[GRASS-SVN] r53671 - grass-addons/grass7/gui/wxpython/wx.animation/animation
svn_grass at osgeo.org
Fri Nov 2 13:28:38 PDT 2012
Author: annakrat
Date: 2012-11-02 13:28:37 -0700 (Fri, 02 Nov 2012)
New Revision: 53671
grass-addons/grass7/gui/wxpython/wx.animation/animation/controller.py
grass-addons/grass7/gui/wxpython/wx.animation/animation/temporal_manager.py
wx.animation: sampling of point data enabled by temporal library
Modified: grass-addons/grass7/gui/wxpython/wx.animation/animation/controller.py
--- grass-addons/grass7/gui/wxpython/wx.animation/animation/controller.py 2012-11-02 20:21:51 UTC (rev 53670)
+++ grass-addons/grass7/gui/wxpython/wx.animation/animation/controller.py 2012-11-02 20:28:37 UTC (rev 53671)
@@ -413,7 +413,9 @@
if anim.inputMapType not in ('strds', 'stvds'):
continue
tempManager.AddTimeSeries(anim.inputData, anim.inputMapType)
- tempManager.EvaluateInputData()
+ message = tempManager.EvaluateInputData()
+ if message:
+ GMessage(parent = self.frame, message = message)
return temporalMode, tempManager
Modified: grass-addons/grass7/gui/wxpython/wx.animation/animation/temporal_manager.py
--- grass-addons/grass7/gui/wxpython/wx.animation/animation/temporal_manager.py 2012-11-02 20:21:51 UTC (rev 53670)
+++ grass-addons/grass7/gui/wxpython/wx.animation/animation/temporal_manager.py 2012-11-02 20:28:37 UTC (rev 53671)
@@ -5,7 +5,7 @@
Classes:
- temporal_manager::DataMode
- - temporal_manager::TemporalMapTime
+ - temporal_manager::GranularityMode
- temporal_manager::TemporalManager
@@ -33,10 +33,6 @@
SIMPLE = 1
MULTIPLE = 2
-class TemporalMapTime:
- POINT = 1
- INTERVAL = 2
class GranularityMode:
ONE_UNIT = 1
ORIGINAL = 2
@@ -50,7 +46,6 @@
self.dataMode = None
self.temporalType = None
- self.temporalMapTime = None
self.granularityMode = GranularityMode.ONE_UNIT
@@ -95,8 +90,13 @@
ret, message = self._setTemporalState()
if not ret:
raise GException(message)
+ if message: # warning
+ return message
+ return None
def _setTemporalState(self):
# check for absolute x relative
absolute, relative = 0, 0
@@ -130,12 +130,9 @@
else:
point += 1
if bool(interval) == bool(point):
- message = _("It is not allowed to display data with different temporal types of maps (interval and point).")
- return False, message
- if interval:
- self.temporalMapTime = TemporalMapTime.INTERVAL
- else:
- self.temporalMapTime = TemporalMapTime.POINT
+ message = _("You are going to display data with different temporal types of maps (interval and point)."
+ " It is recommended to use data of one temporal type to avoid confusion.")
+ return True, message # warning
return True, None
@@ -184,10 +181,7 @@
mapLists = []
labelLists = []
for dataset in self.timeseriesList:
- if self.temporalMapTime == TemporalMapTime.INTERVAL:
- grassLabels, listOfMaps = self._getLabelsAndMapsInterval(dataset)
- else:
- grassLabels, listOfMaps = self._getLabelsAndMapsPoint(dataset)
+ grassLabels, listOfMaps = self._getLabelsAndMaps(dataset)
mapLists.append(listOfMaps)
labelLists.append(grassLabels)
@@ -197,7 +191,8 @@
for mapList, labelList in zip(mapLists, labelLists):
newMapList = [None] * len(timestamps)
i = 0
- while timestamps[i] != labelList[0]:
+ # compare start time
+ while timestamps[i][0] != labelList[0][0]: # compare
i += 1
newMapList[i:i + len(mapList)] = mapList
newMapLists.append(newMapList)
@@ -208,12 +203,11 @@
return timestamps, mapDict
- def _getLabelsAndMapsInterval(self, timeseries):
+ def _getLabelsAndMaps(self, timeseries):
"""!Returns time labels and map names (done by sampling)
- for interval data.
