[GRASS-SVN] r53645 - in grass-addons/grass7/imagery: . i.eb.h_sebal95
Thu Nov 1 20:57:29 PDT 2012
Author: ychemin
Date: 2012-11-01 20:57:29 -0700 (Thu, 01 Nov 2012)
New Revision: 53645
Added:
   grass-addons/grass7/imagery/i.eb.h_sebal95/
   grass-addons/grass7/imagery/i.eb.h_sebal95/i.eb.h_sebal95.html
Removed:
   grass-addons/grass7/imagery/i.eb.h_SEBAL95/
   grass-addons/grass7/imagery/i.eb.h_sebal95/i.eb.h_SEBAL95.html
module name from upper case to lower case
Deleted: grass-addons/grass7/imagery/i.eb.h_sebal95/i.eb.h_SEBAL95.html
--- grass-addons/grass7/imagery/i.eb.h_SEBAL95/i.eb.h_SEBAL95.html	2012-11-02 01:05:44 UTC (rev 53644)
+++ grass-addons/grass7/imagery/i.eb.h_sebal95/i.eb.h_SEBAL95.html	2012-11-02 03:57:29 UTC (rev 53645)
@@ -1,141 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<h2>NAME</h2> <I>i.eb.h_SEBAL95 </I>- computation of <i>sensible heat flux</i> [W/m2] after Bastiaanssen, 1995 in [1].
-<p><I>(GRASS Raster Program)</I>
-<h2>SYNOPSIS</h2>
-<b>i.eb.h_SEBAL95</b>
-<br>
-<b>i.eb.h_SEBAL95</b> help
-<br>
-<b>i.eb.h_SEBAL95</b> <b>[ -qzn ]</b>
-<b>DEM</b>=name
-<b>T</b>=name
-<b>RH</b>=name
-<b>WS</b>=name
-<b>NSR</b>=name
-<b>Vh</b>=name
-<b>ETP</b>=name
-<h2>DESCRIPTION</h2>
-<p><em>i.eb.h_SEBAL95</em> given the vegetation height (hc), humidity (RU),
-wind speed at two meters height (WS), temperature (T), digital terrain model (DEM),
-and net radiation (NSR) raster input maps,
-calculates the sensible heat flux map (h0).
-<p>Optionally the user can activate a flag (-z)
-that allows him setting to zero all of the negative evapotranspiration cells;
-in fact these negative values motivated by the condensation of the air water
-vapour content, are sometime undesired because they can produce  computational
-problems. The usage of the flag -n detect that the module is run in night hours
-and the appropriate soil heat flux is calculated.
-<p>The algorithm implements well known approaches: the hourly Penman-Monteith method as presented in Allen et al. (1998) for land surfaces and the Penman method (Penman, 1948) for water surfaces.<br>
-<p>Land and water surfaces are idenfyied by Vh:<br>
--	where Vh less than 0 vegetation is present and evapotranspiration is calculated;<br>
--	where Vh=0 bare ground is present and evapotranspiration is calculated;<br>
--	where Vh more than 0 water surface is present and evaporation is calculated;<br>
-<p>For more details on the algorithms see [1].
-<h2>OPTIONS</h2>
-The program will run non-interactively if the user specifies program
-arguments and flag settings on the command line using the following
-form:
-<p><b>i.eb.h_SEBAL95</b> <b>[ -qzd ]</b>
-<b>DEM</b>=name
-<b>T</b>=name
-<b>RH</b>=name
-<b>WS</b>=name
-<b>NSR</b>=name
-<b>Vh</b>=name
-<b>ETP</b>=name
-<p>Alternatively, the user can simply type <em>i.eb.h_SEBAL95</em> on the
-command line and the program will ask for parameter values and flag
-settings interactively, using the standard GRASS parser interface.
-<h3>Parameters:</h3>
-<dl>
- <dt><b>DEM</b>=<I>name</I>
- <dd>Input elevation raster [m a.s.l.]. Required.</dd>
- <dt><b>T</b>=<I>name</I>
- <dd>Input temperature raster [�C]. Required.</dd>
- <dt><b>RH</b> =<I>name</I>
- <dd>Input relative humidity raster [%]. Required.</dd>
- <dt><b>WS</b> =<I>name</I>
- <dd>Input wind speed at two meters raster [m/s]. Required.</dd>
- <dt><b>NSR</b> =<I>name</I>
- <dd>Input net solar radiation raster [MJ/(m2*h)]. Required.</dd>
- <dt><b>Vh</b> =<I>name</I>
- <dd>Input vegetation heigth raster [m]. Required.</dd>
- <dt><b>ETP</b> =<I>name</I>
- <dd>Output evapotranspiration raster [mm/h]. Required.</dd>
-</dl>
-<h2>NOTES</h2>
-<p>Net solar radiation map in MJ/(m2*h) can be computed from the combination of the r.sun ,
-run in mode 1, and the r.mapcalc commands.
