDE_UNDOC_MEMBERS tag is set to YES, Doxygen will hide all
+# undocumented members of documented classes, files or namespaces.
+# If set to NO (the default) these members will be included in the
+# various overviews, but no documentation section is generated.
# This option has no effect if EXTRACT_ALL is enabled.
HIDE_UNDOC_MEMBERS = NO
-# If the HIDE_UNDOC_CLASSES tag is set to YES, Doxygen will hide all
-# undocumented classes that are normally visible in the class hierarchy.
-# If set to NO (the default) these classes will be included in the various
+# If the HIDE_UNDOC_CLASSES tag is set to YES, Doxygen will hide all
+# undocumented classes that are normally visible in the class hierarchy.
+# If set to NO (the default) these classes will be included in the various
# overviews. This option has no effect if EXTRACT_ALL is enabled.
HIDE_UNDOC_CLASSES = NO
-# If the HIDE_FRIEND_COMPOUNDS tag is set to YES, Doxygen will hide all
-# friend (class|struct|union) declarations.
-# If set to NO (the default) these declarations will be included in the
+# If the HIDE_FRIEND_COMPOUNDS tag is set to YES, Doxygen will hide all
+# friend (class|struct|union) declarations.
+# If set to NO (the default) these declarations will be included in the
# documentation.
HIDE_FRIEND_COMPOUNDS = NO
-# If the HIDE_IN_BODY_DOCS tag is set to YES, Doxygen will hide any
-# documentation blocks found inside the body of a function.
-# If set to NO (the default) these blocks will be appended to the
+# If the HIDE_IN_BODY_DOCS tag is set to YES, Doxygen will hide any
+# documentation blocks found inside the body of a function.
+# If set to NO (the default) these blocks will be appended to the
# function's detailed documentation block.
HIDE_IN_BODY_DOCS = NO
-# The INTERNAL_DOCS tag determines if documentation
-# that is typed after a \internal command is included. If the tag is set
-# to NO (the default) then the documentation will be excluded.
+# The INTERNAL_DOCS tag determines if documentation
+# that is typed after a \internal command is included. If the tag is set
+# to NO (the default) then the documentation will be excluded.
# Set it to YES to include the internal documentation.
INTERNAL_DOCS = NO
-# If the CASE_SENSE_NAMES tag is set to NO then Doxygen will only generate
-# file names in lower-case letters. If set to YES upper-case letters are also
-# allowed. This is useful if you have classes or files whose names only differ
-# in case and if your file system supports case sensitive file names. Windows
+# If the CASE_SENSE_NAMES tag is set to NO then Doxygen will only generate
+# file names in lower-case letters. If set to YES upper-case letters are also
+# allowed. This is useful if you have classes or files whose names only differ
+# in case and if your file system supports case sensitive file names. Windows
# and Mac users are advised to set this option to NO.
CASE_SENSE_NAMES = YES
-# If the HIDE_SCOPE_NAMES tag is set to NO (the default) then Doxygen
-# will show members with their full class and namespace scopes in the
+# If the HIDE_SCOPE_NAMES tag is set to NO (the default) then Doxygen
+# will show members with their full class and namespace scopes in the
# documentation. If set to YES the scope will be hidden.
HIDE_SCOPE_NAMES = NO
-# If the SHOW_INCLUDE_FILES tag is set to YES (the default) then Doxygen
-# will put a list of the files that are included by a file in the documentation
+# If the SHOW_INCLUDE_FILES tag is set to YES (the default) then Doxygen
+# will put a list of the files that are included by a file in the documentation
# of that file.
SHOW_INCLUDE_FILES = YES
-# If the INLINE_INFO tag is set to YES (the default) then a tag [inline]
+# If the FORCE_LOCAL_INCLUDES tag is set to YES then Doxygen
+# will list include files with double quotes in the documentation
+# rather than with sharp brackets.
+FORCE_LOCAL_INCLUDES = NO
+# If the INLINE_INFO tag is set to YES (the default) then a tag [inline]
# is inserted in the documentation for inline members.
INLINE_INFO = YES
-# If the SORT_MEMBER_DOCS tag is set to YES (the default) then doxygen
-# will sort the (detailed) documentation of file and class members
-# alphabetically by member name. If set to NO the members will appear in
+# If the SORT_MEMBER_DOCS tag is set to YES (the default) then doxygen
+# will sort the (detailed) documentation of file and class members
+# alphabetically by member name. If set to NO the members will appear in
# declaration order.
SORT_MEMBER_DOCS = YES
-# If the SORT_BRIEF_DOCS tag is set to YES then doxygen will sort the
-# brief documentation of file, namespace and class members alphabetically
-# by member name. If set to NO (the default) the members will appear in
+# If the SORT_BRIEF_DOCS tag is set to YES then doxygen will sort the
+# brief documentation of file, namespace and class members alphabetically
+# by member name. If set to NO (the default) the members will appear in
SORT_BRIEF_DOCS = NO
-# If the SORT_BY_SCOPE_NAME tag is set to YES, the class list will be
-# sorted by fully-qualified names, including namespaces. If set to
-# NO (the default), the class list will be sorted only by class name,
-# not including the namespace part.
+# If the SORT_MEMBERS_CTORS_1ST tag is set to YES then doxygen
+# will sort the (brief and detailed) documentation of class members so that
+# constructors and destructors are listed first. If set to NO (the default)
+# the constructors will appear in the respective orders defined by
+# SORT_MEMBER_DOCS and SORT_BRIEF_DOCS.
+# This tag will be ignored for brief docs if SORT_BRIEF_DOCS is set to NO
+# and ignored for detailed docs if SORT_MEMBER_DOCS is set to NO.
+SORT_MEMBERS_CTORS_1ST = NO
+# If the SORT_GROUP_NAMES tag is set to YES then doxygen will sort the
+# hierarchy of group names into alphabetical order. If set to NO (the default)
+# the group names will appear in their defined order.
+SORT_GROUP_NAMES = NO
+# If the SORT_BY_SCOPE_NAME tag is set to YES, the class list will be
+# sorted by fully-qualified names, including namespaces. If set to
+# NO (the default), the class list will be sorted only by class name,
+# not including the namespace part.
# Note: This option is not very useful if HIDE_SCOPE_NAMES is set to YES.
-# Note: This option applies only to the class list, not to the
+# Note: This option applies only to the class list, not to the
# alphabetical list.
SORT_BY_SCOPE_NAME = NO
-# The GENERATE_TODOLIST tag can be used to enable (YES) or
-# disable (NO) the todo list. This list is created by putting \todo
+# If the STRICT_PROTO_MATCHING option is enabled and doxygen fails to
+# do proper type resolution of all parameters of a function it will reject a
+# match between the prototype and the implementation of a member function even
+# if there is only one candidate or it is obvious which candidate to choose
+# by doing a simple string match. By disabling STRICT_PROTO_MATCHING doxygen
+# will still accept a match between prototype and implementation in such cases.
+STRICT_PROTO_MATCHING = NO
+# The GENERATE_TODOLIST tag can be used to enable (YES) or
+# disable (NO) the todo list. This list is created by putting \todo
# commands in the documentation.
GENERATE_TODOLIST = YES
-# The GENERATE_TESTLIST tag can be used to enable (YES) or
-# disable (NO) the test list. This list is created by putting \test
+# The GENERATE_TESTLIST tag can be used to enable (YES) or
+# disable (NO) the test list. This list is created by putting \test
GENERATE_TESTLIST = YES
-# The GENERATE_BUGLIST tag can be used to enable (YES) or
-# disable (NO) the bug list. This list is created by putting \bug
+# The GENERATE_BUGLIST tag can be used to enable (YES) or
+# disable (NO) the bug list. This list is created by putting \bug
GENERATE_BUGLIST = YES
-# The GENERATE_DEPRECATEDLIST tag can be used to enable (YES) or
-# disable (NO) the deprecated list. This list is created by putting
+# The GENERATE_DEPRECATEDLIST tag can be used to enable (YES) or
+# disable (NO) the deprecated list. This list is created by putting
# \deprecated commands in the documentation.
GENERATE_DEPRECATEDLIST= YES
-# The ENABLED_SECTIONS tag can be used to enable conditional
+# The ENABLED_SECTIONS tag can be used to enable conditional
# documentation sections, marked by \if sectionname ... \endif.
-ENABLED_SECTIONS =
+ENABLED_SECTIONS =
-# The MAX_INITIALIZER_LINES tag determines the maximum number of lines
-# the initial value of a variable or define consists of for it to appear in
-# the documentation. If the initializer consists of more lines than specified
-# here it will be hidden. Use a value of 0 to hide initializers completely.
-# The appearance of the initializer of individual variables and defines in the
-# documentation can be controlled using \showinitializer or \hideinitializer
+# The MAX_INITIALIZER_LINES tag determines the maximum number of lines
+# the initial value of a variable or macro consists of for it to appear in
+# the documentation. If the initializer consists of more lines than specified
+# here it will be hidden. Use a value of 0 to hide initializers completely.
+# The appearance of the initializer of individual variables and macros in the
+# documentation can be controlled using \showinitializer or \hideinitializer
# command in the documentation regardless of this setting.
MAX_INITIALIZER_LINES = 30
-# Set the SHOW_USED_FILES tag to NO to disable the list of files generated
-# at the bottom of the documentation of classes and structs. If set to YES the
+# Set the SHOW_USED_FILES tag to NO to disable the list of files generated
+# at the bottom of the documentation of classes and structs. If set to YES the
# list will mention the files that were used to generate the documentation.
SHOW_USED_FILES = YES
-# If the sources in your project are distributed over multiple directories
-# then setting the SHOW_DIRECTORIES tag to YES will show the directory hierarchy
-# in the documentation.
