[GRASS-SVN] r53674 - grass/trunk/lib/python
svn_grass at osgeo.org
Sat Nov 3 07:48:33 PDT 2012
Author: glynn
Date: 2012-11-03 07:48:33 -0700 (Sat, 03 Nov 2012)
New Revision: 53674
grass/trunk/lib/python/core.py
Fix handling of debug_level (don't execute programs from top-level code)
Modified: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py 2012-11-03 11:30:34 UTC (rev 53673)
+++ grass/trunk/lib/python/core.py 2012-11-03 14:48:33 UTC (rev 53674)
@@ -66,7 +66,6 @@
return self.value
raise_on_error = False # raise exception instead of calling fatal()
-debug_level = 0 # DEBUG level
def call(*args, **kwargs):
return Popen(*args, **kwargs).wait()
@@ -167,9 +166,8 @@
args = make_command(prog, flags, overwrite, quiet, verbose, **options)
- global debug_level
- if debug_level > 0:
- sys.stderr.write("D1/%d: %s.start_command(): %s\n" % (debug_level, __name__, ' '.join(args)))
+ if debug_level() > 0:
+ sys.stderr.write("D1/%d: %s.start_command(): %s\n" % (debug_level(), __name__, ' '.join(args)))
sys.stderr.flush()
return Popen(args, **popts)
@@ -1338,5 +1336,13 @@
return data
# get debug_level
-if find_program('g.gisenv', ['--help']):
- debug_level = int(gisenv().get('DEBUG', 0))
+_debug_level = None
+def debug_level():
+ global _debug_level
+ if _debug_level is not None:
+ return _debug_level
+ if find_program('g.gisenv', ['--help']):
+ _debug_level = int(gisenv().get('DEBUG', 0))
+ else:
+ _debug_level = 0