-<p>The sum of the three radiation components outputted by r.sun (beam, diffuse, and reflected)
-multiplied by the Wh to Mj conversion factor (0.0036) and optionally by a
-clear sky factor [0-1] allows the generation of a map to be used as
-an NSR input for the <em>i.evapo.pm</em> command.
-<br>
-example:
-<br>r.sun -s elevin=dem aspin=aspect slopein=slope lin=2 albedo=alb_Mar incidout=out beam_rad=beam diff_rad=diffuse refl_rad=reflected day=73 time=13:00 dist=100;
-<br>r.mapcalc 'NSR=0.0036*(beam+diffuse+reflected)';
-<h2>SEE ALSO</h2>
-<ul>
-  <li><a href=i.eb.h_iter.html>i.eb.h_iter</a>,
-      <a href=i.eb.h0.html>i.eb.h0</a>
-      <a href=i.evapo.pm.html>i.evapo.pm</a>
-</ul>
-<h2>AUTHORS</h2>
-  <p>
-  <i>
-   <br>Yann Chemin
-   <br>International Rice Research Institute, Los Banos, The Philippines.
-   <br>International Water management Institute, Colombo, Sri Lanka.
-  </i>
-  <p>Contact: <a href="mailto:y.chemin at cgiar.org"> Yann chemin</a>
-<h2>REFERENCES</h2>
-  <p>[1] Bastiaanssen, W.G.M., 1995.
-  Estimation of Land surface paramters by remote sensing under clear-sky conditions. PhD thesis, Wageningen University, Wageningen, The Netherlands.
-  <p>[2] Allen, R.G., L.S. Pereira, D. Raes, and M. Smith. 1998.
-  Crop Evapotranspiration: Guidelines for computing crop water requirements.
-  Irrigation and Drainage Paper 56, Food and Agriculture Organization of the
-  United Nations, Rome, pp. 300
-  <p>[3] Penman, H. L. 1948. Natural evaporation from open water,
-  bare soil and grass. Proc. Roy. Soc. London, A193, pp. 120-146.
Copied: grass-addons/grass7/imagery/i.eb.h_sebal95/i.eb.h_sebal95.html (from rev 53644, grass-addons/grass7/imagery/i.eb.h_SEBAL95/i.eb.h_SEBAL95.html)
--- grass-addons/grass7/imagery/i.eb.h_sebal95/i.eb.h_sebal95.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.eb.h_sebal95/i.eb.h_sebal95.html	2012-11-02 03:57:29 UTC (rev 53645)
@@ -0,0 +1,141 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<h2>NAME</h2> <I>i.eb.h_sebal95 </I>- computation of <i>sensible heat flux</i> [W/m2] after Bastiaanssen, 1995 in [1].
+<p><I>(GRASS Raster Program)</I>
+<h2>SYNOPSIS</h2>
+<b>i.eb.h_sebal95</b>
+<br>
+<b>i.eb.h_sebal95</b> help
+<br>
+<b>i.eb.h_sebal95</b> <b>[ -qzn ]</b>
+<b>DEM</b>=name
+<b>T</b>=name
+<b>RH</b>=name
+<b>WS</b>=name
+<b>NSR</b>=name
+<b>Vh</b>=name
+<b>ETP</b>=name
+<h2>DESCRIPTION</h2>
+<p><em>i.eb.h_sebal95</em> given the vegetation height (hc), humidity (RU),
+wind speed at two meters height (WS), temperature (T), digital terrain model (DEM),
+and net radiation (NSR) raster input maps,
+calculates the sensible heat flux map (h0).
+<p>Optionally the user can activate a flag (-z)
+that allows him setting to zero all of the negative evapotranspiration cells;
+in fact these negative values motivated by the condensation of the air water
+vapour content, are sometime undesired because they can produce  computational
+problems. The usage of the flag -n detect that the module is run in night hours
+and the appropriate soil heat flux is calculated.