+# Set the SHOW_FILES tag to NO to disable the generation of the Files page.
+# This will remove the Files entry from the Quick Index and from the
+# Folder Tree View (if specified). The default is YES.
-SHOW_DIRECTORIES = YES
+SHOW_FILES = YES
+# Set the SHOW_NAMESPACES tag to NO to disable the generation of the
+# Namespaces page.
+# This will remove the Namespaces entry from the Quick Index
+# and from the Folder Tree View (if specified). The default is YES.
+SHOW_NAMESPACES = YES
+# The FILE_VERSION_FILTER tag can be used to specify a program or script that
+# doxygen should invoke to get the current version for each file (typically from
+# the version control system). Doxygen will invoke the program by executing (via
+# popen()) the command <command> <input-file>, where <command> is the value of
+# the FILE_VERSION_FILTER tag, and <input-file> is the name of an input file
+# provided by doxygen. Whatever the program writes to standard output
+# is used as the file version. See the manual for examples.
+FILE_VERSION_FILTER =
+# The LAYOUT_FILE tag can be used to specify a layout file which will be parsed
+# by doxygen. The layout file controls the global structure of the generated
+# output files in an output format independent way. The create the layout file
+# that represents doxygen's defaults, run doxygen with the -l option.
+# You can optionally specify a file name after the option, if omitted
+# DoxygenLayout.xml will be used as the name of the layout file.
+LAYOUT_FILE =
+# The CITE_BIB_FILES tag can be used to specify one or more bib files
+# containing the references data. This must be a list of .bib files. The
+# .bib extension is automatically appended if omitted. Using this command
+# requires the bibtex tool to be installed. See also
+# http://en.wikipedia.org/wiki/BibTeX for more info. For LaTeX the style
+# of the bibliography can be controlled using LATEX_BIB_STYLE. To use this
+# feature you need bibtex and perl available in the search path.
+CITE_BIB_FILES =
# configuration options related to warning and progress messages
-# The QUIET tag can be used to turn on/off the messages that are generated
+# The QUIET tag can be used to turn on/off the messages that are generated
# by doxygen. Possible values are YES and NO. If left blank NO is used.
QUIET = NO
-# The WARNINGS tag can be used to turn on/off the warning messages that are
-# generated by doxygen. Possible values are YES and NO. If left blank
+# The WARNINGS tag can be used to turn on/off the warning messages that are
+# generated by doxygen. Possible values are YES and NO. If left blank
# NO is used.
WARNINGS = YES
-# If WARN_IF_UNDOCUMENTED is set to YES, then doxygen will generate warnings
-# for undocumented members. If EXTRACT_ALL is set to YES then this flag will
+# If WARN_IF_UNDOCUMENTED is set to YES, then doxygen will generate warnings
+# for undocumented members. If EXTRACT_ALL is set to YES then this flag will
# automatically be disabled.
WARN_IF_UNDOCUMENTED = YES
-# If WARN_IF_DOC_ERROR is set to YES, doxygen will generate warnings for
-# potential errors in the documentation, such as not documenting some
-# parameters in a documented function, or documenting parameters that
+# If WARN_IF_DOC_ERROR is set to YES, doxygen will generate warnings for
+# potential errors in the documentation, such as not documenting some
+# parameters in a documented function, or documenting parameters that
# don't exist or using markup commands wrongly.
WARN_IF_DOC_ERROR = YES
-# The WARN_FORMAT tag determines the format of the warning messages that
-# doxygen can produce. The string should contain the $file, $line, and $text
-# tags, which will be replaced by the file and line number from which the
-# warning originated and the warning text.
+# The WARN_NO_PARAMDOC option can be enabled to get warnings for
+# functions that are documented, but have no documentation for their parameters
+# or return value. If set to NO (the default) doxygen will only warn about
+# wrong or incomplete parameter documentation, but not about the absence of
+# documentation.
+WARN_NO_PARAMDOC = NO
+# The WARN_FORMAT tag determines the format of the warning messages that
+# doxygen can produce. The string should contain the $file, $line, and $text
+# tags, which will be replaced by the file and line number from which the
+# warning originated and the warning text. Optionally the format may contain
+# $version, which will be replaced by the version of the file (if it could
+# be obtained via FILE_VERSION_FILTER)
WARN_FORMAT = "$file:$line: $text"
-# The WARN_LOGFILE tag can be used to specify a file to which warning
-# and error messages should be written. If left blank the output is written
+# The WARN_LOGFILE tag can be used to specify a file to which warning
+# and error messages should be written. If left blank the output is written
# to stderr.
-WARN_LOGFILE =
+WARN_LOGFILE =
# configuration options related to the input files
-# The INPUT tag can be used to specify the files and/or directories that contain
-# documented source files. You may enter file names like "myfile.cpp" or
-# directories like "/usr/src/myproject". Separate the files or directories
+# The INPUT tag can be used to specify the files and/or directories that contain
+# documented source files. You may enter file names like "myfile.cpp" or
+# directories like "/usr/src/myproject". Separate the files or directories
# with spaces.
INPUT = .
-# If the value of the INPUT tag contains directories, you can use the
-# FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
-# and *.h) to filter out the source-files in the directories. If left
-# blank the following patterns are tested:
-# *.c *.cc *.cxx *.cpp *.c++ *.java *.ii *.ixx *.ipp *.i++ *.inl *.h *.hh *.hxx *.hpp
-# *.h++ *.idl *.odl *.cs *.php *.php3 *.inc *.m *.mm
+# This tag can be used to specify the character encoding of the source files
+# that doxygen parses. Internally doxygen uses the UTF-8 encoding, which is
+# also the default input encoding. Doxygen uses libiconv (or the iconv built
+# into libc) for the transcoding. See http://www.gnu.org/software/libiconv for
+# the list of possible encodings.
+INPUT_ENCODING = UTF-8
+# If the value of the INPUT tag contains directories, you can use the
+# FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
+# and *.h) to filter out the source-files in the directories. If left
+# blank the following patterns are tested:
+# *.c *.cc *.cxx *.cpp *.c++ *.d *.java *.ii *.ixx *.ipp *.i++ *.inl *.h *.hh
+# *.hxx *.hpp *.h++ *.idl *.odl *.cs *.php *.php3 *.inc *.m *.mm *.dox *.py
+# *.f90 *.f *.for *.vhd *.vhdl
FILE_PATTERNS = *.h \
*.c \
- *.i \
+ *.i \
*.py \
*.dox
-# The RECURSIVE tag can be used to turn specify whether or not subdirectories
-# should be searched for input files as well. Possible values are YES and NO.
+# The RECURSIVE tag can be used to turn specify whether or not subdirectories
+# should be searched for input files as well. Possible values are YES and NO.
# If left blank NO is used.
RECURSIVE = YES
-# The EXCLUDE tag can be used to specify files and/or directories that should
-# excluded from the INPUT source files. This way you can easily exclude a
+# The EXCLUDE tag can be used to specify files and/or directories that should be
+# excluded from the INPUT source files. This way you can easily exclude a
# subdirectory from a directory tree whose root is specified with the INPUT tag.
+# Note that relative paths are relative to the directory from which doxygen is
+# run.
EXCLUDE = bin. at ARCH@ \
- db \
- debian \
- demolocation \
- display \
- dist. at ARCH@ \
- doc \
- general \
- gui/scripts \
- gui/wxpython/compat \
- gui/wxpython/icons \
- gui/wxpython/scripts \
- gui/wxpython/tools \
- imagery \
- include/defs \
- lib/btree/test \
- lib/db/dbmi_base/test \
- lib/db/sqlp/test \
- lib/gmath/test \
- lib/gpde/test \
- lib/linkm/test \
- lib/raster3d/test \
+ db \
+ debian \
+ demolocation \
+ display \
+ dist. at ARCH@ \
+ doc \
+ general \
+ gui/scripts \
+ gui/wxpython/compat \
+ gui/wxpython/icons \
+ gui/wxpython/scripts \
+ gui/wxpython/tools \
+ imagery \
+ include/defs \
+ lib/btree/test \
+ lib/db/dbmi_base/test \
+ lib/db/sqlp/test \
+ lib/gmath/test \
+ lib/gpde/test \
+ lib/linkm/test \
+ lib/raster3d/test \
lib/python/ctypes \
- lib/vector/dglib/examples \
- lib/vector/rtree/docs \
- locale \
- macosx \
- man \
- misc \
- mswindows \
- ps \
- raster \
- raster3d \
- rpm \
- scripts \
- sites \
- temporal \
- testsuite \
- tools \
- vector \
- visualization
+ lib/vector/dglib/examples \
+ lib/vector/rtree/docs \
+ locale \
+ macosx \
+ man \
+ misc \
+ mswindows \
+ ps \
+ raster \
+ raster3d \
+ rpm \
+ scripts \
+ sites \
+ temporal \
+ testsuite \
+ tools \
+ vector \
+ visualization
-# The EXCLUDE_SYMLINKS tag can be used select whether or not files or directories
-# that are symbolic links (a Unix filesystem feature) are excluded from the input.
+# The EXCLUDE_SYMLINKS tag can be used to select whether or not files or
+# directories that are symbolic links (a Unix file system feature) are excluded
+# from the input.
EXCLUDE_SYMLINKS = NO
-# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
-# certain files from those directories.
+# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
+# certain files from those directories. Note that the wildcards are matched
+# against the file with absolute path, so to exclude all test directories
+# for example use the pattern */test/*
-EXCLUDE_PATTERNS =
+EXCLUDE_PATTERNS =
-# The EXAMPLE_PATH tag can be used to specify one or more files or
-# directories that contain example code fragments that are included (see
+# The EXCLUDE_SYMBOLS tag can be used to specify one or more symbol names
+# (namespaces, classes, functions, etc.) that should be excluded from the
+# output. The symbol name can be a fully qualified name, a word, or if the
+# wildcard * is used, a substring. Examples: ANamespace, AClass,
+# AClass::ANamespace, ANamespace::*Test
+EXCLUDE_SYMBOLS =
+# The EXAMPLE_PATH tag can be used to specify one or more files or
+# directories that contain example code fragments that are included (see
# the \include command).
-EXAMPLE_PATH =
+EXAMPLE_PATH =
-# If the value of the EXAMPLE_PATH tag contains directories, you can use the
-# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
+# If the value of the EXAMPLE_PATH tag contains directories, you can use the
+# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
# blank all files are included.
-EXAMPLE_PATTERNS =
+EXAMPLE_PATTERNS =
-# If the EXAMPLE_RECURSIVE tag is set to YES then subdirectories will be
-# searched for input files to be used with the \include or \dontinclude
-# commands irrespective of the value of the RECURSIVE tag.
+# If the EXAMPLE_RECURSIVE tag is set to YES then subdirectories will be
+# searched for input files to be used with the \include or \dontinclude
+# commands irrespective of the value of the RECURSIVE tag.
# Possible values are YES and NO. If left blank NO is used.
EXAMPLE_RECURSIVE = NO
-# The IMAGE_PATH tag can be used to specify one or more files or
-# directories that contain image that are included in the documentation (see
+# The IMAGE_PATH tag can be used to specify one or more files or
+# directories that contain image that are included in the documentation (see
# the \image command).
IMAGE_PATH = .
-# The INPUT_FILTER tag can be used to specify a program that doxygen should
-# invoke to filter for each input file. Doxygen will invoke the filter program
-# by executing (via popen()) the command <filter> <input-file>, where <filter>
-# is the value of the INPUT_FILTER tag, and <input-file> is the name of an
-# input file. Doxygen will then use the output that the filter program writes
-# to standard output. If FILTER_PATTERNS is specified, this tag will be
+# The INPUT_FILTER tag can be used to specify a program that doxygen should
+# invoke to filter for each input file. Doxygen will invoke the filter program
+# by executing (via popen()) the command <filter> <input-file>, where <filter>
+# is the value of the INPUT_FILTER tag, and <input-file> is the name of an
+# input file. Doxygen will then use the output that the filter program writes
+# to standard output.
+# If FILTER_PATTERNS is specified, this tag will be
# ignored.
-INPUT_FILTER =
+INPUT_FILTER =
-# The FILTER_PATTERNS tag can be used to specify filters on a per file pattern
-# basis. Doxygen will compare the file name with each pattern and apply the
-# filter if there is a match. The filters are a list of the form:
-# pattern=filter (like *.cpp=my_cpp_filter). See INPUT_FILTER for further
-# info on how filters are used. If FILTER_PATTERNS is empty, INPUT_FILTER
-# is applied to all files.
+# The FILTER_PATTERNS tag can be used to specify filters on a per file pattern
+# basis.
+# Doxygen will compare the file name with each pattern and apply the
+# filter if there is a match.
+# The filters are a list of the form:
+# pattern=filter (like *.cpp=my_cpp_filter). See INPUT_FILTER for further
+# info on how filters are used. If FILTER_PATTERNS is empty or if
+# non of the patterns match the file name, INPUT_FILTER is applied.
-FILTER_PATTERNS =
+FILTER_PATTERNS =
-# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
-# INPUT_FILTER) will be used to filter the input files when producing source
+# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
+# INPUT_FILTER) will be used to filter the input files when producing source
# files to browse (i.e. when SOURCE_BROWSER is set to YES).
FILTER_SOURCE_FILES = NO
+# The FILTER_SOURCE_PATTERNS tag can be used to specify source filters per file
+# pattern. A pattern will override the setting for FILTER_PATTERN (if any)
+# and it is also possible to disable source filtering for a specific pattern
+# using *.ext= (so without naming a filter). This option only has effect when
+# FILTER_SOURCE_FILES is enabled.
+FILTER_SOURCE_PATTERNS =
# configuration options related to source browsing
-# If the SOURCE_BROWSER tag is set to YES then a list of source files will
-# be generated. Documented entities will be cross-referenced with these sources.
-# Note: To get rid of all source code in the generated output, make sure also
+# If the SOURCE_BROWSER tag is set to YES then a list of source files will
+# be generated. Documented entities will be cross-referenced with these sources.
+# Note: To get rid of all source code in the generated output, make sure also
# VERBATIM_HEADERS is set to NO.
SOURCE_BROWSER = YES
-# Setting the INLINE_SOURCES tag to YES will include the body
+# Setting the INLINE_SOURCES tag to YES will include the body
# of functions and classes directly in the documentation.
INLINE_SOURCES = NO
-# Setting the STRIP_CODE_COMMENTS tag to YES (the default) will instruct
-# doxygen to hide any special comment blocks from generated source code
+# Setting the STRIP_CODE_COMMENTS tag to YES (the default) will instruct
+# doxygen to hide any special comment blocks from generated source code
# fragments. Normal C and C++ comments will always remain visible.
STRIP_CODE_COMMENTS = YES
-# If the REFERENCED_BY_RELATION tag is set to YES (the default)
-# then for each documented function all documented
+# If the REFERENCED_BY_RELATION tag is set to YES
+# then for each documented function all documented
# functions referencing it will be listed.
REFERENCED_BY_RELATION = YES
-# If the REFERENCES_RELATION tag is set to YES (the default)
-# then for each documented function all documented entities
+# If the REFERENCES_RELATION tag is set to YES
+# then for each documented function all documented entities
# called/used by that function will be listed.
REFERENCES_RELATION = YES
-# If the VERBATIM_HEADERS tag is set to YES (the default) then Doxygen
-# will generate a verbatim copy of the header file for each class for
+# If the REFERENCES_LINK_SOURCE tag is set to YES (the default)
+# and SOURCE_BROWSER tag is set to YES, then the hyperlinks from
+# functions in REFERENCES_RELATION and REFERENCED_BY_RELATION lists will
+# link to the source code.
+# Otherwise they will link to the documentation.
+REFERENCES_LINK_SOURCE = YES
+# If the USE_HTAGS tag is set to YES then the references to source code
+# will point to the HTML generated by the htags(1) tool instead of doxygen
+# built-in source browser. The htags tool is part of GNU's global source
+# tagging system (see http://www.gnu.org/software/global/global.html). You
+# will need version 4.8.6 or higher.
+USE_HTAGS = NO
+# If the VERBATIM_HEADERS tag is set to YES (the default) then Doxygen
+# will generate a verbatim copy of the header file for each class for
# which an include is specified. Set to NO to disable this.
VERBATIM_HEADERS = YES
@@ -596,279 +877,547 @@
# configuration options related to the alphabetical class index
-# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index
-# of all compounds will be generated. Enable this if the project
+# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index
+# of all compounds will be generated. Enable this if the project
# contains a lot of classes, structs, unions or interfaces.
ALPHABETICAL_INDEX = NO
-# If the alphabetical index is enabled (see ALPHABETICAL_INDEX) then
-# the COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns
+# If the alphabetical index is enabled (see ALPHABETICAL_INDEX) then
+# the COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns
# in which this list will be split (can be a number in the range [1..20])
COLS_IN_ALPHA_INDEX = 5
-# In case all classes in a project start with a common prefix, all
-# classes will be put under the same header in the alphabetical index.
-# The IGNORE_PREFIX tag can be used to specify one or more prefixes that
+# In case all classes in a project start with a common prefix, all
+# classes will be put under the same header in the alphabetical index.
+# The IGNORE_PREFIX tag can be used to specify one or more prefixes that
# should be ignored while generating the index headers.
-IGNORE_PREFIX =
+IGNORE_PREFIX =
# configuration options related to the HTML output
-# If the GENERATE_HTML tag is set to YES (the default) Doxygen will
+# If the GENERATE_HTML tag is set to YES (the default) Doxygen will
# generate HTML output.
GENERATE_HTML = YES
-# The HTML_OUTPUT tag is used to specify where the HTML docs will be put.
-# If a relative path is entered the value of OUTPUT_DIRECTORY will be
+# The HTML_OUTPUT tag is used to specify where the HTML docs will be put.
+# If a relative path is entered the value of OUTPUT_DIRECTORY will be
# put in front of it. If left blank `html' will be used as the default path.
-HTML_OUTPUT =
+HTML_OUTPUT =
-# The HTML_FILE_EXTENSION tag can be used to specify the file extension for
-# each generated HTML page (for example: .htm,.php,.asp). If it is left blank
+# The HTML_FILE_EXTENSION tag can be used to specify the file extension for
+# each generated HTML page (for example: .htm,.php,.asp). If it is left blank
# doxygen will generate files with .html extension.
HTML_FILE_EXTENSION =
-# The HTML_HEADER tag can be used to specify a personal HTML header for
-# each generated HTML page. If it is left blank doxygen will generate a
-# standard header.
+# The HTML_HEADER tag can be used to specify a personal HTML header for
+# each generated HTML page. If it is left blank doxygen will generate a
+# standard header. Note that when using a custom header you are responsible
+# for the proper inclusion of any scripts and style sheets that doxygen
+# needs, which is dependent on the configuration options used.
+# It is advised to generate a default header using "doxygen -w html
+# header.html footer.html stylesheet.css YourConfigFile" and then modify
+# that header. Note that the header is subject to change so you typically
+# have to redo this when upgrading to a newer version of doxygen or when
+# changing the value of configuration settings such as GENERATE_TREEVIEW!
