[GRASS-SVN] r53661 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Fri Nov 2 05:44:54 PDT 2012
Author: huhabla
Date: 2012-11-02 05:44:53 -0700 (Fri, 02 Nov 2012)
New Revision: 53661
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
Added handling of time instances and mixed time to sample by granularity.
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-11-02 11:57:17 UTC (rev 53660)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-11-02 12:44:53 UTC (rev 53661)
@@ -622,6 +622,9 @@
A valid temporal topology (no overlapping or inclusion allowed)
is needed to get correct results.
+ Space time datasets with interval time, time instances and mixed time
+ are supported.
Gaps between maps are identified as unregistered maps with id==None.
@@ -630,7 +633,8 @@
In case more map information are needed, use the select()
method for each listed object.
- @param gran: The granularity to be used
+ @param gran: The granularity to be used, if None the granularity of
+ the space time dataset is used.
@param dbif: The database interface to be used
@return ordered object list, in case nothing found None is returned
@@ -644,7 +648,20 @@
gran = self.get_granularity()
start, end = self.get_valid_time()
+ # Time instances and mixed time
+ is_irregular = False
+ # We need to adjust the end time in case the the dataset ha no
+ # interval time, so we can catch time instances at the end
+ if self.get_map_time() != "interval":
+ is_irregular = True
+ if self.is_time_absolute():
+ end = increment_datetime_by_string(end, gran)
+ else:
+ end = end + gran
while start < end:
next = increment_datetime_by_string(start, gran)
@@ -679,8 +696,12 @@
maplist.append(copy.copy(map))
obj_list.append(copy.copy(maplist))
- else:
- # Searching for time instances
+ else:
+ # We truely found a gap and maybe a time instance
+ found_gap = True
+ # Searching for time instances with start time in the current
+ # granule
where = "(start_time = '%s')" % (start)
rows = self.get_registered_maps("id", where, "start_time", dbif)
@@ -707,11 +728,16 @@
- found_gap = True
+ # In case of irregular time (point, mixed) the last granule
+ # does not belong to the dataset and will be ignored
+ if is_irregular:
+ if next == end:
+ found_gap = False
# Gap handling
if found_gap:
- # Found a gap
+ # Append a map object with None as id to indicate a gap
map = self.get_new_map_instance(None)