+<p>The algorithm implements well known approaches: the hourly Penman-Monteith method as presented in Allen et al. (1998) for land surfaces and the Penman method (Penman, 1948) for water surfaces.<br>
+<p>Land and water surfaces are idenfyied by Vh:<br>
+-	where Vh less than 0 vegetation is present and evapotranspiration is calculated;<br>
+-	where Vh=0 bare ground is present and evapotranspiration is calculated;<br>
+-	where Vh more than 0 water surface is present and evaporation is calculated;<br>
+<p>For more details on the algorithms see [1].
+<h2>OPTIONS</h2>
+The program will run non-interactively if the user specifies program
+arguments and flag settings on the command line using the following
+form:
+<p><b>i.eb.h_sebal95</b> <b>[ -qzd ]</b>
+<b>DEM</b>=name
+<b>T</b>=name
+<b>RH</b>=name
+<b>WS</b>=name
+<b>NSR</b>=name
+<b>Vh</b>=name
+<b>ETP</b>=name
+<p>Alternatively, the user can simply type <em>i.eb.h_sebal95</em> on the
+command line and the program will ask for parameter values and flag
+settings interactively, using the standard GRASS parser interface.
+<h3>Parameters:</h3>
+<dl>
+ <dt><b>DEM</b>=<I>name</I>
+ <dd>Input elevation raster [m a.s.l.]. Required.</dd>
+ <dt><b>T</b>=<I>name</I>
+ <dd>Input temperature raster [�C]. Required.</dd>
+ <dt><b>RH</b> =<I>name</I>
+ <dd>Input relative humidity raster [%]. Required.</dd>
+ <dt><b>WS</b> =<I>name</I>
+ <dd>Input wind speed at two meters raster [m/s]. Required.</dd>
+ <dt><b>NSR</b> =<I>name</I>
+ <dd>Input net solar radiation raster [MJ/(m2*h)]. Required.</dd>
+ <dt><b>Vh</b> =<I>name</I>
+ <dd>Input vegetation heigth raster [m]. Required.</dd>
+ <dt><b>ETP</b> =<I>name</I>
+ <dd>Output evapotranspiration raster [mm/h]. Required.</dd>
+</dl>
+<h2>NOTES</h2>
+<p>Net solar radiation map in MJ/(m2*h) can be computed from the combination of the r.sun ,
+run in mode 1, and the r.mapcalc commands.
+<p>The sum of the three radiation components outputted by r.sun (beam, diffuse, and reflected)
+multiplied by the Wh to Mj conversion factor (0.0036) and optionally by a
+clear sky factor [0-1] allows the generation of a map to be used as
+an NSR input for the <em>i.evapo.pm</em> command.
+<br>
+example:
+<br>r.sun -s elevin=dem aspin=aspect slopein=slope lin=2 albedo=alb_Mar incidout=out beam_rad=beam diff_rad=diffuse refl_rad=reflected day=73 time=13:00 dist=100;
+<br>r.mapcalc 'NSR=0.0036*(beam+diffuse+reflected)';
+<h2>SEE ALSO</h2>
+<ul>
+  <li><a href=i.eb.h_iter.html>i.eb.h_iter</a>,
+      <a href=i.eb.h0.html>i.eb.h0</a>
+      <a href=i.evapo.pm.html>i.evapo.pm</a>
+</ul>
+<h2>AUTHORS</h2>
+  <p>
+  <i>
+   <br>Yann Chemin
+   <br>International Rice Research Institute, Los Banos, The Philippines.
+   <br>International Water management Institute, Colombo, Sri Lanka.
+  </i>
+  <p>Contact: <a href="mailto:y.chemin at cgiar.org"> Yann chemin</a>
+<h2>REFERENCES</h2>
+  <p>[1] Bastiaanssen, W.G.M., 1995.
+  Estimation of Land surface paramters by remote sensing under clear-sky conditions. PhD thesis, Wageningen University, Wageningen, The Netherlands.
+  <p>[2] Allen, R.G., L.S. Pereira, D. Raes, and M. Smith. 1998.
+  Crop Evapotranspiration: Guidelines for computing crop water requirements.
+  Irrigation and Drainage Paper 56, Food and Agriculture Organization of the
+  United Nations, Rome, pp. 300
+  <p>[3] Penman, H. L. 1948. Natural evaporation from open water,
+  bare soil and grass. Proc. Roy. Soc. London, A193, pp. 120-146.