-HTML_HEADER =
+HTML_HEADER =
-# The HTML_FOOTER tag can be used to specify a personal HTML footer for
+# The HTML_FOOTER tag can be used to specify a personal HTML footer for
# standard footer.
-HTML_FOOTER =
+HTML_FOOTER =
-# The HTML_STYLESHEET tag can be used to specify a user-defined cascading
-# style sheet that is used by each HTML page. It can be used to
-# fine-tune the look of the HTML output. If the tag is left blank doxygen
-# will generate a default style sheet. Note that doxygen will try to copy
-# the style sheet file to the HTML output directory, so don't put your own
-# stylesheet in the HTML output directory as well, or it will be erased!
+# The HTML_STYLESHEET tag can be used to specify a user-defined cascading
+# style sheet that is used by each HTML page. It can be used to
+# fine-tune the look of the HTML output. If the tag is left blank doxygen
+# will generate a default style sheet. Note that doxygen will try to copy
+# the style sheet file to the HTML output directory, so don't put your own
+# style sheet in the HTML output directory as well, or it will be erased!
-HTML_STYLESHEET =
+HTML_STYLESHEET =
-# If the HTML_ALIGN_MEMBERS tag is set to YES, the members of classes,
-# files or namespaces will be aligned in HTML using tables. If set to
-# NO a bullet list will be used.
+# The HTML_EXTRA_FILES tag can be used to specify one or more extra images or
+# other source files which should be copied to the HTML output directory. Note
+# that these files will be copied to the base HTML output directory. Use the
+# $relpath$ marker in the HTML_HEADER and/or HTML_FOOTER files to load these
+# files. In the HTML_STYLESHEET file, use the file name only. Also note that
+# the files will be copied as-is; there are no commands or markers available.
-HTML_ALIGN_MEMBERS = YES
+HTML_EXTRA_FILES =
-# If the GENERATE_HTMLHELP tag is set to YES, additional index files
-# will be generated that can be used as input for tools like the
-# Microsoft HTML help workshop to generate a compressed HTML help file (.chm)
+# The HTML_COLORSTYLE_HUE tag controls the color of the HTML output.
+# Doxygen will adjust the colors in the style sheet and background images
+# according to this color. Hue is specified as an angle on a colorwheel,
+# see http://en.wikipedia.org/wiki/Hue for more information.
+# For instance the value 0 represents red, 60 is yellow, 120 is green,
+# 180 is cyan, 240 is blue, 300 purple, and 360 is red again.
+# The allowed range is 0 to 359.
+HTML_COLORSTYLE_HUE = 220
+# The HTML_COLORSTYLE_SAT tag controls the purity (or saturation) of
+# the colors in the HTML output. For a value of 0 the output will use
+# grayscales only. A value of 255 will produce the most vivid colors.
+HTML_COLORSTYLE_SAT = 100
+# The HTML_COLORSTYLE_GAMMA tag controls the gamma correction applied to
+# the luminance component of the colors in the HTML output. Values below
+# 100 gradually make the output lighter, whereas values above 100 make
+# the output darker. The value divided by 100 is the actual gamma applied,
+# so 80 represents a gamma of 0.8, The value 220 represents a gamma of 2.2,
+# and 100 does not change the gamma.
+HTML_COLORSTYLE_GAMMA = 80
+# If the HTML_TIMESTAMP tag is set to YES then the footer of each generated HTML
+# page will contain the date and time when the page was generated. Setting
+# this to NO can help when comparing the output of multiple runs.
+HTML_TIMESTAMP = YES
+# If the HTML_DYNAMIC_SECTIONS tag is set to YES then the generated HTML
+# documentation will contain sections that can be hidden and shown after the
+# page has loaded.
+HTML_DYNAMIC_SECTIONS = NO
+# With HTML_INDEX_NUM_ENTRIES one can control the preferred number of
+# entries shown in the various tree structured indices initially; the user
+# can expand and collapse entries dynamically later on. Doxygen will expand
+# the tree to such a level that at most the specified number of entries are
+# visible (unless a fully collapsed tree already exceeds this amount).
+# So setting the number of entries 1 will produce a full collapsed tree by
+# default. 0 is a special value representing an infinite number of entries
+# and will result in a full expanded tree by default.
+HTML_INDEX_NUM_ENTRIES = 100
+# If the GENERATE_DOCSET tag is set to YES, additional index files
+# will be generated that can be used as input for Apple's Xcode 3
+# integrated development environment, introduced with OSX 10.5 (Leopard).
+# To create a documentation set, doxygen will generate a Makefile in the
+# HTML output directory. Running make will produce the docset in that
+# directory and running "make install" will install the docset in
+# ~/Library/Developer/Shared/Documentation/DocSets so that Xcode will find
+# it at startup.
+# See http://developer.apple.com/tools/creatingdocsetswithdoxygen.html
+# for more information.
+GENERATE_DOCSET = NO
+# When GENERATE_DOCSET tag is set to YES, this tag determines the name of the
+# feed. A documentation feed provides an umbrella under which multiple
+# documentation sets from a single provider (such as a company or product suite)
+# can be grouped.
+DOCSET_FEEDNAME = "Doxygen generated docs"
+# When GENERATE_DOCSET tag is set to YES, this tag specifies a string that
+# should uniquely identify the documentation set bundle. This should be a
+# reverse domain-name style string, e.g. com.mycompany.MyDocSet. Doxygen
+# will append .docset to the name.
+DOCSET_BUNDLE_ID = org.doxygen.Project
+# When GENERATE_PUBLISHER_ID tag specifies a string that should uniquely identify
+# the documentation publisher. This should be a reverse domain-name style
+# string, e.g. com.mycompany.MyDocSet.documentation.
+DOCSET_PUBLISHER_ID = org.doxygen.Publisher
+# The GENERATE_PUBLISHER_NAME tag identifies the documentation publisher.
+DOCSET_PUBLISHER_NAME = Publisher
+# If the GENERATE_HTMLHELP tag is set to YES, additional index files
+# will be generated that can be used as input for tools like the
+# Microsoft HTML help workshop to generate a compiled HTML help file (.chm)
# of the generated HTML documentation.
GENERATE_HTMLHELP = NO
-# If the GENERATE_HTMLHELP tag is set to YES, the CHM_FILE tag can
-# be used to specify the file name of the resulting .chm file. You
-# can add a path in front of the file if the result should not be
+# If the GENERATE_HTMLHELP tag is set to YES, the CHM_FILE tag can
+# be used to specify the file name of the resulting .chm file. You
+# can add a path in front of the file if the result should not be
# written to the html output directory.
-CHM_FILE =
+CHM_FILE =
-# If the GENERATE_HTMLHELP tag is set to YES, the HHC_LOCATION tag can
-# be used to specify the location (absolute path including file name) of
-# the HTML help compiler (hhc.exe). If non-empty doxygen will try to run
+# If the GENERATE_HTMLHELP tag is set to YES, the HHC_LOCATION tag can
+# be used to specify the location (absolute path including file name) of
+# the HTML help compiler (hhc.exe). If non-empty doxygen will try to run
# the HTML help compiler on the generated index.hhp.
-HHC_LOCATION =
+HHC_LOCATION =
-# If the GENERATE_HTMLHELP tag is set to YES, the GENERATE_CHI flag
-# controls if a separate .chi index file is generated (YES) or that
+# If the GENERATE_HTMLHELP tag is set to YES, the GENERATE_CHI flag
+# controls if a separate .chi index file is generated (YES) or that
# it should be included in the master .chm file (NO).
GENERATE_CHI = NO
-# If the GENERATE_HTMLHELP tag is set to YES, the BINARY_TOC flag
-# controls whether a binary table of contents is generated (YES) or a
+# If the GENERATE_HTMLHELP tag is set to YES, the CHM_INDEX_ENCODING
+# is used to encode HtmlHelp index (hhk), content (hhc) and project file
+# content.
+CHM_INDEX_ENCODING =
+# If the GENERATE_HTMLHELP tag is set to YES, the BINARY_TOC flag
+# controls whether a binary table of contents is generated (YES) or a
# normal table of contents (NO) in the .chm file.
BINARY_TOC = NO
-# The TOC_EXPAND flag can be set to YES to add extra items for group members
+# The TOC_EXPAND flag can be set to YES to add extra items for group members
# to the contents of the HTML help documentation and to the tree view.
TOC_EXPAND = NO
-# The DISABLE_INDEX tag can be used to turn on/off the condensed index at
-# top of each HTML page. The value NO (the default) enables the index and
-# the value YES disables it.
+# If the GENERATE_QHP tag is set to YES and both QHP_NAMESPACE and
+# QHP_VIRTUAL_FOLDER are set, an additional index file will be generated
+# that can be used as input for Qt's qhelpgenerator to generate a
+# Qt Compressed Help (.qch) of the generated HTML documentation.
-DISABLE_INDEX = NO
+GENERATE_QHP = NO
-# This tag can be used to set the number of enum values (range [1..20])
-# that doxygen will group on one line in the generated HTML documentation.
+# If the QHG_LOCATION tag is specified, the QCH_FILE tag can
+# be used to specify the file name of the resulting .qch file.
+# The path specified is relative to the HTML output folder.
-ENUM_VALUES_PER_LINE = 4
+QCH_FILE =
-# If the GENERATE_TREEVIEW tag is set to YES, a side panel will be
-# generated containing a tree-like index structure (just like the one that
-# is generated for HTML Help). For this to work a browser that supports
-# JavaScript, DHTML, CSS and frames is required (for instance Mozilla 1.0+,
-# Netscape 6.0+, Internet explorer 5.0+, or Konqueror). Windows users are
-# probably better off using the HTML help feature.
