[GRASS-SVN] r53643 - in grass/trunk/temporal: . t.rast.colors t.rename
svn_grass at osgeo.org
Thu Nov 1 17:56:39 PDT 2012
Author: huhabla
Date: 2012-11-01 17:56:39 -0700 (Thu, 01 Nov 2012)
New Revision: 53643
Added:
grass/trunk/temporal/t.rename/
grass/trunk/temporal/t.rename/Makefile
grass/trunk/temporal/t.rename/t.rename.html
grass/trunk/temporal/t.rename/t.rename.py
grass/trunk/temporal/t.rename/test.t.rename.sh
grass/trunk/temporal/t.rast.colors/t.rast.colors.html
grass/trunk/temporal/t.rast.colors/t.rast.colors.py
New renaming module
Modified: grass/trunk/temporal/t.rast.colors/t.rast.colors.html
--- grass/trunk/temporal/t.rast.colors/t.rast.colors.html 2012-11-02 00:54:33 UTC (rev 53642)
+++ grass/trunk/temporal/t.rast.colors/t.rast.colors.html 2012-11-02 00:56:39 UTC (rev 53643)
@@ -11,7 +11,7 @@
to the <em>file</em> option of <em>r.colors</em>.
<p>
Please have a look at the <a href="r.colors.html">r.colors</a>
-manpage for further informations.
+manual page for further informations.
<h2>EXAMPLE</h2>
Modified: grass/trunk/temporal/t.rast.colors/t.rast.colors.py
--- grass/trunk/temporal/t.rast.colors/t.rast.colors.py 2012-11-02 00:54:33 UTC (rev 53642)
+++ grass/trunk/temporal/t.rast.colors/t.rast.colors.py 2012-11-02 00:56:39 UTC (rev 53643)
@@ -51,7 +51,7 @@
#%flag
#% key: r
-#% description: Remove existing color table
+#% description: Remove existing color tables
#%end
#%flag
Added: grass/trunk/temporal/t.rename/Makefile
--- grass/trunk/temporal/t.rename/Makefile (rev 0)
+++ grass/trunk/temporal/t.rename/Makefile 2012-11-02 00:56:39 UTC (rev 53643)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.rename
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/t.rename/t.rename.html
--- grass/trunk/temporal/t.rename/t.rename.html (rev 0)
+++ grass/trunk/temporal/t.rename/t.rename.html 2012-11-02 00:56:39 UTC (rev 53643)
@@ -0,0 +1,19 @@
+<h2>DESCRIPTION</h2>
+This module renames space time datasets of different types (strds, stvds, str3ds)
+and updates the space time dataset register entries of the registered maps.
+<h2>SEE ALSO</h2>
+<em>
+<a href="t.create.html">t.create</a>,
+<a href="t.support.html">t.support</a>,
+<a href="t.register.html">t.register</a>
+</em>
+<h2>AUTHOR</h2>
+Sören Gebbert
+<p><i>Last changed: $Date: 2012-08-29 14:55:21 +0200 (Mi, 29. Aug 2012) $</i>
Added: grass/trunk/temporal/t.rename/t.rename.py
--- grass/trunk/temporal/t.rename/t.rename.py (rev 0)
+++ grass/trunk/temporal/t.rename/t.rename.py 2012-11-02 00:56:39 UTC (rev 53643)
@@ -0,0 +1,102 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.support
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Modify the metadata of a space time dataset
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Modifies the metadata of a space time dataset.