+ for both interval and point data.
sp = tgis.dataset_factory(self.timeseriesInfo[timeseries]['etype'], timeseries)
- # sp = tgis.SpaceTimeRasterDataset(ident = timeseries)
if sp.is_in_db() == False:
raise GException(_("Space time dataset <%s> not found.") % timeseries)
sp.select()
@@ -231,76 +225,56 @@
unit = self.timeseriesInfo[timeseries]['unit']
if self.granularityMode == GranularityMode.ONE_UNIT:
gran = 1
+ # start sampling - now it can be used for both interval and point data
+ # after instance, there can be a gap or an interval
+ # if it is a gap we remove it and put there the previous instance instead
+ # however the first gap must be removed to avoid duplication
maps = sp.get_registered_maps_as_objects_by_granularity(gran = gran)
- if maps is not None:
- for map in maps:
- if len(map) > 0:
- timeseries = map[0].get_id()
- start, end = map[0].get_valid_time()
- listOfMaps.append(timeseries)
- if end:
- end = str(end)
- timeLabels.append((str(start), end, unit))
+ if maps and len(maps) > 0:
+ lastTimeseries = None
+ followsPoint = False # indicates that we are just after finding a point
+ afterPoint = False # indicates that we are after finding a point
+ for mymap in maps:
+ if isinstance(mymap, list):
+ if len(mymap) > 0:
+ map = mymap[0]
else:
- continue
+ map = mymap
- if self.temporalType == TemporalType.ABSOLUTE:
- timeLabels = self._pretifyTimeLabels(timeLabels)
+ series = map.get_id()
- return timeLabels, listOfMaps
+ start, end = map.get_valid_time()
+ if end:
+ end = str(end)
+ if end is None:
+ # point data
+ listOfMaps.append(series)
+ afterPoint = True
+ followsPoint = True
+ lastTimeseries = series
+ else:
+ # interval data
+ if series:
+ # map exists, stop point mode
+ else:
+ # check point mode
+ if afterPoint:
+ if followsPoint:
+ # skip this one, already there
+ continue
+ else:
+ # append the last one (of point time)
+ listOfMaps.append(lastTimeseries)
+ end = None
+ else:
+ # append series which is None
- def _getLabelsAndMapsPoint(self, timeseries):
- """!Returns time labels and map names (done by sampling)
- for point data.
+ timeLabels.append((str(start), end, unit))
- Simplified sampling is done manually because we cannot sample point data.
- sp = tgis.dataset_factory(self.timeseriesInfo[timeseries]['etype'], timeseries)
- if sp.is_in_db() == False:
- raise GException(_("Space time dataset <%s> not found.") % timeseries)
- sp.select()
- listOfMaps = []
- timeLabels = []
- gran = self.GetGranularity()
- unit = None
- if self.temporalType == TemporalType.ABSOLUTE and \
- self.granularityMode == GranularityMode.ONE_UNIT:
- gran, unit = gran.split()
- gran = '%(one)d %(unit)s' % {'one': 1, 'unit': unit}
- if self.temporalType == TemporalType.RELATIVE:
- unit = self.timeseriesInfo[timeseries]['unit']
- if self.granularityMode == GranularityMode.ONE_UNIT:
- gran = 1
- start, end = sp.get_valid_time()
- rows = sp.get_registered_maps(columns = "id,start_time", where = None, order = "start_time", dbif = None)
- if not rows:
- nextTime = start
- while nextTime <= end:
- timeLabels.append((str(nextTime), None, unit))
- found = False
- for row in rows:
- timeseries, start_time = row
- if start_time == nextTime:
- found = True
- break
- if not found:
- listOfMaps.append(timeseries) # here repeat last used map
- # listOfMaps.append(None)
- if sp.is_time_absolute():
- nextTime = tgis.increment_datetime_by_string(nextTime, gran)
- else:
- nextTime = nextTime + gran
@@ -365,27 +339,18 @@
from pprint import pprint
gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
temp = TemporalManager()
- timeseries1 = 'testRelInt1'
- timeseries2 = 'testRelInt2'
- createRelativeInterval(timeseries1, timeseries2)
+ timeseries1 = 'precip_abs0'
+ timeseries2 = 'precip_abs2'
+ createAbsoluteInterval(timeseries1, timeseries2)
- # timeseries = 'testAbsPoint'
- # createAbsolutePoint(timeseries)
temp.AddTimeSeries(timeseries1, 'strds')
temp.AddTimeSeries(timeseries2, 'strds')
- # try:
- # temp._gatherInformation(timeseries, info)
- # except GException, e:
- # print e
- # pprint(info)
try:
- temp.EvaluateInputData()
+ warn = temp.EvaluateInputData()
+ print warn
print e
return
@@ -394,15 +359,6 @@
gran = temp.GetGranularity()
print "granularity: " + str(gran)
pprint (temp.GetLabelsAndMaps())
- # maps = []
- # labels = []
- # try:
- # maps, labels = temp.GetLabelsAndMaps(timeseries)
- # print e
- # print maps
- # print labels
- # pprint(temp.timeseriesInfo['timeseries'])
@@ -516,11 +472,11 @@
fd = open(n1, 'w')
fd.write(
"prec_1|2001-01-01\n"
- "prec_2|2001-02-10\n"
- "prec_3|2001-07-01\n"
- "prec_4|2001-10-01\n"
- "prec_5|2002-01-01\n"
- "prec_6|2002-04-01\n"
+ "prec_2|2001-03-01\n"
+ "prec_3|2001-04-01\n"
+ "prec_4|2001-05-01\n"
+ "prec_5|2001-08-01\n"
+ "prec_6|2001-09-01\n"
fd.close()
grass.run_command('t.create', overwrite = True, type='strds',