+# The QHP_NAMESPACE tag specifies the namespace to use when generating
+# Qt Help Project output. For more information please see
+# http://doc.trolltech.com/qthelpproject.html#namespace
+QHP_NAMESPACE = org.doxygen.Project
+# The QHP_VIRTUAL_FOLDER tag specifies the namespace to use when generating
+# http://doc.trolltech.com/qthelpproject.html#virtual-folders
+QHP_VIRTUAL_FOLDER = doc
+# If QHP_CUST_FILTER_NAME is set, it specifies the name of a custom filter to
+# add. For more information please see
+# http://doc.trolltech.com/qthelpproject.html#custom-filters
+QHP_CUST_FILTER_NAME =
+# The QHP_CUST_FILT_ATTRS tag specifies the list of the attributes of the
+# custom filter to add. For more information please see
+# <a href="http://doc.trolltech.com/qthelpproject.html#custom-filters">
+# Qt Help Project / Custom Filters</a>.
+QHP_CUST_FILTER_ATTRS =
+# The QHP_SECT_FILTER_ATTRS tag specifies the list of the attributes this
+# project's
+# filter section matches.
+# <a href="http://doc.trolltech.com/qthelpproject.html#filter-attributes">
+# Qt Help Project / Filter Attributes</a>.
+QHP_SECT_FILTER_ATTRS =
+# If the GENERATE_QHP tag is set to YES, the QHG_LOCATION tag can
+# be used to specify the location of Qt's qhelpgenerator.
+# If non-empty doxygen will try to run qhelpgenerator on the generated
+# .qhp file.
+QHG_LOCATION =
+# If the GENERATE_ECLIPSEHELP tag is set to YES, additional index files
+# will be generated, which together with the HTML files, form an Eclipse help
+# plugin. To install this plugin and make it available under the help contents
+# menu in Eclipse, the contents of the directory containing the HTML and XML
+# files needs to be copied into the plugins directory of eclipse. The name of
+# the directory within the plugins directory should be the same as
+# the ECLIPSE_DOC_ID value. After copying Eclipse needs to be restarted before
+# the help appears.
+GENERATE_ECLIPSEHELP = NO
+# A unique identifier for the eclipse help plugin. When installing the plugin
+# the directory name containing the HTML and XML files should also have
+# this name.
+ECLIPSE_DOC_ID = org.doxygen.Project
+# The DISABLE_INDEX tag can be used to turn on/off the condensed index (tabs)
+# at top of each HTML page. The value NO (the default) enables the index and
+# the value YES disables it. Since the tabs have the same information as the
+# navigation tree you can set this option to NO if you already set
+# GENERATE_TREEVIEW to YES.
+DISABLE_INDEX = NO
+# The GENERATE_TREEVIEW tag is used to specify whether a tree-like index
+# structure should be generated to display hierarchical information.
+# If the tag value is set to YES, a side panel will be generated
+# containing a tree-like index structure (just like the one that
+# is generated for HTML Help). For this to work a browser that supports
+# JavaScript, DHTML, CSS and frames is required (i.e. any modern browser).
+# Windows users are probably better off using the HTML help feature.
+# Since the tree basically has the same information as the tab index you
+# could consider to set DISABLE_INDEX to NO when enabling this option.
GENERATE_TREEVIEW = NO
-# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
-# used to set the initial width (in pixels) of the frame in which the tree
+# The ENUM_VALUES_PER_LINE tag can be used to set the number of enum values
+# (range [0,1..20]) that doxygen will group on one line in the generated HTML
+# documentation. Note that a value of 0 will completely suppress the enum
+# values from appearing in the overview section.
+ENUM_VALUES_PER_LINE = 4
+# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
+# used to set the initial width (in pixels) of the frame in which the tree
# is shown.
TREEVIEW_WIDTH = 250
+# When the EXT_LINKS_IN_WINDOW option is set to YES doxygen will open
+# links to external symbols imported via tag files in a separate window.
+EXT_LINKS_IN_WINDOW = NO
+# Use this tag to change the font size of Latex formulas included
+# as images in the HTML documentation. The default is 10. Note that
+# when you change the font size after a successful doxygen run you need
+# to manually remove any form_*.png images from the HTML output directory
+# to force them to be regenerated.
+FORMULA_FONTSIZE = 10
+# Use the FORMULA_TRANPARENT tag to determine whether or not the images
+# generated for formulas are transparent PNGs. Transparent PNGs are
+# not supported properly for IE 6.0, but are supported on all modern browsers.
+# Note that when changing this option you need to delete any form_*.png files
+# in the HTML output before the changes have effect.
+FORMULA_TRANSPARENT = YES
+# Enable the USE_MATHJAX option to render LaTeX formulas using MathJax
+# (see http://www.mathjax.org) which uses client side Javascript for the
+# rendering instead of using prerendered bitmaps. Use this if you do not
+# have LaTeX installed or if you want to formulas look prettier in the HTML
+# output. When enabled you may also need to install MathJax separately and
+# configure the path to it using the MATHJAX_RELPATH option.
+USE_MATHJAX = NO
+# When MathJax is enabled you need to specify the location relative to the
+# HTML output directory using the MATHJAX_RELPATH option. The destination
+# directory should contain the MathJax.js script. For instance, if the mathjax
+# directory is located at the same level as the HTML output directory, then
+# MATHJAX_RELPATH should be ../mathjax. The default value points to
+# the MathJax Content Delivery Network so you can quickly see the result without
+# installing MathJax.
+# However, it is strongly recommended to install a local
+# copy of MathJax from http://www.mathjax.org before deployment.
+MATHJAX_RELPATH = http://cdn.mathjax.org/mathjax/latest
+# The MATHJAX_EXTENSIONS tag can be used to specify one or MathJax extension
+# names that should be enabled during MathJax rendering.
+MATHJAX_EXTENSIONS =
+# When the SEARCHENGINE tag is enabled doxygen will generate a search box
+# for the HTML output. The underlying search engine uses javascript
+# and DHTML and should work on any modern browser. Note that when using
+# HTML help (GENERATE_HTMLHELP), Qt help (GENERATE_QHP), or docsets
+# (GENERATE_DOCSET) there is already a search function so this one should
+# typically be disabled. For large projects the javascript based search engine
+# can be slow, then enabling SERVER_BASED_SEARCH may provide a better solution.
+SEARCHENGINE = NO
+# When the SERVER_BASED_SEARCH tag is enabled the search engine will be
+# implemented using a PHP enabled web server instead of at the web client
+# using Javascript. Doxygen will generate the search PHP script and index
+# file to put on the web server. The advantage of the server
+# based approach is that it scales better to large projects and allows
+# full text search. The disadvantages are that it is more difficult to setup
+# and does not have live searching capabilities.
+SERVER_BASED_SEARCH = NO
# configuration options related to the LaTeX output
-# If the GENERATE_LATEX tag is set to YES (the default) Doxygen will
+# If the GENERATE_LATEX tag is set to YES (the default) Doxygen will
# generate Latex output.
GENERATE_LATEX = YES
-# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put.
+# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put.
# put in front of it. If left blank `latex' will be used as the default path.
-LATEX_OUTPUT =
+LATEX_OUTPUT =
-# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
+# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
# invoked. If left blank `latex' will be used as the default command name.
+# Note that when enabling USE_PDFLATEX this option is only used for
+# generating bitmaps for formulas in the HTML output, but not in the
+# Makefile that is written to the output directory.
LATEX_CMD_NAME = latex
-# The MAKEINDEX_CMD_NAME tag can be used to specify the command name to
-# generate index for LaTeX. If left blank `makeindex' will be used as the
+# The MAKEINDEX_CMD_NAME tag can be used to specify the command name to
+# generate index for LaTeX. If left blank `makeindex' will be used as the
# default command name.
MAKEINDEX_CMD_NAME = makeindex
-# If the COMPACT_LATEX tag is set to YES Doxygen generates more compact
-# LaTeX documents. This may be useful for small projects and may help to
+# If the COMPACT_LATEX tag is set to YES Doxygen generates more compact
+# LaTeX documents. This may be useful for small projects and may help to
# save some trees in general.
COMPACT_LATEX = YES
-# The PAPER_TYPE tag can be used to set the paper type that is used
-# by the printer. Possible values are: a4, a4wide, letter, legal and
+# The PAPER_TYPE tag can be used to set the paper type that is used
+# by the printer. Possible values are: a4, letter, legal and
# executive. If left blank a4wide will be used.
PAPER_TYPE = a4
-# The EXTRA_PACKAGES tag can be to specify one or more names of LaTeX
+# The EXTRA_PACKAGES tag can be to specify one or more names of LaTeX
# packages that should be included in the LaTeX output.
-EXTRA_PACKAGES =
+EXTRA_PACKAGES =
-# The LATEX_HEADER tag can be used to specify a personal LaTeX header for
-# the generated latex document. The header should contain everything until
-# the first chapter. If it is left blank doxygen will generate a
+# The LATEX_HEADER tag can be used to specify a personal LaTeX header for
+# the generated latex document. The header should contain everything until
+# the first chapter. If it is left blank doxygen will generate a
# standard header. Notice: only use this tag if you know what you are doing!
-LATEX_HEADER =
+LATEX_HEADER =
-# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated
-# is prepared for conversion to pdf (using ps2pdf). The pdf file will
-# contain links (just like the HTML output) instead of page references
+# The LATEX_FOOTER tag can be used to specify a personal LaTeX footer for
+# the generated latex document. The footer should contain everything after
+# the last chapter. If it is left blank doxygen will generate a
+# standard footer. Notice: only use this tag if you know what you are doing!
