[GRASS-SVN] r53637 - grass/trunk/vector/v.net.centrality
svn_grass at osgeo.org
Thu Nov 1 11:07:08 PDT 2012
Author: mmetz
Date: 2012-11-01 11:07:06 -0700 (Thu, 01 Nov 2012)
New Revision: 53637
grass/trunk/vector/v.net.centrality/main.c
v.net.centrality: fix for #1779
Modified: grass/trunk/vector/v.net.centrality/main.c
--- grass/trunk/vector/v.net.centrality/main.c 2012-11-01 17:56:33 UTC (rev 53636)
+++ grass/trunk/vector/v.net.centrality/main.c 2012-11-01 18:07:06 UTC (rev 53637)
@@ -345,6 +345,8 @@
if (!Vect_cat_get(Cats, nfield, &cat))
continue;
+ Vect_reset_cats(Cats);
+ Vect_cat_set(Cats, 1, cat);
Vect_write_line(&Out, type, Points, Cats);
node = Vect_find_node(&In, Points->x[0], Points->y[0], Points->z[0], 0, 0);
process_node(node, cat);
