[GRASS-SVN] r53656 - grass/trunk/gui/wxpython/gmodeler
svn_grass at osgeo.org
Fri Nov 2 04:29:45 PDT 2012
Author: martinl
Date: 2012-11-02 04:29:45 -0700 (Fri, 02 Nov 2012)
New Revision: 53656
grass/trunk/gui/wxpython/gmodeler/frame.py
wxGUI Modeler: better positioning new actions
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py 2012-11-02 10:54:05 UTC (rev 53655)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py 2012-11-02 11:29:45 UTC (rev 53656)
@@ -30,11 +30,12 @@
if __name__ == "__main__":
sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython'))
-from core import globalvar
import wx
-from wx.lib import ogl
+from wx.lib import ogl
import wx.lib.flatnotebook as FN
+from core import globalvar
from gui_core.widgets import GNotebook
from gui_core.goutput import GMConsole, PyStc
from core.debug import Debug
@@ -620,7 +621,7 @@
self.searchDialog.CentreOnParent()
else:
self.searchDialog.Reset()
if self.searchDialog.ShowModal() == wx.ID_CANCEL:
self.searchDialog.Hide()
return
@@ -631,8 +632,8 @@
self.ModelChanged()
# add action to canvas
- width, height = self.canvas.GetSize()
- action = ModelAction(self.model, cmd = cmd, x = width/2, y = height/2,
+ x, y = self.canvas.GetNewShapePos()
+ action = ModelAction(self.model, cmd = cmd, x = x, y = y,
id = self.model.GetNextId())
overwrite = self.model.GetProperties().get('overwrite', None)
if overwrite is not None:
@@ -640,7 +641,7 @@
self.canvas.diagram.AddShape(action)
action.Show(True)
self._addEvent(action)
self.model.AddItem(action)
@@ -1004,6 +1005,22 @@
self.Refresh()
+ def GetNewShapePos(self):
+ """!Determine optimal position for newly added object
+ @return x,y
+ xNew, yNew = map(lambda x: x / 2, self.GetSize())
+ diagram = self.GetDiagram()
+ for shape in diagram.GetShapeList():
+ y = shape.GetY()
+ yBox = shape.GetBoundingBoxMin()[1] / 2
+ if yBox > 0 and y < yNew + yBox and y > yNew - yBox:
+ yNew += yBox * 3
+ return xNew, yNew
class ModelEvtHandler(ogl.ShapeEvtHandler):
"""!Model event handler class"""
def __init__(self, log, frame):