+#% keywords: temporal
+#% keywords: support
+#%end
+#%option G_OPT_STDS_INPUT
+#%end
+#%option G_OPT_STDS_OUTPUT
+#%end
+#%option G_OPT_STDS_TYPE
+#% guidependency: input
+#% guisection: Required
+#%end
+import grass.temporal as tgis
+import grass.script as grass
+def main():
+ # Get the options
+ input = options["input"]
+ output = options["output"]
+ type = options["type"]
+ # Make sure the temporal database exists
+ tgis.init()
+ #Get the current mapset to create the id of the space time dataset
+ mapset = grass.gisenv()["MAPSET"]
+ if input.find("@") >= 0:
+ old_id = input
+ else:
+ old_id = input + "@" + mapset
+ if output.find("@") >= 0:
+ new_id = output
+ else:
+ new_id = output + "@" + mapset
+ # Do not overwrite yourself
+ if new_id == old_id:
+ return
+ dbif = tgis.SQLDatabaseInterfaceConnection()
+ dbif.connect()
+ stds = tgis.dataset_factory(type, old_id)
+ if new_id.split("@")[1] != mapset:
+ grass.fatal(_("Space time %s dataset <%s> can not be renamed. "
+ "Mapset of the new identifier differs from the current "
+ "mapset.") % (stds.get_new_map_instance(None).get_type(),
+ old_id))
+ if stds.is_in_db(dbif=dbif) == False:
+ dbif.close()
+ grass.fatal(_("Space time %s dataset <%s> not found") % (
+ stds.get_new_map_instance(None).get_type(), old_id))
+ # Check if the new id is in the database
+ new_stds = tgis.dataset_factory(type, new_id)
+ if new_stds.is_in_db(dbif=dbif) == True and grass.overwrite() == False:
+ dbif.close()
+ grass.fatal(_("Unable to rename Space time %s dataset <%s>. Name <%s> "
+ "is in use, please use the overwrite flag.") % (
+ stds.get_new_map_instance(None).get_type(), old_id, new_id))
+ # Remove an already existing space time dataset
+ if new_stds.is_in_db(dbif=dbif) == True:
+ new_stds.delete(dbif=dbif)
+ stds.select(dbif=dbif)
+ stds.rename(ident=new_id, dbif=dbif)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/temporal/t.rename/t.rename.py
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/temporal/t.rename/test.t.rename.sh
--- grass/trunk/temporal/t.rename/test.t.rename.sh (rev 0)
+++ grass/trunk/temporal/t.rename/test.t.rename.sh 2012-11-02 00:56:39 UTC (rev 53643)
@@ -0,0 +1,51 @@
+#!/bin/sh
+# Tests the rename module of space time datasets
+# We need to set a specific region in the
+# @preprocess step of this test.
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+# We need to create three space time dataset
+t.create --v --o type=strds temporaltype=absolute output=precip_abs1 \
+ title="Test" descr="This is the 1 test strds" semantictype=sum
+t.register -i input=precip_abs1 maps=prec_1,prec_2 \
+ start="2001-01-01" increment="1 seconds"
+t.create --v --o type=strds temporaltype=absolute output=precip_abs2 \
+ title="Test" descr="This is the 2 test strds" semantictype=sum
+t.register input=precip_abs2 maps=prec_1,prec_2
+t.create --v --o type=strds temporaltype=absolute output=precip_abs3 \
+ title="Test" descr="This is the 3 test strds" semantictype=sum
+t.register input=precip_abs3 maps=prec_1,prec_2
+t.info precip_abs1
+t.info precip_abs2
+t.info precip_abs3
+# @test Rename the space time raster dataset by overwritung an old one
+t.rename --o type=strds input=precip_abs1 output=precip_abs2
+t.info precip_abs2
+t.info type=rast input=prec_1
+t.info type=rast input=prec_2
+t.rename --o type=strds input=precip_abs2 output=precip_abs4
+t.info precip_abs4
+# Error checking, new dataset has the wrong mapset
+t.rename type=strds input=precip_abs4 output=precip_abs3 at BLABLA
+# Error checking, no overwrite flag set
+t.remove --v type=strds input=precip_abs3,precip_abs4
+t.unregister type=rast maps=prec_1,prec_2
+g.remove rast=prec_1,prec_2
Property changes on: grass/trunk/temporal/t.rename/test.t.rename.sh