+LATEX_FOOTER =
+# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated
+# is prepared for conversion to pdf (using ps2pdf). The pdf file will
+# contain links (just like the HTML output) instead of page references
# This makes the output suitable for online browsing using a pdf viewer.
PDF_HYPERLINKS = YES
-# If the USE_PDFLATEX tag is set to YES, pdflatex will be used instead of
-# plain latex in the generated Makefile. Set this option to YES to get a
+# If the USE_PDFLATEX tag is set to YES, pdflatex will be used instead of
+# plain latex in the generated Makefile. Set this option to YES to get a
# higher quality PDF documentation.
USE_PDFLATEX = YES
-# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \\batchmode.
-# command to the generated LaTeX files. This will instruct LaTeX to keep
-# running if errors occur, instead of asking the user for help.
+# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \\batchmode.
+# command to the generated LaTeX files. This will instruct LaTeX to keep
+# running if errors occur, instead of asking the user for help.
# This option is also used when generating formulas in HTML.
LATEX_BATCHMODE = YES
-# If LATEX_HIDE_INDICES is set to YES then doxygen will not
-# include the index chapters (such as File Index, Compound Index, etc.)
+# If LATEX_HIDE_INDICES is set to YES then doxygen will not
+# include the index chapters (such as File Index, Compound Index, etc.)
# in the output.
LATEX_HIDE_INDICES = NO
+# If LATEX_SOURCE_CODE is set to YES then doxygen will include
+# source code with syntax highlighting in the LaTeX output.
+# Note that which sources are shown also depends on other settings
+# such as SOURCE_BROWSER.
+LATEX_SOURCE_CODE = NO
+# The LATEX_BIB_STYLE tag can be used to specify the style to use for the
+# bibliography, e.g. plainnat, or ieeetr. The default style is "plain". See
+LATEX_BIB_STYLE = plain
# configuration options related to the RTF output
-# If the GENERATE_RTF tag is set to YES Doxygen will generate RTF output
-# The RTF output is optimized for Word 97 and may not look very pretty with
+# If the GENERATE_RTF tag is set to YES Doxygen will generate RTF output
+# The RTF output is optimized for Word 97 and may not look very pretty with
# other RTF readers or editors.
GENERATE_RTF = NO
-# The RTF_OUTPUT tag is used to specify where the RTF docs will be put.
+# The RTF_OUTPUT tag is used to specify where the RTF docs will be put.
# put in front of it. If left blank `rtf' will be used as the default path.
RTF_OUTPUT = rtf
-# If the COMPACT_RTF tag is set to YES Doxygen generates more compact
-# RTF documents. This may be useful for small projects and may help to
+# If the COMPACT_RTF tag is set to YES Doxygen generates more compact
+# RTF documents. This may be useful for small projects and may help to
COMPACT_RTF = NO
-# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated
-# will contain hyperlink fields. The RTF file will
-# contain links (just like the HTML output) instead of page references.
-# This makes the output suitable for online browsing using WORD or other
-# programs which support those fields.
+# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated
+# will contain hyperlink fields. The RTF file will
+# contain links (just like the HTML output) instead of page references.
+# This makes the output suitable for online browsing using WORD or other
+# programs which support those fields.
# Note: wordpad (write) and others do not support links.
RTF_HYPERLINKS = NO
-# Load stylesheet definitions from file. Syntax is similar to doxygen's
-# config file, i.e. a series of assignments. You only have to provide
+# Load style sheet definitions from file. Syntax is similar to doxygen's
+# config file, i.e. a series of assignments. You only have to provide
# replacements, missing definitions are set to their default value.
-RTF_STYLESHEET_FILE =
+RTF_STYLESHEET_FILE =
-# Set optional variables used in the generation of an rtf document.
+# Set optional variables used in the generation of an rtf document.
# Syntax is similar to doxygen's config file.
-RTF_EXTENSIONS_FILE =
+RTF_EXTENSIONS_FILE =
# configuration options related to the man page output
-# If the GENERATE_MAN tag is set to YES (the default) Doxygen will
+# If the GENERATE_MAN tag is set to YES (the default) Doxygen will
# generate man pages
GENERATE_MAN = NO
-# The MAN_OUTPUT tag is used to specify where the man pages will be put.
+# The MAN_OUTPUT tag is used to specify where the man pages will be put.
# put in front of it. If left blank `man' will be used as the default path.
MAN_OUTPUT = man
-# The MAN_EXTENSION tag determines the extension that is added to
+# The MAN_EXTENSION tag determines the extension that is added to
# the generated man pages (default is the subroutine's section .3)
MAN_EXTENSION = .3
-# If the MAN_LINKS tag is set to YES and Doxygen generates man output,
-# then it will generate one additional man file for each entity
-# documented in the real man page(s). These additional files
-# only source the real man page, but without them the man command
+# If the MAN_LINKS tag is set to YES and Doxygen generates man output,
+# then it will generate one additional man file for each entity
+# documented in the real man page(s). These additional files
+# only source the real man page, but without them the man command
# would be unable to find the correct page. The default is NO.
MAN_LINKS = NO
@@ -877,33 +1426,33 @@
# configuration options related to the XML output
-# If the GENERATE_XML tag is set to YES Doxygen will
-# generate an XML file that captures the structure of
+# If the GENERATE_XML tag is set to YES Doxygen will
+# generate an XML file that captures the structure of
# the code including all documentation.
GENERATE_XML = NO
-# The XML_OUTPUT tag is used to specify where the XML pages will be put.
+# The XML_OUTPUT tag is used to specify where the XML pages will be put.
# put in front of it. If left blank `xml' will be used as the default path.
XML_OUTPUT = xml
-# The XML_SCHEMA tag can be used to specify an XML schema,
-# which can be used by a validating XML parser to check the
+# The XML_SCHEMA tag can be used to specify an XML schema,
+# which can be used by a validating XML parser to check the
# syntax of the XML files.
-XML_SCHEMA =
+XML_SCHEMA =
-# The XML_DTD tag can be used to specify an XML DTD,
+# The XML_DTD tag can be used to specify an XML DTD,
-XML_DTD =
+XML_DTD =
-# If the XML_PROGRAMLISTING tag is set to YES Doxygen will
-# dump the program listings (including syntax highlighting
-# and cross-referencing information) to the XML output. Note that
+# If the XML_PROGRAMLISTING tag is set to YES Doxygen will
+# dump the program listings (including syntax highlighting
+# and cross-referencing information) to the XML output. Note that
# enabling this will significantly increase the size of the XML output.
XML_PROGRAMLISTING = YES
@@ -912,10 +1461,10 @@
# configuration options for the AutoGen Definitions output
-# If the GENERATE_AUTOGEN_DEF tag is set to YES Doxygen will
-# generate an AutoGen Definitions (see autogen.sf.net) file
-# that captures the structure of the code including all
-# documentation. Note that this feature is still experimental
+# If the GENERATE_AUTOGEN_DEF tag is set to YES Doxygen will
+# generate an AutoGen Definitions (see autogen.sf.net) file
+# that captures the structure of the code including all
+# documentation. Note that this feature is still experimental
# and incomplete at the moment.
GENERATE_AUTOGEN_DEF = NO
@@ -924,282 +1473,366 @@
# configuration options related to the Perl module output
-# If the GENERATE_PERLMOD tag is set to YES Doxygen will
-# generate a Perl module file that captures the structure of
-# the code including all documentation. Note that this
-# feature is still experimental and incomplete at the
+# If the GENERATE_PERLMOD tag is set to YES Doxygen will
+# generate a Perl module file that captures the structure of
+# the code including all documentation. Note that this
+# feature is still experimental and incomplete at the
# moment.
GENERATE_PERLMOD = NO
-# If the PERLMOD_LATEX tag is set to YES Doxygen will generate
-# the necessary Makefile rules, Perl scripts and LaTeX code to be able
+# If the PERLMOD_LATEX tag is set to YES Doxygen will generate
+# the necessary Makefile rules, Perl scripts and LaTeX code to be able
# to generate PDF and DVI output from the Perl module output.
PERLMOD_LATEX = NO
-# If the PERLMOD_PRETTY tag is set to YES the Perl module output will be
-# nicely formatted so it can be parsed by a human reader. This is useful
-# if you want to understand what is going on. On the other hand, if this
-# tag is set to NO the size of the Perl module output will be much smaller
+# If the PERLMOD_PRETTY tag is set to YES the Perl module output will be
+# nicely formatted so it can be parsed by a human reader.
+# This is useful
+# if you want to understand what is going on.
+# On the other hand, if this
+# tag is set to NO the size of the Perl module output will be much smaller
# and Perl will parse it just the same.
PERLMOD_PRETTY = YES
-# The names of the make variables in the generated doxyrules.make file
-# are prefixed with the string contained in PERLMOD_MAKEVAR_PREFIX.
-# This is useful so different doxyrules.make files included by the same
+# The names of the make variables in the generated doxyrules.make file
+# are prefixed with the string contained in PERLMOD_MAKEVAR_PREFIX.
+# This is useful so different doxyrules.make files included by the same
# Makefile don't overwrite each other's variables.
-PERLMOD_MAKEVAR_PREFIX =
+PERLMOD_MAKEVAR_PREFIX =
-# Configuration options related to the preprocessor
+# Configuration options related to the preprocessor
-# If the ENABLE_PREPROCESSING tag is set to YES (the default) Doxygen will
-# evaluate all C-preprocessor directives found in the sources and include
+# If the ENABLE_PREPROCESSING tag is set to YES (the default) Doxygen will
+# evaluate all C-preprocessor directives found in the sources and include
# files.
ENABLE_PREPROCESSING = YES
-# If the MACRO_EXPANSION tag is set to YES Doxygen will expand all macro
-# names in the source code. If set to NO (the default) only conditional
-# compilation will be performed. Macro expansion can be done in a controlled
+# If the MACRO_EXPANSION tag is set to YES Doxygen will expand all macro
+# names in the source code. If set to NO (the default) only conditional
+# compilation will be performed. Macro expansion can be done in a controlled
# way by setting EXPAND_ONLY_PREDEF to YES.
MACRO_EXPANSION = NO
-# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES
-# then the macro expansion is limited to the macros specified with the
-# PREDEFINED and EXPAND_AS_PREDEFINED tags.
+# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES
+# then the macro expansion is limited to the macros specified with the
+# PREDEFINED and EXPAND_AS_DEFINED tags.
EXPAND_ONLY_PREDEF = NO
-# If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
-# in the INCLUDE_PATH (see below) will be search if a #include is found.
+# If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
+# pointed to by INCLUDE_PATH will be searched when a #include is found.
SEARCH_INCLUDES = YES
-# The INCLUDE_PATH tag can be used to specify one or more directories that
-# contain include files that are not input files but should be processed by
+# The INCLUDE_PATH tag can be used to specify one or more directories that
+# contain include files that are not input files but should be processed by
# the preprocessor.
INCLUDE_PATH = include
-# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
-# patterns (like *.h and *.hpp) to filter out the header-files in the
-# directories. If left blank, the patterns specified with FILE_PATTERNS will
+# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
+# patterns (like *.h and *.hpp) to filter out the header-files in the
+# directories. If left blank, the patterns specified with FILE_PATTERNS will
# be used.
INCLUDE_FILE_PATTERNS =
-# The PREDEFINED tag can be used to specify one or more macro names that
-# are defined before the preprocessor is started (similar to the -D option of
-# gcc). The argument of the tag is a list of macros of the form: name
-# or name=definition (no spaces). If the definition and the = are
-# omitted =1 is assumed. To prevent a macro definition from being
-# undefined via #undef or recursively expanded use the := operator
+# The PREDEFINED tag can be used to specify one or more macro names that
+# are defined before the preprocessor is started (similar to the -D option of
+# gcc). The argument of the tag is a list of macros of the form: name
+# or name=definition (no spaces). If the definition and the = are
+# omitted =1 is assumed. To prevent a macro definition from being
+# undefined via #undef or recursively expanded use the := operator
# instead of the = operator.
-PREDEFINED = HAVE_OGR HAVE_TIFFIO_H HAVE_GEOS
+PREDEFINED = HAVE_OGR \
+ HAVE_TIFFIO_H \
+ HAVE_GEOS
-# If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then
-# this tag can be used to specify a list of macro names that should be expanded.
-# The macro definition that is found in the sources will be used.
-# Use the PREDEFINED tag if you want to use a different macro definition.
+# If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then
+# this tag can be used to specify a list of macro names that should be expanded.
+# The macro definition that is found in the sources will be used.
+# Use the PREDEFINED tag if you want to use a different macro definition that
+# overrules the definition found in the source code.
-EXPAND_AS_DEFINED =
+EXPAND_AS_DEFINED =
-# If the SKIP_FUNCTION_MACROS tag is set to YES (the default) then
-# doxygen's preprocessor will remove all function-like macros that are alone
-# on a line, have an all uppercase name, and do not end with a semicolon. Such
-# function macros are typically used for boiler-plate code, and will confuse the
-# parser if not removed.
+# If the SKIP_FUNCTION_MACROS tag is set to YES (the default) then
+# doxygen's preprocessor will remove all references to function-like macros
+# that are alone on a line, have an all uppercase name, and do not end with a
+# semicolon, because these will confuse the parser if not removed.
SKIP_FUNCTION_MACROS = YES
-# Configuration::additions related to external references
+# Configuration::additions related to external references
-# The TAGFILES option can be used to specify one or more tagfiles.
-# Optionally an initial location of the external documentation
-# can be added for each tagfile. The format of a tag file without
-# this location is as follows:
-# TAGFILES = file1 file2 ...
-# Adding location for the tag files is done as follows:
-# TAGFILES = file1=loc1 "file2 = loc2" ...
-# where "loc1" and "loc2" can be relative or absolute paths or
-# URLs. If a location is present for each tag, the installdox tool
-# does not have to be run to correct the links.
-# Note that each tag file must have a unique name
-# (where the name does NOT include the path)
-# If a tag file is not located in the directory in which doxygen
-# is run, you must also specify the path to the tagfile here.
+# The TAGFILES option can be used to specify one or more tagfiles. For each
+# tag file the location of the external documentation should be added. The
+# format of a tag file without this location is as follows:
+# TAGFILES = file1 file2 ...
+# Adding location for the tag files is done as follows:
+# TAGFILES = file1=loc1 "file2 = loc2" ...
+# where "loc1" and "loc2" can be relative or absolute paths
+# or URLs. Note that each tag file must have a unique name (where the name does
+# NOT include the path). If a tag file is not located in the directory in which
+# doxygen is run, you must also specify the path to the tagfile here.
-TAGFILES =
+TAGFILES =
-# When a file name is specified after GENERATE_TAGFILE, doxygen will create
+# When a file name is specified after GENERATE_TAGFILE, doxygen will create
# a tag file that is based on the input files it reads.
-GENERATE_TAGFILE =
+GENERATE_TAGFILE =
-# If the ALLEXTERNALS tag is set to YES all external classes will be listed
-# in the class index. If set to NO only the inherited external classes
+# If the ALLEXTERNALS tag is set to YES all external classes will be listed
+# in the class index. If set to NO only the inherited external classes
# will be listed.
ALLEXTERNALS = NO
-# If the EXTERNAL_GROUPS tag is set to YES all external groups will be listed
-# in the modules index. If set to NO, only the current project's groups will
+# If the EXTERNAL_GROUPS tag is set to YES all external groups will be listed
+# in the modules index. If set to NO, only the current project's groups will
# be listed.
EXTERNAL_GROUPS = YES
-# The PERL_PATH should be the absolute path and name of the perl script
+# The PERL_PATH should be the absolute path and name of the perl script
# interpreter (i.e. the result of `which perl').
PERL_PATH = /usr/bin/perl
-# Configuration options related to the dot tool
+# Configuration options related to the dot tool
-# If the CLASS_DIAGRAMS tag is set to YES (the default) Doxygen will
-# generate a inheritance diagram (in HTML, RTF and LaTeX) for classes with base or
-# super classes. Setting the tag to NO turns the diagrams off. Note that this
-# option is superseded by the HAVE_DOT option below. This is only a fallback. It is
-# recommended to install and use dot, since it yields more powerful graphs.
+# If the CLASS_DIAGRAMS tag is set to YES (the default) Doxygen will
+# generate a inheritance diagram (in HTML, RTF and LaTeX) for classes with base
+# or super classes. Setting the tag to NO turns the diagrams off. Note that
+# this option also works with HAVE_DOT disabled, but it is recommended to
+# install and use dot, since it yields more powerful graphs.
CLASS_DIAGRAMS = YES
-# If set to YES, the inheritance and collaboration graphs will hide
-# inheritance and usage relations if the target is undocumented
+# You can define message sequence charts within doxygen comments using the \msc
+# command. Doxygen will then run the mscgen tool (see
+# http://www.mcternan.me.uk/mscgen/) to produce the chart and insert it in the
+# documentation. The MSCGEN_PATH tag allows you to specify the directory where
+# the mscgen tool resides. If left empty the tool is assumed to be found in the
+# default search path.
+MSCGEN_PATH =
+# If set to YES, the inheritance and collaboration graphs will hide
+# inheritance and usage relations if the target is undocumented
# or is not a class.
HIDE_UNDOC_RELATIONS = YES
-# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
-# available from the path. This tool is part of Graphviz, a graph visualization
-# toolkit from AT&T and Lucent Bell Labs. The other options in this section
+# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
+# available from the path. This tool is part of Graphviz, a graph visualization
+# toolkit from AT&T and Lucent Bell Labs. The other options in this section
# have no effect if this option is set to NO (the default)
HAVE_DOT = YES
-# If the CLASS_GRAPH and HAVE_DOT tags are set to YES then doxygen
-# will generate a graph for each documented class showing the direct and
-# indirect inheritance relations. Setting this tag to YES will force the
-# the CLASS_DIAGRAMS tag to NO.
+# The DOT_NUM_THREADS specifies the number of dot invocations doxygen is
+# allowed to run in parallel. When set to 0 (the default) doxygen will
+# base this on the number of processors available in the system. You can set it
+# explicitly to a value larger than 0 to get control over the balance
+# between CPU load and processing speed.
+DOT_NUM_THREADS = 0
+# By default doxygen will use the Helvetica font for all dot files that
+# doxygen generates. When you want a differently looking font you can specify
+# the font name using DOT_FONTNAME. You need to make sure dot is able to find
+# the font, which can be done by putting it in a standard location or by setting
+# the DOTFONTPATH environment variable or by setting DOT_FONTPATH to the
+# directory containing the font.
+DOT_FONTNAME = Helvetica
+# The DOT_FONTSIZE tag can be used to set the size of the font of dot graphs.
+# The default size is 10pt.
+DOT_FONTSIZE = 10
+# By default doxygen will tell dot to use the Helvetica font.
+# If you specify a different font using DOT_FONTNAME you can use DOT_FONTPATH to
+# set the path where dot can find it.
+DOT_FONTPATH =
+# If the CLASS_GRAPH and HAVE_DOT tags are set to YES then doxygen
+# will generate a graph for each documented class showing the direct and
+# indirect inheritance relations. Setting this tag to YES will force the
+# CLASS_DIAGRAMS tag to NO.
CLASS_GRAPH = YES
-# If the COLLABORATION_GRAPH and HAVE_DOT tags are set to YES then doxygen
-# indirect implementation dependencies (inheritance, containment, and
+# If the COLLABORATION_GRAPH and HAVE_DOT tags are set to YES then doxygen
+# indirect implementation dependencies (inheritance, containment, and
# class references variables) of the class with other documented classes.
COLLABORATION_GRAPH = YES
-# If the UML_LOOK tag is set to YES doxygen will generate inheritance and
-# collaboration diagrams in a style similar to the OMG's Unified Modeling
+# If the GROUP_GRAPHS and HAVE_DOT tags are set to YES then doxygen
+# will generate a graph for groups, showing the direct groups dependencies
+GROUP_GRAPHS = YES
+# If the UML_LOOK tag is set to YES doxygen will generate inheritance and
+# collaboration diagrams in a style similar to the OMG's Unified Modeling
# Language.
UML_LOOK = NO
-# If set to YES, the inheritance and collaboration graphs will show the
+# If the UML_LOOK tag is enabled, the fields and methods are shown inside
+# the class node. If there are many fields or methods and many nodes the
+# graph may become too big to be useful. The UML_LIMIT_NUM_FIELDS
+# threshold limits the number of items for each type to make the size more
+# managable. Set this to 0 for no limit. Note that the threshold may be
+# exceeded by 50% before the limit is enforced.
+UML_LIMIT_NUM_FIELDS = 10
+# If set to YES, the inheritance and collaboration graphs will show the
# relations between templates and their instances.
TEMPLATE_RELATIONS = NO
-# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDE_GRAPH, and HAVE_DOT
-# tags are set to YES then doxygen will generate a graph for each documented
-# file showing the direct and indirect include dependencies of the file with
+# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDE_GRAPH, and HAVE_DOT
+# tags are set to YES then doxygen will generate a graph for each documented
+# file showing the direct and indirect include dependencies of the file with
# other documented files.
INCLUDE_GRAPH = YES
-# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDED_BY_GRAPH, and
-# HAVE_DOT tags are set to YES then doxygen will generate a graph for each
-# documented header file showing the documented files that directly or
+# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDED_BY_GRAPH, and
+# HAVE_DOT tags are set to YES then doxygen will generate a graph for each
+# documented header file showing the documented files that directly or
# indirectly include this file.
INCLUDED_BY_GRAPH = YES
-# If the CALL_GRAPH and HAVE_DOT tags are set to YES then doxygen will
-# generate a call dependency graph for every global function or class method.
-# Note that enabling this option will significantly increase the time of a run.
-# So in most cases it will be better to enable call graphs for selected
-# functions only using the \callgraph command.
+# If the CALL_GRAPH and HAVE_DOT options are set to YES then
+# doxygen will generate a call dependency graph for every global function
+# or class method. Note that enabling this option will significantly increase
+# the time of a run. So in most cases it will be better to enable call graphs
+# for selected functions only using the \callgraph command.
CALL_GRAPH = NO
-# If the GRAPHICAL_HIERARCHY and HAVE_DOT tags are set to YES then doxygen
-# will graphical hierarchy of all classes instead of a textual one.
+# If the CALLER_GRAPH and HAVE_DOT tags are set to YES then
+# doxygen will generate a caller dependency graph for every global function
+# the time of a run. So in most cases it will be better to enable caller
+# graphs for selected functions only using the \callergraph command.
+CALLER_GRAPH = NO
+# If the GRAPHICAL_HIERARCHY and HAVE_DOT tags are set to YES then doxygen
+# will generate a graphical hierarchy of all classes instead of a textual one.
GRAPHICAL_HIERARCHY = YES
-# The DOT_IMAGE_FORMAT tag can be used to set the image format of the images
-# generated by dot. Possible values are png, jpg, or gif
-# If left blank png will be used.
+# If the DIRECTORY_GRAPH and HAVE_DOT tags are set to YES
+# then doxygen will show the dependencies a directory has on other directories
+# in a graphical way. The dependency relations are determined by the #include
+# relations between the files in the directories.
+DIRECTORY_GRAPH = YES
+# The DOT_IMAGE_FORMAT tag can be used to set the image format of the images
+# generated by dot. Possible values are svg, png, jpg, or gif.
+# If left blank png will be used. If you choose svg you need to set
+# HTML_FILE_EXTENSION to xhtml in order to make the SVG files
+# visible in IE 9+ (other browsers do not have this requirement).
DOT_IMAGE_FORMAT = png
-# The tag DOT_PATH can be used to specify the path where the dot tool can be
-# found. If left blank, it is assumed the dot tool can be found on the path.
+# If DOT_IMAGE_FORMAT is set to svg, then this option can be set to YES to
+# enable generation of interactive SVG images that allow zooming and panning.
+# Note that this requires a modern browser other than Internet Explorer.
+# Tested and working are Firefox, Chrome, Safari, and Opera. For IE 9+ you
+# need to set HTML_FILE_EXTENSION to xhtml in order to make the SVG files
+# visible. Older versions of IE do not have SVG support.
-DOT_PATH =
+INTERACTIVE_SVG = NO
-# The DOTFILE_DIRS tag can be used to specify one or more directories that
-# contain dot files that are included in the documentation (see the
+# The tag DOT_PATH can be used to specify the path where the dot tool can be
+# found. If left blank, it is assumed the dot tool can be found in the path.
+DOT_PATH =
+# The DOTFILE_DIRS tag can be used to specify one or more directories that
+# contain dot files that are included in the documentation (see the
# \dotfile command).
-DOTFILE_DIRS =
+DOTFILE_DIRS =
-# The MAX_DOT_GRAPH_WIDTH tag can be used to set the maximum allowed width
-# (in pixels) of the graphs generated by dot. If a graph becomes larger than
-# this value, doxygen will try to truncate the graph, so that it fits within
-# the specified constraint. Beware that most browsers cannot cope with very
-# large images.
+# The MSCFILE_DIRS tag can be used to specify one or more directories that
+# contain msc files that are included in the documentation (see the
+# \mscfile command).
-MAX_DOT_GRAPH_WIDTH = 2000
+MSCFILE_DIRS =
-# The MAX_DOT_GRAPH_HEIGHT tag can be used to set the maximum allows height
-# large images.
+# The DOT_GRAPH_MAX_NODES tag can be used to set the maximum number of
+# nodes that will be shown in the graph. If the number of nodes in a graph
+# becomes larger than this value, doxygen will truncate the graph, which is
+# visualized by representing a node as a red box. Note that doxygen if the
+# number of direct children of the root node in a graph is already larger than
+# DOT_GRAPH_MAX_NODES then the graph will not be shown at all. Also note
+# that the size of a graph can be further restricted by MAX_DOT_GRAPH_DEPTH.
-MAX_DOT_GRAPH_HEIGHT = 2000
+DOT_GRAPH_MAX_NODES = 50
-# The MAX_DOT_GRAPH_DEPTH tag can be used to set the maximum depth of the
-# graphs generated by dot. A depth value of 3 means that only nodes reachable
-# from the root by following a path via at most 3 edges will be shown. Nodes that
-# lay further from the root node will be omitted. Note that setting this option to
-# 1 or 2 may greatly reduce the computation time needed for large code bases. Also
-# note that a graph may be further truncated if the graph's image dimensions are
-# not sufficient to fit the graph (see MAX_DOT_GRAPH_WIDTH and MAX_DOT_GRAPH_HEIGHT).
-# If 0 is used for the depth value (the default), the graph is not depth-constrained.
+# The MAX_DOT_GRAPH_DEPTH tag can be used to set the maximum depth of the
+# graphs generated by dot. A depth value of 3 means that only nodes reachable
+# from the root by following a path via at most 3 edges will be shown. Nodes
+# that lay further from the root node will be omitted. Note that setting this
+# option to 1 or 2 may greatly reduce the computation time needed for large
+# code bases. Also note that the size of a graph can be further restricted by
+# DOT_GRAPH_MAX_NODES. Using a depth of 0 means no depth restriction.
MAX_DOT_GRAPH_DEPTH = 0
-# If the GENERATE_LEGEND tag is set to YES (the default) Doxygen will
-# generate a legend page explaining the meaning of the various boxes and
+# Set the DOT_TRANSPARENT tag to YES to generate images with a transparent
+# background. This is disabled by default, because dot on Windows does not
+# seem to support this out of the box. Warning: Depending on the platform used,
+# enabling this option may lead to badly anti-aliased labels on the edges of
+# a graph (i.e. they become hard to read).
+DOT_TRANSPARENT = NO
+# Set the DOT_MULTI_TARGETS tag to YES allow dot to generate multiple output
+# files in one run (i.e. multiple -o and -T options on the command line). This
+# makes dot run faster, but since only newer versions of dot (>1.8.10)
+# support this, this feature is disabled by default.
+DOT_MULTI_TARGETS = YES
+# If the GENERATE_LEGEND tag is set to YES (the default) Doxygen will
+# generate a legend page explaining the meaning of the various boxes and
# arrows in the dot generated graphs.
GENERATE_LEGEND = YES
-# If the DOT_CLEANUP tag is set to YES (the default) Doxygen will
-# remove the intermediate dot files that are used to generate
+# If the DOT_CLEANUP tag is set to YES (the default) Doxygen will
+# remove the intermediate dot files that are used to generate
# the various graphs.
DOT_CLEANUP = YES
-# Configuration::additions related to the search engine
-# The SEARCHENGINE tag specifies whether or not a search engine should be
-# used. If set to NO the values of all tags below this one will be ignored.
-SEARCHENGINE = NO
